path: root/drivers/pcmcia/sa1100_generic.c
2005-10-31Merge master.kernel.org:/home/rmk/linux-2.6-drvmodelLinus Torvalds
Manual #include fixups for clashes - there may be some unnecessary
2005-10-30[ARM] Support pcmcia slot on sharp sl-5500Pavel Machek
This adds support for pcmcia slot on sharp zaurus sl-5500. pxa2xx_sharpsl.c thus becomes quite miss-named, but I guess that is not worth fixing? Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-29Create platform_device.h to contain all the platform device details.Russell King
Convert everyone who uses platform_bus_type to include linux/platform_device.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] DRIVER MODEL: Get rid of the obsolete tri-level suspend/resume callbacksRussell King
In PM v1, all devices were called at SUSPEND_DISABLE level. Then all devices were called at SUSPEND_SAVE_STATE level, and finally SUSPEND_POWER_DOWN level. However, with PM v2, to maintain compatibility for platform devices, I arranged for the PM v2 suspend/resume callbacks to call the old PM v1 suspend/resume callbacks three times with each level in order so that existing drivers continued to work. Since this is obsolete infrastructure which is no longer necessary, we can remove it. Here's an (untested) patch to do exactly that. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-03[ARM] 2873/1: PCMCIA soc: Allow access to filesystems on CF at boot timeRichard Purdie
Patch from Richard Purdie This change makes the soc pcmcia interfaces available earlier in the boot process meaning devices like CF microdrives can be used for the root filesystem. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-07-07[PATCH] pcmcia: remove references to pcmcia/version.hDominik Brodowski
As a follow-up, remove the inclusion of pcmcia/version.h in many files. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-16[PATCH] fix u32 vs. pm_message_t in pcmciaPavel Machek
This fixes u32 vs. pm_message_t in pcmcia. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
