[ Upstream commit 16b6c8bb687cc3bec914de09061fcb8411951fda ]
When removing a device, for example a VF being removed due to SR-IOV
teardown, a "soft" hot-unplug via 'echo 1 > remove' in sysfs, or an actual
hot-unplug, we first remove the procfs and sysfs attributes for the device
before attempting to release the device from any driver bound to it.
Unbinding the driver from the device can take time. The device might need
to write out data or it might be actively in use. If it's in use by
userspace through a vfio driver, the unbind might block until the user
releases the device. This leads to a potentially non-trivial amount of
time where the device exists, but we've torn down the interfaces that
userspace uses to examine devices, for instance lspci might generate this
sort of error:
pcilib: Cannot open /sys/bus/pci/devices/0000:01:0a.3/config
lspci: Unable to read the standard configuration space header of device 0000:01:0a.3
We don't seem to have any dependence on this teardown ordering in the
kernel, so let's unbind the driver first, which is also more symmetric with
the instantiation of the device in pci_bus_add_device().
Signed-off-by: Alex Williamson <alex.williamson@redhat.com>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Starting with v4.8, we allow a PCIe port to runtime suspend to D3hot if the
port itself and its children satisfy a number of conditions. Once a child
is removed, we recheck those conditions in case the removed device was
blocking the port from suspending.
The rechecking needs to happen *after* the device has been removed from the
bus it resides on. Otherwise when walking the port's subordinate bus in
pci_bridge_d3_update(), the device being removed would erroneously still be
taken into account.
However the device is removed from the bus_list in pci_destroy_dev() and we
currently recheck *before* that. Fix it.
Fixes: 9d26d3a8f1b0 ("PCI: Put PCIe ports into D3 during suspend")
Signed-off-by: Lukas Wunner <lukas@wunner.de>
Reviewed-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Acked-by: Rafael J. Wysocki <mika.westerberg@linux.intel.com>
Currently the Linux PCI core does not touch power state of PCI bridges and
PCIe ports when system suspend is entered. Leaving them in D0 consumes
power unnecessarily and may prevent the CPU from entering deeper C-states.
With recent PCIe hardware we can power down the ports to save power given
that we take into account few restrictions:
- The PCIe port hardware is recent enough, starting from 2015.
- Devices connected to PCIe ports are effectively in D3cold once the port
is transitioned to D3 (the config space is not accessible anymore and
the link may be powered down).
- Devices behind the PCIe port need to be allowed to transition to D3cold
and back. There is a way both drivers and userspace can forbid this.
- If the device behind the PCIe port is capable of waking the system it
needs to be able to do so from D3cold.
This patch adds a new flag to struct pci_device called 'bridge_d3'. This
flag is set and cleared by the PCI core whenever there is a change in power
management state of any of the devices behind the PCIe port. When system
later on is suspended we only need to check this flag and if it is true
transition the port to D3 otherwise we leave it in D0.
Also provide override mechanism via command line parameter
"pcie_port_pm=[off|force]" that can be used to disable or enable the
feature regardless of the BIOS manufacturing date.
Tested-by: Lukas Wunner <lukas@wunner.de>
Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
* pci/resource:
PCI: Simplify pci_create_attr() control flow
PCI: Don't leak memory if sysfs_create_bin_file() fails
PCI: Simplify sysfs ROM cleanup
PCI: Remove unused IORESOURCE_ROM_COPY and IORESOURCE_ROM_BIOS_COPY
MIPS: Loongson 3: Keep CPU physical (not virtual) addresses in shadow ROM resource
MIPS: Loongson 3: Use temporary struct resource * to avoid repetition
ia64/PCI: Keep CPU physical (not virtual) addresses in shadow ROM resource
ia64/PCI: Use ioremap() instead of open-coded equivalent
ia64/PCI: Use temporary struct resource * to avoid repetition
PCI: Clean up pci_map_rom() whitespace
PCI: Remove arch-specific IORESOURCE_ROM_SHADOW size from sysfs
PCI: Set ROM shadow location in arch code, not in PCI core
PCI: Don't enable/disable ROM BAR if we're using a RAM shadow copy
PCI: Don't assign or reassign immutable resources
PCI: Mark shadow copy of VGA ROM as IORESOURCE_PCI_FIXED
x86/PCI: Mark Broadwell-EP Home Agent & PCU as having non-compliant BARs
PCI: Disable IO/MEM decoding for devices with non-compliant BARs
The IORESOURCE_ROM_COPY and IORESOURCE_ROM_BIOS_COPY bits are unused.
Remove them and code that depends on them.
Add pci_ops.{add,remove}_bus() callbacks, which will be called on every
newly created bus and when a bus is being removed, respectively. This can
be used by drivers to implement driver-specific initialization and teardown
of the bus, in addition to the architecture-specifics implemented by the
pcibios_add_bus() and the pcibios_remove_bus() functions.
Signed-off-by: Thierry Reding <treding@nvidia.com>
Export the following symbols so they can be referenced by a PCI host bridge
driver compiled as a kernel loadable module:
pci_common_swizzle
pci_create_root_bus
pci_stop_root_bus
pci_remove_root_bus
pci_assign_unassigned_bus_resources
pci_fixup_irqs
Signed-off-by: Ray Jui <rjui@broadcom.com>
Revert commit ef83b0781a73 "PCI: Remove from bus_list and release
resources in pci_release_dev()" that made some nasty race conditions
become possible. For example, if a Thunderbolt link is unplugged
and then replugged immediately, the pci_release_dev() resulting from
the hot-remove code path may be racing with the hot-add code path
which after that commit causes various kinds of breakage to happen
(up to and including a hard crash of the whole system).
Moreover, the problem that commit ef83b0781a73 attempted to address
cannot happen any more after commit 8a4c5c329de7 "PCI: Check parent
kobject in pci_destroy_dev()", because pci_destroy_dev() will now
return immediately if it has already been executed for the given
device.
Note, however, that the invocation of msi_remove_pci_irq_vectors()
removed by commit ef83b0781a73 from pci_free_resources() along with
the other changes made by it is not added back because of subsequent
code changes depending on that modification.
Fixes: ef83b0781a73 (PCI: Remove from bus_list and release resources in pci_release_dev())
Reported-by: Mika Westerberg <mika.westerberg@linux.intel.com>
If pci_stop_and_remove_bus_device() is run concurrently for a device and
its parent bridge via remove_callback(), both code paths attempt to acquire
pci_rescan_remove_lock. If the child device removal acquires it first,
there will be no problems. However, if the parent bridge removal acquires
it first, it will eventually execute pci_destroy_dev() for the child
device, but that device object will not be freed yet due to the reference
held by the concurrent child removal. Consequently, both
pci_stop_bus_device() and pci_remove_bus_device() will be executed for that
device unnecessarily and pci_destroy_dev() will see a corrupted list head
in that object. Moreover, an excess put_device() will be executed for that
device in that case which may lead to a use-after-free in the final
kobject_put() done by sysfs_schedule_callback_work().
To avoid that problem, make pci_destroy_dev() check if the device's parent
kobject is NULL, which only happens after device_del() has already run for
it. Make pci_destroy_dev() return immediately whithout doing anything in
that case.
There are multiple PCI device addition and removal code paths that may be
run concurrently with the generic PCI bus rescan and device removal that
can be triggered via sysfs. If that happens, it may lead to multiple
different, potentially dangerous race conditions.
The most straightforward way to address those problems is to run
the code in question under the same lock that is used by the
generic rescan/remove code in pci-sysfs.c. To prepare for those
changes, move the definition of the global PCI remove/rescan lock
to probe.c and provide global wrappers, pci_lock_rescan_remove()
and pci_unlock_rescan_remove(), allowing drivers to manipulate
that lock. Also provide pci_stop_and_remove_bus_device_locked()
for the callers of pci_stop_and_remove_bus_device() who only need
to hold the rescan/remove lock around it.
Previously we removed the pci_dev from the bus_list and released its
resources in pci_destroy_dev(). But that's too early: it's possible to
call pci_destroy_dev() twice for the same device (e.g., via sysfs), and
that will cause an oops when we try to remove it from bus_list the second
time.
We should remove it from the bus_list only when the last reference to the
pci_dev has been released, i.e., in pci_release_dev().
[bhelgaas: changelog]
Signed-off-by: Yinghai Lu <yinghai@kernel.org>
To be consistent with 4bff6749905d ("PCI: Move device_del() from
pci_stop_dev() to pci_destroy_dev()", this changes pci_stop_root_bus()
to use device_release_driver() instead of device_del().
This also changes pci_remove_root_bus() to use device_unregister()
instead of put_device() so it corresponds with the device_register()
call in pci_create_root_bus().
After commit bcdde7e221a8 (sysfs: make __sysfs_remove_dir() recursive)
I'm seeing traces analogous to the one below in Thunderbolt testing:
WARNING: CPU: 3 PID: 76 at /scratch/rafael/work/linux-pm/fs/sysfs/group.c:214 sysfs_remove_group+0x59/0xe0()
sysfs group ffffffff81c6c500 not found for kobject '0000:08'
Modules linked in: ...
CPU: 3 PID: 76 Comm: kworker/u16:7 Not tainted 3.13.0-rc1+ #76
Hardware name: Acer Aspire S5-391/Venus , BIOS V1.02 05/29/2012
Workqueue: kacpi_hotplug acpi_hotplug_work_fn
0000000000000009 ffff8801644b9ac8 ffffffff816b23bf 0000000000000007
ffff8801644b9b18 ffff8801644b9b08 ffffffff81046607 ffff88016925b800
0000000000000000 ffffffff81c6c500 ffff88016924f928 ffff88016924f800
Call Trace:
[<ffffffff816b23bf>] dump_stack+0x4e/0x71
[<ffffffff81046607>] warn_slowpath_common+0x87/0xb0
[<ffffffff810466d1>] warn_slowpath_fmt+0x41/0x50
[<ffffffff811e42ef>] ? sysfs_get_dirent_ns+0x6f/0x80
[<ffffffff811e5389>] sysfs_remove_group+0x59/0xe0
[<ffffffff8149f00b>] dpm_sysfs_remove+0x3b/0x50
[<ffffffff81495818>] device_del+0x58/0x1c0
[<ffffffff814959c8>] device_unregister+0x48/0x60
[<ffffffff813254fe>] pci_remove_bus+0x6e/0x80
[<ffffffff81325548>] pci_remove_bus_device+0x38/0x110
[<ffffffff8132555d>] pci_remove_bus_device+0x4d/0x110
[<ffffffff81325639>] pci_stop_and_remove_bus_device+0x19/0x20
[<ffffffff813418d0>] disable_slot+0x20/0xe0
[<ffffffff81341a38>] acpiphp_check_bridge+0xa8/0xd0
[<ffffffff813427ad>] hotplug_event+0x17d/0x220
[<ffffffff81342880>] hotplug_event_work+0x30/0x70
[<ffffffff8136d665>] acpi_hotplug_work_fn+0x18/0x24
[<ffffffff81061331>] process_one_work+0x261/0x450
[<ffffffff81061a7e>] worker_thread+0x21e/0x370
[<ffffffff81061860>] ? rescuer_thread+0x300/0x300
[<ffffffff81068342>] kthread+0xd2/0xe0
[<ffffffff81068270>] ? flush_kthread_worker+0x70/0x70
[<ffffffff816c19bc>] ret_from_fork+0x7c/0xb0
(Mika Westerberg sees them too in his tests).
Some investigation documented in kernel bug #65281 led me to the
conclusion that the source of the problem is the device_del() in
pci_stop_dev() as it now causes the sysfs directory of the device to be
removed recursively along with all of its subdirectories. That includes
the sysfs directory of the device's subordinate bus (dev->subordinate) and
its "power" group.
Consequently, when pci_remove_bus() is called for dev->subordinate in
pci_remove_bus_device(), it calls device_unregister(&bus->dev), but at this
point the sysfs directory of bus->dev doesn't exist any more and its
"power" group doesn't exist either. Thus, when dpm_sysfs_remove() called
from device_del() tries to remove that group, it triggers the above
warning.
That indicates a logical mistake in the design of
pci_stop_and_remove_bus_device(), which causes bus device objects to be
left behind their parents (bridge device objects) and can be fixed by
moving the device_del() from pci_stop_dev() into pci_destroy_dev(), so
pci_remove_bus() can be called for the device's subordinate bus before the
device itself is unregistered from the hierarchy. Still, the driver, if
any, should be detached from the device in pci_stop_dev(), so use
device_release_driver() directly from there.
References: https://bugzilla.kernel.org/show_bug.cgi?id=65281#c6
Fix whitespace, capitalization, and spelling errors. No functional change.
I know "busses" is not an error, but "buses" was more common, so I used it
consistently.
Signed-off-by: Marta Rybczynska <rybczynska@gmail.com> (pci_reset_bridge_secondary_bus())
On ACPI-based platforms, the pci_slot driver creates PCI slot devices
according to information from ACPI tables by registering an ACPI PCI
subdriver. The ACPI PCI subdriver will only be called when creating/
destroying PCI root buses, and it won't be called when hot-plugging
P2P bridges. It may cause stale PCI slot devices after hot-removing
a P2P bridge if that bridge has associated PCI slots. And the acpiphp
driver has the same issue too.
This patch introduces two hook points into the PCI core, which will
be invoked when creating/destroying PCI buses for PCI host and P2P
bridges. They could be used to setup/destroy platform dependent stuff
in a unified way, both at boot time and for PCI hotplug operations.
Signed-off-by: Jiang Liu <jiang.liu@huawei.com>
Signed-off-by: Yijing Wang <wangyijing@huawei.com>
Reviewed-by: Yinghai Lu <yinghai@kernel.org>
Cc: "Rafael J. Wysocki" <rafael.j.wysocki@intel.com>
Cc: Toshi Kani <toshi.kani@hp.com>
Cc: Myron Stowe <myron.stowe@redhat.com>
We always call device_register() and pci_create_legacy_files() for a
new bus before handing out the "struct pci_bus *". Therefore, there's
no possiblity of removing the bus with pci_remove_bus() before those
calls have been made, so we don't need to check "bus->is_added" before
calling pci_remove_legacy_files() and device_unregister().
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI changes from Bjorn Helgaas:
"Host bridge hotplug
- Major overhaul of ACPI host bridge add/start (Rafael Wysocki, Yinghai Lu)
- Major overhaul of PCI/ACPI binding (Rafael Wysocki, Yinghai Lu)
- Split out ACPI host bridge and ACPI PCI device hotplug (Yinghai Lu)
- Stop caching _PRT and make independent of bus numbers (Yinghai Lu)
PCI device hotplug
- Clean up cpqphp dead code (Sasha Levin)
- Disable ARI unless device and upstream bridge support it (Yijing Wang)
- Initialize all hot-added devices (not functions 0-7) (Yijing Wang)
Power management
- Don't touch ASPM if disabled (Joe Lawrence)
- Fix ASPM link state management (Myron Stowe)
Miscellaneous
- Fix PCI_EXP_FLAGS accessor (Alex Williamson)
- Disable Bus Master in pci_device_shutdown (Konstantin Khlebnikov)
- Document hotplug resource and MPS parameters (Yijing Wang)
- Add accessor for PCIe capabilities (Myron Stowe)
- Drop pciehp suspend/resume messages (Paul Bolle)
- Make pci_slot built-in only (not a module) (Jiang Liu)
- Remove unused PCI/ACPI bind ops (Jiang Liu)
- Removed used pci_root_bus (Bjorn Helgaas)"
* tag 'pci-v3.9-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (51 commits)
PCI/ACPI: Don't cache _PRT, and don't associate them with bus numbers
PCI: Fix PCI Express Capability accessors for PCI_EXP_FLAGS
ACPI / PCI: Make pci_slot built-in only, not a module
PCI/PM: Clear state_saved during suspend
PCI: Use atomic_inc_return() rather than atomic_add_return()
PCI: Catch attempts to disable already-disabled devices
PCI: Disable Bus Master unconditionally in pci_device_shutdown()
PCI: acpiphp: Remove dead code for PCI host bridge hotplug
PCI: acpiphp: Create companion ACPI devices before creating PCI devices
PCI: Remove unused "rc" in virtfn_add_bus()
PCI: pciehp: Drop suspend/resume ENTRY messages
PCI/ASPM: Don't touch ASPM if forcibly disabled
PCI/ASPM: Deallocate upstream link state even if device is not PCIe
PCI: Document MPS parameters pci=pcie_bus_safe, pci=pcie_bus_perf, etc
PCI: Document hpiosize= and hpmemsize= resource reservation parameters
PCI: Use PCI Express Capability accessor
PCI: Introduce accessor to retrieve PCIe Capabilities Register
PCI: Put pci_dev in device tree as early as possible
PCI: Skip attaching driver in device_add()
PCI: acpiphp: Keep driver loaded even if no slots found
Devices are added to pci_pme_list when drivers use pci_enable_wake()
or pci_wake_from_d3(), but they aren't removed from the list unless
the driver explicitly disables wakeup. Many drivers never disable
wakeup, so their devices remain on the list even after they are
removed, e.g., via hotplug. A subsequent PME poll will oops when
it tries to touch the device.
This patch disables PME# on a device before removing it, which removes
the device from pci_pme_list. This is safe even if the device never
had PME# enabled.
This oops can be triggered by unplugging a Thunderbolt ethernet adapter
on a Macbook Pro, as reported by Daniel below.
Reference: http://lkml.kernel.org/r/CAMVG2svG21yiM1wkH4_2pen2n+cr2-Zv7TbH3Gj+8MwevZjDbw@mail.gmail.com
Reported-and-tested-by: Daniel J Blueman <daniel@quora.org>
CC: stable@vger.kernel.org
According to device model documentation, the way to create/destroy PCI
devices should be symmetric. The rule is to either use
1) device_register()/device_unregister()
or
2) device_initialize()/device_add()/device_del()/put_device().
So change PCI core logic to follow the rule and get rid of the redundant
pci_dev_get()/pci_dev_put() pair.
It supports both PCI root bus and PCI bus under PCI bridge.
This restores the previous behavior of stopping all child devices before
removing any of them. The current SR-IOV design, where removing the PF
also drops references on all the VFs, depends on having the VFs continue
to exist after having been stopped.
list_del() already sets next/prev to LIST_POISON1/LIST_POISON2, so we
don't need to do anything special here to prevent further list accesses.
Tested-by: Yijing Wang <wangyijing@huawei.com>
Acked-by: Yinghai Lu <yinghai@kernel.org>
"bus" is the conventional name for a "struct pci_bus *" variable.
This removes unused code that was already commented out.
Previously, when we removed a PCI device, we made two passes over the
hierarchy rooted at the device. In the first pass, we stopped all
the devices, and in the second, we removed them.
This patch combines the two passes into one so that we remove a device as
soon as it and all its children have been stopped.
Note that we previously stopped devices in reverse order and removed them
in forward order. Now we stop and remove them in reverse order.
pci_stop_bus_devices() is only two lines of code and is only called by
pci_stop_bus_device(), so I think it's easier to read if we just fold it
into the caller. Similarly for __pci_remove_behind_bridge().
Replace list_for_each() + pci_dev_b() with the simpler
list_for_each_entry().
The PCMCIA CardBus driver was the only user of
pci_stop_and_remove_behind_bridge(), and it now uses
pci_stop_and_remove_bus_device() instead, so remove this interface.
This removes exported symbol pci_stop_and_remove_behind_bridge.
The acpiphp hotplug driver was the only user of pci_stop_bus_device() and
__pci_remove_bus_device(), and it now uses pci_stop_and_remove_bus_device()
instead, so stop exposing these interfaces.
This removes these exported symbols:
pci_stop_bus_device
Release bus number resource when removing a bus.
Don't switch to pci_remove_bus_device yet, keep the __ prefix for now
(the behavior is still the same: remove without stopping first).
This allows other out of tree users or pending patches to get notified
from compiler warning.
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
The old pci_remove_behind_bridge actually do stop and remove.
Make the name reflect that to reduce confusion.
Suggested-by: Jesse Barnes <jbarnes@virtuousgeek.org>
The old pci_remove_bus_device actually did stop and remove.
This patch is done by sed scripts and changes back some incorrect
__pci_remove_bus_device changes.
When hot removing a pci express module that has a pcie switch and supports
SRIOV, we got:
[ 5918.610127] pciehp 0000:80:02.2:pcie04: pcie_isr: intr_loc 1
[ 5918.615779] pciehp 0000:80:02.2:pcie04: Attention button interrupt received
[ 5918.622730] pciehp 0000:80:02.2:pcie04: Button pressed on Slot(3)
[ 5918.629002] pciehp 0000:80:02.2:pcie04: pciehp_get_power_status: SLOTCTRL a8 value read 1f9
[ 5918.637416] pciehp 0000:80:02.2:pcie04: PCI slot #3 - powering off due to button press.
[ 5918.647125] pciehp 0000:80:02.2:pcie04: pcie_isr: intr_loc 10
[ 5918.653039] pciehp 0000:80:02.2:pcie04: pciehp_green_led_blink: SLOTCTRL a8 write cmd 200
[ 5918.661229] pciehp 0000:80:02.2:pcie04: pciehp_set_attention_status: SLOTCTRL a8 write cmd c0
[ 5924.667627] pciehp 0000:80:02.2:pcie04: Disabling domain:bus:device=0000:b0:00
[ 5924.674909] pciehp 0000:80:02.2:pcie04: pciehp_get_power_status: SLOTCTRL a8 value read 2f9
[ 5924.683262] pciehp 0000:80:02.2:pcie04: pciehp_unconfigure_device: domain:bus:dev = 0000:b0:00
[ 5924.693976] libfcoe_device_notification: NETDEV_UNREGISTER eth6
[ 5924.764979] libfcoe_device_notification: NETDEV_UNREGISTER eth14
[ 5924.873539] libfcoe_device_notification: NETDEV_UNREGISTER eth15
[ 5924.995209] libfcoe_device_notification: NETDEV_UNREGISTER eth16
[ 5926.114407] sxge 0000:b2:00.0: PCI INT A disabled
[ 5926.119342] BUG: unable to handle kernel NULL pointer dereference at (null)
[ 5926.127189] IP: [<ffffffff81353a3b>] pci_stop_bus_device+0x33/0x83
[ 5926.133377] PGD 0
[ 5926.135402] Oops: 0000 [#1] SMP
[ 5926.138659] CPU 2
[ 5926.140499] Modules linked in:
[ 5926.143754]
[ 5926.275823] Call Trace:
[ 5926.278267] [<ffffffff81353a38>] pci_stop_bus_device+0x30/0x83
[ 5926.284180] [<ffffffff81353af4>] pci_remove_bus_device+0x1a/0xba
[ 5926.290264] [<ffffffff81366311>] pciehp_unconfigure_device+0x110/0x17b
[ 5926.296866] [<ffffffff81365dd9>] ? pciehp_disable_slot+0x188/0x188
[ 5926.303123] [<ffffffff81365d6f>] pciehp_disable_slot+0x11e/0x188
[ 5926.309206] [<ffffffff81365e68>] pciehp_power_thread+0x8f/0xe0
+-[0000:80]-+-00.0-[81-8f]--
| +-01.0-[90-9f]--
| +-02.0-[a0-af]--
| +-02.2-[b0-bf]----00.0-[b1-b3]--+-02.0-[b2]--+-00.0 Device
| | | +-00.1 Device
| | | +-00.2 Device
| | | \-00.3 Device
| | \-03.0-[b3]--+-00.0 Device
| | +-00.1 Device
| | +-00.2 Device
| | \-00.3 Device
root complex: 80:02.2
pci express modules: have pcie switch and are listed as b0:00.0, b1:02.0 and b1:03.0.
end devices are b2:00.0 and b3.00.0.
VFs are: b2:00.1,... b2:00.3, and b3:00.1,...,b3:00.3
Root cause: when doing pci_stop_bus_device() with phys fn, it will stop
virt fn and remove the fn, so
list_for_each_safe(l, n, &bus->devices)
will have problem to refer freed n that is pointed to vf entry.
Solution is just replacing list_for_each_safe() with
list_for_each_prev_safe(). This will make sure we can get valid n pointer
to PF instead of the freed VF pointer (because newly added devices are
inserted to the bus->devices list tail).
During reviewing the patch, Bjorn said:
| The PCI hot-remove path calls pci_stop_bus_devices() via
| pci_remove_bus_device().
| pci_stop_bus_devices() traverses the bus->devices list (point A below),
| stopping each device in turn, which calls the driver remove() method. When
| the device is an SR-IOV PF, the driver calls pci_disable_sriov(), which
| also uses pci_remove_bus_device() to remove the VF devices from the
| bus->devices list (point B).
| pci_stop_bus_device
| pci_stop_bus_devices(subordinate)
| list_for_each(bus->devices) <-- A
| pci_stop_bus_device(PF)
| driver->remove
| pci_disable_sriov
| pci_remove_bus_device(VF)
| <remove from bus_list> <-- B
| At B, we're changing the same list we're iterating through at A, so when
| the driver remove() method returns, the pci_stop_bus_devices() iterator has
| a pointer to a list entry that has already been freed.
Discussion thread can be found : https://lkml.org/lkml/2011/10/15/141
https://lkml.org/lkml/2012/1/23/360
-v5: According to Linus to make remove more robust, Change to
list_for_each_prev_safe instead. That is more reasonable, because
those devices are added to tail of the list before.
During test busn_res allocation with cardbus, found pci card removal is not
working anymore, and it turns out it is broken by:
|commit 79cc9601c3e42b4f0650fe7e69132ebce7ab48f9
|Date: Tue Nov 22 21:06:53 2011 -0800
| PCI: Only call pci_stop_bus_device() one time for child devices at remove
The above changed the behavior of pci_remove_behind_bridge that
yenta_cardbus depended on. So restore the old behavoir of
pci_remove_behind_bridge (which requires stopping and removing of all
devices) by:
1. rename pci_remove_behind_bridge to __pci_remove_behind_bridge, and let
__pci_remove_bus_device() call it instead.
2. add pci_stop_behind_bridge that will stop devices behind a bridge
3. add back pci_remove_behind_bridge that will stop and remove devices
under bridge.
-v2: update commit description a little bit.
Tested-by: Dominik Brodowski <linux@dominikbrodowski.net>
During debugging pcie hotplug with SRIOV with pcie switch, I found
pci_stop_bus_device() is called several times for some child devices.
So change original pci_remove_bus_device() to __pci_remove_bus_device(),
and make it only do remove work, and add a new pci_remove_bus_device
that calls pci_stop_bus_device() one time, and then call
__pci_remove_bus_device().
Requested by Greg KH to fix a race condition in the creating of PCI bus
cpuaffinity files.
We always call pci_stop_bus_device before calling pci_destroy_dev.
Since pci_stop_bus_device calls pci_stop_dev, there is no need
for pci_destroy_dev to repeat the call.
Signed-off-by: Alex Chiang <achiang@hp.com>
Fix the following kernel oops problem that happens when removing PCI
bridge with pciehp loaded. It should also occur with other hotplug
driver that is implemented as a bridge's driver.
[ 459.997257] pciehp 0000:2f:04.0:pcie24: unloading service driver pciehp
[ 459.997495] general protection fault: 0000 [#1] SMP
[ 459.997737] last sysfs file: /sys/devices/pci0000:00/0000:00:04.0/0000:2e:00.0/0000:2f:04.0/remove
[ 459.997964] CPU 4
[ 459.998129] Modules linked in: pciehp ipv6 autofs4 hidp rfcomm l2cap bluetooth sunrpc cpufreq_ondemand acpi_cpufreq dm_mirror dm_region_hash dm_log dm_multipath scsi_dh dm_mod sbs sbshc battery ac parport_pc lp parport mptspi mptscsih mptbase scsi_transport_spi e1000e sg sr_mod cdrom button serio_raw i2c_i801 i2c_core shpchp pcspkr ata_piix libata megaraid_sas sd_mod scsi_mod crc_t10dif ext3 jbd uhci_hcd ohci_hcd ehci_hcd [last unloaded: microcode]
[ 459.998129] Pid: 56, comm: events/4 Not tainted 2.6.29-rc8-kk #1 PRIMERGY
[ 459.998129] RIP: 0010:[<ffffffff803bf047>] [<ffffffff803bf047>] pci_slot_release+0x37/0x100
[ 459.998129] RSP: 0018:ffff88083b3bf9e0 EFLAGS: 00010246
[ 459.998129] RAX: ffff88083adc5158 RBX: ffff880836c1bc80 RCX: 6b6b6b6b6b6b6b6b
[ 459.998129] RDX: 0000000000000000 RSI: ffffffff803a77f0 RDI: ffff880836c1bc48
[ 459.998129] RBP: ffff88083b3bfa00 R08: 0000000000000002 R09: 0000000000000000
[ 459.998129] R10: 0000000000000000 R11: 0000000000000000 R12: ffff880836c1bc48
[ 459.998129] R13: ffff880836c1bc20 R14: ffff880836c1bc48 R15: ffff880836d1ec38
[ 459.998129] FS: 0000000000000000(0000) GS:ffff88083ccc3770(0000) knlGS:0000000000000000
[ 459.998129] CS: 0010 DS: 0018 ES: 0018 CR0: 000000008005003b
[ 459.998129] CR2: 00007f1562f1d558 CR3: 0000000838090000 CR4: 00000000000006e0
[ 459.998129] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[ 459.998129] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400
[ 459.998129] Process events/4 (pid: 56, threadinfo ffff88083b3be000, task ffff88083b3b3e40)
[ 459.998129] Stack:
[ 459.998129] ffff880836c1bc80 ffff880836c1bc48 ffffffff80793320 ffff88083b0d0960
[ 459.998129] ffff88083b3bfa30 ffffffff803a788a ffff880836c1bc80 ffffffff803a77f0
[ 459.998129] ffff880836c1bc20 ffff880836d1ec38 ffff88083b3bfa50 ffffffff803a8ce7
[ 459.998129] Call Trace:
[ 459.998129] [<ffffffff803a788a>] kobject_release+0x9a/0x290
[ 459.998129] [<ffffffff803a77f0>] ? kobject_release+0x0/0x290
[ 459.998129] [<ffffffff803a8ce7>] kref_put+0x37/0x80
[ 459.998129] [<ffffffff803a76f7>] kobject_put+0x27/0x60
[ 459.998129] [<ffffffff803bebcc>] ? pci_destroy_slot+0x3c/0xc0
[ 459.998129] [<ffffffff803bebd5>] pci_destroy_slot+0x45/0xc0
[ 459.998129] [<ffffffff803c797d>] pci_hp_deregister+0x13d/0x210
[ 459.998129] [<ffffffffa031141d>] cleanup_slots+0x2d/0x80 [pciehp]
[ 459.998129] [<ffffffffa0311735>] pciehp_remove+0x15/0x30 [pciehp]
[ 459.998129] [<ffffffff803c4c99>] pcie_port_remove_service+0x69/0x90
[ 459.998129] [<ffffffff80441da9>] __device_release_driver+0x59/0x90
[ 459.998129] [<ffffffff80441edb>] device_release_driver+0x2b/0x40
[ 459.998129] [<ffffffff804419d6>] bus_remove_device+0xa6/0x120
[ 459.998129] [<ffffffff8043e46b>] device_del+0x12b/0x190
[ 459.998129] [<ffffffff803c4d90>] ? remove_iter+0x0/0x40
[ 459.998129] [<ffffffff8043e4f6>] device_unregister+0x26/0x70
[ 459.998129] [<ffffffff803c4dbf>] remove_iter+0x2f/0x40
[ 459.998129] [<ffffffff8043ddf3>] device_for_each_child+0x33/0x60
[ 459.998129] [<ffffffff8033ee30>] ? sysfs_schedule_callback_work+0x0/0x50
[ 459.998129] [<ffffffff803c4d30>] pcie_port_device_remove+0x30/0x80
[ 459.998129] [<ffffffff803c55a1>] pcie_portdrv_remove+0x11/0x20
[ 459.998129] [<ffffffff803bfeb2>] pci_device_remove+0x32/0x70
[ 459.998129] [<ffffffff803ba969>] pci_stop_dev+0x49/0x60
[ 459.998129] [<ffffffff803baab0>] pci_remove_bus_device+0x40/0xc0
[ 459.998129] [<ffffffff803c10d9>] remove_callback+0x29/0x40
[ 459.998129] [<ffffffff8033ee4f>] sysfs_schedule_callback_work+0x1f/0x50
[ 459.998129] [<ffffffff8025769a>] run_workqueue+0x15a/0x230
[ 459.998129] [<ffffffff80257648>] ? run_workqueue+0x108/0x230
[ 459.998129] [<ffffffff8025846f>] worker_thread+0x9f/0x100
[ 459.998129] [<ffffffff8025bce0>] ? autoremove_wake_function+0x0/0x40
[ 459.998129] [<ffffffff802583d0>] ? worker_thread+0x0/0x100
[ 459.998129] [<ffffffff8025b89d>] kthread+0x4d/0x80
[ 459.998129] [<ffffffff8020d4ba>] child_rip+0xa/0x20
[ 459.998129] [<ffffffff8020cebc>] ? restore_args+0x0/0x30
[ 459.998129] [<ffffffff8025b850>] ? kthread+0x0/0x80
[ 459.998129] [<ffffffff8020d4b0>] ? child_rip+0x0/0x20
[ 459.998129] Code: 56 49 89 fe 41 55 4c 8d 6f d8 41 54 53 74 09 f6 05 b8 05 c7 00 08 75 72 49 8b 45 00 48 8b 48 28 eb 05 66 90 48 89 f1 49 8b 45 00 <48> 8b 31 48 83 c0 28 0f 18 0e 48 39 c1 74 1c 8b 41 38 41 0f b6
[ 459.998129] RIP [<ffffffff803bf047>] pci_slot_release+0x37/0x100
[ 459.998129] RSP <ffff88083b3bf9e0>
[ 460.018595] ---[ end trace 5a08d2095374aedc ]---
The pci_remove_bus_device() removes all buses and devices under the
bridge, and then removes the bridge. So the remove() callback of the
hotplug drivers implemented as a bridge's driver is executed after the
struct pci_bus of the bridge's secondary bus is removed. The remove()
callback of those driver unregisters the slot using pci_destroy_slot(),
and slot's release callback refers to the the struct pci_bus that was
already freed. This is the cause of the kernel oops.
This patch solves the problem by stopping bus drivers before removing the
bridge and its child bus and devices.
Acked-by: Alex Chiang <achiang@hp.com>
Signed-off-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com>
When removing a bus, 'is_added' should be checked to make sure the
bus has been successfully added by pci_bus_add_child() who will sets
'is_added'.
Signed-off-by: Yu Zhao <yu.zhao@intel.com>
Get rid of the second definition of dev which hides the earlier one in
the argument list and causes a warning from sparse.
Stephen Hemminger wrote:
> Looks like Mike created cpulistaffinty in sysfs but never completed
> the job.
This patch hooks things up correctly, taking care to remove the new file
when the bus is destroyed.
Signed-off-by: Mike Travis <travis@sgi.com>
PCI Express ASPM defines a protocol for PCI Express components in the D0
state to reduce Link power by placing their Links into a low power state
and instructing the other end of the Link to do likewise. This
capability allows hardware-autonomous, dynamic Link power reduction
beyond what is achievable by software-only controlled power management.
However, The device should be configured by software appropriately.
Enabling ASPM will save power, but will introduce device latency.
This patch adds ASPM support in Linux. It introduces a global policy for
ASPM, a sysfs file /sys/module/pcie_aspm/parameters/policy can control
it. The interface can be used as a boot option too. Currently we have
below setting:
-default, BIOS default setting
-powersave, highest power saving mode, enable all available ASPM
state and clock power management
-performance, highest performance, disable ASPM and clock power
management
By default, the 'default' policy is used currently.
In my test, power difference between powersave mode and performance mode
is about 1.3w in a system with 3 PCIE links.
Note: some devices might not work well with aspm, either because chipset
issue or device issue. The patch provide API (pci_disable_link_state),
driver can disable ASPM for specific device.
Signed-off-by: Shaohua Li <shaohua.li@intel.com>
This patch finally removes the global list of PCI devices. We are
relying entirely on the list held in the driver core now, and do not
need a separate "shadow" list as no one uses it.
This lets us check if the device is really added to the driver core or
not, which is what we need when walking some of the bus lists. The flag
is there in anticipation of getting rid of the other PCI device list,
which is what we used to check in this situation.
This reverts commit 6c723d5bd89f03fc3ef627d50f89ade054d2ee3b.
It caused build errors on non-x86 platforms, config file confusion, and
even some boot errors on some x86-64 boxes. All around, not quite ready
for prime-time :(
Cc: Shaohua Li <shaohua.li@intel.com>
This moves the pci_bus class device to be a real struct device and at
the same time, place it in the device tree in the correct location.
Note, the old "bridge" symlink is now gone, but this was a non-standard
link and no userspace program used it. If you need to determine the
device that the bus is on, follow the standard device symlink, or walk
up the device tree.
below setting:
state
management
This patch adds pci_stop_bus_device() which stops a PCI device (detach
the driver, remove from the global list and so on) and any children.
This is needed for ACPI based PCI-to-PCI bridge hot-remove, and it will
be also needed for ACPI based PCI root bridge hot-remove.
Signed-off-by: MUNEDA Takahiro <muneda.takahiro@jp.fujitsu.com>
Signed-off-by: Satoru Takeuchi <takeuchi_satoru@jp.fujitsu.com>
Signed-off-by: Kristen Carlson Accardi <kristen.c.accardi@intel.com>
pci_walk_bus has a race with pci_destroy_dev. When cb is called
in pci_walk_bus, pci_destroy_dev might unlink the dev pointed by next.
Later on in the next loop, pointer next becomes NULL and cause
kernel panic.
Below patch against 2.6.17-rc4 fixes it by changing pci_bus_lock (spin_lock)
to pci_bus_sem (rw_semaphore).
Signed-off-by: Zhang Yanmin <yanmin.zhang@intel.com>
