commit a776c491ca5e38c26d9f66923ff574d041e747f4 upstream.
I traced a nasty kexec on panic boot failure to the fact that we had
screaming msi interrupts and we were not disabling the msi messages at
kernel startup. The booting kernel had not enabled those interupts so
was not prepared to handle them.
I can see no reason why we would ever want to leave the msi interrupts
enabled at boot if something else has enabled those interrupts. The pci
spec specifies that msi interrupts should be off by default. Drivers
are expected to enable the msi interrupts if they want to use them. Our
interrupt handling code reprograms the interrupt handlers at boot and
will not be be able to do anything useful with an unexpected interrupt.
This patch applies cleanly all of the way back to 2.6.32 where I noticed
the problem.
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
Scripted with coccinelle.
Then we can use it instead of magic number 1.
Reviewed-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com>
Cc: Matthew Wilcox <willy@linux.intel.com>
Signed-off-by: Sheng Yang <sheng@linux.intel.com>
Introduce an override for the arch_[teardown|setup]_msi_irqs
that can be utilized to fallback to the default arch_* code.
If a platform wants to utilize the code paths defined
in driver/pci/msi.c it has to define HAVE_DEFAULT_MSI_TEARDOWN_IRQS
or HAVE_DEFAULT_MSI_SETUP_IRQS. Otherwise the old mechanism
of over-ridding the arch_* works fine.
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: x86@kernel.org
Handing down irq_desc to msi just so that msi can access
irq_desc.irq_data.msi_desc is a pretty stupid idea. The calling code
can hand down a pointer to msi_desc so msi code does not need to know
about the irq descriptor at all.
Reviewed-by: Ingo Molnar <mingo@elte.hu>
Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org>
commit 2ca1af9aa3285c6a5f103ed31ad09f7399fc65d7 "PCI: MSI: Remove
unsafe and unnecessary hardware access" changed read_msi_msg_desc() to
return the last MSI message written instead of reading it from the
device, since it may be called while the device is in a reduced
power state.
However, the pSeries platform code really does need to read messages
from the device, since they are initially written by firmware.
Therefore:
- Restore the previous behaviour of read_msi_msg_desc()
- Add new functions get_cached_msi_msg{,_desc}() which return the
- Use the new functions where appropriate
Acked-by: Michael Ellerman <michael@ellerman.id.au>
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
During suspend on an SMP system, {read,write}_msi_msg_desc() may be
called to mask and unmask interrupts on a device that is already in a
reduced power state. At this point memory-mapped registers including
MSI-X tables are not accessible, and config space may not be fully
functional either.
While a device is in a reduced power state its interrupts are
effectively masked and its MSI(-X) state will be restored when it is
brought back to D0. Therefore these functions can simply read and
write msi_desc::msg for devices not in D0.
Further, read_msi_msg_desc() should only ever be used to update a
previously written message, so it can always read msi_desc::msg
and never needs to touch the hardware.
Tested-by: "Michael Chan" <mchan@broadcom.com>
Use resource_size_t for MMIO address instead of unsigned long. Otherwise,
higher 32-bits of MMIO address are cleared unexpectedly in x86-32 PAE.
Acked-by: Matthew Wilcox <willy@linux.intel.com>
Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Cleanups (nearly based on checkpatch).
Before: total: 11 errors, 2 warnings, 0 checks, 842 lines checked
After: total: 0 errors, 0 warnings, 0 checks, 842 lines checked
v2: fix it's/its mistakes in comment
Reviewed-by: Matthew Wilcox <willy@linux.intel.com>
Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com>
Cleanup based on the prototype from Matthew Milcox.
Move it from the middle of the function to the end.
Unify msi_free_irqs() and msix_free_all_irqs(), and rename it to a
common void function free_msi_irqs().
And relocate the common function to where the prototype is located now.
use list_first_entry() instead of list_entry().
The msi_list never have MSI-X's msi_desc while MSI is enabled,
and also it never have MSI's msi_desc while MSI-X is enabled.
This patch remove check for MSI-X entry from the pci_disable_msi(),
referring that pci_disable_msix() does not have any check for MSI
entry.
There are 2 problems on mask states in suspend/resume.
[1]:
It is better to restore the mask states of MSI/MSI-X to initial states
(MSI is unmasked, MSI-X is masked) when we release the device.
The pci_msi_shutdown() does the restoration of mask states for MSI,
while the msi_free_irqs() does it for MSI-X. In other words, in the
"disable" path both of MSI and MSI-X are handled, but in the "shutdown"
path only MSI is handled.
MSI:
pci_disable_msi()
=> pci_msi_shutdown()
[ mask states for MSI restored ]
=> msi_set_enable(dev, pos, 0);
=> msi_free_irqs()
MSI-X:
pci_disable_msix()
=> pci_msix_shutdown()
=> msix_set_enable(dev, 0);
=> msix_free_all_irqs
=> msi_free_irqs()
[ mask states for MSI-X restored ]
This patch moves the masking for MSI-X from msi_free_irqs() to
pci_msix_shutdown().
This change has some positive side effects:
- It prevents OS from touching mask states before reading preserved
bits in the register, which can be happen if msi_free_irqs() is
called from error path in msix_capability_init().
- It also prevents touching the register after turning off MSI-X in
"disable" path, which can be a problem on some devices.
[2]:
We have cache of the mask state in msi_desc, which is automatically
updated when msi/msix_mask_irq() is called. This cached states are
used for the resume.
But since what need to be restored in the resume is the states before
the shutdown on the suspend, calling msi/msix_mask_irq() from
pci_msi/msix_shutdown() is not appropriate.
This patch introduces __msi/msix_mask_irq() that do mask as same
as msi/msix_mask_irq() but does not update cached state, for use
in pci_msi/msix_shutdown().
[updated: get rid of msi/msix_mask_irq_nocache() (proposed by Matthew Wilcox)]
The initial state of mask register of MSI is unmasked. We set it
masked before calling arch_setup_msi_irqs(). If arch_setup_msi_irq()
fails, it is better to restore the state of the mask register.
These names are too long! Drop _OFFSET to save some bytes/lines.
In current code it continues setup even if alloc_msi_entry() for MSI-X
is failed due to lack of memory. It means arch_setup_msi_irqs() might
be called with msi_desc entries less than its argument nvec.
At least x86's arch_setup_msi_irqs() uses list_for_each_entry() for
dev->msi_list that suspected to have entries same numbers as nvec, and
it doesn't check the number of allocated vectors and passed arg nvec.
Therefore it will result in success of pci_enable_msix(), with less
vectors allocated than requested.
This patch fixes the error route to return -ENOMEM, instead of continuing
the setup (proposed by Matthew Wilcox).
Note that there is no iounmap in msi_free_irqs() if no msi_disc is
allocated.
Reviewed-by: Matthew Wilcox <matthew@wil.cx>
Use msix_mask_irq() instead of direct use of writel, so as not to clear
preserved bits in the Vector Control register [31:1].
The previous MSI-X fix (8d181018532dd709ec1f789e374cda92d7b01ce1) had
three bugs. First, it didn't move the write that disabled the vector.
This led to writing garbage to the MSI-X vector (spotted by Michael
Ellerman). It didn't fix the PCI resume case, and it had a race window
where the device could generate an interrupt before the MSI-X registers
were programmed (leading to a DMA to random addresses).
Fortunately, the MSI-X capability has a bit to mask all the vectors.
By setting this bit instead of clearing the enable bit, we can ensure
the device will not generate spurious interrupts. Since the capability
is now enabled, the NIU device will not have a problem with the reads
and writes to the MSI-X registers being in the original order in the code.
Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
We have the 'pos' of the MSI capability at all locations which call
msi_set_enable(), so pass it to msi_set_enable() instead of making it
find the capability every time.
Reviewed-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com>
Remove invalid comment of msi_mask_irq().
pci_enable_msix currently returns -EINVAL if you ask
for more vectors than supported by the device, which would
typically cause fallback to regular interrupts.
It's better to return the table size, making the driver retry
MSI-X with less vectors.
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
Impact: cleanup, improve readability
Define PCI_MSI_MASK_32/64 for 32/64bit devices, instead of using
implicit offset (-4), "PCI_MSI_MASK_BIT - 4" and "PCI_MSI_MASK_BIT".
The NIU device refuses to allow accesses to MSI-X registers before MSI-X
is enabled. This patch fixes the problem by moving the read of the mask
register to after MSI-X is enabled.
Reported-by: David S. Miller <davem@davemloft.net>
Tested-by: David S. Miller <davem@davemloft.net>
Reviewed-by: David S. Miller <davem@davemloft.net>
Add the new API pci_enable_msi_block() to allow drivers to
request multiple MSI and reimplement pci_enable_msi in terms of
pci_enable_msi_block. Ensure that the architecture back ends don't
have to know about multiple MSI.
Since most of the callers already know whether they have an MSI or
an MSI-X capability, split msi_set_mask_bits() into msi_mask_irq()
and msix_mask_irq(). The only callers which don't (mask_msi_irq()
and unmask_msi_irq()) can share code in msi_set_mask_bit(). This then
becomes the only caller of msix_flush_writes(), so we can inline it.
The flushing read can be to any address that belongs to the device,
so we can eliminate the calculation too.
We can also get rid of maskbits_mask from struct msi_desc and simply
recalculate it on the rare occasion that we need it. The single-bit
'masked' element is replaced by a copy of the 32-bit 'masked' register,
so this patch does not affect the size of msi_desc.
MSI interrupts have a mask_pos where MSI-X have a mask_base. Use a
transparent union to get rid of some ugly casts.
By passing the pci_dev into alloc_msi_entry() we can be sure that
the ->dev entry is always assigned and so we don't need to check it.
Also, we used kzalloc() so we don't need to initialise ->irq to 0.
By changing from a 5-bit field to a 1-bit field, we free up some bits
that can be used by a later patch. Also rearrange the fields for better
packing on 64-bit platforms (reducing the size of msi_desc from 72 bytes
to 64 bytes).
There is code in msix_capability_init() which, when the requested number
of MSI-X couldn't be allocated, calculates how many MSI-X /could/ be
allocated and returns that to the driver. That allows the driver to then
make a second request, with a number of MSIs that should succeed.
The current code requires the arch code to setup as many msi_descs as it
can, and then return to the generic code. On some platforms the arch
code may already know how many MSI-X it can allocate, before it sets up
any of the msi_descs.
So change the logic such that if the arch code returns a positive error
code, that is taken to be the number of MSI-X that could be allocated.
If the error code is negative we still calculate the number available
using the old method.
Because it's a little subtle, make sure the error return code from
arch_setup_msi_irq() is always negative. That way only implementations
of arch_setup_msi_irqs() need to be careful about returning a positive
error code.
Signed-off-by: Michael Ellerman <michael@ellerman.id.au>
Weak functions aren't all they're cracked up to be. They lead to
incorrect binaries with some toolchains, they require us to have empty
functions we otherwise wouldn't, and the unused code is not elided
(as of gcc 4.3.2 anyway).
So replace the weak MSI arch hooks with the #define foo foo idiom. We no
longer need empty versions of arch_setup/teardown_msi_irq().
This is less source (by 1 line!), and results in smaller binaries too:
9354300 1693916 678424 11726640 b2ef30 build/powerpc/vmlinux-before
9354052 1693852 678424 11726328 b2edf8 build/powerpc/vmlinux-after
Also smaller on x86_64 and arm (iop13xx).
Introduce new function pci_msix_table_size() returning the size of
the MSI-X table of given PCI device or 0 if the device doesn't
support MSI-X.
Hidetoshi Seto points out that commit
bffac3c593eba1f9da3efd0199e49ea6558a40ce has wrong values in the array.
Rather than correct the array, we can just use a bounds check and
perform the calculation specified in the comment. As a bonus, this will
not run off the end of the array if the device specifies an illegal
value in the MSI capability.
Add an msi_mask() function which returns the correct bitmask for the
number of MSI interrupts you have. This fixes an undefined bug in
msi_capability_init().
This patch fix a following bug and does a cleanup.
bug:
commit 5993760f7fc75b77e4701f1e56dc84c0d6cf18d5
had a wrong change (since is_64 is boolean[0|1]):
- pci_write_config_dword(dev,
- msi_mask_bits_reg(pos, is_64bit_address(control)),
- maskbits);
+ pci_write_config_dword(dev, entry->msi_attrib.is_64, maskbits);
utilize:
Unify separated if (entry->msi_attrib.maskbit) statements.
Acked-by: "Jike Song" <albcamus@gmail.com>
Cc: stable@vger.kernel.org
The _OSC capability OSC_MSI_SUPPORT is set when the root bridge is added
with pci_acpi_osc_support(), so we no longer need to do it in the PCI
MSI driver. Also adds the function pci_msi_enabled, which returns true
if pci=nomsi is not on the kernel command-line.
Signed-off-by: Andrew Patterson <andrew.patterson@hp.com>
Impact: simplify code
Pass irq_desc and cfg around, instead of raw IRQ numbers - this way
we dont have to look it up again and again.
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
Currently linux doesn't have any code to set the "MSI supported" bit in
Support Fireld of _OSC. This patch adds the code for that.
Signed-off-by: Taku Izumi <izumi.taku@jp.fujitsu.com>
In msi_capability_init, we can make use of the calculated results
instead of calling is_mask_bit_support and is_64bit_address twice.
Signed-off-by: Jike Song <albcamus@gmail.com>
With the recent change to avoid masking MSIs using the MSI enable bit, devices
without an MSI mask bit will have their MSI capability always enabled when MSI
is in use, so we need to restore it regardless of the mask bit state.
Fixes kernel bz 11178.
Signed-off-by: Alan Jenkins <alan-jenkins@tuffmail.co.uk>
David Vrabel has a device which generates an interrupt storm on the INTx
pin if we disable MSI interrupts altogether. Masking interrupts is only
a performance optimisation, so we can ignore the request to mask the
interrupt.
Convert printks to use dev_printk().
I converted pr_debug() to dev_dbg(). Both use KERN_DEBUG and are enabled
only when DEBUG is defined.
I converted printk(KERN_DEBUG) to dev_printk(KERN_DEBUG), not to dev_dbg(),
because dev_dbg() is only enabled when DEBUG is defined.
I converted DBG(KERN_INFO) (only in setup-bus.c) to dev_info(). The DBG()
name makes it sound like debug, but it's been enabled forever, so dev_info()
preserves the previous behavior.
I tried to make the resource assignment formats more consistent, e.g.,
"BAR %d: got res [%#llx-%#llx] bus [%#llx-%#llx] flags %#lx\n"
instead of sometimes using "start-end" and sometimes using "size@start".
I'm not attached to one or the other; I'd just like them consistent.
Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com>
The position of MSI capability is already cached in the msi_desc when
we enter the msi_set_mask_bits(). Use it instead.
Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com>
[PATCH 2/2] pci/irq: let pci_device_shutdown to call pci_msi_shutdown v2
this change
| commit 23a274c8a5adafc74a66f16988776fc7dd6f6e51
| Author: Prakash, Sathya <sathya.prakash@lsi.com>
| Date: Fri Mar 7 15:53:21 2008 +0530
| [SCSI] mpt fusion: Enable MSI by default for SAS controllers
| This patch modifies the driver to enable MSI by default for all SAS chips.
| Signed-off-by: Sathya Prakash <sathya.prakash@lsi.com>
| Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
Causes the kexec of a RHEL 5.1 kernel to fail.
root casue: the rhel 5.1 kernel still uses INTx emulation. and
mptscsih_shutdown doesn't call pci_disable_msi to reenable INTx on kexec path
So call pci_msi_shutdown in the shutdown path to do the same thing to msix
Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com>
Signed-off-by: Jesse Barnes <jbarnes@hobbes.lan>
[PATCH 1/2] pci/irq: restore mask_bits in msi shutdown -v3
Yinghai found that kexec'ing a RHEL 5.1 kernel with 2.6.25-rc3+ kernels
prevents his NIC from working. He bisected to
| commit 89d694b9dbe769ca1004e01db0ca43964806a611
| Author: Thomas Gleixner <tglx@linutronix.de>
| Date: Mon Feb 18 18:25:17 2008 +0100
| genirq: do not leave interupts enabled on free_irq
| The default_disable() function was changed in commit:
| 76d2160147f43f982dfe881404cfde9fd0a9da21
| genirq: do not mask interrupts by default
For MSI, default_shutdown will call mask_bit for msi device. All mask bits
will left disabled after free_irq. Then in the kexec case, the next kernel
can only use msi_enable bit, so all device's MSI can not be used.
So lets to restore the mask bit to its pci reset defined value (enabled) when
we disable the kernels use of msi to be a little friendlier to kexec'd kernels.
Extend msi_set_mask_bit to msi_set_mask_bits to take mask, so we can fully
restore that to 0x00 instead of 0xfe.
