path: root/drivers/phy/Makefile
2016-09-10phy: Add USB Type-C PHY driver for rk3399Chris Zhong
Add a PHY provider driver for the rk3399 SoC Type-c PHY. The USB Type-C PHY is designed to support the USB3 and DP applications. The USB3 operates in SuperSpeed mode and the DP can operate at RBR, HBR and HBR2 data rates. This driver create 2 PHY devices separately for USB3 and DisplyPort, and registers them under the child node. Signed-off-by: Chris Zhong <zyw@rock-chips.com> Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Reviewed-by: Guenter Roeck <groeck@chromium.org> Tested-by: Guenter Roeck <groeck@chromium.org> Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
2016-09-10phy: add a driver for the Rockchip SoC internal PCIe PHYShawn Lin
This patch to add a generic PHY driver for rockchip PCIe PHY. Access the PHY via registers provided by GRF (general register files) module. Signed-off-by: Shawn Lin <shawn.lin@rock-chips.com> Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
2016-09-10phy: rockchip-inno-usb2: add a new driver for Rockchip usb2phyFrank Wang
The newer SoCs (rk3366, rk3399) take a different usb-phy IP block than rk3288 and before, and most of phy-related registers are also different from the past, so a new phy driver is required necessarily. Signed-off-by: Frank Wang <frank.wang@rock-chips.com> Suggested-by: Heiko Stuebner <heiko@sntech.de> Suggested-by: Guenter Roeck <linux@roeck-us.net> Suggested-by: Doug Anderson <dianders@chromium.org> Reviewed-by: Heiko Stuebner <heiko@sntech.de> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
2016-09-10phy: bcm-ns-usb3: new driver for USB 3.0 PHY on NorthstarRafał Miłecki
Northstar is a family of SoCs used in home routers. They have USB 2.0 and 3.0 controllers with PHYs that need to be properly initialized. This driver provides PHY init support in a generic way and can be bound with XHCI controller driver. There aren't any public datasheets from Broadcom so we can't have nice defines for all used bits. It means we just follow Broadcom's initialization procedure using their magic values. We were quite lucky actually that Broadcom put some comments in their SDK reference code explaining what given writes are responsible for. Signed-off-by: Rafał Miłecki <rafal@milecki.pl> Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
2016-07-27Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: 1) Unified UDP encapsulation offload methods for drivers, from Alexander Duyck. 2) Make DSA binding more sane, from Andrew Lunn. 3) Support QCA9888 chips in ath10k, from Anilkumar Kolli. 4) Several workqueue usage cleanups, from Bhaktipriya Shridhar. 5) Add XDP (eXpress Data Path), essentially running BPF programs on RX packets as soon as the device sees them, with the option to mirror the packet on TX via the same interface. From Brenden Blanco and others. 6) Allow qdisc/class stats dumps to run lockless, from Eric Dumazet. 7) Add VLAN support to b53 and bcm_sf2, from Florian Fainelli. 8) Simplify netlink conntrack entry layout, from Florian Westphal. 9) Add ipv4 forwarding support to mlxsw spectrum driver, from Ido Schimmel, Yotam Gigi, and Jiri Pirko. 10) Add SKB array infrastructure and convert tun and macvtap over to it. From Michael S Tsirkin and Jason Wang. 11) Support qdisc packet injection in pktgen, from John Fastabend. 12) Add neighbour monitoring framework to TIPC, from Jon Paul Maloy. 13) Add NV congestion control support to TCP, from Lawrence Brakmo. 14) Add GSO support to SCTP, from Marcelo Ricardo Leitner. 15) Allow GRO and RPS to function on macsec devices, from Paolo Abeni. 16) Support MPLS over IPV4, from Simon Horman. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1622 commits) xgene: Fix build warning with ACPI disabled. be2net: perform temperature query in adapter regardless of its interface state l2tp: Correctly return -EBADF from pppol2tp_getname. net/mlx5_core/health: Remove deprecated create_singlethread_workqueue net: ipmr/ip6mr: update lastuse on entry change macsec: ensure rx_sa is set when validation is disabled tipc: dump monitor attributes tipc: add a function to get the bearer name tipc: get monitor threshold for the cluster tipc: make cluster size threshold for monitoring configurable tipc: introduce constants for tipc address validation net: neigh: disallow transition to NUD_STALE if lladdr is unchanged in neigh_update() MAINTAINERS: xgene: Add driver and documentation path Documentation: dtb: xgene: Add MDIO node dtb: xgene: Add MDIO node drivers: net: xgene: ethtool: Use phy_ethtool_gset and sset drivers: net: xgene: Use exported functions drivers: net: xgene: Enable MDIO driver drivers: net: xgene: Add backward compatibility drivers: net: phy: xgene: Add MDIO driver ...
2016-07-04phy: da8xx-usb: new driver for DA8xx SoC USB PHYDavid Lechner
This is a new phy driver for the SoC USB controllers on the TI DA8xx family of microcontrollers. The USB 1.1 PHY is just a simple on/off. The USB 2.0 PHY also allows overriding the VBUS and ID pins. Signed-off-by: David Lechner <david@lechnology.com> Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
2016-06-10phy: Add Northstar2 PCI Phy supportPramod Kumar
Add PCI Phy support for Broadcom Northstar2 SoCs. This driver uses the interface from the iproc mdio mux driver to enable the devices respective phys. Reviewed-by: Andrew Lunn <andrew@lunn.ch> Signed-off-by: Jon Mason <jonmason@broadcom.com> Signed-off-by: Pramod Kumar <pramod.kumar@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-05-20Merge tag 'usb-4.7-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb Pull USB updates from Greg KH: "Here's the big pull request for USB and PHY drivers for 4.7-rc1 Full details in the shortlog, but it's the normal major gadget driver updates, phy updates, new usbip code, as well as a bit of lots of other stuff. All have been in linux-next with no reported issues" * tag 'usb-4.7-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (164 commits) USB: serial: ti_usb_3410_5052: add MOXA UPORT 11x0 support USB: serial: fix minor-number allocation USB: serial: quatech2: fix use-after-free in probe error path USB: serial: mxuport: fix use-after-free in probe error path USB: serial: keyspan: fix debug and error messages USB: serial: keyspan: fix URB unlink USB: serial: keyspan: fix use-after-free in probe error path USB: serial: io_edgeport: fix memory leaks in probe error path USB: serial: io_edgeport: fix memory leaks in attach error path usb: Remove unnecessary space before operator ','. usb: Remove unnecessary space before open square bracket. USB: FHCI: avoid redundant condition usb: host: xhci-rcar: Avoid long wait in xhci_reset() usb/host/fotg210: remove dead code in create_sysfs_files usb: wusbcore: Do not initialise statics to 0. usb: wusbcore: Remove space before ',' and '(' . USB: serial: cp210x: clean up CRTSCTS flag code USB: serial: cp210x: get rid of magic numbers in CRTSCTS flag code USB: serial: cp210x: fix hardware flow-control disable USB: serial: option: add even more ZTE device ids ...
2016-04-30phy: bcm-ns-usb2: new driver for USB 2.0 PHY on NorthstarRafał Miłecki
Northstar is a family of SoCs used in home routers. They have USB 2.0 and 3.0 controllers with PHYs that need to be properly initialized. This driver provides PHY init support in a generic way and can be bound with an EHCI controller driver. There are (just a few) registers being defined in bcma header. It's because DMU/CRU registers will be also needed in other drivers. We will need them e.g. in PCIe controller/PHY driver and at some point probably in clock driver for BCM53573 chipset. By using include/linux/bcma/ we avoid code duplication. Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
2016-04-30phy: Add support for NS2 SATA3 PHY in Broadcom SATA3 PHY driverAnup Patel
This patch adds support for Broadcom NS2 SATA3 PHY in existing Broadcom SATA3 PHY driver. Signed-off-by: Anup Patel <anup.patel@broadcom.com> Acked-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
2016-04-29phy: Add Tegra XUSB pad controller supportThierry Reding
Add a new driver for the XUSB pad controller found on NVIDIA Tegra SoCs. This hardware block used to be exposed as a pin controller, but it turns out that this isn't a good fit. The new driver and DT binding much more accurately describe the hardware and are more flexible in supporting new SoC generations. Acked-by: Kishon Vijay Abraham I <kishon@ti.com> Signed-off-by: Thierry Reding <treding@nvidia.com>
2016-04-29phy: Rename phy-brcmstb-sata driver to phy-brcm-sata driverAnup Patel
Currently, we have a common SATA3 PHY driver for all Broadcom STB SoCs. This driver can be extended and re-used for Broadcom iProc SoCs having same SATA3 PHY. This patch renames existing Broadcom STB SATA3 PHY driver to common Broadcom SATA3 PHY driver to share this PHY driver across Broadcom SoCs. Signed-off-by: Anup Patel <anup.patel@broadcom.com> Acked-by: Florian Fainelli <f.fainelli@gmail.com> Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
2016-03-01phy: Add driver for rockchip Display Port PHYYakir Yang
Add phy driver for the Rockchip DisplayPort PHY module. This is required to get DisplayPort working in Rockchip SoCs. Signed-off-by: Yakir Yang <ykk@rock-chips.com> Reviewed-by: Heiko Stuebner <heiko@sntech.de> Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
2016-03-01phy: add a driver for the Rockchip SoC internal eMMC PHYShawn Lin
This patch to add a generic PHY driver for ROCKCHIP eMMC PHY. Access the PHY via registers provided by GRF (general register files) module. Signed-off-by: Shawn Lin <shawn.lin@rock-chips.com> Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
2015-12-20phy: add phy-hi6220-usbZhangfei Gao
Support hi6220 use phy for HiKey board Acked-by: Rob Herring <robh@kernel.org> Signed-off-by: Zhangfei Gao <zhangfei.gao@linaro.org> Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
2015-12-20phy: rcar-gen3-usb2: Add R-Car Gen3 USB2 PHY driverYoshihiro Shimoda
This patch adds support for R-Car generation 3 USB2 PHY driver. This SoC has 3 EHCI/OHCI channels, and the channel 0 is shared with the HSUSB (USB2.0 peripheral) device. And each channel has independent registers about the PHYs. So, the purpose of this driver is: 1) initializes some registers of SoC specific to use the {ehci,ohci}-platform driver. 2) detects id pin to select host or peripheral on the channel 0. For now, this driver only supports 1) above. Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Acked-by: Rob Herring <robh@kernel.org> Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
2015-10-06phy: cygnus: pcie: Add Cygnus PCIe PHY supportRay Jui
This patch adds the PCIe PHY support for the Broadcom PCIe RC interface on Cygnus Signed-off-by: Ray Jui <rjui@broadcom.com> Reviewed-by: Arun Parameswaran <aparames@broadcom.com> Reviewed-by: JD (Jiandong) Zheng <jdzheng@broadcom.com> Reviewed-by: Scott Branden <sbranden@broadcom.com> Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
2015-10-06phy: add usb3.0 phy driver for mt65xx SoCsChunfeng Yun
support usb3.0 phy of mt65xx SoCs Signed-off-by: Chunfeng Yun <chunfeng.yun@mediatek.com> Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
2015-07-25phy: add lpc18xx usb otg phy driverJoachim Eastwood
Add PHY driver for the internal USB OTG PHY found on NXP LPC18xx and LPC43xx devices. This driver takes care of enabling the PHY in CREG (syscon) and setting the required clock frequency. Signed-off-by: Joachim Eastwood <manabian@gmail.com> Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
2015-06-27Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS updates from Ralf Baechle: - Improvements to the tlb_dump code - KVM fixes - Add support for appended DTB - Minor improvements to the R12000 support - Minor improvements to the R12000 support - Various platform improvments for BCM47xx - The usual pile of minor cleanups - A number of BPF fixes and improvments - Some improvments to the support for R3000 and DECstations - Some improvments to the ATH79 platform support - A major patchset for the JZ4740 SOC adding support for the CI20 platform - Add support for the Pistachio SOC - Minor BMIPS/BCM63xx platform support improvments. - Avoid "SYNC 0" as memory barrier when unlocking spinlocks - Add support for the XWR-1750 board. - Paul's __cpuinit/__cpuinitdata cleanups. - New Malta CPU board support large memory so enable ZONE_DMA32. * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: (131 commits) MIPS: spinlock: Adjust arch_spin_lock back-off time MIPS: asmmacro: Ensure 64-bit FP registers are used with MSA MIPS: BCM47xx: Simplify handling SPROM revisions MIPS: Cobalt Don't use module_init in non-modular MTD registration. MIPS: BCM47xx: Move NVRAM driver to the drivers/firmware/ MIPS: use for_each_sg() MIPS: BCM47xx: Don't select BCMA_HOST_PCI MIPS: BCM47xx: Add helper variable for storing NVRAM length MIPS: IRQ/IP27: Move IRQ allocation API to platform code. MIPS: Replace smp_mb with release barrier function in unlocks. MIPS: i8259: DT support MIPS: Malta: Basic DT plumbing MIPS: include errno.h for ENODEV in mips-cm.h MIPS: Define GCR_GIC_STATUS register fields MIPS: BPF: Introduce BPF ASM helpers MIPS: BPF: Use BPF register names to describe the ABI MIPS: BPF: Move register definition to the BPF header MIPS: net: BPF: Replace RSIZE with SZREG MIPS: BPF: Free up some callee-saved registers MIPS: Xtalk: Update xwidget.h with known Xtalk device numbers ...
2015-06-21PHY: Add driver for Pistachio USB2.0 PHYAndrew Bresticker
Add a driver for the USB2.0 PHY found on the IMG Pistachio SoC. Signed-off-by: Andrew Bresticker <abrestic@chromium.org> Cc: Kishon Vijay Abraham I <kishon@ti.com> Cc: devicetree@vger.kernel.org Cc: linux-mips@linux-mips.org Cc: linux-kernel@vger.kernel.org Cc: James Hartley <james.hartley@imgtec.com> Cc: Damien Horsley <Damien.Horsley@imgtec.com> Patchwork: https://patchwork.linux-mips.org/patch/9728/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2015-06-09phy: add Marvell HSIC 28nm PHYRob Herring
Add PHY driver for the Marvell HSIC 28nm PHY. This PHY is found in PXA1928 SOC. Signed-off-by: Rob Herring <robh@kernel.org> Cc: Kishon Vijay Abraham I <kishon@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-06-09phy: Add Marvell USB 2.0 OTG 28nm PHYRob Herring
Add driver for USB 28nm PHY found in Marvell PXA1928 SOC. Signed-off-by: Rob Herring <robh@kernel.org> Cc: Kishon Vijay Abraham I <kishon@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-06-03Merge tag 'phy-for-v4.2' of ↵Greg Kroah-Hartman
git://git.kernel.org/pub/scm/linux/kernel/git/kishon/linux-phy into usb-next Kishon writes: phy: for 4.2 merge window *) new Broadcom SATA3 PHY driver for Broadcom STB SoCs *) new phy API to get PHY by index which is used in EHCI and OHCI controller drivers *) support specifying supply at port level used for multi-port PHYs *) sparse warning fixes in miphy PHYs *) fix pm_runtime issues in twl4030 driver Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
2015-05-22phy: add Broadcom SATA3 PHY driver for Broadcom STB SoCsBrian Norris
Supports up to two ports which can each be powered on/off and configured independently. Signed-off-by: Brian Norris <computersforpeace@gmail.com> Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
2015-05-13phy: add driver for TI TUSB1210 ULPI PHYHeikki Krogerus
TUSB1210 ULPI PHY has vendor specific register for eye diagram tuning. On some platforms the system firmware has set optimized value to it. In order to not loose the optimized value, the driver stores it during probe and restores it every time the PHY is powered back on. Signed-off-by: Heikki Krogerus <heikki.krogerus@linux.intel.com> Acked-by: David Cohen <david.a.cohen@linux.intel.com> Acked-by: Kishon Vijay Abraham I <kishon@ti.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2015-04-03phy: Add driver to support individual USB PHYs on sun9iChen-Yu Tsai
Unlike previous Allwinner SoCs, there is no central PHY control block on the A80. Also, OTG support is completely split off into a different controller. This adds a new driver to support the regular USB PHYs. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
2015-04-03phy: Add a driver for dm816x USB PHYTony Lindgren
Add a minimal driver for dm816x USB. This makes USB work on dm816x without any other changes needed as it can use the existing musb_dsps glue layer for the USB controller. Note that this phy is different from dm814x and am335x. Cc: Bin Liu <binmlist@gmail.com> Cc: Brian Hutchinson <b.hutchman@gmail.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Matthijs van Duin <matthijsvanduin@gmail.com> Cc: Paul Bolle <pebolle@tiscali.nl> Cc: Rusty Russell <rusty@rustcorp.com.au> Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
2015-02-15Merge tag 'usb-3.20-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb Pull USB patches from Greg KH: "Here's the big pull request for the USB driver tree for 3.20-rc1. Nothing major happening here, just lots of gadget driver updates, new device ids, and a bunch of cleanups. All of these have been in linux-next for a while with no reported issues" * tag 'usb-3.20-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (299 commits) usb: musb: fix device hotplug behind hub usb: dwc2: Fix a bug in reading the endpoint directions from reg. staging: emxx_udc: fix the build error usb: Retry port status check on resume to work around RH bugs Revert "usb: Reset USB-3 devices on USB-3 link bounce" uhci-hub: use HUB_CHAR_* usb: kconfig: replace PPC_OF with PPC ehci-pci: disable for Intel MID platforms (update) usb: gadget: Kconfig: use bool instead of boolean usb: musb: blackfin: remove incorrect __exit_p() USB: fix use-after-free bug in usb_hcd_unlink_urb() ehci-pci: disable for Intel MID platforms usb: host: pci_quirks: joing string literals USB: add flag for HCDs that can't receive wakeup requests (isp1760-hcd) USB: usbfs: allow URBs to be reaped after disconnection cdc-acm: kill unnecessary messages cdc-acm: add sanity checks usb: phy: phy-generic: Fix USB PHY gpio reset usb: dwc2: fix USB core dependencies usb: renesas_usbhs: fix NULL pointer dereference in dma_release_channel() ...
2015-01-30phy: add a driver for the Rockchip SoC internal USB2.0 PHYYunzhi Li
This patch to add a generic PHY driver for ROCKCHIP usb PHYs, currently this driver can support RK3288. The RK3288 SoC have three independent USB PHY IPs which are all configured through a set of registers located in the GRF (general register files) module. Signed-off-by: Yunzhi Li <lyz@rock-chips.com> Tested-by: Doug Anderson <dianders@chromium.org> Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
2015-01-20phy: qcom-ufs: add support for 14nm phyYaniv Gardi
This change adds a support for a 14nm qcom-ufs phy that is required in platforms that use ufs-qcom controller. Signed-off-by: Yaniv Gardi <ygardi@codeaurora.org> Reviewed-by: Dov Levenglick <dovl@codeaurora.org> Signed-off-by: Christoph Hellwig <hch@lst.de>
2015-01-20phy: qcom-ufs: add support for 20nm phyYaniv Gardi
This change adds a support for a 20nm qcom-ufs phy that is required in platforms that use ufs-qcom controller. Signed-off-by: Yaniv Gardi <ygardi@codeaurora.org> Reviewed-by: Dov Levenglick <dovl@codeaurora.org> Signed-off-by: Christoph Hellwig <hch@lst.de>
2015-01-20phy: qcom-ufs: add support for QUALCOMM Technologies UFS PHY driversYaniv Gardi
This change adds a generic and common API support for ufs phy QUALCOMM Technologies. This support provides common code and also points to specific phy callbacks to differentiate between different behaviors of frequent use-cases (like power on, power off, phy calibration etc). Signed-off-by: Yaniv Gardi <ygardi@codeaurora.org> Reviewed-by: Dov Levenglick <dovl@codeaurora.org> Signed-off-by: Christoph Hellwig <hch@lst.de>
2014-11-26phy: add support for USB cluster on the Armada 375 SoCGregory CLEMENT
The Armada 375 SoC comes with an USB2 host and device controller and an USB3 controller. The USB cluster control register allows to manage common features of both USB controllers. This commit adds a driver integrated in the generic PHY framework to control this USB cluster feature. Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> [ kishon@ti.com : Made it to use the updated devm_phy_create API and soem cosmentic changes in Kconfig file.] Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Acked-by: Jason Cooper <jason@lakedaemon.net>
2014-11-21phy: add the Berlin USB PHY driverAntoine Tenart
Add the driver driving the Marvell Berlin USB PHY. This allows to initialize the PHY and to use it from the USB driver later. Signed-off-by: Antoine Tenart <antoine.tenart@free-electrons.com> Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
2014-11-12phy: miphy28lp: Provide support for the MiPHY28lp Generic PHYGabriel FERNANDEZ
The MiPHY28lp is a Generic PHY which can serve various SATA or PCIe or USB3 devices. Signed-off-by: alexandre torgue <alexandre.torgue@st.com> Signed-off-by: Giuseppe Cavallaro <peppe.cavallaro@st.com> Signed-off-by: Gabriel Fernandez <gabriel.fernandez@linaro.org> Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
2014-09-24phy: phy-stih41x-usb: Add usb phy support for STiH41x SoCs.Peter Griffin
This driver adds support for USB (1.1 and 2.0) phy for STiH415 and STiH416 System-On-Chips from STMicroelectronics. Signed-off-by: Maxime Coquelin <maxime.coquelin@st.com> Signed-off-by: Peter Griffin <peter.griffin@linaro.org> Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
2014-09-24phy: phy-stih407-usb: Add usb picoPHY driver found on stih407 SoC familyPeter Griffin
This is the generic phy driver for the picoPHY ports used by the USB2 and USB3 Host controllers when controlling usb2/1.1 devices. It is found on STiH407 SoC family from STMicroelectronics. Signed-off-by: Giuseppe Cavallaro <peppe.cavallaro@st.com> Signed-off-by: Peter Griffin <peter.griffin@linaro.org> Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
2014-09-24phy: Renesas R-Car Gen2 PHY driverSergei Shtylyov
This PHY, though formally being a part of Renesas USBHS controller, contains the UGCTRL2 register that controls multiplexing of the USB ports (Renesas calls them channels) to the different USB controllers: channel 0 can be connected to either PCI EHCI/OHCI or USBHS controllers, channel 2 can be connected to PCI EHCI/OHCI or xHCI controllers. This is a new driver for this USB PHY currently already supported under drivers/ usb/phy/. The reason for writing the new driver was the requirement that the multiplexing of USB channels to the controller be dynamic, depending on what USB drivers are loaded, rather than static as provided by the old driver. The infrastructure provided by drivers/phy/phy-core.c seems to fit that purpose ideally. The new driver only supports device tree probing for now. Signed-off-by: Sergei Shtylyov <sergei.shtylyov@cogentembedded.com> Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
2014-08-08Merge tag 'drivers-for-3.17' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC driver changes from Olof Johansson: "A handful of driver-related changes. We've had a bunch of them going in through other branches as well, so it's only a part of what we really have this release. Larger pieces are: - Removal of a now unused PWM driver for atmel [ This includes AVR32 changes that have been appropriately acked ] - Performance counter support for the arm CCN interconnect - OMAP mailbox driver cleanups and consolidation - PCI and SATA PHY drivers for SPEAr 13xx platforms - Redefinition (with backwards compatibility!) of PCI DT bindings for Tegra to better model regulators/power" Note: this merge also fixes up the semantic conflict with the new calling convention for devm_phy_create(), see commit f0ed817638b5 ("phy: core: Let node ptr of PHY point to PHY and not of PHY provider") that came in through Greg's USB tree. Semantic merge patch by Stephen Rothwell <sfr@canb.auug.org.au> through the next tree. * tag 'drivers-for-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (38 commits) bus: arm-ccn: Fix error handling at event allocation mailbox/omap: add a parent structure for every IP instance mailbox/omap: remove the private mailbox structure mailbox/omap: consolidate OMAP mailbox driver mailbox/omap: simplify the fifo assignment by using macros mailbox/omap: remove omap_mbox_type_t from mailbox ops mailbox/omap: remove OMAP1 mailbox driver mailbox/omap: use devm_* interfaces bus: ARM CCN: add PERF_EVENTS dependency bus: ARM CCN PMU driver PCI: spear: Remove spear13xx_pcie_remove() PCI: spear: Fix Section mismatch compilation warning for probe() ARM: tegra: Remove legacy PCIe power supply properties PCI: tegra: Remove deprecated power supply properties PCI: tegra: Implement accurate power supply scheme ARM: SPEAr13xx: Update defconfigs ARM: SPEAr13xx: Add pcie and miphy DT nodes ARM: SPEAr13xx: Add bindings and dt node for misc block ARM: SPEAr13xx: Fix static mapping table phy: Add drivers for PCIe and SATA phy on SPEAr13xx ...
2014-08-08Merge tag 'soc-for-3.17' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC platform changes from Olof Johansson: "This is the bulk of new SoC enablement and other platform changes for 3.17: - Samsung S5PV210 has been converted to DT and multiplatform - Clock drivers and bindings for some of the lower-end i.MX 1/2 platforms - Kirkwood, one of the popular Marvell platforms, is folded into the mvebu platform code, removing mach-kirkwood - Hwmod data for TI AM43xx and DRA7 platforms - More additions of Renesas shmobile platform support - Removal of plat-samsung contents that can be removed with S5PV210 being multiplatform/DT-enabled and the other two old platforms being removed New platforms (most with only basic support right now): - Hisilicon X5HD2 settop box chipset is introduced - Mediatek MT6589 (mobile chipset) is introduced - Broadcom BCM7xxx settop box chipset is introduced + as usual a lot other pieces all over the platform code" * tag 'soc-for-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (240 commits) ARM: hisi: remove smp from machine descriptor power: reset: move hisilicon reboot code ARM: dts: Add hix5hd2-dkb dts file. ARM: debug: Rename Hi3716 to HIX5HD2 ARM: hisi: enable hix5hd2 SoC ARM: hisi: add ARCH_HISI MAINTAINERS: add entry for Broadcom ARM STB architecture ARM: brcmstb: select GISB arbiter and interrupt drivers ARM: brcmstb: add infrastructure for ARM-based Broadcom STB SoCs ARM: configs: enable SMP in bcm_defconfig ARM: add SMP support for Broadcom mobile SoCs Documentation: arm: misc updates to Marvell EBU SoC status Documentation: arm: add URLs to public datasheets for the Marvell Armada XP SoC ARM: mvebu: fix build without platforms selected ARM: mvebu: add cpuidle support for Armada 38x ARM: mvebu: add cpuidle support for Armada 370 cpuidle: mvebu: add Armada 38x support cpuidle: mvebu: add Armada 370 support cpuidle: mvebu: rename the driver from armada-370-xp to mvebu-v7 ARM: mvebu: export the SCU address ...
2014-07-22phy: miphy365x: Provide support for the MiPHY356x Generic PHYLee Jones
The MiPHY365x is a Generic PHY which can serve various SATA or PCIe devices. It has 2 ports which it can use for either; both SATA, both PCIe or one of each in any configuration. Acked-by: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Alexandre Torgue <alexandre.torgue@st.com> Signed-off-by: Lee Jones <lee.jones@linaro.org> Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
2014-07-22phy: qcom: Add driver for QCOM IPQ806x SATA PHYKumar Gala
Add a PHY driver for uses with AHCI based SATA controller driver on the IPQ806x family of SoCs. Signed-off-by: Kumar Gala <galak@codeaurora.org> Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
2014-07-22phy: add a driver for the Berlin SATA PHYAntoine Ténart
The Berlin SoC has a two SATA ports. Add a PHY driver to handle them. The mode selection can let us think this PHY can be configured to fit other purposes. But there are reasons to think the SATA mode will be the only one usable: the PHY registers are only accessible indirectly through two registers in the SATA range, the PHY seems to be integrated and no information tells us the contrary. For these reasons, make the driver a SATA PHY driver. Signed-off-by: Antoine Ténart <antoine.tenart@free-electrons.com> Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
2014-07-22phy: qcom: Add driver for QCOM APQ8064 SATA PHYSrinivas Kandagatla
Add a PHY driver for uses with AHCI based SATA controller driver on the APQ8064 family of SoCs. This patch is a forward port from Qualcomm's v3.4 andriod kernel. Tested on IFC6410 board. CC: Sujit Reddy Thumma <sthumma@codeaurora.org> Tested-by: Kiran Padwal <kiran.padwal@smartplayin.com> Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@linaro.org> Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
2014-07-22phy: add hix5hd2-sata-phy driverJiancheng Xue
Add hix5hd2-sata-phy driver on Hisilicon hix5hd2 soc. Signed-off-by: Jiancheng Xue <xuejiancheng@huawei.com> Signed-off-by: Zhangfei Gao <zhangfei.gao@linaro.org> Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
2014-07-19phy: Add support for S5PV210 to the Exynos USB 2.0 PHY driverMateusz Krawczuk
Add support for the Samsung's S5PV210 SoC to the Exynos USB 2.0 PHY driver. Signed-off-by: Mateusz Krawczuk <m.krawczuk@partner.samsung.com> [k.debski@samsung.com: cleanup and commit description] [k.debski@samsung.com: make changes accordingly to the mailing list comments] Signed-off-by: Kamil Debski <k.debski@samsung.com> Signed-off-by: Tomasz Figa <t.figa@samsung.com> Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2014-07-14phy: Add drivers for PCIe and SATA phy on SPEAr13xxPratyush Anand
ARM based ST Microelectronics's SPEAr1310/40 platforms uses ST's phy (known as 'miphy') for PCIe and SATA. This patch adds drivers for these miphys. This also adds proper bindings for miphys. Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Pratyush Anand <pratyush.anand@st.com> Tested-by: Mohit Kumar <mohit.kumar@st.com> Cc: Kishon Vijay Abraham I <kishon@ti.com> [viresh: fixed logs/cclist/checkpatch warnings, broken into smaller patches] Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
2014-05-13phy: Add new Exynos5 USB 3.0 PHY driverVivek Gautam
Add a new driver for the USB 3.0 PHY on Exynos5 series of SoCs. The new driver uses the generic PHY framework and will interact with DWC3 controller present on Exynos5 series of SoCs. Also, created a new header file in linux/mfd/syscon/ for Exynos5 SoCs and put the required PMU offset definitions for the basic available PHYs. Signed-off-by: Vivek Gautam <gautam.vivek@samsung.com> Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
2014-04-24phy: exynos: fix building as a moduleArnd Bergmann
The top-level phy-samsung-usb2 driver may be configured as a loadable module, which currently causes link errors because of the dependency on the exynos{5250,4x12,4210}_usb2_phy_config symbol. Solving this could be achieved by exporting these symbols, but as the SoC-specific parts of the driver are not currently built as modules, it seems better to just link everything into one module and avoid the need for the export. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Kamil Debski <k.debski@samsung.com> Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
