path: root/drivers/pci/pci-sysfs.c
2015-02-24PCI: Don't read past the end of sysfs "driver_override" bufferSasha Levin
When printing the driver_override parameter when it is 4095 and 4094 bytes long, the printing code would access invalid memory because we need count+1 bytes for printing. Fixes: 782a985d7af2 ("PCI: Introduce new device binding path using pci_dev.driver_override") Signed-off-by: Sasha Levin <sasha.levin@oracle.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Alex Williamson <alex.williamson@redhat.com> CC: stable@vger.kernel.org # v3.16+ CC: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> CC: Alexander Graf <agraf@suse.de> CC: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-12-14Merge tag 'driver-core-3.19-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core update from Greg KH: "Here's the set of driver core patches for 3.19-rc1. They are dominated by the removal of the .owner field in platform drivers. They touch a lot of files, but they are "simple" changes, just removing a line in a structure. Other than that, a few minor driver core and debugfs changes. There are some ath9k patches coming in through this tree that have been acked by the wireless maintainers as they relied on the debugfs changes. Everything has been in linux-next for a while" * tag 'driver-core-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (324 commits) Revert "ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries" fs: debugfs: add forward declaration for struct device type firmware class: Deletion of an unnecessary check before the function call "vunmap" firmware loader: fix hung task warning dump devcoredump: provide a one-way disable function device: Add dev_<level>_once variants ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries ath: use seq_file api for ath9k debugfs files debugfs: add helper function to create device related seq_file drivers/base: cacheinfo: remove noisy error boot message Revert "core: platform: add warning if driver has no owner" drivers: base: support cpu cache information interface to userspace via sysfs drivers: base: add cpu_device_create to support per-cpu devices topology: replace custom attribute macros with standard DEVICE_ATTR* cpumask: factor out show_cpumap into separate helper function driver core: Fix unbalanced device reference in drivers_probe driver core: fix race with userland in device_add() sysfs/kernfs: make read requests on pre-alloc files use the buffer. sysfs/kernfs: allow attributes to request write buffer be pre-allocated. fs: sysfs: return EGBIG on write if offset is larger than file size ...
2014-12-10Merge tag 'pm+acpi-3.19-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull ACPI and power management updates from Rafael Wysocki: "This time we have some more new material than we used to have during the last couple of development cycles. The most important part of it to me is the introduction of a unified interface for accessing device properties provided by platform firmware. It works with Device Trees and ACPI in a uniform way and drivers using it need not worry about where the properties come from as long as the platform firmware (either DT or ACPI) makes them available. It covers both devices and "bare" device node objects without struct device representation as that turns out to be necessary in some cases. This has been in the works for quite a few months (and development cycles) and has been approved by all of the relevant maintainers. On top of that, some drivers are switched over to the new interface (at25, leds-gpio, gpio_keys_polled) and some additional changes are made to the core GPIO subsystem to allow device drivers to manipulate GPIOs in the "canonical" way on platforms that provide GPIO information in their ACPI tables, but don't assign names to GPIO lines (in which case the driver needs to do that on the basis of what it knows about the device in question). That also has been approved by the GPIO core maintainers and the rfkill driver is now going to use it. Second is support for hardware P-states in the intel_pstate driver. It uses CPUID to detect whether or not the feature is supported by the processor in which case it will be enabled by default. However, it can be disabled entirely from the kernel command line if necessary. Next is support for a platform firmware interface based on ACPI operation regions used by the PMIC (Power Management Integrated Circuit) chips on the Intel Baytrail-T and Baytrail-T-CR platforms. That interface is used for manipulating power resources and for thermal management: sensor temperature reporting, trip point setting and so on. Also the ACPI core is now going to support the _DEP configuration information in a limited way. Basically, _DEP it supposed to reflect off-the-hierarchy dependencies between devices which may be very indirect, like when AML for one device accesses locations in an operation region handled by another device's driver (usually, the device depended on this way is a serial bus or GPIO controller). The support added this time is sufficient to make the ACPI battery driver work on Asus T100A, but it is general enough to be able to cover some other use cases in the future. Finally, we have a new cpufreq driver for the Loongson1B processor. In addition to the above, there are fixes and cleanups all over the place as usual and a traditional ACPICA update to a recent upstream release. As far as the fixes go, the ACPI LPSS (Low-power Subsystem) driver for Intel platforms should be able to handle power management of the DMA engine correctly, the cpufreq-dt driver should interact with the thermal subsystem in a better way and the ACPI backlight driver should handle some more corner cases, among other things. On top of the ACPICA update there are fixes for race conditions in the ACPICA's interrupt handling code which might lead to some random and strange looking failures on some systems. In the cleanups department the most visible part is the series of commits targeted at getting rid of the CONFIG_PM_RUNTIME configuration option. That was triggered by a discussion regarding the generic power domains code during which we realized that trying to support certain combinations of PM config options was painful and not really worth it, because nobody would use them in production anyway. For this reason, we decided to make CONFIG_PM_SLEEP select CONFIG_PM_RUNTIME and that lead to the conclusion that the latter became redundant and CONFIG_PM could be used instead of it. The material here makes that replacement in a major part of the tree, but there will be at least one more batch of that in the second part of the merge window. Specifics: - Support for retrieving device properties information from ACPI _DSD device configuration objects and a unified device properties interface for device drivers (and subsystems) on top of that. As stated above, this works with Device Trees and ACPI and allows device drivers to be written in a platform firmware (DT or ACPI) agnostic way. The at25, leds-gpio and gpio_keys_polled drivers are now going to use this new interface and the GPIO subsystem is additionally modified to allow device drivers to assign names to GPIO resources returned by ACPI _CRS objects (in case _DSD is not present or does not provide the expected data). The changes in this set are mostly from Mika Westerberg, Rafael J Wysocki, Aaron Lu, and Darren Hart with some fixes from others (Fabio Estevam, Geert Uytterhoeven). - Support for Hardware Managed Performance States (HWP) as described in Volume 3, section 14.4, of the Intel SDM in the intel_pstate driver. CPUID is used to detect whether or not the feature is supported by the processor. If supported, it will be enabled automatically unless the intel_pstate=no_hwp switch is present in the kernel command line. From Dirk Brandewie. - New Intel Broadwell-H ID for intel_pstate (Dirk Brandewie). - Support for firmware interface based on ACPI operation regions used by the PMIC chips on the Intel Baytrail-T and Baytrail-T-CR platforms for power resource control and thermal management (Aaron Lu). - Limited support for retrieving off-the-hierarchy dependencies between devices from ACPI _DEP device configuration objects and deferred probing support for the ACPI battery driver based on the _DEP information to make that driver work on Asus T100A (Lan Tianyu). - New cpufreq driver for the Loongson1B processor (Kelvin Cheung). - ACPICA update to upstream revision 20141107 which only affects tools (Bob Moore). - Fixes for race conditions in the ACPICA's interrupt handling code and in the ACPI code related to system suspend and resume (Lv Zheng and Rafael J Wysocki). - ACPI core fix for an RCU-related issue in the ioremap() regions management code that slowed down significantly after CPUs had been allowed to enter idle states even if they'd had RCU callbakcs queued and triggered some problems in certain proprietary graphics driver (and elsewhere). The fix replaces synchronize_rcu() in that code with synchronize_rcu_expedited() which makes the issue go away. From Konstantin Khlebnikov. - ACPI LPSS (Low-Power Subsystem) driver fix to handle power management of the DMA engine included into the LPSS correctly. The problem is that the DMA engine doesn't have ACPI PM support of its own and it simply is turned off when the last LPSS device having ACPI PM support goes into D3cold. To work around that, the PM domain used by the ACPI LPSS driver is redesigned so at least one device with ACPI PM support will be on as long as the DMA engine is in use. From Andy Shevchenko. - ACPI backlight driver fix to avoid using it on "Win8-compatible" systems where it doesn't work and where it was used by default by mistake (Aaron Lu). - Assorted minor ACPI core fixes and cleanups from Tomasz Nowicki, Sudeep Holla, Huang Rui, Hanjun Guo, Fabian Frederick, and Ashwin Chaugule (mostly related to the upcoming ARM64 support). - Intel RAPL (Running Average Power Limit) power capping driver fixes and improvements including new processor IDs (Jacob Pan). - Generic power domains modification to power up domains after attaching devices to them to meet the expectations of device drivers and bus types assuming devices to be accessible at probe time (Ulf Hansson). - Preliminary support for controlling device clocks from the generic power domains core code and modifications of the ARM/shmobile platform to use that feature (Ulf Hansson). - Assorted minor fixes and cleanups of the generic power domains core code (Ulf Hansson, Geert Uytterhoeven). - Assorted minor fixes and cleanups of the device clocks control code in the PM core (Geert Uytterhoeven, Grygorii Strashko). - Consolidation of device power management Kconfig options by making CONFIG_PM_SLEEP select CONFIG_PM_RUNTIME and removing the latter which is now redundant (Rafael J Wysocki and Kevin Hilman). That is the first batch of the changes needed for this purpose. - Core device runtime power management support code cleanup related to the execution of callbacks (Andrzej Hajda). - cpuidle ARM support improvements (Lorenzo Pieralisi). - cpuidle cleanup related to the CPUIDLE_FLAG_TIME_VALID flag and a new MAINTAINERS entry for ARM Exynos cpuidle (Daniel Lezcano and Bartlomiej Zolnierkiewicz). - New cpufreq driver callback (->ready) to be executed when the cpufreq core is ready to use a given policy object and cpufreq-dt driver modification to use that callback for cooling device registration (Viresh Kumar). - cpufreq core fixes and cleanups (Viresh Kumar, Vince Hsu, James Geboski, Tomeu Vizoso). - Assorted fixes and cleanups in the cpufreq-pcc, intel_pstate, cpufreq-dt, pxa2xx cpufreq drivers (Lenny Szubowicz, Ethan Zhao, Stefan Wahren, Petr Cvek). - OPP (Operating Performance Points) framework modification to allow OPPs to be removed too and update of a few cpufreq drivers (cpufreq-dt, exynos5440, imx6q, cpufreq) to remove OPPs (added during initialization) on driver removal (Viresh Kumar). - Hibernation core fixes and cleanups (Tina Ruchandani and Markus Elfring). - PM Kconfig fix related to CPU power management (Pankaj Dubey). - cpupower tool fix (Prarit Bhargava)" * tag 'pm+acpi-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (120 commits) i2c-omap / PM: Drop CONFIG_PM_RUNTIME from i2c-omap.c dmaengine / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM tools: cpupower: fix return checks for sysfs_get_idlestate_count() drivers: sh / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM e1000e / igb / PM: Eliminate CONFIG_PM_RUNTIME MMC / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM MFD / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM misc / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM media / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM input / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM leds: leds-gpio: Fix multiple instances registration without 'label' property iio / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM hsi / OMAP / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM i2c-hid / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM drm / exynos / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM gpio / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM hwrandom / exynos / PM: Use CONFIG_PM in #ifdef block / PM: Replace CONFIG_PM_RUNTIME with CONFIG_PM USB / PM: Drop CONFIG_PM_RUNTIME from the USB core PM: Merge the SET*_RUNTIME_PM_OPS() macros ...
2014-12-10Merge tag 'pci-v3.19-changes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull PCI changes from Bjorn Helgaas: "Here are the PCI changes intended for v3.19. I don't think there's anything very exciting here, but there was a lot of MSI-related stuff coming via Thomas. Details: NUMA - Allow numa_node override via sysfs (Prarit Bhargava) Resource management - Restore detection of read-only BARs (Myron Stowe) - Shrink decoding-disabled window while sizing BARs (Myron Stowe) - Add informational printk for invalid BARs (Myron Stowe) - Remove fixed parameter in pci_iov_resource_bar() (Myron Stowe) MSI - Add pci_msi_ignore_mask to prevent writes to MSI/MSI-X Mask Bits (Yijing Wang) - Revert "PCI: Add x86_msi.msi_mask_irq() and msix_mask_irq()" (Yijing Wang) - s390/MSI: Use __msi_mask_irq() instead of default_msi_mask_irq() (Yijing Wang) Virtualization - xen: Process failure for pcifront_(re)scan_root() (Chen Gang) - Make FLR and AF FLR reset warning messages different (Gavin Shan) Generic host bridge driver - Allocate config space windows after limiting bus number range (Lorenzo Pieralisi) - Convert to DT resource parsing API (Lorenzo Pieralisi) Freescale Layerscape - Add Freescale Layerscape PCIe driver (Minghuan Lian) NVIDIA Tegra - Do not build on 64-bit ARM (Thierry Reding) - Add Kconfig help text (Thierry Reding) Renesas R-Car - Make rcar_pci static (Jingoo Han) Samsung Exynos - Add exynos prefix to add_pcie_port(), pcie_init() (Jingoo Han) ST Microelectronics SPEAr13xx - Add spear prefix to add_pcie_port(), pcie_init() (Jingoo Han) - Make spear13xx_add_pcie_port() __init (Jingoo Han) - Remove unnecessary OOM message (Jingoo Han) TI DRA7xx - Add dra7xx prefix to add_pcie_port() (Jingoo Han) - Make dra7xx_add_pcie_port() __init (Jingoo Han) TI Keystone - Make ks_dw_pcie_msi_domain_ops static (Jingoo Han) - Remove unnecessary OOM message (Jingoo Han) Miscellaneous - Delete unnecessary NULL pointer checks (Markus Elfring) - Remove unused to_hotplug_slot() (Gavin Shan) - Whitespace cleanup (Jingoo Han) - Simplify if-return sequences (Quentin Lambert)" * tag 'pci-v3.19-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (28 commits) PCI: Remove fixed parameter in pci_iov_resource_bar() PCI: Add informational printk for invalid BARs PCI: tegra: Add Kconfig help text PCI: tegra: Do not build on 64-bit ARM PCI: spear: Remove unnecessary OOM message PCI: mvebu: Add a blank line after declarations PCI: designware: Add a blank line after declarations PCI: exynos: Remove unnecessary return statement PCI: imx6: Use tabs for indentation PCI: keystone: Remove unnecessary OOM message PCI: Remove unused and broken to_hotplug_slot() PCI: Make FLR and AF FLR reset warning messages different PCI: dra7xx: Add __init annotation to dra7xx_add_pcie_port() PCI: spear: Add __init annotation to spear13xx_add_pcie_port() PCI: spear: Rename add_pcie_port(), pcie_init() to spear13xx_add_pcie_port(), etc. PCI: dra7xx: Rename add_pcie_port() to dra7xx_add_pcie_port() PCI: layerscape: Add Freescale Layerscape PCIe driver PCI: Simplify if-return sequences PCI: Delete unnecessary NULL pointer checks PCI: Shrink decoding-disabled window while sizing BARs ...
2014-12-04PCI / PM: Drop CONFIG_PM_RUNTIME from the PCI coreRafael J. Wysocki
After commit b2b49ccbdd54 (PM: Kconfig: Set PM_RUNTIME if PM_SLEEP is selected) PM_RUNTIME is always set if PM is set, so quite a few depend on CONFIG_PM. Replace CONFIG_PM_RUNTIME with CONFIG_PM in the PCI core code. Reviewed-by: Ulf Hansson <ulf.hansson@linaro.org> Acked-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Kevin Hilman <khilman@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-11-07cpumask: factor out show_cpumap into separate helper functionSudeep Holla
Many sysfs *_show function use cpu{list,mask}_scnprintf to copy cpumap to the buffer aligned to PAGE_SIZE, append '\n' and '\0' to return null terminated buffer with newline. This patch creates a new helper function cpumap_print_to_pagebuf in cpumask.h using newly added bitmap_print_to_pagebuf and consolidates most of those sysfs functions using the new helper function. Signed-off-by: Sudeep Holla <sudeep.holla@arm.com> Suggested-by: Stephen Boyd <sboyd@codeaurora.org> Tested-by: Stephen Boyd <sboyd@codeaurora.org> Acked-by: "Rafael J. Wysocki" <rjw@rjwysocki.net> Acked-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: x86@kernel.org Cc: linux-acpi@vger.kernel.org Cc: linux-pci@vger.kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-06PCI: Allow numa_node override via sysfsPrarit Bhargava
NUMA systems with ACPI normally describe the physical topology via _PXM methods. But many BIOSes don't implement _PXM, which leaves the kernel with no way to discover the device topology, which reduces performance because we can't put memory and processes close to the device. The NUMA node of a PCI device is already exported in the sysfs "numa_node" file. Make that file writable so users can workaround the lack of _PXM methods in the BIOS. For example: echo 3 > /sys/devices/pci0000:ff/0000:03:1f.3/numa_node sets the node for PCI device 0000:03:1f.3. Writing the file emits a FW_BUG warning to encourage users to request firmware updates. It also taints the kernel with TAINT_FIRMWARE_WORKAROUND because overriding the node incorrectly can cause performance issues. [bhelgaas: changelog, documentation text] Signed-off-by: Prarit Bhargava <prarit@redhat.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> CC: Myron Stowe <mstowe@redhat.com> CC: Alexander Ducyk <alexander.h.duyck@redhat.com> CC: Jiang Liu <jiang.liu@linux.intel.com>
2014-10-30PCI: Rename sysfs 'enabled' file back to 'enable'Greg Kroah-Hartman
Back in commit 5136b2da770d ("PCI: convert bus code to use dev_groups"), I misstyped the 'enable' sysfs filename as 'enabled', which broke the userspace API. This patch fixes that issue by renaming the file back. Fixes: 5136b2da770d ("PCI: convert bus code to use dev_groups") Reported-by: Jeff Epler <jepler@unpythonic.net> Tested-by: Jeff Epler <jepler@unpythonic.net> # on v3.14-rt Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> CC: stable@vger.kernel.org # 3.13
2014-10-01Merge branch 'pci/msi' into nextBjorn Helgaas
* pci/msi: PCI/MSI: Remove unnecessary temporary variable PCI/MSI: Use __write_msi_msg() instead of write_msi_msg() MSI/powerpc: Use __read_msi_msg() instead of read_msi_msg() PCI/MSI: Use __get_cached_msi_msg() instead of get_cached_msi_msg() PCI/MSI: Add "msi_bus" sysfs MSI/MSI-X control for endpoints PCI/MSI: Remove "pos" from the struct msi_desc msi_attrib PCI/MSI: Remove unused kobject from struct msi_desc PCI/MSI: Rename pci_msi_check_device() to pci_msi_supported() PCI/MSI: Move D0 check into pci_msi_check_device() PCI/MSI: Remove arch_msi_check_device() irqchip: armada-370-xp: Remove arch_msi_check_device() PCI/MSI/PPC: Remove arch_msi_check_device() Conflicts: drivers/pci/host/pcie-designware.c
2014-10-01PCI/MSI: Add "msi_bus" sysfs MSI/MSI-X control for endpointsYijing Wang
The "msi_bus" sysfs file for bridges sets a bus flag to allow or disallow future driver requests for MSI or MSI-X. Previously, the sysfs file existed for endpoints but did nothing. Add "msi_bus" support for endpoints, so an administrator can prevent the use of MSI and MSI-X for individual devices. Note that as for bridges, these changes only affect future driver requests for MSI or MSI-X, so drivers may need to be reloaded. Add documentation for the "msi_bus" sysfs file. [bhelgaas: changelog, comments, add "subordinate", add endpoint printk, rework bus_flags setting, make bus_flags printk unconditional] Signed-off-by: Yijing Wang <wangyijing@huawei.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2014-09-22PCI: Generate uppercase hex for modalias interface classRicardo Ribalda Delgado
Some implementations of modprobe fail to load the driver for a PCI device automatically because the "interface" part of the modalias from the kernel is lowercase, and the modalias from file2alias is uppercase. The "interface" is the low-order byte of the Class Code, defined in PCI r3.0, Appendix D. Most interface types defined in the spec do not use alpha characters, so they won't be affected. For example, 00h, 01h, 10h, 20h, etc. are unaffected. Print the "interface" byte of the Class Code in uppercase hex, as we already do for the Vendor ID, Device ID, Class, etc. [bhelgaas: changelog] Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> CC: stable@vger.kernel.org
2014-06-10PCI: Merge multi-line quoted stringsRyan Desfosses
Merge quoted strings that are broken across lines into a single entity. The compiler merges them anyway, but checkpatch complains about it, and merging them makes it easier to grep for strings. No functional change. [bhelgaas: changelog, do the same for everything under drivers/pci] Signed-off-by: Ryan Desfosses <ryan@desfo.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2014-06-10PCI: Whitespace cleanupRyan Desfosses
Fix various whitespace errors. No functional change. [bhelgaas: fix other similar problems] Signed-off-by: Ryan Desfosses <ryan@desfo.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2014-05-28Merge branches 'pci/hotplug', 'pci/pci_is_bridge' and 'pci/virtualization' ↵Bjorn Helgaas
into next * pci/hotplug: PCI: cpqphp: Fix possible null pointer dereference NVMe: Implement PCIe reset notification callback PCI: Notify driver before and after device reset * pci/pci_is_bridge: pcmcia: Use pci_is_bridge() to simplify code PCI: pciehp: Use pci_is_bridge() to simplify code PCI: acpiphp: Use pci_is_bridge() to simplify code PCI: cpcihp: Use pci_is_bridge() to simplify code PCI: shpchp: Use pci_is_bridge() to simplify code PCI: rpaphp: Use pci_is_bridge() to simplify code sparc/PCI: Use pci_is_bridge() to simplify code powerpc/PCI: Use pci_is_bridge() to simplify code ia64/PCI: Use pci_is_bridge() to simplify code x86/PCI: Use pci_is_bridge() to simplify code PCI: Use pci_is_bridge() to simplify code PCI: Add new pci_is_bridge() interface PCI: Rename pci_is_bridge() to pci_has_subordinate() * pci/virtualization: PCI: Introduce new device binding path using pci_dev.driver_override Conflicts: drivers/pci/pci-sysfs.c
2014-05-28PCI: Introduce new device binding path using pci_dev.driver_overrideAlex Williamson
The driver_override field allows us to specify the driver for a device rather than relying on the driver to provide a positive match of the device. This shortcuts the existing process of looking up the vendor and device ID, adding them to the driver new_id, binding the device, then removing the ID, but it also provides a couple advantages. First, the above existing process allows the driver to bind to any device matching the new_id for the window where it's enabled. This is often not desired, such as the case of trying to bind a single device to a meta driver like pci-stub or vfio-pci. Using driver_override we can do this deterministically using: echo pci-stub > /sys/bus/pci/devices/0000:03:00.0/driver_override echo 0000:03:00.0 > /sys/bus/pci/devices/0000:03:00.0/driver/unbind echo 0000:03:00.0 > /sys/bus/pci/drivers_probe Previously we could not invoke drivers_probe after adding a device to new_id for a driver as we get non-deterministic behavior whether the driver we intend or the standard driver will claim the device. Now it becomes a deterministic process, only the driver matching driver_override will probe the device. To return the device to the standard driver, we simply clear the driver_override and reprobe the device: echo > /sys/bus/pci/devices/0000:03:00.0/driver_override echo 0000:03:00.0 > /sys/bus/pci/devices/0000:03:00.0/driver/unbind echo 0000:03:00.0 > /sys/bus/pci/drivers_probe Another advantage to this approach is that we can specify a driver override to force a specific binding or prevent any binding. For instance when an IOMMU group is exposed to userspace through VFIO we require that all devices within that group are owned by VFIO. However, devices can be hot-added into an IOMMU group, in which case we want to prevent the device from binding to any driver (override driver = "none") or perhaps have it automatically bind to vfio-pci. With driver_override it's a simple matter for this field to be set internally when the device is first discovered to prevent driver matches. Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Reviewed-by: Alexander Graf <agraf@suse.de> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-05-22PCI: Remove pcibios_add_platform_entries()Sebastian Ott
Remove pcibios_add_platform_entries(). Architecture-specific attributes can be achieved by setting pdev->dev.groups. Link: https://lkml.kernel.org/r/alpine.LFD.2.11.1404141101500.1529@denkbrett Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-30PCI: Move Open Firmware devspec attribute to PCI common codeSebastian Ott
Move the devspec OF attribute to PCI common code's set of device attributes since it's not architecture dependent. As a side effect microblaze and powerpc no longer need to use pcibios_add_platform_entries(). [bhelgaas: fold in #include for compile error] Link: https://lkml.kernel.org/r/alpine.LFD.2.11.1404141101500.1529@denkbrett Signed-off-by: Sebastian Ott <sebott@linux.vnet.ibm.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2014-02-07pci: use device_remove_file_self() instead of device_schedule_callback()Tejun Heo
driver-core now supports synchrnous self-deletion of attributes and the asynchrnous removal mechanism is scheduled for removal. Use it instead of device_schedule_callback(). This makes "remove" behave synchronously. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Bjorn Helgaas <bhelgaas@google.com> Cc: linux-pci@vger.kernel.org Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-13PCI: Add global pci_lock_rescan_remove()Rafael J. Wysocki
There are multiple PCI device addition and removal code paths that may be run concurrently with the generic PCI bus rescan and device removal that can be triggered via sysfs. If that happens, it may lead to multiple different, potentially dangerous race conditions. The most straightforward way to address those problems is to run the code in question under the same lock that is used by the generic rescan/remove code in pci-sysfs.c. To prepare for those changes, move the definition of the global PCI remove/rescan lock to probe.c and provide global wrappers, pci_lock_rescan_remove() and pci_unlock_rescan_remove(), allowing drivers to manipulate that lock. Also provide pci_stop_and_remove_bus_device_locked() for the callers of pci_stop_and_remove_bus_device() who only need to hold the rescan/remove lock around it. Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2013-11-14PCI: Fix whitespace, capitalization, and spelling errorsBjorn Helgaas
Fix whitespace, capitalization, and spelling errors. No functional change. I know "busses" is not an error, but "buses" was more common, so I used it consistently. Signed-off-by: Marta Rybczynska <rybczynska@gmail.com> (pci_reset_bridge_secondary_bus()) Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-10-31Merge branch 'pci/misc' into nextBjorn Helgaas
* pci/misc: PCI: Report pci_pme_active() kmalloc failure mn10300/PCI: Remove useless pcibios_last_bus frv/PCI: Remove pcibios_last_bus PCI: Fail MSI/MSI-X initialization if device is not in PCI_D0 x86/PCI: Coalesce multiple overlapping host bridge windows MAINTAINERS: Add arch/x86/pci to PCI file patterns PCI/PM: Remove pci_pm_complete() PCI: Add pci_dev_show_local_cpu() to simplify code mn10300/PCI: Remove unused pci_mem_start cris/PCI: Remove unused pci_mem_start PCI: Make pci_dev_pm_ops static Conflicts: drivers/pci/pci-sysfs.c
2013-10-07PCI: Add pci_dev_show_local_cpu() to simplify codeYijing Wang
local_cpus_show() and local_cpulist_show() are almost the same. This adds a new helper function, pci_dev_show_local_cpu(), to simplify code. The same strategy is already used by cpuaffinity_show() and cpulistaffinity_show(). Signed-off-by: Yijing Wang <wangyijing@huawei.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2013-10-07PCI: Make pci_bus_attrs, pci_dev_attrs, dev_rescan_attr, dev_remove_attr, ↵Sachin Kamat
vga_attr static Local variables used only in this file are made static. [bhelgaas: also make pci_dev_attrs[] static (from Fengguang)] Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2013-10-07PCI: convert bus code to use dev_groupsGreg Kroah-Hartman
The dev_attrs field of struct bus_type is going away soon, dev_groups should be used instead. This converts the PCI bus code to use the correct field. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2013-10-07PCI: convert bus code to use bus_groupsGreg Kroah-Hartman
The bus_attrs field of struct bus_type is going away soon, dev_groups should be used instead. This converts the PCI bus code to use the correct field. Cc: Bjorn Helgaas <bhelgaas@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-07-25PCI: Convert class code to use dev_groupsGreg Kroah-Hartman
The dev_attrs field of struct class is going away soon, dev_groups should be used instead. This converts the PCI class code to use the correct field. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2013-06-05Merge branch 'pci/jiang-iov-fixes' into nextBjorn Helgaas
* pci/jiang-iov-fixes: PCI: Hide remove and rescan sysfs interfaces for SR-IOV virtual functions PCI: Finish SR-IOV VF setup before adding the device
2013-06-05PCI: Hide remove and rescan sysfs interfaces for SR-IOV virtual functionsJiang Liu
PCI devices for SR-IOV virtual functions should only be created/ destroyed by pci_enable_sriov()/pci_disable_sriov() because special data structures are associated with SR-IOV virtual functions. So hide hotplug related sysfs interfaces "remove" and "rescan" for SR-IOV virtual functions, otherwise it may cause memory leakage and other issues. Signed-off-by: Jiang Liu <jiang.liu@huawei.com> Signed-off-by: Yijing Wang <wangyijing@huawei.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Cc: Donald Dutile <ddutile@redhat.com> Cc: Yinghai Lu <yinghai@kernel.org> Cc: Ram Pai <linuxram@us.ibm.com>
2013-06-01PCI: Replace strict_strtoul() with kstrtoul()Jingoo Han
The usage of strict_strtoul() is not preferred, because strict_strtoul() is obsolete. Thus, kstrtoul() should be used. [bhelgaas: "#define strict_strtoul kstrtoul", so no functional change] Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2013-04-15PCI: Use vma_pages() to replace (vm_end - vm_start) >> PAGE_SHIFTLibin
(*->vm_end - *->vm_start) >> PAGE_SHIFT operation is implemented as an inline funcion vma_pages() in linux/mm.h, so use it. Signed-off-by: Libin <huawei.libin@huawei.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-12-26PCI: Remove spurious error for sriov_numvfs store and simplify flowBjorn Helgaas
If we request "num_vfs" and the driver's sriov_configure() method enables exactly that number ("num_vfs_enabled"), we complain "Invalid value for number of VFs to enable" and return an error. We should silently return success instead. Also, use kstrtou16() since numVFs is defined to be a 16-bit field and rework to simplify control flow. Reported-by: Greg Rose <gregory.v.rose@intel.com> Reference: http://lkml.kernel.org/r/20121214101911.00002f59@unknown Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Tested-by: Donald Dutile <ddutile@redhat.com>
2012-12-13Merge tag 'for-3.8' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pciLinus Torvalds
Pull PCI update from Bjorn Helgaas: "Host bridge hotplug: - Untangle _PRT from struct pci_bus (Bjorn Helgaas) - Request _OSC control before scanning root bus (Taku Izumi) - Assign resources when adding host bridge (Yinghai Lu) - Remove root bus when removing host bridge (Yinghai Lu) - Remove _PRT during hot remove (Yinghai Lu) SRIOV - Add sysfs knobs to control numVFs (Don Dutile) Power management - Notify devices when power resource turned on (Huang Ying) Bug fixes - Work around broken _SEG on HP xw9300 (Bjorn Helgaas) - Keep runtime PM enabled for unbound PCI devices (Huang Ying) - Fix Optimus dual-GPU runtime D3 suspend issue (Dave Airlie) - Fix xen frontend shutdown issue (David Vrabel) - Work around PLX PCI 9050 BAR alignment erratum (Ian Abbott) Miscellaneous - Add GPL license for drivers/pci/ioapic (Andrew Cooks) - Add standard PCI-X, PCIe ASPM register #defines (Bjorn Helgaas) - NumaChip remote PCI support (Daniel Blueman) - Fix PCIe Link Capabilities Supported Link Speed definition (Jingoo Han) - Convert dev_printk() to dev_info(), etc (Joe Perches) - Add support for non PCI BAR ROM data (Matthew Garrett) - Add x86 support for host bridge translation offset (Mike Yoknis) - Report success only when every driver supports AER (Vijay Pandarathil)" Fix up trivial conflicts. * tag 'for-3.8' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (48 commits) PCI: Use phys_addr_t for physical ROM address x86/PCI: Add NumaChip remote PCI support ath9k: Use standard #defines for PCIe Capability ASPM fields iwlwifi: Use standard #defines for PCIe Capability ASPM fields iwlwifi: collapse wrapper for pcie_capability_read_word() iwlegacy: Use standard #defines for PCIe Capability ASPM fields iwlegacy: collapse wrapper for pcie_capability_read_word() cxgb3: Use standard #defines for PCIe Capability ASPM fields PCI: Add standard PCIe Capability Link ASPM field names PCI/portdrv: Use PCI Express Capability accessors PCI: Use standard PCIe Capability Link register field names x86: Use PCI setup data PCI: Add support for non-BAR ROMs PCI: Add pcibios_add_device EFI: Stash ROMs if they're not in the PCI BAR PCI: Add and use standard PCI-X Capability register names PCI/PM: Keep runtime PM enabled for unbound PCI devices xen-pcifront: Handle backend CLOSED without CLOSING PCI: SRIOV control and status via sysfs (documentation) PCI/AER: Report success only when every device has AER-aware driver ...
2012-11-28PCI: Remove CONFIG_HOTPLUG ifdefsBill Pemberton
Remove conditional code based on CONFIG_HOTPLUG being false. It's always on now in preparation of it going away as an option. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Acked-by: Bjorn Helgaas <bhelgaas@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-26Merge branch 'for-linus' into nextBjorn Helgaas
* for-linus: PCI/portdrv: Don't create hotplug slots unless port supports hotplug PCI/PM: Fix proc config reg access for D3cold and bridge suspending PCI/PM: Resume device before shutdown PCI/PM: Fix deadlock when unbinding device if parent in D3cold
2012-11-09PCI: Use spec names for SR-IOV capability fieldsBjorn Helgaas
Use the same names (almost) as the spec for TotalVFs, InitialVFs, NumVFs. Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-11-09PCI: Provide method to reduce the number of total VFs supportedDonald Dutile
Some implementations of SRIOV provide a capability structure value of TotalVFs that is greater than what the software can support. Provide a method to reduce the capability structure reported value to the value the driver can support. This ensures sysfs reports the current capability of the system, hardware and software. Example for its use: igb & ixgbe -- report 8 & 64 as TotalVFs, but drivers only support 7 & 63 maximum. Signed-off-by: Donald Dutile <ddutile@redhat.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-11-09PCI: SRIOV control and status via sysfsDonald Dutile
Provide files under sysfs to determine the maximum number of VFs an SR-IOV-capable PCIe device supports, and methods to enable and disable the VFs on a per-device basis. Currently, VF enablement by SR-IOV-capable PCIe devices is done via driver-specific module parameters. If not setup in modprobe files, it requires admin to unload & reload PF drivers with number of desired VFs to enable. Additionally, the enablement is system wide: all devices controlled by the same driver have the same number of VFs enabled. Although the latter is probably desired, there are PCI configurations setup by system BIOS that may not enable that to occur. Two files are created for the PF of PCIe devices with SR-IOV support: sriov_totalvfs Contains the maximum number of VFs the device could support as reported by the TotalVFs register in the SR-IOV extended capability. sriov_numvfs Contains the number of VFs currently enabled on this device as reported by the NumVFs register in the SR-IOV extended capability. Writing zero to this file disables all VFs. Writing a positive number to this file enables that number of VFs. These files are readable for all SR-IOV PF devices. Writes to the sriov_numvfs file are effective only if a driver that supports the sriov_configure() method is attached. Signed-off-by: Donald Dutile <ddutile@redhat.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-11-09PCI: Use is_visible() with boot_vga attribute for pci_devYinghai Lu
Should make pci_create_sysfs_dev_files() simpler. Also fix possible memleak in remove path. Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-11-09PCI: Add pci_device_type to pdev's device structYinghai Lu
Need type filled in device structure so it can be used for visible attribute control in sysfs for pci_dev. Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-11-05PCI/PM: Fix proc config reg access for D3cold and bridge suspendingHuang Ying
In https://bugzilla.kernel.org/show_bug.cgi?id=48981 Peter reported that /proc/bus/pci/??/??.? does not work for 3.6. This is because the device configuration space registers are not accessible if the corresponding parent bridge is suspended or the device is put into D3cold state. This is the same as /sys/bus/pci/devices/0000:??:??.?/config access issue. So the function used to solve sysfs issue is used to solve this issue. This patch moves pci_config_pm_runtime_get()/_put() from pci/pci-sysfs.c to pci/pci.c and makes them extern so they can be used by both the sysfs and proc paths. [bhelgaas: changelog, references, reporters] Reference: https://bugzilla.kernel.org/show_bug.cgi?id=48981 Reference: https://bugzilla.kernel.org/show_bug.cgi?id=49031 Reported-by: Forrest Loomis <cybercyst@gmail.com> Reported-by: Peter <lekensteyn@gmail.com> Reported-by: Micael Dias <kam1kaz3@gmail.com> Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> CC: stable@vger.kernel.org # v3.6+
2012-08-21PCI/PM: Fix config reg access for D3cold and bridge suspendingHuang Ying
This patch fixes the following bug: http://marc.info/?l=linux-pci&m=134338059022620&w=2 Where lspci does not work properly if a device and the corresponding parent bridge (such as PCIe port) is suspended. This is because the device configuration space registers will be not accessible if the corresponding parent bridge is suspended or the device is put into D3cold state. To solve the issue, the bridge/PCIe port connected to the device is put into active state before read/write configuration space registers. If the device is in D3cold state, it will be put into active state too. To avoid resume/suspend PCIe port for each configuration register read/write, a small delay is added before the PCIe port to go suspended. Reported-by: Bjorn Mork <bjorn@mork.no> Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Reviewed-by: Rafael J. Wysocki <rjw@sisk.pl>
2012-06-23Merge branch 'topic/huang-d3cold-v7' into nextBjorn Helgaas
* topic/huang-d3cold-v7: PCI/PM: add PCIe runtime D3cold support PCI: do not call pci_set_power_state with PCI_D3cold PCI/PM: add runtime PM support to PCIe port ACPI/PM: specify lowest allowed state for device sleep state
2012-06-23PCI/PM: add PCIe runtime D3cold supportHuang Ying
This patch adds runtime D3cold support and corresponding ACPI platform support. This patch only enables runtime D3cold support; it does not enable D3cold support during system suspend/hibernate. D3cold is the deepest power saving state for a PCIe device, where its main power is removed. While it is in D3cold, you can't access the device at all, not even its configuration space (which is still accessible in D3hot). Therefore the PCI PM registers can not be used to transition into/out of the D3cold state; that must be done by platform logic such as ACPI _PR3. To support wakeup from D3cold, a system may provide auxiliary power, which allows a device to request wakeup using a Beacon or the sideband WAKE# signal. WAKE# is usually connected to platform logic such as ACPI GPE. This is quite different from other power saving states, where devices request wakeup via a PME message on the PCIe link. Some devices, such as those in plug-in slots, have no direct platform logic. For example, there is usually no ACPI _PR3 for them. D3cold support for these devices can be done via the PCIe Downstream Port leading to the device. When the PCIe port is powered on/off, the device is powered on/off too. Wakeup events from the device will be notified to the corresponding PCIe port. For more information about PCIe D3cold and corresponding ACPI support, please refer to: - PCI Express Base Specification Revision 2.0 - Advanced Configuration and Power Interface Specification Revision 5.0 [bhelgaas: changelog] Reviewed-by: Rafael J. Wysocki <rjw@sisk.pl> Originally-by: Zheng Yan <zheng.z.yan@intel.com> Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-06-20PCI: use __weak consistentlyBjorn Helgaas
Use "__weak" instead of the gcc-specific "__attribute__ ((weak))" Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2012-04-24vgaarb: Add support for setting the default video device (v2)Matthew Garrett
The default VGA device is a somewhat fluid concept on platforms with multiple GPUs. Add support for setting it so switching code can update things appropriately, and make sure that the sysfs code returns the right device if it's changed. v2: Updated to fix builds when __ARCH_HAS_VGA_DEFAULT_DEVICE is false. Signed-off-by: Matthew Garrett <mjg@redhat.com> Acked-by: H. Peter Anvin <hpa@zytor.com> Acked-by: benh@kernel.crashing.org Cc: airlied@redhat.com Signed-off-by: Dave Airlie <airlied@redhat.com>
2012-02-27PCI: Rename pci_remove_bus_device to pci_stop_and_remove_bus_deviceYinghai Lu
The old pci_remove_bus_device actually did stop and remove. Make the name reflect that to reduce confusion. This patch is done by sed scripts and changes back some incorrect __pci_remove_bus_device changes. Suggested-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2012-02-14PCI: Make rescan bus increase bridge resource size if neededYinghai Lu
Current rescan will not touch bridge MMIO and IO. Try to reuse pci_assign_unassigned_bridge_resources(bridge) to update bridge resources, if child devices need more resources. Only do that for bridges whose children are all removed already; i.e. don't release resources that could already be in use by drivers on child devices. Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2012-01-14Merge branch 'for-linus' of git://selinuxproject.org/~jmorris/linux-securityLinus Torvalds
* 'for-linus' of git://selinuxproject.org/~jmorris/linux-security: capabilities: remove __cap_full_set definition security: remove the security_netlink_recv hook as it is equivalent to capable() ptrace: do not audit capability check when outputing /proc/pid/stat capabilities: remove task_ns_* functions capabitlies: ns_capable can use the cap helpers rather than lsm call capabilities: style only - move capable below ns_capable capabilites: introduce new has_ns_capabilities_noaudit capabilities: call has_ns_capability from has_capability capabilities: remove all _real_ interfaces capabilities: introduce security_capable_noaudit capabilities: reverse arguments to security_capable capabilities: remove the task from capable LSM hook entirely selinux: sparse fix: fix several warnings in the security server cod selinux: sparse fix: fix warnings in netlink code selinux: sparse fix: eliminate warnings for selinuxfs selinux: sparse fix: declare selinux_disable() in security.h selinux: sparse fix: move selinux_complete_init selinux: sparse fix: make selinux_secmark_refcount static SELinux: Fix RCU deref check warning in sel_netport_insert() Manually fix up a semantic mis-merge wrt security_netlink_recv(): - the interface was removed in commit fd7784615248 ("security: remove the security_netlink_recv hook as it is equivalent to capable()") - a new user of it appeared in commit a38f7907b926 ("crypto: Add userspace configuration API") causing no automatic merge conflict, but Eric Paris pointed out the issue.
2012-01-05capabilities: reverse arguments to security_capableEric Paris
security_capable takes ns, cred, cap. But the LSM capable() hook takes cred, ns, cap. The capability helper functions also take cred, ns, cap. Rather than flip argument order just to flip it back, leave them alone. Heck, this should be a little faster since argument will be in the right place! Signed-off-by: Eric Paris <eparis@redhat.com>
2011-10-31pci: Fix files needing export.h for EXPORT_SYMBOL/THIS_MODULEPaul Gortmaker
They were implicitly getting it from device.h --> module.h but we want to clean that up. So add the minimal header for these macros. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
