path: root/drivers/pcmcia
2016-04-20pcmcia: db1xxx_ss: fix last irq_to_gpio userManuel Lauss
commit e34b6fcf9b09ec9d93503edd5f81489791ffd602 upstream. remove the usage of removed irq_to_gpio() function. On pre-DB1200 boards, pass the actual carddetect GPIO number instead of the IRQ, because we need the gpio to actually test card status (inserted or not) and can get the irq number with gpio_to_irq() instead. Tested on DB1300 and DB1500, this patch fixes PCMCIA on the DB1500, which used irq_to_gpio(). Fixes: 832f5dacfa0b ("MIPS: Remove all the uses of custom gpio.h") Signed-off-by: Manuel Lauss <manuel.lauss@gmail.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Reviewed-by: Linus Walleij <linus.walleij@linaro.org> Cc: linux-pcmcia@lists.infradead.org Cc: Linux-MIPS <linux-mips@linux-mips.org> Patchwork: https://patchwork.linux-mips.org/patch/12747/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-05pcmcia: use kstrdup() in pcmcia_device_query()Geliang Tang
Use kstrdup instead of kmalloc and strncpy. Signed-off-by: Geliang Tang <geliangtang@163.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-09-03pcmcia: soc_common: remove skt_dev_info's clk pointerRussell King
We no longer need to store the clk pointer in struct skt_dev_info as we no longer need to remember the clk pointer for the cleanup paths. Reviewed-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2015-09-03pcmcia: sa11xx_base.c: remove useless init/exit functionsRussell King
A library module is not required to have module init/exit functions. Get rid of these unnecessary functions. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2015-09-03pcmcia: sa1111: simplify clk handing in sa1111_pcmcia_add()Russell King
clk_get(dev, NULL) will always refer to the same clock, so it's pointless calling this multiple times for the same device. As we no longer have to worry about the cleanup (via use of devm_clk_get()) we can simplify sa1111_pcmcia_add() too. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2015-09-03pcmcia: sa1111: update socket driver to use devm_clk_get() APIRussell King
Update the pxa2xx socket driver to use the devm_clk_get() API so that the cleanup paths are simplified. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2015-09-03pcmcia: pxa2xx: convert memory allocation to devm_* APIRussell King
Convert the pxa2xx socket driver memory allocation to use devm_kzalloc() to simplify the cleanup path. Reviewed-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2015-09-03pcmcia: pxa2xx: update socket driver to use devm_clk_get() APIRussell King
Update the pxa2xx socket driver to use the devm_clk_get() API so that the cleanup paths are simplified. Reviewed-by: Robert Jarzmik <robert.jarzmik@free.fr> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2015-07-08pcmcia: sa11x0: convert memory allocation to devm_* APIRussell King
Convert the sa11x0 socket driver memory allocation to use devm_kzalloc() to simplify the cleanup path. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2015-07-08pcmcia: sa11x0: fix missing clk_put() in sa11x0 socket driversRussell King
Fix the lack of clk_put() in sa11xx_base.c's error cleanup paths by converting the driver to the devm_* API. Fixes: 86d88bfca475 ("ARM: 8247/2: pcmcia: sa1100: make use of device clock") Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2015-07-02Merge tag 'module-implicit-v4.1-rc8' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux Pull implicit module.h fixes from Paul Gortmaker: "Fix up implicit <module.h> users that will break later. The files changed here are simply modular source files that are implicitly relying on <module.h> being present. We fix them up now, so that we can decouple some of the module related init code from the core init code in the future. The addition of the module.h include to several files here is also a no-op from a code generation point of view, else there would already be compile issues with these files today. There may be lots more implicit includes of <module.h> in tree, but these are the ones that extensive build test coverage has shown that must be fixed in order to avoid build breakage fallout for the pending module.h <---> init.h code relocation we desire to complete" * tag 'module-implicit-v4.1-rc8' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: frv: add module.h to mb93090-mb00/flash.c to avoid compile fail drivers/cpufreq: include <module.h> for modular exynos-cpufreq.c code drivers/staging: include <module.h> for modular android tegra_ion code crypto/asymmetric_keys: pkcs7_key_type needs module.h sh: mach-highlander/psw.c is tristate and should use module.h drivers/regulator: include <module.h> for modular max77802 code drivers/pcmcia: include <module.h> for modular xxs1500_ss code drivers/hsi: include <module.h> for modular omap_ssi code drivers/gpu: include <module.h> for modular rockchip code drivers/gpio: include <module.h> for modular crystalcove code drivers/clk: include <module.h> for clk-max77xxx modular code
2015-06-26Merge tag 'char-misc-4.2-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc Pull char/misc driver updates from Greg KH: "Here's the big char/misc driver pull request for 4.2-rc1. Lots of mei, extcon, coresight, uio, mic, and other driver updates in here. Full details in the shortlog. All of these have been in linux-next for some time with no reported problems" * tag 'char-misc-4.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (176 commits) mei: me: wait for power gating exit confirmation mei: reset flow control on the last client disconnection MAINTAINERS: mei: add mei_cl_bus.h to maintained file list misc: sram: sort and clean up included headers misc: sram: move reserved block logic out of probe function misc: sram: add private struct device and virt_base members misc: sram: report correct SRAM pool size misc: sram: bump error message level on unclean driver unbinding misc: sram: fix device node reference leak on error misc: sram: fix enabled clock leak on error path misc: mic: Fix reported static checker warning misc: mic: Fix randconfig build error by including errno.h uio: pruss: Drop depends on ARCH_DAVINCI_DA850 from config uio: pruss: Add CONFIG_HAS_IOMEM dependence uio: pruss: Include <linux/sizes.h> extcon: Redefine the unique id of supported external connectors without 'enum extcon' type char:xilinx_hwicap:buffer_icap - change 1/0 to true/false for bool type variable in function buffer_icap_set_configuration(). Drivers: hv: vmbus: Allocate ring buffer memory in NUMA aware fashion parport: check exclusive access before register w1: use correct lock on error in w1_seq_show() ...
2015-06-26Merge tag 'armsoc-cleanup' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC cleanups from Kevin Hilman: "A relatively small setup of cleanups this time around, and similar to last time the bulk of it is removal of legacy board support: - OMAP: removal of legacy (non-DT) booting for several platforms - i.MX: remove some legacy board files" * tag 'armsoc-cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (36 commits) ARM: fix EFM32 build breakage caused by cpu_resume_arm ARM: 8389/1: Add cpu_resume_arm() for firmwares that resume in ARM state ARM: v7 setup function should invalidate L1 cache mach-omap2: Remove use of deprecated marco, PTR_RET in devices.c ARM: OMAP2+: Remove calls to deprecacted marco,PTR_RET in the files,fb.c and pmu.c ARM: OMAP2+: Constify irq_domain_ops ARM: OMAP2+: use symbolic defines for console loglevels instead of numbers ARM: at91: remove useless Makefile.boot ARM: at91: remove at91rm9200_sdramc.h ARM: at91: remove mach/at91_ramc.h and mach/at91rm9200_mc.h ARM: at91/pm: use the atmel-mc syscon defines pcmcia: at91_cf: Use syscon to configure the MC/smc ARM: at91: declare the at91rm9200 memory controller as a syscon mfd: syscon: Add Atmel MC (Memory Controller) registers definition ARM: at91: drop sam9_smc.c ata: at91: use syscon to configure the smc ARM: ux500: delete static resource defines ARM: ux500: rename ux500_map_io ARM: ux500: look up PRCMU resource from DT ARM: ux500: kill off L2CC static map ...
2015-06-16drivers/pcmcia: include <module.h> for modular xxs1500_ss codePaul Gortmaker
This file is built off of a tristate Kconfig option and also contains modular function calls so it should explicitly include module.h to avoid compile breakage during header shuffles done in the future. Cc: Wolfram Sang <wsa@the-dreams.de> Acked-by: Wolfram Sang <wsa@the-dreams.de> Cc: linux-pcmcia@lists.infradead.org Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2015-06-16pcmcia: do not break rsrc_nonstatic when handling anonymous cardsDominik Brodowski
Patch 1c6c9b1d9d25 caused a regression for rsrc_nonstatic: It relies on pccard_validate_cis() to determine whether an iomem resource can be used for PCMCIA cards. This override, however, lead invalid iomem resources to be accepted -- and lead to a fake CIS being used instead of the original CIS. To fix this issue, move the override for anonymous cards to the one place where it is needed -- when adding a PCMCIA device. Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2015-06-14pcmcia: Fix resource leaks in yenta_probe() and _close()Takeshi Yoshimura
There are some resource leaks in yenta_probe() and _close(). I fixed the following issues with some code cleanups. Thanks to Dominik's suggestions. On the error path in yenta_probe(): - a requested irq is not released - yenta_free_resources() and pci_set_drvdata(dev, NULL) are not called In yenta_close(): - kfree(sock) is not called - sock->base is always set to non-NULL when yenta_close() is called, therefore the check in yenta_close() is not necessary. Signed-off-by: Takeshi Yoshimura <yos@sslab.ics.keio.ac.jp> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2015-06-13Disable write buffering on Toshiba ToPIC95Ryan Underwood
Disable write buffering on the Toshiba ToPIC95 if it is enabled by somebody (it is not supposed to be a power-on default according to the datasheet). On the ToPIC95, practically no 32-bit Cardbus card will work under heavy load without locking up the whole system if this is left enabled. I tried about a dozen. It does not affect 16-bit cards. This is similar to the O2 bugs in early controller revisions it seems. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=55961 Cc: <stable@vger.kernel.org> Signed-off-by: Ryan C. Underwood <nemesis@icequake.net> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2015-05-30pcmcia: Convert dev_printk to dev_<level>Joe Perches
Reduce object size a little by using dev_<level> calls instead of dev_printk(KERN_<LEVEL>. Other miscellanea: o Coalesce formats o Realign arguments o Use pr_cont instead of naked printk reorder test to use "%s\n" Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2015-05-30pcmcia/vrc4171: Remove typedefs for enums and structHimangi Saraogi
The Linux kernel coding style guidelines suggest not using typedefs for structure and enum types. This patch gets rid of the typedefs for vrc4171_slot_t, vrc4171_slotb_t and vrc4171_socket_t. Also, the names of the enums and the struct are changed to drop the _t, to make the name look less typedef-like. The following Coccinelle semantic patch detects the cases for struct type: @tn@ identifier i; type td; @@ -typedef struct i { ... } -td ; @@ type tn.td; identifier tn.i; @@ -td + struct i Signed-off-by: Himangi Saraogi <himangi774@gmail.com> Acked-by: Julia Lawall <julia.lawall@lip6.fr> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2015-05-30pcmcia: Remove typedef in structs and emumHimangi Saraogi
The Linux kernel coding style guidelines suggest not using typedefs for structure and enum types. This patch gets rid of the typedefs for cirrus_state_t, vg46x_state_t and pcic_id. Also, the names of the structs are changed to drop the _t, to make the name look less typedef-like. The following Coccinelle semantic patch detects the cases for struct type: @tn@ identifier i; type td; @@ -typedef struct i { ... } -td ; @@ type tn.td; identifier tn.i; @@ -td + struct i [linux@dominikbrodowski.net: fix patch to apply cleanly after e632cd94723e was applied first] Signed-off-by: Himangi Saraogi <himangi774@gmail.com> Acked-by: Julia Lawall <julia.lawall@lip6.fr> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2015-05-30pcmcia: Remove typedef tuple_flagsHimangi Saraogi
The Linux kernel coding style guidelines suggest not using typedefs for structure types. This patch gets rid of the typedef for tuple_flags. The following Coccinelle semantic patch makes the transformation. @tn@ identifier i; type td; @@ -typedef struct i { ... } -td ; @@ type tn.td; identifier tn.i; @@ -td + struct i Signed-off-by: Himangi Saraogi <himangi774@gmail.com> Acked-by: Julia Lawall <julia.lawall@lip6.fr> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2015-05-30drivers: pcmcia: electra_cf.c fix checkpatch error and warningsLaurent Navet
fix these checkpatch errors and warning: - ERROR: "foo * bar" should be "foo *bar" - WARNING: please, no space before tabs - WARNING: sizeof *cf should be sizeof(*cf) - WARNING: space prohibited between function name and open parenthesis '('i Signed-off-by: Laurent Navet <laurent.navet@gmail.com> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2015-05-30drivers: pcmcia: ds.c fix checkpatch errorsLaurent Navet
fix these checkpatch errors : - ERROR: spaces required around that '<' (ctx:VxW) - ERROR: "foo * bar" should be "foo *bar" - WARNING: please, no space before tabs Signed-off-by: Laurent Navet <laurent.navet@gmail.com> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2015-05-30PCMCIA: Remove commented references to dead class_device_create_file()Robert P. J. Day
Since this routine doesn't even exist anymore, there's no point leaving in commented code using it. Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2015-05-30drivers/pcmcia/electra_cf.c: add missing iounmap and kfreeJulia Lawall
cf and cf->mem_base have been allocated at the point of this failure, so they should be freed before leaving the function. [linux@dominikbrodowski.net: limit call to device_init_wakeup() to the same error paths as before] Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2015-05-30pcmcia: replace open-coded ARRAY_SIZE with macroJim Cromie
Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
2015-05-24pcmcia: fix a boot time warning in pcmcia cs codeDmitry Eremin-Solenikov
During bootup pcmcia (pccardd) code enforces the following warning backtrace: do not call blocking ops when !TASK_RUNNING; state=1 set at [<c0319e74>] pccardd+0xb8/0x3fc Modules linked in: CPU: 0 PID: 14 Comm: pccardd Not tainted 4.0.0-rc6+ #11 Hardware name: Sharp-Collie [<c0105cd8>] (unwind_backtrace) from [<c0103ef8>] (show_stack+0x10/0x14) [<c0103ef8>] (show_stack) from [<c010e9b8>] (warn_slowpath_common+0x74/0xac) [<c010e9b8>] (warn_slowpath_common) from [<c010ea20>] (warn_slowpath_fmt+0x30/0x40) [<c010ea20>] (warn_slowpath_fmt) from [<c012b1b4>] (__might_sleep+0x84/0xa0) [<c012b1b4>] (__might_sleep) from [<c040fbb0>] (mutex_lock_nested+0x24/0x388) [<c040fbb0>] (mutex_lock_nested) from [<c0319eb4>] (pccardd+0xf8/0x3fc) [<c0319eb4>] (pccardd) from [<c0127370>] (kthread+0xdc/0xfc) [<c0127370>] (kthread) from [<c01013a8>] (ret_from_fork+0x14/0x2c) ---[ end trace fd94911637eed4ba ]--- This happens due to kthread trying to lock mutex in a TASK_INTERRUPTIBLE state. Limit TASK_INTERRUPTIBLE task state to the schedule() call only, so that the rest of the code runs in TASK_RUNNING state. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-20pcmcia: at91_cf: Use syscon to configure the MC/smcAlexandre Belloni
Use syscon/regmap to configure the smc part of the memory controller. This allows to avoid using mach/at91rm9200_mc.h and mach/at91_ramc.h and to compile the driver in a multiplatform configuration. Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2015-04-22Merge tag 'armsoc-cleanup' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC cleanups from Olof Johansson: "We've got a fairly large cleanup branch this time. The bulk of this is removal of non-DT platforms of several flavors: - Atmel at91 platforms go full-DT, with removal of remaining board-file based support - OMAP removes legacy board files for three more platforms - removal of non-DT mach-msm, newer Qualcomm platforms now live in mach-qcom - Freescale i.MX25 also removes non-DT platform support" Most of the rest of the changes here are fallout from the above, i.e. for example removal of drivers that now lack platforms, etc. * tag 'armsoc-cleanup' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (58 commits) mmc: Remove msm_sdcc driver gpio: Remove gpio-msm-v1 driver ARM: Remove mach-msm and associated ARM architecture code ARM: shmobile: cpuidle: Remove the pointless default driver ARM: davinci: dm646x: Add interrupt resource for McASPs ARM: davinci: irqs: Correct McASP1 TX interrupt definition for DM646x ARM: davinci: dm646x: Clean up the McASP DMA resources ARM: davinci: devices-da8xx: Add support for McASP2 on da830 ARM: davinci: devices-da8xx: Clean up and correct the McASP device creation ARM: davinci: devices-da8xx: Add interrupt resource to McASP structs ARM: davinci: devices-da8xx: Add resource name for the McASP DMA request ARM: OMAP2+: Remove legacy support for omap3 TouchBook ARM: OMAP3: Remove legacy support for devkit8000 ARM: OMAP3: Remove legacy support for EMA-Tech Stalker board ARM: shmobile: Consolidate the pm code for R-Car Gen2 ARM: shmobile: r8a7791: Correct SYSCIER value ARM: shmobile: r8a7790: Correct SYSCIER value ARM: at91: remove old setup ARM: at91: sama5d4: remove useless map_io ARM: at91: sama5 use SoC detection infrastructure ...
2015-03-25Merge 4.0-rc5 into char-misc-nextGreg Kroah-Hartman
We want those fixes in here as well. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-16pcmcia: Use setup_timer and mod_timerVaishali Thakkar
This patch introduces the use of functions setup_timer and mod_timer. This is done using Coccinelle and semantic patch used for this as follows: // <smpl> @@ expression x,y,z,a,b; @@ -init_timer (&x); +setup_timer (&x, y, z); +mod_timer (&a, b); -x.function = y; -x.data = z; -x.expires = b; -add_timer(&a); // </smpl> Signed-off-by: Vaishali Thakkar <vthakkar1994@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-16pcmcia: Use setup_timerVaishali Thakkar
This patch introduces the use of function setup_timer. This is done using Coccinelle and semantic patch used is as follows: @@ expression x,y,z; @@ - init_timer (&x); + setup_timer (&x, y, z); - x.function = y; - x.data = z; Signed-off-by: Vaishali Thakkar <vthakkar1994@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-13ARM: at91: remove NEED_MACH_IO_HArnd Bergmann
The mach/io.h header on at91 is used to support a nonstandard I/O space window for the cf card driver. This changes the driver to use pci_ioremap_io in order to have the standard location, and then removes the custom mach/io.h. [alexandre.belloni@free-electrons.com: Added PCI dependency] Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
2015-03-11Revert "pcmcia: add a new resource manager for non ISA systems"Greg Kroah-Hartman
This reverts commit 02b03846bb2befc558bfd0665749d6bb26f4c2f1. Alan writes: it seems there is a regression in there for some configuration of I/O based devices. I'll take a look at it over the next couple of kernel releases and see what is up then resubmit it with fixes. Reported-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-11Revert "pcmcia: fix incorrect bracketing on a test"Greg Kroah-Hartman
This reverts commit c3762b248faf9db2b00b36c0535f79758942069e. The file this fixes is about to be reverted. Reported-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-03-11Revert "pcmcia: add missing include for new pci resource handler"Greg Kroah-Hartman
This reverts commit d885d4f3728f386034bb2f7a61b7f2054c49b2d4 as the patch that it fixes is about to be reverted. Reported-by: Alan Cox <alan@linux.intel.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Jim Davis <jim.epost@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-02-17Merge tag 'drivers-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC driver updates from Olof Johansson: "These are changes for drivers that are intimately tied to some SoC and for some reason could not get merged through the respective subsystem maintainer tree. This time around, much of this is for at91, with the bulk of it being syscon and udc drivers. Also, there's: - coupled cpuidle support for Samsung Exynos4210 - Renesas 73A0 common-clk work - of/platform changes to tear down DMA mappings on device destruction - a few updates to the TI Keystone knav code" * tag 'drivers-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (26 commits) cpuidle: exynos: add coupled cpuidle support for exynos4210 ARM: EXYNOS: apply S5P_CENTRAL_SEQ_OPTION fix only when necessary soc: ti: knav_qmss_queue: change knav_range_setup_acc_irq to static soc: ti: knav_qmss_queue: makefile tweak to build as dynamic module pcmcia: at91_cf: depend on !ARCH_MULTIPLATFORM soc: ti: knav_qmss_queue: export API calls for use by user driver of/platform: teardown DMA mappings on device destruction usb: gadget: at91_udc: Allocate udc instance usb: gadget: at91_udc: Update DT binding documentation usb: gadget: at91_udc: Rework for multi-platform kernel support usb: gadget: at91_udc: Simplify probe and remove functions usb: gadget: at91_udc: Remove non-DT handling code usb: gadget: at91_udc: Document DT clocks and clock-names property usb: gadget: at91_udc: Drop uclk clock usb: gadget: at91_udc: Fix clock names mfd: syscon: Add Atmel SMC binding doc mfd: syscon: Add atmel-smc registers definition mfd: syscon: Add Atmel Matrix bus DT binding documentation mfd: syscon: Add atmel-matrix registers definition clk: shmobile: fix sparse NULL pointer warning ...
2015-01-29pcmcia: at91_cf: depend on !ARCH_MULTIPLATFORMAlexandre Belloni
Until the driver is corrected to stop including mach/at91_ramc.h and using mach/io.h, it won't compile in a ARCH_MULTIPLATFORM configuration. Suggested-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2015-01-25pcmcia: fix incorrect bracketing on a testAlan
Reported by wonderful 0-Day Test infrastructure. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-13pcmcia: add missing include for new pci resource handlerArnd Bergmann
The recently added rsrc_pci.c file calls pci_bus_alloc_resource without including the header file that declares it, and that sometimes causes a build warning on ARM: drivers/pcmcia/rsrc_pci.c: In function 'find_io_region': drivers/pcmcia/rsrc_pci.c:40:2: error: implicit declaration of function 'pci_bus_alloc_resource' [-Werror=implicit-function-declaration] This adds the missing include statement. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Fixes: 02b03846bb2be ("pcmcia: add a new resource manager for non ISA systems") Acked-by: Alan Cox <alan@linux.intel.com> Reported-by: Jim Davis <jim.epost@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-12pcmcia: add a new resource manager for non ISA systemsAlan Cox
On a pure PCI platform we don't actually need all the complexity of the rsrc_nonstatic manager, in fact we can just work directly with the pci allocators and avoid all the complexity (and code bloat). Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-12pcmcia: handle anonymous cards by generating a fake CISAlan Cox
The core pcmcia code blows up all over the place if it allowed a card without a valid CIS. We need to allow such cards as the CIS stuff is not on the older flash, ROM and SRAM cards. In order to minimise the risk of misidentifying junk and feeding it to the wrong thing we only fix up apparently anonymous cards if the driver for them has been enabled. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-12pcmcia: Fix requeryAlan Cox
The requery logic goes off and attempts to read the CIS of empty slots. In most cases this happens not to do any harm - but not all! Add the missing check and also a WARN() to catch any other offenders. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-12pcmcia cis: on an out of range CIS read return 0xff, don't just warnAlan Cox
The current code displays warnings but then proceeds to try and reference the data through the PCMCIA window. Instead return 0xff. This prevents bogus CIS data sending us off into hyperspace. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-01-12pcmcia: correct typesAlan Cox
We should be using resource_size_t and unsigned types correctly, otherwise we sign extend the flags on a 64bit box, which is not what we want. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-12-14Merge tag 'char-misc-3.19-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc Pull char/misc driver updates from Greg KH: "Here's the big char/misc driver update for 3.19-rc1 Lots of little things all over the place in different drivers, and a new subsystem, "coresight" has been added. Full details are in the shortlog" * tag 'char-misc-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (73 commits) parport: parport_pc, do not remove parent devices early spmi: Remove shutdown/suspend/resume kernel-doc carma-fpga-program: drop videobuf dependency carma-fpga: drop videobuf dependency carma-fpga-program.c: fix compile errors i8k: Fix temperature bug handling in i8k_get_temp() cxl: Name interrupts in /proc/interrupt CXL: Return error to PSL if IRQ demultiplexing fails & print clearer warning coresight-replicator: remove .owner field for driver coresight: fixed comments in coresight.h coresight: fix typo in comment in coresight-priv.h coresight: bindings for coresight drivers coresight: Adding ABI documentation w1: support auto-load of w1_bq27000 module. w1: avoid potential u16 overflow cn: verify msg->len before making callback mei: export fw status registers through sysfs mei: read and print all six FW status registers mei: txe: add cherrytrail device id mei: kill cached host and me csr values ...
2014-12-14Merge tag 'driver-core-3.19-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core update from Greg KH: "Here's the set of driver core patches for 3.19-rc1. They are dominated by the removal of the .owner field in platform drivers. They touch a lot of files, but they are "simple" changes, just removing a line in a structure. Other than that, a few minor driver core and debugfs changes. There are some ath9k patches coming in through this tree that have been acked by the wireless maintainers as they relied on the debugfs changes. Everything has been in linux-next for a while" * tag 'driver-core-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (324 commits) Revert "ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries" fs: debugfs: add forward declaration for struct device type firmware class: Deletion of an unnecessary check before the function call "vunmap" firmware loader: fix hung task warning dump devcoredump: provide a one-way disable function device: Add dev_<level>_once variants ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries ath: use seq_file api for ath9k debugfs files debugfs: add helper function to create device related seq_file drivers/base: cacheinfo: remove noisy error boot message Revert "core: platform: add warning if driver has no owner" drivers: base: support cpu cache information interface to userspace via sysfs drivers: base: add cpu_device_create to support per-cpu devices topology: replace custom attribute macros with standard DEVICE_ATTR* cpumask: factor out show_cpumap into separate helper function driver core: Fix unbalanced device reference in drivers_probe driver core: fix race with userland in device_add() sysfs/kernfs: make read requests on pre-alloc files use the buffer. sysfs/kernfs: allow attributes to request write buffer be pre-allocated. fs: sysfs: return EGBIG on write if offset is larger than file size ...
2014-12-12Merge branch 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-armLinus Torvalds
Pull ARM updates from Russell King: "The major updates included in this update are: - Clang compatible stack pointer accesses by Behan Webster. - SA11x0 updates from Dmitry Eremin-Solenikov. - kgdb handling of breakpoints with read-only text/modules - Support for Privileged-no-execute feature on ARMv7 to prevent userspace code execution by the kernel. - AMBA primecell bus handling of irq-safe runtime PM - Unwinding support for memset/memzero/memmove/memcpy functions - VFP fixes for Krait CPUs and improvements in detecting the VFP architecture - A number of code cleanups (using pr_*, removing or reducing the severity of a couple of kernel messages, splitting ftrace asm code out to a separate file, etc.) - Add machine name to stack dump output" * 'for-linus' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: (62 commits) ARM: 8247/2: pcmcia: sa1100: make use of device clock ARM: 8246/2: pcmcia: sa1111: provide device clock ARM: 8245/1: pcmcia: soc-common: enable/disable socket clocks ARM: 8244/1: fbdev: sa1100fb: make use of device clock ARM: 8243/1: sa1100: add a clock alias for sa1111 pcmcia device ARM: 8242/1: sa1100: add cpu clock ARM: 8221/1: PJ4: allow building in Thumb-2 mode ARM: 8234/1: sa1100: reorder IRQ handling code ARM: 8233/1: sa1100: switch to hwirq usage ARM: 8232/1: sa1100: merge GPIO multiplexer IRQ to "normal" irq domain ARM: 8231/1: sa1100: introduce irqdomains support ARM: 8230/1: sa1100: shift IRQs by one ARM: 8229/1: sa1100: replace irq numbers with names in irq driver ARM: 8228/1: sa1100: drop entry-macro.S ARM: 8227/1: sa1100: switch to MULTI_IRQ_HANDLER ARM: 8241/1: Update processor_modes for hyp and monitor mode ARM: 8240/1: MCPM: document mcpm_sync_init() ARM: 8239/1: Introduce {set,clear}_pte_bit ARM: 8238/1: mm: Refine set_memory_* functions ARM: 8237/1: fix flush_pfn_alias ...
2014-12-05ARM: 8247/2: pcmcia: sa1100: make use of device clockDmitry Eremin-Solenikov
Use per-device clock (instead of calling cpufreq_get(0), which can return 0 if no cpu frequency driver is selected) to program timings. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-12-05ARM: 8246/2: pcmcia: sa1111: provide device clockDmitry Eremin-Solenikov
Both pxa2xx (long ago) and sa1100 (now) make use of clock device to get the cpu speed. Make sa1111 glue code provide clock to platform layer. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
