commit b6cc9474e2dd9f0c19b694b40961d81117f1e918 upstream.
On arm64 NUMA kernels we can pass "numa=off" on the command line to
disable NUMA. A side effect of this is that kmalloc_node() calls to
non-zero nodes will crash the system with an OOPS:
[ 0.000000] ITS@0x0000901000020000: allocated 2097152 Devices @10002000000 (flat, esz 8, psz 64K, shr 1)
[ 0.000000] Unable to handle kernel NULL pointer dereference at virtual address 00001680
[ 0.000000] pgd = fffffc0009470000
[ 0.000000] [00001680] *pgd=0000010ffff90003, *pud=0000010ffff90003, *pmd=0000010ffff90003, *pte=0000000000000000
[ 0.000000] Internal error: Oops: 96000006 [#1] SMP
[ 0.000000] [<fffffc00081c8950>] __alloc_pages_nodemask+0xa4/0xe68
[ 0.000000] [<fffffc000821fa70>] new_slab+0xd0/0x564
[ 0.000000] [<fffffc0008221e24>] ___slab_alloc+0x2e4/0x514
[ 0.000000] [<fffffc0008239498>] __slab_alloc+0x48/0x58
[ 0.000000] [<fffffc0008222c20>] __kmalloc_node+0xd0/0x2dc
[ 0.000000] [<fffffc0008115374>] __irq_domain_add+0x7c/0x164
[ 0.000000] [<fffffc0008b461dc>] its_probe+0x784/0x81c
[ 0.000000] [<fffffc0008b462bc>] its_init+0x48/0x1b0
[ 0.000000] [<fffffc0008b4543c>] gic_init_bases+0x228/0x360
[ 0.000000] [<fffffc0008b456bc>] gic_of_init+0x148/0x1cc
[ 0.000000] [<fffffc0008b5aec8>] of_irq_init+0x184/0x298
[ 0.000000] [<fffffc0008b43f9c>] irqchip_init+0x14/0x38
[ 0.000000] [<fffffc0008b12d60>] init_IRQ+0xc/0x30
[ 0.000000] [<fffffc0008b10a3c>] start_kernel+0x240/0x3b8
[ 0.000000] [<fffffc0008b101c4>] __primary_switched+0x30/0x6c
[ 0.000000] Code: 912ec2a0 b9403809 0a0902fb 37b007db (f9400300)
This is caused by code like this in kernel/irq/irqdomain.c
domain = kzalloc_node(sizeof(*domain) + (sizeof(unsigned int) * size),
GFP_KERNEL, of_node_to_nid(of_node));
When NUMA is disabled, the concept of a node is really undefined, so
of_node_to_nid() should unconditionally return NUMA_NO_NODE.
Fix by returning NUMA_NO_NODE when the nid is not in the set of
possible nodes.
Reported-by: Gilbert Netzer <noname@pdc.kth.se>
Signed-off-by: David Daney <david.daney@cavium.com>
Signed-off-by: Rob Herring <robh@kernel.org>
Add helper to deregister fixed-link PHYs registered using
of_phy_register_fixed_link().
Convert the two drivers that care to deregister their fixed-link PHYs to
use the new helper, but note that most drivers currently fail to do so.
Signed-off-by: Johan Hovold <johan@kernel.org>
Make sure to drop the reference taken by bus_find_device() before
returning NULL from of_phy_find_device() when the found device is not a
PHY.
Fixes: 6ed742363b9c ("of: of_mdio: Ensure mdio device is a PHY")
Make sure to drop the of_node reference also on failure to parse the
speed property in of_phy_register_fixed_link().
Fixes: 3be2a49e5c08 ("of: provide a binding for fixed link PHYs")
This reverts commit 05fd007e4629 ("console: don't prefer first
registered if DT specifies stdout-path").
The reverted commit changes existing behavior on which many ARM boards
rely. Many ARM small-board-computers, like e.g. the Raspberry Pi have
both a video output and a serial console. Depending on whether the user
is using the device as a more regular computer; or as a headless device
we need to have the console on either one or the other.
Many users rely on the kernel behavior of the console being present on
both outputs, before the reverted commit the console setup with no
console= kernel arguments on an ARM board which sets stdout-path in dt
would look like this:
[root@localhost ~]# cat /proc/consoles
ttyS0 -W- (EC p a) 4:64
tty0 -WU (E p ) 4:1
Where as after the reverted commit, it looks like this:
This commit reverts commit 05fd007e4629 ("console: don't prefer first
registered if DT specifies stdout-path") restoring the original
behavior.
Fixes: 05fd007e4629 ("console: don't prefer first registered if DT specifies stdout-path")
Link: http://lkml.kernel.org/r/20161104121135.4780-2-hdegoede@redhat.com
Cc: Paul Burton <paul.burton@imgtec.com>
Cc: Rob Herring <robh+dt@kernel.org>
Cc: Frank Rowand <frowand.list@gmail.com>
Cc: Thorsten Leemhuis <regressions@leemhuis.info>
Cc: Tejun Heo <tj@kernel.org>
Cc: <stable@vger.kernel.org>
Pull MIPS updates from Ralf Baechle:
"This is the main MIPS pull request for 4.9:
MIPS core arch code:
- traps: 64bit kernels should read CP0_EBase 64bit
- traps: Convert ebase to KSEG0
- c-r4k: Drop bc_wback_inv() from icache flush
- c-r4k: Split user/kernel flush_icache_range()
- cacheflush: Use __flush_icache_user_range()
- uprobes: Flush icache via kernel address
- KVM: Use __local_flush_icache_user_range()
- c-r4k: Fix flush_icache_range() for EVA
- Fix -mabi=64 build of vdso.lds
- VDSO: Drop duplicated -I*/-E* aflags
- tracing: move insn_has_delay_slot to a shared header
- tracing: disable uprobe/kprobe on compact branch instructions
- ptrace: Fix regs_return_value for kernel context
- Squash lines for simple wrapper functions
- Move identification of VP(E) into proc.c from smp-mt.c
- Add definitions of SYNC barrierstype values
- traps: Ensure full EBase is written
- tlb-r4k: If there are wired entries, don't use TLBINVF
- Sanitise coherentio semantics
- dma-default: Don't check hw_coherentio if device is non-coherent
- Support per-device DMA coherence
- Adjust MIPS64 CAC_BASE to reflect Config.K0
- Support generating Flattened Image Trees (.itb)
- generic: Introduce generic DT-based board support
- generic: Convert SEAD-3 to a generic board
- Enable hardened usercopy
- Don't specify STACKPROTECTOR in defconfigs
Octeon:
- Delete dead code and files across the platform.
- Change to use all memory into use by default.
- Rename upper case variables in setup code to lowercase.
- Delete legacy hack for broken bootloaders.
- Leave maintaining the link state to the actual ethernet/PHY drivers.
- Add DTS for D-Link DSR-500N.
- Fix PCI interrupt routing on D-Link DSR-500N.
Pistachio:
- Remove ANDROID_TIMED_OUTPUT from defconfig
TX39xx:
- Move GPIO setup from .mem_setup() to .arch_init()
- Convert to Common Clock Framework
TX49xx:
txx9wdt:
- Add missing clock (un)prepare calls for CCF
BMIPS:
- Add PW, GPIO SDHCI and NAND device node names
- Support APPENDED_DTB
- Add missing bcm97435svmb to DT_NONE
- Rename bcm96358nb4ser to bcm6358-neufbox4-sercom
- Add DT examples for BCM63268, BCM3368 and BCM6362
- Add support for BCM3368 and BCM6362
PCI
- Reduce stack frame usage
- Use struct list_head lists
- Support for CONFIG_PCI_DOMAINS_GENERIC
- Make pcibios_set_cache_line_size an initcall
- Inline pcibios_assign_all_busses
- Split pci.c into pci.c & pci-legacy.c
- Introduce CONFIG_PCI_DRIVERS_LEGACY
- Support generic drivers
CPC
- Convert bare 'unsigned' to 'unsigned int'
- Avoid lock when MIPS CM >= 3 is present
GIC:
- Delete unused file smp-gic.c
mt7620:
- Delete unnecessary assignment for the field "owner" from PCI
BCM63xx:
- Let clk_disable() return immediately if clk is NULL
pm-cps:
- Change FSB workaround to CPU blacklist
- Update comments on barrier instructions
- Use MIPS standard lightweight ordering barrier
- Use MIPS standard completion barrier
- Remove selection of sync types
- Add MIPSr6 CPU support
- Support CM3 changes to Coherence Enable Register
SMP:
- Wrap call to mips_cpc_lock_other in mips_cm_lock_other
- Introduce mechanism for freeing and allocating IPIs
cpuidle:
- cpuidle-cps: Enable use with MIPSr6 CPUs.
SEAD3:
- Rewrite to use DT and generic kernel feature.
USB:
- host: ehci-sead3: Remove SEAD-3 EHCI code
FBDEV:
- cobalt_lcdfb: Drop SEAD3 support
dt-bindings:
- Document a binding for simple ASCII LCDs
auxdisplay:
- img-ascii-lcd: driver for simple ASCII LCD displays
irqchip i8259:
- i8259: Add domain before mapping parent irq
- i8259: Allow platforms to override poll function
- i8259: Remove unused i8259A_irq_pending
Malta:
- Rewrite to use DT
of/platform:
- Probe "isa" busses by default
CM:
- Print CM error reports upon bus errors
Module:
- Migrate exception table users off module.h and onto extable.h
- Make various drivers explicitly non-modular:
- Audit and remove any unnecessary uses of module.h
mailmap:
- Canonicalize to Qais' current email address.
Documentation:
- MIPS supports HAVE_REGS_AND_STACK_ACCESS_API
Loongson1C:
- Add CPU support for Loongson1C
- Add board support
- Add defconfig
- Add RTC support for Loongson1C board
All this except one Documentation fix has sat in linux-next and has
survived Imagination's automated build test system"
* 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (127 commits)
Documentation: MIPS supports HAVE_REGS_AND_STACK_ACCESS_API
MIPS: ptrace: Fix regs_return_value for kernel context
MIPS: VDSO: Drop duplicated -I*/-E* aflags
MIPS: Fix -mabi=64 build of vdso.lds
MIPS: Enable hardened usercopy
MIPS: generic: Convert SEAD-3 to a generic board
MIPS: generic: Introduce generic DT-based board support
MIPS: Support generating Flattened Image Trees (.itb)
MIPS: Adjust MIPS64 CAC_BASE to reflect Config.K0
MIPS: Print CM error reports upon bus errors
MIPS: Support per-device DMA coherence
MIPS: dma-default: Don't check hw_coherentio if device is non-coherent
MIPS: Sanitise coherentio semantics
MIPS: PCI: Support generic drivers
MIPS: PCI: Introduce CONFIG_PCI_DRIVERS_LEGACY
MIPS: PCI: Split pci.c into pci.c & pci-legacy.c
MIPS: PCI: Inline pcibios_assign_all_busses
MIPS: PCI: Make pcibios_set_cache_line_size an initcall
MIPS: PCI: Support for CONFIG_PCI_DOMAINS_GENERIC
MIPS: PCI: Use struct list_head lists
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu
Pull IOMMU updates from Joerg Roedel:
- support for interrupt virtualization in the AMD IOMMU driver. These
patches were shared with the KVM tree and are already merged through
that tree.
- generic DT-binding support for the ARM-SMMU driver. With this the
driver now makes use of the generic DMA-API code. This also required
some changes outside of the IOMMU code, but these are acked by the
respective maintainers.
- more cleanups and fixes all over the place.
* tag 'iommu-updates-v4.9' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu: (40 commits)
iommu/amd: No need to wait iommu completion if no dte irq entry change
iommu/amd: Free domain id when free a domain of struct dma_ops_domain
iommu/amd: Use standard bitmap operation to set bitmap
iommu/amd: Clean up the cmpxchg64 invocation
iommu/io-pgtable-arm: Check for v7s-incapable systems
iommu/dma: Avoid PCI host bridge windows
iommu/dma: Add support for mapping MSIs
iommu/arm-smmu: Set domain geometry
iommu/arm-smmu: Wire up generic configuration support
Docs: dt: document ARM SMMU generic binding usage
iommu/arm-smmu: Convert to iommu_fwspec
iommu/arm-smmu: Intelligent SMR allocation
iommu/arm-smmu: Add a stream map entry iterator
iommu/arm-smmu: Streamline SMMU data lookups
iommu/arm-smmu: Refactor mmu-masters handling
iommu/arm-smmu: Keep track of S2CR state
iommu/arm-smmu: Consolidate stream map entry state
iommu/arm-smmu: Handle stream IDs more dynamically
iommu/arm-smmu: Set PRIVCFG in stage 1 STEs
iommu/arm-smmu: Support non-PCI devices with SMMUv3
Pull MTD updates from Brian Norris:
"I've not been very active this cycle, so these are mostly from Boris,
for the NAND flash subsystem.
NAND:
- Add the infrastructure to automate NAND timings configuration
- Provide a generic DT property to maximize ECC strength
- Some refactoring in the core bad block table handling, to help with
improving some of the logic in error cases.
- Minor cleanups and fixes
MTD:
- Add APIs for handling page pairing; this is necessary for reliably
supporting MLC and TLC NAND flash, where paired-page disturbance
affects reliability. Upper layers (e.g., UBI) should make use of
these in the near future"
* tag 'for-linus-20161008' of git://git.infradead.org/linux-mtd: (35 commits)
mtd: nand: fix trivial spelling error
mtdpart: Propagate _get/put_device()
mtd: nand: Provide nand_cleanup() function to free NAND related resources
mtd: Kill the OF_MTD Kconfig option
mtd: nand: mxc: Test CONFIG_OF instead of CONFIG_OF_MTD
mtd: nand: Fix nand_command_lp() for 8bits opcodes
mtd: nand: sunxi: Support ECC maximization
mtd: nand: Support maximizing ECC when using software BCH
mtd: nand: Add an option to maximize the ECC strength
mtd: nand: mxc: Add timing setup for v2 controllers
mtd: nand: mxc: implement onfi get/set features
mtd: nand: sunxi: switch from manual to automated timing config
mtd: nand: automate NAND timings selection
mtd: nand: Expose data interface for ONFI mode 0
mtd: nand: Add function to convert ONFI mode to data_interface
mtd: nand: convert ONFI mode into data interface
mtd: nand: Introduce nand_data_interface
mtd: nand: Create a NAND reset function
mtd: nand: remove unnecessary 'extern' from function declarations
MAINTAINERS: Add maintainer entry for Ingenic JZ4780 NAND driver
If a device tree specifies a preferred device for kernel console output
via the stdout-path or linux,stdout-path chosen node properties or the
stdout alias then the kernel ought to honor it & output the kernel
console to that device. As it stands, this isn't the case. Whilst we
parse the stdout-path properties & set an of_stdout variable from
of_alias_scan(), and use that from of_console_check() to determine
whether to add a console device as a preferred console whilst
registering it, we also prefer the first registered console if no other
has been selected at the time of its registration.
This means that if a console other than the one the device tree selects
via stdout-path is registered first, we will switch to using it & when
the stdout-path console is later registered the call to
add_preferred_console() via of_console_check() is too late to do
anything useful. In practice this seems to mean that we switch to the
dummy console device fairly early & see no further console output:
Console: colour dummy device 80x25
console [tty0] enabled
bootconsole [ns16550a0] disabled
Fix this by not automatically preferring the first registered console if
one is specified by the device tree. This allows consoles to be
registered but not enabled, and once the driver for the console selected
by stdout-path calls of_console_check() the driver will be added to the
list of preferred consoles before any other console has been enabled.
When that console is then registered via register_console() it will be
enabled as expected.
Link: http://lkml.kernel.org/r/20160809151937.26118-1-paul.burton@imgtec.com
Signed-off-by: Paul Burton <paul.burton@imgtec.com>
Cc: Sergey Senozhatsky <sergey.senozhatsky@gmail.com>
Cc: Jiri Slaby <jslaby@suse.cz>
Cc: Daniel Vetter <daniel.vetter@ffwll.ch>
Cc: Ivan Delalande <colona@arista.com>
Cc: Thierry Reding <treding@nvidia.com>
Cc: Borislav Petkov <bp@suse.de>
Cc: Jan Kara <jack@suse.com>
Cc: Petr Mladek <pmladek@suse.com>
Cc: Joe Perches <joe@perches.com>
Since commit 44a7185c2ae6 ("of/platform: Add common method to populate
default bus") platforms calling of_platform_bus_probe from an initcall
is either a rather unsafe race with of_platform_default_populate_init or
a no-op. The MIPS Malta board needs to probe devices under an ISA bus,
which we do support in the of_busses array but until now haven't
included in of_default_bus_match_table.
Add an "isa" entry to of_default_bus_match_table such that we can just
accept use of of_platform_default_populate_init & remove the
Malta-specific match table in a later patch.
Acked-by: Rob Herring <robh@kernel.org>
Cc: linux-mips@linux-mips.org
Cc: devicetree@vger.kernel.org
Patchwork: https://patchwork.linux-mips.org/patch/14275/
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux
Pull DeviceTree updates from Rob Herring:
- update changeset documentation on locking to reflect current code
- fix alphabetizing of vendor-prefixes.txt
- add various vendor prefixes
- add ESP8089 WiFi binding
- add new variable sized array parsing functions
* tag 'devicetree-for-4.9' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux: (21 commits)
DT: irqchip: renesas-irqc: document R8A7743/5 support
dt-bindings: Add Keith&Koep vendor prefix
dt-bindings: add vendor prefix for Auvidea GmbH
of: Add vendor prefix for Engicam s.r.l company
devicetree: Add vendor-prefix for Silead Inc.
devicetree: bindings: Add vendor prefix for Topeet.
dt-bindings: Add summit vendor id
of/platform: Initialise dev->fwnode appropriately
of: Add array read functions with min/max size limits
of: Make of_find_property_value_of_size take a length range
dt: net: enhance DWC EQoS binding to support Tegra186
bindings: PCI: artpec: correct pci binding example
Documentation: devicetree: Fix max77693 spelling errors
dt: bindings: Add binding for ESP8089 wifi chips
PCI: Xilinx NWL PCIe: Updating device tree documentation with prefetchable memory space
Documentation: devicetree: spi: fix wrong spi-bus documentation
dt-bindings: Add Japan Display Inc vendor id
dt-bindings: vendor-prefixes: Add Sierra Wireless
devicetree: Add vendor prefix for Shenzhen Sunchip Technology Co., Ltd
devicetree: Sort vendor prefixes in alphabetical order
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty
Pull tty and serial updates from Greg KH:
"Here is the big tty and serial patch set for 4.9-rc1.
It also includes some drivers/dma/ changes, as those were needed by
some serial drivers, and they were all acked by the DMA maintainer.
Also in here is the long-suffering ACPI SPCR patchset, which was
passed around from maintainer to maintainer like a hot-potato. Seems I
was the sucker^Wlucky one. All of those patches have been acked by the
various subsystem maintainers as well.
All of this has been in linux-next with no reported issues"
* tag 'tty-4.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (111 commits)
Revert "serial: pl011: add console matching function"
MAINTAINERS: update entry for atmel_serial driver
ARM64: ACPI: enable ACPI_SPCR_TABLE
ACPI: parse SPCR and enable matching console
of/serial: move earlycon early_param handling to serial
Revert "drivers/tty: Explicitly pass current to show_stack"
tty: amba-pl011: Don't complain on -EPROBE_DEFER when no irq
nios2: dts: 10m50: Add tx-threshold parameter
serial: 8250: Set Altera 16550 TX FIFO Threshold
serial: 8250: of: Load TX FIFO Threshold from DT
Documentation: dt: serial: Add TX FIFO threshold parameter
serial: imx: Fix DCD reading
serial: stm32: mark symbols static where possible
serial: xuartps: Add some register initialisation to cdns_early_console_setup()
serial: xuartps: Removed unwanted checks while reading the error conditions
serial: xuartps: Rewrite the interrupt handling logic
serial: stm32: use mapbase instead of membase for DMA
tty/serial: atmel: fix fractional baud rate computation
We have multiple "earlycon" early_param handlers - merge the DT one into
the main earlycon one. It's a cleanup that also will be useful
to defer setting up DT console until ACPI/DT decision is made.
Rename the exported function to avoid clashing with the function from
arch/microblaze/kernel/prom.c
Signed-off-by: Leif Lindholm <leif.lindholm@linaro.org>
Signed-off-by: Aleksey Makarov <aleksey.makarov@linaro.org>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Reviewed-by: Peter Hurley <peter@hurleysoftware.com>
Tested-by: Kefeng Wang <wangkefeng.wang@huawei.com>
Tested-by: Christopher Covington <cov@codeaurora.org>
Commit d48f62b9a0a0 ("mtd: nand: move of_get_nand_xxx() helpers into
nand_base.c") removed the drivers/of/of_mtd.c file but did not remove
the associated OF_MTD Kconfig option.
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
The PCI msi-map code is already doing double-duty translating IDs and
retrieving MSI parents, which unsurprisingly is the same functionality
we need for the identically-formatted PCI iommu-map property. Drag the
core parsing routine up yet another layer into the general OF-PCI code,
and further generalise it for either kind of lookup in either flavour
of map property.
Acked-by: Rob Herring <robh+dt@kernel.org>
Acked-by: Marc Zyngier <marc.zyngier@arm.com>
Tested-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Signed-off-by: Robin Murphy <robin.murphy@arm.com>
Whilst we're some of the way towards a universal firmware property
interface, drivers which deal with both OF and ACPI probing end up
having to do things like this:
dev->of_node ? &dev->of_node->fwnode : dev->fwnode
This seems unnecessary, when the OF code could instead simply fill in
the device's fwnode when binding the of_node, and let the drivers use
dev->fwnode either way. Let's give it a go and see what falls out.
Add a new set of array reading functions that take a minimum and
maximum size limit and will fail if the property size is not within
the size limits. This makes it more convenient for drivers that
use variable-size DT arrays which must be bounded at both ends -
data must be at least N entries but must not overflow the array
it is being copied into. It is also more efficient than making this
functionality out of existing public functions and avoids duplication.
The existing array functions have been left in the API, since there
are a very large number of clients of those functions and their
existing functionality is still useful. This avoids turning a small
API improvement into a major kernel rework.
The old functions have been turned into mininmal static inlines calling
the new functions. The old functions had no upper limit on the actual
size of the dts entry, to preserve this functionality rather than keeping
two near-identical implementations, if the new function is called with
max=0 there is no limit on the size of the dts entry but only the min
number of elements are read.
Signed-off-by: Richard Fitzgerald <rf@opensource.wolfsonmicro.com>
In preparation for adding variable-length array reads, change
of_find_property_value_of_size so that it takes an optional
maximum length. If the maximum is passed as 0, the behaviour is
unchanged and it will return a property if it's >= the requested
minimum length. If maximum is non-zero it will only return a
property whose length is min <= l <= max.
Use pr_fmt to prefix kernel output.
Signed-off-by: Kefeng Wang <wangkefeng.wang@huawei.com>
Use of_get_next_parent() instead of open-code.
This warning has been printed in of_numa_parse_cpu_nodes before.
Signed-off-by: Zhen Lei <thunder.leizhen@huawei.com>
If the numa-id which was configured in memory@ devicetree node is greater
than MAX_NUMNODES, we should report a warning. We have done this for cpus
and distance-map dt nodes, this patch help them to be consistent.
For a normal memory@ devicetree node, its reg property can contains more
memory blocks.
Because we don't known how many memory blocks maybe contained, so we try
from index=0, increase 1 until error returned(the end).
This information will be printed in the subfunction numa_add_memblk.
They are not the same, but very similar.
The called of_graph_get_next_endpoint() already decrements the refcount
of the prev node, so it is wrong to do it again in the calling function.
Use the for_each_endpoint_of_node() helper to interate through the
endpoint OF nodes, which already does the right thing and simplifies
the code a bit.
Fixes: 8ccd0d0ca041
(of: add helper for getting endpoint node of specific identifiers)
Cc: stable@vger.kernel.org
Reported-by: David Jander <david@protonic.nl>
Signed-off-by: Lucas Stach <l.stach@pengutronix.de>
Acked-by: Philipp Zabel <p.zabel@pengutronix.de>
boards
With the commit 44a7185c2ae6 ("of/platform: Add common method to
populate default bus"), a default function is introduced to populate
the default bus and this function is invoked at the arch_initcall_sync
level. But a lot of ppc boards use machine_device_initcall() to
populate the default bus. This means that the default populate function
has higher priority and would override the arch specific population of
the bus. The side effect is that some arch specific bus are not probed,
then cause various malfunction due to the miss of some devices. Since
it is very possible to introduce bugs if we simply change the initcall
level for all these boards(about 30+). This just disable this default
function for all the ppc boards.
Signed-off-by: Kevin Hao <haokexin@gmail.com>
That way the init callback may clear the flag again, in case of drivers
split between early irq chip and a normal platform driver.
Fixes: 15cc2ed6dcf9 ("of/irq: Mark initialised interrupt controllers as populated")
Suggested-by: Rob Herring <robh@kernel.org>
Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de>
Acked-by: Jon Hunter <jonathanh@nvidia.com>
@mynodes is set to NULL when __unflatten_device_tree() is called
to unflatten device sub-tree in PCI hot add scenario on PowerPC
PowerNV platform. Marking @mynodes detached unconditionally causes
kernel crash as below backtrace shows:
Unable to handle kernel paging request for data at address 0x00000000
Faulting instruction address: 0xc000000000b26f64
cpu 0x0: Vector: 300 (Data Access) at [c000003fcc7cf740]
pc: c000000000b26f64: __unflatten_device_tree+0xf4/0x190
lr: c000000000b26f40: __unflatten_device_tree+0xd0/0x190
sp: c000003fcc7cf9c0
msr: 900000000280b033
dar: 0
dsisr: 40000000
current = 0xc000003fcc281680
paca = 0xc00000000ff00000 softe: 0 irq_happened: 0x01
pid = 2724, comm = sh
Linux version 4.7.0-gavin-07754-g92a6836 (gwshan@gwshan) (gcc version \
4.9.3 (Buildroot 2016.02-rc2-00093-g5ea3bce) ) #539 SMP Mon Aug 1 \
12:40:29 AEST 2016
enter ? for help
[c000003fcc7cfa50] c000000000b27060 of_fdt_unflatten_tree+0x60/0x90
[c000003fcc7cfaa0] c0000000004c6288 pnv_php_set_slot_power_state+0x118/0x440
[c000003fcc7cfb80] c0000000004c6a10 pnv_php_enable+0xc0/0x170
[c000003fcc7cfbd0] c0000000004c4d80 power_write_file+0xa0/0x190
[c000003fcc7cfc50] c0000000004be93c pci_slot_attr_store+0x3c/0x60
[c000003fcc7cfc70] c0000000002d3fd4 sysfs_kf_write+0x94/0xc0
[c000003fcc7cfcb0] c0000000002d2c30 kernfs_fop_write+0x180/0x260
[c000003fcc7cfd00] c000000000230fe0 __vfs_write+0x40/0x190
[c000003fcc7cfd90] c000000000232278 vfs_write+0xc8/0x240
[c000003fcc7cfde0] c000000000233d90 SyS_write+0x60/0x110
[c000003fcc7cfe30] c000000000009524 system_call+0x38/0x108
This avoids the kernel crash by marking @mynodes detached only when
@mynodes is dereferencing valid device node in __unflatten_device_tree().
Fixes: 1d1bde550ea3 ("of: fdt: mark unflattened tree as detached")
Reported-by: Meng Li <shlimeng@cn.ibm.com>
Signed-off-by: Gavin Shan <gwshan@linux.vnet.ibm.com>
The of_node_put() function tests whether its argument is NULL
and then returns immediately.
Thus the test around the call is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring <elfring@users.sourceforge.net>
Instead of a ramoops-specific node, use a child node of /reserved-memory.
This requires that of_platform_device_create() be explicitly called
for the node, though, since "/reserved-memory" does not have its own
"compatible" property.
git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux
Pull powerpc updates from Michael Ellerman:
"Highlights:
- PowerNV PCI hotplug support.
- Lots more Power9 support.
- eBPF JIT support on ppc64le.
- Lots of cxl updates.
- Boot code consolidation.
Bug fixes:
- Fix spin_unlock_wait() from Boqun Feng
- Fix stack pointer corruption in __tm_recheckpoint() from Michael
Neuling
- Fix multiple bugs in memory_hotplug_max() from Bharata B Rao
- mm: Ensure "special" zones are empty from Oliver O'Halloran
- ftrace: Separate the heuristics for checking call sites from
Michael Ellerman
- modules: Never restore r2 for a mprofile-kernel style mcount() call
- Fix endianness when reading TCEs from Alexey Kardashevskiy
- start rtasd before PCI probing from Greg Kurz
- PCI: rpaphp: Fix slot registration for multiple slots under a PHB
from Tyrel Datwyler
- powerpc/mm: Add memory barrier in __hugepte_alloc() from Sukadev
Bhattiprolu
Cleanups & fixes:
- Drop support for MPIC in pseries from Rashmica Gupta
- Define and use PPC64_ELF_ABI_v2/v1 from Michael Ellerman
- Remove unused symbols in asm-offsets.c from Rashmica Gupta
- Fix SRIOV not building without EEH enabled from Russell Currey
- Remove kretprobe_trampoline_holder from Thiago Jung Bauermann
- Reduce log level of PCI I/O space warning from Benjamin
Herrenschmidt
- Add array bounds checking to crash_shutdown_handlers from Suraj
Jitindar Singh
- Avoid -maltivec when using clang integrated assembler from Anton
Blanchard
- Fix array overrun in ppc_rtas() syscall from Andrew Donnellan
- Fix error return value in cmm_mem_going_offline() from Rasmus
Villemoes
- export cpu_to_core_id() from Mauricio Faria de Oliveira
- Remove old symbols from defconfigs from Andrew Donnellan
- Update obsolete comments in setup_32.c about entry conditions from
Benjamin Herrenschmidt
- Add comment explaining the purpose of setup_kdump_trampoline() from
- Merge the RELOCATABLE config entries for ppc32 and ppc64 from Kevin
Hao
- Remove RELOCATABLE_PPC32 from Kevin Hao
- Fix .long's in tlb-radix.c to more meaningful from Balbir Singh
Minor cleanups & fixes:
- Andrew Donnellan, Anna-Maria Gleixner, Anton Blanchard, Benjamin
Herrenschmidt, Bharata B Rao, Christophe Leroy, Colin Ian King,
Geliang Tang, Greg Kurz, Madhavan Srinivasan, Michael Ellerman,
Michael Ellerman, Stephen Rothwell, Stewart Smith.
Freescale updates from Scott:
- "Highlights include more 8xx optimizations, device tree updates,
and MVME7100 support."
PowerNV PCI hotplug from Gavin Shan:
- PCI: Add pcibios_setup_bridge()
- Override pcibios_setup_bridge()
- Remove PCI_RESET_DELAY_US
- Move pnv_pci_ioda_setup_opal_tce_kill() around
- Increase PE# capacity
- Allocate PE# in reverse order
- Create PEs in pcibios_setup_bridge()
- Setup PE for root bus
- Extend PCI bridge resources
- Make pnv_ioda_deconfigure_pe() visible
- Dynamically release PE
- Update bridge windows on PCI plug
- Delay populating pdn
- Support PCI slot ID
- Use PCI slot reset infrastructure
- Introduce pnv_pci_get_slot_id()
- Functions to get/set PCI slot state
- PCI/hotplug: PowerPC PowerNV PCI hotplug driver
- Print correct PHB type names
Power9 idle support from Shreyas B. Prabhu:
- set power_save func after the idle states are initialized
- Use PNV_THREAD_WINKLE macro while requesting for winkle
- make hypervisor state restore a function
- Rename idle_power7.S to idle_book3s.S
- Rename reusable idle functions to hardware agnostic names
- Make pnv_powersave_common more generic
- abstraction for saving SPRs before entering deep idle states
- Add platform support for stop instruction
- cpuidle/powernv: Use CPUIDLE_STATE_MAX instead of MAX_POWERNV_IDLE_STATES
- cpuidle/powernv: cleanup cpuidle-powernv.c
- cpuidle/powernv: Add support for POWER ISA v3 idle states
- Use deepest stop state when cpu is offlined
Power9 PMU from Madhavan Srinivasan:
- factor out power8 pmu macros and defines
- factor out power8 pmu functions
- factor out power8 __init_pmu code
- Add power9 event list macros for generic and cache events
- Power9 PMU support
- Export Power9 generic and cache events to sysfs
Power9 preliminary interrupt & PCI support from Benjamin Herrenschmidt:
- Add XICS emulation APIs
- Move a few exception common handlers to make room
- Add support for HV virtualization interrupts
- Add mechanism to force a replay of interrupts
- Add ICP OPAL backend
- Discover IODA3 PHBs
- pci: Remove obsolete SW invalidate
- opal: Add real mode call wrappers
- Rename TCE invalidation calls
- Remove SWINV constants and obsolete TCE code
- Rework accessing the TCE invalidate register
- Fallback to OPAL for TCE invalidations
- Use the device-tree to get available range of M64's
- Check status of a PHB before using it
- pci: Don't try to allocate resources that will be reassigned
Other Power9:
- Send SIGBUS on unaligned copy and paste from Chris Smart
- Large Decrementer support from Oliver O'Halloran
- Load Monitor Register Support from Jack Miller
Performance improvements from Anton Blanchard:
- Avoid load hit store in __giveup_fpu() and __giveup_altivec()
- Avoid load hit store in setup_sigcontext()
- Remove assembly versions of strcpy, strcat, strlen and strcmp
- Align hot loops of some string functions
eBPF JIT from Naveen N. Rao:
- Fix/enhance 32-bit Load Immediate implementation
- Optimize 64-bit Immediate loads
- Introduce rotate immediate instructions
- A few cleanups
- Isolate classic BPF JIT specifics into a separate header
- Implement JIT compiler for extended BPF
Operator Panel driver from Suraj Jitindar Singh:
- devicetree/bindings: Add binding for operator panel on FSP machines
- Add inline function to get rc from an ASYNC_COMP opal_msg
- Add driver for operator panel on FSP machines
Sparse fixes from Daniel Axtens:
- make some things static
- Introduce asm-prototypes.h
- Include headers containing prototypes
- Use #ifdef __BIG_ENDIAN__ #else for REG_BYTE
- kvm: Clarify __user annotations
- Pass endianness to sparse
- Make ppc_md.{halt, restart} __noreturn
MM fixes & cleanups from Aneesh Kumar K.V:
- radix: Update LPCR HR bit as per ISA
- use _raw variant of page table accessors
- Compile out radix related functions if RADIX_MMU is disabled
- Clear top 16 bits of va only on older cpus
- Print formation regarding the the MMU mode
- hash: Update SDR1 size encoding as documented in ISA 3.0
- radix: Update PID switch sequence
- radix: Update machine call back to support new HCALL.
- radix: Add LPID based tlb flush helpers
- radix: Add a kernel command line to disable radix
- Cleanup LPCR defines
Boot code consolidation from Benjamin Herrenschmidt:
- Move epapr_paravirt_early_init() to early_init_devtree()
- cell: Don't use flat device-tree after boot
- ge_imp3a: Don't use the flat device-tree after boot
- mpc85xx_ds: Don't use the flat device-tree after boot
- mpc85xx_rdb: Don't use the flat device-tree after boot
- Don't test for machine type in rtas_initialize()
- Don't test for machine type in smp_setup_cpu_maps()
- dt: Add of_device_compatible_match()
- Factor do_feature_fixup calls
- Move 64-bit feature fixup earlier
- Move 64-bit memory reserves to setup_arch()
- Use a cachable DART
- Move FW feature probing out of pseries probe()
- Put exception configuration in a common place
- Remove early allocation of the SMU command buffer
- Move MMU backend selection out of platform code
- pasemi: Remove IOBMAP allocation from platform probe()
- mm/hash: Don't use machine_is() early during boot
- Don't test for machine type to detect HEA special case
- pmac: Remove spurrious machine type test
- Move hash table ops to a separate structure
- Ensure that ppc_md is empty before probing for machine type
- Move 64-bit probe_machine() to later in the boot process
- Move 32-bit probe() machine to later in the boot process
- Get rid of ppc_md.init_early()
- Move the boot time info banner to a separate function
- Move setting of {i,d}cache_bsize to initialize_cache_info()
- Move the content of setup_system() to setup_arch()
- Move cache info inits to a separate function
- Re-order the call to smp_setup_cpu_maps()
- Re-order setup_panic()
- Make a few boot functions __init
- Merge 32-bit and 64-bit setup_arch()
Other new features:
- tty/hvc: Use IRQF_SHARED for OPAL hvc consoles from Sam Mendoza-Jonas
- tty/hvc: Use opal irqchip interface if available from Sam Mendoza-Jonas
- powerpc: Add module autoloading based on CPU features from Alastair D'Silva
- crypto: vmx - Convert to CPU feature based module autoloading from Alastair D'Silva
- Wake up kopald polling thread before waiting for events from Benjamin Herrenschmidt
- xmon: Dump ISA 2.06 SPRs from Michael Ellerman
- xmon: Dump ISA 2.07 SPRs from Michael Ellerman
- Add a parameter to disable 1TB segs from Oliver O'Halloran
- powerpc/boot: Add OPAL console to epapr wrappers from Oliver O'Halloran
- Assign fixed PHB number based on device-tree properties from Guilherme G. Piccoli
- pseries: Add pseries hotplug workqueue from John Allen
- pseries: Add support for hotplug interrupt source from John Allen
- pseries: Use kernel hotplug queue for PowerVM hotplug events from John Allen
- pseries: Move property cloning into its own routine from Nathan Fontenot
- pseries: Dynamic add entires to associativity lookup array from Nathan Fontenot
- pseries: Auto-online hotplugged memory from Nathan Fontenot
- pseries: Remove call to memblock_add() from Nathan Fontenot
cxl:
- Add set and get private data to context struct from Michael Neuling
- make base more explicitly non-modular from Paul Gortmaker
- Use for_each_compatible_node() macro from Wei Yongjun
- Frederic Barrat
- Abstract the differences between the PSL and XSL
- Make vPHB device node match adapter's
- Philippe Bergheaud
- Add mechanism for delivering AFU driver specific events
- Ignore CAPI adapters misplaced in switched slots
- Refine slice error debug messages
- Andrew Donnellan
- static-ify variables to fix sparse warnings
- PCI/hotplug: pnv_php: export symbols and move struct types needed by cxl
- PCI/hotplug: pnv_php: handle OPAL_PCI_SLOT_OFFLINE power state
- Add cxl_check_and_switch_mode() API to switch bi-modal cards
- remove dead Kconfig options
- fix potential NULL dereference in free_adapter()
- Ian Munsie
- Update process element after allocating interrupts
- Add support for CAPP DMA mode
- Fix allowing bogus AFU descriptors with 0 maximum processes
- Fix allocating a minimum of 2 pages for the SPA
- Fix bug where AFU disable operation had no effect
- Workaround XSL bug that does not clear the RA bit after a reset
- Fix NULL pointer dereference on kernel contexts with no AFU interrupts
- powerpc/powernv: Split cxl code out into a separate file
- Add cxl_slot_is_supported API
- Enable bus mastering for devices using CAPP DMA mode
- Move cxl_afu_get / cxl_afu_put to base
- Allow a default context to be associated with an external pci_dev
- Do not create vPHB if there are no AFU configuration records
- powerpc/powernv: Add support for the cxl kernel api on the real phb
- Add support for using the kernel API with a real PHB
- Add kernel APIs to get & set the max irqs per context
- Add preliminary workaround for CX4 interrupt limitation
- Add support for interrupts on the Mellanox CX4
- Workaround PE=0 hardware limitation in Mellanox CX4
- powerpc/powernv: Fix pci-cxl.c build when CONFIG_MODULES=n
selftests:
- Test unaligned copy and paste from Chris Smart
- Load Monitor Register Tests from Jack Miller
- Cyril Bur
- exec() with suspended transaction
- Use signed long to read perf_event_paranoid
- Fix usage message in context_switch
- Fix generation of vector instructions/types in context_switch
- Michael Ellerman
- Use "Delta" rather than "Error" in normal output
- Import Anton's mmap & futex micro benchmarks
- Add a test for PROT_SAO"
* tag 'powerpc-4.8-1' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux: (263 commits)
powerpc/mm: Parenthesise IS_ENABLED() in if condition
selftests/powerpc: exec() with suspended transaction
powerpc: Improve comment explaining why we modify VRSAVE
powerpc/mm: Drop unused externs for hpte_init_beat[_v3]()
powerpc/mm: Rename hpte_init_lpar() and move the fallback to a header
powerpc/mm: Fix build break when PPC_NATIVE=n
powerpc/powernv/ioda: Fix endianness when reading TCEs
powerpc/modules: Never restore r2 for a mprofile-kernel style mcount() call
powerpc/ftrace: Separate the heuristics for checking call sites
powerpc: Merge 32-bit and 64-bit setup_arch()
powerpc/64: Make a few boot functions __init
powerpc: Re-order setup_panic()
powerpc: Re-order the call to smp_setup_cpu_maps()
powerpc/32: Move cache info inits to a separate function
powerpc/64: Move the content of setup_system() to setup_arch()
- remove most of_platform_populate() calls in arch code. Now the DT
core code calls it in the default case and platforms only need to
call it if they have special needs
- use pr_fmt on all the DT core print statements
- CoreSight binding doc improvements to block name descriptions
- add dt_to_config script which can parse dts files and list
corresponding kernel config options
- fix memory leak hit with a PowerMac DT
- correct a bunch of STMicro compatible strings to use the correct
vendor prefix
- fix DA9052 PMIC binding doc to match what is actually used in dts
files
* tag 'devicetree-for-4.8' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux: (35 commits)
documentation: da9052: Update regulator bindings names to match DA9052/53 DTS expectations
xtensa: Partially Revert "xtensa: Remove unnecessary of_platform_populate with default match table"
xtensa: Fix build error due to missing include file
MIPS: ath79: Add missing include file
Fix spelling errors in Documentation/devicetree
ARM: dts: fix STMicroelectronics compatible strings
powerpc/dts: fix STMicroelectronics compatible strings
Documentation: dt: i2c: use correct STMicroelectronics vendor prefix
scripts/dtc: dt_to_config - kernel config options for a devicetree
of: overlay: add resolver error prints
coresight: document binding acronyms
Documentation/devicetree: document cavium-pip rx-delay/tx-delay properties
of: use pr_fmt prefix for all console printing
of: fix memory leak related to safe_name()
Revert "of/platform: export of_default_bus_match_table"
of: unittest: use of_platform_default_populate() to populate default bus
memory: omap-gpmc: use of_platform_default_populate() to populate default bus
bus: uniphier-system-bus: use of_platform_default_populate() to populate default bus
Pull networking updates from David Miller:
1) Unified UDP encapsulation offload methods for drivers, from
Alexander Duyck.
2) Make DSA binding more sane, from Andrew Lunn.
3) Support QCA9888 chips in ath10k, from Anilkumar Kolli.
4) Several workqueue usage cleanups, from Bhaktipriya Shridhar.
5) Add XDP (eXpress Data Path), essentially running BPF programs on RX
packets as soon as the device sees them, with the option to mirror
the packet on TX via the same interface. From Brenden Blanco and
others.
6) Allow qdisc/class stats dumps to run lockless, from Eric Dumazet.
7) Add VLAN support to b53 and bcm_sf2, from Florian Fainelli.
8) Simplify netlink conntrack entry layout, from Florian Westphal.
9) Add ipv4 forwarding support to mlxsw spectrum driver, from Ido
Schimmel, Yotam Gigi, and Jiri Pirko.
10) Add SKB array infrastructure and convert tun and macvtap over to it.
From Michael S Tsirkin and Jason Wang.
11) Support qdisc packet injection in pktgen, from John Fastabend.
12) Add neighbour monitoring framework to TIPC, from Jon Paul Maloy.
13) Add NV congestion control support to TCP, from Lawrence Brakmo.
14) Add GSO support to SCTP, from Marcelo Ricardo Leitner.
15) Allow GRO and RPS to function on macsec devices, from Paolo Abeni.
16) Support MPLS over IPV4, from Simon Horman.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1622 commits)
xgene: Fix build warning with ACPI disabled.
be2net: perform temperature query in adapter regardless of its interface state
l2tp: Correctly return -EBADF from pppol2tp_getname.
net/mlx5_core/health: Remove deprecated create_singlethread_workqueue
net: ipmr/ip6mr: update lastuse on entry change
macsec: ensure rx_sa is set when validation is disabled
tipc: dump monitor attributes
tipc: add a function to get the bearer name
tipc: get monitor threshold for the cluster
tipc: make cluster size threshold for monitoring configurable
tipc: introduce constants for tipc address validation
net: neigh: disallow transition to NUD_STALE if lladdr is unchanged in neigh_update()
MAINTAINERS: xgene: Add driver and documentation path
Documentation: dtb: xgene: Add MDIO node
drivers: net: xgene: ethtool: Use phy_ethtool_gset and sset
drivers: net: xgene: Use exported functions
drivers: net: xgene: Enable MDIO driver
drivers: net: xgene: Add backward compatibility
drivers: net: phy: xgene: Add MDIO driver
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip
Pull xen updates from David Vrabel:
"Features and fixes for 4.8-rc0:
- ACPI support for guests on ARM platforms.
- Generic steal time support for arm and x86.
- Support cases where kernel cpu is not Xen VCPU number (e.g., if
in-guest kexec is used).
- Use the system workqueue instead of a custom workqueue in various
places"
* tag 'for-linus-4.8-rc0-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip: (47 commits)
xen: add static initialization of steal_clock op to xen_time_ops
xen/pvhvm: run xen_vcpu_setup() for the boot CPU
xen/evtchn: use xen_vcpu_id mapping
xen/events: fifo: use xen_vcpu_id mapping
xen/events: use xen_vcpu_id mapping in events_base
x86/xen: use xen_vcpu_id mapping when pointing vcpu_info to shared_info
x86/xen: use xen_vcpu_id mapping for HYPERVISOR_vcpu_op
xen: introduce xen_vcpu_id mapping
x86/acpi: store ACPI ids from MADT for future usage
x86/xen: update cpuid.h from Xen-4.7
xen/evtchn: add IOCTL_EVTCHN_RESTRICT
xen-blkback: really don't leak mode property
xen-blkback: constify instance of "struct attribute_group"
xen-blkfront: prefer xenbus_scanf() over xenbus_gather()
xen-blkback: prefer xenbus_scanf() over xenbus_gather()
xen: support runqueue steal time on xen
arm/xen: add support for vm_assist hypercall
xen: update xen headers
xen-pciback: drop superfluous variables
xen-pciback: short-circuit read path used for merging write values
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media
Pull media updates from Mauro Carvalho Chehab:
- new framework support for HDMI CEC and remote control support
- new encoding codec driver for Mediatek SoC
- new frontend driver: helene tuner
- added support for NetUp almost universal devices, with supports
DVB-C/S/S2/T/T2 and ISDB-T
- the mn88472 frontend driver got promoted from staging
- a new driver for RCar video input
- some soc_camera legacy drivers got removed: timb, omap1, mx2, mx3
- lots of driver cleanups, improvements and fixups
* tag 'media/v4.8-1' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (377 commits)
[media] cec: always check all_device_types and features
[media] cec: poll should check if there is room in the tx queue
[media] vivid: support monitor all mode
[media] cec: fix test for unconfigured adapter in main message loop
[media] cec: limit the size of the transmit queue
[media] cec: zero unused msg part after msg->len
[media] cec: don't set fh to NULL in CEC_TRANSMIT
[media] cec: clear all status fields before transmit and always fill in sequence
[media] cec: CEC_RECEIVE overwrote the timeout field
[media] cxd2841er: Reading SNR for DVB-C added
[media] cxd2841er: Reading BER and UCB for DVB-C added
[media] cxd2841er: fix switch-case for DVB-C
[media] cxd2841er: fix signal strength scale for ISDB-T
[media] cxd2841er: adjust the dB scale for DVB-C
[media] cxd2841er: provide signal strength for DVB-C
[media] cxd2841er: fix BER report via DVBv5 stats API
[media] mb86a20s: apply mask to val after checking for read failure
[media] airspy: fix error logic during device register
[media] s5p-cec/TODO: add TODO item
[media] cec/TODO: drop comment about sphinx documentation
* acpi-numa:
ACPI / NUMA: Enable ACPI based NUMA on ARM64
arm64, ACPI, NUMA: NUMA support based on SRAT and SLIT
ACPI / processor: Add acpi_map_madt_entry()
ACPI / NUMA: Improve SRAT error detection and add messages
ACPI / NUMA: Move acpi_numa_memory_affinity_init() to drivers/acpi/numa.c
ACPI / NUMA: remove unneeded acpi_numa=1
ACPI / NUMA: move bad_srat() and srat_disabled() to drivers/acpi/numa.c
x86 / ACPI / NUMA: cleanup acpi_numa_processor_affinity_init()
arm64, NUMA: Cleanup NUMA disabled messages
arm64, NUMA: rework numa_add_memblk()
ACPI / NUMA: move acpi_numa_slit_init() to drivers/acpi/numa.c
ACPI / NUMA: Move acpi_numa_arch_fixup() to ia64 only
ACPI / NUMA: remove duplicate NULL check
ACPI / NUMA: Replace ACPI_DEBUG_PRINT() with pr_debug()
ACPI / NUMA: Use pr_fmt() instead of printk
This provides an equivalent of of_fdt_match() for non-flat trees.
This is more practical than matching an array of of_device_id structs
when converting a bunch of existing users of of_fdt_match().
The tree returned from of_fdt_unflatten_tree cannot be attached to the
live tree because it is not marked as detached so mark it as such. The
dt resolver checks the flag and refuses to process the tree otherwise.
Signed-off-by: Michal Suchanek <hramrach@gmail.com>
Applying overlay fails silently in case of an error. Add error prints.
Most notably the lack of symbols in the live tree is not reported.
Clean-up all the DT printk functions to use common pr_fmt prefix.
Some print statements such as kmalloc errors were redundant, so just
drop those.
Cc: Pantelis Antoniou <pantelis.antoniou@konsulko.com>
Reviewed-by: Frank Rowand <frank.rowand@am.sony.com>
Abstract a general interface "of_phy_get_and_connect"
for PHY connect. User will have no bother with getting
"phy-mode" and "phy-handle" any more.
Suggested-by: Arnd Bergmann <arnd@arndb.de>
Signed-off-by: Dongpo Li <lidongpo@hisilicon.com>
Reviewed-by: Jiancheng Xue <xuejiancheng@hisilicon.com>
Linux 4.7-rc6
* tag 'v4.7-rc6': (1245 commits)
Linux 4.7-rc6
ovl: warn instead of error if d_type is not supported
MIPS: Fix possible corruption of cache mode by mprotect.
locks: use file_inode()
usb: dwc3: st: Use explicit reset_control_get_exclusive() API
phy: phy-stih407-usb: Use explicit reset_control_get_exclusive() API
phy: miphy28lp: Inform the reset framework that our reset line may be shared
namespace: update event counter when umounting a deleted dentry
9p: use file_dentry()
lockd: unregister notifier blocks if the service fails to come up completely
ACPI,PCI,IRQ: correct operator precedence
fuse: serialize dirops by default
drm/i915: Fix missing unlock on error in i915_ppgtt_info()
powerpc: Initialise pci_io_base as early as possible
mfd: da9053: Fix compiler warning message for uninitialised variable
mfd: max77620: Fix FPS switch statements
phy: phy-stih407-usb: Inform the reset framework that our reset line may be shared
usb: dwc3: st: Inform the reset framework that our reset line may be shared
usb: host: ehci-st: Inform the reset framework that our reset line may be shared
usb: host: ohci-st: Inform the reset framework that our reset line may be shared
Sometimes it needs to check if there is a subnode of given node in FDT
by given name. Introduce this helper to get the subnode if it exists.
CC: Rob Herring <robh@kernel.org>
Signed-off-by: Shannon Zhao <shannon.zhao@linaro.org>
Acked-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
Tested-by: Julien Grall <julien.grall@arm.com>
Several cases of overlapping changes, except the packet scheduler
conflicts which deal with the addition of the free list parameter
to qdisc_enqueue().
Calling the fixed-phy functions when CONFIG_FIXED_PHY=m as a previous
change tried cannot work if the caller is in built-in code:
drivers/of/built-in.o: In function `of_phy_register_fixed_link':
of_reserved_mem.c:(.text+0x85e0): undefined reference to `fixed_phy_register'
Making of_mdio depend on 'FIXED_PHY || !FIXED_PHY' would solve this
dependency by enforcing that OF_MDIO itself becomes a loadable module
when FIXED_PHY=y, but that creates a different dependency as it
breaks any built-in ethernet driver that uses of_mdio.
Making FIXED_PHY a bool option also cannot work, since it depends on
PHYLIB, which again is tristate.
This version now uses 'select FIXED_PHY' to ensure that the fixed-phy
portion of of_mdio is not optional. The main downside of this is
a small increase in code size for cases that do not need fixed phy
support, but it should avoid all of the link-time problems.
Fixes: d1bd330a229f ("of_mdio: Enable fixed PHY support if driver is a module")
Acked-by: Randy Dunlap <rdunlap@infradead.org>
For interrupt controllers successfully initialised early via device-tree,
mark these interrupt controllers as populated so we don't unnecessarily
create a device and populate any platform data later on in the boot
sequence when we populate all the various platform devices.
Signed-off-by: Jon Hunter <jonathanh@nvidia.com>
Fix a memory leak resulting from memory allocation in safe_name().
This patch fixes all call sites of safe_name().
Mathieu Malaterre reported the memory leak on boot:
On my PowerMac device-tree would generate a duplicate name:
[ 0.023043] device-tree: Duplicate name in PowerPC,G4@0, renamed to "l2-cache#1"
in this case a newly allocated name is generated by `safe_name`. However
in this case it is never deallocated.
The bug was found using kmemleak reported as:
unreferenced object 0xdf532e60 (size 32):
comm "swapper", pid 1, jiffies 4294892300 (age 1993.532s)
hex dump (first 32 bytes):
6c 32 2d 63 61 63 68 65 23 31 00 dd e4 dd 1e c2 l2-cache#1......
ec d4 ba ce 04 ec cc de 8e 85 e9 ca c4 ec cc 9e ................
backtrace:
[<c02d3350>] kvasprintf+0x64/0xc8
[<c02d3400>] kasprintf+0x4c/0x5c
[<c0453814>] safe_name.isra.1+0x80/0xc4
[<c04545d8>] __of_attach_node_sysfs+0x6c/0x11c
[<c075f21c>] of_core_init+0x8c/0xf8
[<c0729594>] kernel_init_freeable+0xd4/0x208
[<c00047e8>] kernel_init+0x24/0x11c
[<c00158ec>] ret_from_kernel_thread+0x5c/0x64
Link: https://bugzilla.kernel.org/show_bug.cgi?id=120331
Signed-off-by: Frank Rowand <frank.rowand@am.sony.com>
Reported-by: mathieu.malaterre@gmail.com
Tested-by: Mathieu Malaterre <mathieu.malaterre@gmail.com>
This reverts commit b80443c2211c7daaabd20fbbe9e7beb3fa3408e0.
After covering to use helper of_platform_default_populate() to populate
the default bus, no need to export of_default_bus_match_table anymore.
Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
Cc: Grant Likely <grant.likely@linaro.org>
Use helper of_platform_default_populate() in linux/of_platform
when possible, instead of calling of_platform_populate() with
the default match table.
The arch code calls of_platform_populate() with default match table
when it wants to populate default bus.
This patch introduce a new of_platform_default_populate_init() and make it
arch_initcall_sync(it should be later than some iommu configration, eg,
of_iommu_init() and swiotlb_late_init in arm64), then we can finish above
job in common method.
In order to avoid the default bus being populated twice, simply checking
the flag of bus node whether has be set OF_POPULATED_BUS or not.
After that, we can safely remove the caller in arch code.
Btw, add debug print in of_platform_populate(), and use __func__ to
print function's name of of_platform_bus_create().
