This patch fixes array subscription bugs in the parport_pc driver.
drivers/parport/parport_pc.c: In function ‘parport_irq_probe’:
drivers/parport/parport_pc.c:1589: warning: array subscript is above array bounds
drivers/parport/parport_pc.c: In function ‘parport_pc_probe_port’:
drivers/parport/parport_pc.c:1579: warning: array subscript is above array bounds
The patch also fixes a few other array bugs, which the compiler was
unable to find. Coding style violations are also fixed.
Signed-off-by: Michael Buesch <mb@bu3sch.de>
Signed-off-by: Alan Cox <alan@linux.intel.com>
Ideally we should have a directory of drivers and a link to the 'active'
driver. For now just show the first device which is effectively the existing
semantics without a warning.
This is an update on the original buggy patch that I then forgot to
resubmit. Confusingly it was proposed by Red Hat, written by Etched Pixels
fixed and submitted by Intel ...
Resolves-Bug: http://bugzilla.kernel.org/show_bug.cgi?id=9749
drivers/parport/parport_gsc.c:356: warning: format '%lx' expects type
'long unsigned int', but argument 2 has type 'resource_size_t'
[akpm@linux-foundation.org: fix it to handle u64's]
Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com>
PCI parallel port devices can IRQ share so we should stop them hogging
the line and making a mess on modern PC systems. We know the sharing
side works as the PCMCIA driver has shared the parallel port IRQ for
some time.
Signed-off-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
netmos serial/parallel adapters come in different flavour differing only
by the number of parallel and serial ports, which are encoded in the
subdevice ID.
Last fix of Christian Pellegrin for 9855 2P2S broke support for 9855 1P4S,
and works only by side-effect for the first parallel port of a 2P2S, as
this first parallel port is found by reading the second addr entry of
(struct parport_pc_pci) cards[netmos_9855], which is not initialized, and
hence has value 0, which happens to be the BAR of the first parallel port.
netmos_9xx5_combo entry in (struct parport_pc_pci) cards[], which is used
for a 9845 1P4S must also be fixed for the parallel port support when
there are 4 serial ports because this entry currently gives 2 as BAR index
for the parallel port. Actually, in this case, BAR 2 is the 3rd serial
port while the parallel port is at BAR 4.
I fixed 9845 1P4S and 9855 1P4S support, while preserving 9855 2P2S support,
- by creating a netmos_9855_2p entry and using it for 9855 boards with 2
parallel ports : 9855 2P2S and 9855 2P0S boards,
- and by allowing netmos_parallel_init to change not only the number of
parallel ports (0 or 1), but making it also change the BAR index of the
parallel port when the serial ports are before the parallel port.
PS: the netmos_9855_2p entry in (struct pciserial_board)
pci_parport_serial_boards[] is needed because netmos_parallel_init has no
clean way to replace FL_BASE2 by FL_BASE4 in the description of the serial
ports in function of the number of parallel ports on the card.
Tested with 9845 1P4S, 9855 1P4S and 9855 2P2S boards.
Signed-off-by: Philippe De Muyter <phdm@macqel.be>
Tested-by: Christian Pellegrin <chripell@fsfe.org>
http://kisskb.ellerman.id.au/kisskb/buildresult/72115/:
| net/mac80211/ieee80211_i.h:327: error: syntax error before 'volatile'
| net/mac80211/ieee80211_i.h:350: error: syntax error before '}' token
| net/mac80211/ieee80211_i.h:455: error: field 'sta' has incomplete type
| distcc[19430] ERROR: compile net/mac80211/main.c on sprygo/32 failed
This is caused by
| # define mfp ((*(volatile struct MFP*)MFP_BAS))
in arch/m68k/include/asm/atarihw.h, which conflicts with the new "mfp" enum in
net/mac80211/ieee80211_i.h.
Rename "mfp" to "st_mfp", as it's a way too generic name for a global #define.
Since netmos 9835 with subids 0x1014(IBM):0x0299 is now bound with
serial/8250_pci, because it has no parallel ports and subdevice id isn't
in the expected form, return -ENODEV from probe function.
This is performed in netmos preinit_hook.
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
Use del_timer_sync() instead of del_timer() to make sure the timer won't
be running when we return from parport_wait_event(), because this would
crash due to destruction of timer_list.
This is untested and just based on a code review. Just think about the
following sequence of events:
- add_timer()
- down_interruptible() is interrupted by a signal.
- we enter the timer callback handler on another CPU.
- del_timer(), but the timer callback is still running.
- eturn from parport_wait_even, which destroys the automatic variable
"timer" while the callback is running on another CPU.
The netmos_9xx5_combo type assumes that PCI SSID provides always the
correct value for the number of parallel and serial ports, but there are
indeed broken devices with wrong numbers, which may result in Oops.
This patch simply adds the check of the array range.
Reference: Novell bnc#447067
https://bugzilla.novell.com/show_bug.cgi?id=447067
Cc: <stable@kernel.org>
Signed-off-by: Mike Frysinger <vapier.adi@gmail.com>
Signed-off-by: Bryan Wu <cooloney@kernel.org>
* git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6:
fdomain_cs: Sort out modules with duplicate description
pcmcia: Whine harder about use of EXCLUSIVE
pcmcia: IRQ_TYPE_EXCLUSIVE is long obsoleted
Add support for the OxSemi 'Tornado' devices.
Reformatted and reworked a bit by Alan Cox
Signed-off-by: Lee Howard <lee.howard@mainpine.com>
Signed-off-by: Alan Cox <alan@redhat.com>
Switch more drivers to dynamic sharing after checking their IRQ handlers
use dev_id and are robust
Acked-by: Marcel Holtmann <marcel@holtmann.org>
Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
Remove CVS keywords that weren't updated for a long time from comments.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
People can use the real name an an index into MAINTAINERS to find the
current email address.
Signed-off-by: Francois Cami <francois.cami@free.fr>
* git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6: (49 commits)
pcmcia: ioctl-internal definitions
pcmcia: cistpl header cleanup
pcmcia: remove unused argument to pcmcia_parse_tuple()
pcmcia: card services header cleanup
pcmcia: device_id header cleanup
pcmcia: encapsulate ioaddr_t
pcmcia: cleanup device driver header file
pcmcia: cleanup socket services header file
pcmcia: merge ds_internal.h into cs_internal.h
pcmcia: cleanup cs_internal.h
pcmcia: cs_internal.h is internal
pcmcia: use dev_printk for cs_error()
pcmcia: remove CS_ error codes alltogether
pcmcia: deprecate CS_BAD_TUPLE
pcmcia: deprecate CS_BAD_ARGS
pcmcia: deprecate CS_BAD_BASE, CS_BAD_IRQ, CS_BAD_OFFSET and CS_BAD_SIZE
pcmcia: deprecate CS_BAD_ATTRIBUTE, CS_BAD_TYPE and CS_BAD_PAGE
pcmcia: deprecate CS_NO_MORE_ITEMS
pcmcia: deprecate CS_IN_USE
pcmcia: deprecate CS_CONFIGURATION_LOCKED
Fix trivial conflict in drivers/pcmcia/ds.c manually
As suggested by Stephen Rothwell.
By passing the current Vcc setting to the pcmcia_config_loop callback
function, we can remove pcmcia_get_configuration_info() calls from many
drivers.
Many drivers use the default CIS entry within their pcmcia_config_loop()
callback function. Therefore, factor the default CIS entry handling out.
Almost all drivers set p_dev->conf.ConfigIndex to cfg->index in
the pcmcia_config_loop() callback function. Therefore, factor it out.
Use the config loop helper in misc pcmcia drivers.
CC: Harald Welte <laforge@gnumonks.org>
CC: <linux-parport@lists.infradead.org>
CC: Russell King <rmk+kernel@arm.linux.org.uk>
CC: Ed Okerson <eokerson@quicknet.net>
CC: linux-serial@vger.kernel.org
CC: boti@rocketmail.com
CC: linux-usb@vger.kernel.org
This patch makes the needlessly global parport_cs_release() static.
Use the 2nd BAR for the oxsemi_840 chip as BAR for base_hi. Tested with:
Parallel controller [0701]: Oxford Semiconductor Ltd VScom 011H-EP1
1 port parallel adaptor [1415:8403] (prog-if 03 [IEEE1284])
This patch is needed to make 'TRISTATE' work with that adaptor.
Signed-off-by: Bernhard Walle <bwalle@suse.de>
Signed-off-by: Andre Haupt <andre@bitwigglers.org>
This patch adds proper externs for parport_default_timeslice and
parport_default_spintime in include/linux/parport.h
Since 43cc71eed1250755986da4c0f9898f9a635cb3bf (platform: prefix MODALIAS
with "platform:"), the platform modalias is prefixed with "platform:".
Add MODULE_ALIAS() to the hotpluggable parport platform drivers, to
re-enable auto loading.
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
Cc: Greg KH <greg@kroah.com>
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
Acked-by: Ben Dooks <ben-linux@fluff.org>
Add calls to the generic object debugging infrastructure and provide fixup
functions which allow to keep the system alive when recoverable problems have
been detected by the object debugging core code.
Cc: Randy Dunlap <randy.dunlap@oracle.com>
Cc: Kay Sievers <kay.sievers@vrfy.org>
__FUNCTION__ is gcc-specific, use __func__
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Cc: Ben Dooks <ben-linux@fluff.org>
Wrap PNP probe code in #ifdef CONFIG_PNP. We already do the same for
CONFIG_PCI.
Without this change, we'll have unresolved references to pnp_get_resource()
function when CONFIG_PNP=n. (This is a new interface that's not in mainline
yet.)
Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com>
This patch fixes the following compile error:
<-- snip -->
CC [M] drivers/parport/parport_pc.o
/home/bunk/linux/kernel-2.6/git/linux-2.6/drivers/parport/parport_pc.c:67:25: error: asm/parport.h: No such file or directory
/home/bunk/linux/kernel-2.6/git/linux-2.6/drivers/parport/parport_pc.c: In function 'parport_pc_find_ports':
/home/bunk/linux/kernel-2.6/git/linux-2.6/drivers/parport/parport_pc.c:3215: error: implicit declaration of function 'parport_pc_find_nonpci_ports'
make[3]: *** [drivers/parport/parport_pc.o] Error 1
<-- snip -->
Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
Commit f63fd7e299ee13da071ecfce2b90b58c5e1562b1 ("parport_pc: detection
for SuperIO IT87XX POST") only released the IO port region on success,
not when the probe for the IT87XX chip failed.
That caused not only a reserved region to leak, but also caused an oops
when the driver module was unloaded and somebody tried to cat
/proc/ioports - because the string that was assigned to the IO port
region was a static string in the module virtual address area.
Reported-by: Lubos Lunak <l.lunak@suse.cz>
Cc: Jan Kara <jack@suse.cz>
Cc: Petr Cvek <petr.cvek@tul.cz>
Acked-by: Andrew Morton <akpm@linux-foundation.org>
Fix section warning for parport_ECP_supported(); it's called from a routine
exported to modules, so it can't be removed with __devinit section pruning.
We bought cheap notebooks to control our custom data acquisition system, which
requires EPP mode (read/write, data/addr). The bios does not offer EPP mode,
and indeed hardware EPP mode appears not to work, although the parport driver
tries to use it. EPPSWE mode does work for data r/w and addr write, but addr
read requires this patch.
(stephan)rshgse3: lspci
00:00.0 Host bridge: Intel Corporation Mobile 945GM/PM/GMS/940GML and 945GT Express Memory Controller Hub (rev 03)
00:02.0 VGA compatible controller: Intel Corporation Mobile 945GM/GMS/940GML Express Integrated Graphics Controller (rev 03)
00:02.1 Display controller: Intel Corporation Mobile 945GM/GMS/940GML Express Integrated Graphics Controller (rev 03)
00:1b.0 Audio device: Intel Corporation 82801G (ICH7 Family) High Definition Audio Controller (rev 02)
00:1c.0 PCI bridge: Intel Corporation 82801G (ICH7 Family) PCI Express Port 1 (rev 02)
00:1c.1 PCI bridge: Intel Corporation 82801G (ICH7 Family) PCI Express Port 2 (rev 02)
00:1c.2 PCI bridge: Intel Corporation 82801G (ICH7 Family) PCI Express Port 3 (rev 02)
00:1d.0 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI #1 (rev 02)
00:1d.1 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI #2 (rev 02)
00:1d.2 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI #3 (rev 02)
00:1d.3 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI #4 (rev 02)
00:1d.7 USB Controller: Intel Corporation 82801G (ICH7 Family) USB2 EHCI Controller (rev 02)
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev e2)
00:1f.0 ISA bridge: Intel Corporation 82801GBM (ICH7-M) LPC Interface Bridge (rev 02)
00:1f.1 IDE interface: Intel Corporation 82801G (ICH7 Family) IDE Controller (rev 02)
00:1f.2 SATA controller: Intel Corporation 82801GBM/GHM (ICH7 Family) Serial ATA Storage Controller AHCI (rev 02)
00:1f.3 SMBus: Intel Corporation 82801G (ICH7 Family) SMBus Controller (rev 02)
02:00.0 Ethernet controller: Marvell Technology Group Ltd. 88E8055 PCI-E Gigabit Ethernet Controller (rev 12)
05:00.0 Network controller: Intel Corporation PRO/Wireless 3945ABG Network Connection (rev 02)
08:03.0 CardBus bridge: Ricoh Co Ltd RL5c476 II (rev b3)
08:03.1 FireWire (IEEE 1394): Ricoh Co Ltd R5C552 IEEE 1394 Controller (rev 08)
08:03.2 Generic system peripheral [0805]: Ricoh Co Ltd R5C822 SD/SDIO/MMC/MS/MSPro Host Adapter (rev 17)
(stephan)rshgse3: grep . /proc/sys/dev/parport/parport0/*
/proc/sys/dev/parport/parport0/base-addr:888 1912
/proc/sys/dev/parport/parport0/dma:-1
/proc/sys/dev/parport/parport0/irq:7
/proc/sys/dev/parport/parport0/modes:PCSPP,TRISTATE,EPP
/proc/sys/dev/parport/parport0/spintime:500
Add architecture support for the MN10300/AM33 CPUs produced by MEI to the
kernel.
This patch also adds board support for the ASB2303 with the ASB2308 daughter
board, and the ASB2305. The only processor supported is the MN103E010, which
is an AM33v2 core plus on-chip devices.
[akpm@linux-foundation.org: nuke cvs control strings]
Signed-off-by: Masakazu Urade <urade.masakazu@jp.panasonic.com>
Signed-off-by: Koichi Yasutake <yasutake.koichi@jp.panasonic.com>
Add detection for IT87XX SuperIO chip and disabling its POST feature, which
made noise on parallel port's pins.
Signed-off-by: Petr Cvek <petr.cvek@tul.cz>
Fix wrong netmos 9855 serial port configuration.
On loading only one serial port was present and it wasn't working. After
looking in the data sheet I realized that the base address was wrong. For
further reference here is lspci and relevant dmesg output:
02:00.0 Communication controller: NetMos Technology PCI 9855 Multi-I/O
Controller (rev 01) (prog-if 02)
Subsystem: LSI Logic / Symbios Logic Unknown device 0022
Flags: medium devsel, IRQ 19
I/O ports at df00 [size=8]
I/O ports at de00 [size=8]
I/O ports at dd00 [size=8]
I/O ports at dc00 [size=8]
I/O ports at db00 [size=8]
I/O ports at da00 [size=16]
parport1: PC-style at 0xdd00 [PCSPP,TRISTATE]
parport2: PC-style at 0xdf00 [PCSPP,TRISTATE,EPP]
0000:02:00.0: ttyS0 at I/O 0xdb00 (irq = 19) is a 16550A
0000:02:00.0: ttyS1 at I/O 0xda00 (irq = 19) is a 16550A
Signed-off-by: Christian Pellegrin <chripell@fsfe.org>
Cc: Thomas Richter <thor@math.TU-Berlin.DE>
Cc: Bjorn Helgaas <bjorn.helgaas@hp.com>
Cc: Martin Schitter <ms@gewi.kfunigraz.ac.at>
Added pci device id for the Quatech SPPXP-100 ExpressCard - 0x278 - to
include/linux/pci_id.h
Modified drivers/parport/parport_pc.c to support the Quatech SPPXP-100 Parallel port PCI ExpressCard
[akpm@linux-foundation.org: build fix]
Signed-off-by: Luís P Mendes <luis.p.mendes@gmail.com>
Signed-off-by: Paulius Zaleckas <pauliusz@yahoo.com>
While auditing proc_doulongvec_ms_jiffies_minmax() usage in kernel, I found
a bug in drivers/parport/procfs.c, incorrectly using sizeof(int) instead of
sizeof(unsigned long)
Only 64bit arches are affected by this old bug.
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com>
None of the drivers with a struct pardevice's ->irq_func() hook ever
used the 'irq' argument passed to it, so remove it.
parport_ieee1284_interrupt() was not using its first arg at all.
Delete.
parport_generic_irq()'s second arg makes its first arg completely
redundant. Delete, and use port->irq in the one place where we actually
need it.
Also, s/__inline__/inline/ to make the code look nicer.
Several arches used the exact same code for their parport irq handling.
Make that code generic, in parport_irq_handler().
Also, s/__inline__/inline/ in include/linux/parport.h.
The sysctl binary paths don't look as if they even code work, .data is not
filled in, and all of the proc_handlers look at extra1 and there is not
strategy routine.
So just kill the binary paths.
In addition this patch removes the setting of extra1 on directories. It
doesn't look like the parport code ever examines it, and it's bad sysctl form.
[bunk@kernel.org: remove parport_device_num()]
http://bugzilla.kernel.org/show_bug.cgi?id=8821 reports a might_sleep()
warning due to parport_pc_exit() running platform_device_unregister() while
holding ports_lock.
Just remove the locking: nobody else can access ports_list during module_exit.
Cc: "Mike Sharkey" <mike@pikeaero.com>
Cc: Tim Waugh <tim@cyberelk.net>
Cc: Stas Sergeev <stsp@aknet.ru>
anything that wants working dma-mapping won't work
parport_pc won't work on m68k unless we have ISA
Transform some calls to kmalloc/memset to a single kzalloc (or kcalloc).
Here is a short excerpt of the semantic patch performing
this transformation:
type T2;
expression x;
identifier f,fld;
expression E;
expression E1,E2;
expression e1,e2,e3,y;
statement S;
x =
- kmalloc
+ kzalloc
(E1,E2)
... when != \(x->fld=E;\|y=f(...,x,...);\|f(...,x,...);\|x=E;\|while(...) S\|for(e1;e2;e3) S\)
- memset((T2)x,0,E1);
expression E1,E2,E3;
- kzalloc(E1 * E2,E3)
+ kcalloc(E1,E2,E3)
[akpm@linux-foundation.org: get kcalloc args the right way around]
Signed-off-by: Yoann Padioleau <padator@wanadoo.fr>
Cc: Richard Henderson <rth@twiddle.net>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Acked-by: Russell King <rmk@arm.linux.org.uk>
Cc: Bryan Wu <bryan.wu@analog.com>
Acked-by: Jiri Slaby <jirislaby@gmail.com>
Cc: Dave Airlie <airlied@linux.ie>
Acked-by: Roland Dreier <rolandd@cisco.com>
Cc: Jiri Kosina <jkosina@suse.cz>
Acked-by: Dmitry Torokhov <dtor@mail.ru>
Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org>
Acked-by: Pierre Ossman <drzeus-list@drzeus.cx>
Cc: Jeff Garzik <jeff@garzik.org>
Acked-by: Greg KH <greg@kroah.com>
Cc: James Bottomley <James.Bottomley@steeleye.com>
Cc: "Antonino A. Daplas" <adaplas@pol.net>
The IO port range requested by parport_pc.c:sio_ite_8872_probe is too small.
The IO-ports of ttyS1 (0x2f8) will be missconfigured by the ITE-chip. The ITE
starts looking for the chip a 0x2a0. An IO-portrange of 32 will not overwrite
the ports of ttyS1. Therefore register 0x60 should be written with
0xe5000000, enabling the ITE and setting IO-portsize to 32 bytes.
Use menuconfigs instead of menus, so the whole menu can be disabled at once
instead of going through all options.
Signed-off-by: Jan Engelhardt <jengelh@gmx.de>
Signed-off-by: Helge Deller <deller@gmx.de>
Signed-off-by: Kyle McMartin <kyle@parisc-linux.org>
