commit 917e3e65c35459d52f0d0b890aa5df0cad07a051 upstream.
With Xen changeset 23428 "libxl: Add 'e820_host' option to config file"
the E820 as seen from the host can now be passed into the guest.
This means that a PV guest can now:
- Use the correct PCI I/O gap. Before these patches, Linux guest would
boot up and would tell:
[ 0.000000] Allocating PCI resources starting at 40000000 (gap: 40000000:c0000000)
while in actuality the PCI I/O gap should have been:
[ 0.000000] Allocating PCI resources starting at b0000000 (gap: b0000000:4c000000)
- The PV domain with PCI devices was limited to 3GB. It now can be booted
with 4GB, 8GB, or whatever number you want. The PCI devices will now _not_ conflict
with System RAM. Meaning the drivers can load.
CC: Jesse Barnes <jbarnes@virtuousgeek.org>
CC: linux-pci@vger.kernel.org
[v2: Made the string less broken up. Suggested by Joe Perches]
Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
This allows us to move duplicated code in <asm/atomic.h>
(atomic_inc_not_zero() for now) to <linux/atomic.h>
Signed-off-by: Arun Sharma <asharma@fb.com>
Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com>
Cleanup code. Cosmetic change to make the code look easier
to read.
Reviewed-by: Ian Campbell <Ian.Campbell@citrix.com>
Check the returned vector values for any values that are
odd or plain incorrect (say vector value zero), and if so
print a warning. Also fixup the return values.
This patch was precipiated by the Xen PCIBack returning the
incorrect values due to how it was retrieving PIRQ values.
This has been fixed in the xen-pciback by
"xen/pciback: Utilize 'xen_pirq_from_irq' to get PIRQ value"
patch.
flush_scheduled_work() is scheduled for deprecation. Cancel ->op_work
directly instead.
Cc: Ryan Wilson <hap9@epoch.ncsc.mil>
Cc: Jan Beulich <JBeulich@novell.com>
Cc: Jesse Barnes <jbarnes@virtuousgeek.org>
Stanse found that when pdev is found and has no driver a reference is
leaked in pcifront_common_process. So add pci_dev_put there. For the
pdev == NULL case, pci_dev_put(NULL) is fine.
[v2: Updated to not dereference pcidev->dev per Milton's observation]
Cc: Milton Miller <miltonm@bga.com>
In drivers/pci/xen-pcifront.c the xen/xenbus.h header is included twice -
once is enough.
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
This is a port of the 2.6.18 Xen PCI front driver with fixes
to make it build under 2.6.34 and later (for the full list of
changes: git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen.git
historic/xen-pcifront-0.1). It also includes the fixes
to make it work properly.
[v2: Updated Kconfig, removed crud, added Reviewed-by]
[v3: Added 'static', fixed grant table leak, redid Kconfig]
[v4: Added one more 'static' and removed comments]
Reviewed-by: Stefano Stabellini <stefano.stabellini@eu.citrix.com>
Reviewed-by: Jan Beulich <JBeulich@novell.com>
