path: root/drivers/parport/share.c
2009-06-02parport: quickfix the proc registration bugAlan Cox
Ideally we should have a directory of drivers and a link to the 'active' driver. For now just show the first device which is effectively the existing semantics without a warning. This is an update on the original buggy patch that I then forgot to resubmit. Confusingly it was proposed by Red Hat, written by Etched Pixels fixed and submitted by Intel ... Resolves-Bug: http://bugzilla.kernel.org/show_bug.cgi?id=9749 Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16parport: remove CVS keywordsAdrian Bunk
Remove CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-23[PARPORT] Remove unused 'irq' argument from parport irq functionsJeff Garzik
None of the drivers with a struct pardevice's ->irq_func() hook ever used the 'irq' argument passed to it, so remove it. Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2007-10-23[PARPORT] Kill useful 'irq' arg from parport_{generic_irq,ieee1284_interrupt}Jeff Garzik
parport_ieee1284_interrupt() was not using its first arg at all. Delete. parport_generic_irq()'s second arg makes its first arg completely redundant. Delete, and use port->irq in the one place where we actually need it. Also, s/__inline__/inline/ to make the code look nicer. Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2007-10-23[PARPORT] Consolidate code copies into a single generic irq handlerJeff Garzik
Several arches used the exact same code for their parport irq handling. Make that code generic, in parport_irq_handler(). Also, s/__inline__/inline/ in include/linux/parport.h. Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2007-05-08parport->dev driver model supportDavid Brownell
Currently a parport_driver can't get a handle on the device node for the underlying parport (PNPACPI, PCI, etc). That prevents correct placement of sysfs child nodes, which can affect things like power management. This patch adds a field to "struct parport" pointing to that device node, and updates non-legacy port drivers to initialize that device pointer. That field replaces the analagous PCI-only support in parport_pc. [akpm@linux-foundation.org: fix powerpc build] Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-06-25[PATCH] parport: add to kernel-docRandy Dunlap
Add parport interfaces to kernel-doc template. Small doc. cleanups in 2 parport source files. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] sem2mutex: misc static one-file mutexesIngo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Dave Jones <davej@codemonkey.org.uk> Cc: Paul Mackerras <paulus@samba.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Jens Axboe <axboe@suse.de> Cc: Neil Brown <neilb@cse.unsw.edu.au> Acked-by: Alasdair G Kergon <agk@redhat.com> Cc: Greg KH <greg@kroah.com> Cc: Dominik Brodowski <linux@dominikbrodowski.net> Cc: Adam Belay <ambx1@neo.rr.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] parport: export parport_get_port()Marko Kohtala
Help external ppSCSI driver by exporting parport_get_port to match the parport_put_port. Signed-off-by: Marko Kohtala <marko.kohtala@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] kfree cleanup: misc remaining driversJesper Juhl
This is the remaining misc drivers/ part of the big kfree cleanup patch. Remove pointless checks for NULL prior to calling kfree() in misc files in drivers/. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Acked-by: Aristeu Sergio Rozanski Filho <aris@cathedrallabs.org> Acked-by: Roland Dreier <rolandd@cisco.com> Acked-by: Pierre Ossman <drzeus@drzeus.cx> Acked-by: Jean Delvare <khali@linux-fr.org> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Len Brown <len.brown@intel.com> Acked-by: "Antonino A. Daplas" <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
