path: root/drivers/of
2011-08-04Revert "dt: add of_alias_scan and of_alias_get_id"Grant Likely
This reverts commit 750f463a749e28464151ad26938d11b07b1c43cb. of_alias_* still needs work to be generalized for 'promtree' dt platforms, and to no implicitly create entries for available ids. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-08-03dt: add of_alias_scan and of_alias_get_idShawn Guo
The patch adds function of_alias_scan to populate a global lookup table with the properties of 'aliases' node and function of_alias_get_id for drivers to find alias id from the lookup table. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> [grant.likely: add locking and rework parse loop] Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-08-02Merge branch 'devicetree/next' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'devicetree/next' of git://git.secretlab.ca/git/linux-2.6: MAINTAINERS: Add keyword match for of_match_table to device tree section of: constify property name parameters for helper functions input: xilinx_ps2: Add missing of_address.h header of: address: use resource_size helper
2011-08-02of: constify property name parameters for helper functionsJamie Iles
The helper functions for reading u32 integers, u32 arrays and strings should have the property name as a const pointer. Cc: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Jamie Iles <jamie@jamieiles.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-08-01Merge branch 'gpio/next' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'gpio/next' of git://git.secretlab.ca/git/linux-2.6: gpio_msm: Move Qualcomm MSM v2 gpio driver into drivers gpio_msm: Move Qualcomm v6 MSM driver into drivers msm: gpio: Fold register defs into C file msm: gpiomux: Move public API to public header msm: gpio: Remove ifdefs on gpio chip registers msm: gpio: Remove chip-specific register definitions msm: Remove chip-ifdefs for GPIO io mappings msm: gpio: Remove unsupported devices gpio: ab8500: fix MODULE_ALIAS for ab8500 of/gpio: export of_gpio_simple_xlate
2011-08-01of: address: use resource_size helperFelipe Balbi
that should be the approved way of calculating the size of resources. No functional changes. Cc: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-07-28of/gpio: export of_gpio_simple_xlateJamie Iles
Allow GPIO drivers to use of_gpio_simple_xlate. This is useful for the generic GPIO driver for example where gpio_chip is embedded in bgpio_chip and doesn't need of_mm_gpio_chip but has a simple 1:1 GPIO mapping. Cc: Anton Vorontsov <avorontsov@ru.mvista.com> Cc: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Jamie Iles <jamie@jamieiles.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-07-27net: ibm_newemac: convert it to use of_get_phy_modeShawn Guo
The patch extends 'enum phy_interface_t' and of_get_phy_mode a little bit with PHY_INTERFACE_MODE_NA and PHY_INTERFACE_MODE_SMII added, and then converts ibm_newemac net driver to use of_get_phy_mode getting phy mode from device tree. It also resolves the namespace conflict on phy_read/write between common mdiobus interface and ibm_newemac private one. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Cc: David S. Miller <davem@davemloft.net> Cc: Grant Likely <grant.likely@secretlab.ca> Acked-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: David Miller <davem@davemloft.net>
2011-07-27dt/net: add helper function of_get_phy_modeShawn Guo
It adds the helper function of_get_phy_mode getting phy interface from device tree. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Cc: Grant Likely <grant.likely@secretlab.ca> Acked-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: David Miller <davem@davemloft.net>
2011-07-25Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: (99 commits) drivers/virt: add missing linux/interrupt.h to fsl_hypervisor.c powerpc/85xx: fix mpic configuration in CAMP mode powerpc: Copy back TIF flags on return from softirq stack powerpc/64: Make server perfmon only built on ppc64 server devices powerpc/pseries: Fix hvc_vio.c build due to recent changes powerpc: Exporting boot_cpuid_phys powerpc: Add CFAR to oops output hvc_console: Add kdb support powerpc/pseries: Fix hvterm_raw_get_chars to accept < 16 chars, fixing xmon powerpc/irq: Quieten irq mapping printks powerpc: Enable lockup and hung task detectors in pseries and ppc64 defeconfigs powerpc: Add mpt2sas driver to pseries and ppc64 defconfig powerpc: Disable IRQs off tracer in ppc64 defconfig powerpc: Sync pseries and ppc64 defconfigs powerpc/pseries/hvconsole: Fix dropped console output hvc_console: Improve tty/console put_chars handling powerpc/kdump: Fix timeout in crash_kexec_wait_realmode powerpc/mm: Fix output of total_ram. powerpc/cpufreq: Add cpufreq driver for Momentum Maple boards powerpc: Correct annotations of pmu registration functions ... Fix up trivial Kconfig/Makefile conflicts in arch/powerpc, drivers, and drivers/cpufreq
2011-07-23of: fix missing include from of_pci.cGrant Likely
of_pci.c references symbols from linux/of.h. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-07-22Merge branch 'of-pci' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'of-pci' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: pci/of: Consolidate pci_bus_to_OF_node() pci/of: Consolidate pci_device_to_OF_node() x86/devicetree: Use generic PCI <-> OF matching microblaze/pci: Move the remains of pci_32.c to pci-common.c microblaze/pci: Remove powermac originated cruft pci/of: Match PCI devices to OF nodes dynamically
2011-07-22Merge branch 'devicetree/next' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'devicetree/next' of git://git.secretlab.ca/git/linux-2.6: dt: include linux/errno.h in linux/of_address.h of/address: Add of_find_matching_node_by_address helper dt: remove extra xsysace platform_driver registration tty/serial: Add devicetree support for nVidia Tegra serial ports dt: add empty of_property_read_u32[_array] for non-dt dt: bindings: move SEC node under new crypto/ dt: add helper function to read u32 arrays tty/serial: change of_serial to use new of_property_read_u32() api dt: add 'const' for of_property_read_string parameter **out_string dt: add helper functions to read u32 and string property values tty: of_serial: support for 32 bit accesses dt: document the of_serial bindings dt/platform: allow device name to be overridden drivers/amba: create devices from device tree dt: add of_platform_populate() for creating device from the device tree dt: Add default match table for bus ids
2011-07-18of/address: Add of_find_matching_node_by_address helperGrant Likely
of_find_matching_node_by_address() can be used to find a device tree node for a device at a specific address. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-07-08powerpc: implement arch_setup_pdev_archdataKumar Gala
We have a long standing issues with platform devices not have a valid dma_mask pointer. This hasn't been an issue to date as no platform device has tried to set its dma_mask value to a non-default value. Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-07-06dt: add helper function to read u32 arraysRob Herring
Rework of_property_read_u32 to read an array of values. Then of_property_read_u32 becomes an inline with array size of 1. Also make struct device_node ptr const. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-07-03dt: add 'const' for of_property_read_string parameter **out_stringShawn Guo
The existing dt codes usually call of_get_property to get a string property and save it as a 'const char *'. The patch adds'const' for of_property_read_string parameter **out_string to make the converting of existing code a little easier. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-06-30dt: add helper functions to read u32 and string property valuesThomas Abraham
Add helper functions to retrieve unsigned integer and string property values from properties of a device node. These helper functions can be used to lookup a property in a device node, perform error checking and read the property value. [grant.likely@secretlab.ca: Proposal and initial implementation] Signed-off-by: Thomas Abraham <thomas.abraham@linaro.org> [grant.likely: some word smithing and be more defensive validating the string] Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-06-28of/gpio: Add new method for getting gpios under different property namesJohn Bonesio
This patch adds a new routine, of_get_named_gpio_flags(), which takes the property name as a parameter rather than assuming "gpios". of_get_gpio_flags() is modified to call of_get_named_gpio_flags() with "gpios" as the property parameter. Signed-off-by: John Bonesio <bones@secretlab.ca> [grant.likely: Tidied up whitespace and tweaked kerneldoc comments.] Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-06-21dt/platform: allow device name to be overriddenGrant Likely
Some platform code has specific requirements on the naming of devices. This patch allows callers of of_platform_populate() to provide a device name lookup table. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-06-21drivers/amba: create devices from device treeGrant Likely
Add a function to create amba_devices (i.e. primecell peripherals) from device tree nodes. The device tree scanning is done by the of_platform_populate() function which can call of_amba_device_create based on a match table entry. Nodes with a "arm,primecell-periphid" property can override the h/w peripheral id value. Based on the original work by Jeremy Kerr. Signed-off-by: Jeremy Kerr <jeremy.kerr@canonical.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Rob Herring <rob.herring@calxeda.com> Reviewed-by: Arnd Bergmann <arnd@arndb.de> [grant.likely: add Jeremy's original s-o-b line, changes from review comments, and moved all code to drivers/of/platform.c] Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-06-21dt: add of_platform_populate() for creating device from the device treeGrant Likely
of_platform_populate() is similar to of_platform_bus_probe() except that it strictly enforces that all device nodes must have a compatible property, and it can be used to register devices (not buses) which are children of the root node. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-06-21dt: Add default match table for bus idsGrant Likely
No need for most platforms to define their own bus table when calling of_platform_populate(). Supply a stock one. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-06-08pci/of: Match PCI devices to OF nodes dynamicallyBenjamin Herrenschmidt
powerpc has two different ways of matching PCI devices to their corresponding OF node (if any) for historical reasons. The ppc64 one does a scan looking for matching bus/dev/fn, while the ppc32 one does a scan looking only for matching dev/fn on each level in order to be agnostic to busses being renumbered (which Linux does on some platforms). This removes both and instead moves the matching code to the PCI core itself. It's the most logical place to do it: when a pci_dev is created, we know the parent and thus can do a single level scan for the matching device_node (if any). The benefit is that all archs now get the matching for free. There's one hook the arch might want to provide to match a PHB bus to its device node. A default weak implementation is provided that looks for the parent device device node, but it's not entirely reliable on powerpc for various reasons so powerpc provides its own. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Michal Simek <monstr@monstr.eu> Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-05-25Merge branch 'devicetree/arm-next' of git://git.secretlab.ca/git/linux-2.6 ↵Russell King
into devel-stable
2011-05-11dt/flattree: explicitly pass command line pointer to early_init_dt_scan_chosenGrant Likely
This patch drops the reference to a global 'cmd_line' variable from early_init_dt_scan_chosen, and instead passes the pointer to the command line string via the *data argument. Each architecture does something slightly different with the initial command line, so it makes sense for the architecture to be able to specify the variable name. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-04-20of: Export of_irq_find_parent()Michael Ellerman
We have platform code that needs to find a node's interrupt parent, so export of_irq_find_parent() so we can use it. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-03-23of/flattree: minor cleanupsAndres Salomon
- static-ize some functions - add some additional comments Signed-off-by: Andres Salomon <dilinger@queued.net> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-03-23dt: eliminate OF_NO_DEEP_PROBE and test for NULL match tableGrant Likely
There are no users of OF_NO_DEEP_PROBE, and of_match_node() now gracefully handles being passed a NULL pointer, so the checks at the top of of_platform_bus_probe can be dropped. While at it, consolidate the root node pointer check to be easier to read and tidy up related comments. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-03-23dt: protect against NULL matches passed to of_match_node()Grant Likely
There are a few use cases where it is convenient to pass NULL to of_match_node() and have it fail gracefully. The patch adds a null check to the beginning so taht it does so. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-03-23dt: Refactor of_platform_bus_probe()Grant Likely
The current implementation uses three copies of of basically identical code. This patch consolidates them to make the code simpler. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-03-16Merge branch 'devicetree/next' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'devicetree/next' of git://git.secretlab.ca/git/linux-2.6: (21 commits) tty: serial: altera_jtaguart: Add device tree support tty: serial: altera_uart: Add devicetree support dt: eliminate of_platform_driver shim code dt: Eliminate of_platform_{,un}register_driver dt/serial: Eliminate users of of_platform_{,un}register_driver dt/usb: Eliminate users of of_platform_{,un}register_driver dt/video: Eliminate users of of_platform_{,un}register_driver dt/net: Eliminate users of of_platform_{,un}register_driver dt/sound: Eliminate users of of_platform_{,un}register_driver dt/spi: Eliminate users of of_platform_{,un}register_driver dt: uartlite: merge platform and of_platform driver bindings dt: xilinx_hwicap: merge platform and of_platform driver bindings ipmi: convert OF driver to platform driver leds/leds-gpio: merge platform_driver with of_platform_driver dt/sparc: Eliminate users of of_platform_{,un}register_driver dt/powerpc: Eliminate users of of_platform_{,un}register_driver dt/powerpc: move of_bus_type infrastructure to ibmebus drivercore/dt: add a match table pointer to struct device dt: Typo fix. altera_ps2: Add devicetree support ...
2011-03-15Merge branch 'x86-platform-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-platform-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (27 commits) x86: Clean up apic.c and apic.h x86: Remove superflous goal definition of tsc_sync x86: dt: Correct local apic documentation in device tree bindings x86: dt: Cleanup local apic setup x86: dt: Fix OLPC=y/INTEL_CE=n build rtc: cmos: Add OF bindings x86: ce4100: Use OF to setup devices x86: ioapic: Add OF bindings for IO_APIC x86: dtb: Add generic bus probe x86: dtb: Add support for PCI devices backed by dtb nodes x86: dtb: Add device tree support for HPET x86: dtb: Add early parsing of IO_APIC x86: dtb: Add irq domain abstraction x86: dtb: Add a device tree for CE4100 x86: Add device tree support x86: e820: Remove conditional early mapping in parse_e820_ext x86: OLPC: Make OLPC=n build again x86: OLPC: Remove extra OLPC_OPENFIRMWARE_DT indirection x86: OLPC: Cleanup config maze completely x86: OLPC: Hide OLPC_OPENFIRMWARE config switch ... Fix up conflicts in arch/x86/platform/ce4100/ce4100.c
2011-03-02of/promtree: allow DT device matching by fixing 'name' brokenness (v5)Andres Salomon
Commit e2f2a93b, "of/promtree: add package-to-path support to pdt" changed dp->name from using the 'name' property to using package-to-path. This fixed /proc/device-tree creation by eliminating conflicts between names (the 'name' property provides names like 'battery', whereas package-to-path provides names like '/foo/bar/battery@0', which we stripped to 'battery@0'). However, it also breaks of_device_id table matching. The fix that we _really_ wanted was to keep dp->name based upon the name property ('battery'), but based dp->full_name upon package-to-path ('battery@0'). This patch does just that. This changes all users (except SPARC) of promtree to use the full result from package-to-path for full_name, rather than stripping the directory out. In practice, the strings end up being exactly the same; this change saves time, code, and memory. SPARC continues to use the existing build_path_component() code. v2: combine two patches and revert of_pdt_node_name to original version v3: use dp->phandle instead of passing around node v4: warn/bail out for non-sparc archs if pkg2path is not set v5: split of_pdt_build_full_name into sparc & non-sparc versions v6: Pass NULL to pkg2path before buf gets assigned. Drop check for pkg2path hook on each and every node. v7: Don't BUG() when unable to get the full_path; create a known-unique name instead. Signed-off-by: Andres Salomon <dilinger@queued.net> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-03-01dt: eliminate of_platform_driver shim codeGrant Likely
Commit eca393016, "of: Merge of_platform_bus_type with platform_bus_type" added a shim to allow of_platform_drivers to get registers onto the platform bus so that there was time to migrate the existing drivers to the platform_bus_type. This patch removes the shim since there are no more users of the old interface. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-02-28dt/powerpc: move of_bus_type infrastructure to ibmebusGrant Likely
arch/powerpc/kernel/ibmebus.c is the only remaining user of the of_bus_type support code for initializing the bus and registering drivers. All others have either been switched to the vanilla platform bus or already have their own infrastructure. This patch moves the functionality that ibmebus is using out of drivers/of/{platform,device}.c and into ibmebus.c where it is actually used. Also renames the moved symbols from of_platform_* to ibmebus_bus_* to reflect the actual usage. This patch is part of moving all of the of_platform_bus_type users over to the platform_bus_type. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-02-23x86: dtb: Add support for PCI devices backed by dtb nodesSebastian Andrzej Siewior
x86_of_pci_init() does two things: - it provides a generic irq enable and disable function. enable queries the device tree for the interrupt information, calls ->xlate on the irq host and updates the pci->irq information for the device. - it walks through PCI bus(es) in the device tree and adds its children (device) nodes to appropriate pci_dev nodes in kernel. So the dtb node information is available at probe time of the PCI device. Adding a PCI bus based on the information in the device tree is currently not supported. Right now direct access via ioports is used. Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Tested-by: Dirk Brandewie <dirk.brandewie@gmail.com> Acked-by: Grant Likely <grant.likely@secretlab.ca> Cc: sodaville@linutronix.de Cc: devicetree-discuss@lists.ozlabs.org LKML-Reference: <1298405266-1624-8-git-send-email-bigeasy@linutronix.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2011-02-04of/pci: move of_irq_map_pci() into generic codeSebastian Andrzej Siewior
There is a tiny difference between PPC32 and PPC64. Microblaze uses the PPC32 variant. Signed-off-by: Sebastian Andrzej Siewior <sebastian@breakpoint.cc> [grant.likely@secretlab.ca: Added comment to #endif, moved documentation block to function implementation, fixed for non ppc and microblaze compiles] Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-01-15dt/flattree: Return virtual address from early_init_dt_alloc_memory_arch()Grant Likely
The physical address is never used by the device tree code when allocating memory for unflattening. Change the architecture's alloc hook to return the virutal address instead. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-01-10Merge branch 'next-devicetree' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'next-devicetree' of git://git.secretlab.ca/git/linux-2.6: (29 commits) of/flattree: forward declare struct device_node in of_fdt.h ipmi: explicitly include of_address.h and of_irq.h sparc: explicitly cast negative phandle checks to s32 powerpc/405: Fix missing #{address,size}-cells in i2c node powerpc/5200: dts: refactor dts files powerpc/5200: dts: Change combatible strings on localbus powerpc/5200: dts: remove unused properties powerpc/5200: dts: rename nodes to prepare for refactoring dts files of/flattree: Update dtc to current mainline. of/device: Don't register disabled devices powerpc/dts: fix syntax bugs in bluestone.dts of: Fixes for OF probing on little endian systems of: make drivers depend on CONFIG_OF instead of CONFIG_PPC_OF of/flattree: Add of_flat_dt_match() helper function of_serial: explicitly include of_irq.h of/flattree: Refactor unflatten_device_tree and add fdt_unflatten_tree of/flattree: Reorder unflatten_dt_node of/flattree: Refactor unflatten_dt_node of/flattree: Add non-boottime device tree functions of/flattree: Add Kconfig for EARLY_FLATTREE ... Fix up trivial conflict in arch/sparc/prom/tree_32.c as per Grant.
2011-01-03of/device: Don't register disabled devicesGrant Likely
Device nodes with the property status="disabled" are not usable and so don't register them when parsing the device tree for devices. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Cc: Hollis Blanchard <hollis_blanchard@mentor.com> Cc: Deepak Saxena <deepak_saxena@mentor.com> Cc: Scott Wood <scottwood@freescale.com>, Cc: David Gibson <david@gibson.dropbear.id.au> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-01-01of/flattree: Add of_flat_dt_match() helper functionGrant Likely
This patch adds of_flat_dt_match() which tests a node for compatibility with a list of values and converts the relevant powerpc platform code to use it. This approach simplifies the board support code a bit. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Reviewed-by: Stephen Neuendorffer <stephen.neuendorffer@xilinx.com>
2010-12-29of/flattree: Refactor unflatten_device_tree and add fdt_unflatten_treeStephen Neuendorffer
unflatten_device_tree has two dependencies on things that happen during boot time. Firstly, it references the initial device tree directly. Secondly, it allocates memory using the early boot allocator. This patch factors out these dependencies and uses the new __unflatten_device_tree function to implement a driver-visible fdt_unflatten_tree function, which can be used to unflatten a blob after boot time. V2: - remove extra __va() call - make dt_alloc functions return void *. This doesn't fix the general strangeness in this code that constantly casts back and forth between unsigned long and __be32 * Signed-off-by: Stephen Neuendorffer <stephen.neuendorffer@xilinx.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-12-29of/flattree: Reorder unflatten_dt_nodeStephen Neuendorffer
Move unflatten_dt_node to be grouped with non-__init functions. Signed-off-by: Stephen Neuendorffer <stephen.neuendorffer@xilinx.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-12-29of/flattree: Refactor unflatten_dt_nodeStephen Neuendorffer
unflatten_dt_node is a helper function that does most of the work to convert a device tree blob into tree of device nodes. This code now uses a passed-in blob instead of using the single boot-time blob, allowing it to be called in more contexts. Signed-off-by: Stephen Neuendorffer <stephen.neuendorffer@xilinx.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-12-29of/flattree: Add non-boottime device tree functionsStephen Neuendorffer
In preparation for providing run-time handling of device trees, factor out some of the basic functions so that they take an arbitrary blob, rather than relying on the single boot-time tree. V2: - functions have of_fdt_* names - removed find_flat_dt_string - blob argument is first Signed-off-by: Stephen Neuendorffer <stephen.neuendorffer@xilinx.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-12-29of/flattree: Add Kconfig for EARLY_FLATTREEStephen Neuendorffer
The device tree code is now in two pieces: some which can be used generically on any platform which selects CONFIG_OF_FLATTREE, and some early which is used at boot time on only a few architectures. This patch segregates the early code so that only those architectures which care about it need compile it. This also means that some of the requirements in the early code (such as a cmd_line variable) that most architectures (e.g. X86) don't provide can be ignored. Signed-off-by: Stephen Neuendorffer <stephen.neuendorffer@xilinx.com> [grant.likely@secretlab.ca: remove extra blank line addition] [grant.likely@secretlab.ca: fixed incorrect #ifdef CONFIG_EARLY_FLATTREE check] [grant.likely@secretlab.ca: Made OF_EARLY_FLATTREE select instead of depend on OF_FLATTREE] Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-12-24of/i2c: Fix request module by aliasDavid Daney
If we are registering an i2c device that has a device tree node like this real-world example: rtc@68 { compatible = "dallas,ds1337"; reg = <0x68>; }; of_i2c_register_devices() will try to load a module called ds1337.ko. There is no such module, so it will fail. If we look in modules.alias we will find entries like these: . . . alias i2c:ds1339 rtc_ds1307 alias i2c:ds1338 rtc_ds1307 alias i2c:ds1337 rtc_ds1307 alias i2c:ds1307 rtc_ds1307 alias i2c:ds1374 rtc_ds1374 . . . The module we want is really called rtc_ds1307.ko. If we request a module called "i2c:ds1337", the userspace module loader will do the right thing (unless it is busybox) and load rtc_ds1307.ko. So we add the I2C_MODULE_PREFIX to the request_module() string. Signed-off-by: David Daney <ddaney@caviumnetworks.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-12-24of/mdio: Fix some endianness problems.David Daney
In of_mdiobus_register(), the __be32 *addr variable is dereferenced. This will not work on little-endian targets. Also since it is unsigned, checking for less than zero is redundant. Fix these two issues. Signed-off-by: David Daney <ddaney@caviumnetworks.com> [grant.likely@secretlab.ca: removed goto] Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
