attribute_groups are not supposed to change at runtime. All functions
working with attribute_groups provided by <linux/sysfs.h> work with const
attribute_group. So mark the non-const structs as const.
File size before:
418 160 8 586 24a drivers/pci/hotplug/rpadlpar_sysfs.o
File size After adding 'const':
482 96 8 586 232 drivers/pci/hotplug/rpadlpar_sysfs.o
Signed-off-by: Arvind Yadav <arvind.yadav.cs@gmail.com>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Reviewed-by: Tyrel Datwyler <tyreld@linux.vnet.ibm.com>
Currently, /sys/bus/pci/slots/ only exposes hotplug attributes when a
hotplug driver is loaded, but PCI slots have attributes such as address,
speed, width, etc. that are not related to hotplug at all.
Introduce pci_slot as the primary data structure and kobject model.
Hotplug attributes described in hotplug_slot become a secondary
structure associated with the pci_slot.
This patch only creates the infrastructure that allows the separation of
PCI slot attributes and hotplug attributes. In this patch, the PCI
hotplug core remains the only user of this infrastructure, and thus,
/sys/bus/pci/slots/ will still only become populated when a hotplug
driver is loaded.
A later patch in this series will add a second user of this new
infrastructure and demonstrate splitting the task of exposing pci_slot
attributes from hotplug_slot attributes.
- Make pci_slot the primary sysfs entity. hotplug_slot becomes a
subsidiary structure.
o pci_create_slot() creates and registers a slot with the PCI core
o pci_slot_add_hotplug() gives it hotplug capability
- Change the prototype of pci_hp_register() to take the bus and
slot number (on parent bus) as parameters.
- Remove all the ->get_address methods since this functionality is
now handled by pci_slot directly.
[achiang@hp.com: rpaphp-correctly-pci_hp_register-for-empty-pci-slots]
Tested-by: Badari Pulavarty <pbadari@us.ibm.com>
Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
[akpm@linux-foundation.org: build fix]
[akpm@linux-foundation.org: make headers_check happy]
[akpm@linux-foundation.org: nuther build fix]
[akpm@linux-foundation.org: fix typo in #include]
Signed-off-by: Alex Chiang <achiang@hp.com>
Signed-off-by: Matthew Wilcox <matthew@wil.cx>
Cc: Greg KH <greg@kroah.com>
Cc: Kristen Carlson Accardi <kristen.c.accardi@intel.com>
Cc: Len Brown <lenb@kernel.org>
Acked-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
When Greg "fixed" the sysfs usage of that driver a while back, he seem
to have introduced a bug where the quotes are added around the name of
our specific sysfs files, thus breaking the user space tool.
This fixes it. Tested DLPAR operations on a POWER6 machine successfully.
There is no need for kobject_unregister() anymore, thanks to Kay's
kobject cleanup changes, so replace all instances of it with
kobject_put().
Cc: Kay Sievers <kay.sievers@vrfy.org>
rpadlpar pci hotplug driver was doing some pretty bad stuff with the
sysfs files. This cleans up the logic to be sane and gets rid of the
gratuitous kset that is not needed for a simple directory like this.
Note, this patch is not even build tested, let alone run-time tested.
Someone with access to this hardware and can test would be greatly
appreciated.
Cc: John Rose <johnrose@austin.ibm.com>
Cc: Badari Pulavarty <pbadari@gmail.com>
Cc: Kamalesh Babulal <kamalesh@linux.vnet.ibm.com>
This also renames pci_hotplug_slots_subsys to pcis_hotplug_slots_kset
catch all current users with a build error instead of a build warning
which can easily be missed.
We don't need a "default" ktype for a kset. We should set this
explicitly every time for each kset. This change is needed so that we
can make ksets dynamic, and cleans up one of the odd, undocumented
assumption that the kset/kobject/ktype model has.
This patch is based on a lot of help from Kay Sievers.
Nasty bug in the block code was found by Dave Young
<hidave.darkstar@gmail.com>
Cc: Dave Young <hidave.darkstar@gmail.com>
A kset should not have its name set directly, so dynamically set the
name at runtime.
This is needed to remove the static array in the kobject structure which
will be changed in a future patch.
This makes it possible to build pci hotplug drivers outside of the main
kernel tree, and Sam keeps telling me to move local header files to
their proper places...
Signed-off-by: Linda Xie <lxie@us.ibm.com>
sysfs: fix drivers/pci so if an attribute does not implement
show or store method read/write will return -EIO
instead of 0.
infrastructure for it.
Let it rip!
