path: root/drivers/parisc/iosapic.c
2011-02-10[PARISC] Convert to new irq_chip functionsThomas Gleixner
Convert all the parisc driver interrupt handlers (dino, eisa, gsc, iosapic and superio) as well as the cpu interrupts. Prepare show_interrupts for GENERIC_HARDIRQS_NO_DEPRECATED and finally selects that Kconfig option [jejb: compile and testing fixes] Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-12-04parisc: convert the rest of the irq handlers to simple/percpuJames Bottomley
The generic conversion eliminates the spurious no_ack and no_end routines, converts all the cascaded handlers to handle_simple_irq() and makes iosapic use a modified handle_percpu_irq() to become the same as the CPU irq's. This isn't an essential change, but it eliminates the mask/unmask overhead of handle_level_irq(). Signed-off-by: James Bottomley <James.Bottomley@suse.de> Tested-by: Helge Deller <deller@gmx.de> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2010-10-21drivers/parisc/iosapic.c: Remove unnecessary kzalloc castJoe Perches
Convert kzalloc to kcalloc Signed-off-by: Joe Perches <joe@perches.com> Reviewed-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@redhat.com>
2010-10-14parisc: convert iosapic interrupts to proper flow handlersKyle McMartin
Shift the ->end call (cpu eoi) from __do_IRQ into our unmask handler. Also nuke some redundant code. Signed-off-by: Kyle McMartin <kyle@redhat.com>
2010-10-14parisc: convert cpu interrupts to proper flow handlersKyle McMartin
Only major change is renaming functions to match the conventions expected by the generic irq code. Signed-off-by: Kyle McMartin <kyle@redhat.com>
2010-10-14parisc: lay groundwork for killing __do_IRQKyle McMartin
Use proper accessors and handlers for generic irq cleanups. We just call back into __do_IRQ through desc->handler now, and remove the explicit calls. Signed-off-by: Kyle McMartin <kyle@redhat.com>
2009-12-16parisc: Fixup last users of irq_chip->typenameThomas Gleixner
The typename member of struct irq_chip was kept for migration purposes and is obsolete since more than 2 years. Fix up the leftovers. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2009-07-03parisc: remove obsolete hw_interrupt_typeThomas Gleixner
The defines and typedefs (hw_interrupt_type, no_irq_type, irq_desc_t) have been kept around for migration reasons. After more than two years it's time to remove them finally. This patch cleans up one of the remaining users. When all such patches hit mainline we can remove the defines and typedefs finally. Impact: cleanup Convert the last remaining users to struct irq_chip and remove the define. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2009-04-28irq: change ->set_affinity() to return statusYinghai Lu
according to Ingo, change set_affinity() in irq_chip should return int, because that way we can handle failure cases in a much cleaner way, in the genirq layer. v2: fix two typos [ Impact: extend API ] Signed-off-by: Yinghai Lu <yinghai@kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Suresh Siddha <suresh.b.siddha@intel.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: linux-arch@vger.kernel.org LKML-Reference: <49F654E9.4070809@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-31parisc: iosapic: fix build breakageAlexander Beregalov
drivers/parisc/iosapic.c:717: error: incompatible types in assignment irq_desc::affinity was changed from cpumask_t to cpumask_var_t in 7f7ace0cda (cpumask: update irq_desc to use cpumask_var_t) Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2009-03-13parisc: convert cpu_check_affinity to new cpumask apiKyle McMartin
cpumask arg to the affinity function is now const, sort that out through the irq_desc implementations. Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2009-03-13parisc: fix wrong assumption about bus->selfGrant Grundler
Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> posted a patch series to linux-pci to fix a wrong assumption about pci_bus->self==NULL for all PCI host bus controllers. While PARISC platforms to not behave this way, I prefer to have the code consistent across architectures. The following patch replaces pci_bus->self with pci_bus->parent when used as a test to check for "root bus controller". Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2009-01-07PCI: parisc: use generic pci_swizzle_interrupt_pin()Bjorn Helgaas
Use the generic pci_swizzle_interrupt_pin() instead of arch-specific code. Acked-by: Kyle McMartin <kyle@infradead.org> Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-12-13cpumask: make irq_set_affinity() take a const struct cpumaskRusty Russell
Impact: change existing irq_chip API Not much point with gentle transition here: the struct irq_chip's setaffinity method signature needs to change. Fortunately, not widely used code, but hits a few architectures. Note: In irq_select_affinity() I save a temporary in by mangling irq_desc[irq].affinity directly. Ingo, does this break anything? (Folded in fix from KOSAKI Motohiro) Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Mike Travis <travis@sgi.com> Reviewed-by: Grant Grundler <grundler@parisc-linux.org> Acked-by: Ingo Molnar <mingo@redhat.com> Cc: ralf@linux-mips.org Cc: grundler@parisc-linux.org Cc: jeremy@xensource.com Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
2008-10-16generic: sparse irqs: use irq_desc() together with dyn_array, instead of ↵Yinghai Lu
irq_desc[] add CONFIG_HAVE_SPARSE_IRQ to for use condensed array. Get rid of irq_desc[] array assumptions. Preallocate 32 irq_desc, and irq_desc() will try to get more. ( No change in functionality is expected anywhere, except the odd build failure where we missed a code site or where a crossing commit itroduces new irq_desc[] usage. ) v2: according to Eric, change get_irq_desc() to irq_desc() Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2006-12-13[PATCH] getting rid of all casts of k[cmz]alloc() callsRobert P. J. Day
Run this: #!/bin/sh for f in $(grep -Erl "\([^\)]*\) *k[cmz]alloc" *) ; do echo "De-casting $f..." perl -pi -e "s/ ?= ?\([^\)]*\) *(k[cmz]alloc) *\(/ = \1\(/" $f done And then go through and reinstate those cases where code is casting pointers to non-pointers. And then drop a few hunks which conflicted with outstanding work. Cc: Russell King <rmk@arm.linux.org.uk>, Ian Molton <spyro@f2s.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Greg KH <greg@kroah.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Paul Fulghum <paulkf@microgate.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Karsten Keil <kkeil@suse.de> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Ian Kent <raven@themaw.net> Cc: Steven French <sfrench@us.ibm.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Neil Brown <neilb@cse.unsw.edu.au> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-30Fix misc .c/.h comment typosMatt LaPlante
Fix various .c/.h typos in comments (no code changes). Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-04[PARISC] Create shared <asm/ropes.h> headerKyle McMartin
Pull out struct sba_device and struct lba_device into a common ropes.h header. Also fold the parisc portion of iosapic.h into this file. (Then delete the useless portion of iosapic.h) Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-10-04[PARISC] Allow nested interruptsJames Bottomley
Our prior mode of operation didn't allow nested interrupts because it makes the interrupt code much simpler. However, nested interrupts are better for latency. This code uses the EIEM register to simulate level interrupts and thus achieve nesting. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-06-29[PATCH] genirq: rename desc->handler to desc->chipIngo Molnar
This patch-queue improves the generic IRQ layer to be truly generic, by adding various abstractions and features to it, without impacting existing functionality. While the queue can be best described as "fix and improve everything in the generic IRQ layer that we could think of", and thus it consists of many smaller features and lots of cleanups, the one feature that stands out most is the new 'irq chip' abstraction. The irq-chip abstraction is about describing and coding and IRQ controller driver by mapping its raw hardware capabilities [and quirks, if needed] in a straightforward way, without having to think about "IRQ flow" (level/edge/etc.) type of details. This stands in contrast with the current 'irq-type' model of genirq architectures, which 'mixes' raw hardware capabilities with 'flow' details. The patchset supports both types of irq controller designs at once, and converts i386 and x86_64 to the new irq-chip design. As a bonus side-effect of the irq-chip approach, chained interrupt controllers (master/slave PIC constructs, etc.) are now supported by design as well. The end result of this patchset intends to be simpler architecture-level code and more consolidation between architectures. We reused many bits of code and many concepts from Russell King's ARM IRQ layer, the merging of which was one of the motivations for this patchset. This patch: rename desc->handler to desc->chip. Originally i did not want to do this, because it's a big patch. But having both "desc->handler", "desc->handle_irq" and "action->handler" caused a large degree of confusion and made the code appear alot less clean than it truly is. I have also attempted a dual approach as well by introducing a desc->chip alias - but that just wasnt robust enough and broke frequently. So lets get over with this quickly. The conversion was done automatically via scripts and converts all the code in the kernel. This renaming patch is the first one amongst the patches, so that the remaining patches can stay flexible and can be merged and split up without having some big monolithic patch act as a merge barrier. [akpm@osdl.org: build fix] [akpm@osdl.org: another build fix] Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-30[PARISC] I/O-Space must be ioremap_nocache()'dHelge Deller
Addresses in F-space must be accessed uncached on most parisc machines. Signed-off-by: Helge Deller <deller@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2006-01-22[PARISC] Use kzalloc and other janitor-style cleanupsHelge Deller
Helge, o Convert a bunch of kmalloc/memset uses to kzalloc. o pci.c: Add some __read_mostly annotations. o pci.c: Move constant pci_post_reset_delay to asm/pci.h o grfioctl.h: Add A4450A to comment of CRT_ID_VISUALIZE_EG. o Add some consts to perf.c/perf_images.h Matthew, o sticore.c: Add some consts to suppress compile warnings. Signed-off-by: Helge Deller <deller@parisc-linux.org> Signed-off-by: Matthew Wilcox <willy@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-11-17[PARISC] Add IRQ affinitiesJames Bottomley
This really only adds them for the machines I can check SMP on, which is CPU interrupts and IOSAPIC (so not any of the GSC based machines). With this patch, irqbalanced can be used to maintain irq balancing. Unfortunately, irqbalanced is a bit x86 centric, so it doesn't do an incredibly good job, but it does work. Signed-off-by: James Bottomley <jejb@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-10-21[PARISC] Minor iosapic.c cleanupGrant Grundler
minor cleanup: qualify constant with "UL" Acked-by: "Hmamouche, Youssef" <youssef@ece.utexas.edu> Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2005-09-09[PATCH] more SPIN_LOCK_UNLOCKED -> DEFINE_SPINLOCK conversionsIngo Molnar
This converts the final 20 DEFINE_SPINLOCK holdouts. (another 580 places are already using DEFINE_SPINLOCK). Build tested on x86. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
