path: root/drivers/pcmcia/sa1100_shannon.c
2010-11-10pcmcia/sa1100: don't put machine specific init functions in .init.textUwe Kleine-König
These are called by sa11x0_drv_pcmcia_probe (which is marked now with __devinit) so they can go to .devinit.text now, too. This fixes: WARNING: drivers/pcmcia/sa1100_cs.o(.text+0x10): Section mismatch in reference from the function sa11x0_drv_pcmcia_probe() to the function .init.text:pcmcia_simpad_init() The function sa11x0_drv_pcmcia_probe() references the function __init pcmcia_simpad_init(). This is often because sa11x0_drv_pcmcia_probe lacks a __init annotation or the annotation of pcmcia_simpad_init is wrong. and a similar warning for pcmcia_collie_init, pcmcia_cerf_init, pcmcia_h3600_init and pcmcia_shannon_init. While at it mark pcmcia_assabet_init with __devinit, too. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> CC: Russell King <linux@arm.linux.org.uk> CC: Eric Miao <eric.y.miao@gmail.com> CC: linux-arm-kernel@lists.infradead.org Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2009-11-09PCMCIA: stop duplicating pci_irq in soc_pcmcia_socketRussell King - ARM Linux
skt->irq is a mere duplication of pcmcia_socket's pci_irq member. Get rid of it. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-08-07[ARM] Remove asm/hardware.h, use asm/arch/hardware.h insteadRussell King
Remove includes of asm/hardware.h in addition to asm/arch/hardware.h. Then, since asm/hardware.h only exists to include asm/arch/hardware.h, update everything to directly include asm/arch/hardware.h and remove asm/hardware.h. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-05-01pcmcia: replace remaining __FUNCTION__ occurrencesHarvey Harrison
