The pciehp_handle_*() functions (pciehp_handle_attention_button(), etc.)
only contain a line or two of useful code, so it's clumsy to put
them in separate functions. All they so is add an event to a work queue,
and it's clearer to see that directly in the ISR.
Inline them directly into pcie_isr(). No functional change.
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Reviewed-by: Rajat Jain <rajatja@google.com>
Acked-by: Yinghai Lu <yinghai@kernel.org>
The pciehp debug logging is overly verbose and often redundant. Almost all
of the information printed by dbg_ctrl() is also printed by the normal PCI
core enumeration code and by pcie_init().
Remove the redundant debug info.
When claiming a pciehp bridge, we print the slot characteristics, e.g.,
Slot #6 AttnBtn- AttnInd- PwrInd- PwrCtrl- MRL- Interlock- NoCompl+ LLActRep+
Add the Hot-Plug Capable and Hot-Plug Surprise bits to this information,
and print it all in the same order as lspci does.
No functional change except the message text changes.
The commit referenced below deferred waiting for command completion until
the start of the next command, allowing hardware to do the latching
asynchronously. Unfortunately, being ready to accept a new command is the
only indication we have that the previous command is completed. In cases
where we need that state change to be enabled, we must still wait for
completion. For instance, pciehp_reset_slot() attempts to disable anything
that might generate a surprise hotplug on slots that support presence
detection. If we don't wait for those settings to latch before the
secondary bus reset, we negate any value in attempting to prevent the
spurious hotplug.
Create a base function with optional wait and helper functions so that
pcie_write_cmd() turns back into the "safe" interface which waits before
and after issuing a command and add pcie_write_cmd_nowait(), which
eliminates the trailing wait for asynchronous completion. The following
functions are returned to their previous behavior:
pciehp_power_on_slot
pciehp_power_off_slot
pcie_disable_notification
pciehp_reset_slot
The rationale is that pciehp_power_on_slot() enables the link and therefore
relies on completion of power-on. pciehp_power_off_slot() and
pcie_disable_notification() need a wait because data structures may be
freed after these calls and continued signaling from the device would be
unexpected. And, of course, pciehp_reset_slot() needs to wait for the
scenario outlined above.
Fixes: 3461a068661c ("PCI: pciehp: Wait for hotplug command completion lazily")
Signed-off-by: Alex Williamson <alex.williamson@redhat.com>
CC: stable@vger.kernel.org # v3.17+
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI updates from Bjorn Helgaas:
"The interesting things here are:
- Turn on Config Request Retry Status Software Visibility. This
caused hangs last time, but we included a fix this time.
- Rework PCI device configuration to use _HPP/_HPX more aggressively
- Allow PCI devices to be put into D3cold during system suspend
- Add arm64 PCI support
- Add APM X-Gene host bridge driver
- Add TI Keystone host bridge driver
- Add Xilinx AXI host bridge driver
More detailed summary:
Enumeration
- Check Vendor ID only for Config Request Retry Status (Rajat Jain)
- Enable Config Request Retry Status when supported (Rajat Jain)
- Add generic domain handling (Catalin Marinas)
- Generate uppercase hex for modalias interface class (Ricardo Ribalda Delgado)
Resource management
- Add missing MEM_64 mask in pci_assign_unassigned_bridge_resources() (Yinghai Lu)
- Increase IBM ipr SAS Crocodile BARs to at least system page size (Douglas Lehr)
PCI device hotplug
- Prevent NULL dereference during pciehp probe (Andreas Noever)
- Move _HPP & _HPX handling into core (Bjorn Helgaas)
- Apply _HPP to PCIe devices as well as PCI (Bjorn Helgaas)
- Apply _HPP/_HPX to display devices (Bjorn Helgaas)
- Preserve SERR & PARITY settings when applying _HPP/_HPX (Bjorn Helgaas)
- Preserve MPS and MRRS settings when applying _HPP/_HPX (Bjorn Helgaas)
- Apply _HPP/_HPX to all devices, not just hot-added ones (Bjorn Helgaas)
- Fix wait time in pciehp timeout message (Yinghai Lu)
- Add more pciehp Slot Control debug output (Yinghai Lu)
- Stop disabling pciehp notifications during init (Yinghai Lu)
MSI
- Remove arch_msi_check_device() (Alexander Gordeev)
- Rename pci_msi_check_device() to pci_msi_supported() (Alexander Gordeev)
- Move D0 check into pci_msi_check_device() (Alexander Gordeev)
- Remove unused kobject from struct msi_desc (Yijing Wang)
- Remove "pos" from the struct msi_desc msi_attrib (Yijing Wang)
- Add "msi_bus" sysfs MSI/MSI-X control for endpoints (Yijing Wang)
- Use __get_cached_msi_msg() instead of get_cached_msi_msg() (Yijing Wang)
- Use __read_msi_msg() instead of read_msi_msg() (Yijing Wang)
- Use __write_msi_msg() instead of write_msi_msg() (Yijing Wang)
Power management
- Drop unused runtime PM support code for PCIe ports (Rafael J. Wysocki)
- Allow PCI devices to be put into D3cold during system suspend (Rafael J. Wysocki)
AER
- Add additional AER error strings (Gong Chen)
- Make <linux/aer.h> standalone includable (Thierry Reding)
Virtualization
- Add ACS quirk for Solarflare SFC9120 & SFC9140 (Alex Williamson)
- Add ACS quirk for Intel 10G NICs (Alex Williamson)
- Add ACS quirk for AMD A88X southbridge (Marti Raudsepp)
- Remove unused pci_find_upstream_pcie_bridge(), pci_get_dma_source() (Alex Williamson)
- Add device flag helpers (Ethan Zhao)
- Assume all Mellanox devices have broken INTx masking (Gavin Shan)
Generic host bridge driver
- Fix ioport_map() for !CONFIG_GENERIC_IOMAP (Liviu Dudau)
- Add pci_register_io_range() and pci_pio_to_address() (Liviu Dudau)
- Define PCI_IOBASE as the base of virtual PCI IO space (Liviu Dudau)
- Fix the conversion of IO ranges into IO resources (Liviu Dudau)
- Add pci_get_new_domain_nr() and of_get_pci_domain_nr() (Liviu Dudau)
- Add support for parsing PCI host bridge resources from DT (Liviu Dudau)
- Add pci_remap_iospace() to map bus I/O resources (Liviu Dudau)
- Add arm64 architectural support for PCI (Liviu Dudau)
APM X-Gene
- Add APM X-Gene PCIe driver (Tanmay Inamdar)
- Add arm64 DT APM X-Gene PCIe device tree nodes (Tanmay Inamdar)
Freescale i.MX6
- Probe in module_init(), not fs_initcall() (Lucas Stach)
- Delay enabling reference clock for SS until it stabilizes (Tim Harvey)
Marvell MVEBU
- Fix uninitialized variable in mvebu_get_tgt_attr() (Thomas Petazzoni)
NVIDIA Tegra
- Make sure the PCIe PLL is really reset (Eric Yuen)
- Add error path tegra_msi_teardown_irq() cleanup (Jisheng Zhang)
- Fix extended configuration space mapping (Peter Daifuku)
- Implement resource hierarchy (Thierry Reding)
- Clear CLKREQ# enable on port disable (Thierry Reding)
- Add Tegra124 support (Thierry Reding)
ST Microelectronics SPEAr13xx
- Pass config resource through reg property (Pratyush Anand)
Synopsys DesignWare
- Use NULL instead of false (Fabio Estevam)
- Parse bus-range property from devicetree (Lucas Stach)
- Use pci_create_root_bus() instead of pci_scan_root_bus() (Lucas Stach)
- Remove pci_assign_unassigned_resources() (Lucas Stach)
- Check private_data validity in single place (Lucas Stach)
- Setup and clear exactly one MSI at a time (Lucas Stach)
- Remove open-coded bitmap operations (Lucas Stach)
- Fix configuration base address when using 'reg' (Minghuan Lian)
- Fix IO resource end address calculation (Minghuan Lian)
- Rename get_msi_data() to get_msi_addr() (Minghuan Lian)
- Add get_msi_data() to pcie_host_ops (Minghuan Lian)
- Add support for v3.65 hardware (Murali Karicheri)
- Fold struct pcie_port_info into struct pcie_port (Pratyush Anand)
TI Keystone
- Add TI Keystone PCIe driver (Murali Karicheri)
- Limit MRSS for all downstream devices (Murali Karicheri)
- Assume controller is already in RC mode (Murali Karicheri)
- Set device ID based on SoC to support multiple ports (Murali Karicheri)
Xilinx AXI
- Add Xilinx AXI PCIe driver (Srikanth Thokala)
- Fix xilinx_pcie_assign_msi() return value test (Dan Carpenter)
Miscellaneous
- Clean up whitespace (Quentin Lambert)
- Remove assignments from "if" conditions (Quentin Lambert)
- Move PCI_VENDOR_ID_VMWARE to pci_ids.h (Francesco Ruggeri)
- x86: Mark DMI tables as initialization data (Mathias Krause)
- x86: Move __init annotation to the correct place (Mathias Krause)
- x86: Mark constants of pci_mmcfg_nvidia_mcp55() as __initconst (Mathias Krause)
- x86: Constify pci_mmcfg_probes[] array (Mathias Krause)
- x86: Mark PCI BIOS initialization code as such (Mathias Krause)
- Parenthesize PCI_DEVID and PCI_VPD_LRDT_ID parameters (Megan Kamiya)
- Remove unnecessary variable in pci_add_dynid() (Tobias Klauser)"
* tag 'pci-v3.18-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (109 commits)
arm64: dts: Add APM X-Gene PCIe device tree nodes
PCI: Add ACS quirk for AMD A88X southbridge devices
PCI: xgene: Add APM X-Gene PCIe driver
PCI: designware: Remove open-coded bitmap operations
PCI/MSI: Remove unnecessary temporary variable
PCI/MSI: Use __write_msi_msg() instead of write_msi_msg()
MSI/powerpc: Use __read_msi_msg() instead of read_msi_msg()
PCI/MSI: Use __get_cached_msi_msg() instead of get_cached_msi_msg()
PCI/MSI: Add "msi_bus" sysfs MSI/MSI-X control for endpoints
PCI/MSI: Remove "pos" from the struct msi_desc msi_attrib
PCI/MSI: Remove unused kobject from struct msi_desc
PCI/MSI: Rename pci_msi_check_device() to pci_msi_supported()
PCI/MSI: Move D0 check into pci_msi_check_device()
PCI/MSI: Remove arch_msi_check_device()
irqchip: armada-370-xp: Remove arch_msi_check_device()
PCI/MSI/PPC: Remove arch_msi_check_device()
arm64: Add architectural support for PCI
PCI: Add pci_remap_iospace() to map bus I/O resources
of/pci: Add support for parsing PCI host bridge resources from DT
of/pci: Add pci_get_new_domain_nr() and of_get_pci_domain_nr()
arch/arm64/boot/dts/apm-storm.dtsi
During pciehp initialization, we previously wrote two hotplug commands:
pciehp_probe
pcie_init
pcie_write_cmd # command 1
pcie_init_notification
pcie_enable_notification
pcie_write_cmd # command 2
For controllers with errata like Intel CF118, we previously waited for a
timeout before issuing the second hotplug command because the first command
only updates interrupt enable bits and is not a "real" hotplug command, so
the controller doesn't report Command Completed for it.
But there's no need to disable notifications in the first place. If BIOS
left them enabled, we could easily take an interrupt before disabling them,
so there's no benefit in disabling them for the tiny window before we
enable them.
Drop the unnecessary pcie_disable_notification() call.
[bhelgaas: changelog]
Link: http://www.intel.com/content/www/us/en/processors/xeon/xeon-e7-v2-spec-update.html
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Add more Slot Control debug output and move one print after
pcie_write_cmd() to be consistent with other debug output.
When we warned about a timeout on a hotplug command, we previously printed
the time between calls to pcie_write_cmd(), without accounting for any time
spent actually waiting. Consider this sequence:
pcie_write_cmd
write SLTCTL
cmd_started = jiffies # T1
pcie_write_cmd
pcie_wait_cmd
now = jiffies # T2
wait_event_timeout # we may wait here
if (timeout)
ctrl_info("Timeout on command issued %u msec ago",
jiffies_to_msecs(now - cmd_started))
We previously printed (T2 - T1), but that doesn't include the time spent in
wait_event_timeout().
Fix this by using the current jiffies value, not the one cached before
calling wait_event_timeout().
[bhelgaas: changelog, use current jiffies instead of adding timeout]
Fixes: 40b960831cfa ("PCI: pciehp: Compute timeout from hotplug command start time")
pcie_poll_cmd() take msecs instead of jiffies, so convert timeout to msecs.
4283c70e91dc ("PCI: pciehp: Make pcie_wait_cmd() self-contained") added
a cache of the most recent command written to the Slot Control register.
This register is only 16 bits wide, but the cache ("slot_ctrl") is 32 bits.
Reduce slot_ctrl to a u16 so it matches the register size. No functional
change.
Powering off a hot-pluggable device, e.g., with pci_set_power_state(D3cold),
normally generates a hot-remove event that unbinds the driver.
Some drivers expect to remain bound to a device even while they power it
off and back on again. This can be dangerous, because if the device is
removed or replaced while it is powered off, the driver doesn't know that
anything changed. But some drivers accept that risk.
Add pci_ignore_hotplug() for use by drivers that know their device cannot
be removed. Using pci_ignore_hotplug() tells the PCI core that hot-plug
events for the device should be ignored.
The radeon and nouveau drivers use this to switch between a low-power,
integrated GPU and a higher-power, higher-performance discrete GPU. They
power off the unused GPU, but they want to remain bound to it.
This is a reimplementation of f244d8b623da ("ACPIPHP / radeon / nouveau:
Fix VGA switcheroo problem related to hotplug") but extends it to work with
both acpiphp and pciehp.
This fixes a problem where systems with dual GPUs using the radeon drivers
become unusable, freezing every few seconds (see bugzillas below). The
resume of the radeon device may also fail, e.g.,
This fixes problems on dual GPU systems where the radeon driver becomes
unusable because of problems while suspending the device, as in bug 79701:
[drm] radeon: finishing device.
radeon 0000:01:00.0: Userspace still has active objects !
radeon 0000:01:00.0: ffff8800cb4ec288 ffff8800cb4ec000 16384 4294967297 force free
WARNING: CPU: 0 PID: 67 at /home/apw/COD/linux/drivers/gpu/drm/radeon/radeon_gart.c:234 radeon_gart_unbind+0xd2/0xe0 [radeon]()
trying to unbind memory from uninitialized GART !
or while resuming it, as in bug 77261:
radeon 0000:01:00.0: ring 0 stalled for more than 10158msec
radeon 0000:01:00.0: GPU lockup ...
radeon 0000:01:00.0: GPU pci config reset
pciehp 0000:00:01.0:pcie04: Card not present on Slot(1-1)
radeon 0000:01:00.0: GPU reset succeeded, trying to resume
*ERROR* radeon: dpm resume failed
radeon 0000:01:00.0: Wait for MC idle timedout !
Link: https://bugzilla.kernel.org/show_bug.cgi?id=77261
Link: https://bugzilla.kernel.org/show_bug.cgi?id=79701
Reported-by: Shawn Starr <shawn.starr@rogers.com>
Reported-by: Jose P. <lbdkmjdf@sharklasers.com>
Acked-by: Alex Deucher <alexander.deucher@amd.com>
Acked-by: Rajat Jain <rajatxjain@gmail.com>
Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
Acked-by: Dave Airlie <airlied@redhat.com>
CC: stable@vger.kernel.org # v3.15+
During PCIe hot-plug initialization - pciehp_probe() - data structures
related to slot capabilities are set up. As part of this set up, ISRs are
put in place to handle slot events and all event bits are cleared out.
This patch adds the Data Link Layer State Changed (PCI_EXP_SLTSTA_DLLSC)
Slot Status bit to the event bits that are cleared out during
initialization.
If the BIOS doesn't clear DLLSC before handoff to the OS, pciehp notices
that it's set and interprets it as a new Link Up event, which results in
spurious messages:
pciehp 0000:82:04.0:pcie24: slot(4): Link Up event
pciehp 0000:82:04.0:pcie24: Device 0000:83:00.0 already exists at 0000:83:00, cannot hot-add
pciehp 0000:82:04.0:pcie24: Cannot add device at 0000:83:00
Prior to e48f1b67f668 ("PCI: pciehp: Use link change notifications for
hot-plug and removal"), pciehp ignored DLLSC.
Reference:
PCI-SIG. PCI Express Base Specification Revision 4.0 Version 0.3
(PCI-SIG, 2014): 7.8.11. Slot Status Register (Offset 1Ah).
[bhelgaas: add e48f1b67f668 ref and stable tag]
Fixes: e48f1b67f668 ("PCI: pciehp: Use link change notifications for hot-plug and removal")
Link: https://bugzilla.kernel.org/show_bug.cgi?id=79611
Signed-off-by: Myron Stowe <myron.stowe@redhat.com>
"no_cmd_complete" is only used once, and it duplicates read-only
information we already have in the cached Slot Capabilities value.
Remove the field and use the existing macro NO_CMD_CMPL() instead.
Signed-off-by: Rajat Jain <rajatxjain@gmail.com>
Signed-off-by: Rajat Jain <rajatjain@juniper.net>
Signed-off-by: Guenter Roeck <groeck@juniper.net>
We use incorrect logic to decide whether a PCIe hotplug controller
generates command completion events.
5808639bfa98 ("pciehp: fix slow probing") assumed that the Slot Status
"Command Completed" bit was set only for commands affecting slot power,
indicators, or electromechanical interlock. That assumption is false: per
sec. 6.7.3.2 of PCIe spec r3.0, a write targeting any portion of the Slot
Control register is a command, and (if command completed events are
supported) software must wait for a command to complete before issuing the
next command.
5808639bfa98 was to fix boot-time timeouts (see bugzilla below) on a Lenovo
Thinkpad R61 with an Intel hotplug controller. The controller probably has
the Intel CF118 erratum, which means it doesn't report Command Completed
unless the Slot Control power, indicator, or interlock bits are changed.
This causes a timeout because pciehp always waits for Command Complete (if
supported), regardless of which bits are changed.
Remove the incorrect logic because the timeouts have been addressed
differently by these changes:
Link: https://bugzilla.kernel.org/show_bug.cgi?id=10751
Tested-by: Rajat Jain <rajatxjain@gmail.com> (IDT 807a controller)
If we issue a hotplug command, go do something else, then come back and
wait for the command to complete, we don't have to wait the whole timeout
period, because some of it elapsed while we were doing something else.
Keep track of the time we issued the command, and wait only until the
timeout period from that point has elapsed.
For controllers with errata like Intel CF118, we previously timed out
before issuing the second hotplug command:
At time T1 (during boot):
- Write DLLSCE, ABPE, PDCE, etc. to Slot Control
At time T2 (hotplug event):
- Wait for command completion (CC) in Slot Status
- Timeout at T2 + 1 second because CC is never set in Slot Status
- Write PCC, PIC, etc. to Slot Control
With this change, we wait until T1 + 1 second instead of T2 + 1 second.
If the hotplug event is more than 1 second after the boot-time
initialization, we won't wait for the timeout at all.
We still emit a "Timeout on hotplug command" message if it timed out; we
should see this on the first hotplug event on every controller with this
erratum, as well as on real errors on controllers without the erratum.
Previously we issued a hotplug command and waited for it to complete. But
there's no need to wait until we're ready to issue the *next* command. The
next command will probably be much later, so the first one may have already
completed and we may not have to actually wait at all.
Because of hardware errata, some controllers generate command completion
events for some commands but not others. In the case of Intel CF118 (see
spec update reference), the controller indicates command completion only
for Slot Control writes that change the value of the following bits:
Power Controller Control
Power Indicator Control
Attention Indicator Control
Electromechanical Interlock Control
Changes to other bits, e.g., the interrupt enable bits, do not cause the
Command Completed bit to be set. Controllers from AMD and Nvidia are
reported to have similar errata.
These errata cause timeouts when pcie_enable_notification() enables
interrupts. Previously that timeout occurred at boot-time. With this
change, the timeout occurs later, when we change the state of the slot
power, indicators, or interlock. This speeds up boot but causes a timeout
at the first hotplug event on the slot. Subsequent events don't timeout
because only the first (boot-time) hotplug command updates Slot Control
without touching the power/indicator/interlock controls.
pcie_wait_cmd() waits for the controller to finish a hotplug command. Move
the associated logic (to determine whether waiting is required and whether
we're using interrupts or polling) from pcie_write_cmd() to
pcie_wait_cmd().
Merge quoted strings that are broken across lines into a single entity.
The compiler merges them anyway, but checkpatch complains about it, and
merging them makes it easier to grep for strings.
[bhelgaas: changelog, do the same for everything under drivers/pci]
Signed-off-by: Ryan Desfosses <ryan@desfo.org>
Fix various whitespace errors.
[bhelgaas: fix other similar problems]
In case of a spurious "cmd completed", pcie_write_cmd() does not clear it,
but yet expects more "cmd completed" events to be generated. This does not
happen because the previous (spurious) event has not been acknowledged.
Fix that.
In case a card is physically yanked out, it should immediately be removed,
regardless of the "surprise" capability bit. Thus:
- Always handle the physical removal - regardless of the "surprise" bit.
- Don't use "surprise" capability when making decisions about enabling
presence detect notifications.
- Reword the comments to indicate the intent.
Today it is there is no protection around pciehp_enable_slot() and
pciehp_disable_slot() to ensure that they complete before another
hot-plug operation can be done on that particular slot.
This patch introduces the slot->hotplug_lock to ensure that any hotplug
operations (add / remove) complete before another hotplug event can begin
processing on that particular slot.
Disable the link notification (in addition to presence detect
notifications) across the slot reset since the reset could flap the link,
and we don't want to treat it as hot unplug followed by a hotplug.
We need future link up events for hot-add, thus don't disable the link
permanently during device removal. Also, remove the static functions that
are now left unused.
This reverts part of 2debd9289997 ("PCI: pciehp: Disable/enable link during
slot power off/on"). This was discussed at the URL below, where it was
revealed that it was done for a bug in a PCIe repeater chip on that
particular platform.
Link: https://lkml.kernel.org/r/CAErSpo72KZ-a2OSQLWoK71GCgwBt676XZdGt4tEYm-6UYnLmPw@mail.gmail.com
Enable the Link state notifications unconditionally. Enable the
presence detection notification only if attention button is absent.
This was discussed at this thread:
https://lkml.kernel.org/r/529E5C0E.80903@gmail.com
A lot of systems do not have the fancy buttons and LEDs, and instead
want to rely only on the Link state change events to drive the hotplug
and removal state machinery.
(http://www.spinics.net/lists/hotplug/msg05802.html)
This patch adds support for that functionality. Here are the details
about the patch itself:
* Define and use interrupt events for linkup / linkdown.
* Make the pcie_isr() also look at link events, and direct control to
corresponding (new) link state change handler function.
* Introduce the functions to handle link-up and link-down events and
queue the add / removal work in the slot->wq to be processed by
pciehp_power_thread()
As a side note, this patch also fixes the bug
https://bugzilla.kernel.org/show_bug.cgi?id=65521 "pciehp ignores Data Link
Layer State Changed bit."
check_link_active() functionality needs to be used by subsequent patches
(that introduce link state change based hotplug). Thus make the function
non-static, and rename it to pciehp_check_link_active() so as to be
consistent with other non-static functions.
Previously, the caller checked ATTN_LED() or PWR_LED() to see whether the
slot has indicators before setting the indicator state. That clutters the
caller unnecessarily, so this moves the test inside the callees. The test
may not even be necessary; per spec it should be harmless to try to turn on
a non-existent LED. But checking first does avoid unnecessary hotplug
commands.
Add symbolic constants for the PCIe Slot Control indicator and power
control fields defined by spec and use them instead of open-coded hex
constants.
Use the PCI_EXP_SLTSTA definitions, not 0x1f, when clearing Slot Status
bits.
It's simpler to test the PCI_EXP_SLTSTA_PFD bit directly and to write the
constant back to PCI_EXP_SLTSTA.
We already have the vendor/device IDs from pci_setup_device(), so drop that
info and print things that will be more useful for debugging: the slot
number and presence of button/indicators/link active reporting/etc.
These functions:
pciehp_get_power_status()
pciehp_get_attention_status()
pciehp_set_attention_status()
pciehp_get_latch_status()
pciehp_get_adapter_status()
pcie_write_cmd()
now always return success, so this patch makes them void and drops the
error-checking code in their callers.
There's not much point in checking the return value from every config space
access because the only likely errors are design-time things like unaligned
accesses or invalid register numbers. The checking clutters the code
significantly, so this patch removes it.
Reference: http://lkml.kernel.org/r/CA+55aFzP4xEbcNmZ+MS0SQ3LrULzSq+dBiT_X9U-bPpR-Ukgrw@mail.gmail.com
The pciehp_readw() and pciehp_writew() wrappers only look up the pci_dev
and call the PCIe Capability accessors, so we can make things a little
more straightforward by just using the PCIe Capability accessors directly.
Fix whitespace, capitalization, and spelling errors. No functional change.
I know "busses" is not an error, but "buses" was more common, so I used it
consistently.
Signed-off-by: Marta Rybczynska <rybczynska@gmail.com> (pci_reset_bridge_secondary_bus())
PCIe hotplug has a bus per slot, so we can just use a normal
secondary bus reset. However, if a slot supports surprise removal,
a bus reset can be seen as a presence detection change triggering
a hot-remove followed by a hot-add. Disable presence detection from
triggering an interrupt or being polled around the bus reset.
For the workqueue creation interfaces that do not expect format strings,
make sure they cannot accidently be parsed that way. Additionally, clean
up calls made with a single parameter that would be handled as a format
string. Many callers are passing potentially dynamic string content, so
use "%s" in those cases to avoid any potential accidents.
When we have a hotplug-capable PCIe port with a second hotplug-capable
PCIe port below it, removing the device below the upstream port causes
a deadlock.
The deadlock happens because we use the pciehp_wq workqueue to run
pciehp_power_thread(), which uses pciehp_disable_slot() to remove devices
below the upstream port. When we remove the downstream PCIe port, we call
pciehp_remove(), the pciehp driver's .remove() method. That calls
flush_workqueue(pciehp_wq), which deadlocks because the
pciehp_power_thread() work item is still running.
This patch avoids the deadlock by creating a workqueue for every PCIe port
and removing the single shared workqueue.
Here's the call path that leads to the deadlock:
pciehp_queue_pushbutton_work
queue_work(pciehp_wq) # queue pciehp_power_thread
pciehp_power_thread
pciehp_disable_slot
remove_board
pciehp_unconfigure_device
pci_stop_and_remove_bus_device
pciehp_remove # pciehp driver .remove method
pciehp_release_ctrl
pcie_cleanup_slot
This is fairly urgent because it can be caused by simply unplugging a
Thunderbolt adapter, as reported by Daniel below.
Reference: http://lkml.kernel.org/r/CAMVG2ssiRgcTD1bej2tkUUfsWmpL5eNtPcNif9va2-Gzb2u8nQ@mail.gmail.com
Reported-and-tested-by: Daniel J Blueman <daniel@quora.org>
Reviewed-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com>
Signed-off-by: Yijing Wang <wangyijing@huawei.com>
Use PCI Express Capability access functions to simplify pciehp.
Signed-off-by: Jiang Liu <jiang.liu@huawei.com>
pciehp_get_cur_lnk_width()
Cc: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com>
On a system with a repeater on the system board to support gen2 hotplug,
we found that when an ExpressModule is removed from some slots,
/var/log/messages will be full of "card present/not present" warnings.
It turns out the root complex is continually trying to train the link to
the repeater because the repeater has not been reset.
This patch will disable the link at removal time to allow the repeater
to be reset properly. This also prevents a potential AER message at
removal time.
Also, when testing hotplug on a system under development, we found if we
boot the system without an EM installed, and later hot-add an EM, it
does not work with Linux, but another OS is ok. The root cause is that
BIOS left link disabled when slot was empty at boot time, and other OS
is modifying the link disable bit in link ctrl during power on/off.
So we should do the same thing to disable/enable link during power off/on.
-v2: check link DLLA bit instead of 100ms waiting.
Separate link disable/enable functions to another patch.
Signed-off-by: Yinghai Lu <yinghai.lu@oracle.com>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Will use it during power off/on of slots
Will use it for link disable status checking.
A few changes:
- remove the 'inline' and let the complier decide
- return a bool to indicate whether the link was active
- add a debug message to indicate link state when it beocmes active
During reviewing
| PCI: pciehp: wait 1000 ms before Link Training check
Linus said:
> That's a *long* time, and it's irritating to the user. It makes the
> user think "the machine is slow".
> And quite frankly, an unconditional one-second delay here seems bad.
>Two seconds was unacceptable, one second is just bad.
Try to access the pci conf of a pci device that is supposed to show up
in 1s. If we can read back a valid vendor/device id, we can return
early.
Related discussion could be found:
https://lkml.org/lkml/2011/12/6/339
-v2: seperate code to pci_bus_read_dev_vendor_id() from pci_scan_device()
and reuse it from pciehp code. Suggested by Matthew Wilcox.
-v3: According to Kenj, don't use array in stack, and don't wait too long
for crs, also return fail status if not found.
Also separate pci_bus_dev_read_vendor_id() change to another patch.
Use non-ordered workqueue for attention button events.
Attention button events on each slot can be handled asynchronously. So
we should use non-ordered workqueue. This patch also removes ordered
workqueue in pciehp as a result.
Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com>
If the port supports Link speeds greater than 5.0 GT/s, we must wait
for 100 ms after Link training completes before sending configuration
request.
Tested-by: Yinghai Lu <yinghai@kernel.org>
We need to wait for 1000 ms after Data Link Layer Link Active (DLLLA)
bit reads 1b before sending configuration request. Currently pciehp
does this wait after checking Link Training (LT) bit. But we need it
before checking LT bit because LT is still set even after DLLLA bit is
set on some platforms.
During hot plug, board_added will call pciehp_power_on_slot().
But link speed is updated in pciehp_power_on_slot().
We should not update link speed there, because that is too early.
So move the link speed update to pciehp_check_link_status() after making
sure the link has been trained.
-v2: fix compile warning that Kenji found.
Tested-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com>
Naoki Yanagimoto reported that configuration read on some hot-added
PCIe device returns invalid value. This patch fixes this problem.
According to the PCIe spec, software must wait for at least 1 second
to judge if the hot-added device is broken after Data Link Layer State
Changed Event. This patch changes pciehp driver to wait for 1 second
after the Data Link Layer State Changed Event is detected before
initiating a configuration access instead of 100 ms.
Tested-by: Naoki Yanagimoto <yanagimoto@np.css.fujitsu.com>
