Previously, the caller checked ATTN_LED() or PWR_LED() to see whether the
slot has indicators before setting the indicator state. That clutters the
caller unnecessarily, so this moves the test inside the callees. The test
may not even be necessary; per spec it should be harmless to try to turn on
a non-existent LED. But checking first does avoid unnecessary hotplug
commands.
No functional change.
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
These functions:
pcie_enable_notification()
pciehp_power_off_slot()
pciehp_get_power_status()
pciehp_get_attention_status()
pciehp_set_attention_status()
pciehp_get_latch_status()
pciehp_get_adapter_status()
pcie_write_cmd()
now always return success, so this patch makes them void and drops the
error-checking code in their callers.
When we have a hotplug-capable PCIe port with a second hotplug-capable
PCIe port below it, removing the device below the upstream port causes
a deadlock.
The deadlock happens because we use the pciehp_wq workqueue to run
pciehp_power_thread(), which uses pciehp_disable_slot() to remove devices
below the upstream port. When we remove the downstream PCIe port, we call
pciehp_remove(), the pciehp driver's .remove() method. That calls
flush_workqueue(pciehp_wq), which deadlocks because the
pciehp_power_thread() work item is still running.
This patch avoids the deadlock by creating a workqueue for every PCIe port
and removing the single shared workqueue.
Here's the call path that leads to the deadlock:
pciehp_queue_pushbutton_work
queue_work(pciehp_wq) # queue pciehp_power_thread
pciehp_power_thread
pciehp_disable_slot
remove_board
pciehp_unconfigure_device
pci_stop_and_remove_bus_device
pciehp_remove # pciehp driver .remove method
pciehp_release_ctrl
pcie_cleanup_slot
This is fairly urgent because it can be caused by simply unplugging a
Thunderbolt adapter, as reported by Daniel below.
[bhelgaas: changelog]
Reference: http://lkml.kernel.org/r/CAMVG2ssiRgcTD1bej2tkUUfsWmpL5eNtPcNif9va2-Gzb2u8nQ@mail.gmail.com
Reported-and-tested-by: Daniel J Blueman <daniel@quora.org>
Reviewed-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com>
Signed-off-by: Yijing Wang <wangyijing@huawei.com>
CC: stable@vger.kernel.org
Use non-ordered workqueue for attention button events.
Attention button events on each slot can be handled asynchronously. So
we should use non-ordered workqueue. This patch also removes ordered
workqueue in pciehp as a result.
Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
We need to wait for 1000 ms after Data Link Layer Link Active (DLLLA)
bit reads 1b before sending configuration request. Currently pciehp
does this wait after checking Link Training (LT) bit. But we need it
before checking LT bit because LT is still set even after DLLLA bit is
set on some platforms.
Acked-by: Yinghai Lu <yinghai@kernel.org>
Tested-by: Yinghai Lu <yinghai@kernel.org>
Naoki Yanagimoto reported that configuration read on some hot-added
PCIe device returns invalid value. This patch fixes this problem.
According to the PCIe spec, software must wait for at least 1 second
to judge if the hot-added device is broken after Data Link Layer State
Changed Event. This patch changes pciehp driver to wait for 1 second
after the Data Link Layer State Changed Event is detected before
initiating a configuration access instead of 100 ms.
Tested-by: Naoki Yanagimoto <yanagimoto@np.css.fujitsu.com>
* Rename pciehp_wq to pciehp_ordered_wq and add non-ordered pciehp_wq
which is used instead of the system workqueue. This is to remove
the use of flush_scheduled_work() which is deprecated and scheduled
for removal.
* With cmwq in place, there's no point in creating workqueues lazily.
Create both pciehp_wq and pciehp_ordered_wq upfront.
* Include workqueue.h from pciehp.h.
Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Stanse found a cut&pasted memory leak in pciehp_queue_pushbutton_work
and shpchp_queue_pushbutton_work. info is not freed/assigned on all
paths. Fix that.
Enabling power fault detected event notification in current pciehp
might cause power fault interrupt storm on some machines. On those
machines. On those machines, power fault detected bit in the slot
status register was set again immediately when it is cleared in the
interrupt service routine, and next power fault detected interrupt was
notified again. Therefore, disable power fault detected event
notification for now.
This patch also removes unnecessary handling for power fault cleared
event because this event is not supported by PCIe spec.
Tested-by: Jens Axboe <jens.axboe@oracle.com>
Current pciehp returns successfully on read/write failure with dummy
state values. It should return error instead.
With this patch, pciehp no longer uses hotplug_slot_info data
structure. So this also removes hotplug_slot_info related code. But
note that it still allocates hotplug_slot_info because it is required
by pci hotplug core.
Remove (almost) unused error message definitions.
Acked-by: Alex Chiang <achiang@hp.com>
The struct hpc_ops seems a set of hooks to controller specific
routines. But, it is meaningless because no hotplug controller driver
follows this framework.
Since we have a pointer to pcie_device in struct controller, we don't
need a pointer to pci_dev.
The crit_sect mutex defined in struct controller is to serialize
hot-plug operations against multiple slots under the same bus. But,
since PCIe doesnstream port has only one slot at most, it is
meaningless and we don't need it.
Since the device number of the hot-slot under the PCIe downstream port
is always 0, the slot_device_offset field in the slot is meaningless
The hp_slot field is to identify the slot under the same
controller. But, since PCIe downstream port has only one slot at most,
it is meaningless and we don't need it.
The device field in the struct slot is not necessary because it is
always 0 in pciehp driver.
The bus field in struct slot is not necessary.
There is a very old quirk for the intel E7502 E7320 and E7525 memory
controller hubs that disables usage of msi interrupts on pcie hotplug
bridges of those devices, and disables changing the affinity of irqs.
Today all we have to do to disable msi on a specific device is to set
dev->no_msi, which is much more straightforward than the previous
logic.
The re-running of this fixup after pci hotplug happens below these
devices is totally bogus. All of the state we change is pure software
state and we don't change the hardware at all. Which means hotplug on
the lower devices doesn't have a chance to change this state. So we
can safely remove the special case from the pciehp driver and the pcie
portdriver.
I suspect the special case was someone's expermental debug code that
slipped in. Certainly it isn't mentioned in commit
6fb8880a61510295aece04a542767161f624dffe aka BKrev:
41966101LJ_ogfOU0m2aE6teZfQnuQ where the code first appears.
* Remove smp_lock.h from files which don't need it (including some headers!)
* Add smp_lock.h to files which do need it
* Make smp_lock.h include conditional in hardirq.h
It's needed only for one kernel_locked() usage which is under CONFIG_PREEMPT
This will make hardirq.h inclusion cheaper for every PREEMPT=n config
(which includes allmodconfig/allyesconfig, BTW)
The pciehp driver waits for 1000 msec after turning power off to make
sure the power has been completely removed. But this 1000 msec wait is
not needed if a slot doesn't implement power control because software
cannot control the power. Power will be automatically removed at adapter
removal time on such a slot
Tested-by: "Phil Endecott" <phil_pibbu_endecott@chezphil.org>
This patch refines messages in pciehp module. The main changes are as
follows:
- remove the trailing "."
- remove __func__ as much as possible
- capitalize the first letter of messages
- show PCI device address including its domain
Signed-off-by: Taku Izumi <izumi.taku@jp.fujitsu.com>
This patch adds polling mechanism for Data Link Layer Link Active bit
after turning power on, instead of waiting for 1000 msec. This reduces
reduce the unnecessary long wait.
We do not need to manage our own name parameter, especially since
the PCI core can change it on our behalf, in the case of duplicate
slot names.
Remove 'name' from pciehp's version of struct slot, and remove
unused 'task_list' as well.
Cc: kristen.c.accardi@intel.com
Acked-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com>
Signed-off-by: Alex Chiang <achiang@hp.com>
This patch replaces printks within pciehp module with dev_printks.
According to the PCI Express specification, we must wait for at least
1 second after turning power off before taking any action that relies
on power having been removed from the slot/adapter. For this, current
pciehp wait for 1 second after issuing the power off command in
hpc_power_off_slot() function. But waiting for 1 second in
hpc_power_off_slot() can make pciehp probing slow-down because pciehp
probe code calls hpc_power_off_slot() if the slot is not occupied just
in case. We don't need to wait for 1 second at the pciehp probe time
because there is no action on that empty slot. So move 1 second wait
from hpc_power_off_slot() to the caller of hpc_power_off_slot().
Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com>
Fix the following NULL dereference problem reported from Pierre Ossman
and Ingo Molnar.
pciehp: HPC vendor_id 8086 device_id 27d0 ss_vid 0 ss_did 0
pciehp: pciehp_find_slot: slot (device=0x0) not found
BUG: unable to handle kernel NULL pointer dereference at 0000000000000070
IP: [<ffffffff80494a8b>] pciehp_handle_presence_change+0x7e/0x113
PGD 0
Oops: 0000 [1]
CPU 0
Modules linked in:
Pid: 1, comm: swapper Tainted: G W 2.6.26-rc3-sched-devel.git-00001-g2b99b26-dirty #170
RIP: 0010:[<ffffffff80494a8b>] [<ffffffff80494a8b>] pciehp_handle_presence_change+0x7e/0x113
RSP: 0000:ffff81003f83fbb0 EFLAGS: 00010046
RAX: 0000000000000039 RBX: 0000000000000000 RCX: 0000000000000000
RDX: 0000000000000000 RSI: 0000000000000001 RDI: 0000000000000046
RBP: ffff81003f83fbd0 R08: 0000000000000001 R09: ffffffff80245103
R10: 0000000000000020 R11: 0000000000000000 R12: ffff81003ea53a30
R13: 0000000000000000 R14: 0000000000000011 R15: ffffffff80495926
FS: 0000000000000000(0000) GS:ffffffff80be7400(0000) knlGS:0000000000000000
CS: 0010 DS: 0018 ES: 0018 CR0: 000000008005003b
CR2: 0000000000000070 CR3: 0000000000201000 CR4: 00000000000006a0
Process swapper (pid: 1, threadinfo ffff81003f83e000, task ffff81003f840000)
Stack: 0000000000000008 ffff81003f83fbf6 ffff81003ea53a30 0000000000000008
ffff81003f83fc10 ffffffff80495ab4 0000000000000011 0000000000000002
0000000000000202 0000000000000202 00000000fffffff4 ffff81003ea53a30
Call Trace:
[<ffffffff80495ab4>] pcie_isr+0x18e/0x1bc
[<ffffffff80260831>] request_irq+0x106/0x12f
[<ffffffff80495fb6>] pcie_init+0x15e/0x6cc
[<ffffffff804933a3>] pciehp_probe+0x64/0x541
[<ffffffff8048f4e7>] pcie_port_probe_service+0x4c/0x76
[<ffffffff8054af70>] driver_probe_device+0xd4/0x1f0
[<ffffffff8054b108>] __driver_attach+0x7c/0x7e
[<ffffffff8054b08c>] ? __driver_attach+0x0/0x7e
[<ffffffff8054a4b6>] bus_for_each_dev+0x53/0x7d
[<ffffffff8054ad3c>] driver_attach+0x1c/0x1e
[<ffffffff8054a9c2>] bus_add_driver+0xdd/0x25b
[<ffffffff80c09d3d>] ? pcied_init+0x0/0x8b
[<ffffffff8054b288>] driver_register+0x5f/0x13e
[<ffffffff8048f441>] pcie_port_service_register+0x47/0x49
[<ffffffff80c09d52>] pcied_init+0x15/0x8b
[<ffffffff80bf3938>] kernel_init+0x75/0x243
[<ffffffff808639d2>] ? _spin_unlock_irq+0x2b/0x3a
[<ffffffff80228d1f>] ? finish_task_switch+0x57/0x9a
[<ffffffff8020c258>] child_rip+0xa/0x12
[<ffffffff8020bcec>] ? restore_args+0x0/0x30
[<ffffffff80bf38c3>] ? kernel_init+0x0/0x243
[<ffffffff8020c24e>] ? child_rip+0x0/0x12
Code: 83 80 00 00 00 48 39 f0 75 e1 0f b6 c9 48 c7 c2 00 0e 8d 80 48 c7 c6 8a 60 a6 80 48 c7 c7 10 db a8 80 31 c0 e8 3f 8d d9 ff 31 db <48> 8b 43 70 48 8d 75 ef 48 89 df ff 50 30 80 7d ef 00 74 37 48
RIP [<ffffffff80494a8b>] pciehp_handle_presence_change+0x7e/0x113
RSP <ffff81003f83fbb0>
Kernel panic - not syncing: Fatal exception
The situation under which it occurs is hw and timing related: it appears
to happen on a system that has PCI hotplug hardware but with no active
hotplug cards, and another interrupt in the same (shared) IRQ line
arrives too early, before the hotplug-slot entry has been set up - as
triggered by CONFIG_DEBUG_SHIRQ=y:
This patch contains the following two fixes.
(1) Clear all events bits in Slot Status register to prevent the pciehp
driver from detecting the spurious events that would have been occur
before pciehp loading.
(2) Add check whether slot initialization had been already done.
This is short term fix. We need more structural fixes to install
interrupt handler after slot initialization is done.
Current pciehp saves only 8bits of Slot Capability registers in
ctrl->ctrlcap. But it refers more than 8bit for checking EMI capability.
It is clearly a bug and EMI would never work. To fix this problem,
this patch saves full Slot Capability contens in ctrl->slot_cap. It also
reduce the redundant reads of Slot Capability register. And this pach
also cleans up the macros to check the slot capabilitys (e.g. MRL_SENS(),
and so on).
__FUNCTION__ is gcc-specific, use __func__
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
After turning power off, we must wait for at least 1 second *before*
LED operation.
Remove needless hp_slot calculation. This has no functional changes.
Make use of the previously split out pcie_init_enable_events() function
to reinitialize the hotplug hardware on resume from suspend, but only
when pciehp_force==1. Otherwise behaviour is unmodified.
Signed-off-by: Mark Lord <mlord@pobox.com>
Cc: Theodore Ts'o <tytso@mit.edu>
notebooks (and others?) in conjunction with modparam of pciehp_force=1.
Fix pciehp_probe() to deal with ExpressCard cards
that were inserted prior to the driver being loaded.
acpiphp.h: not using kernel-doc, so change /** to /*
acpiphp_core.c: lots of kernel-doc cleanups
acpiphp_glue.c: lots of kernel-doc cleanups
acpiphp_ibm.c: lots of kernel-doc cleanups
cpqphp_core.c: lots of kernel-doc cleanups
cpqphp_ctrl.c: lots of kernel-doc cleanups
fakephp.c: correct kernel-doc notation
pciehp_ctrl.c: correct kernel-doc notation
rpadlpar_core.c: correct function names & kernel-doc notation
rpaphp_core.c: correct kernel-doc notation
shpchp_ctrl.c: correct kernel-doc notation
Cc: Kristen Accardi <kristen.c.accardi@intel.com>
Remove trailing whitespaces from pciehp_ctrl.c.
According to the specification, we must wait for at least 1 second
after turning power off before taking any action that relies on power
Fix duplicate names in shpchp and pciehp.
The event handler of PCIEHP driver is unnecessarily very complex. In
addition, current event handler can only a fixed number of events at
the same time, and some of events would be lost if several number of
events happened at the same time.
This patch simplify the event handler using 'work queue', and it also
fix the above-mentioned issue.
This patch cleans up the code to wait for command completion.
This patch cleans up pciehp.h. This has no functional change.
The struct php_ctlr seems to be only for complicating codes. This
patch removes struct php_ctlr and related codes.
this was spotted by coverity (cid #819). We dereference p_slot
earlier in the function, and i found no way it could become NULL
anywhere.
Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de>
This patch fixes the problem that system will panic if multiple power
on/off operations are issued to the same slot in parallel. This
problem can be easily reproduced by commands below.
# while true; do echo 1 > power; echo 0 > power; done &
The cause is lack of locking for enable/disable operations. This patch
fixes this problem.
The slot number displayed in info messages would cause a confusion
because those are displayed in several ways (decimal and hex).
Furthermore, those slot number is not same as slot name (directory
name). This patch fixes those improper info messages.
This patch fixes the problem that trying to enable already enabled
slot disables the slot by returning the proper value from
pciehp_enable_slot()/pciehp_disable_slot().
semaphore to mutex conversion.
the conversion was generated via scripts, and the result was validated
automatically via a script as well.
build tested with allyesconfig.
Per the PCI Express spec, the power-fault-detected bit in the
slot status register can be set anytime hardware detects a power
fault, regardless of whether the slot has a device populated in
it or not. This bit is sticky and must be explicitly cleared.
This patch is needed to allow hot-add after such a power fault
has been detected.
Signed-off-by: Rajesh Shah <rajesh.shah@intel.com>
Reduce the number of debug messages generated if pciehp debug is
enabled. I tried to restrict this to removing debug messages that
are either early-driver-debug type messages, or print information
that can be inferred through other debug prints.
Remove un-necessary header includes, remove dead code, remove
some hardcoded constants...
