path: root/drivers/parisc/dino.c
2012-03-28Merge tag 'split-asm_system_h-for-linus-20120328' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system Pull "Disintegrate and delete asm/system.h" from David Howells: "Here are a bunch of patches to disintegrate asm/system.h into a set of separate bits to relieve the problem of circular inclusion dependencies. I've built all the working defconfigs from all the arches that I can and made sure that they don't break. The reason for these patches is that I recently encountered a circular dependency problem that came about when I produced some patches to optimise get_order() by rewriting it to use ilog2(). This uses bitops - and on the SH arch asm/bitops.h drags in asm-generic/get_order.h by a circuituous route involving asm/system.h. The main difficulty seems to be asm/system.h. It holds a number of low level bits with no/few dependencies that are commonly used (eg. memory barriers) and a number of bits with more dependencies that aren't used in many places (eg. switch_to()). These patches break asm/system.h up into the following core pieces: (1) asm/barrier.h Move memory barriers here. This already done for MIPS and Alpha. (2) asm/switch_to.h Move switch_to() and related stuff here. (3) asm/exec.h Move arch_align_stack() here. Other process execution related bits could perhaps go here from asm/processor.h. (4) asm/cmpxchg.h Move xchg() and cmpxchg() here as they're full word atomic ops and frequently used by atomic_xchg() and atomic_cmpxchg(). (5) asm/bug.h Move die() and related bits. (6) asm/auxvec.h Move AT_VECTOR_SIZE_ARCH here. Other arch headers are created as needed on a per-arch basis." Fixed up some conflicts from other header file cleanups and moving code around that has happened in the meantime, so David's testing is somewhat weakened by that. We'll find out anything that got broken and fix it.. * tag 'split-asm_system_h-for-linus-20120328' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system: (38 commits) Delete all instances of asm/system.h Remove all #inclusions of asm/system.h Add #includes needed to permit the removal of asm/system.h Move all declarations of free_initmem() to linux/mm.h Disintegrate asm/system.h for OpenRISC Split arch_align_stack() out from asm-generic/system.h Split the switch_to() wrapper out of asm-generic/system.h Move the asm-generic/system.h xchg() implementation to asm-generic/cmpxchg.h Create asm-generic/barrier.h Make asm-generic/cmpxchg.h #include asm-generic/cmpxchg-local.h Disintegrate asm/system.h for Xtensa Disintegrate asm/system.h for Unicore32 [based on ver #3, changed by gxt] Disintegrate asm/system.h for Tile Disintegrate asm/system.h for Sparc Disintegrate asm/system.h for SH Disintegrate asm/system.h for Score Disintegrate asm/system.h for S390 Disintegrate asm/system.h for PowerPC Disintegrate asm/system.h for PA-RISC Disintegrate asm/system.h for MN10300 ...
2012-03-28Remove all #inclusions of asm/system.hDavid Howells
Remove all #inclusions of asm/system.h preparatory to splitting and killing it. Performed with the following command: perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *` Signed-off-by: David Howells <dhowells@redhat.com>
2012-02-23parisc/PCI: get rid of device resource fixupsBjorn Helgaas
Tell the PCI core about host bridge address translation so it can take care of bus-to-resource conversion for us. CC: linux-parisc@vger.kernel.org Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-01-06parisc/PCI: dino: convert to pci_create_root_bus() for correct root bus ↵Bjorn Helgaas
resources Supply root bus resources to pci_create_root_bus() so they're correct immediately. This fixes the problem of "early" and "header" quirks seeing incorrect root bus resources. CC: linux-parisc@vger.kernel.org Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2012-01-06parisc/PCI: dino: use pci_create_bus() instead of pci_scan_bus_parented()Bjorn Helgaas
No functional change here; just converting from pci_scan_bus_parented() to pci_create_bus() to make a future patch simpler. CC: linux-parisc@vger.kernel.org Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-02-10[PARISC] Convert to new irq_chip functionsThomas Gleixner
Convert all the parisc driver interrupt handlers (dino, eisa, gsc, iosapic and superio) as well as the cpu interrupts. Prepare show_interrupts for GENERIC_HARDIRQS_NO_DEPRECATED and finally selects that Kconfig option [jejb: compile and testing fixes] Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-12-04parisc: convert the rest of the irq handlers to simple/percpuJames Bottomley
The generic conversion eliminates the spurious no_ack and no_end routines, converts all the cascaded handlers to handle_simple_irq() and makes iosapic use a modified handle_percpu_irq() to become the same as the CPU irq's. This isn't an essential change, but it eliminates the mask/unmask overhead of handle_level_irq(). Signed-off-by: James Bottomley <James.Bottomley@suse.de> Tested-by: Helge Deller <deller@gmx.de> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2010-10-14parisc: convert gsc and dino pci interrupts to flow handlersKyle McMartin
Signed-off-by: Kyle McMartin <kyle@redhat.com>
2010-10-14parisc: lay groundwork for killing __do_IRQKyle McMartin
Use proper accessors and handlers for generic irq cleanups. We just call back into __do_IRQ through desc->handler now, and remove the explicit calls. Signed-off-by: Kyle McMartin <kyle@redhat.com>
2009-12-16parisc: Fixup last users of irq_chip->typenameThomas Gleixner
The typename member of struct irq_chip was kept for migration purposes and is obsolete since more than 2 years. Fix up the leftovers. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2009-08-02parisc: dino.c - check return value of pci_assign_resource()Helge Deller
Signed-off-by: Helge Deller <deller@gmx.de>
2009-07-03parisc: remove obsolete hw_interrupt_typeThomas Gleixner
The defines and typedefs (hw_interrupt_type, no_irq_type, irq_desc_t) have been kept around for migration reasons. After more than two years it's time to remove them finally. This patch cleans up one of the remaining users. When all such patches hit mainline we can remove the defines and typedefs finally. Impact: cleanup Convert the last remaining users to struct irq_chip and remove the define. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2009-07-03parisc: advertise PCI devs after "assign_resources"Grant Grundler
Alex Chiang asked me why PARISC was calling pci_bus_add_devices() and pci_bus_assign_resources() in the opposite order from everyone else. No reason and I couldn't see any data dependency. Patch below applies cleanly to 2.6.30-rc2. Later, I suspected the code worked only because no drivers would be loaded/ready until much later in the system initialization sequence. Tested "LBA" code on J6000 (32-bit) and A500 (64-bit SMP) with 2.6.30-rc2. Not tested with any Dino controllers. Not tested with PCI-PCI Bridge (TBD). Reported-by: Alex Chiang <achiang@hp.com> Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2009-04-02parisc: drivers: fix warningsAlexander Beregalov
ccio-dma.c:456: warning: overflow in implicit constant conversion ccio-dma.c:459: warning: overflow in implicit constant conversion ccio-dma.c:1032: warning: unused variable 'j' ccio-dma.c:1031: warning: unused variable 'max' ccio-dma.c:1031: warning: unused variable 'min' ccio-dma.c:1031: warning: unused variable 'avg' ccio-dma.c:1403: warning: format '%08lx' expects type 'long unsigned int', but argument 3 has type 'resource_size_t' ccio-dma.c:1403: warning: format '%08lx' expects type 'long unsigned int', but argument 4 has type 'resource_size_t' ccio-dma.c:1554: warning: format '%lx' expects type 'long unsigned int', but argument 3 has type 'resource_size_t' dino.c:822: warning: format '%lx' expects type 'long unsigned int', but argument 4 has type 'resource_size_t' dino.c:822: warning: format '%lx' expects type 'long unsigned int', but argument 5 has type 'resource_size_t' dino.c:902: warning: format '%lx' expects type 'long unsigned int', but argument 3 has type 'resource_size_t' dino.c:902: warning: format '%lx' expects type 'long unsigned int', but argument 4 has type 'resource_size_t' asp.c:84: warning: format '%lx' expects type 'long unsigned int', but argument 4 has type 'resource_size_t' eisa.c:317: warning: format '%08lx' expects type 'long unsigned int', but argument 3 has type 'resource_size_t' eisa_enumerator.c:101: warning: format '%lx' expects type 'long unsigned int', but argument 2 has type 'resource_size_t' eisa_enumerator.c:101: warning: format '%lx' expects type 'long unsigned int', but argument 3 has type 'resource_size_t' eisa_enumerator.c:191: warning: format '%lx' expects type 'long unsigned int', but argument 2 has type 'resource_size_t' eisa_enumerator.c:191: warning: format '%lx' expects type 'long unsigned int', but argument 3 has type 'resource_size_t' Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2009-03-13parisc: dino: struct device - replace bus_id with dev_name(), dev_set_name()Kay Sievers
Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2009-03-13parisc: fix wrong assumption about bus->selfGrant Grundler
Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> posted a patch series to linux-pci to fix a wrong assumption about pci_bus->self==NULL for all PCI host bus controllers. While PARISC platforms to not behave this way, I prefer to have the code consistent across architectures. The following patch replaces pci_bus->self with pci_bus->parent when used as a test to check for "root bus controller". Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2009-01-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/kyle/parisc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/kyle/parisc-2.6: parisc: export length of os_hpmc vector parisc: fix kernel crash (protection id trap) when compiling ruby1.9 parisc: Use DEFINE_SPINLOCK parisc: add uevent helper for parisc bus parisc: fix ipv6 checksum parisc: quiet palo not-found message from "which" parisc: Replace NR_CPUS in parisc code parisc: trivial fixes parisc: fix braino in commit adding __space_to_prot parisc: factor out sid to protid conversion parisc: use leX_to_cpu in place of __fswabX parisc: fix GFP_KERNEL use while atomic in unwinder parisc: remove dead BIO_VMERGE_BOUNDARY and BIO_VMERGE_MAX_SIZE definitions parisc: set_time() catch errors parisc: use the new byteorder headers parisc: drivers/parisc/: make code static parisc: lib/: make code static
2009-01-07PCI: parisc: use generic pci_swizzle_interrupt_pin()Bjorn Helgaas
Use the generic pci_swizzle_interrupt_pin() instead of arch-specific code. Acked-by: Kyle McMartin <kyle@infradead.org> Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-05parisc: drivers/parisc/: make code staticAdrian Bunk
Make the following needlessly global code static: - asp.c: asp_init_chip() - ccio-dma.c: ccio_io_pdir_entry() - dino.c: struct dino_port_ops - dino.c: struct dino_bios_ops - hppb.c: struct hppb_card_head - lasi.c: lasi_led_init() - lasi.c: lasi_init_chip() - lba_pci.c: struct lba_bios_ops - sba_iommu.c: sba_io_pdir_entry() - sba_iommu.c: sba_driver_callback() - sba_iommu.c: sba_driver_callback() - wax.c: wax_init_chip() Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2008-10-16generic: sparse irqs: use irq_desc() together with dyn_array, instead of ↵Yinghai Lu
irq_desc[] add CONFIG_HAVE_SPARSE_IRQ to for use condensed array. Get rid of irq_desc[] array assumptions. Preallocate 32 irq_desc, and irq_desc() will try to get more. ( No change in functionality is expected anywhere, except the odd build failure where we missed a code site or where a crossing commit itroduces new irq_desc[] usage. ) v2: according to Eric, change get_irq_desc() to irq_desc() Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-05-15drivers/parisc: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Matthew Wilcox <willy@debian.org> Cc: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2008-04-20PCI: remove parisc consumer of the pci global_listJames Bottomley
Remove the parisc usage of the global_list, as it's not needed anymore. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-10-06Build fixes for struct pt_regs removalMatthew Wilcox
Signed-off-by: Matthew Wilcox <matthew@wil.cx>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-06-29[PATCH] genirq: rename desc->handler to desc->chipIngo Molnar
This patch-queue improves the generic IRQ layer to be truly generic, by adding various abstractions and features to it, without impacting existing functionality. While the queue can be best described as "fix and improve everything in the generic IRQ layer that we could think of", and thus it consists of many smaller features and lots of cleanups, the one feature that stands out most is the new 'irq chip' abstraction. The irq-chip abstraction is about describing and coding and IRQ controller driver by mapping its raw hardware capabilities [and quirks, if needed] in a straightforward way, without having to think about "IRQ flow" (level/edge/etc.) type of details. This stands in contrast with the current 'irq-type' model of genirq architectures, which 'mixes' raw hardware capabilities with 'flow' details. The patchset supports both types of irq controller designs at once, and converts i386 and x86_64 to the new irq-chip design. As a bonus side-effect of the irq-chip approach, chained interrupt controllers (master/slave PIC constructs, etc.) are now supported by design as well. The end result of this patchset intends to be simpler architecture-level code and more consolidation between architectures. We reused many bits of code and many concepts from Russell King's ARM IRQ layer, the merging of which was one of the motivations for this patchset. This patch: rename desc->handler to desc->chip. Originally i did not want to do this, because it's a big patch. But having both "desc->handler", "desc->handle_irq" and "action->handler" caused a large degree of confusion and made the code appear alot less clean than it truly is. I have also attempted a dual approach as well by introducing a desc->chip alias - but that just wasnt robust enough and broke frequently. So lets get over with this quickly. The conversion was done automatically via scripts and converts all the code in the kernel. This renaming patch is the first one amongst the patches, so that the remaining patches can stay flexible and can be merged and split up without having some big monolithic patch act as a merge barrier. [akpm@osdl.org: build fix] [akpm@osdl.org: another build fix] Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-30[PARISC] I/O-Space must be ioremap_nocache()'dHelge Deller
Addresses in F-space must be accessed uncached on most parisc machines. Signed-off-by: Helge Deller <deller@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-01-22[PARISC] Use kzalloc and other janitor-style cleanupsHelge Deller
Helge, o Convert a bunch of kmalloc/memset uses to kzalloc. o pci.c: Add some __read_mostly annotations. o pci.c: Move constant pci_post_reset_delay to asm/pci.h o grfioctl.h: Add A4450A to comment of CRT_ID_VISUALIZE_EG. o Add some consts to perf.c/perf_images.h Matthew, o sticore.c: Add some consts to suppress compile warnings. Signed-off-by: Helge Deller <deller@parisc-linux.org> Signed-off-by: Matthew Wilcox <willy@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-01-10[PARISC] Fix Dino reporting on J2240Matthew Wilcox
Fix Dino reporting on J2240. This particular machine thought it had a Cujo. Also add J2240 Dino chip to the hp_hardware_list. Signed-off-by: Matthew Wilcox <willy@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-01-10[PARISC] Introduce DINO_LOCAL_IRQS and use it for gsc_find_local_irqHelge Deller
Fix dino by using DINO_LOCAL_IRQS as the limit for gsc_find_local_irq() instead of the irq itself. Signed-off-by: Helge Deller <deller@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-01-10[PARISC] Fix Cirrus 6832 Cardbus on RDI Tadpole PARISC LaptopHelge Deller
Fix irq-off-by-one for Cirrus 6832 Cardbus on RDI Tadpole PARISC Laptop. We just DECLARE_PCI_FIXUP_ENABLE as it is unlikely that this will be found in any other parisc system. Signed-off-by: Helge Deller <deller@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-10-21[PARISC] Update dino from parisc treeMatthew Wilcox
Fix card-mode Dino crashes on 725 (and probably other Snake) systems. Dino was coming up in fatal mode after a warm reboot. Resetting Dino brings it out of fatal mode, so do that if the status register indicates we're in fatal mode. Since this was never observed on any later systems, I presume firmware does this for us on those. Signed-off-by: Matthew Wilcox <willy@parisc-linux.org> Add debug statements in the cfg_read and cfg_write functions Fix debug statements from the IRQ overhaul last winter Rename dino_driver_callback() to dino_probe() Signed-off-by: Matthew Wilcox <willy@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-10-21[PARISC] Convert parisc_device to use struct resource for hpaMatthew Wilcox
Convert pa_dev->hpa from an unsigned long to a struct resource. Signed-off-by: Matthew Wilcox <willy@parisc-linux.org> Fix up users of ->hpa to use ->hpa.start instead. Signed-off-by: Matthew Wilcox <willy@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-10-21[PARISC] Change the driver names so /sys/bus/parisc/drivers/ looks betterMatthew Wilcox
Make /sys/bus/parisc/drivers look better by cleaning up parisc_driver names. Signed-off-by: Matthew Wilcox <willy@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-06-27[PATCH] acpi bridge hotadd: ACPI based root bridge hot-addRajesh Shah
When you hot-plug a (root) bridge hierarchy, it may have p2p bridges and devices attached to it that have not been configured by firmware. In this case, we need to configure the devices before starting them. This patch separates device start from device scan so that we can introduce the configuration step in the middle. I kept the existing semantics for pci_scan_bus() since there are a huge number of callers to that function. Also, I have no way of testing the changes I made to the parisc files, so this needs review by those folks. Sorry for the massive cross-post, this touches files in many different places. Signed-off-by: Rajesh Shah <rajesh.shah@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
