__FUNCTION__ is gcc-specific, use __func__
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
drivers/pci/hotplug/acpiphp_ibm.c:ibm_find_acpi_device() is not
large enough to accommodate data returned by the _CID method
executed from acpi_get_object_info().
This patch eliminates the problem by letting ACPI code
(instead of driver code) determine and obtain a correctly
sized buffer.
Signed-off-by: Gary Hade <garyhade@us.ibm.com>
Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com>
This also renames pci_hotplug_slots_subsys to pcis_hotplug_slots_kset
catch all current users with a build error instead of a build warning
which can easily be missed.
Cc: Kay Sievers <kay.sievers@vrfy.org>
Cc: Kristen Carlson Accardi <kristen.c.accardi@intel.com>
acpiphp.h: not using kernel-doc, so change /** to /*
acpiphp_core.c: lots of kernel-doc cleanups
acpiphp_glue.c: lots of kernel-doc cleanups
acpiphp_ibm.c: lots of kernel-doc cleanups
cpqphp_core.c: lots of kernel-doc cleanups
cpqphp_ctrl.c: lots of kernel-doc cleanups
fakephp.c: correct kernel-doc notation
pciehp_ctrl.c: correct kernel-doc notation
rpadlpar_core.c: correct function names & kernel-doc notation
rpaphp_core.c: correct kernel-doc notation
shpchp_ctrl.c: correct kernel-doc notation
Cc: Kristen Accardi <kristen.c.accardi@intel.com>
drivers/acpi/video.c
Signed-off-by: Len Brown <len.brown@intel.com>
Add missing \n to error in ibm_find_acpi_device.
Signed-off-by: Jeremy Fitzhardinge <jeremy@goop.org>
Cc: Greg Kroah-Hartman <gregkh@suse.de>
Cc: Adrian Bunk <trivial@kernel.org>
Schedule /proc/acpi/event for removal in 6 months.
Re-name acpi_bus_generate_event() to acpi_bus_generate_proc_event()
to make sure there is no confusion that it is for /proc/acpi/event only.
Add CONFIG_ACPI_PROC_EVENT to allow removal of /proc/acpi/event.
There is no functional change if CONFIG_ACPI_PROC_EVENT=y
The previous events patch added a netlink event for every
user of the legacy /proc/acpi/event interface.
However, some users of /proc/acpi/event are really input events,
and they already report their events via the input layer.
Introduce a new interface, acpi_bus_generate_netlink_event(),
which is explicitly called by devices that want to repoprt
events via netlink. This allows the input-like events
to opt-out of generating netlink events. In summary:
events that are sent via netlink:
ac/battery/sbs
thermal
processor
thinkpad_acpi dock/bay
events that are sent via input layer:
button
video hotkey
thinkpad_acpi hotkey
asus_acpi/asus-laptop hotkey
sonypi/sonylaptop
Signed-off-by: Zhang Rui <rui.zhang@intel.com>
sysfs binary attributes
Well, first of all, I don't want to change so many files either.
What I do:
Adding a new parameter "struct bin_attribute *" in the
.read/.write methods for the sysfs binary attributes.
In fact, only the four lines change in fs/sysfs/bin.c and
include/linux/sysfs.h do the real work.
But I have to update all the files that use binary attributes
to make them compatible with the new .read and .write methods.
I'm not sure if I missed any. :(
Why I do this:
For a sysfs attribute, we can get a pointer pointing to the
struct attribute in the .show/.store method,
while we can't do this for the binary attributes.
I don't know why this is different, but this does make it not
so handy to use the binary attributes as the regular ones.
So I think this patch is reasonable. :)
Who benefits from it:
The patch that exposes ACPI tables in sysfs
requires such an improvement.
All the table binary attributes share the same .read method.
Parameter "struct bin_attribute *" is used to get
the table signature and instance number which are used to
distinguish different ACPI table binary attributes.
Without this parameter, we need to offer different .read methods
for different ACPI table binary attributes.
This is impossible as there are various ACPI tables on different
platforms, and we don't know what they are until they are loaded.
sysfs is now completely out of driver/module lifetime game. After
deletion, a sysfs node doesn't access anything outside sysfs proper,
so there's no reason to hold onto the attribute owners. Note that
often the wrong modules were accounted for as owners leading to
accessing removed modules.
This patch kills now unnecessary attribute->owner. Note that with
this change, userland holding a sysfs node does not prevent the
backing module from being unloaded.
For more info regarding lifetime rule cleanup, please read the
following message.
http://article.gmane.org/gmane.linux.kernel/510293
(tweaked by Greg to not delete the field just yet, to make it easier to
merge things properly.)
Signed-off-by: Tejun Heo <htejun@gmail.com>
Cc: Cornelia Huck <cornelia.huck@de.ibm.com>
We need to work on cleaning up the relationship between kobjects, ksets and
ktypes. The removal of 'struct subsystem' is the first step of this,
especially as it is not really needed at all.
Thanks to Kay for fixing the bugs in this patch.
This makes it possible to build pci hotplug drivers outside of the main
kernel tree, and Sam keeps telling me to move local header files to
their proper places...
Make sysfs_remove_bin_file() void. If it detects an error,
printk the file name and call dump_stack().
sysfs_hash_and_remove() now returns an error code indicating
its success or failure so that sysfs_remove_bin_file() can
know success/failure.
Convert the only driver that checked the return value of
sysfs_remove_bin_file().
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
Signed-off-by: Pavel Machek <pavel@suse.cz>
infrastructure for it.
Let it rip!
