path: root/drivers/pci/hotplug/pciehp_ctrl.c
2008-05-27pciehp: move msleep after power offKenji Kaneshige
According to the PCI Express specification, we must wait for at least 1 second after turning power off before taking any action that relies on power having been removed from the slot/adapter. For this, current pciehp wait for 1 second after issuing the power off command in hpc_power_off_slot() function. But waiting for 1 second in hpc_power_off_slot() can make pciehp probing slow-down because pciehp probe code calls hpc_power_off_slot() if the slot is not occupied just in case. We don't need to wait for 1 second at the pciehp probe time because there is no action on that empty slot. So move 1 second wait from hpc_power_off_slot() to the caller of hpc_power_off_slot(). Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-05-27pciehp: fix NULL dereference in interrupt handlerKenji Kaneshige
Fix the following NULL dereference problem reported from Pierre Ossman and Ingo Molnar. pciehp: HPC vendor_id 8086 device_id 27d0 ss_vid 0 ss_did 0 pciehp: pciehp_find_slot: slot (device=0x0) not found BUG: unable to handle kernel NULL pointer dereference at 0000000000000070 IP: [<ffffffff80494a8b>] pciehp_handle_presence_change+0x7e/0x113 PGD 0 Oops: 0000 [1] CPU 0 Modules linked in: Pid: 1, comm: swapper Tainted: G W 2.6.26-rc3-sched-devel.git-00001-g2b99b26-dirty #170 RIP: 0010:[<ffffffff80494a8b>] [<ffffffff80494a8b>] pciehp_handle_presence_change+0x7e/0x113 RSP: 0000:ffff81003f83fbb0 EFLAGS: 00010046 RAX: 0000000000000039 RBX: 0000000000000000 RCX: 0000000000000000 RDX: 0000000000000000 RSI: 0000000000000001 RDI: 0000000000000046 RBP: ffff81003f83fbd0 R08: 0000000000000001 R09: ffffffff80245103 R10: 0000000000000020 R11: 0000000000000000 R12: ffff81003ea53a30 R13: 0000000000000000 R14: 0000000000000011 R15: ffffffff80495926 FS: 0000000000000000(0000) GS:ffffffff80be7400(0000) knlGS:0000000000000000 CS: 0010 DS: 0018 ES: 0018 CR0: 000000008005003b CR2: 0000000000000070 CR3: 0000000000201000 CR4: 00000000000006a0 DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 Process swapper (pid: 1, threadinfo ffff81003f83e000, task ffff81003f840000) Stack: 0000000000000008 ffff81003f83fbf6 ffff81003ea53a30 0000000000000008 ffff81003f83fc10 ffffffff80495ab4 0000000000000011 0000000000000002 0000000000000202 0000000000000202 00000000fffffff4 ffff81003ea53a30 Call Trace: [<ffffffff80495ab4>] pcie_isr+0x18e/0x1bc [<ffffffff80260831>] request_irq+0x106/0x12f [<ffffffff80495fb6>] pcie_init+0x15e/0x6cc [<ffffffff804933a3>] pciehp_probe+0x64/0x541 [<ffffffff8048f4e7>] pcie_port_probe_service+0x4c/0x76 [<ffffffff8054af70>] driver_probe_device+0xd4/0x1f0 [<ffffffff8054b108>] __driver_attach+0x7c/0x7e [<ffffffff8054b08c>] ? __driver_attach+0x0/0x7e [<ffffffff8054a4b6>] bus_for_each_dev+0x53/0x7d [<ffffffff8054ad3c>] driver_attach+0x1c/0x1e [<ffffffff8054a9c2>] bus_add_driver+0xdd/0x25b [<ffffffff80c09d3d>] ? pcied_init+0x0/0x8b [<ffffffff8054b288>] driver_register+0x5f/0x13e [<ffffffff80c09d3d>] ? pcied_init+0x0/0x8b [<ffffffff8048f441>] pcie_port_service_register+0x47/0x49 [<ffffffff80c09d52>] pcied_init+0x15/0x8b [<ffffffff80bf3938>] kernel_init+0x75/0x243 [<ffffffff808639d2>] ? _spin_unlock_irq+0x2b/0x3a [<ffffffff80228d1f>] ? finish_task_switch+0x57/0x9a [<ffffffff8020c258>] child_rip+0xa/0x12 [<ffffffff8020bcec>] ? restore_args+0x0/0x30 [<ffffffff80bf38c3>] ? kernel_init+0x0/0x243 [<ffffffff8020c24e>] ? child_rip+0x0/0x12 Code: 83 80 00 00 00 48 39 f0 75 e1 0f b6 c9 48 c7 c2 00 0e 8d 80 48 c7 c6 8a 60 a6 80 48 c7 c7 10 db a8 80 31 c0 e8 3f 8d d9 ff 31 db <48> 8b 43 70 48 8d 75 ef 48 89 df ff 50 30 80 7d ef 00 74 37 48 RIP [<ffffffff80494a8b>] pciehp_handle_presence_change+0x7e/0x113 RSP <ffff81003f83fbb0> CR2: 0000000000000070 Kernel panic - not syncing: Fatal exception The situation under which it occurs is hw and timing related: it appears to happen on a system that has PCI hotplug hardware but with no active hotplug cards, and another interrupt in the same (shared) IRQ line arrives too early, before the hotplug-slot entry has been set up - as triggered by CONFIG_DEBUG_SHIRQ=y: This patch contains the following two fixes. (1) Clear all events bits in Slot Status register to prevent the pciehp driver from detecting the spurious events that would have been occur before pciehp loading. (2) Add check whether slot initialization had been already done. This is short term fix. We need more structural fixes to install interrupt handler after slot initialization is done. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-04-25pciehp: Fix wrong slot capability checkKenji Kaneshige
Current pciehp saves only 8bits of Slot Capability registers in ctrl->ctrlcap. But it refers more than 8bit for checking EMI capability. It is clearly a bug and EMI would never work. To fix this problem, this patch saves full Slot Capability contens in ctrl->slot_cap. It also reduce the redundant reads of Slot Capability register. And this pach also cleans up the macros to check the slot capabilitys (e.g. MRL_SENS(), and so on). Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-04-20PCI: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01pciehp: wait for 1000ms before LED operation after power offKenji Kaneshige
After turning power off, we must wait for at least 1 second *before* LED operation. Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01PCI Hotplug: pciehp: remove needless hp_slot calculationKenji Kaneshige
Remove needless hp_slot calculation. This has no functional changes. Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01PCIE: Make use of the previously split out pcie_init_enable_events() functionMark Lord
Make use of the previously split out pcie_init_enable_events() function to reinitialize the hotplug hardware on resume from suspend, but only when pciehp_force==1. Otherwise behaviour is unmodified. Signed-off-by: Mark Lord <mlord@pobox.com> Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01PCIE: fix PCIe Hotplug so that it works with ExpressCard slots on Dell ↵Mark Lord
notebooks (and others?) in conjunction with modparam of pciehp_force=1. Fix pciehp_probe() to deal with ExpressCard cards that were inserted prior to the driver being loaded. Signed-off-by: Mark Lord <mlord@pobox.com> Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-11-28pci hotplug: kernel-doc fixesRandy Dunlap
acpiphp.h: not using kernel-doc, so change /** to /* acpiphp_core.c: lots of kernel-doc cleanups acpiphp_glue.c: lots of kernel-doc cleanups acpiphp_ibm.c: lots of kernel-doc cleanups cpqphp_core.c: lots of kernel-doc cleanups cpqphp_ctrl.c: lots of kernel-doc cleanups fakephp.c: correct kernel-doc notation pciehp_ctrl.c: correct kernel-doc notation rpadlpar_core.c: correct function names & kernel-doc notation rpaphp_core.c: correct kernel-doc notation shpchp_ctrl.c: correct kernel-doc notation Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Kristen Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12pciehp: remove trailing whitespace from pciehp_ctrl.cKenji Kaneshige
Remove trailing whitespaces from pciehp_ctrl.c. Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-11PCI: hotplug: pciehp: wait for 1 second after power off slotKenji Kaneshige
According to the specification, we must wait for at least 1 second after turning power off before taking any action that relies on power having been removed from the slot/adapter. Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-05-02PCI: fix multiple definition of `queue_pushbutton_work'Kristen Carlson Accardi
Fix duplicate names in shpchp and pciehp. Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-05-02pciehp: Event handling reworkKenji Kaneshige
The event handler of PCIEHP driver is unnecessarily very complex. In addition, current event handler can only a fixed number of events at the same time, and some of events would be lost if several number of events happened at the same time. This patch simplify the event handler using 'work queue', and it also fix the above-mentioned issue. Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-07pciehp: cleanup wait command completionKenji Kaneshige
This patch cleans up the code to wait for command completion. Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-07pciehp: cleanup pciehp.hKenji Kaneshige
This patch cleans up pciehp.h. This has no functional change. Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-07pciehp: remove unnecessary php_ctlrKenji Kaneshige
The struct php_ctlr seems to be only for complicating codes. This patch removes struct php_ctlr and related codes. Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-10-18pciehp: Remove unnecessary check in pciehp_ctrl.cEric Sesterhenn
this was spotted by coverity (cid #819). We dereference p_slot earlier in the function, and i found no way it could become NULL anywhere. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-10-18pciehp - add missing lockingKenji Kaneshige
This patch fixes the problem that system will panic if multiple power on/off operations are issued to the same slot in parallel. This problem can be easily reproduced by commands below. # while true; do echo 1 > power; echo 0 > power; done & # while true; do echo 1 > power; echo 0 > power; done & The cause is lack of locking for enable/disable operations. This patch fixes this problem. Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-10-18pciehp: fix improper info messagesKenji Kaneshige
The slot number displayed in info messages would cause a confusion because those are displayed in several ways (decimal and hex). Furthermore, those slot number is not same as slot name (directory name). This patch fixes those improper info messages. Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-26pciehp - fix wrong return valueKenji Kaneshige
This patch fixes the problem that trying to enable already enabled slot disables the slot by returning the proper value from pciehp_enable_slot()/pciehp_disable_slot(). Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-23[PATCH] PCI hotplug: convert semaphores to mutexIngo Molnar
semaphore to mutex conversion. the conversion was generated via scripts, and the result was validated automatically via a script as well. build tested with allyesconfig. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-11-23[PATCH] PCI Express Hotplug: clear sticky power-fault bitRajesh Shah
Per the PCI Express spec, the power-fault-detected bit in the slot status register can be set anytime hardware detects a power fault, regardless of whether the slot has a device populated in it or not. This bit is sticky and must be explicitly cleared. This patch is needed to allow hot-add after such a power fault has been detected. Signed-off-by: Rajesh Shah <rajesh.shah@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-10[PATCH] pciehp: reduce debug message verbosityrajesh.shah@intel.com
Reduce the number of debug messages generated if pciehp debug is enabled. I tried to restrict this to removing debug messages that are either early-driver-debug type messages, or print information that can be inferred through other debug prints. Signed-off-by: Rajesh Shah <rajesh.shah@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-11-10[PATCH] pciehp: miscellaneous cleanupsrajesh.shah@intel.com
Remove un-necessary header includes, remove dead code, remove some hardcoded constants... Signed-off-by: Rajesh Shah <rajesh.shah@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-11-10[PATCH] pciehp: remove redundant data structuresrajesh.shah@intel.com
State information is currently stored in per-slot as well as per-pci-function data structures in pciehp. There's a lot of overlap in the information kept, and some of it is never used. This patch consolidates the state information to per-slot and eliminates unused data structures. The biggest change is to eliminate the pci_func structure and the code around managing its lists. Signed-off-by: Rajesh Shah <rajesh.shah@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-11-10[PATCH] pciehp: reduce dependence on ACPIrajesh.shah@intel.com
Reduce the PCI Express hotplug driver's dependence on ACPI. We don't walk the acpi namespace anymore to build a list of bridges and devices. We go to ACPI only to run the _OSC or _OSHP methods to transition control of hotplug hardware from system BIOS to the hotplug driver, and to run the _HPP method to get hotplug device parameters like cache line size, latency timer and SERR/PERR enable from BIOS. Note that one of the side effects of this patch is that pciehp does not automatically enable the hot-added device or its DMA bus mastering capability now. It expects the device driver to do that. This may break some drivers and we will have to fix them as they are reported. Signed-off-by: Rajesh Shah <rajesh.shah@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-11-10[PATCH] patch 1/8] pciehp: use the PCI core for hotplug resource managementrajesh.shah@intel.com
This patch converts the pci express hotplug controller driver to use the PCI core for resource management. This eliminates a lot of duplicated code and integrates pciehp with the system's normal PCI handling code. Signed-off-by: Rajesh Shah <rajesh.shah@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-17[PATCH] pciehp: Use dword accessors for PCI_ROM_ADDRESSAdam Kropelin
PCI_ROM_ADDRESS is a 32 bit register and as such should be accessed using pci_bus_{read,write}_config_dword(). A recent audit of drivers/ turned up several cases of byte- and word-sized accesses. The harmful ones were fixed by Linus directly. This patches up one of the remaining harmless-but-still-wrong cases caught in the dragnet. Signed-off-by: Adam Kropelin <akropel1@rochester.rr.com> Cc: <kristen.c.accardi@intel.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-16[PATCH] PCI Hotplug: new contact infoKristen Accardi
Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
