path: root/drivers/pci
2011-06-14Merge branch 'drm-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: drm: Compare only lower 32 bits of framebuffer map offsets drm/i915: Don't leak in i915_gem_shmem_pread_slow() drm/radeon/kms: do bounds checking for 3D_LOAD_VBPNTR and bump array limit drm/radeon/kms: fix mac g5 quirk x86/uv/x2apic: update for change in pci bridge handling. alpha, drm: Remove obsolete Alpha support in MGA DRM code alpha/drm: Cleanup Alpha support in DRM generic code savage: remove unnecessary if statement drm/radeon: fix GUI idle IH debug statements drm/radeon/kms: check modes against max pixel clock drm: fix fbs in DRM_IOCTL_MODE_GETRESOURCES ioctl
2011-06-14x86/uv/x2apic: update for change in pci bridge handling.Dave Airlie
When I added 3448a19da479b6bd1e28e2a2be9fa16c6a6feb39 I forgot about the special uv handling code for this, so this patch fixes it up. Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org> Acked-by: Ingo Molnar Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-06-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc-2.6: sparc32, leon: bugfix in LEON SMP interrupt init sparc32, sun4m: bugfix in SMP IPI traphandler sparc: Remove unnecessary semicolons Add support for allocating irqs for bootbus devices Do not skip interrupt sources in sun4d interrupt handler and acknowledge interrupts correctly Restructure sun4d_build_device_irq so that timer interrupts can be allocated sparc: PCIC_PCI needs SPARC32 dependency sparc: Do not select GENERIC_HARDIRQS_NO_DEPRECATED sparc32,leon: add GRPCI2 PCI Host driver sparc32,leon: added LEON-common low-level PCI routines sparc32: added CONFIG_PCIC_PCI Kconfig setting
2011-06-07PM / Intel IOMMU: Fix init_iommu_pm_ops() for CONFIG_PM unsetRafael J. Wysocki
If CONFIG_PM is not set, init_iommu_pm_ops() introduced by commit 134fac3f457f3dd753ecdb25e6da3e5f6629f696 (PCI / Intel IOMMU: Use syscore_ops instead of sysdev class and sysdev) is not defined appropriately. Fix this issue. Reported-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2011-06-02sparc32,leon: added LEON-common low-level PCI routinesDaniel Hellstrom
The LEON architecture does not have a BIOS or bootloader that initializes PCI for us, instead Linux generic PCI layer is used to set up resources and IRQ. Signed-off-by: Daniel Hellstrom <daniel@gaisler.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-02Merge git://git.infradead.org/iommu-2.6Linus Torvalds
* git://git.infradead.org/iommu-2.6: intel-iommu: Fix off-by-one in RMRR setup intel-iommu: Add domain check in domain_remove_one_dev_info intel-iommu: Remove Host Bridge devices from identity mapping intel-iommu: Use coherent DMA mask when requested intel-iommu: Dont cache iova above 32bit intel-iommu: Speed up processing of the identity_mapping function intel-iommu: Check for identity mapping candidate using system dma mask intel-iommu: Only unlink device domains from iommu intel-iommu: Enable super page (2MiB, 1GiB, etc.) support intel-iommu: Flush unmaps at domain_exit intel-iommu: Remove obsolete comment from detect_intel_iommu intel-iommu: fix VT-d PMR disable for TXT on S3 resume
2011-06-01intel-iommu: Fix off-by-one in RMRR setupDavid Woodhouse
We were mapping an extra byte (and hence usually an extra page): iommu_prepare_identity_map() expects to be given an 'end' argument which is the last byte to be mapped; not the first byte *not* to be mapped. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2011-06-01intel-iommu: Add domain check in domain_remove_one_dev_infoMike Habeck
The comment in domain_remove_one_dev_info() states "No need to compare PCI domain; it has to be the same". But for the si_domain that isn't going to be true, as it consists of all the PCI devices that are identity mapped thus multiple PCI domains can be in si_domain. The code needs to validate the PCI domain too. Signed-off-by: Mike Habeck <habeck@sgi.com> Signed-off-by: Mike Travis <travis@sgi.com> Cc: stable@kernel.org Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2011-06-01intel-iommu: Remove Host Bridge devices from identity mappingMike Travis
When using the 1:1 (identity) PCI DMA remapping, PCI Host Bridge devices that do not use the IOMMU causes a kernel panic. Fix that by not inserting those devices into the si_domain. Signed-off-by: Mike Travis <travis@sgi.com> Reviewed-by: Mike Habeck <habeck@sgi.com> Cc: stable@kernel.org Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2011-06-01intel-iommu: Use coherent DMA mask when requestedMike Travis
The __intel_map_single function is not honoring the passed in DMA mask. This results in not using the coherent DMA mask when called from intel_alloc_coherent(). Signed-off-by: Mike Travis <travis@sgi.com> Acked-by: Chris Wright <chrisw@sous-sol.org> Reviewed-by: Mike Habeck <habeck@sgi.com> Cc: stable@kernel.org Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2011-06-01intel-iommu: Dont cache iova above 32bitChris Wright
Mike Travis and Mike Habeck reported an issue where iova allocation would return a range that was larger than a device's dma mask. https://lkml.org/lkml/2011/3/29/423 The dmar initialization code will reserve all PCI MMIO regions and copy those reservations into a domain specific iova tree. It is possible for one of those regions to be above the dma mask of a device. It is typical to allocate iovas with a 32bit mask (despite device's dma mask possibly being larger) and cache the result until it exhausts the lower 32bit address space. Freeing the iova range that is >= the last iova in the lower 32bit range when there is still an iova above the 32bit range will corrupt the cached iova by pointing it to a region that is above 32bit. If that region is also larger than the device's dma mask, a subsequent allocation will return an unusable iova and cause dma failure. Simply don't cache an iova that is above the 32bit caching boundary. Reported-by: Mike Travis <travis@sgi.com> Reported-by: Mike Habeck <habeck@sgi.com> Cc: stable@kernel.org Acked-by: Mike Travis <travis@sgi.com> Tested-by: Mike Habeck <habeck@sgi.com> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2011-06-01intel-iommu: Speed up processing of the identity_mapping functionMike Travis
When there are a large count of PCI devices, and the pass through option for iommu is set, much time is spent in the identity_mapping function hunting though the iommu domains to check if a specific device is "identity mapped". Speed up the function by checking the cached info to see if it's mapped to the static identity domain. Signed-off-by: Mike Travis <travis@sgi.com> Reviewed-by: Mike Habeck <habeck@sgi.com> Cc: stable@kernel.org Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2011-06-01intel-iommu: Check for identity mapping candidate using system dma maskChris Wright
The identity mapping code appears to make the assumption that if the devices dma_mask is greater than 32bits the device can use identity mapping. But that is not true: take the case where we have a 40bit device in a 44bit architecture. The device can potentially receive a physical address that it will truncate and cause incorrect addresses to be used. Instead check to see if the device's dma_mask is large enough to address the system's dma_mask. Signed-off-by: Mike Travis <travis@sgi.com> Reviewed-by: Mike Habeck <habeck@sgi.com> Cc: stable@kernel.org Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2011-06-01intel-iommu: Only unlink device domains from iommuAlex Williamson
Commit a97590e5 added unlinking domains from iommus to reciprocate the iommu from domains unlinking that was already done. We actually want to only do this for device domains and never for the static identity map domain or VM domains. The SI domain is special and never freed, while VM domain->id lives in their own special address space, separate from iommu->domain_ids. In the current code, a VM can get domain->id zero, then mark that domain unused when unbound from pci-stub. This leads to DMAR write faults when the device is re-bound to the host driver. Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Cc: stable@kernel.org Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2011-06-01intel-iommu: Enable super page (2MiB, 1GiB, etc.) supportYouquan Song
There are no externally-visible changes with this. In the loop in the internal __domain_mapping() function, we simply detect if we are mapping: - size >= 2MiB, and - virtual address aligned to 2MiB, and - physical address aligned to 2MiB, and - on hardware that supports superpages. (and likewise for larger superpages). We automatically use a superpage for such mappings. We never have to worry about *breaking* superpages, since we trust that we will always *unmap* the same range that was mapped. So all we need to do is ensure that dma_pte_clear_range() will also cope with superpages. Adjust pfn_to_dma_pte() to take a superpage 'level' as an argument, so it can return a PTE at the appropriate level rather than always extending the page tables all the way down to level 1. Again, this is simplified by the fact that we should never encounter existing small pages when we're creating a mapping; any old mapping that used the same virtual range will have been entirely removed and its obsolete page tables freed. Provide an 'intel_iommu=sp_off' argument on the command line as a chicken bit. Not that it should ever be required. == The original commit seen in the iommu-2.6.git was Youquan's implementation (and completion) of my own half-baked code which I'd typed into an email. Followed by half a dozen subsequent 'fixes'. I've taken the unusual step of rewriting history and collapsing the original commits in order to keep the main history simpler, and make life easier for the people who are going to have to backport this to older kernels. And also so I can give it a more coherent commit comment which (hopefully) gives a better explanation of what's going on. The original sequence of commits leading to identical code was: Youquan Song (3): intel-iommu: super page support intel-iommu: Fix superpage alignment calculation error intel-iommu: Fix superpage level calculation error in dma_pfn_level_pte() David Woodhouse (4): intel-iommu: Precalculate superpage support for dmar_domain intel-iommu: Fix hardware_largepage_caps() intel-iommu: Fix inappropriate use of superpages in __domain_mapping() intel-iommu: Fix phys_pfn in __domain_mapping for sglist pages Signed-off-by: Youquan Song <youquan.song@intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2011-05-29Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: ACPI EC: remove redundant code ACPI: Add D3 cold state ACPI: processor: fix processor_physically_present in UP kernel ACPI: Split out custom_method functionality into an own driver ACPI: Cleanup custom_method debug stuff ACPI EC: enable MSI workaround for Quanta laptops ACPICA: Update to version 20110413 ACPICA: Execute an orphan _REG method under the EC device ACPICA: Move ACPI_NUM_PREDEFINED_REGIONS to a more appropriate place ACPICA: Update internal address SpaceID for DataTable regions ACPICA: Add more methods eligible for NULL package element removal ACPICA: Split all internal Global Lock functions to new file - evglock ACPI: EC: add another DMI check for ASUS hardware ACPI EC: remove dead code ACPICA: Fix code divergence of global lock handling ACPICA: Use acpi_os_create_lock interface ACPI: osl, add acpi_os_create_lock interface ACPI:Fix goto flows in thermal-sys
2011-05-29ACPI: Add D3 cold stateLin Ming
_SxW returns an Integer containing the lowest D-state supported in state Sx. If OSPM has not indicated that it supports _PR3, then the value “3” corresponds to D3. If it has indicated _PR3 support, the value “3” represents D3hot and the value “4” represents D3cold. Linux does set _OSC._PR3, so we should fix it to expect that _SxW can return 4. Signed-off-by: Lin Ming <ming.m.lin@intel.com> Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Len Brown <len.brown@intel.com>
2011-05-24Merge branch 'drm-core-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: (169 commits) drivers/gpu/drm/radeon/atom.c: fix warning drm/radeon/kms: bump kms version number drm/radeon/kms: properly set num banks for fusion asics drm/radeon/kms/atom: move dig phy init out of modesetting drm/radeon/kms/cayman: fix typo in register mask drm/radeon/kms: fix typo in spread spectrum code drm/radeon/kms: fix tile_config value reported to userspace on cayman. drm/radeon/kms: fix incorrect comparison in cayman setup code. drm/radeon/kms: add wait idle ioctl for eg->cayman drm/radeon/cayman: setup hdp to invalidate and flush when asked drm/radeon/evergreen/btc/fusion: setup hdp to invalidate and flush when asked agp/uninorth: Fix lockups with radeon KMS and >1x. drm/radeon/kms: the SS_Id field in the LCD table if for LVDS only drm/radeon/kms: properly set the CLK_REF bit for DCE3 devices drm/radeon/kms: fixup eDP connector handling drm/radeon/kms: bail early for eDP in hotplug callback drm/radeon/kms: simplify hotplug handler logic drm/radeon/kms: rewrite DP handling drm/radeon/kms/atom: add support for setting DP panel mode drm/radeon/kms: atombios.h updates for DP panel mode ...
2011-05-24intel-iommu: Flush unmaps at domain_exitAlex Williamson
We typically batch unmaps to be lazily flushed out at regular intervals. When we destroy a domain, we need to force a flush of these lazy unmaps to be sure none reference the domain we're about to free. Fixes: https://bugzilla.kernel.org/show_bug.cgi?id=35062 Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Cc: stable@kernel.org
2011-05-24intel-iommu: Remove obsolete comment from detect_intel_iommuJan Kiszka
Since cacd4213d8, this comment no longer applies. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2011-05-24intel-iommu: fix VT-d PMR disable for TXT on S3 resumeJoseph Cihula
This patch is a follow on to https://lkml.org/lkml/2011/3/21/239, which was merged as commit 51a63e67da6056c13b5b597dcc9e1b3bd7ceaa55. This patch adds support for S3, as pointed out by Chris Wright. Signed-off-by: Joseph Cihula <joseph.cihula@intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2011-05-23Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: (27 commits) PCI: Don't use dmi_name_in_vendors in quirk PCI: remove unused AER functions PCI/sysfs: move bus cpuaffinity to class dev_attrs PCI: add rescan to /sys/.../pci_bus/.../ PCI: update bridge resources to get more big ranges when allocating space (again) KVM: Use pci_store/load_saved_state() around VM device usage PCI: Add interfaces to store and load the device saved state PCI: Track the size of each saved capability data area PCI/e1000e: Add and use pci_disable_link_state_locked() x86/PCI: derive pcibios_last_bus from ACPI MCFG PCI: add latency tolerance reporting enable/disable support PCI: add OBFF enable/disable support PCI: add ID-based ordering enable/disable support PCI hotplug: acpiphp: assume device is in state D0 after powering on a slot. PCI: Set PCIE maxpayload for card during hotplug insertion PCI/ACPI: Report _OSC control mask returned on failure to get control x86/PCI: irq and pci_ids patch for Intel Panther Point DeviceIDs PCI: handle positive error codes PCI: check pci_vpd_pci22_wait() return PCI: Use ICH6_GPIO_EN in ich6_lpc_acpi_gpio ... Fix up trivial conflicts in include/linux/pci_ids.h: commit a6e5e2be4461 moved the intel SMBUS ID definitons to the i2c-i801.c driver.
2011-05-21PCI: Don't use dmi_name_in_vendors in quirkJean Delvare
Don't use the costly dmi_name_in_vendors() when we know the string we are looking for can only be in the DMI board name field. This is more robust and, more importantly, much faster. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-05-21PCI: remove unused AER functionsChen Gong
In the commit 28eb5f2, aer_osc_setup is removed but corresponding definiton information in the aerdrv.h is missed. Acked-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Chen Gong <gong.chen@linux.intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-05-21PCI/sysfs: move bus cpuaffinity to class dev_attrsYinghai Lu
Requested by Greg KH to fix a race condition in the creating of PCI bus cpuaffinity files. Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-05-21PCI: add rescan to /sys/.../pci_bus/.../Yinghai Lu
After remove the device from /sys, we have to rescan all or find out the bridge and access /sys../device/rescan there. this patch add /sys/.../pci_bus/.../rescan. So user can rescan more easy. that is more clean and easy to understand. like after remove 0000:c4:00.0, you can rescan 0000:c4 directly. -v2: According to Jesse, use function instead of exposing attr, so could hide #ifdef in header file. also add code to remove rescan file in remove path. -v3: GregKH pointed out that we should use dev_attrs to avoid racing. So add pcibus_attrs and make it to be member of pcibus_attrs. -v4: Change name to pcibus_dev_attrs according to GregKH Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-05-21PCI: update bridge resources to get more big ranges when allocating space ↵Yinghai Lu
(again) With Ram's fixes, this should be safe to do again. So let's give it another try. BIOS separates IO ranges between several IOHs, and on some slots, BIOS assigns resources to a bridge, but stops assigning resources to the device under that bridge, because the device needs a big resource. So: 1. allocate resources and record the failed device resources 2. clear the BIOS assigned resources of the parent bridge of failing device 3. go back and call pci assign unassigned 4. if it still fails, go up the tree, clear more bridges. and try again Now Ram's allocate requested resource already got into mainline. could put this one again. Reviewed-by: Ram Pai <linuxram@us.ibm.com> Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-05-21PCI: Add interfaces to store and load the device saved stateAlex Williamson
For KVM device assignment, we'd like to save off the state of a device prior to passing it to the guest and restore it later. We also want to allow pci_reset_funciton() to be called while the device is owned by the guest. This however overwrites and invalidates the struct pci_dev buffers, so we can't just manually call save and restore. Add generic interfaces for the saved state to be stored and reloaded back into struct pci_dev at a later time. Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-05-21PCI: Track the size of each saved capability data areaAlex Williamson
This will allow us to store and load it later. Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-05-21PCI/e1000e: Add and use pci_disable_link_state_locked()Yinghai Lu
Need to use it in _e1000e_disable_aspm. This routine is used for error recovery, where the pci_bus_sem is already held, and we don't want pci_disable_link_state to try to take it again. So add a locked variant for use in cases like this. Found lock up: [ 2374.654557] kworker/32:1 D ffff881027f6b0f0 0 6075 2 0x00000000 [ 2374.654816] ffff88503f099a68 0000000000000046 ffff88503f098000 0000000000004000 [ 2374.654837] 00000000001d1ec0 ffff88503f099fd8 00000000001d1ec0 ffff88503f099fd8 [ 2374.654860] 0000000000004000 00000000001d1ec0 ffff88503dcc8000 ffff88503f090000 [ 2374.654880] Call Trace: [ 2374.654898] [<ffffffff810b1302>] ? __lock_acquired+0x3a/0x224 [ 2374.654914] [<ffffffff81c2b59c>] ? _raw_spin_unlock_irq+0x30/0x36 [ 2374.654925] [<ffffffff810b069d>] ? trace_hardirqs_on_caller+0x1f/0x178 [ 2374.654936] [<ffffffff81c2ab24>] rwsem_down_failed_common+0xd3/0x103 [ 2374.654945] [<ffffffff810b158f>] ? __lock_contended+0x3a/0x2a2 [ 2374.654955] [<ffffffff81c2ab7b>] rwsem_down_read_failed+0x12/0x14 [ 2374.654967] [<ffffffff813371e4>] call_rwsem_down_read_failed+0x14/0x30 [ 2374.654981] [<ffffffff8135df20>] ? pci_disable_link_state+0x5f/0xf5 [ 2374.654990] [<ffffffff81c2a0e6>] ? down_read+0x7e/0x91 [ 2374.654999] [<ffffffff8135df20>] ? pci_disable_link_state+0x5f/0xf5 [ 2374.655008] [<ffffffff8135df20>] pci_disable_link_state+0x5f/0xf5 [ 2374.655024] [<ffffffff81661796>] e1000e_disable_aspm+0x55/0x5a [ 2374.655037] [<ffffffff816677eb>] e1000_io_slot_reset+0x59/0xea [ 2374.655048] [<ffffffff8135fe0d>] ? report_mmio_enabled+0x5d/0x5d [ 2374.655057] [<ffffffff8135fe3b>] report_slot_reset+0x2e/0x5d [ 2374.655072] [<ffffffff8135369e>] pci_walk_bus+0x8a/0xb7 [ 2374.655081] [<ffffffff8135fe0d>] ? report_mmio_enabled+0x5d/0x5d [ 2374.655091] [<ffffffff813603be>] broadcast_error_message+0xa4/0xb2 [ 2374.655101] [<ffffffff81352c71>] ? pci_bus_read_config_dword+0x72/0x80 [ 2374.655110] [<ffffffff813606df>] do_recovery+0x9e/0xf9 [ 2374.655120] [<ffffffff81360786>] handle_error_source+0x4c/0x51 [ 2374.655129] [<ffffffff81360974>] aer_isr_one_error+0x1e9/0x21a [ 2374.655138] [<ffffffff81360a6c>] aer_isr+0xc7/0xcc [ 2374.655147] [<ffffffff813609a5>] ? aer_isr_one_error+0x21a/0x21a [ 2374.655159] [<ffffffff81096d9f>] process_one_work+0x237/0x3ec [ 2374.655168] [<ffffffff81096d10>] ? process_one_work+0x1a8/0x3ec [ 2374.655178] [<ffffffff8109728d>] worker_thread+0x17c/0x240 [ 2374.655186] [<ffffffff810b0803>] ? trace_hardirqs_on+0xd/0xf [ 2374.655196] [<ffffffff81097111>] ? manage_workers+0xab/0xab [ 2374.655209] [<ffffffff8109c8ed>] kthread+0xa0/0xa8 [ 2374.655223] [<ffffffff81c332d4>] kernel_thread_helper+0x4/0x10 [ 2374.655232] [<ffffffff81c2b880>] ? retint_restore_args+0xe/0xe [ 2374.655243] [<ffffffff8109c84d>] ? __init_kthread_worker+0x5b/0x5b [ 2374.655252] [<ffffffff81c332d0>] ? gs_change+0xb/0xb when aer happens, pci_walk_bus already have down_read(&pci_bus_sem)... then report_slot_reset ==> e1000_io_slot_reset ==> e1000e_disable_aspm ==> pci_disable_link_state... We can not use pci_disable_link_state, and it will try to hold pci_bus_sem again. Try to have __pci_disable_link_state that will not need to hold pci_bus_sem. -v2: change name to pci_disable_link_state_locked() according to Jesse. [jbarnes: make sure new function is exported for modules] Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-05-19Merge branch 'core-iommu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-iommu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, gart: Rename pci-gart_64.c to amd_gart_64.c x86/amd-iommu: Use threaded interupt handler arch/x86/kernel/pci-iommu_table.c: Convert sprintf_symbol to %pS x86/amd-iommu: Add support for invalidate_all command x86/amd-iommu: Add extended feature detection x86/amd-iommu: Add ATS enable/disable code x86/amd-iommu: Add flag to indicate IOTLB support x86/amd-iommu: Flush device IOTLB if ATS is enabled x86/amd-iommu: Select PCI_IOV with AMD IOMMU driver PCI: Move ATS declarations in seperate header file dma-debug: print information about leaked entry x86/amd-iommu: Flush all internal TLBs when IOMMUs are enabled x86/amd-iommu: Rename iommu_flush_device x86/amd-iommu: Improve handling of full command buffer x86/amd-iommu: Rename iommu_flush* to domain_flush* x86/amd-iommu: Remove command buffer resetting logic x86/amd-iommu: Cleanup completion-wait handling x86/amd-iommu: Cleanup inv_pages command handling x86/amd-iommu: Move inv-dte command building to own function x86/amd-iommu: Move compl-wait command building to own function
2011-05-16PCI: Clear bridge resource flags if requested size is 0Yinghai Lu
During pci remove/rescan testing found: pci 0000:c0:03.0: PCI bridge to [bus c4-c9] pci 0000:c0:03.0: bridge window [io 0x1000-0x0fff] pci 0000:c0:03.0: bridge window [mem 0xf0000000-0xf00fffff] pci 0000:c0:03.0: bridge window [mem 0xfc180000000-0xfc197ffffff 64bit pref] pci 0000:c0:03.0: device not available (can't reserve [io 0x1000-0x0fff]) pci 0000:c0:03.0: Error enabling bridge (-22), continuing pci 0000:c0:03.0: enabling bus mastering pci 0000:c0:03.0: setting latency timer to 64 pcieport 0000:c0:03.0: device not available (can't reserve [io 0x1000-0x0fff]) pcieport: probe of 0000:c0:03.0 failed with error -22 This bug was caused by commit c8adf9a3e873 ("PCI: pre-allocate additional resources to devices only after successful allocation of essential resources.") After that commit, pci_hotplug_io_size is changed to additional_io_size from minium size. So it will not go through resource_size(res) != 0 path, and will not be reset. The root cause is: pci_bridge_check_ranges will set RESOURCE_IO flag for pci bridge, and later if children do not need IO resource. those bridge resources will not need to be allocated. but flags is still there. that will confuse the the pci_enable_bridges later. related code: static void assign_requested_resources_sorted(struct resource_list *head, struct resource_list_x *fail_head) { struct resource *res; struct resource_list *list; int idx; for (list = head->next; list; list = list->next) { res = list->res; idx = res - &list->dev->resource[0]; if (resource_size(res) && pci_assign_resource(list->dev, idx)) { ... reset_resource(res); } } } At last, We have to clear the flags in pbus_size_mem/io when requested size == 0 and !add_head. becasue this case it will not go through adjust_resources_sorted(). Just make size1 = size0 when !add_head. it will make flags get cleared. At the same time when requested size == 0, add_size != 0, will still have in head and add_list. because we do not clear the flags for it. After this, we will get right result: pci 0000:c0:03.0: PCI bridge to [bus c4-c9] pci 0000:c0:03.0: bridge window [io disabled] pci 0000:c0:03.0: bridge window [mem 0xf0000000-0xf00fffff] pci 0000:c0:03.0: bridge window [mem 0xfc180000000-0xfc197ffffff 64bit pref] pci 0000:c0:03.0: enabling bus mastering pci 0000:c0:03.0: setting latency timer to 64 pcieport 0000:c0:03.0: setting latency timer to 64 pcieport 0000:c0:03.0: irq 160 for MSI/MSI-X pcieport 0000:c0:03.0: Signaling PME through PCIe PME interrupt pci 0000:c4:00.0: Signaling PME through PCIe PME interrupt pcie_pme 0000:c0:03.0:pcie01: service driver pcie_pme loaded aer 0000:c0:03.0:pcie02: service driver aer loaded pciehp 0000:c0:03.0:pcie04: Hotplug Controller: v3: more simple fix. also fix one typo in pbus_size_mem Signed-off-by: Yinghai Lu <yinghai@kernel.org> Reviewed-by: Ram Pai <linuxram@us.ibm.com> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: Bjorn Helgaas <bhelgaas@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-05-11PCI: add latency tolerance reporting enable/disable supportJesse Barnes
Latency tolerance reporting allows devices to send messages to the root complex indicating their latency tolerance for snooped & unsnooped memory transactions. Add support for enabling & disabling this feature, along with a routine to set the max latencies a device should send upstream. Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-05-11PCI: add OBFF enable/disable supportJesse Barnes
OBFF (optimized buffer flush/fill), where supported, can help improve energy efficiency by giving devices information about when interrupts and other activity will have a reduced power impact. It requires support from both the device and system (i.e. not only does the device need to respond to OBFF messages, but the platform must be capable of generating and routing them to the end point). Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-05-11PCI: add ID-based ordering enable/disable supportJesse Barnes
Add support to allow drivers to enable/disable ID-based ordering. Where supported, ID-based ordering can significantly improve the latency of individual requests by preventing them from queueing up behind unrelated traffic. Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-05-11PCI hotplug: acpiphp: assume device is in state D0 after powering on a slot.Ian Campbell
Devices which do not support PCI configuration space based power management may not otherwise be enabled. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-05-10PCI: Set PCIE maxpayload for card during hotplug insertionJordan_Hargrave@Dell.com
The following patch sets the MaxPayload setting to match the parent reading when inserting a PCIE card into a hotplug slot. On our system, the upstream bridge is set to 256, but when inserting a card, the card setting defaults to 128. As soon as I/O is performed to the card it starts receiving errors since the payload size is too small. Reviewed-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Jordan Hargrave <jordan_hargrave@dell.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-05-10PCI: handle positive error codesGreg Thelen
Callers expect pci_user_{read,write}_config_*() to indicate errors by returning negative values. Prior to this change, the indicated routines could return positive error codes (e.g. PCIBIOS_BAD_REGISTER_NUMBER) which callers would mistakenly interpret as success. This change converts any non-zero return from the mentioned routines into unambiguous negative value return codes. Signed-off-by: Greg Thelen <gthelen@google.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-05-10PCI: check pci_vpd_pci22_wait() returnGreg Thelen
pci_vpd_pci22_write() calls pci_vpd_pci22_wait() after writing PCI_VPD_DATA and PCI_VPD_ADDR to wait for the VPD operation to complete. The result pci_vpd_pci22_wait() was not checked for error. This change checks for error. Signed-off-by: Greg Thelen <gthelen@google.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-05-10PCI: Use ICH6_GPIO_EN in ich6_lpc_acpi_gpioJean Delvare
We were just lucky that ICH4_GPIO_EN and ICH6_GPIO_EN happen to have the same value. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-05-10PCI: Fix typo in ich7 quirk commentJean Delvare
2011-05-10PCI: Add quirk for setting valid class for TI816X EndpointHemant Pedanekar
TI816X (common name for DM816x/C6A816x/AM389x family) devices configured to boot as PCIe Endpoint have class code = 0. This makes kernel PCI bus code to skip allocating BARs to these devices resulting into following type of error when trying to enable them: "Device 0000:01:00.0 not available because of resource collisions" The device cannot be operated because of the above issue. This patch adds a ID specific (TI VENDOR ID and 816X DEVICE ID based) 'early' fixup quirk to replace class code with PCI_CLASS_MULTIMEDIA_VIDEO as class. Signed-off-by: Hemant Pedanekar <hemantp@ti.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-05-10PCI: Fix uninitialized variable bug in AER injection codeWanlong Gao
If it was preempted, and the variable aer_mask_override is changed after the spin_unlock_irqrestore it will write an uninitialized variable by the pci_write_config_dword() function. Signed-off-by: Wanlong Gao <wanlong.gao@gmail.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-05-10PCI/PM: Add kerneldoc description of pci_pm_reset()Rafael J. Wysocki
The pci_pm_reset() function is not a very nice interface due to its limitations and conditional behavior (e.g. it doesn't affect devices in low-power states), but it cannot be simply dropped, because existing device drivers may depend on it. However, its behavior and limitations should be well documented, so add an appropriate kerneldoc comment to it. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-05-10PCI: Enable ASPM state clearing regardless of policyAlex Williamson
Commit 2f671e2d allowed us to clear ASPM state when the FADT tells us it isn't supported, but we don't put this into effect if the aspm_policy is set to POLICY_POWERSAVE. Enable the state to be cleared regardless of policy. Signed-off-by: Alex Williamson <alex.williamson@redhat.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-05-10Merge branches 'dma-debug/next', 'amd-iommu/command-cleanups', ↵Joerg Roedel
'amd-iommu/ats' and 'amd-iommu/extended-features' into iommu/2.6.40 Conflicts: arch/x86/include/asm/amd_iommu_types.h arch/x86/kernel/amd_iommu.c arch/x86/kernel/amd_iommu_init.c
2011-05-04vgaarb: use bridges to control VGA routing where possible.Dave Airlie
So in a lot of modern systems, a GPU will always be below a parent bridge that won't share with any other GPUs. This means VGA arbitration on those GPUs can be controlled by using the bridge routing instead of io/mem decodes. The problem is locating which GPUs share which upstream bridges. This patch attempts to identify all the GPUs which can be controlled via bridges, and ones that can't. This patch endeavours to work out the bridge sharing semantics. When disabling GPUs via a bridge, it doesn't do irq callbacks or touch the io/mem decodes for the gpu. Signed-off-by: Dave Airlie <airlied@redhat.com>
2011-04-21Merge git://git.infradead.org/iommu-2.6Linus Torvalds
* git://git.infradead.org/iommu-2.6: intel_iommu: disable all VT-d PMRs when TXT launched intel-iommu: Fix get_domain_for_dev() error path intel-iommu: Unlink domain from iommu intel-iommu: Fix use after release during device attach
2011-04-21intel_iommu: disable all VT-d PMRs when TXT launchedJoseph Cihula
Intel VT-d Protected Memory Regions (PMRs) are supposed to be disabled, on each VT-d engine, after DMA remapping is enabled on the engines. This is because the behavior of having both enabled is not deterministic and because, if TXT has been used to launch the kernel, the PMRs may be programmed to cover memory regions that will be used for DMA. Under some circumstances (certain quirks detected, lack of multiple devices, etc.), the current code does not set up DMA remapping on some VT-d engines. In such cases it also skips disabling the PMRs. This causes failures when the kernel is launched with TXT (most often this occurs on the graphics engine and results in colored vertical bars on the display). This patch detects when the kernel has been launched with TXT and then disables the PMRs on all VT-d engines. In some cases where the reason that remapping is not being enabled is due to possible ACPI DMAR table errors, the VT-d engine addresses may not be correct and thus not able to be safely programmed even to disable PMRs. Because part of the TXT launch process is the verification of these addresses, it will always be safe to disable PMRs if the TXT launch has succeeded and hence only doing this in such cases. Signed-off-by: Joseph Cihula <joseph.cihula@intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2011-04-19Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: PCI: pci-label: Fix build failure when CONFIG_NLS is set to 'm' by allmodconfig
