DM816x PHY uses usb_phy_* methods and because
of that, it must select USB_PHY, however, because
the drivers in question (DM816x, TWL4030 and
OMAP_USB2) sit outside of drivers/usb/ directory,
meaning they can be built even if USB_SUPPORT=n.
This patches fixes the dependencies by adding
USB_SUPPORT as a dependency and making all drivers
select USB_PHY (which cannot be selected through
menuconfig).
Note that this fixes some linking breakages when
building with randconfig.
Cc: Tony Lindgren <tony@atomide.com>
Cc: Kishon Vijay Abraham I <kishon@ti.com>
Signed-off-by: Felipe Balbi <balbi@ti.com>
Signed-off-by: Kishon Vijay Abraham I <kishon@ti.com>
This phy only exists on platforms under ARCH_QCOM, not ARCH_MSM.
Cc: Yaniv Gardi <ygardi@codeaurora.org>
Cc: Dov Levenglick <dovl@codeaurora.org>
Cc: David Brown <davidb@codeaurora.org>
Cc: Bryan Huntsman <bryanh@codeaurora.org>
Cc: Daniel Walker <dwalker@fifo99.com>
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
Reviewed-by: Yaniv Gardi <ygardi@codeaurora.org>
This is a common checking in various drivers, so move the checking to
_of_phy_get().
Signed-off-by: Axel Lin <axel.lin@ingics.com>
Add missing 'static' modifier so sparse
won't complain anymore.
Acked-by: Maxime Coquelin <maxime.coquelin@st.com>
Add missing __iomem annotation to the base address
so Sparse doesn't complain.
Multi-port phys may have per port power supplies. Let's change phy
core to look for supply at the port level when multiple ports are
specified. To keep compatibility with the existing device tree board
descriptions for single-port phys we will continue looking up the
power supply at the parent node level
Signed-off-by: Dmitry Torokhov <dtor@chromium.org>
Signed-off-by: Arun Ramamurthy <arun.ramamurthy@broadcom.com>
Reviewed-by: Ray Jui <rjui@broadcom.com>
Reviewed-by: Scott Branden <sbranden@broadcom.com>
Some generic drivers, such as ehci, may use multiple phys and for such
drivers referencing phy(s) by name(s) does not make sense. Instead of
inventing new naming schemes and using custom code to iterate through them,
such drivers are better of using nameless phy bindings and using this newly
introduced API to iterate through them.
[kishon@ti.com: fix compilation errors]
Don't pass valid pointer to PTR_ERR, use PTR_ERR(phy) only when
IS_ERR(phy) is true.
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB driver updates from Greg KH:
"Here's the big USB (and PHY) driver patchset for 4.1-rc1.
Everything here has been in linux-next, and the full details are below
in the shortlog. Nothing major, just the normal round of new
drivers,api updates, and other changes, mostly in the USB gadget area,
as usual"
* tag 'usb-4.1-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (252 commits)
drivers/usb/core: devio.c: Removed an uneeded space before tab
usb: dwc2: host: sleep USB_RESUME_TIMEOUT during resume
usb: chipidea: debug: add low power mode check before print registers
usb: chipidea: udc: bypass pullup DP when gadget connect in OTG fsm mode
usb: core: hub: use new USB_RESUME_TIMEOUT
usb: isp1760: hcd: use new USB_RESUME_TIMEOUT
usb: dwc2: hcd: use new USB_RESUME_TIMEOUT
usb: host: sl811: use new USB_RESUME_TIMEOUT
usb: host: r8a66597: use new USB_RESUME_TIMEOUT
usb: host: oxu210hp: use new USB_RESUME_TIMEOUT
usb: host: fusbh200: use new USB_RESUME_TIMEOUT
usb: host: fotg210: use new USB_RESUME_TIMEOUT
usb: host: isp116x: use new USB_RESUME_TIMEOUT
usb: musb: use new USB_RESUME_TIMEOUT
usb: host: uhci: use new USB_RESUME_TIMEOUT
usb: host: ehci: use new USB_RESUME_TIMEOUT
usb: host: xhci: use new USB_RESUME_TIMEOUT
usb: define a generic USB_RESUME_TIMEOUT macro
usb: musb: dsps: fix build on i386 when COMPILE_TEST is set
ehci-hub: use USB_DT_HUB
'regulator/topic/notifier', 'regulator/topic/palmas', 'regulator/topic/qcom' and 'regulator/topic/stw481x' into regulator-next
git://git.kernel.org/pub/scm/linux/kernel/git/kishon/linux-phy into usb-next
Kishon writes:
New Features
*) Add driver for USB PHYs on sun9i
*) Add driver for USB PHY on dm816x
*) Modified exynos5-usbdrd driver to add support for Exynos5433 SoC
Fixes
*) Fix power_on/power_off failure paths in some drivers
*) Make miphy365x use generic PHY type constants
*) Fix build errors due to missing export symbols in qcom-ufs driver
*) Make all the functions return proper error values
Cleanups
*) use PTR_ERR_OR_ZERO to simplify code
*) use devm_kcalloc instead of devm_kzalloc with multiply
*) remove un-necessary ifdef CONFIG_OF
The of_xlate callback should return ERR_PTR on error.
Now there are generic phy type constants declared in phy.h, migrate over to
using them rather than defining our own. This change has been done as one
atomic commit to be bisectable.
Note: The values of the defines are the same, so there is no ABI breakage
with this patch.
Signed-off-by: Peter Griffin <peter.griffin@linaro.org>
Acked-by: Rob Herring <robh@kernel.org>
Acked-by: Lee Jones <lee.jones@linaro.org>
Unlike previous Allwinner SoCs, there is no central PHY control block
on the A80. Also, OTG support is completely split off into a different
controller.
This adds a new driver to support the regular USB PHYs.
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Add a minimal driver for dm816x USB. This makes USB work on dm816x
without any other changes needed as it can use the existing musb_dsps
glue layer for the USB controller.
Note that this phy is different from dm814x and am335x.
Cc: Bin Liu <binmlist@gmail.com>
Cc: Brian Hutchinson <b.hutchman@gmail.com>
Cc: Felipe Balbi <balbi@ti.com>
Cc: Matthijs van Duin <matthijsvanduin@gmail.com>
Cc: Paul Bolle <pebolle@tiscali.nl>
"dev_ref_clk_ctrl_mem" is optional resource, so don't return error if fail to
get the resource. Since it's an optional resource, don't emit error if
fail to get dev_ref_clk_ctrl_mem.
Also remove redundant test for res, it's done by devm_ioremap_resource().
Fix below build error when compile the driver as a module.
ERROR: "ufs_qcom_phy_power_off" [drivers/phy/phy-qcom-ufs-qmp-20nm.ko] undefined!
ERROR: "ufs_qcom_phy_power_on" [drivers/phy/phy-qcom-ufs-qmp-20nm.ko] undefined!
ERROR: "ufs_qcom_phy_exit" [drivers/phy/phy-qcom-ufs-qmp-20nm.ko] undefined!
ERROR: "ufs_qcom_phy_calibrate" [drivers/phy/phy-qcom-ufs-qmp-20nm.ko] undefined!
ERROR: "ufs_qcom_phy_generic_probe" [drivers/phy/phy-qcom-ufs-qmp-20nm.ko] undefined!
ERROR: "ufs_qcom_phy_init_vregulators" [drivers/phy/phy-qcom-ufs-qmp-20nm.ko] undefined!
ERROR: "ufs_qcom_phy_init_clks" [drivers/phy/phy-qcom-ufs-qmp-20nm.ko] undefined!
ERROR: "ufs_qcom_phy_remove" [drivers/phy/phy-qcom-ufs-qmp-20nm.ko] undefined!
ERROR: "get_ufs_qcom_phy" [drivers/phy/phy-qcom-ufs-qmp-20nm.ko] undefined!
ERROR: "ufs_qcom_phy_power_off" [drivers/phy/phy-qcom-ufs-qmp-14nm.ko] undefined!
ERROR: "ufs_qcom_phy_power_on" [drivers/phy/phy-qcom-ufs-qmp-14nm.ko] undefined!
ERROR: "ufs_qcom_phy_exit" [drivers/phy/phy-qcom-ufs-qmp-14nm.ko] undefined!
ERROR: "ufs_qcom_phy_generic_probe" [drivers/phy/phy-qcom-ufs-qmp-14nm.ko] undefined!
ERROR: "ufs_qcom_phy_init_vregulators" [drivers/phy/phy-qcom-ufs-qmp-14nm.ko] undefined!
ERROR: "ufs_qcom_phy_init_clks" [drivers/phy/phy-qcom-ufs-qmp-14nm.ko] undefined!
ERROR: "ufs_qcom_phy_calibrate" [drivers/phy/phy-qcom-ufs-qmp-14nm.ko] undefined!
ERROR: "ufs_qcom_phy_remove" [drivers/phy/phy-qcom-ufs-qmp-14nm.ko] undefined!
ERROR: "get_ufs_qcom_phy" [drivers/phy/phy-qcom-ufs-qmp-14nm.ko] undefined!
make[1]: *** [__modpost] Error 1
make: *** [modules] Error 2
Ensure we have balanced clk_prepare_enable/clk_disable_unprepare calls if
.power_on or .power_off callbacks return error.
This patch adds driver data to support for Exynos5433 SoC.
The Exynos5433 has one USB3.0 Host and USB3.0 DRD(Dual Role Device).
Exynos5433 is simplar to Eyxnos7 but Exynos5433 have
one more USB3.0 Host controller.
Signed-off-by: Jaewon Kim <jaewon02.kim@samsung.com>
Current code does NULL test against return value of ufs_qcom_phy_generic_probe.
However, in the case of devm_phy_create() failure, ufs_qcom_phy_generic_probe
does not return NULL. Fix it.
If stih41x_usb_phy_power_on() fails, we need to call clk_disable_unprepare()
before return error. This is to ensure we have balanced clk_enable/disable
calls.
Acked-by: Patrice Chotard <patrice.chotard@st.com>
Current code does not call clk_prepare(phy->optclk) when using the old
usb_otg_ss_refclk960m name. Fix it.
Remove extra space in MODULE_ALIAS.
Acked-by: Roger Quadros <rogerq@ti.com>
When phy_pm_runtime_get_sync() returns -ENOTSUPP, phy_exit() also returns
-ENOTSUPP if !phy->ops->exit. Fix it.
Also move the code to override ret close to the code we got ret.
I think it is less error prone this way.
Prefer devm_kcalloc over devm_kzalloc with multiply.
In additional, use sizeof(phy) is incorrect, fix it.
Acked-by: Gabriel Fernandez<gabriel.fernandez@linaro.org>
It's pointless to set twl->linkstat twice.
Current code uses args->args[0] as array subscript of phy_drd->phys[].
So the valid value range for args->args[0] is 0 ... EXYNOS5_DRDPHYS_NUM - 1.
Reviewed by: Vivek Gautam <gautam.vivek@samsung.com>
devm_phy_create() stores the pointer to the new PHY at the address
returned by devres_alloc(). The res parameter passed to devm_phy_match()
is therefore the location where the pointer to the PHY is stored, hence
it needs to be dereferenced before comparing to the match data in order
to find the correct match.
Cc: <stable@vger.kernel.org> # v3.13+
Signed-off-by: Thierry Reding <treding@nvidia.com>
If rockchip_usb_phy_power() fails, we need to call clk_disable_unprepare()
before return. This is to ensure we have balanced clk_enable/disable calls.
Also remove unneeded ret checking in rockchip_usb_phy_power_off.
Code simplification. No functional change.
Current code uses num_phys settings to tell the number of entries in phys.
Thus remove the NULL terminating entry from phys array which is not necessary.
This prevent NULL pointer dereference if res is NULL.
Acked-by: Zhangfei Gao <zhangfei.gao@linaro.org>
If IS_ERR(state->regs) the .probe fails.
So IS_ERR(state->regs) test in exynos_dp_video_phy_pwr_isol() is not necessary.
exynos_dp_video_phy_pwr_isol() simply does a regmap_update_bits() call now,
just call regmap_update_bits() instead and return proper return value.
Reviewed-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
The state->regmap is initialized by devm_regmap_init_mmio().
So it's fine to use spin_lock rather than mutex to protct state->regmap rmw
operations.
Acked-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
Tested-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
[Julia.Lawall@lip6.fr: Found an issue with the original patch w.r.t unbalanced
spin_lock call]
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
At the context where we have pointer to struct phy, it's useful to call
phy_get_drvdata() to get the address of priv. With this change, we can
remove the to_phy_berlin_usb_priv() macro and remove *phy from struct
phy_berlin_usb_priv.
Signed-off-by: Mark Brown <broonie@kernel.org>
if !CONFIG_OF, the probe fails.
This is a dt-only driver, so the ifdef CONFIG_OF guard and of_match_ptr are
not needed.
not needed.
not needed.
PTR_ERR_OR_ZERO simplifies the code.
Also remove unneeded goto and rc variable.
syscon_regmap_lookup_by_phandle() returns ERR_PTR on error.
Thus don't use null test against state->regmap.
Add missing .owner field in miphy28lp_ops, which is used for refcounting.
Set it once is enough and it's done after devm_kzalloc().
At the context we have pointer to struct phy, it's useful to call
phy_get_drvdata() to get the address of cluster_phy. This has slightly
better readability than calling dev_get_drvdata(phy->dev.parent).
Currently, of_get_child_count() is called in each iteration of the for loop in
miphy365x_xlate(). This patch stores the return value of of_get_child_count()
in miphy_dev->nphys and call of_get_child_count() once in miphy365x_probe().
