path: root/drivers/parport/parport_sunbpp.c
2014-10-20parport: drop owner assignment from platform_driversWolfram Sang
A platform_driver does not need to set an owner, it will be populated by the driver core. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2013-03-25parport: use kmemdup instead of kmalloc + memcpySilviu-Mihai Popescu
This replaces calls to kmalloc followed by memcpy with a single call to kmemdup. This was found via make coccicheck. Signed-off-by: Silviu-Mihai Popescu <silviupopescu1990@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-03Drivers: parport: remove __dev* attributes.Greg Kroah-Hartman
CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the use of __devinit, __devexit_p, __devinitdata, and __devexit from these drivers. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Cc: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Matt Porter <mporter@ti.com> Cc: Kay Sievers <kay@vrfy.org> Cc: Gianluca Anzolin <gianluca@sottospazio.it> Cc: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-20parport: remove unused dead code from lowlevel driversMatt Porter
This unused code has been untouched for over 7 years and must go. Signed-off-by: Matt Porter <mporter@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2011-11-30parport: convert drivers/parport/* to use module_platform_driver()Axel Lin
This patch converts the drivers in drivers/parport/* to use the module_platform_driver() macro which makes the code smaller and a bit simpler. Cc: Ben Dooks <ben@simtec.co.uk> Cc: Derrick J. Brashear <shadow@dementia.org> Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-28dt/sparc: Eliminate users of of_platform_{,un}register_driverGrant Likely
Get rid of old users of of_platform_driver in arch/sparc. Most of_platform_driver users can be converted to use the platform_bus directly. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-08-06of/device: Replace struct of_device with struct platform_deviceGrant Likely
of_device is just an alias for platform_device, so remove it entirely. Also replace to_of_device() with to_platform_device() and update comment blocks. This patch was initially generated from the following semantic patch, and then edited by hand to pick up the bits that coccinelle didn't catch. @@ @@ -struct of_device +struct platform_device Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Reviewed-by: David S. Miller <davem@davemloft.net>
2010-07-24of/platform: remove all of_bus_type and of_platform_bus_type referencesGrant Likely
Both of_bus_type and of_platform_bus_type are just #define aliases for the platform bus. This patch removes all references to them and switches to the of_register_platform_driver()/of_unregister_platform_driver() API for registering. Subsequent patches will convert each user of of_register_platform_driver() into plain platform_drivers without the of_platform_driver shim. At which point the of_register_platform_driver()/of_unregister_platform_driver() functions can be removed. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: David S. Miller <davem@davemloft.net>
2010-06-28sparc/of: Move of_device fields into struct pdev_archdataGrant Likely
This patch moves SPARC architecture specific data members out of struct of_device and into the pdev_archdata structure. The reason for this change is to unify the struct of_device definition amongst all the architectures. It also remvoes the .sysdata, .slot, .portid and .clock_freq properties because they aren't actually used by anything. A subsequent patch will replace struct of_device entirely with struct platform_device and the of_platform support code will share common routines with the platform bus (but the bus instances themselves can remain separate). This patch also adds 'struct resources *resource' and num_resources to match the fields defined in struct platform_device. After this change, 'struct platform_device' can be used as a drop-in replacement for 'struct of_platform'. This change is in preparation for merging the of_platform_bus_type with the platform_bus_type. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: David S. Miller <davem@davemloft.net> Cc: Stephen Rothwell <sfr@canb.auug.org.au>
2010-05-22of: Remove duplicate fields from of_platform_driverGrant Likely
.name, .match_table and .owner are duplicated in both of_platform_driver and device_driver. This patch is a removes the extra copies from struct of_platform_driver and converts all users to the device_driver members. This patch is a pretty mechanical change. The usage model doesn't change and if any drivers have been missed, or if anything has been fixed up incorrectly, then it will fail with a compile time error, and the fixup will be trivial. This patch looks big and scary because it touches so many files, but it should be pretty safe. Signed-off-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Sean MacLennan <smaclennan@pikatech.com>
2008-08-31sparc: Annotate of_device_id arrays with const or __initdata.David S. Miller
As suggested by Stephen Rothwell. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-29parport_sunbpp: Convert to pure OF driver.David S. Miller
2007-10-23[PARPORT] Consolidate code copies into a single generic irq handlerJeff Garzik
Several arches used the exact same code for their parport irq handling. Make that code generic, in parport_irq_handler(). Also, s/__inline__/inline/ in include/linux/parport.h. Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2007-05-08parport->dev driver model supportDavid Brownell
Currently a parport_driver can't get a handle on the device node for the underlying parport (PNPACPI, PCI, etc). That prevents correct placement of sysfs child nodes, which can affect things like power management. This patch adds a field to "struct parport" pointing to that device node, and updates non-legacy port drivers to initialize that device pointer. That field replaces the analagous PCI-only support in parport_pc. [akpm@linux-foundation.org: fix powerpc build] Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-23[PARPORT] SUNBPP: Fix OOPS when debugging is enabled.David S. Miller
The debugging code would dereference __iomem pointers instead of going through sbus_{read,write}{b,w,l}(). Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-08[PATCH] sparc32 pt_regs fixesAl Viro
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-07-02[PATCH] irq-flags: misc drivers: Use the new IRQF_ constantsThomas Gleixner
Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PARPORT] sunbpp: Fix typo.David S. Miller
2006-06-23[PARPORT] sunbpp: Convert to new SBUS device framework.David S. Miller
