[ Upstream commit 533ca1feed98b0bf024779a14760694c7cb4d431 ]
The slot must be removed before the pci_dev is removed, otherwise a panic
can happen due to use-after-free.
Fixes: 15becc2b56c6 ("PCI: hv: Add hv_pci_remove_slots() when we unload the driver")
Signed-off-by: Dexuan Cui <decui@microsoft.com>
Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Cc: stable@vger.kernel.org
commit 4df591b20b80cb77920953812d894db259d85bd7 upstream.
Fix a use-after-free in hv_eject_device_work().
Fixes: 05f151a73ec2 ("PCI: hv: Fix a memory leak in hv_eject_device_work()")
Reviewed-by: Michael Kelley <mikelley@microsoft.com>
[ Upstream commit 340d455699400f2c2c0f9b3f703ade3085cdb501 ]
When we hot-remove a device, usually the host sends us a PCI_EJECT message,
and a PCI_BUS_RELATIONS message with bus_rel->device_count == 0.
When we execute the quick hot-add/hot-remove test, the host may not send
us the PCI_EJECT message if the guest has not fully finished the
initialization by sending the PCI_RESOURCES_ASSIGNED* message to the
host, so it's potentially unsafe to only depend on the
pci_destroy_slot() in hv_eject_device_work() because the code path
create_root_hv_pci_bus()
-> hv_pci_assign_slots()
is not called in this case. Note: in this case, the host still sends the
guest a PCI_BUS_RELATIONS message with bus_rel->device_count == 0.
In the quick hot-add/hot-remove test, we can have such a race before
the code path
pci_devices_present_work()
-> new_pcichild_device()
adds the new device into the hbus->children list, we may have already
received the PCI_EJECT message, and since the tasklet handler
hv_pci_onchannelcallback()
may fail to find the "hpdev" by calling
get_pcichild_wslot(hbus, dev_message->wslot.slot)
hv_pci_eject_device() is not called; Later, by continuing execution
creates the slot and the PCI_BUS_RELATIONS message with
bus_rel->device_count == 0 removes the device from hbus->children, and
we end up being unable to remove the slot in
hv_pci_remove()
-> hv_pci_remove_slots()
Remove the slot in pci_devices_present_work() when the device
is removed to address this race.
pci_devices_present_work() and hv_eject_device_work() run in the
singled-threaded hbus->wq, so there is not a double-remove issue for the
slot.
We cannot offload hv_pci_eject_device() from hv_pci_onchannelcallback()
to the workqueue, because we need the hv_pci_onchannelcallback()
synchronously call hv_pci_eject_device() to poll the channel
ringbuffer to work around the "hangs in hv_compose_msi_msg()" issue
fixed in commit de0aa7b2f97d ("PCI: hv: Fix 2 hang issues in
hv_compose_msi_msg()")
Fixes: a15f2c08c708 ("PCI: hv: support reporting serial number as slot information")
[lorenzo.pieralisi@arm.com: rewritten commit log]
Reviewed-by: Stephen Hemminger <stephen@networkplumber.org>
[ Upstream commit 15becc2b56c6eda3d9bf5ae993bafd5661c1fad1 ]
When we unload the pci-hyperv host controller driver, the host does not
send us a PCI_EJECT message.
In this case we also need to make sure the sysfs PCI slot directory is
removed, otherwise a command on a slot file eg:
"cat /sys/bus/pci/slots/2/address"
will trigger a
"BUG: unable to handle kernel paging request"
and, if we unload/reload the driver several times we would end up with
stale slot entries in PCI slot directories in /sys/bus/pci/slots/
root@localhost:~# ls -rtl /sys/bus/pci/slots/
total 0
drwxr-xr-x 2 root root 0 Feb 7 10:49 2
drwxr-xr-x 2 root root 0 Feb 7 10:49 2-1
drwxr-xr-x 2 root root 0 Feb 7 10:51 2-2
Add the missing code to remove the PCI slot and fix the current
behaviour.
[lorenzo.pieralisi@arm.com: reformatted the log]
Reviewed-by: Stephen Hemminger <sthemmin@microsoft.com>
[ Upstream commit 05f151a73ec2b23ffbff706e5203e729a995cdc2 ]
When a device is created in new_pcichild_device(), hpdev->refs is set
to 2 (i.e. the initial value of 1 plus the get_pcichild()).
When we hot remove the device from the host, in a Linux VM we first call
hv_pci_eject_device(), which increases hpdev->refs by get_pcichild() and
then schedules a work of hv_eject_device_work(), so hpdev->refs becomes
3 (let's ignore the paired get/put_pcichild() in other places). But in
hv_eject_device_work(), currently we only call put_pcichild() twice,
meaning the 'hpdev' struct can't be freed in put_pcichild().
Add one put_pcichild() to fix the memory leak.
The device can also be removed when we run "rmmod pci-hyperv". On this
path (hv_pci_remove() -> hv_pci_bus_exit() -> hv_pci_devices_present()),
hpdev->refs is 2, and we do correctly call put_pcichild() twice in
pci_devices_present_work().
Fixes: 4daace0d8ce8 ("PCI: hv: Add paravirtual PCI front-end for Microsoft Hyper-V VMs")
[lorenzo.pieralisi@arm.com: commit log rework]
[ Upstream commit a15f2c08c70811f120d99288d81f70d7f3d104f1 ]
The Hyper-V host API for PCI provides a unique "serial number" which
can be used as basis for sysfs PCI slot table. This can be useful
for cases where userspace wants to find the PCI device based on
serial number.
When an SR-IOV NIC is added, the host sends an attach message
with serial number. The kernel doesn't use the serial number, but
it is useful when doing the same thing in a userspace driver such
as the DPDK. By having /sys/bus/pci/slots/N it provides a direct
way to find the matching PCI device.
There maybe some cases where serial number is not unique such
as when using GPU's. But the PCI slot infrastructure will handle
that.
This has a side effect which may also be useful. The common udev
network device naming policy uses the slot information (rather
than PCI address).
Signed-off-by: Stephen Hemminger <sthemmin@microsoft.com>
commit 447ae316670230d7d29430e2cbf1f5db4f49d14c upstream
The next patch in this series will have to make the definition of
irq_cpustat_t available to entering_irq().
Inclusion of asm/hardirq.h into asm/apic.h would cause circular header
dependencies like
asm/smp.h
asm/apic.h
asm/hardirq.h
linux/irq.h
linux/topology.h
linux/smp.h
asm/smp.h
or
linux/gfp.h
linux/mmzone.h
asm/mmzone.h
asm/mmzone_64.h
asm/smp.h
asm/apic.h
asm/hardirq.h
linux/irq.h
linux/irqdesc.h
linux/kobject.h
linux/sysfs.h
linux/kernfs.h
linux/idr.h
linux/gfp.h
and others.
This causes compilation errors because of the header guards becoming
effective in the second inclusion: symbols/macros that had been defined
before wouldn't be available to intermediate headers in the #include chain
anymore.
A possible workaround would be to move the definition of irq_cpustat_t
into its own header and include that from both, asm/hardirq.h and
asm/apic.h.
However, this wouldn't solve the real problem, namely asm/harirq.h
unnecessarily pulling in all the linux/irq.h cruft: nothing in
asm/hardirq.h itself requires it. Also, note that there are some other
archs, like e.g. arm64, which don't have that #include in their
asm/hardirq.h.
Remove the linux/irq.h #include from x86' asm/hardirq.h.
Fix resulting compilation errors by adding appropriate #includes to *.c
files as needed.
Note that some of these *.c files could be cleaned up a bit wrt. to their
set of #includes, but that should better be done from separate patches, if
at all.
Signed-off-by: Nicolai Stange <nstange@suse.de>
commit 35a88a18d7ea58600e11590405bc93b08e16e7f5 upstream.
Commit de0aa7b2f97d ("PCI: hv: Fix 2 hang issues in hv_compose_msi_msg()")
uses local_bh_disable()/enable(), because hv_pci_onchannelcallback() can
also run in tasklet context as the channel event callback, so bottom halves
should be disabled to prevent a race condition.
With CONFIG_PROVE_LOCKING=y in the recent mainline, or old kernels that
don't have commit f71b74bca637 ("irq/softirqs: Use lockdep to assert IRQs
are disabled/enabled"), when the upper layer IRQ code calls
hv_compose_msi_msg() with local IRQs disabled, we'll see a warning at the
beginning of __local_bh_enable_ip():
IRQs not enabled as expected
WARNING: CPU: 0 PID: 408 at kernel/softirq.c:162 __local_bh_enable_ip
The warning exposes an issue in de0aa7b2f97d: local_bh_enable() can
potentially call do_softirq(), which is not supposed to run when local IRQs
are disabled. Let's fix this by using local_irq_save()/restore() instead.
Note: hv_pci_onchannelcallback() is not a hot path because it's only called
when the PCI device is hot added and removed, which is infrequent.
Fixes: de0aa7b2f97d ("PCI: hv: Fix 2 hang issues in hv_compose_msi_msg()")
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Reviewed-by: Haiyang Zhang <haiyangz@microsoft.com>
Cc: Stephen Hemminger <sthemmin@microsoft.com>
Cc: K. Y. Srinivasan <kys@microsoft.com>
commit 29927dfb7f69bcf2ae7fd1cda10997e646a5189c upstream.
When Linux runs as a guest VM in Hyper-V and Hyper-V adds the virtual PCI
bus to the guest, Hyper-V always provides unique PCI domain.
commit 4a9b0933bdfc ("PCI: hv: Use device serial number as PCI domain")
overrode unique domain with the serial number of the first device added to
the virtual PCI bus.
The reason for that patch was to have a consistent and short name for the
device, but Hyper-V doesn't provide unique serial numbers. Using non-unique
serial numbers as domain IDs leads to duplicate device addresses, which
causes PCI bus registration to fail.
commit 0c195567a8f6 ("netvsc: transparent VF management") avoids the need
for commit 4a9b0933bdfc ("PCI: hv: Use device serial number as PCI
domain"). When scripts were used to configure VF devices, the name of
the VF needed to be consistent and short, but with commit 0c195567a8f6
("netvsc: transparent VF management") all the setup is done in the kernel,
and we do not need to maintain consistent name.
Revert commit 4a9b0933bdfc ("PCI: hv: Use device serial number as PCI
domain") so we can reliably support multiple devices being assigned to
a guest.
Tag the patch for stable kernels containing commit 0c195567a8f6
("netvsc: transparent VF management").
Fixes: 4a9b0933bdfc ("PCI: hv: Use device serial number as PCI domain")
Signed-off-by: Sridhar Pitchai <sridhar.pitchai@microsoft.com>
[lorenzo.pieralisi@arm.com: trimmed commit log]
Cc: stable@vger.kernel.org # v4.14+
Reviewed-by: Bjorn Helgaas <bhelgaas@google.com>
commit c3635da2a336441253c33298b87b3042db100725 upstream.
Before the guest finishes the device initialization, the device can be
removed anytime by the host, and after that the host won't respond to
the guest's request, so the guest should be prepared to handle this
case.
Add a polling mechanism to detect device presence.
[lorenzo.pieralisi@arm.com: edited commit log]
commit de0aa7b2f97d348ba7d1e17a00744c989baa0cb6 upstream.
1. With the patch "x86/vector/msi: Switch to global reservation mode",
the recent v4.15 and newer kernels always hang for 1-vCPU Hyper-V VM
with SR-IOV. This is because when we reach hv_compose_msi_msg() by
request_irq() -> request_threaded_irq() ->__setup_irq()->irq_startup()
-> __irq_startup() -> irq_domain_activate_irq() -> ... ->
msi_domain_activate() -> ... -> hv_compose_msi_msg(), local irq is
disabled in __setup_irq().
Note: when we reach hv_compose_msi_msg() by another code path:
pci_enable_msix_range() -> ... -> irq_domain_activate_irq() -> ... ->
hv_compose_msi_msg(), local irq is not disabled.
hv_compose_msi_msg() depends on an interrupt from the host.
With interrupts disabled, a UP VM always hangs in the busy loop in
the function, because the interrupt callback hv_pci_onchannelcallback()
can not be called.
We can do nothing but work it around by polling the channel. This
is ugly, but we don't have any other choice.
2. If the host is ejecting the VF device before we reach
hv_compose_msi_msg(), in a UP VM, we can hang in hv_compose_msi_msg()
forever, because at this time the host doesn't respond to the
CREATE_INTERRUPT request. This issue exists the first day the
pci-hyperv driver appears in the kernel.
Luckily, this can also by worked around by polling the channel
for the PCI_EJECT message and hpdev->state, and by checking the
PCI vendor ID.
Note: actually the above 2 issues also happen to a SMP VM, if
"hbus->hdev->channel->target_cpu == smp_processor_id()" is true.
Fixes: 4900be83602b ("x86/vector/msi: Switch to global reservation mode")
Tested-by: Adrian Suhov <v-adsuho@microsoft.com>
Tested-by: Chris Valean <v-chvale@microsoft.com>
Acked-by: Haiyang Zhang <haiyangz@microsoft.com>
Cc: <stable@vger.kernel.org>
Cc: Vitaly Kuznetsov <vkuznets@redhat.com>
Cc: Jack Morgenstein <jackm@mellanox.com>
commit 021ad274d7dc31611d4f47f7dd4ac7a224526f30 upstream.
When we hot-remove the device, we first receive a PCI_EJECT message and
then receive a PCI_BUS_RELATIONS message with bus_rel->device_count == 0.
The first message is offloaded to hv_eject_device_work(), and the second
is offloaded to pci_devices_present_work(). Both the paths can be running
list_del(&hpdev->list_entry), causing general protection fault, because
system_wq can run them concurrently.
The patch eliminates the race condition.
Since access to present/eject work items is serialized, we do not need the
hbus->enum_sem anymore, so remove it.
Link: https://lkml.kernel.org/r/KL1P15301MB00064DA6B4D221123B5241CFBFD70@KL1P15301MB0006.APCP153.PROD.OUTLOOK.COM
[lorenzo.pieralisi@arm.com: squashed semaphore removal patch]
Cc: <stable@vger.kernel.org> # v4.6+
commit 79aa801e899417a56863d6713f76c4e108856000 upstream.
The effective_affinity_mask is always set when an interrupt is assigned in
__assign_irq_vector() -> apic->cpu_mask_to_apicid(), e.g. for struct apic
apic_physflat: -> default_cpu_mask_to_apicid() ->
irq_data_update_effective_affinity(), but it looks d->common->affinity
remains all-1's before the user space or the kernel changes it later.
In the early allocation/initialization phase of an IRQ, we should use the
effective_affinity_mask, otherwise Hyper-V may not deliver the interrupt to
the expected CPU. Without the patch, if we assign 7 Mellanox ConnectX-3
VFs to a 32-vCPU VM, one of the VFs may fail to receive interrupts.
Reviewed-by: Jake Oshins <jakeo@microsoft.com>
Cc: Jork Loeser <jloeser@microsoft.com>
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI updates from Bjorn Helgaas:
- add enhanced Downstream Port Containment support, which prints more
details about Root Port Programmed I/O errors (Dongdong Liu)
- add Layerscape ls1088a and ls2088a support (Hou Zhiqiang)
- add MediaTek MT2712 and MT7622 support (Ryder Lee)
- add MediaTek MT2712 and MT7622 MSI support (Honghui Zhang)
- add Qualcom IPQ8074 support (Varadarajan Narayanan)
- add R-Car r8a7743/5 device tree support (Biju Das)
- add Rockchip per-lane PHY support for better power management (Shawn
Lin)
- fix IRQ mapping for hot-added devices by replacing the
pci_fixup_irqs() boot-time design with a host bridge hook called at
probe-time (Lorenzo Pieralisi, Matthew Minter)
- fix race when enabling two devices that results in upstream bridge
not being enabled correctly (Srinath Mannam)
- fix pciehp power fault infinite loop (Keith Busch)
- fix SHPC bridge MSI hotplug events by enabling bus mastering
(Aleksandr Bezzubikov)
- fix a VFIO issue by correcting PCIe capability sizes (Alex
Williamson)
- fix an INTD issue on Xilinx and possibly other drivers by unifying
INTx IRQ domain support (Paul Burton)
- avoid IOMMU stalls by marking AMD Stoney GPU ATS as broken (Joerg
Roedel)
- allow APM X-Gene device assignment to guests by adding an ACS quirk
(Feng Kan)
- fix driver crashes by disabling Extended Tags on Broadcom HT2100
(Extended Tags support is required for PCIe Receivers but not
Requesters, and we now enable them by default when Requesters support
them) (Sinan Kaya)
- fix MSIs for devices that use phantom RIDs for DMA by assuming MSIs
use the real Requester ID (not a phantom RID) (Robin Murphy)
- prevent assignment of Intel VMD children to guests (which may be
supported eventually, but isn't yet) by not associating an IOMMU with
them (Jon Derrick)
- fix Intel VMD suspend/resume by releasing IRQs on suspend (Scott
Bauer)
- fix a Function-Level Reset issue with Intel 750 NVMe by waiting
longer (up to 60sec instead of 1sec) for device to become ready
(Sinan Kaya)
- fix a Function-Level Reset issue on iProc Stingray by working around
hardware defects in the CRS implementation (Oza Pawandeep)
- fix an issue with Intel NVMe P3700 after an iProc reset by adding a
delay during shutdown (Oza Pawandeep)
- fix a Microsoft Hyper-V lockdep issue by polling instead of blocking
in compose_msi_msg() (Stephen Hemminger)
- fix a wireless LAN driver timeout by clearing DesignWare MSI
interrupt status after it is handled, not before (Faiz Abbas)
- fix DesignWare ATU enable checking (Jisheng Zhang)
- reduce Layerscape dependencies on the bootloader by doing more
initialization in the driver (Hou Zhiqiang)
- improve Intel VMD performance allowing allocation of more IRQ vectors
than present CPUs (Keith Busch)
- improve endpoint framework support for initial DMA mask, different
BAR sizes, configurable page sizes, MSI, test driver, etc (Kishon
Vijay Abraham I, Stan Drozd)
- rework CRS support to add periodic messages while we poll during
enumeration and after Function-Level Reset and prepare for possible
other uses of CRS (Sinan Kaya)
- clean up Root Port AER handling by removing unnecessary code and
moving error handler methods to struct pcie_port_service_driver
(Christoph Hellwig)
- clean up error handling paths in various drivers (Bjorn Andersson,
Fabio Estevam, Gustavo A. R. Silva, Harunobu Kurokawa, Jeffy Chen,
Lorenzo Pieralisi, Sergei Shtylyov)
- clean up SR-IOV resource handling by disabling VF decoding before
updating the corresponding resource structs (Gavin Shan)
- clean up DesignWare-based drivers by unifying quirks to update Class
Code and Interrupt Pin and related handling of write-protected
registers (Hou Zhiqiang)
- clean up by adding empty generic pcibios_align_resource() and
pcibios_fixup_bus() and removing empty arch-specific implementations
(Palmer Dabbelt)
- request exclusive reset control for several drivers to allow cleanup
elsewhere (Philipp Zabel)
- constify various structures (Arvind Yadav, Bhumika Goyal)
- convert from full_name() to %pOF (Rob Herring)
- remove unused variables from iProc, HiSi, Altera, Keystone (Shawn
Lin)
* tag 'pci-v4.14-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (170 commits)
PCI: xgene: Clean up whitespace
PCI: xgene: Define XGENE_PCI_EXP_CAP and use generic PCI_EXP_RTCTL offset
PCI: xgene: Fix platform_get_irq() error handling
PCI: xilinx-nwl: Fix platform_get_irq() error handling
PCI: rockchip: Fix platform_get_irq() error handling
PCI: altera: Fix platform_get_irq() error handling
PCI: spear13xx: Fix platform_get_irq() error handling
PCI: artpec6: Fix platform_get_irq() error handling
PCI: armada8k: Fix platform_get_irq() error handling
PCI: dra7xx: Fix platform_get_irq() error handling
PCI: exynos: Fix platform_get_irq() error handling
PCI: iproc: Clean up whitespace
PCI: iproc: Rename PCI_EXP_CAP to IPROC_PCI_EXP_CAP
PCI: iproc: Add 500ms delay during device shutdown
PCI: Fix typos and whitespace errors
PCI: Remove unused "res" variable from pci_resource_io()
PCI: Correct kernel-doc of pci_vpd_srdt_size(), pci_vpd_srdt_tag()
PCI/AER: Reformat AER register definitions
iommu/vt-d: Prevent VMD child devices from being remapping targets
x86/PCI: Use is_vmd() rather than relying on the domain number
To support implementing remote TLB flushing on Hyper-V with a hypercall
we need to make vp_index available outside of vmbus module. Rename and
globalize.
Signed-off-by: Vitaly Kuznetsov <vkuznets@redhat.com>
Reviewed-by: Andy Shevchenko <andy.shevchenko@gmail.com>
Cc: Haiyang Zhang <haiyangz@microsoft.com>
Cc: Jork Loeser <Jork.Loeser@microsoft.com>
Cc: Simon Xiao <sixiao@microsoft.com>
Cc: devel@linuxdriverproject.org
Link: http://lkml.kernel.org/r/20170802160921.21791-7-vkuznets@redhat.com
The setup of MSI with Hyper-V host was sleeping with locks held. This
error is reported when doing SR-IOV hotplug with kernel built with lockdep:
BUG: sleeping function called from invalid context at kernel/sched/completion.c:93
in_atomic(): 1, irqs_disabled(): 1, pid: 1405, name: ip
3 locks held by ip/1405:
#0: (rtnl_mutex){+.+.+.}, at: [<ffffffff976b10bb>] rtnetlink_rcv+0x1b/0x40
#1: (&desc->request_mutex){+.+...}, at: [<ffffffff970ddd33>] __setup_irq+0xb3/0x720
#2: (&irq_desc_lock_class){-.-...}, at: [<ffffffff970ddd65>] __setup_irq+0xe5/0x720
irq event stamp: 3476
hardirqs last enabled at (3475): [<ffffffff971b3005>] get_page_from_freelist+0x225/0xc90
hardirqs last disabled at (3476): [<ffffffff978024e7>] _raw_spin_lock_irqsave+0x27/0x90
softirqs last enabled at (2446): [<ffffffffc05ef0b0>] ixgbevf_configure+0x380/0x7c0 [ixgbevf]
softirqs last disabled at (2444): [<ffffffffc05ef08d>] ixgbevf_configure+0x35d/0x7c0 [ixgbevf]
The workaround is to poll for host response instead of blocking on
completion.
Update the Hyper-V vPCI driver to use the Server-2016 version of the vPCI
protocol, fixing MSI creation and retargeting issues.
Signed-off-by: Jork Loeser <jloeser@microsoft.com>
Reviewed-by: K. Y. Srinivasan <kys@microsoft.com>
Acked-by: K. Y. Srinivasan <kys@microsoft.com>
Hyper-V vPCI offers different protocol versions. Add the infra for
negotiating the one to use.
To ease parallel effort to centralize CPU-number-to-vCPU-number conversion,
temporarily stand up own version, file-local hv_tmp_cpu_nr_to_vp_nr().
Once the changes have merged, this work-around can be removed, and the
calls replaced with hv_cpu_number_to_vp_number().
The hv_pcibus_device structure contains an in-memory hypercall argument
that must not cross a page boundary. Allocate the structure as a page to
ensure that.
Fix comment formatting and use proper integer fields.
refcount_t type and corresponding API should be used instead of atomic_t
when the variable is used as a reference counter. This allows to avoid
accidental refcounter overflows that might lead to use-after-free
situations.
Signed-off-by: Elena Reshetova <elena.reshetova@intel.com>
Signed-off-by: Hans Liljestrand <ishkamiel@gmail.com>
Signed-off-by: David Windsor <dwindsor@gmail.com>
The memory allocation here needs to be non-blocking. Fix the issue.
Signed-off-by: K. Y. Srinivasan <kys@microsoft.com>
Reviewed-by: Long Li <longli@microsoft.com>
When we have 32 or more CPUs in the affinity mask, we should use a special
constant to specify that to the host. Fix this issue.
A PCI_EJECT message can arrive at the same time we are calling
pci_scan_child_bus() in the workqueue for the previous PCI_BUS_RELATIONS
message or in create_root_hv_pci_bus(). In this case we could potentially
modify the bus from multiple places.
Properly lock the bus access.
Thanks Dexuan Cui <decui@microsoft.com> for pointing out the race condition
Reported-by: Xiaofeng Wang <xiaofwan@redhat.com>
Signed-off-by: Long Li <longli@microsoft.com>
hv_pci_devices_present() is called in hv_pci_remove() when we remove a PCI
device from the host, e.g., by disabling SR-IOV on a device. In
hv_pci_remove(), the bus is already removed before the call, so we don't
need to rescan the bus in the workqueue scheduled from
hv_pci_devices_present().
By introducing bus state hv_pcibus_removed, we can avoid this situation.
Use the device serial number as the PCI domain. The serial numbers start
with 1 and are unique within a VM. So names, such as VF NIC names, that
include domain number as part of the name, can be shorter than that based
on part of bus UUID previously. The new names will also stay same for VMs
created with copied VHD and same number of devices.
Signed-off-by: Haiyang Zhang <haiyangz@microsoft.com>
The devfn of 00:02.0 is 0x10. devfn_to_wslot(0x10) == 0x2, and
wslot_to_devfn(0x2) should be 0x10, while it's 0x2 in the current code.
Due to this, hv_eject_device_work() -> pci_get_domain_bus_and_slot()
returns NULL and pci_stop_and_remove_bus_device() is not called.
Later when the real device driver's .remove() is invoked by
hv_pci_remove() -> pci_stop_root_bus(), some warnings can be noticed
because the VM has lost the access to the underlying device at that
time.
Signed-off-by: Jake Oshins <jakeo@microsoft.com>
CC: stable@vger.kernel.org
CC: K. Y. Srinivasan <kys@microsoft.com>
CC: Stephen Hemminger <sthemmin@microsoft.com>
hv_do_hypercall() assumes that we pass a segment from a physically
contiguous buffer. A buffer allocated on the stack may not work if
CONFIG_VMAP_STACK=y is set.
Use kmalloc() to allocate this buffer.
Reported-by: Haiyang Zhang <haiyangz@microsoft.com>
After we send a PCI_EJECTION_COMPLETE message to the host, the host will
immediately send us a PCI_BUS_RELATIONS message with
relations->device_count == 0, so pci_devices_present_work(), running on
another thread, can find the being-ejected device, mark the
hpdev->reported_missing to true, and run list_move_tail()/list_del() for
the device -- this races hv_eject_device_work() -> list_del().
Move the list_del() in hv_eject_device_work() to an earlier place, i.e.,
before we send PCI_EJECTION_COMPLETE, so later the
pci_devices_present_work() can't see the device.
CC: Haiyang Zhang <haiyangz@microsoft.com>
CC: Vitaly Kuznetsov <vkuznets@redhat.com>
1. We don't really need such a big on-stack buffer when sending the
teardown_packet: vmbus_sendpacket() here only uses sizeof(struct
pci_message).
2. In the hot-remove case (PCI_EJECT), after we send PCI_EJECTION_COMPLETE
to the host, the host will send a RESCIND_CHANNEL message to us and the
host won't access the per-channel ringbuffer any longer, so we needn't send
PCI_RESOURCES_RELEASED/PCI_BUS_D0EXIT to the host, and we shouldn't expect
the host's completion message of PCI_BUS_D0EXIT, which will never come.
3. We should send PCI_BUS_D0EXIT after hv_send_resources_released().
We don't really need such a big on-stack buffer. vmbus_sendpacket() here
only uses sizeof(struct pci_child_message).
Make hv_irq_mask() and hv_irq_unmask() static as they are only used in
pci-hyperv.c
This fixes a sparse warning.
Signed-off-by: Tobias Klauser <tklauser@distanz.ch>
'completion_status' is used in some places, e.g.,
hv_pci_protocol_negotiation(), so we should make sure it's initialized in
error case too, though the error is unlikely here.
[bhelgaas: fix changelog typo and nearby whitespace]
Acked-by: KY Srinivasan <kys@microsoft.com>
CC: Jake Oshins <jakeo@microsoft.com>
Handle vmbus_sendpacket() failure in hv_compose_msi_msg().
I happened to find this when reading the code. I didn't get a real issue
however.
Remove the unused 'wrk' member in struct hv_pcibus_device.
The 2 structs can use a zero-length array here, because dynamic memory of
the correct size is allocated in hv_pci_devices_present() and we don't need
this extra element.
No functional change.
Use zero-length array in struct pci_packet and rename struct pci_message's
field "message_type" to "type". This makes the code more readable.
No functionality change.
Use list_move_tail() instead of list_del() + list_add_tail(). No
functional change intended
Signed-off-by: Wei Yongjun <weiyj.lk@gmail.com>
SR-IOV disabled from the host causes a memory leak. pci-hyperv usually
first receives a PCI_EJECT notification and then proceeds to delete the
hpdev list entry in hv_eject_device_work(). Later in hv_msi_free() since
the device is no longer on the device list hpdev is NULL and hv_msi_free
returns without freeing int_desc as part of hv_int_desc_free().
Signed-off-by: Cathy Avery <cavery@redhat.com>
Acked-by: Jake Oshins <jakeo@microsoft.com>
When we have an interrupt from the host we have a bit set in event page
indicating there are messages for the particular channel. We need to read
them all as we won't get signaled for what was on the queue before we
cleared the bit in vmbus_on_event(). This applies to all Hyper-V drivers
and the pass-through driver should do the same.
I did not meet any bugs; the issue was found by code inspection. We don't
have many events going through hv_pci_onchannelcallback(), which explains
why nobody reported the issue before.
While on it, fix handling non-zero vmbus_recvpacket_raw() return values by
dropping out. If the return value is not zero, it is wrong to inspect
buffer or bytes_recvd as these may contain invalid data.
We don't free buffer on several code paths in hv_pci_onchannelcallback(),
put kfree() to the end of the function to fix the issue. Direct { kfree();
return; } can now be replaced with a simple 'break';
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc
Pull char / misc driver updates from Greg KH:
"Here's the big char and misc driver update for 4.7-rc1.
Lots of different tiny driver subsystems have updates here with new
drivers and functionality. Details in the shortlog.
All have been in linux-next with no reported issues for a while"
* tag 'char-misc-4.7-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (125 commits)
mcb: Delete num_cells variable which is not required
mcb: Fixed bar number assignment for the gdd
mcb: Replace ioremap and request_region with the devm version
mcb: Implement bus->dev.release callback
mcb: export bus information via sysfs
mcb: Correctly initialize the bus's device
mei: bus: call mei_cl_read_start under device lock
coresight: etb10: adjust read pointer only when needed
coresight: configuring ETF in FIFO mode when acting as link
coresight: tmc: implementing TMC-ETF AUX space API
coresight: moving struct cs_buffers to header file
coresight: tmc: keep track of memory width
coresight: tmc: make sysFS and Perf mode mutually exclusive
coresight: tmc: dump system memory content only when needed
coresight: tmc: adding mode of operation for link/sinks
coresight: tmc: getting rid of multiple read access
coresight: tmc: allocating memory when needed
coresight: tmc: making prepare/unprepare functions generic
coresight: tmc: splitting driver in ETB/ETF and ETR components
coresight: tmc: cleaning up header file
I'm trying to pass-through Broadcom BCM5720 NIC (Dell device 1f5b) on a
Dell R720 server. Everything works fine when the target VM has only one
CPU, but SMP guests reboot when the NIC driver accesses PCI config space
with hv_pcifront_read_config()/hv_pcifront_write_config(). The reboot
appears to be induced by the hypervisor and no crash is observed. Windows
event logs are not helpful at all ('Virtual machine ... has quit
unexpectedly'). The particular access point is always different and
putting debug between them (printk/mdelay/...) moves the issue further
away. The server model affects the issue as well: on Dell R420 I'm able to
pass-through BCM5720 NIC to SMP guests without issues.
While I'm obviously failing to reveal the essence of the issue I was able
to come up with a (possible) solution: if explicit barriers are added to
hv_pcifront_read_config()/hv_pcifront_write_config() the issue goes away.
The essential minimum is rmb() at the end on _hv_pcifront_read_config() and
wmb() at the end of _hv_pcifront_write_config() but I'm not confident it
will be sufficient for all hardware. I suggest the following barriers:
1) wmb()/mb() between choosing the function and writing to its space.
2) mb() before releasing the spinlock in both _hv_pcifront_read_config()/
_hv_pcifront_write_config() to ensure that consecutive reads/writes to
the space won't get re-ordered as drivers may count on that.
Config space access is not supposed to be performance-critical so these
explicit barriers should not cause any slowdown.
[bhelgaas: use Linux "barriers" terminology]
Kernel hang is observed when pci-hyperv module is release with device
drivers still attached. E.g., when I do 'rmmod pci_hyperv' with BCM5720
device pass-through-ed (tg3 module) I see the following:
NMI watchdog: BUG: soft lockup - CPU#1 stuck for 22s! [rmmod:2104]
Call Trace:
[<ffffffffa0641487>] tg3_read_mem+0x87/0x100 [tg3]
[<ffffffffa063f000>] ? 0xffffffffa063f000
[<ffffffffa0644375>] tg3_poll_fw+0x85/0x150 [tg3]
[<ffffffffa0649877>] tg3_chip_reset+0x357/0x8c0 [tg3]
[<ffffffffa064ca8b>] tg3_halt+0x3b/0x190 [tg3]
[<ffffffffa0657611>] tg3_stop+0x171/0x230 [tg3]
[<ffffffffa064c550>] tg3_remove_one+0x90/0x140 [tg3]
[<ffffffff813bee59>] pci_device_remove+0x39/0xc0
[<ffffffff814a3201>] __device_release_driver+0xa1/0x160
[<ffffffff814a32e3>] device_release_driver+0x23/0x30
[<ffffffff813b794a>] pci_stop_bus_device+0x8a/0xa0
[<ffffffff813b7ab6>] pci_stop_root_bus+0x36/0x60
[<ffffffffa02c3f38>] hv_pci_remove+0x238/0x260 [pci_hyperv]
The problem seems to be that we report local resources release before
stopping the bus and removing devices from it and device drivers may try to
perform some operations with these resources on shutdown. Move resources
release report after we do pci_stop_root_bus().
This patch modifies all the callers of vmbus_mmio_allocate()
to call vmbus_mmio_free() instead of release_mem_region().
Add a new driver which exposes a root PCI bus whenever a PCI Express device
is passed through to a guest VM under Hyper-V. The device can be single-
or multi-function. The interrupts for the devices are managed by an IRQ
domain, implemented within the driver.
[bhelgaas: fold in race condition fix (http://lkml.kernel.org/r/1456340196-13717-1-git-send-email-jakeo@microsoft.com)]
