path: root/drivers/parisc
2014-10-13Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler updates from Ingo Molnar: "The main changes in this cycle were: - Optimized support for Intel "Cluster-on-Die" (CoD) topologies (Dave Hansen) - Various sched/idle refinements for better idle handling (Nicolas Pitre, Daniel Lezcano, Chuansheng Liu, Vincent Guittot) - sched/numa updates and optimizations (Rik van Riel) - sysbench speedup (Vincent Guittot) - capacity calculation cleanups/refactoring (Vincent Guittot) - Various cleanups to thread group iteration (Oleg Nesterov) - Double-rq-lock removal optimization and various refactorings (Kirill Tkhai) - various sched/deadline fixes ... and lots of other changes" * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (72 commits) sched/dl: Use dl_bw_of() under rcu_read_lock_sched() sched/fair: Delete resched_cpu() from idle_balance() sched, time: Fix build error with 64 bit cputime_t on 32 bit systems sched: Improve sysbench performance by fixing spurious active migration sched/x86: Fix up typo in topology detection x86, sched: Add new topology for multi-NUMA-node CPUs sched/rt: Use resched_curr() in task_tick_rt() sched: Use rq->rd in sched_setaffinity() under RCU read lock sched: cleanup: Rename 'out_unlock' to 'out_free_new_mask' sched: Use dl_bw_of() under RCU read lock sched/fair: Remove duplicate code from can_migrate_task() sched, mips, ia64: Remove __ARCH_WANT_UNLOCKED_CTXSW sched: print_rq(): Don't use tasklist_lock sched: normalize_rt_tasks(): Don't use _irqsave for tasklist_lock, use task_rq_lock() sched: Fix the task-group check in tg_has_rt_tasks() sched/fair: Leverage the idle state info when choosing the "idlest" cpu sched: Let the scheduler see CPU idle states sched/deadline: Fix inter- exclusive cpusets migrations sched/deadline: Clear dl_entity params when setscheduling to different class sched/numa: Kill the wrong/dead TASK_DEAD check in task_numa_fault() ...
2014-10-01parisc: Fix serial console for machines with serial port on superio chipHelge Deller
Fix the serial console on machines where the serial port is located on the SuperIO chip. Signed-off-by: Helge Deller <deller@gmx.de> Cc: Peter Hurley <peter@hurleysoftware.com>
2014-09-21parisc: pdc_stable.c: Avoid potential stack overflowsHelge Deller
2014-09-21parisc: pdc_stable.c: Cleaning up unnecessary use of memset in conjunction ↵Rickard Strandqvist
with strncpy Using memset before strncpy just to ensure a trailing null character is an unnecessary double writing of a string Patch modified by Helge Deller to additionally reduce stack usage. Signed-off-by: Rickard Strandqvist <rickard_strandqvist@spectrumdigital.se> Signed-off-by: Helge Deller <deller@gmx.de>
2014-09-19sched, cleanup, treewide: Remove set_current_state(TASK_RUNNING) after ↵Kirill Tkhai
schedule() schedule(), io_schedule() and schedule_timeout() always return with TASK_RUNNING state set, so one more setting is unnecessary. (All places in patch are visible good, only exception is kiblnd_scheduler() from: drivers/staging/lustre/lnet/klnds/o2iblnd/o2iblnd_cb.c Its schedule() is one line above standard 3 lines of unified diff) No places where set_current_state() is used for mb(). Signed-off-by: Kirill Tkhai <ktkhai@parallels.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Link: http://lkml.kernel.org/r/1410529254.3569.23.camel@tkhai Cc: Alasdair Kergon <agk@redhat.com> Cc: Anil Belur <askb23@gmail.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Dave Kleikamp <shaggy@kernel.org> Cc: David Airlie <airlied@linux.ie> Cc: David Howells <dhowells@redhat.com> Cc: Dmitry Eremin <dmitry.eremin@intel.com> Cc: Frank Blaschka <blaschka@linux.vnet.ibm.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Helge Deller <deller@gmx.de> Cc: Isaac Huang <he.huang@intel.com> Cc: James E.J. Bottomley <JBottomley@parallels.com> Cc: James E.J. Bottomley <jejb@parisc-linux.org> Cc: J. Bruce Fields <bfields@fieldses.org> Cc: Jeff Dike <jdike@addtoit.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Jiri Slaby <jslaby@suse.cz> Cc: Laura Abbott <lauraa@codeaurora.org> Cc: Liang Zhen <liang.zhen@intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Masaru Nomura <massa.nomura@gmail.com> Cc: Michael Opdenacker <michael.opdenacker@free-electrons.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Mike Snitzer <snitzer@redhat.com> Cc: Neil Brown <neilb@suse.de> Cc: Oleg Drokin <green@linuxhacker.ru> Cc: Peng Tao <bergwolf@gmail.com> Cc: Richard Weinberger <richard@nod.at> Cc: Robert Love <robert.w.love@intel.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Trond Myklebust <trond.myklebust@primarydata.com> Cc: Ursula Braun <ursula.braun@de.ibm.com> Cc: Zi Shen Lim <zlim.lnx@gmail.com> Cc: devel@driverdev.osuosl.org Cc: dm-devel@redhat.com Cc: dri-devel@lists.freedesktop.org Cc: fcoe-devel@open-fcoe.org Cc: jfs-discussion@lists.sourceforge.net Cc: linux390@de.ibm.com Cc: linux-afs@lists.infradead.org Cc: linux-cris-kernel@axis.com Cc: linux-kernel@vger.kernel.org Cc: linux-nfs@vger.kernel.org Cc: linux-parisc@vger.kernel.org Cc: linux-raid@vger.kernel.org Cc: linux-s390@vger.kernel.org Cc: linux-scsi@vger.kernel.org Cc: qla2xxx-upstream@qlogic.com Cc: user-mode-linux-devel@lists.sourceforge.net Cc: user-mode-linux-user@lists.sourceforge.net Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-08-27parisc: dino: fix %d confusingly prefixed with 0x in format stringHans Wennborg
Signed-off-by: Hans Wennborg <hans@hanshq.net> Signed-off-by: Helge Deller <deller@gmx.de>
2013-09-03Merge tag 'pci-v3.12-changes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull PCI changes from Bjorn Helgaas: PCI device hotplug: - Use PCIe native hotplug, not ACPI hotplug, when possible (Neil Horman) - Assign resources on per-host bridge basis (Yinghai Lu) MPS (Max Payload Size): - Allow larger MPS settings below hotplug-capable Root Port (Yijing Wang) - Add warnings about unsafe MPS settings (Yijing Wang) - Simplify interface and messages (Bjorn Helgaas) SR-IOV: - Return -ENOSYS on non-SR-IOV devices (Stefan Assmann) - Update NumVFs register when disabling SR-IOV (Yijing Wang) Virtualization: - Add bus and slot reset support (Alex Williamson) - Fix ACS (Access Control Services) issues (Alex Williamson) Miscellaneous: - Simplify PCIe Capability accessors (Bjorn Helgaas) - Add pcibios_pm_ops for arch-specific hibernate stuff (Sebastian Ott) - Disable decoding during BAR sizing only when necessary (Zoltan Kiss) - Delay enabling bridges until they're needed (Yinghai Lu) - Split Designware support into Synopsys and Exynos parts (Jingoo Han) - Convert class code to use dev_groups (Greg Kroah-Hartman) - Cleanup Designware and Exynos I/O access wrappers (Seungwon Jeon) - Fix bridge I/O window alignment (Bjorn Helgaas) - Add pci_wait_for_pending_transaction() (Casey Leedom) - Use devm_ioremap_resource() in Marvell driver (Tushar Behera) * tag 'pci-v3.12-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (63 commits) PCI/ACPI: Fix _OSC ordering to allow PCIe hotplug use when available PCI: exynos: Add I/O access wrappers PCI: designware: Drop "addr" arg from dw_pcie_readl_rc()/dw_pcie_writel_rc() PCI: Remove pcie_cap_has_devctl() PCI: Support PCIe Capability Slot registers only for ports with slots PCI: Remove PCIe Capability version checks PCI: Allow PCIe Capability link-related register access for switches PCI: Add offsets of PCIe capability registers PCI: Tidy bitmasks and spacing of PCIe capability definitions PCI: Remove obsolete comment reference to pci_pcie_cap2() PCI: Clarify PCI_EXP_TYPE_PCI_BRIDGE comment PCI: Rename PCIe capability definitions to follow convention PCI: Warn if unsafe MPS settings detected PCI: Fix MPS peer-to-peer DMA comment syntax PCI: Disable decoding for BAR sizing only when it was actually enabled PCI: Add comment about needing pci_msi_off() even when CONFIG_PCI_MSI=n PCI: Add pcibios_pm_ops for optional arch-specific hibernate functionality PCI: Don't restrict MPS for slots below Root Ports PCI: Simplify MPS test for Downstream Port PCI: Remove unnecessary check for pcie_get_mps() failure ...
2013-07-31parisc: Fix interrupt routing for C8000 serial portsThomas Bogendoerfer
We can't use dev->mod_index for selecting the interrupt routing entry, because it's not an index into interrupt routing table. It will be even wrong on a machine with 2 CPUs (4 cores). But all needed information is contained in the PAT entries for the serial ports. mod[0] contains the iosapic address and mod_info has some indications for the interrupt input (at least it looks like it). This patch implements the searching for the right iosapic and uses this interrupt input information. Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Cc: <stable@vger.kernel.org> # 3.10 Signed-off-by: Helge Deller <deller@gmx.de>
2013-07-25PCI: Delay enabling bridges until they're neededYinghai Lu
We currently enable PCI bridges after scanning a bus and assigning resources. This is often done in arch code. This patch changes this so we don't enable a bridge until necessary, i.e., until we enable a PCI device behind the bridge. We do this in the generic pci_enable_device() path, so this also removes the arch-specific code to enable bridges. [bhelgaas: changelog] Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2013-07-09parisc: fix LMMIO mismatch between PAT length and MASK registerHelge Deller
The LMMIO length reported by PAT and the length given by the LBA MASK register are not consistent. This leads e.g. to a not-working ATI FireGL card with the radeon DRM driver since the memory can't be mapped. Fix this by correctly adjusting the resource sizes. Signed-off-by: Helge Deller <deller@gmx.de> Cc: <stable@vger.kernel.org> # 3.10
2013-07-03Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull second set of VFS changes from Al Viro: "Assorted f_pos race fixes, making do_splice_direct() safe to call with i_mutex on parent, O_TMPFILE support, Jeff's locks.c series, ->d_hash/->d_compare calling conventions changes from Linus, misc stuff all over the place." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (63 commits) Document ->tmpfile() ext4: ->tmpfile() support vfs: export lseek_execute() to modules lseek_execute() doesn't need an inode passed to it block_dev: switch to fixed_size_llseek() cpqphp_sysfs: switch to fixed_size_llseek() tile-srom: switch to fixed_size_llseek() proc_powerpc: switch to fixed_size_llseek() ubi/cdev: switch to fixed_size_llseek() pci/proc: switch to fixed_size_llseek() isapnp: switch to fixed_size_llseek() lpfc: switch to fixed_size_llseek() locks: give the blocked_hash its own spinlock locks: add a new "lm_owner_key" lock operation locks: turn the blocked_list into a hashtable locks: convert fl_link to a hlist_node locks: avoid taking global lock if possible when waking up blocked waiters locks: protect most of the file_lock handling with i_lock locks: encapsulate the fl_link list handling locks: make "added" in __posix_lock_file a bool ...
2013-06-29eisa_eeprom: switch to fixed_size_llseek()Al Viro
2013-06-18parisc: fix serial ports on C8000 workstationThomas Bogendoerfer
The C8000 workstation (64 bit kernel only) has a somewhat different serial port configuration than other models. Thomas Bogendoerfer sent a patch to fix this in September 2010, which was now minimally modified by me. Signed-off-by: Thomas Bogendoerfer <tsbogend@alpha.franken.de> Signed-off-by: Helge Deller <deller@gmx.de>
2013-06-01parisc/PCI: lba: fix: convert to pci_create_root_bus() for correct root bus ↵Helge Deller
resources (v2) commit dc7dce280a Author: Bjorn Helgaas <bhelgaas@google.com> Date: Fri Oct 28 16:27:27 2011 -0600 parisc/PCI: lba: convert to pci_create_root_bus() for correct root bus resources Supply root bus resources to pci_create_root_bus() so they're correct immediately. This fixes the problem of "early" and "header" quirks seeing incorrect root bus resources. added tests for elmmio_space.start while it should use elmmio_space.flags. This for example led to incorrect resource assignments and a non-working stifb framebuffer on most parisc machines. LBA 10:1: PCI host bridge to bus 0000:01 pci_bus 0000:01: root bus resource [io 0x12000-0x13fff] (bus address [0x2000-0x3fff]) pci_bus 0000:01: root bus resource [mem 0xfffffffffa000000-0xfffffffffbffffff] (bus address [0xfa000000-0xfbffffff]) pci_bus 0000:01: root bus resource [mem 0xfffffffff4800000-0xfffffffff4ffffff] (bus address [0xf4800000-0xf4ffffff]) pci_bus 0000:01: root bus resource [??? 0x00000001 flags 0x0] Signed-off-by: Helge Deller <deller@gmx.de> Acked-by: Bjorn Helgaas <bhelgaas@google.com>
2013-06-01parisc/PCI: Set type for LBA bus_num resourceBjorn Helgaas
The non-PAT resource probing code failed to set the type of the LBA bus_num resource (30aa80da43 "parisc/PCI: register busn_res for root buses" did the corresponding thing for the PAT case). This causes incorrect resource assignments and a non-working stifb framebuffer on most parisc machines. Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Signed-off-by: Helge Deller <deller@gmx.de>
2013-05-24parisc/superio: Use module_pci_driver to register driverPeter Huewe
Removing some boilerplate by using module_pci_driver instead of calling register and unregister in the otherwise empty init/exit functions. Signed-off-by: Peter Huewe <peterhuewe@gmx.de> Signed-off-by: Helge Deller <deller@gmx.de>
2013-05-06parisc: fix partly 16/64k PAGE_SIZE bootHelge Deller
This patch fixes partly PAGE_SIZEs of 16K or 64K by adjusting the assembler PTE lookup code and the assembler TEMPALIAS code. Furthermore some data alignments for PAGE_SIZE have been limited to 4K (or less) to not waste too much memory with greater page sizes. As a side note, the palo loader can (currently) only handle up to 10 ELF segments which is fixed with tighter aligning as well. My testings indicated that the ldci command in the sba iommu coding needed adjustment by the PAGE_SHIFT value and that the I/O PDIR Page size was only set to 4K for my machine (C3000). All this fixes partly the boot, but there are still quite some caching problems left. Examples are e.g. the symbios logic driver which is failing: sym0: <896> rev 0x7 at pci 0000:00:0f.0 irq 69 sym0: PA-RISC Firmware, ID 7, Fast-40, SE, parity checking CACHE TEST FAILED: DMA error (dstat=0x81).sym0: CACHE INCORRECTLY CONFIGURED. and the tulip network driver which doesn't seem to work correctly either: Sending BOOTP requests .net eth0: Setting full-duplex based on MII#1 link partner capability of 05e1 ..... timed out! Beside those kernel fixes glibc will need fixes too to be able to handle >4K page sizes. Signed-off-by: Helge Deller <deller@gmx.de>
2013-04-09procfs: new helper - PDE_DATA(inode)Al Viro
The only part of proc_dir_entry the code outside of fs/proc really cares about is PDE(inode)->data. Provide a helper for that; static inline for now, eventually will be moved to fs/proc, along with the knowledge of struct proc_dir_entry layout. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-02-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs pile (part one) from Al Viro: "Assorted stuff - cleaning namei.c up a bit, fixing ->d_name/->d_parent locking violations, etc. The most visible changes here are death of FS_REVAL_DOT (replaced with "has ->d_weak_revalidate()") and a new helper getting from struct file to inode. Some bits of preparation to xattr method interface changes. Misc patches by various people sent this cycle *and* ocfs2 fixes from several cycles ago that should've been upstream right then. PS: the next vfs pile will be xattr stuff." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (46 commits) saner proc_get_inode() calling conventions proc: avoid extra pde_put() in proc_fill_super() fs: change return values from -EACCES to -EPERM fs/exec.c: make bprm_mm_init() static ocfs2/dlm: use GFP_ATOMIC inside a spin_lock ocfs2: fix possible use-after-free with AIO ocfs2: Fix oops in ocfs2_fast_symlink_readpage() code path get_empty_filp()/alloc_file() leave both ->f_pos and ->f_version zero target: writev() on single-element vector is pointless export kernel_write(), convert open-coded instances fs: encode_fh: return FILEID_INVALID if invalid fid_type kill f_vfsmnt vfs: kill FS_REVAL_DOT by adding a d_weak_revalidate dentry op nfsd: handle vfs_getattr errors in acl protocol switch vfs_getattr() to struct path default SET_PERSONALITY() in linux/elf.h ceph: prepopulate inodes only when request is aborted d_hash_and_lookup(): export, switch open-coded instances 9p: switch v9fs_set_create_acl() to inode+fid, do it before d_instantiate() 9p: split dropping the acls from v9fs_set_create_acl() ...
2013-02-22new helper: file_inode(file)Al Viro
2013-02-20parisc: led driver requires CONFIG_VM_EVENT_COUNTERSHelge Deller
LED activity is calculated out of the vm event counters wich are delivered through the all_vm_events() function which requires CONFIG_VM_EVENT_COUNTERS. Signed-off-by: Helge Deller <deller@gmx.de>
2013-02-20parisc: remove IRQF_DISABLEDPeter Zijlstra
People are playing odd games with IRQF_DISABLED, remove it. Its not reliable, since shared interrupt lines could disable it for you, and its possible and allowed for archs to disable IRQs to limit IRQ nesting. Therefore, simply mandate that _ALL_ IRQ handlers are run with IRQs disabled. [ This _should_ not break anything, since we've mandated that IRQ handlers _must_ be able to deal with this for a _long_ time ] IRQ handlers should be fast, no if buts and any other exceptions. We also have plenty instrumentation to find any offending IRQ latency sources. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Helge Deller <deller@gmx.de>
2013-02-20drivers/parisc/pdc_stable.c: use WARNJulia Lawall
Use WARN rather than printk followed by WARN_ON(1), for conciseness. Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Helge Deller <deller@gmx.de>
2013-02-20drivers/parisc: Use printf extension %pR for struct resourceJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Helge Deller <deller@gmx.de>
2013-01-03Drivers: misc: remove __dev* attributes.Greg Kroah-Hartman
CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit from these drivers. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-22parisc/PCI: Use list_for_each_entry() for bus->devices traversalBjorn Helgaas
Replace list_for_each() + pci_dev_b() with the simpler list_for_each_entry(). Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Yinghai Lu <yinghai@kernel.org> CC: linux-parisc@vger.kernel.org
2012-08-22parisc/PCI: Enable PERR/SERR on all devicesBjorn Helgaas
Previously, we enabled PERR & SERR for the first device on the bus, but left other devices alone. Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Yinghai Lu <yinghai@kernel.org> CC: linux-parisc@vger.kernel.org
2012-07-24Merge tag 'for-3.6' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pciLinus Torvalds
Pull PCI changes from Bjorn Helgaas: "Host bridge hotplug: - Add MMCONFIG support for hot-added host bridges (Jiang Liu) Device hotplug: - Move fixups from __init to __devinit (Sebastian Andrzej Siewior) - Call FINAL fixups for hot-added devices, too (Myron Stowe) - Factor out generic code for P2P bridge hot-add (Yinghai Lu) - Remove all functions in a slot, not just those with _EJx (Amos Kong) Dynamic resource management: - Track bus number allocation (struct resource tree per domain) (Yinghai Lu) - Make P2P bridge 1K I/O windows work with resource reassignment (Bjorn Helgaas, Yinghai Lu) - Disable decoding while updating 64-bit BARs (Bjorn Helgaas) Power management: - Add PCIe runtime D3cold support (Huang Ying) Virtualization: - Add VFIO infrastructure (ACS, DMA source ID quirks) (Alex Williamson) - Add quirks for devices with broken INTx masking (Jan Kiszka) Miscellaneous: - Fix some PCI Express capability version issues (Myron Stowe) - Factor out some arch code with a weak, generic, pcibios_setup() (Myron Stowe)" * tag 'for-3.6' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (122 commits) PCI: hotplug: ensure a consistent return value in error case PCI: fix undefined reference to 'pci_fixup_final_inited' PCI: build resource code for M68K architecture PCI: pciehp: remove unused pciehp_get_max_lnk_width(), pciehp_get_cur_lnk_width() PCI: reorder __pci_assign_resource() (no change) PCI: fix truncation of resource size to 32 bits PCI: acpiphp: merge acpiphp_debug and debug PCI: acpiphp: remove unused res_lock sparc/PCI: replace pci_cfg_fake_ranges() with pci_read_bridge_bases() PCI: call final fixups hot-added devices PCI: move final fixups from __init to __devinit x86/PCI: move final fixups from __init to __devinit MIPS/PCI: move final fixups from __init to __devinit PCI: support sizing P2P bridge I/O windows with 1K granularity PCI: reimplement P2P bridge 1K I/O windows (Intel P64H2) PCI: disable MEM decoding while updating 64-bit MEM BARs PCI: leave MEM and IO decoding disabled during 64-bit BAR sizing, too PCI: never discard enable/suspend/resume_early/resume fixups PCI: release temporary reference in __nv_msi_ht_cap_quirk() PCI: restructure 'pci_do_fixups()' ...
2012-06-13parisc/PCI: register busn_res for root busesYinghai Lu
Add the host bridge bus number aperture to the resource list. Like the MMIO and I/O port apertures, this is used when assigning resources to hot-added devices or in the case of conflicts. [bhelgaas: changelog, set flags directly, at LBA bus_num init] CC: Kyle McMartin <kyle@mcmartin.ca> CC: Helge Deller <deller@gmx.de> CC: linux-parisc@vger.kernel.org Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-06-13PCI: replace struct pci_bus secondary/subordinate with busn_resYinghai Lu
Replace the struct pci_bus secondary/subordinate members with the struct resource busn_res. Later we'll build a resource tree of these bus numbers. [bhelgaas: changelog] Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-06-05parisc: cleanup quoted includePaul Bolle
A quoted include starts with a superfluous "./". Clean up that quoted include. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-05-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial updates from Jiri Kosina: "As usual, it's mostly typo fixes, redundant code elimination and some documentation updates." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (57 commits) edac, mips: don't change code that has been removed in edac/mips tree xtensa: Change mail addresses of Hannes Weiner and Oskar Schirmer lib: Change mail address of Oskar Schirmer net: Change mail address of Oskar Schirmer arm/m68k: Change mail address of Sebastian Hess i2c: Change mail address of Oskar Schirmer net: Fix tcp_build_and_update_options comment in struct tcp_sock atomic64_32.h: fix parameter naming mismatch Kconfig: replace "--- help ---" with "---help---" c2port: fix bogus Kconfig "default no" edac: Fix spelling errors. qla1280: Remove redundant NULL check before release_firmware() call remoteproc: remove redundant NULL check before release_firmware() qla2xxx: Remove redundant NULL check before release_firmware() call. aic94xx: Get rid of redundant NULL check before release_firmware() call tehuti: delete redundant NULL check before release_firmware() qlogic: get rid of a redundant test for NULL before call to release_firmware() bna: remove redundant NULL test before release_firmware() tg3: remove redundant NULL test before release_firmware() call typhoon: get rid of redundant conditional before all to release_firmware() ...
2012-05-10parisc: move definition of PAGE0 to asm/page.hRolf Eike Beer
This was defined in asm/pdc.h which needs to include asm/page.h for __PAGE_OFFSET. This leads to an include loop so that page.h eventually will include pdc.h again. While this is no problem because of header guards, it is a problem because some symbols may be undefined. Such an error is this: In file included from include/linux/bitops.h:35:0, from include/asm-generic/getorder.h:7, from arch/parisc/include/asm/page.h:162, from arch/parisc/include/asm/pdc.h:346, from arch/parisc/include/asm/processor.h:16, from arch/parisc/include/asm/spinlock.h:6, from arch/parisc/include/asm/atomic.h:20, from include/linux/atomic.h:4, from include/linux/sysfs.h:20, from include/linux/kobject.h:21, from include/linux/device.h:17, from include/linux/eisa.h:5, from arch/parisc/kernel/pci.c:11: arch/parisc/include/asm/bitops.h: In function ‘set_bit’: arch/parisc/include/asm/bitops.h:82:2: error: implicit declaration of function ‘_atomic_spin_lock_irqsave’ [-Werror=implicit-function-declaration] arch/parisc/include/asm/bitops.h:84:2: error: implicit declaration of function ‘_atomic_spin_unlock_irqrestore’ [-Werror=implicit-function-declaration] Signed-off-by: Rolf Eike Beer <eike-kernel@sf-tec.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-04-08Merge branch 'master' into for-nextJiri Kosina
Merge with latest Linus' tree, as I have incoming patches that fix code that is newer than current HEAD of for-next. Conflicts: drivers/net/ethernet/realtek/r8169.c
2012-04-05parisc: Use vsprintf extention %pf with builtin_return_addressJoe Perches
Emit the function name not the address when possible. builtin_return_address() gives an address. When building a kernel with CONFIG_KALLSYMS, emit the actual function name not the address. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-03-28Merge tag 'split-asm_system_h-for-linus-20120328' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system Pull "Disintegrate and delete asm/system.h" from David Howells: "Here are a bunch of patches to disintegrate asm/system.h into a set of separate bits to relieve the problem of circular inclusion dependencies. I've built all the working defconfigs from all the arches that I can and made sure that they don't break. The reason for these patches is that I recently encountered a circular dependency problem that came about when I produced some patches to optimise get_order() by rewriting it to use ilog2(). This uses bitops - and on the SH arch asm/bitops.h drags in asm-generic/get_order.h by a circuituous route involving asm/system.h. The main difficulty seems to be asm/system.h. It holds a number of low level bits with no/few dependencies that are commonly used (eg. memory barriers) and a number of bits with more dependencies that aren't used in many places (eg. switch_to()). These patches break asm/system.h up into the following core pieces: (1) asm/barrier.h Move memory barriers here. This already done for MIPS and Alpha. (2) asm/switch_to.h Move switch_to() and related stuff here. (3) asm/exec.h Move arch_align_stack() here. Other process execution related bits could perhaps go here from asm/processor.h. (4) asm/cmpxchg.h Move xchg() and cmpxchg() here as they're full word atomic ops and frequently used by atomic_xchg() and atomic_cmpxchg(). (5) asm/bug.h Move die() and related bits. (6) asm/auxvec.h Move AT_VECTOR_SIZE_ARCH here. Other arch headers are created as needed on a per-arch basis." Fixed up some conflicts from other header file cleanups and moving code around that has happened in the meantime, so David's testing is somewhat weakened by that. We'll find out anything that got broken and fix it.. * tag 'split-asm_system_h-for-linus-20120328' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-asm_system: (38 commits) Delete all instances of asm/system.h Remove all #inclusions of asm/system.h Add #includes needed to permit the removal of asm/system.h Move all declarations of free_initmem() to linux/mm.h Disintegrate asm/system.h for OpenRISC Split arch_align_stack() out from asm-generic/system.h Split the switch_to() wrapper out of asm-generic/system.h Move the asm-generic/system.h xchg() implementation to asm-generic/cmpxchg.h Create asm-generic/barrier.h Make asm-generic/cmpxchg.h #include asm-generic/cmpxchg-local.h Disintegrate asm/system.h for Xtensa Disintegrate asm/system.h for Unicore32 [based on ver #3, changed by gxt] Disintegrate asm/system.h for Tile Disintegrate asm/system.h for Sparc Disintegrate asm/system.h for SH Disintegrate asm/system.h for Score Disintegrate asm/system.h for S390 Disintegrate asm/system.h for PowerPC Disintegrate asm/system.h for PA-RISC Disintegrate asm/system.h for MN10300 ...
2012-03-28Remove all #inclusions of asm/system.hDavid Howells
Remove all #inclusions of asm/system.h preparatory to splitting and killing it. Performed with the following command: perl -p -i -e 's!^#\s*include\s*<asm/system[.]h>.*\n!!' `grep -Irl '^#\s*include\s*<asm/system[.]h>' *` Signed-off-by: David Howells <dhowells@redhat.com>
2012-03-23Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci Pull PCI changes (including maintainer change) from Jesse Barnes: "This pull has some good cleanups from Bjorn and Yinghai, as well as some more code from Yinghai to better handle resource re-allocation when enabled. There's also a new initcall_debug feature from Arjan which will print out quirk timing information to help identify slow quirks for fixing or refinement (Yinghai sent in a few patches to do just that once the new debug code landed). Beyond that, I'm handing off PCI maintainership to Bjorn Helgaas. He's been a core PCI and Linux contributor for some time now, and has kindly volunteered to take over. I just don't feel I have the time for PCI review and work that it deserves lately (I've taken on some other projects), and haven't been as responsive lately as I'd like, so I approached Bjorn asking if he'd like to manage things. He's going to give it a try, and I'm confident he'll do at least as well as I have in keeping the tree managed, patches flowing, and keeping things stable." Fix up some fairly trivial conflicts due to other cleanups (mips device resource fixup cleanups clashing with list handling cleanup, ppc iseries removal clashing with pci_probe_only cleanup etc) * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci: (112 commits) PCI: Bjorn gets PCI hotplug too PCI: hand PCI maintenance over to Bjorn Helgaas unicore32/PCI: move <asm-generic/pci-bridge.h> include to asm/pci.h sparc/PCI: convert devtree and arch-probed bus addresses to resource powerpc/PCI: allow reallocation on PA Semi powerpc/PCI: convert devtree bus addresses to resource powerpc/PCI: compute I/O space bus-to-resource offset consistently arm/PCI: don't export pci_flags PCI: fix bridge I/O window bus-to-resource conversion x86/PCI: add spinlock held check to 'pcibios_fwaddrmap_lookup()' PCI / PCIe: Introduce command line option to disable ARI PCI: make acpihp use __pci_remove_bus_device instead PCI: export __pci_remove_bus_device PCI: Rename pci_remove_behind_bridge to pci_stop_and_remove_behind_bridge PCI: Rename pci_remove_bus_device to pci_stop_and_remove_bus_device PCI: print out PCI device info along with duration PCI: Move "pci reassigndev resource alignment" out of quirks.c PCI: Use class for quirk for usb host controller fixup PCI: Use class for quirk for ti816x class fixup PCI: Use class for quirk for intel e100 interrupt fixup ...
2012-02-27[PARISC] include <linux/prefetch.h> in drivers/parisc/iommu-helpers.hCong Wang
drivers/parisc/iommu-helpers.h:62: error: implicit declaration of function 'prefetchw' make[3]: *** [drivers/parisc/sba_iommu.o] Error 1 drivers/parisc/iommu-helpers.h needs to #include <linux/prefetch.h> where prefetchw is declared. Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: James Bottomley <JBottomley@Parallels.com>
2012-02-23parisc/PCI: get rid of device resource fixupsBjorn Helgaas
Tell the PCI core about host bridge address translation so it can take care of bus-to-resource conversion for us. CC: linux-parisc@vger.kernel.org Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-01-11Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci: (80 commits) x86/PCI: Expand the x86_msi_ops to have a restore MSIs. PCI: Increase resource array mask bit size in pcim_iomap_regions() PCI: DEVICE_COUNT_RESOURCE should be equal to PCI_NUM_RESOURCES PCI: pci_ids: add device ids for STA2X11 device (aka ConneXT) PNP: work around Dell 1536/1546 BIOS MMCONFIG bug that breaks USB x86/PCI: amd: factor out MMCONFIG discovery PCI: Enable ATS at the device state restore PCI: msi: fix imbalanced refcount of msi irq sysfs objects PCI: kconfig: English typo in pci/pcie/Kconfig PCI/PM/Runtime: make PCI traces quieter PCI: remove pci_create_bus() xtensa/PCI: convert to pci_scan_root_bus() for correct root bus resources x86/PCI: convert to pci_create_root_bus() and pci_scan_root_bus() x86/PCI: use pci_scan_bus() instead of pci_scan_bus_parented() x86/PCI: read Broadcom CNB20LE host bridge info before PCI scan sparc32, leon/PCI: convert to pci_scan_root_bus() for correct root bus resources sparc/PCI: convert to pci_create_root_bus() sh/PCI: convert to pci_scan_root_bus() for correct root bus resources powerpc/PCI: convert to pci_create_root_bus() powerpc/PCI: split PHB part out of pcibios_map_io_space() ... Fix up conflicts in drivers/pci/msi.c and include/linux/pci_regs.h due to the same patches being applied in other branches.
2012-01-06parisc/PCI: lba: convert to pci_create_root_bus() for correct root bus resourcesBjorn Helgaas
Supply root bus resources to pci_create_root_bus() so they're correct immediately. This fixes the problem of "early" and "header" quirks seeing incorrect root bus resources. CC: linux-parisc@vger.kernel.org Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2012-01-06parisc/PCI: lba: use pci_create_bus() instead of pci_scan_bus_parented()Bjorn Helgaas
No functional change here; just converting from pci_scan_bus_parented() to pci_create_bus() to make a future patch simpler. CC: linux-parisc@vger.kernel.org Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2012-01-06parisc/PCI: lba: deal with LMMIO/PAT overlaps before creating PCI root busBjorn Helgaas
This moves the truncate_pat_collision() call out of the pcibios_fixup_bus() path so that when a future patch builds a list of root bus resources for pci_create_bus(), it can use the truncated LMMIO range. truncate_pat_collision() used to be called in this path: pci_scan_bus_parented pci_create_bus pci_scan_child_bus pcibios_fixup_bus lba_fixup_bus truncate_pat_collision All of the PAT and lba_dev resource setup must be done before we call pci_scan_bus_parented(), so it should be safe to move the truncate_pat_collision() to just before pci_scan_bus_parented(). CC: linux-parisc@vger.kernel.org Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2012-01-06parisc/PCI: dino: convert to pci_create_root_bus() for correct root bus ↵Bjorn Helgaas
resources Supply root bus resources to pci_create_root_bus() so they're correct immediately. This fixes the problem of "early" and "header" quirks seeing incorrect root bus resources. CC: linux-parisc@vger.kernel.org Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2012-01-06parisc/PCI: dino: use pci_create_bus() instead of pci_scan_bus_parented()Bjorn Helgaas
2011-11-13Merge branch 'master' into for-nextJiri Kosina
Sync with Linus tree to have 157550ff ("mtd: add GPMI-NAND driver in the config and Makefile") as I have patch depending on that one.
2011-10-31parisc: add module.h to files really requiring itPaul Gortmaker
We want to clean up the implicit everywhere presence of module.h which means files like this that use module infrastructure need to explicitly call it out for inclusion. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31parisc: Add export.h to files needing EXPORT_SYMBOL/THIS_MODULEPaul Gortmaker
These guys were getting it implicitly via module.h before, when module.h was everywhere. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-29treewide: remove commented out Kconfig entriesPaul Bolle
These Kconfig entries have been commented out since (at least) v2.6.12-rc2 (the first commit of the git repository). There's no indication why they're commented out. They might as well be removed. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
