path: root/drivers/pci/pci-driver.c
2008-05-24PCI: use dev_to_node in pci_call_probeYinghai Lu
to make sure get one online node. Signed-off-by: Yinghai Lu <yinghai.lu@sun.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2008-04-29pci/irq: let pci_device_shutdown to call pci_msi_shutdown v2Yinghai Lu
[PATCH 2/2] pci/irq: let pci_device_shutdown to call pci_msi_shutdown v2 this change | commit 23a274c8a5adafc74a66f16988776fc7dd6f6e51 | Author: Prakash, Sathya <sathya.prakash@lsi.com> | Date: Fri Mar 7 15:53:21 2008 +0530 | | [SCSI] mpt fusion: Enable MSI by default for SAS controllers | | This patch modifies the driver to enable MSI by default for all SAS chips. | | Signed-off-by: Sathya Prakash <sathya.prakash@lsi.com> | Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com> | Causes the kexec of a RHEL 5.1 kernel to fail. root casue: the rhel 5.1 kernel still uses INTx emulation. and mptscsih_shutdown doesn't call pci_disable_msi to reenable INTx on kexec path So call pci_msi_shutdown in the shutdown path to do the same thing to msix Signed-off-by: Yinghai Lu <yhlu.kernel@gmail.com> Signed-off-by: Jesse Barnes <jbarnes@hobbes.lan>
2008-04-19generic: use new set_cpus_allowed_ptr functionMike Travis
* Use new set_cpus_allowed_ptr() function added by previous patch, which instead of passing the "newly allowed cpus" cpumask_t arg by value, pass it by pointer: -int set_cpus_allowed(struct task_struct *p, cpumask_t new_mask) +int set_cpus_allowed_ptr(struct task_struct *p, const cpumask_t *new_mask) * Modify CPU_MASK_ALL Depends on: [sched-devel]: sched: add new set_cpus_allowed_ptr function Signed-off-by: Mike Travis <travis@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-02-01PCI: Mem Policy: fix mempolicy usage in pci driverLee Schermerhorn
In an attempt to ensure memory allocation from the local node, the pci driver temporarily replaces the current task's memory policy with the system default policy. Trying to be a good citizen, the driver then call's mpol_get() on the new policy. When it's finished probing, it undoes the '_get by calling mpol_free() [on the system default policy] and then restores the current task's saved mempolicy. A couple of issues here: 1) it's never necessary to set a task's mempolicy to the system default policy in order to get system default allocation behavior. Simply set the current task's mempolicy to NULL and allocations will fall back to system default policy. 2) we should never [need to] call mpol_free() on the system default policy. [I plan on trapping this with a VM_BUG_ON() in a subsequent patch.] This patch removes the calls to mpol_get() and mpol_free() and uses NULL for the temporary task mempolicy to effect default allocation behavior. Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Acked-by: Christoph Lameter <clameter@sgi.com> Acked-by: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24PCI: remove foolish code from pci-driver.cGreg Kroah-Hartman
The PCI bus should not be trying to declare its own attribute type. Especially as this code could never ever be called because the driver core overwrites the driver kobject type to be its own internal type. Delete all of this code as it was never being used and is not correct. Also update my copyright on the file while I'm touching things there. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-24PCI: use proper call to driver_create_fileGreg Kroah-Hartman
Don't try to call the "raw" sysfs_create_file when we already have a helper function to do this kind of work for us. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-11-05PCI: make pci_match_device() staticAdrian Bunk
pci_match_device() no longer has any other users. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/pci-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/gregkh/pci-2.6: (37 commits) PCI: merge almost all of pci_32.h and pci_64.h together PCI: X86: Introduce and enable PCI domain support PCI: Add 'nodomains' boot option, and pci_domains_supported global PCI: modify PCI bridge control ISA flag for clarity PCI: use _CRS for PCI resource allocation PCI: avoid P2P prefetch window for expansion ROMs PCI: skip ISA ioresource alignment on some systems PCI: remove transparent bridge sizing pci: write file size to inode on proc bus file write pci: use size stored in proc_dir_entry for proc bus files pci: implement "pci=noaer" PCI: fix IDE legacy mode resources MSI: Use correct data offset for 32-bit MSI in read_msi_msg() PCI: Fix incorrect argument order to list_add_tail() in PCI dynamic ID code PCI: i386: Compaq EVO N800c needs PCI bus renumbering PCI: Remove no longer correct documentation regarding MSI vector assignment PCI: re-enable onboard sound on "MSI K8T Neo2-FIR" PCI: quirk_vt82c586_acpi: Omit reading PCI revision ID PCI: quirk amd_8131_mmrbc: Omit reading pci revision ID cpqphp: Use PCI_CLASS_REVISION instead of PCI_REVISION_ID for read ...
2007-10-12PCI: Fix incorrect argument order to list_add_tail() in PCI dynamic ID codeMichael Ellerman
The code for dynamically assigning new ids to PCI drivers, store_new_id(), calls list_add_tail() with the list head and new node arguments in reversed order. The result is that every new id written essentially overwrites the previous list of ids. Caught with the help of Rusty's "horribly bad" list_node patch: http://lkml.org/lkml/2007/6/10/10 Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12Driver core: change add_uevent_var to use a structKay Sievers
This changes the uevent buffer functions to use a struct instead of a long list of parameters. It does no longer require the caller to do the proper buffer termination and size accounting, which is currently wrong in some places. It fixes a known bug where parts of the uevent environment are overwritten because of wrong index calculations. Many thanks to Mathieu Desnoyers for finding bugs and improving the error handling. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-08-01pci: rename __pci_reenable_device() to pci_reenable_device()Tejun Heo
Rename __pci_reenable_device() to pci_reenable_device(). Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-05-09Fix more "deprecated" spellos.Randy Dunlap
Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-02PCI: remove the broken PCI_MULTITHREAD_PROBE optionAdrian Bunk
This patch removes the PCI_MULTITHREAD_PROBE option that had already been marked as broken. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-05-02PCI: Require vendor and device for new_idJean Delvare
Currently, there is no minimum number of fields required when adding a new device ID to a PCI driver through the new_id sysfs file. It is possible to add a new ID with only the vendor ID set, causing the driver to attempt to attach to all PCI devices from that vendor. This has been reported to happen accidentally: http://lists.lm-sensors.org/pipermail/lm-sensors/2007-March/019366.html It is even possible to not even set the vendor ID field, causing the driver to attempt to attach to _all_ the PCI devices. This sounds dangerous and I fail to see any valid use of this "feature". Thus I suggest that we now require at least the first two fields (vendor ID and device ID) to be set. For what it's worth, this is what the USB subsystem does. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-04-27driver core: per-subsystem multithreaded probingCornelia Huck
Make multithreaded probing work per subsystem instead of per driver. It doesn't make much sense to probe the same device for multiple drivers in parallel (after all, only one driver can bind to the device). Instead, create a probing thread for each device that probes the drivers one after another. Also make the decision to use multi-threaded probe per bus instead of per device and adapt the pci code. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-16PCI/sysfs/kobject kernel-doc fixesRandy Dunlap
Fix kernel-doc warnings in PCI, sysfs, and kobject files. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-07Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/pci-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/gregkh/pci-2.6: (41 commits) Revert "PCI: remove duplicate device id from ata_piix" msi: Make MSI useable more architectures msi: Kill the msi_desc array. msi: Remove attach_msi_entry. msi: Fix msi_remove_pci_irq_vectors. msi: Remove msi_lock. msi: Kill msi_lookup_irq MSI: Combine pci_(save|restore)_msi/msix_state MSI: Remove pci_scan_msi_device() MSI: Replace pci_msi_quirk with calls to pci_no_msi() PCI: remove duplicate device id from ipr PCI: remove duplicate device id from ata_piix PCI: power management: remove noise on non-manageable hw PCI: cleanup MSI code PCI: make isa_bridge Alpha-only PCI: remove quirk_sis_96x_compatible() PCI: Speed up the Intel SMBus unhiding quirk PCI Quirk: 1k I/O space IOBL_ADR fix on P64H2 shpchp: delete trailing whitespace shpchp: remove DBG_XXX_ROUTINE ...
2007-02-07PCI : add extremely specialized __pci_reenable_device for default resumeHidetoshi Seto
Original patch was posted as "PCI : Move pci_fixup_device and is_enabled". This 3 of 3 patches does: - add __pci_reenable_device (recover former change of 1st patch) Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Cc: Inaky Perez-Gonzalez <inaky@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-07PCI : remove too specialized __pci_enable_device for default resumeHidetoshi Seto
Original patch was posted as "PCI : Move pci_fixup_device and is_enabled". This 1 of 3 patches does: - reverts small part of Inaky's patch (remove __pci_enable_device) This change will be recovered by 3rd patch. - temporarily remove pci_fixup_device. This change will be recovered by 2nd patch. Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Cc: Inaky Perez-Gonzalez <inaky@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-07PCI: add the sysfs driver name to all modulesGreg Kroah-Hartman
This adds the module name to all PCI drivers, if they are built into the kernel or not. It will show up in /sys/modules/MODULE_NAME/drivers/ It also fixes up the IDE core, which was calling __pci_register_driver() directly. Cc: Kay Sievers <kay.sievers@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-01-22PCI: fix pci-driver kernel-docRandy Dunlap
Function short description should be on only one line. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-12-20PCI: Fix multiple problems with VIA hardwareAlan Cox
This patch is designed to fix: - Disk eating corruptor on KT7 after resume from RAM - VIA IRQ handling - VIA fixups for bus lockups after resume from RAM The core of this is to add a table of resume fixups run at resume time. We need to do this for a variety of boards and features, but particularly we need to do this to get various critical VIA fixups done on resume. The second part of the problem is to handle VIA IRQ number rules which are a bit odd and need special handling for PIC interrupts. Various patches broke various boxes and while this one may not be perfect (hopefully it is) it ensures the workaround is applied to the right devices only. From: Jean Delvare <khali@linux-fr.org> Now that PCI quirks are replayed on software resume, we can safely re-enable the Asus SMBus unhiding quirk even when software suspend support is enabled. [akpm@osdl.org: fix const warning] Signed-off-by: Alan Cox <alan@redhat.com> Cc: Jean Delvare <khali@linux-fr.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-12-20PCI: use /sys/bus/pci/drivers/<driver>/new_id firstRussell King
Unfortunately, the .../new_id feature does not work with the 8250_pci driver. The reason for this comes down to the way .../new_id is implemented. When PCI tries to match a driver to a device, it checks the modules static device ID tables _before_ checking the dynamic new_id tables. When a driver is capable of matching by ID, and falls back to matching by class (as 8250_pci does), this makes it absolutely impossible to specify a board by ID, and as such the correct driver_data value to use with it. Let's say you have a serial board with vendor 0x1234 and device 0x5678. It's class is set to PCI_CLASS_COMMUNICATION_SERIAL. On boot, this card is matched to the 8250_pci driver, which tries to probe it because it matched using the class entry. The driver finds that it is unable to automatically detect the correct settings to use, so it returns -ENODEV. You know that the information the driver needs is to match this card using a device_data value of '7'. So you echo 1234 5678 0 0 0 0 7 into new_id. The kernel attempts to re-bind 8250_pci to this device. However, because it scans the PCI driver tables, it _again_ matches the class entry which has the wrong device_data. It fails. End of story. You can't support the card without rebuilding the kernel (or writing a specific PCI probe module to support it.) So, can we make new_id override the driver-internal PCI ID tables? IOW, like this: From: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-12-01PCI: switch pci_{enable,disable}_device() to be nestableInaky Perez-Gonzalez
Changes the pci_{enable,disable}_device() functions to work in a nested basis, so that eg, three calls to enable_device() require three calls to disable_device(). The reason for this is to simplify PCI drivers for multi-interface/capability devices. These are devices that cram more than one interface in a single function. A relevant example of that is the Wireless [USB] Host Controller Interface (similar to EHCI) [see http://www.intel.com/technology/comms/wusb/whci.htm]. In these kind of devices, multiple interfaces are accessed through a single bar and IRQ line. For that, the drivers map only the smallest area of the bar to access their register banks and use shared IRQ handlers. However, because the order at which those drivers load cannot be known ahead of time, the sequence in which the calls to pci_enable_device() and pci_disable_device() cannot be predicted. Thus: 1. driverA starts pci_enable_device() 2. driverB starts pci_enable_device() 3. driverA shutdown pci_disable_device() 4. driverB shutdown pci_disable_device() between steps 3 and 4, driver B would loose access to it's device, even if it didn't intend to. By using this modification, the device won't be disabled until all the callers to enable() have called disable(). This is implemented by replacing 'struct pci_dev->is_enabled' from a bitfield to an atomic use count. Each caller to enable increments it, each caller to disable decrements it. When the count increments from 0 to 1, __pci_enable_device() is called to actually enable the device. When it drops to zero, pci_disable_device() actually does the disabling. We keep the backend __pci_enable_device() for pci_default_resume() to use and also change the sysfs method implementation, so that userspace enabling/disabling the device doesn't disable it one time too much. Signed-off-by: Inaky Perez-Gonzalez <inaky@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-12-01pci: fix __pci_register_driver error handlingAkinobu Mita
__pci_register_driver() error path forgot to unwind. driver_unregister() needs to be called when pci_create_newid_file() failed. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-10-27PCI: reset pci device state to unknown state for resumeShaohua Li
Considering below scenario: 1.Unload a PCI device's driver, the device ->current remains in PCI_D0. 2.Do suspend/resume circle. After that, BIOS puts the device to D3. 3.Reload the device driver. The calling pci_set_power_state in the driver can't change the state to D0, as set_power_state thinks the device is already in D0. A bug is reported at http://bugzilla.kernel.org/show_bug.cgi?id=6024 Pat attached a patch at http://marc.theaimsgroup.com/?l=linux-pci&m=114049761428561&w=2 for this issue, but it's lost. As pci_set_power_state can handle D3 -> D0 correctly (restore config space), I simplified Patrick's patch. Signed-off-by: Shaohua Li <shaohua.li@intel.com> Cc: Patrick Mochel <mochel@digitalimplant.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-26PCI: Multiprobe sanitizerAlan Cox
There are numerous drivers that can use multithreaded probing but having some kind of global flag as the way to control this makes migration to threaded probing hard and since it enables it everywhere and is almost as likely to cause serious pain as holding a clog dance in a minefield. If we have a pci_driver multithread_probe flag to inherit you can turn it on for one driver at a time. From playing so far however I think we need a different model at the device layer which serializes until the called probe function says "ok you can start another one now". That would need some kind of flag and semaphore plus a helper function. Anyway in the absence of that this is a starting point to usefully play with this stuff Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-26PCI: fix __must_check warningsGreg Kroah-Hartman
2006-09-25PCI: enable driver multi-threaded probeGreg Kroah-Hartman
This provides a build and run-time option to turn on multhreaded probe for all PCI drivers. It can cause bad problems on multi-processor machines that take a while to find their root disks, and play havoc on machines that don't use persistant device names for block or network devices. But it can cause speedups on some machines, my tiny laptop's boot goes up by 0.4 seconds, and my desktop boots up several seconds faster. Use at your own risk!!! Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-25PM: no suspend_prepare() phaseDavid Brownell
Remove the new suspend_prepare() phase. It doesn't seem very usable, has never been tested, doesn't address fault cleanup, and would need a sibling resume_complete(); plus there are no real use cases. It could be restored later if those issues get resolved. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Linus Torvalds <torvalds@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-25Suspend changes for PCI coreLinus Torvalds
Changes the PCI core to use the new suspend infrastructure changes. Signed-off-by: Linus Torvalds <torvalds@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-08-26[PATCH] PCI: kerneldoc correction in pci-driverHenrik Kretzschmar
Removes an unused kerneldoc entry from pci_match_device and put the others into correct order. Signed-off-by: Henrik Kretzschmar <henne@nachtwindheim.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-11[PATCH] PCI: Error handling on PCI device resumeJean Delvare
We currently don't handle errors properly when resuming a PCI device: * In pci_default_resume() we capture the error code returned by pci_enable_device() but don't pass it up to the caller. Introduced by commit 95a629657dbe28e44a312c47815b3dc3f1ce0970 * In pci_resume_device(), the errors possibly returned by the driver's .resume method or by the generic pci_default_resume() function are ignored. This patch fixes both issues. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-04-14[PATCH] pm: print name of failed suspend functionAndrew Morton
Print more diagnostic info to help identify the source of power management suspend failures. Example: usb_hcd_pci_suspend(): pci_set_power_state+0x0/0x1af() returns -22 pci_device_suspend(): usb_hcd_pci_suspend+0x0/0x11b() returns -22 suspend_device(): pci_device_suspend+0x0/0x34() returns -22 Work-in-progress. It needs lots more suspend_report_result() calls sprinkled everywhere. Cc: Patrick Mochel <mochel@digitalimplant.org> Cc: Pavel Machek <pavel@ucw.cz> Cc: Nigel Cunningham <nigel@suspend2.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-23[PATCH] PCI: kzalloc() conversion in drivers/pciEric Sesterhenn
this patch converts drivers/pci to kzalloc usage. Compile tested with allyes config. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-23[PATCH] PCI: Add pci_device_shutdown to pci_bus_typeBrian Gerst
The extra compatability code is not necessary. Any code still using the old shutdown method will trigger the warning in driver_register() instead. Signed-off-by: Brian Gerst <bgerst@didntduck.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-13[PATCH] Add pci_bus_type probe and remove methodsRussell King
Move the PCI bus device probe/remove methods to the bus_type structure. We leave the shutdown method alone since there are compatibility issues with that. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] driver core: replace "hotplug" by "uevent"Kay Sievers
Leave the overloaded "hotplug" word to susbsystems which are handling real devices. The driver core does not "plug" anything, it just exports the state to userspace and generates events. Signed-off-by: Kay Sievers <kay.sievers@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-11-10[PATCH] PCI: automatically set device_driver.ownerLaurent riffard
A nice feature of sysfs is that it can create the symlink from the driver to the module that is contained in it. It requires that the device_driver.owner is set, what is not the case for many PCI drivers. This patch allows pci_register_driver to set automatically the device_driver.owner for any PCI driver. Credits to Al Viro who suggested the method. Signed-off-by: Laurent Riffard <laurent.riffard@free.fr> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> -- drivers/ide/setup-pci.c | 12 +++++++----- drivers/pci/pci-driver.c | 9 +++++---- include/linux/ide.h | 3 ++- include/linux/pci.h | 10 ++++++++-- 4 files changed, 22 insertions(+), 12 deletions(-)
2005-11-10[PATCH] pci-driver: store_new_id() not inlineRandy Dunlap
store_new_id() should not be (and cannot be) inline; the function pointer is stored in a device_attribute table. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-11-07[PATCH] fix remaining missing includesTim Schmielau
Fix more include file problems that surfaced since I submitted the previous fix-missing-includes.patch. This should now allow not to include sched.h from module.h, which is done by a followup patch. Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] fix missing includesTim Schmielau
I recently picked up my older work to remove unnecessary #includes of sched.h, starting from a patch by Dave Jones to not include sched.h from module.h. This reduces the number of indirect includes of sched.h by ~300. Another ~400 pointless direct includes can be removed after this disentangling (patch to follow later). However, quite a few indirect includes need to be fixed up for this. In order to feed the patches through -mm with as little disturbance as possible, I've split out the fixes I accumulated up to now (complete for i386 and x86_64, more archs to follow later) and post them before the real patch. This way this large part of the patch is kept simple with only adding #includes, and all hunks are independent of each other. So if any hunk rejects or gets in the way of other patches, just drop it. My scripts will pick it up again in the next round. Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-28[PATCH] kernel-doc: PCI fixesRandy Dunlap
PCI: add descriptions for missing function parameters. Eliminate all kernel-doc warnings here. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] PCI: Fixup PCI driver shutdownRussell King
Add a warning to pci driver registration code so that we know whether we have drivers using the obsolete driver shutdown method. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-08[PATCH] PCI: start paying attention to a lot of pci function return valuesGreg Kroah-Hartman
2005-09-08[PATCH] PCI: Run PCI driver initialization on local nodeAndi Kleen
Run PCI driver initialization on local node Instead of adding messy kmalloc_node()s everywhere run the PCI driver probe on the node local to the device. This would not have helped for IDE, but should for other more clean drivers that do more initialization in probe(). It won't help for drivers that do most of the work on first open (like many network drivers) Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-07-06[PATCH] PCI: fix !CONFIG_HOTPLUG pci build problemGreg KH
Here's a patch to fix the build issue when CONFIG_HOTPLUG is not enabled in 2.6.13-rc2. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-01[PATCH] PCI: clean up dynamic pci id logicGreg Kroah-Hartman
The dynamic pci id logic has been bothering me for a while, and now that I started to look into how to move some of this to the driver core, I thought it was time to clean it all up. It ends up making the code smaller, and easier to follow, and fixes a few bugs at the same time (dynamic ids were not being matched everywhere, and so could be missed on some call paths for new devices, semaphore not needed to be grabbed when adding a new id and calling the driver core, etc.) I also renamed the function pci_match_device() to pci_match_id() as that's what it really does. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-20[PATCH] sysfs: (driver/pci) if show/store is missing return -EIODmitry Torokhov
sysfs: fix drivers/pci so if an attribute does not implement show or store method read/write will return -EIO instead of 0. Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-18[PATCH] Fix typo in drivers/pci/pci-driver.cMika Kukkonen
The git commit 794f5bfa77955c4455f6d72d8b0e2bee25f1ff0c accidentally suffers from a previous typo in that file (',' instead of ';' in end of line). Patch included. Signed-off-by: Mika Kukkonen (mikukkon@iki.fi) Signed-off-by: Linus Torvalds <torvalds@osdl.org>
