git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6
* 'tty-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: (48 commits)
serial: 8250_pci: add support for Cronyx Omega PCI multiserial board.
tty/serial: Fix break handling for PORT_TEGRA
tty/serial: Add explicit PORT_TEGRA type
n_tracerouter and n_tracesink ldisc additions.
Intel PTI implementaiton of MIPI 1149.7.
Kernel documentation for the PTI feature.
export kernel call get_task_comm().
tty: Remove to support serial for S5P6442
pch_phub: Support new device ML7223
8250_pci: Add support for the Digi/IBM PCIe 2-port Adapter
ASoC: Update cx20442 for TTY API change
pch_uart: Support new device ML7223 IOH
parport: Use request_muxed_region for IT87 probe and lock
tty/serial: add support for Xilinx PS UART
n_gsm: Use print_hex_dump_bytes
drivers/tty/moxa.c: Put correct tty value
TTY: tty_io, annotate locking functions
TTY: serial_core, remove superfluous set_task_state
TTY: serial_core, remove invalid test
Char: moxa, fix locking in moxa_write
Fix up trivial conflicts in drivers/bluetooth/hci_ldisc.c and
drivers/tty/serial/Makefile.
I did the hci_ldisc thing as an evil merge, cleaning things up.
This is needed as part of making the various IT87 drivers actually co-exist
politely with each other, and with other superio devices that may be muxed
on 0x2E/0x2F.
It can be applied before or after the other patches by Nat Gurumoorthy without
problem.
Signed-off-by: Alan Cox <alan@linux.intel.com>
Replace release_resource() by release_region() and also fix the
inconsistency in the size of the requested/released region.
The size of the resource should be 32, not 0x8 like it was corrected in
commit e7c310c36e5fdf1b83a459e5db167bfbd86137db already.
CC: linux-serial@vger.kernel.org
Reported-by: Julia Lawall <julia@diku.dk>
Signed-off-by: Niels de Vos <ndevos@redhat.com>
Get rid of old users of of_platform_driver in arch/sparc. Most
of_platform_driver users can be converted to use the platform_bus
directly.
parport_unregister_device() should never be used when interrupts are
enabled in hardware and irq handler is registered so there is no need to
disable interrupts when using waitlist_lock. But there is no way to
explain this subtle semantics to lockdep analyzer.
So disable interrupts here too to simplify things. The price is
negligible.
Signed-off-by: Alexander Gordeev <lasaine@lvk.cs.msu.su>
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
Update broken web addresses in arch directory.
Update broken web addresses in the kernel.
Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget
Revert "Fix typo: configuation => configuration" partially
ida: document IDA_BITMAP_LONGS calculation
ext2: fix a typo on comment in ext2/inode.c
drivers/scsi: Remove unnecessary casts of private_data
drivers/s390: Remove unnecessary casts of private_data
net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data
drivers/infiniband: Remove unnecessary casts of private_data
drivers/gpu/drm: Remove unnecessary casts of private_data
kernel/pm_qos_params.c: Remove unnecessary casts of private_data
fs/ecryptfs: Remove unnecessary casts of private_data
fs/seq_file.c: Remove unnecessary casts of private_data
arm: uengine.c: remove C99 comments
arm: scoop.c: remove C99 comments
Fix typo configue => configure in comments
Fix typo interrest[ing|ed] => interest[ing|ed]
Fix various typos of valid in comments
Fix up trivial conflicts in:
drivers/char/ipmi/ipmi_si_intf.c
drivers/usb/gadget/rndis.c
net/irda/irnet/irnet_ppp.c
* git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6: (22 commits)
pcmcia: synclink_cs: fix information leak to userland
pcmcia: don't call flush_scheduled_work() spuriously
serial_cs: drop spurious flush_scheduled_work() call
pcmcia/yenta: guide users in case of problems with O2-bridges
pcmcia: fix unused function compile warning
pcmcia: vrc4173_cardu: Fix error path for pci_release_regions and pci_disable_device
pcmcia: add a few debug statements
pcmcia: remove obsolete and wrong comments
pcmcia: avoid messages on module (un)loading
pcmcia: move driver name to struct pcmcia_driver
pcmcia: remove the "Finally, report what we've done" message
pcmcia: use autoconfiguration feature for ioports and iomem
pcmcia: introduce autoconfiguration feature
pcmcia: Documentation update
pcmcia: convert pcmcia_request_configuration to pcmcia_enable_device
pcmcia: move config_{base,index,regs} to struct pcmcia_device
pcmcia: simplify IntType
pcmcia: simplify Status, ExtStatus register access
pcmcia: remove Pin, Copy configuration register access
pcmcia: move Vpp setup to struct pcmcia_device
Get rid of init_MUTEX[_LOCKED]() and use sema_init() instead.
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
LKML-Reference: <20100907125055.743613774@linutronix.de>
What's worse than no comment? A wrong comment.
Several PCMCIA device drivers contained the same comments, which
were based on how the PCMCIA subsystem worked in the old days of 2.4.,
and which were originally part of a "dummy_cs" driver. These comments
no longer matched at all what is happening now, and therefore should
be removed.
Tested-by: Wolfram Sang <w.sang@pengutronix.de>
Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
When CONF_AUTO_SET_IO or CONF_AUTO_SET_IOMEM are set, the corresponding
fields in struct pcmcia_device *p_dev->resource[0,1,2] are set
accordinly. Drivers wishing to override certain settings may do so in
the callback function, but they no longer need to parse the CIS entries
stored in cistpl_cftable_entry_t themselves.
CC: netdev@vger.kernel.org
CC: linux-wireless@vger.kernel.org
CC: linux-ide@vger.kernel.org
CC: linux-usb@vger.kernel.org
CC: laforge@gnumonks.org
CC: linux-mtd@lists.infradead.org
CC: linux-bluetooth@vger.kernel.org
CC: alsa-devel@alsa-project.org
CC: Jiri Kosina <jkosina@suse.cz>
CC: linux-scsi@vger.kernel.org
Introduce an autoconfiguration feature to set certain values in
pcmcia_loop_config(), instead of copying the same code over and over
in each PCMCIA driver. At first, introduce the following options:
CONF_AUTO_CHECK_VCC check or matching Vcc entry
CONF_AUTO_SET_VPP set Vpp
CONF_AUTO_AUDIO enable the speaker line
Acked-by: Gustavo F. Padovan <padovan@profusion.mobi> (for drivers/bluetooth)
pcmcia_enable_device() now replaces pcmcia_request_configuration().
Instead of config_req_t, all necessary flags are either passed as
a parameter to pcmcia_enable_device(), or (in rare circumstances)
set in struct pcmcia_device -> flags.
With the last remaining user of include/pcmcia/cs.h gone, remove
all references.
Several drivers prefer to explicitly set config_{base,index,regs},
formerly known as ConfigBase, ConfigIndex and Present. Instead of
passing these values inside config_req_t, store it in struct
pcmcia_device.
IntType was only set to INT_MEMORY (driver pcmciamtd) or INT_MEMORY_AND_IO
(all other drivers). As this flags seems to relate to ioport access, make
it conditional to the driver having requested IO port access. There are two
drivers which do not request IO ports, but did set INT_MEMORY_AND_IO:
ray_cs and b43. For those, we consistently only set INT_MEMORY in future.
The printk message for the 2 serial port version is obscured with a debug
macro, unlike all other versions of the card. It should be changed to make
the output equal for all detected models.
Reference: https://bugzilla.redhat.com/show_bug.cgi?id=578616#c1
CC: Joe Krahn <krahn@niehs.nih.gov>
* 'next-devicetree' of git://git.secretlab.ca/git/linux-2.6:
mmc_spi: Fix unterminated of_match_table
of/sparc: fix build regression from of_device changes
of/device: Replace struct of_device with struct platform_device
Commit 51dcdfe ("parport: Use the PCI IRQ if offered") added IRQ support
for PCI parallel port devices handled by parport_pc, but turned it off for
parport_serial, despite a printk() message to the contrary.
Signed-off-by: Fr?d?ric Bri?re <fbriere@fbriere.net>
pcmcia: avoid buffer overflow in pcmcia_setup_isa_irq
pcmcia: do not request windows if you don't need to
pcmcia: insert PCMCIA device resources into resource tree
pcmcia: export resource information to sysfs
pcmcia: use struct resource for PCMCIA devices, part 2
pcmcia: remove memreq_t
pcmcia: move local definitions out of include/pcmcia/cs.h
pcmcia: do not use io_req_t when calling pcmcia_request_io()
pcmcia: do not use io_req_t after call to pcmcia_request_io()
pcmcia: clean up cs.h
pcmcia: use pcmica_{read,write}_config_byte
pcmcia: remove cs_types.h
pcmcia: remove unused flag, simplify headers
pcmcia: remove obsolete CS_EVENT_ definitions
pcmcia: split up central event handler
pcmcia: simplify event callback
pcmcia: remove obsolete ioctl
Conflicts in:
- drivers/staging/comedi/drivers/*
- drivers/staging/wlags49_h2/wl_cs.c
due to dev_info_t and whitespace changes
of_device is just an alias for platform_device, so remove it entirely. Also
replace to_of_device() with to_platform_device() and update comment blocks.
This patch was initially generated from the following semantic patch, and then
edited by hand to pick up the bits that coccinelle didn't catch.
-struct of_device
+struct platform_device
Reviewed-by: David S. Miller <davem@davemloft.net>
Instead of io_req_t, drivers are now requested to fill out
struct pcmcia_device *p_dev->resource[0,1] for up to two ioport
ranges. After a call to pcmcia_request_io(), the ports found there
are reserved, after calling pcmcia_request_configuration(), they may
be used.
CC: Michael Buesch <mb@bu3sch.de>
Acked-by: Marcel Holtmann <marcel@holtmann.org> (for drivers/bluetooth/)
After pcmcia_request_io(), do not make use of the values stored in
io_req_t, but instead use those found in struct pcmcia_device->resource[].
Remove cs_types.h which is no longer needed: Most definitions aren't
used at all, a few can be made away with, and two remaining definitions
(typedefs, unfortunatley) may be moved to more specific places.
Both of_bus_type and of_platform_bus_type are just #define aliases
for the platform bus. This patch removes all references to them and
switches to the of_register_platform_driver()/of_unregister_platform_driver()
API for registering.
Subsequent patches will convert each user of of_register_platform_driver()
into plain platform_drivers without the of_platform_driver shim. At which
point the of_register_platform_driver()/of_unregister_platform_driver()
functions can be removed.
This patch moves SPARC architecture specific data members out of
struct of_device and into the pdev_archdata structure. The reason
for this change is to unify the struct of_device definition amongst
all the architectures. It also remvoes the .sysdata, .slot, .portid
and .clock_freq properties because they aren't actually used by
anything.
A subsequent patch will replace struct of_device entirely with struct
platform_device and the of_platform support code will share common
routines with the platform bus (but the bus instances themselves can
remain separate).
This patch also adds 'struct resources *resource' and num_resources
to match the fields defined in struct platform_device. After this
change, 'struct platform_device' can be used as a drop-in replacement
for 'struct of_platform'.
This change is in preparation for merging the of_platform_bus_type
with the platform_bus_type.
Merging in current state of Linus' tree to deal with merge conflicts and
build failures in vio.c after merge.
drivers/i2c/busses/i2c-cpm.c
drivers/i2c/busses/i2c-mpc.c
drivers/net/gianfar.c
Also fixed up one line in arch/powerpc/kernel/vio.c to use the
correct node pointer.
.name, .match_table and .owner are duplicated in both of_platform_driver
and device_driver. This patch is a removes the extra copies from struct
of_platform_driver and converts all users to the device_driver members.
This patch is a pretty mechanical change. The usage model doesn't change
and if any drivers have been missed, or if anything has been fixed up
incorrectly, then it will fail with a compile time error, and the fixup
will be trivial. This patch looks big and scary because it touches so
many files, but it should be pretty safe.
Acked-by: Sean MacLennan <smaclennan@pikatech.com>
dev_node_t was only used to transport some minor/major numbers
from the PCMCIA device drivers to deprecated userspace helpers.
However, only a few drivers made use of it, and the userspace
helpers are deprecated anyways. Therefore, get rid of dev_node_t .
As a first step, remove any usage of dev_node_t from drivers which
only wrote to this typedef/struct, but did not make use of it.
CC: Harald Welte <laforge@gnumonks.org>
Instead of the old pcmcia_request_irq() interface, drivers may now
choose between:
- calling request_irq/free_irq directly. Use the IRQ from *p_dev->irq.
- use pcmcia_request_irq(p_dev, handler_t); the PCMCIA core will
clean up automatically on calls to pcmcia_disable_device() or
device ejection.
- drivers still not capable of IRQF_SHARED (or not telling us so) may
use the deprecated pcmcia_request_exclusive_irq() for the time
being; they might receive a shared IRQ nonetheless.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Documentation/filesystems/proc.txt
arch/arm/mach-u300/include/mach/debug-macro.S
drivers/net/qlge/qlge_ethtool.c
drivers/net/qlge/qlge_main.c
drivers/net/typhoon.c
This patch is heavily based on an earlier patch found on the linux-serial
mailing list [1], written by Darius Augulis.
The previous incarnation of this patch only supported a 2x serial port
card. I have added support for my SYBA 6x serial port card, and tested on
x86.
[1]: http://marc.info/?l=linux-serial&m=124975806304760
Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu>
Cc: Darius Augulis <augulis.darius@gmail.com>
Cc: Greg KH <greg@kroah.com>
Remove outdated drivers/parport/ChangeLog. No need for such files
since we have git.
Acked-by: Alan Cox <alan@linux.intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k:
m68k: parport_mfc3 - Not makes it a bool before the comparison.
m68k: don't export static inline functions
fbdev: atafb - add palette register check
m68k: Remove the BKL from sys_execve
m68k: Cleanup linker scripts using new linker script macros.
m68k: Make thread_info.h usable from assembly.
m68knommu: define arch_has_single_step() and friends
m68k: ptrace fixes
m68k: use generic code for ptrace requests
rtc: Add an RTC driver for the Ricoh RP5C01
rtc: Add an RTC driver for the Oki MSM6242
* git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/sysctl-2.6: (43 commits)
security/tomoyo: Remove now unnecessary handling of security_sysctl.
security/tomoyo: Add a special case to handle accesses through the internal proc mount.
sysctl: Drop & in front of every proc_handler.
sysctl: Remove CTL_NONE and CTL_UNNUMBERED
sysctl: kill dead ctl_handler definitions.
sysctl: Remove the last of the generic binary sysctl support
sysctl net: Remove unused binary sysctl code
sysctl security/tomoyo: Don't look at ctl_name
sysctl arm: Remove binary sysctl support
sysctl x86: Remove dead binary sysctl support
sysctl sh: Remove dead binary sysctl support
sysctl powerpc: Remove dead binary sysctl support
sysctl ia64: Remove dead binary sysctl support
sysctl s390: Remove dead sysctl binary support
sysctl frv: Remove dead binary sysctl support
sysctl mips/lasat: Remove dead binary sysctl support
sysctl drivers: Remove dead binary sysctl support
sysctl crypto: Remove dead binary sysctl support
sysctl security/keys: Remove dead binary sysctl support
sysctl kernel: Remove binary sysctl logic
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
Most of the irq_req_t typedef'd struct can be re-worked quite
easily:
(1) IRQInfo2 was unused in any case, so drop it.
(2) IRQInfo1 was used write-only, so drop it.
(3) Instance (private data to be passed to the IRQ handler):
Most PCMCIA drivers using pcmcia_request_irq() to actually
register an IRQ handler set the "dev_id" to the same pointer
as the "priv" pointer in struct pcmcia_device. Modify the two
exceptions (ipwireless, ibmtr_cs) to also work this waym and
set the IRQ handler's "dev_id" to p_dev->priv unconditionally.
(4) Handler is to be of type irq_handler_t.
(5) Handler != NULL already tells whether an IRQ handler is present.
Therefore, we do not need the IRQ_HANDLER_PRESENT flag in
irq_req_t.Attributes.
CC: Jaroslav Kysela <perex@perex.cz>
CC: Karsten Keil <isdn@linux-pingi.de>
for the Bluetooth parts: Acked-by: Marcel Holtmann <marcel@holtmann.org>
For consistency drop & in front of every proc_handler. Explicity
taking the address is unnecessary and it prevents optimizations
like stubbing the proc_handlers to NULL.
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Cc: Joe Perches <joe@perches.com>
Now that sys_sysctl is a wrapper around /proc/sys all of
the binary sysctl support elsewhere in the tree is
dead code.
Cc: Corey Minyard <minyard@acm.org>
Cc: Greg Kroah-Hartman <gregkh@suse.de>
Cc: Matt Mackall <mpm@selenic.com>
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Cc: Neil Brown <neilb@suse.de>
Cc: "James E.J. Bottomley" <James.Bottomley@suse.de>
Acked-by: Clemens Ladisch <clemens@ladisch.de> for drivers/char/hpet.c
Convert PCMCIA drivers to use the dynamic debug infrastructure, instead of
requiring manual settings of PCMCIA_DEBUG.
Also, remove all usages of the CS_CHECK macro and replace them with proper
Linux style calling and return value checking. The extra error reporting may
be dropped, as the PCMCIA core already complains about any (non-driver-author)
errors.
It's unused.
It isn't needed -- read or write flag is already passed and sysctl
shouldn't care about the rest.
It _was_ used in two places at arch/frv for some reason.
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Add support for the PCI-Express NetMos 9901 Multi-IO card.
0001:06:00.0 Serial controller [0700]: NetMos Technology Device [9710:9901] (prog-if 02 [16550])
Subsystem: Device [a000:1000]
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0, Cache Line Size: 64 bytes
Interrupt: pin A routed to IRQ 65
Region 0: I/O ports at 0030 [size=8]
Region 1: Memory at 80105000 (32-bit, non-prefetchable) [size=4K]
Region 4: Memory at 80104000 (32-bit, non-prefetchable) [size=4K]
Capabilities: <access denied>
Kernel driver in use: serial
Kernel modules: 8250_pci
0001:06:00.1 Serial controller [0700]: NetMos Technology Device [9710:9901] (prog-if 02 [16550])
Interrupt: pin B routed to IRQ 65
Region 0: I/O ports at 0020 [size=8]
Region 1: Memory at 80103000 (32-bit, non-prefetchable) [size=4K]
Region 4: Memory at 80102000 (32-bit, non-prefetchable) [size=4K]
0001:06:00.2 Parallel controller [0701]: NetMos Technology Device [9710:9901] (prog-if 03 [IEEE1284])
Subsystem: Device [a000:2000]
Interrupt: pin C routed to IRQ 65
Region 0: I/O ports at 0010 [size=8]
Region 1: I/O ports at <unassigned>
Region 2: Memory at 80101000 (32-bit, non-prefetchable) [size=4K]
Region 4: Memory at 80100000 (32-bit, non-prefetchable) [size=4K]
Kernel driver in use: parport_pc
Kernel modules: parport_pc
[ 16.760181] PCI parallel port detected: 416c:0100, I/O at 0x812010(0x0), IRQ 65
[ 16.760225] parport0: PC-style at 0x812010, irq 65 [PCSPP,TRISTATE,EPP]
[ 16.851842] serial 0001:06:00.0: enabling device (0004 -> 0007)
[ 16.883776] 0001:06:00.0: ttyS0 at I/O 0x812030 (irq = 65) is a ST16650V2
[ 16.893832] serial 0001:06:00.1: enabling device (0004 -> 0007)
[ 16.926537] 0001:06:00.1: ttyS1 at I/O 0x812020 (irq = 65) is a ST16650V2
Signed-off-by: Michael Buesch <mb@bu3sch.de>
parport_pc_probe_port() creates the own 'parport_pc' device if the
device argument is NULL. Then parport_pc_probe_port() doesn't
initialize the dma_mask and coherent_dma_mask of the device and calls
dma_alloc_coherent with it. dma_alloc_coherent fails because
dma_alloc_coherent() doesn't accept the uninitialized dma_mask:
http://lkml.org/lkml/2009/6/16/150
Long ago, X86_32 and X86_64 had the own dma_alloc_coherent
implementations; X86_32 accepted a device having dma_mask that is not
initialized however X86_64 didn't. When we merged them, we chose to
prohibit a device having dma_mask that is not initialized. I think
that it's good to require drivers to set up dma_mask (and
coherent_dma_mask) properly if the drivers want DMA.
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
Reported-by: Malcom Blaney <malcolm.blaney@maptek.com.au>
Tested-by: Malcom Blaney <malcolm.blaney@maptek.com.au>
Cc: stable@kernel.org
Acked-by: Jeff Garzik <jgarzik@redhat.com>
CONFIG_PARPORT_PC_SUPERIO probes for various superio chips by writing
byte sequences to a set of different potential I/O ranges. But the
probed ranges are not exclusive to parallel ports. Some of our boards
just happen to have a watchdog in one of them. Took us almost a week
to figure out why some distros reboot without warning after running
flawlessly for 3 hours. For exactly 170 = 0xAA minutes, that is ...
Fixed by restoring original values after probing. Also fixed too small
request_region() in detect_and_report_it87().
Signed-off-by: Jens Rottmann <JRottmann@LiPPERTEmbedded.de>
Cc: <stable@kernel.org>
In the near future, the driver core is going to not allow direct access
to the driver_data pointer in struct device. Instead, the functions
dev_get_drvdata() and dev_set_drvdata() should be used. These functions
have been around since the beginning, so are backwards compatible with
all older kernel versions.
And tidy up a few bits coding style detectors missed
Michael's patch fixed some of the coding style so the style is now
inconsistent. Sort the rest out
