path: root/drivers/pci
2009-03-12PCIe: portdrv: call pci_disable_device during removeAlex Chiang
The PCIe port driver calls pci_enable_device() during probe but never calls pci_disable_device() during remove. Cc: stable@kernel.org Signed-off-by: Alex Chiang <achiang@hp.com> Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2009-03-12pci: Fix typo in message while disabling HT MSI mappingPrakash Punnoor
"Enabling" should read "Disabling" Signed-off-by: Prakash Punnoor <prakash@punnoor.de> Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2009-03-12pci: don't disable too many HT MSI mappingPrakash Punnoor
Prakash's system needs MSI disabled on some bridges, but not all. This seems to be the minimal fix for 2.6.29, but should be replaced during 2.6.30. Signed-off-by: Prakash Punnoor <prakash@punnoor.de> Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2009-03-12powerpc/pseries: The RPA PCI hotplug driver depends on EEHMichael Ellerman
The RPA PCI hotplug driver calls EEH routines, so should depend on EEH. Also PPC_PSERIES implies PPC64, so remove that. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2009-03-12PCIe: AER: during disable, check subordinate before walkingAlex Chiang
Commit 47a8b0cc (Enable PCIe AER only after checking firmware support) wants to walk the PCI bus in the remove path to disable AER, and calls pci_walk_bus for downstream bridges. Unfortunately, in the remove path, we remove devices and bridges in a depth-first manner, starting with the furthest downstream bridge and working our way backwards. The furthest downstream bridges will not have a dev->subordinate, and we hit a NULL deref in pci_walk_bus. Check for dev->subordinate first before attempting to walk the PCI hierarchy below us. Acked-by: Andrew Patterson <andrew.patterson@hp.com> Signed-off-by: Alex Chiang <achiang@hp.com> Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2009-03-12PCI: Add PCI quirk to disable L0s ASPM state for 82575 and 82598Alexander Duyck
This patch is intended to disable L0s ASPM link state for 82598 (ixgbe) parts due to the fact that it is possible to corrupt TX data when coming back out of L0s on some systems. The workaround had been added for 82575 (igb) previously, but did not use the ASPM api. This quirk uses the ASPM api to prevent the ASPM subsystem from re-enabling the L0s state. Instead of adding the fix in igb to the ixgbe driver as well it was decided to move it into a pci quirk. It is necessary to move the fix out of the driver and into a pci quirk in order to prevent the issue from occuring prior to driver load to handle the possibility of the device being passed to a VM via direct assignment. Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> CC: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2009-02-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: PCI: AMD 813x B2 devices do not need boot interrupt quirk PCI: Enable PCIe AER only after checking firmware support PCI: pciehp: Handle interrupts that happen during initialization. PCI: don't enable too many HT MSI mappings PCI: add some sysfs ABI docs PCI quirk: enable MSI on 8132
2009-02-26PCI: AMD 813x B2 devices do not need boot interrupt quirkStefan Assmann
Turns out that the new AMD 813x devices do not need the quirk_disable_amd_813x_boot_interrupt quirk to be run on them. If it is, no interrupts are seen on the PCI-X adapter. From: Stefan Assmann <sassmann@novell.com> Reported-by: Jamie Wellnitz <Jamie.Wellnitz@emulex.com> Tested-by: Jamie Wellnitz <Jamie.Wellnitz@emulex.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Jesse Barnes <jbarnes@hobbes.lan>
2009-02-25Merge git://git.infradead.org/iommu-2.6Linus Torvalds
* git://git.infradead.org/iommu-2.6: intel-iommu: fix endless "Unknown DMAR structure type" loop VT-d: handle Invalidation Queue Error to avoid system hang intel-iommu: fix build error with INTR_REMAP=y and DMAR=n
2009-02-24PCI: Enable PCIe AER only after checking firmware supportAndrew Patterson
The PCIe port driver currently sets the PCIe AER error reporting bits for any root or switch port without first checking to see if firmware will grant control. This patch moves setting these bits to the AER service driver aer_enable_port routine. The bits are then set for the root port and any downstream switch ports after the check for firmware support (aer_osc_setup) is made. The patch also unsets the bits in a similar fashion when the AER service driver is unloaded. Reviewed-by: Alex Chiang <achiang@hp.com> Signed-off-by: Andrew Patterson <andrew.patterson@hp.com> Signed-off-by: Jesse Barnes <jbarnes@hobbes.lan>
2009-02-24PCI: pciehp: Handle interrupts that happen during initialization.Eric W. Biederman
Move the enabling of interrupts after all of the data structures are setup so that we can safely run the interrupt handler as soon as it is registered. Reviewed-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Tested-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Signed-off-by: Jesse Barnes <jbarnes@hobbes.lan>
2009-02-24PCI: don't enable too many HT MSI mappingsYinghai Lu
Prakash reported that his c51-mcp51 ondie sound card doesn't work with MSI. But if he hacks out the HT-MSI quirk, MSI works fine. So this patch reworks the nv_msi_ht_cap_quirk(). It will now only enable ht_msi on own its root device, avoiding enabling it on devices following that root dev. Reported-by: Prakash Punnoor <prakash@punnoor.de> Tested-by: Prakash Punnoor <prakash@punnoor.de> Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Jesse Barnes <jbarnes@hobbes.lan>
2009-02-18PCI quirk: enable MSI on 8132Yinghai Lu
David reported that LSI SAS doesn't work with MSI. It turns out that his BIOS doesn't enable it, but the HT MSI 8132 does support HT MSI. Add quirk to enable it Cc: stable@kernel.org Reported-by: David Lang <david@lang.hm> Signed-off-by: Yinghai Lu <yinghai@kernel.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-02-17Merge branch 'core-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: iommu: fix Intel IOMMU write-buffer flushing futex: fix reference leak Trivial conflicts fixed manually in drivers/pci/intel-iommu.c
2009-02-17Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: PCI: Documentation: fix minor PCIe HOWTO thinko PCI: fix missing kernel-doc and typos PCI: fix struct pci_platform_pm_ops kernel-doc PCI: fix rom.c kernel-doc warning PCI/MSI: fix msi_mask() shift fix
2009-02-17Fix Intel IOMMU write-buffer flushingDavid Woodhouse
This is the cause of the DMA faults and disk corruption that people have been seeing. Some chipsets neglect to report the RWBF "capability" -- the flag which says that we need to flush the chipset write-buffer when changing the DMA page tables, to ensure that the change is visible to the IOMMU. Override that bit on the affected chipsets, and everything is happy again. Thanks to Chris and Bhavesh and others for helping to debug. Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Tested-by: Chris Wright <chrisw@sous-sol.org> Reviewed-by: Bhavesh Davda <bhavesh@vmware.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-14iommu: fix Intel IOMMU write-buffer flushingDavid Woodhouse
This is the cause of the DMA faults and disk corruption that people have been seeing. Some chipsets neglect to report the RWBF "capability" -- the flag which says that we need to flush the chipset write-buffer when changing the DMA page tables, to ensure that the change is visible to the IOMMU. Override that bit on the affected chipsets, and everything is happy again. Thanks to Chris and Bhavesh and others for helping to debug. Should resolve: https://bugzilla.redhat.com/show_bug.cgi?id=479996 http://bugzilla.kernel.org/show_bug.cgi?id=12578 Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Tested-and-acked-by: Chris Wright <chrisw@sous-sol.org> Reviewed-by: Bhavesh Davda <bhavesh@vmware.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-14intel-iommu: fix endless "Unknown DMAR structure type" loopTony Battersby
I have a SuperMicro C2SBX motherboard with BIOS revision 1.0b. With vt-d enabled in the BIOS, Linux gets into an endless loop printing "DMAR:Unknown DMAR structure type" when booting. Here is the DMAR ACPI table: DMAR @ 0x7fe86dec 0000: 44 4d 41 52 98 00 00 00 01 6f 49 6e 74 65 6c 20 DMAR.....oIntel 0010: 4f 45 4d 44 4d 41 52 20 00 00 04 06 4c 4f 48 52 OEMDMAR ....LOHR 0020: 01 00 00 00 23 00 00 00 00 00 00 00 00 00 00 00 ....#........... 0030: 01 00 58 00 00 00 00 00 00 a0 e8 7f 00 00 00 00 ..X............. 0040: ff ff ef 7f 00 00 00 00 01 08 00 00 00 00 1d 00 ................ 0050: 01 08 00 00 00 00 1d 01 01 08 00 00 00 00 1d 02 ................ 0060: 01 08 00 00 00 00 1d 07 01 08 00 00 00 00 1a 00 ................ 0070: 01 08 00 00 00 00 1a 01 01 08 00 00 00 00 1a 02 ................ 0080: 01 08 00 00 00 00 1a 07 01 08 00 00 00 00 1a 07 ................ 0090: c0 00 68 00 04 10 66 60 ..h...f` Here are the messages printed by the kernel: DMAR:Host address width 36 DMAR:RMRR base: 0x000000007fe8a000 end: 0x000000007fefffff DMAR:Unknown DMAR structure type DMAR:Unknown DMAR structure type DMAR:Unknown DMAR structure type ... Although I not very familiar with ACPI, to me it looks like struct acpi_dmar_header::length == 0x0058 is incorrect, causing parse_dmar_table() to look at an invalid offset on the next loop. This offset happens to have struct acpi_dmar_header::length == 0x0000, which prevents the loop from ever terminating. This patch checks for this condition and bails out instead of looping forever. Signed-off-by: Tony Battersby <tonyb@cybernetics.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-02-13PCI: fix missing kernel-doc and typosRandy Dunlap
Fix pci kernel-doc parameter missing notation, correct function name, and fix typo: Warning(linux-2.6.28-git10//drivers/pci/pci.c:1511): No description found for parameter 'exclusive' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-02-13PCI: fix struct pci_platform_pm_ops kernel-docRandy Dunlap
Fix struct pci_platform_pm_ops kernel-doc notation. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-02-13PCI: fix rom.c kernel-doc warningRandy Dunlap
Fix PCI kernel-doc warning: Warning(linux-2.6.29-rc4-git1/drivers/pci/rom.c:67): No description found for parameter 'pdev' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> cc: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-02-13PCI/MSI: fix msi_mask() shift fixMatthew Wilcox
Hidetoshi Seto points out that commit bffac3c593eba1f9da3efd0199e49ea6558a40ce has wrong values in the array. Rather than correct the array, we can just use a bounds check and perform the calculation specified in the comment. As a bonus, this will not run off the end of the array if the device specifies an illegal value in the MSI capability. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-02-11Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: ptrace, x86: fix the usage of ptrace_fork() i8327: fix outb() parameter order x86: fix math_emu register frame access x86: math_emu info cleanup x86: include correct %gs in a.out core dump x86, vmi: put a missing paravirt_release_pmd in pgd_dtor x86: find nr_irqs_gsi with mp_ioapic_routing x86: add clflush before monitor for Intel 7400 series x86: disable intel_iommu support by default x86: don't apply __supported_pte_mask to non-present ptes x86: fix grammar in user-visible BIOS warning x86/Kconfig.cpu: make Kconfig help readable in the console x86, 64-bit: print DMI info in the oops trace
2009-02-09VT-d: handle Invalidation Queue Error to avoid system hangYu Zhao
When hardware detects any error with a descriptor from the invalidation queue, it stops fetching new descriptors from the queue until software clears the Invalidation Queue Error bit in the Fault Status register. Following fix handles the IQE so the kernel won't be trapped in an infinite loop. Signed-off-by: Yu Zhao <yu.zhao@intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-02-09intel-iommu: fix build error with INTR_REMAP=y and DMAR=nJoerg Roedel
This fix should be safe since iommu->agaw is only used in intel-iommu.c. And this file is only compiled with DMAR=y. Signed-off-by: Joerg Roedel <joerg.roedel@amd.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-02-05x86: disable intel_iommu support by defaultKyle McMartin
Due to recurring issues with DMAR support on certain platforms. There's a number of filesystem corruption incidents reported: https://bugzilla.redhat.com/show_bug.cgi?id=479996 http://bugzilla.kernel.org/show_bug.cgi?id=12578 Provide a Kconfig option to change whether it is enabled by default. If disabled, it can still be reenabled by passing intel_iommu=on to the kernel. Keep the .config option off by default. Signed-off-by: Kyle McMartin <kyle@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Acked-By: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-02-04PCI PM: make the PM core more careful with drivers using the new PM frameworkRafael J. Wysocki
Currently, the PM core always attempts to manage devices with drivers that use the new PM framework. In particular, it attempts to disable the devices (which is unnecessary), to save their state (which may be undesirable if the driver has done that already) and to put them into low power states (again, this may be undesirable if the driver has already put the device into a low power state). That need not be the right thing to do, so make the core be more careful in this respect. Generally, there are the following categories of devices to consider: * bridge devices without drivers * non-bridge devices without drivers * bridge devices with drivers * non-bridge devices with drivers and each of them should be handled differently. For bridge devices without drivers the PCI PM core will save their state on suspend and restore it (early) during resume, after putting them into D0 if necessary. It will not attempt to do anything else to these devices. For non-bridge devices without drivers the PCI PM core will disable them and save their state on suspend. During resume, it will put them into D0, if necessary, restore their state (early) and reenable them. For bridge devices with drivers the PCI PM core will only save their state on suspend if the driver hasn't done that already. Still, the core will restore their state (early) during resume, after putting them into D0, if necessary. For non-bridge devices with drivers the PCI PM core will only save their state on suspend if the driver hasn't done that already. Also, if the state of the device hasn't been saved by the driver, the core will attempt to put the device into a low power state. During resume the core will restore the state of the device (early), after putting it into D0, if necessary. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-02-04PCI PM: Read power state from device after trying to change it on resumeRafael J. Wysocki
pci_restore_standard_config() unconditionally changes current_state to PCI_D0 after attempting to change the device's power state, but it should rather read the actual current power state from the device. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-02-04PCI PM: Do not disable and enable bridges during suspend-resumeRafael J. Wysocki
It is a mistake to disable and enable PCI bridges and PCI Express ports during suspend-resume, at least at the time when it is currently done. Disabling them may lead to problems with accessing devices behind them and they should be automatically enabled when their standard config spaces are restored. Fix this by not attempting to disable bridges during suspend and enable them during resume. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-02-04PCI: PCIe portdrv: Simplify suspend and resumeRafael J. Wysocki
Simplify suspend and resume of the PCI Express port driver. It no longer needs to save and restore the standard configuration space of the device; this is now done by the PCI PM core layer. This patch is reported to fix the regression tracked as http://bugzilla.kernel.org/show_bug.cgi?id=12598 Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Reported-and-tested-by: Parag Warudkar <parag.lkml@gmail.com> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-02-04PCI PM: Fix saving of device state in pci_legacy_suspendRafael J. Wysocki
Make pci_legacy_suspend() save the state of the device if it is in PCI_UNKNOWN after its suspend callback has run and warn only if the power state of the device has been changed by its suspend callback. Also, use WARN_ONCE(), which is more useful, in pci_legacy_suspend(), so that the name of the offending function is printed. Additionally, remove the unnecessary line of code setting pci_dev->state_saved. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Reported-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-02-04PCI PM: Check if the state has been saved before trying to restore itRafael J. Wysocki
Check if the standard configuration registers of a PCI device have been saved during suspend before trying to restore them during resume. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Reported-By: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-02-04PCI PM: Fix handling of devices without driversRafael J. Wysocki
Suspend to RAM is reported to break on some machines as a result of attempting to put one of driverless PCI devices into a low power state. Avoid that by not attepmting to power manage driverless devices during suspend. Fix up pci_pm_poweroff() after a previous incomplete fix for the same thing during hibernation. This patch is reported to fix the regression from 2.6.28 tracked as http://bugzilla.kernel.org/show_bug.cgi?id=12605 Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Reported-and-tested-by: Eric Sesterhenn <snakebyte@gmx.de> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-02-04PCI: return error on failure to read PCI ROMsTimothy S. Nelson
This patch makes the ROM reading code return an error to user space if the size of the ROM read is equal to 0. The patch also emits a warnings if the contents of the ROM are invalid, and documents the effects of the "enable" file on ROM reading. Signed-off-by: Timothy S. Nelson <wayland@wayland.id.au> Acked-by: Alex Villacis-Lasso <a_villacis@palosanto.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-02-04PCI: properly clean up ASPM link state on device removeAlex Chiang
We only want to disable ASPM when the last function is removed from the parent's device list. We determine this by checking to see if the parent's device list is completely empty. Unfortunately, we never hit that code because the parent is considered an upstream port, and never had an ASPM link_state associated with it. The early check for !link_state causes us to return early, we never discover that our device list is empty, and thus we never remove the downstream ports' link_state nodes. Instead of checking to see if the parent's device list is empty, we can check to see if we are the last device on the list, and if so, then we know that we can clean up properly. Cc: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Alex Chiang <achiang@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-27PCI hotplug: Change link order of pciehp & acpiphpMatthew Garrett
Some hardware exposes PCIE slots in such a way that they can be claimed by either the acpiphp or pciehp driver. pciehp is the preferred driver if the firmware allows the OS to claim control via the _OSC method so should be loaded first - if it fails to bind (either due to a missing _OSC method or the firmware refusing to hand off control) then we can fall back to acpiphp or a vendor-specific driver. This patch simply changes the link order to ensure that pciehp will be initialised before acpiphp if both are statically built into the kernel. Signed-off-by: Matthew Garrett <mjg@redhat.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-27PCI hotplug: fakephp: Allocate PCI resources before adding the deviceDarrick J. Wong
For PCI devices, pci_bus_assign_resources() must be called to set up the pci_device->resource array before pci_bus_add_devices() can be called, else attempts to load drivers results in BAR collision errors where there are none. This is not done in fakephp, so devices can be "unplugged" but scanning the parent bus won't bring the devices back due to resource unallocation. Move the pci_bus_add_device-calling logic into pci_rescan_bus and preface it with a call to pci_bus_assign_resources so that we only have to (re)allocate resources once per bus where a new device is found. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Acked-by: Alex Chiang <achiang@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-27PCI MSI: Fix undefined shift by 32Matthew Wilcox
Add an msi_mask() function which returns the correct bitmask for the number of MSI interrupts you have. This fixes an undefined bug in msi_capability_init(). Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-27PCI PM: Do not wait for buses in B2 or B3 during resumeRafael J. Wysocki
pci_restore_standard_config() adds extra delay for PCI buses in low power states (B2 or B3), but this is only correct for buses in B2, because the buses in B3 are reset when they are put back into B0. Thus we should wait for such buses to settle after the reset, but it's not a good idea to wait that long (1.1 s) with interrupts off. On the other hand, we have never waited for buses in B2 and B3 during resume and it seems reasonable to go back to this well tested behaviour. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-27PCI PM: Power up devices before restoring their stateRafael J. Wysocki
Devices that have MSI-X enabled before suspend to RAM or hibernation and that are in a low power state during resume will not be handled correctly by pci_restore_standard_config(). Namely, it first calls pci_restore_state() which calls pci_restore_msi_state(), which in turn executes __pci_restore_msix_state() that accesses the device's memory space to restore the contents of the MSI-X table. However, if the device is in a low power state at this point, it's memory space is not accessible. The easiest way to fix this potential problem is to make pci_restore_standard_config() call pci_restore_state() after it has put the device into the full power state, D0. Fortunately, all of this is done with interrupts off, so the change of ordering should not cause any trouble. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-27PCI PM: Fix hibernation breakage on EeePC 701Rafael J. Wysocki
Hibernation breaks on EeePC 701 as a result of attempting to put one of its (driverless) devices into a low power state. Avoid that by not attepmting to power manage driverless devices during hibernation. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Reported-and-tested-by: Alan Jenkins <alan-jenkins@tuffmail.co.uk> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-27PCI PM: Fix suspend error paths and testing facility breakageRafael J. Wysocki
If one of device drivers refuses to suspend by returning error code from its ->suspend() callback, the devices that have already been suspended are resumed by executing their drivers' ->resume() callbacks. Some of these callbacks expect the device's configuration space to be restored if the device has been put into D3 before they are called. Unfortunately, this mechanism has been broken by recent changes moving the restoration of config spaces of some devices (most importantly, USB controllers and HDA Intel) into the resume callbacks executed with interrupts off. Obviously, these callbacks are not invoked in the suspend error path and, as a result, the system cannot be successfully brought back into the working state in case of a suspend error. The same thing happens in the hibernation error path right before putting the system into S4. Similarly, the suspend testing facility associated with the /sys/power/pm_test file is broken, because it uses the very same mechanism that is used in the suspend and hibernation error paths. Fix the breakage by making the PCI core restore the configuration spaces of PCI devices that haven't been restored already before pci_pm_resume() is called for those devices by the PM core. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: PCI hotplug: fix lock imbalance in pciehp PCI PM: Restore standard config registers of all devices early PCI/MSI: bugfix/utilize for msi_capability_init()
2009-01-19PCI hotplug: fix lock imbalance in pciehpJiri Slaby
set_lock_status omits mutex_unlock in fail path. Add the omitted unlock. As a result a lockup caused by this can be triggered from userspace by writing 1 to /sys/bus/pci/slots/.../lock often enough. Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Reviewed-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-16PCI PM: Restore standard config registers of all devices earlyRafael J. Wysocki
There is a problem in our handling of suspend-resume of PCI devices that many of them have their standard config registers restored with interrupts enabled and they are put into the full power state with interrupts enabled as well. This may lead to the following scenario: * an interrupt vector is shared between two or more devices * one device is resumed earlier and generates an interrupt * the interrupt handler of another device tries to handle it and attempts to access the device the config space of which hasn't been restored yet and/or which still is in a low power state * the system crashes as a result To prevent this from happening we should restore the standard configuration registers of all devices with interrupts disabled and we should put them into the D0 power state right after that. Unfortunately, this cannot be done using the existing pci_set_power_state(), because it can sleep. Also, to do it we have to make sure that the config spaces of all devices were actually saved during suspend. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-16PCI/MSI: bugfix/utilize for msi_capability_init()Hidetoshi Seto
This patch fix a following bug and does a cleanup. bug: commit 5993760f7fc75b77e4701f1e56dc84c0d6cf18d5 had a wrong change (since is_64 is boolean[0|1]): - pci_write_config_dword(dev, - msi_mask_bits_reg(pos, is_64bit_address(control)), - maskbits); + pci_write_config_dword(dev, entry->msi_attrib.is_64, maskbits); utilize: Unify separated if (entry->msi_attrib.maskbit) statements. Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com> Acked-by: "Jike Song" <albcamus@gmail.com> Cc: stable@vger.kernel.org Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-01-16ACPI PCI hotplug: harden against panic regressionJames Bottomley
ACPI hotplug panic with current git head http://lkml.org/lkml/2009/1/10/136 Rather than reverting the entire commit that causes the crash: e8c331e963c58b83db24b7d0e39e8c07f687dbc6 "PCI hotplug: introduce functions for ACPI slot detection" simply harden against it while the changes to the hotplug code on this particularl machine are understood. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com> Acked-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Len Brown <len.brown@intel.com>
2009-01-16Revert "PCI PM: Register power state of devices during initialization"Linus Torvalds
This reverts commit 98e6e286d7b01deb7453b717aa38ebb69d6cefc0, as Yinghai Lu reports that it breaks kexec with at least the e1000 and e1000e drivers. The reason is that the shutdown sequence puts the hardware into D3 sleep, and the commit causes us to claim that it then is in D0 (running) state just because we don't understand the PM capabilities. Which then later makes "pci_set_power_state()" not do anything, and the device never wakes up properly and just returns 0xff to everything. Reported-by: Yinghai Lu <yinghai@kernel.org> Acked-by: From: Rafael J. Wysocki <rjw@sisk.pl> Cc: Jesse Barnes <jesse.barnes@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-14[CVE-2009-0029] System call wrappers part 26Heiko Carstens
2009-01-13Prevent oops at boot with VT-dDirk Hohndel
With some broken BIOSs when VT-d is enabled, the data structures are filled incorrectly. This can cause a NULL pointer dereference in very early boot. Signed-off-by: Dirk Hohndel <hohndel@linux.intel.com> Acked-by: Yu Zhao <yu.zhao@intel.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
