path: root/drivers/parisc
2009-04-02parisc: drivers: fix warningsAlexander Beregalov
ccio-dma.c:456: warning: overflow in implicit constant conversion ccio-dma.c:459: warning: overflow in implicit constant conversion ccio-dma.c:1032: warning: unused variable 'j' ccio-dma.c:1031: warning: unused variable 'max' ccio-dma.c:1031: warning: unused variable 'min' ccio-dma.c:1031: warning: unused variable 'avg' ccio-dma.c:1403: warning: format '%08lx' expects type 'long unsigned int', but argument 3 has type 'resource_size_t' ccio-dma.c:1403: warning: format '%08lx' expects type 'long unsigned int', but argument 4 has type 'resource_size_t' ccio-dma.c:1554: warning: format '%lx' expects type 'long unsigned int', but argument 3 has type 'resource_size_t' dino.c:822: warning: format '%lx' expects type 'long unsigned int', but argument 4 has type 'resource_size_t' dino.c:822: warning: format '%lx' expects type 'long unsigned int', but argument 5 has type 'resource_size_t' dino.c:902: warning: format '%lx' expects type 'long unsigned int', but argument 3 has type 'resource_size_t' dino.c:902: warning: format '%lx' expects type 'long unsigned int', but argument 4 has type 'resource_size_t' asp.c:84: warning: format '%lx' expects type 'long unsigned int', but argument 4 has type 'resource_size_t' eisa.c:317: warning: format '%08lx' expects type 'long unsigned int', but argument 3 has type 'resource_size_t' eisa_enumerator.c:101: warning: format '%lx' expects type 'long unsigned int', but argument 2 has type 'resource_size_t' eisa_enumerator.c:101: warning: format '%lx' expects type 'long unsigned int', but argument 3 has type 'resource_size_t' eisa_enumerator.c:191: warning: format '%lx' expects type 'long unsigned int', but argument 2 has type 'resource_size_t' eisa_enumerator.c:191: warning: format '%lx' expects type 'long unsigned int', but argument 3 has type 'resource_size_t' Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2009-04-02parisc: led: remove proc_dir_entry::ownerAlexander Beregalov
proc_dir_entry::owner was removed in 0702c1c1a4 (proc 2/2: remove struct proc_dir_entry::owner) Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2009-03-31parisc: iosapic: fix build breakageAlexander Beregalov
drivers/parisc/iosapic.c:717: error: incompatible types in assignment irq_desc::affinity was changed from cpumask_t to cpumask_var_t in 7f7ace0cda (cpumask: update irq_desc to use cpumask_var_t) Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2009-03-31parisc: blink all or loadavg LEDs on oopsHelge Deller
- depending on machine type, blink all leds or just the loadavg leds twice a second on oops. - cancel_rearming_delayed_workqueue() is obsolete, use cancel_delayed_work_sync() instead Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2009-03-15parisc: sba_iommu: fix build bug when CONFIG_PARISC_AGP=yKyle McMartin
CC drivers/parisc/sba_iommu.o drivers/parisc/sba_iommu.c:1373: error: expected identifier or '(' before '}' token make[2]: *** [drivers/parisc/sba_iommu.o] Error 1 make[1]: *** [drivers/parisc] Error 2 make: *** [drivers] Error 2 Don't know how this has gone missed for so long... clearly I need to do builds on my C8000 more often. Signed-off-by: Kyle McMartin <kyle@mcmartin.ca> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-13parisc: dino: struct device - replace bus_id with dev_name(), dev_set_name()Kay Sievers
Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2009-03-13parisc: convert cpu_check_affinity to new cpumask apiKyle McMartin
cpumask arg to the affinity function is now const, sort that out through the irq_desc implementations. Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2009-03-13parisc: fix wrong assumption about bus->selfGrant Grundler
Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> posted a patch series to linux-pci to fix a wrong assumption about pci_bus->self==NULL for all PCI host bus controllers. While PARISC platforms to not behave this way, I prefer to have the code consistent across architectures. The following patch replaces pci_bus->self with pci_bus->parent when used as a test to check for "root bus controller". Signed-off-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2009-03-13parisc: remove klist iteratorsJames Bottomley
commit 11c3b5c3e08f4d855cbef52883c266b9ab9df879 Author: Greg Kroah-Hartman <gregkh@suse.de> Date: Tue Dec 16 12:24:56 2008 -0800 driver core: move klist_children into private structure Broke our parisc build pretty badly because we touch the klists directly in three cases (AGP, SBA and GSC). Although GregKH will revert this patch, there's no reason we should be using the iterators directly, we can just move to the standard device_for_each_child() API. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com> Tested-by: Helge Deller <deller@gmx.de> Tested-by: Kyle McMartin <kyle@mcmartin.ca> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2009-01-29Documentation: move DMA-mapping.txt to Doc/PCI/Randy Dunlap
Move DMA-mapping.txt to Documentation/PCI/. DMA-mapping.txt was supposed to be moved from Documentation/ to Documentation/PCI/. The 00-INDEX files in those two directories were updated, along with a few other text files, but the file itself somehow escaped being moved, so move it and update more text files and source files with its new location. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> cc: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-13fix early_serial_setup() regressionHelge Deller
Commit b430428a188e8a434325e251d0704af4b88b4711 ("8250: Don't clobber spinlocks.") introduced a regression on the parisc architecture, which broke the handover to the serial port at boottime. early_serial_setup() was changed to only copy a subset of the uart_port fields, and sadly the "type" and "line" fields were forgotten and thus the serial port was not initialized and could not be used for a handover. This patch fixes this by copying the missing fields. As this change to early_serial_setup() doesn't need an initialized spinlock in the uart_port struct any longer, we can drop the spinlock initialization in the superio driver. Cc: David Daney <ddaney@caviumnetworks.com> Cc: Tomaso Paoletti <tpaoletti@caviumnetworks.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Acked-by: Kyle McMartin <kyle@mcmartin.ca> Cc: linux-parisc@vger.kernel.org Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/kyle/parisc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/kyle/parisc-2.6: parisc: export length of os_hpmc vector parisc: fix kernel crash (protection id trap) when compiling ruby1.9 parisc: Use DEFINE_SPINLOCK parisc: add uevent helper for parisc bus parisc: fix ipv6 checksum parisc: quiet palo not-found message from "which" parisc: Replace NR_CPUS in parisc code parisc: trivial fixes parisc: fix braino in commit adding __space_to_prot parisc: factor out sid to protid conversion parisc: use leX_to_cpu in place of __fswabX parisc: fix GFP_KERNEL use while atomic in unwinder parisc: remove dead BIO_VMERGE_BOUNDARY and BIO_VMERGE_MAX_SIZE definitions parisc: set_time() catch errors parisc: use the new byteorder headers parisc: drivers/parisc/: make code static parisc: lib/: make code static
2009-01-07PCI: parisc: use generic pci_swizzle_interrupt_pin()Bjorn Helgaas
Use the generic pci_swizzle_interrupt_pin() instead of arch-specific code. Acked-by: Kyle McMartin <kyle@infradead.org> Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-05parisc: remove dead BIO_VMERGE_BOUNDARY and BIO_VMERGE_MAX_SIZE definitionsFUJITA Tomonori
The block layer dropped the virtual merge feature (b8b3e16cfe6435d961f6aaebcfd52a1ff2a988c5). BIO_VMERGE_BOUNDARY and BIO_VMERGE_MAX_SIZE definitions are meaningless now. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2009-01-05parisc: drivers/parisc/: make code staticAdrian Bunk
Make the following needlessly global code static: - asp.c: asp_init_chip() - ccio-dma.c: ccio_io_pdir_entry() - dino.c: struct dino_port_ops - dino.c: struct dino_bios_ops - hppb.c: struct hppb_card_head - lasi.c: lasi_led_init() - lasi.c: lasi_init_chip() - lba_pci.c: struct lba_bios_ops - sba_iommu.c: sba_io_pdir_entry() - sba_iommu.c: sba_driver_callback() - sba_iommu.c: sba_driver_callback() - wax.c: wax_init_chip() Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2009-01-02Merge branch 'cpus4096-for-linus-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'cpus4096-for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (66 commits) x86: export vector_used_by_percpu_irq x86: use logical apicid in x2apic_cluster's x2apic_cpu_mask_to_apicid_and() sched: nominate preferred wakeup cpu, fix x86: fix lguest used_vectors breakage, -v2 x86: fix warning in arch/x86/kernel/io_apic.c sched: fix warning in kernel/sched.c sched: move test_sd_parent() to an SMP section of sched.h sched: add SD_BALANCE_NEWIDLE at MC and CPU level for sched_mc>0 sched: activate active load balancing in new idle cpus sched: bias task wakeups to preferred semi-idle packages sched: nominate preferred wakeup cpu sched: favour lower logical cpu number for sched_mc balance sched: framework for sched_mc/smt_power_savings=N sched: convert BALANCE_FOR_xx_POWER to inline functions x86: use possible_cpus=NUM to extend the possible cpus allowed x86: fix cpu_mask_to_apicid_and to include cpu_online_mask x86: update io_apic.c to the new cpumask code x86: Introduce topology_core_cpumask()/topology_thread_cpumask() x86: xen: use smp_call_function_many() x86: use work_on_cpu in x86/kernel/cpu/mcheck/mce_amd_64.c ... Fixed up trivial conflict in kernel/time/tick-sched.c manually
2008-12-13cpumask: make irq_set_affinity() take a const struct cpumaskRusty Russell
Impact: change existing irq_chip API Not much point with gentle transition here: the struct irq_chip's setaffinity method signature needs to change. Fortunately, not widely used code, but hits a few architectures. Note: In irq_select_affinity() I save a temporary in by mangling irq_desc[irq].affinity directly. Ingo, does this break anything? (Folded in fix from KOSAKI Motohiro) Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Mike Travis <travis@sgi.com> Reviewed-by: Grant Grundler <grundler@parisc-linux.org> Acked-by: Ingo Molnar <mingo@redhat.com> Cc: ralf@linux-mips.org Cc: grundler@parisc-linux.org Cc: jeremy@xensource.com Cc: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
2008-11-19netdev: introduce dev_get_stats()Stephen Hemminger
In order for the network device ops get_stats call to be immutable, the handling of the default internal network device stats block has to be changed. Add a new helper function which replaces the old use of internal_get_stats. Note: change return code to make it clear that the caller should not go changing the returned statistics. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-21[PATCH] introduce fmode_t, do annotationsAl Viro
2008-10-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/kyle/parisc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/kyle/parisc-2.6: parisc: convert to generic compat_sys_ptrace parisc: add rtc platform driver parisc: initialize unwinder much earlier parisc: add new syscalls parisc: hijack jump to start_kernel parisc: add pdc_coproc_cfg_unlocked and set_firmware_width_unlocked parisc: move include/asm-parisc to arch/parisc/include/asm parisc: move pdc_result to real2.S parisc: unify CCIO_COLLECT_STATS implementation parisc: add arch/parisc/kernel/.gitignore parisc: ropes.h - fix <asm-parisc/*> -> <asm/*> parisc: parisc-agp - fix <asm-parisc/*> -> <asm/*> Resolve remove/rename conflict: include/asm-parisc/a.out.h is no longer relevant.
2008-10-16generic: sparse irqs: use irq_desc() together with dyn_array, instead of ↵Yinghai Lu
irq_desc[] add CONFIG_HAVE_SPARSE_IRQ to for use condensed array. Get rid of irq_desc[] array assumptions. Preallocate 32 irq_desc, and irq_desc() will try to get more. ( No change in functionality is expected anywhere, except the odd build failure where we missed a code site or where a crossing commit itroduces new irq_desc[] usage. ) v2: according to Eric, change get_irq_desc() to irq_desc() Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-10parisc: unify CCIO_COLLECT_STATS implementationKyle McMartin
Make it behave in the same manner as SBA_COLLECT_STATS, further clean ups pending.
2008-07-02parisc-eisa_eeprom: BKL pushdownArnd Bergmann
2008-05-15drivers/parisc: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Matthew Wilcox <willy@debian.org> Cc: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2008-04-29parisc: use non-racy method for proc entries creationDenis V. Lunev
Use proc_create() to make sure that ->proc_fops be setup before gluing PDE to main tree. Signed-off-by: Denis V. Lunev <den@openvz.org> Cc: Kyle McMartin <kyle@parisc-linux.org> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Grant Grundler <grundler@parisc-linux.org> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-20PCI: remove parisc consumer of the pci global_listJames Bottomley
Remove the parisc usage of the global_list, as it's not needed anymore. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-03-15[PARISC] make ptr_to_pide() staticFUJITA Tomonori
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2008-03-15[PARISC] pdc_stable: fix compile errorsJoel Soete
Signed-off-by: Joel Soete <rubisher@scarlet.be> Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
2008-03-05parisc: fix IOMMU's device boundary overflow bug on 32bits archFUJITA Tomonori
On 32bits boxes, boundary_size becomes zero due to a overflow and we hit BUG_ON in iommu_is_span_boundary. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Kyle McMartin <kyle@parisc-linux.org> Cc: Matthew Wilcox <matthew@wil.cx> Acked-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04iommu: parisc: make the IOMMUs respect the segment boundary limitsFUJITA Tomonori
Make PARISC's two IOMMU implementations not allocate a memory area spanning LLD's segment boundary. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Kyle McMartin <kyle@parisc-linux.org> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04iommu: parisc: pass struct device to iommu_alloc_rangeFUJITA Tomonori
This adds struct device argument to sba_alloc_range and ccio_alloc_range, a preparation for modifications to fix the IOMMU segment boundary problem. This change enables ccio_alloc_range to access to LLD's segment boundary limits. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Kyle McMartin <kyle@parisc-linux.org> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05iommu sg merging: parisc: make iommu respect the segment size limitsFUJITA Tomonori
This patch makes iommu respect segment size limits when merging sg lists. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Jeff Garzik <jeff@garzik.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Acked-by: Jens Axboe <jens.axboe@oracle.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Acked-by: Grant Grundler <grundler@parisc-linux.org> Cc: Matthew Wilcox <willy@debian.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-03drivers/parisc/: Spelling fixesJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Grant Grundler <grundler@parisc-linux.org> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2008-01-28[PARISC]: Fix build after ipv4_is_*() changes.Joe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-24Kobject: convert drivers/* from kobject_unregister() to kobject_put()Greg Kroah-Hartman
There is no need for kobject_unregister() anymore, thanks to Kay's kobject cleanup changes, so replace all instances of it with kobject_put(). Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24Kobject: change drivers/parisc/pdc_stable.c to use kobject_init_and_addGreg Kroah-Hartman
Stop using kobject_register, as this way we can control the sending of the uevent properly, after everything is properly initialized. Cc: Kyle McMartin <kyle@parisc-linux.org> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Grant Grundler <grundler@parisc-linux.org> Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24kobject: convert parisc/pdc_stable to use kobject_createGreg Kroah-Hartman
Using a kset for this simple directory is an overkill. Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Thibaut VARENE <varenet@parisc-linux.org> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Grant Grundler <grundler@parisc-linux.org> Cc: Kyle McMartin <kyle@parisc-linux.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24firmware: change firmware_kset to firmware_kobjGreg Kroah-Hartman
There is no firmware "subsystem" it's just a directory in /sys that other portions of the kernel want to hook into. So make it a kobject not a kset to help alivate anyone who tries to do some odd kset-like things with this. Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24kset: convert parisc/pdc_stable.c to use kset_createGreg Kroah-Hartman
Dynamically create the kset instead of declaring it statically. This makes the kobject attributes now work properly that I broke in the previous patch. Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Thibaut VARENE <varenet@parisc-linux.org> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Grant Grundler <grundler@parisc-linux.org> Cc: Kyle McMartin <kyle@parisc-linux.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24kobject: convert parisc/pdc_stable to kobj_attr interfaceGreg Kroah-Hartman
This makes the code a bit simpler and and gets us one step closer to deleting the deprecated subsys_attr code. NOTE, this needs the next patch in the series in order to work properly. This will build, but the sysfs files will not properly operate. Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Thibaut VARENE <varenet@parisc-linux.org> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Grant Grundler <grundler@parisc-linux.org> Cc: Kyle McMartin <kyle@parisc-linux.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24kobject: remove struct kobj_type from struct ksetGreg Kroah-Hartman
We don't need a "default" ktype for a kset. We should set this explicitly every time for each kset. This change is needed so that we can make ksets dynamic, and cleans up one of the odd, undocumented assumption that the kset/kobject/ktype model has. This patch is based on a lot of help from Kay Sievers. Nasty bug in the block code was found by Dave Young <hidave.darkstar@gmail.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Dave Young <hidave.darkstar@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-12-06[PARISC] lba_pci: pci_claim_resources disabled expansion romsKyle McMartin
radeonfb was HPMC-ing my C8000 by trying to map its expansion rom from IO_VIEW, instead of PA_VIEW. Fix seems to be to ensure that its disabled ROM is properly inserted into the resource tree. FIXME: this will result in a whinging printk for cards which share expansion ROMS, such as a quad tulip. Thankfully, it isn't harmful. Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2007-10-23parisc: fix sg_page() falloutFUJITA Tomonori
arch/parisc/kernel/pci-dma.c: In function 'pa11_dma_map_sg': arch/parisc/kernel/pci-dma.c:487: error: 'struct scatterlist' has no member named 'page' arch/parisc/kernel/pci-dma.c: In function 'pa11_dma_unmap_sg': arch/parisc/kernel/pci-dma.c:508: error: 'struct scatterlist' has no member named 'page' arch/parisc/kernel/pci-dma.c:508: error: 'struct scatterlist' has no member named 'page' arch/parisc/kernel/pci-dma.c: In function 'pa11_dma_sync_sg_for_cpu': arch/parisc/kernel/pci-dma.c:535: error: 'struct scatterlist' has no member named 'page' arch/parisc/kernel/pci-dma.c:535: error: 'struct scatterlist' has no member named 'page' arch/parisc/kernel/pci-dma.c: In function 'pa11_dma_sync_sg_for_device': arch/parisc/kernel/pci-dma.c:545: error: 'struct scatterlist' has no member named 'page' arch/parisc/kernel/pci-dma.c:545: error: 'struct scatterlist' has no member named 'page' Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-18[PARISC] Fix infinite loop in /proc/iomemMatthew Wilcox
pcibios_link_hba_resources() could corrupt the resource tree by inserting resources in the wrong place. Fix this by calling pci_claim_resource() for PCI-PCI bridges. Delete pcibios_link_hba_resources as we shouldn't need it any more. Also get rid of lba_claim_dev_resources() and just call pci_claim_resource() directly. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2007-10-18[PARISC] Quiet sysfs_create_link __must_check warnings in pdc_stableKyle McMartin
Failing to create the links doesn't seem like a fatal error in these paths. WARN_ON seems better than nothing though. Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2007-10-18[PARISC] Squelch pci_enable_device __must_check warning in superioKyle McMartin
If we have a SuckyIO, and pci_enable_device fails, we'll be in a world of hurt anyways, so we might as well BUG_ON. Signed-off-by: Kyle McMartin <kyle@mcmartin.ca>
2007-10-18[PARISC] Clean up a resource_size_t warning in sba_iommuKyle McMartin
2007-10-10[NET]: Make the device list and device lookups per namespace.Eric W. Biederman
This patch makes most of the generic device layer network namespace safe. This patch makes dev_base_head a network namespace variable, and then it picks up a few associated variables. The functions: dev_getbyhwaddr dev_getfirsthwbytype dev_get_by_flags dev_get_by_name __dev_get_by_name dev_get_by_index __dev_get_by_index dev_ioctl dev_ethtool dev_load wireless_process_ioctl were modified to take a network namespace argument, and deal with it. vlan_ioctl_set and brioctl_set were modified so their hooks will receive a network namespace argument. So basically anthing in the core of the network stack that was affected to by the change of dev_base was modified to handle multiple network namespaces. The rest of the network stack was simply modified to explicitly use &init_net the initial network namespace. This can be fixed when those components of the network stack are modified to handle multiple network namespaces. For now the ifindex generator is left global. Fundametally ifindex numbers are per namespace, or else we will have corner case problems with migration when we get that far. At the same time there are assumptions in the network stack that the ifindex of a network device won't change. Making the ifindex number global seems a good compromise until the network stack can cope with ifindex changes when you change namespaces, and the like. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-18serial: add early_serial_setup() back to header fileYinghai Lu
early_serial_setup was removed from serial.h, but forgot to put in serial_8250.h Signed-off-by: Yinghai Lu <yinghai.lu@sun.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17hppb: Add missing dma-mapping.h includeFrank Lichtenheld
This fixes the following build-error: CC drivers/parisc/hppb.o drivers/parisc/hppb.c: In function ‘hppb_probe’: drivers/parisc/hppb.c:73: error: implicit declaration of function ‘ccio_request_resource’ Signed-off-by: Frank Lichtenheld <frank@lichtenheld.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
