path: root/drivers/pinctrl/mediatek
2016-09-13pinctrl: mediatek: constify gpio_chip structuresJulia Lawall
These structures are only used to copy into other structures, so declare them as const. The semantic patch that makes this change is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r disable optional_qualifier@ identifier i; position p; @@ static struct gpio_chip i@p = { ... }; @ok@ identifier r.i; expression e; position p; @@ e = i@p; @bad@ position p != {r.p,ok.p}; identifier r.i; struct gpio_chip e; @@ e@i@p @depends on !bad disable optional_qualifier@ identifier r.i; @@ static +const struct gpio_chip i = { ... }; // </smpl> Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2016-08-27pinctrl: mediatek: make mtk-common explicitly non-modularPaul Gortmaker
The Makefile currently controlling compilation of this code is: drivers/pinctrl/mediatek/pinctrl-mtk-common.o ---> drivers/pinctrl/mediatek/Makefile:obj-y += pinctrl-mtk-common.o ...meaning that it currently is not being built as a module by anyone. Lets remove the couple traces of modular infrastructure use, so that when reading the driver there is no doubt it is builtin-only. We delete the MODULE_LICENSE tag etc. since all that information is already contained at the top of the file in the comments. We don't replace module.h with init.h since the file doesn't need that. Cc: Linus Walleij <linus.walleij@linaro.org> Cc: Hongzhou Yang <hongzhou.yang@mediatek.com> Cc: linux-gpio@vger.kernel.org Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2016-07-28Merge tag 'pinctrl-v4.8-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl Pull pin control updates from Linus Walleij: "This is the bulk of pin control changes for the v4.8 kernel cycle. Nothing stands out as especially exiting: new drivers, new subdrivers, lots of cleanups and incremental features. Business as usual. New drivers: - New driver for Oxnas pin control and GPIO. This ARM-based chipset is used in a few storage (NAS) type devices. - New driver for the MAX77620/MAX20024 pin controller portions. - New driver for the Intel Merrifield pin controller. New subdrivers: - New subdriver for the Qualcomm MDM9615 - New subdriver for the STM32F746 MCU - New subdriver for the Broadcom NSP SoC. Cleanups: - Demodularization of bool compiled-in drivers. Apart from this there is just regular incremental improvements to a lot of drivers, especially Uniphier and PFC" * tag 'pinctrl-v4.8-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl: (131 commits) pinctrl: fix pincontrol definition for marvell pinctrl: xway: fix typo Revert "pinctrl: amd: make it explicitly non-modular" pinctrl: iproc: Add NSP and Stingray GPIO support pinctrl: Update iProc GPIO DT bindings pinctrl: bcm: add OF dependencies pinctrl: ns2: remove redundant dev_err call in ns2_pinmux_probe() pinctrl: Add STM32F746 MCU support pinctrl: intel: Protect set wake flow by spin lock pinctrl: nsp: remove redundant dev_err call in nsp_pinmux_probe() pinctrl: uniphier: add Ethernet pin-mux settings sh-pfc: Use PTR_ERR_OR_ZERO() to simplify the code pinctrl: ns2: fix return value check in ns2_pinmux_probe() pinctrl: qcom: update DT bindings with ebi2 groups pinctrl: qcom: establish proper EBI2 pin groups pinctrl: imx21: Remove the MODULE_DEVICE_TABLE() macro Documentation: dt: Add new compatible to STM32 pinctrl driver bindings includes: dt-bindings: Add STM32F746 pinctrl DT bindings pinctrl: sunxi: fix nand0 function name for sun8i pinctrl: uniphier: remove pointless pin-mux settings for PH1-LD11 ...
2016-06-08pinctrl: mediatek: fix suspend/resume timing issuehongkun.cao
An irq which is a wake up source maybe masked unexpectedly if the wake up source irq was triggered after pinctrl irqchip suspend and before suspend_device_irqs finished. Use *_noirq callbacks to guarantee pinctrl irqchip suspend would be called after suspend_devices_irqs. Signed-off-by: hongkun.cao <hongkun.cao@mediatek.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2016-05-31pinctrl: mediatek: fix dual-edge code defecthongkun.cao
When a dual-edge irq is triggered, an incorrect irq will be reported on condition that the external signal is not stable and this incorrect irq has been registered. Correct the register offset. Cc: stable@vger.kernel.org Signed-off-by: Hongkun Cao <hongkun.cao@mediatek.com> Reviewed-by: Matthias Brugger <matthias.bgg@gmail.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2016-05-19Merge tag 'pinctrl-v4.7-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl Pull pin control updates from Linus Walleij: "This kernel cycle was quite calm when it comes to pin control and there is really just one major change, and that is the introduction of devm_pinctrl_register() managed resources. Apart from that linear development, details below. Core changes: - Add the devm_pinctrl_register() API and switch all applicable drivers to use it, saving lots of lines of code all over the place. New drivers: - driver for the Broadcom NS2 SoC - subdriver for the PXA25x SoCs - subdriver for the AMLogic Meson GXBB SoC Driver improvements: - the Intel Baytrail driver now properly supports pin control - Nomadik, Rockchip, Broadcom BCM2835 support the .get_direction() callback in the GPIO portions - continued development and stabilization of several SH-PFC SoC subdrivers: r8a7795, r8a7790, r8a7794 etc" * tag 'pinctrl-v4.7-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl: (85 commits) Revert "pinctrl: tegra: avoid parked_reg and parked_bank" pinctrl: meson: Fix eth_tx_en bit index pinctrl: tegra: avoid parked_reg and parked_bank pinctrl: tegra: Correctly check the supported configuration pinctrl: amlogic: Add support for Amlogic Meson GXBB SoC pinctrl: rockchip: fix pull setting error for rk3399 pinctrl: stm32: Implement .pin_config_dbg_show() pinctrl: nomadik: hide nmk_gpio_get_mode when unused pinctrl: ns2: rename pinctrl_utils_dt_free_map pinctrl: at91: Merge clk_prepare and clk_enable into clk_prepare_enable pinctrl: at91: Make at91_gpio_template const pinctrl: baytrail: fix some error handling in debugfs pinctrl: ns2: add pinmux driver support for Broadcom NS2 SoC pinctrl: sirf/atlas7: trivial fix of spelling mistake on flagged pinctrl: sh-pfc: Kill unused variable in sh_pfc_remove() pinctrl: nomadik: implement .get_direction() pinctrl: nomadik: use BIT() with offsets consequently pinctrl: exynos5440: Use off-stack memory for pinctrl_gpio_range pinctrl: zynq: Use devm_pinctrl_register() for pinctrl registration pinctrl: u300: Use devm_pinctrl_register() for pinctrl registration ...
2016-04-21pinctrl: mtk-common: Use devm_pinctrl_register() for pinctrl registrationLaxman Dewangan
Use devm_pinctrl_register() for pin control registration and clean the error path. Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Cc: Matthias Brugger <matthias.bgg@gmail.com> Cc: Hongzhou Yang <hongzhou.yang@mediatek.com> Cc: Yingjoe Chen <yingjoe.chen@mediatek.com> Reviewed-by: Matthias Brugger <matthias.bgg@gmail.com> Acked-by: Hongzhou Yang <hongzhou.yang@mediatek.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2016-04-15pinctrl: mediatek: correct debounce time unit in mtk_gpio_set_debounceYingjoe Chen
The debounce time unit for gpio_chip.set_debounce is us but mtk_gpio_set_debounce regard it as ms. Fix this by correct debounce time array dbnc_arr so it can find correct debounce setting. Debounce time for first debounce setting is 500us, correct this as well. While I'm at it, also change the debounce time array name to "debounce_time" for readability. Cc: stable@vger.kernel.org Signed-off-by: Yingjoe Chen <yingjoe.chen@mediatek.com> Reviewed-by: Daniel Kurtz <djkurtz@chromium.org> Acked-by: Hongzhou Yang <hongzhou.yang@mediatek.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2016-04-01pinctrl: Rename pinctrl_utils_dt_free_map to pinctrl_utils_free_mapIrina Tirdea
Rename pinctrl_utils_dt_free_map to pinctrl_utils_free_map, since it does not depend on device tree despite the current name. This will enforce a consistent naming in pinctr-utils.c and will make it clear it can be called from outside device tree (e.g. from ACPI handling code). Signed-off-by: Irina Tirdea <irina.tirdea@intel.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2016-03-10Merge tag 'v4.5-rc5' into develLinus Walleij
Linux 4.5-rc5
2016-03-09pinctrl: pinctrl-mt6397 driver explicitly non-modularPaul Gortmaker
The Kconfig for this driver is currently: config PINCTRL_MT6397 bool "Mediatek MT6397 pin control" if COMPILE_TEST && !MFD_MT6397 ...meaning that it is currently not being built as a module by anyone. Lets remove the modular code that is essentially orphaned, so that when reading the driver there is no doubt it is builtin-only. Since module_init translates to device_initcall in the non-modular case, the init ordering remains unchanged with this commit. We also delete the MODULE_LICENSE tag etc. since all that information is already contained at the top of the file in the comments. Also note that MODULE_DEVICE_TABLE is a no-op for non-modular code. Cc: Matthias Brugger <matthias.bgg@gmail.com> Cc: linux-gpio@vger.kernel.org Cc: linux-mediatek@lists.infradead.org Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Acked-by: Hongzhou Yang <hongzhou.yang@mediatek.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2016-02-25pinctrl: mediatek/7623: delete unnecessary .ownerLinus Walleij
This is set by the device core. Cc: John Crispin <blogic@openwrt.org> Reported-by: kbuild test robot <fengguang.wu@intel.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2016-02-19pinctrl: mediatek: Add Pinctrl/GPIO/EINT driver for MT7623John Crispin
Add the driver and header files required to make pinctrl work on MediaTek MT7623. Signed-off-by: John Crispin <blogic@openwrt.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2016-02-19pinctrl: mediatek: add input-enable and direction setting for eint resourcesBiao Huang
To use pin as eint, user should make sure that: 1. pin is set to right mode, this is done in .irq_request_resources implementation already. 2. direction of the pin is input, which should call GPIO API to set pin to input gpio. We add what step 2 do to .irq_request_resources so that user doesn't need call GPIO API any more when pin for eint usage. Signed-off-by: Biao Huang <biao.huang@mediatek.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2016-02-19pinctrl: mediatek: add input-enable setting in gpio_request_enableBiao Huang
Since input-disable cuts off input signal of gpio, add input-enable setting in .gpio_request_enable implementation to ensure gpio function well Signed-off-by: Biao Huang <biao.huang@mediatek.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2016-02-17pinctrl: mtk2701: skip setting .ownerLinus Walleij
The device core will handle this and Coccinelle complains. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2016-02-16pinctrl: mediatek: fix handling return value of mtk_pmx_find_gpio_modeAndrzej Hajda
The function can return negative values, so its result should be assigned to signed variable. The problem has been detected using coccinelle semantic patch scripts/coccinelle/tests/assign_signed_to_unsigned.cocci. Fixes: 59ee9c9 ('pinctrl: mediatek: Add gpio_request_enable support') Signed-off-by: Andrzej Hajda <a.hajda@samsung.com> Acked-by: Hongzhou Yang <hongzhou.yang@mediatek.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2016-02-13pinctrl: mediatek: guard sub-directory with CONFIG_PINCTRL_MTKMasahiro Yamada
CONFIG_PINCTRL_MTK is more suitable than CONFIG_ARCH_MEDIATEK to guard the drivers/pinctrl/mediatek/ directory. (I renamed CONFIG_PINCTRL_MTK_COMMON to CONFIG_PINCTRL_MTK.) This allows COMPILE_TEST to descend into drivers/pinctrl/mediatek without CONFIG_ARCH_MEDIATEK define. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2016-02-09Merge branch 'devel-mt2701' into develLinus Walleij
2016-02-05pinctrl: mediatek: Add gpio_request_enable supportBiao Huang
Implement the .gpio_request_enable() callbacks in struct pinmux_ops in mediatek pinctrl driver. Make sure that when gpio_request is called, GPIO on the pin is enabled. Signed-off-by: Biao Huang <biao.huang@mediatek.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2016-02-05pinctrl: mediatek: fix direction control issueBiao Huang
Since input-enable/disable and input-schmitt-enable/disable are workable when gpio direction is input, so add direction setting when do input-enable/disable and input-schmitt-enable/disable properties. Signed-off-by: Biao Huang <biao.huang@mediatek.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2016-01-28pinctrl: mediatek: Add Pinctrl/GPIO/EINT driver for mt2701Biao Huang
Add mt2701 support using mediatek common pinctrl driver. MT2701 have some special pins need an extra setting register than other ICs, so adding this support to common code. Signed-off-by: Biao Huang <biao.huang@mediatek.com> Acked-by: Yingjoe Chen <yingjoe.chen@mediatek.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2016-01-27pinctrl: mediatek: mt8* make driver explicitly non-modularPaul Gortmaker
The Kconfig for these drivers are currently: config PINCTRL_MT8127 bool "Mediatek MT8127 pin control" if COMPILE_TEST && !MACH_MT8127 config PINCTRL_MT8135 bool "Mediatek MT8135 pin control" if COMPILE_TEST && !MACH_MT8135 config PINCTRL_MT8173 bool "Mediatek MT8173 pin control" ...meaning that they are currently not being built as a module by anyone. Lets remove the modular code that is essentially orphaned, so that when reading the driver there is no doubt it is builtin-only. A recent commit moved these from module_init to arch_initcall already, so the init ordering remains untouched with this commit. We also delete the MODULE_LICENSE tag etc. since all that information is already contained at the top of the file in the comments. Also note that MODULE_DEVICE_TABLE is a no-op for non-modular code. Cc: Daniel Kurtz <djkurtz@chromium.org> Cc: Matthias Brugger <matthias.bgg@gmail.com> Cc: Hongzhou Yang <hongzhou.yang@mediatek.com> Cc: Yingjoe Chen <yingjoe.chen@mediatek.com> Cc: linux-gpio@vger.kernel.org Cc: linux-mediatek@lists.infradead.org Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2016-01-17Merge tag 'gpio-v4.5-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio Pull GPIO updates from Linus Walleij: "Here is the bulk of GPIO changes for v4.5. Notably there are big refactorings mostly by myself, aimed at getting the gpio_chip into a shape that makes me believe I can proceed to preserve state for a proper userspace ABI (character device) that has already been proposed once, but resulted in the feedback that I need to go back and restructure stuff. So I've been restructuring stuff. On the way I ran into brokenness (return code from the get_value() callback) and had to fix it. Also, refactored generic GPIO to be simpler. Some of that is still waiting to trickle down from the subsystems all over the kernel that provide random gpio_chips, I've touched every single GPIO driver in the kernel now, oh man I didn't know I was responsible for so much... Apart from that we're churning along as usual. I took some effort to test and retest so it should merge nicely and we shook out a couple of bugs in -next. Infrastructural changes: - In struct gpio_chip, rename the .dev node to .parent to better reflect the fact that this is not the GPIO struct device abstraction. We will add that soon so this would be totallt confusing. - It was noted that the driver .get_value() callbacks was sometimes reporting negative -ERR values to the gpiolib core, expecting them to be propagated to consumer gpiod_get_value() and gpio_get_value() calls. This was not happening, so as there was a mess of drivers returning negative errors and some returning "anything else than zero" to indicate that a line was active. As some would have bit 31 set to indicate "line active" it clashed with negative error codes. This is fixed by the largeish series clamping values in all drivers with !!value to [0,1] and then augmenting the code to propagate error codes to consumers. (Includes some ACKed patches in other subsystems.) - Add a void *data pointer to struct gpio_chip. The container_of() design pattern is indeed very nice, but we want to reform the struct gpio_chip to be a non-volative, stateless business, and keep states internal to the gpiolib to be able to hold on to the state when adding a proper userspace ABI (character device) further down the road. To achieve this, drivers need a handle at the internal state that is not dependent on their struct gpio_chip() so we add gpiochip_add_data() and gpiochip_get_data() following the pattern of many other subsystems. All the "use gpiochip data pointer" patches transforms drivers to this scheme. - The Generic GPIO chip header has been merged into the general <linux/gpio/driver.h> header, and the custom header for that removed. Instead of having a separate mm_gpio_chip struct for these generic drivers, merge that into struct gpio_chip, simplifying the code and removing the need for separate and confusing includes. Misc improvements: - Stabilize the way GPIOs are looked up from the ACPI legacy specification. - Incremental driver features for PXA, PCA953X, Lantiq (patches from the OpenWRT community), RCAR, Zynq, PL061, 104-idi-48 New drivers: - Add a GPIO chip to the ALSA SoC AC97 driver. - Add a new Broadcom NSP SoC driver (this lands in the pinctrl dir, but the branch is merged here too to account for infrastructural changes). - The sx150x driver now supports the sx1502" * tag 'gpio-v4.5-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (220 commits) gpio: generic: make bgpio_pdata always visible gpiolib: fix chip order in gpio list gpio: mpc8xxx: Do not use gpiochip_get_data() in mpc8xxx_gpio_save_regs() gpio: mm-lantiq: Do not use gpiochip_get_data() in ltq_mm_save_regs() gpio: brcmstb: Allow building driver for BMIPS_GENERIC gpio: brcmstb: Set endian flags for big-endian MIPS gpio: moxart: fix build regression gpio: xilinx: Do not use gpiochip_get_data() in xgpio_save_regs() leds: pca9532: use gpiochip data pointer leds: tca6507: use gpiochip data pointer hid: cp2112: use gpiochip data pointer bcma: gpio: use gpiochip data pointer avr32: gpio: use gpiochip data pointer video: fbdev: via: use gpiochip data pointer gpio: pch: Optimize pch_gpio_get() Revert "pinctrl: lantiq: Implement gpio_chip.to_irq" pinctrl: nsp-gpio: use gpiochip data pointer pinctrl: vt8500-wmt: use gpiochip data pointer pinctrl: exynos5440: use gpiochip data pointer pinctrl: at91-pio4: use gpiochip data pointer ...
2016-01-05pinctrl: mediatek: use gpiochip data pointerLinus Walleij
This makes the driver use the data pointer added to the gpio_chip to store a pointer to the state container instead of relying on container_of(). Acked-by: Matthias Brugger <matthias.bgg@gmail.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-12-22pinctrl: mediatek: convert to arch_initcallDaniel Kurtz
Move pinctrl initialization earlier in boot so that real devices can find their pctldev without probe deferring. Note: We don't change mt6397 probe order in this patch, since MT6397 is mfd PMIC, which depends on pwrap on main AP to work. Since pmic-wrap itself is module_platform_driver, we keep it as module_init. A later patch will convert both pmic-wrap, and all functions of the MT6397 mfd to arch_initcall. Signed-off-by: Daniel Kurtz <djkurtz@chromium.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-12-22pinctrl: mediatek: add missing of_node_putJulia Lawall
for_each_child_of_node performs an of_node_get on each iteration, so a return from the loop requires an of_node_put. A simplified version of the semantic patch that fixes this problem is as follows (http://coccinelle.lip6.fr): // <smpl> @@ local idexpression n; expression e,e1; @@ for_each_child_of_node(e1,n) { ... ( of_node_put(n); | e = n | return n; | + of_node_put(n); ? return ...; ) ... } // </smpl> Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-12-21Merge tag 'v4.4-rc6' into develLinus Walleij
Linux 4.4-rc6
2015-12-17Merge tag 'v4.4-rc5' into develLinus Walleij
Linux 4.4-rc5
2015-11-29pinctrl: mediatek: fix a memleak when do dt maps.Hongzhou Yang
configs will kmemdup to dup_configs in pictrl util function. So configs need to be freed. Signed-off-by: Hongzhou Yang <hongzhou.yang@mediatek.com> Reviewed-by: Daniel Kurtz <djkurtz@chromium.org> Reviewed-by: Matthias Brugger <matthias.bgg@gmail.com> Reviewed-by: Yingjoe Chen <yingjoe.chen@mediatek.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-11-19gpio: change member .dev to .parentLinus Walleij
The name .dev in a struct is normally reserved for a struct device that is let us say a superclass to the thing described by the struct. struct gpio_chip stands out by confusingly using a struct device *dev to point to the parent device (such as a platform_device) that represents the hardware. As we want to give gpio_chip:s real devices, this is not working. We need to rename this member to parent. This was done by two coccinelle scripts, I guess it is possible to combine them into one, but I don't know such stuff. They look like this: @@ struct gpio_chip *var; @@ -var->dev +var->parent and: @@ struct gpio_chip var; @@ -var.dev +var.parent and: @@ struct bgpio_chip *var; @@ -var->gc.dev +var->gc.parent Plus a few instances of bgpio that I couldn't figure out how to teach Coccinelle to rewrite. This patch hits all over the place, but I *strongly* prefer this solution to any piecemal approaches that just exercise patch mechanics all over the place. It mainly hits drivers/gpio and drivers/pinctrl which is my own backyard anyway. Cc: Haavard Skinnemoen <hskinnemoen@gmail.com> Cc: Rafał Miłecki <zajec5@gmail.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Mauro Carvalho Chehab <mchehab@osg.samsung.com> Cc: Alek Du <alek.du@intel.com> Cc: Jaroslav Kysela <perex@perex.cz> Cc: Takashi Iwai <tiwai@suse.com> Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Acked-by: Lee Jones <lee.jones@linaro.org> Acked-by: Jiri Kosina <jkosina@suse.cz> Acked-by: Hans-Christian Egtvedt <egtvedt@samfundet.no> Acked-by: Jacek Anaszewski <j.anaszewski@samsung.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-11-18pinctrl: mediatek: Add get_direction support.Hongzhou Yang
Since Linux gpio framework return 0 for output, 1 for input. But HW use 0 stands for input, and 1 stands for output. So use negative to correct it. And gpio_chip.get is used to get input value, no need to get output value, so removing it. Signed-off-by: Hongzhou Yang <hongzhou.yang@mediatek.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-11-02Merge tag 'gpio-v4.4-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio Pull GPIO updates from Linus Walleij: "Here is the bulk of GPIO changes for the v4.4 development cycle. The only changes hitting outside drivers/gpio are in the pin control subsystem and these seem to have settled nicely in linux-next. Development mistakes and catfights are nicely documented in the reverts as you can see. The outcome of the ABI fight is that we're working on a chardev ABI for GPIO now, where hope to show results for the v4.5 kernel. Summary of changes: GPIO core: - Define and handle flags for open drain/open collector and open source/open emitter, also know as "single-ended" configurations. - Generic request/free operations that handle calling out to the (optional) pin control backend. - Some refactoring related to an ABI change that did not happen, yet provide useful. - Added a real-time compliance checklist. Many GPIO chips have irqchips, and need to think this over with the RT patches going upstream. - Restructure, fix and clean up Kconfig menus a bit. New drivers: - New driver for AMD Promony. - New driver for ACCES 104-IDIO-16, a port-mapped I/O card, ISA-style. Very retro. Subdriver changes: - OMAP changes to handle real time requirements. - Handle trigger types for edge and level IRQs on PL061 properly. As this hardware is very common it needs to set a proper example for others to follow. - Some container_of() cleanups. - Delete the unused MSM driver in favor of the driver that is embedded inside the pin control driver. - Cleanup of the ath79 GPIO driver used by many, many OpenWRT router targets. - A consolidated IT87xx driver replacing the earlier very specific IT8761e driver. - Handle the TI TCA9539 in the PCA953x driver. Also handle ACPI devices in this subdriver. - Drop xilinx arch dependencies as these FPGAs seem to profilate over a few different architectures. MIPS and ARM come to mind" * tag 'gpio-v4.4-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (57 commits) gpio: fix up SPI submenu gpio: drop surplus I2C dependencies gpio: drop surplus X86 dependencies gpio: dt-bindings: document the official use of "ngpios" gpio: MAINTAINERS: Add an entry for the ATH79 GPIO driver gpio / ACPI: Allow shared GPIO event to be read via operation region gpio: group port-mapped I/O drivers in a menu gpio: Add ACCES 104-IDIO-16 driver maintainer entry gpio: zynq: Document interrupt-controller DT binding gpio: xilinx: Drop architecture dependencies gpio: generic: Revert to old error handling in bgpio_map gpio: add a real time compliance notes Revert "gpio: add a real time compliance checklist" gpio: Add GPIO support for the ACCES 104-IDIO-16 gpio: driver for AMD Promontory gpio: xlp: Convert to use gpiolib irqchip helpers gpio: add a real time compliance checklist gpio/xilinx: enable for MIPS gpiolib: Add and use OF_GPIO_SINGLE_ENDED flag gpiolib: Split GPIO flags parsing and GPIO configuration ...
2015-10-16pinctrl: replace trivial implementations of gpio_chip request/freeJonas Gorski
Replace all trivial request/free callbacks that do nothing but call into pinctrl code with the generic versions. Signed-off-by: Jonas Gorski <jogo@openwrt.org> Acked-by: Bjorn Andersson <bjorn.andersson@sonymobile.com> Acked-by: Heiko Stuebner <heiko@sntech.de> Acked-by: Eric Anholt <eric@anholt.net> Acked-by: Mika Westerberg <mika.westerberg@linux.intel.com> Acked-by: Andrew Bresticker <abrestic@chromium.org> Acked-by: Baruch Siach <baruch@tkos.co.il> Acked-by: Matthias Brugger <matthias.bgg@gmail.com> Acked-by: Lee Jones <lee@kernel.org> Acked-by: Laxman Dewangan <ldewangan@nvidia.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-10-02pinctrl: mediatek: Remove unneded semicolonJavier Martinez Canillas
It's not needed an is just creating a null statement, so remove it. Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com> Acked-by: Hongzhou Yang <hongzhou.yang@mediatek.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-09-25pinctrl: mediatek: Consistently use the BIT() macroJavier Martinez Canillas
The mediatek pinctrl driver uses the BIT() macro instead of open coding 1 << n in all but one place. Replace this occurrence with the BIT() macro for consistency. Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com> Reviewed-by: Matthias Brugger <matthias.bgg@gmail.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-09-16genirq: Remove irq argument from irq flow handlersThomas Gleixner
Most interrupt flow handlers do not use the irq argument. Those few which use it can retrieve the irq number from the irq descriptor. Remove the argument. Search and replace was done with coccinelle and some extra helper scripts around it. Thanks to Julia for her help! Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Julia Lawall <Julia.Lawall@lip6.fr> Cc: Jiang Liu <jiang.liu@linux.intel.com>
2015-08-26pinctrl: mediatek: Implement wake handler and suspend resumeMaoguang Meng
This patch implement irq_set_wake to get who is wakeup source and setup on suspend resume. Signed-off-by: Maoguang Meng <maoguang.meng@mediatek.com> Reviewed-by: Daniel Kurtz <djkurtz@chromium.org> Acked-by: Yingjoe Chen <yingjoe.chen@mediatek.com> Acked-by: Hongzhou Yang <hongzhou.yang@mediatek.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-08-26pinctrl: mediatek: Fix multiple registration issue.Hongzhou Yang
Since our common driver need support main chip and PMU at the same time, that means it will register two pinctrl device, and the pinctrl_desc structure should be used two times. But pinctrl_desc use global static definition, then the latest registered pinctrl device will overwrite the old one's, all members in pinctrl_desc will set to the new one's, such as name, pins and pins numbers, etc. This is a bug. Move pinctrl_desc into mtk_pinctrl, assign new value for each pinctrl device to fix it. Cc: stable@vger.kernel.org # v4.1+ Signed-off-by: Hongzhou Yang <hongzhou.yang@mediatek.com> Reviewed-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-08-13pinctrl/mediatek: fix spelling mistake in dev_err error messageColin Ian King
Trivial change, fix spelling mistake 'invaild' -> 'invalid' in dev_err message. Signed-off-by: Colin Ian King <colin.king@canonical.com> Acked-by: Hongzhou Yang <hongzhou.yang@mediatek.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-07-28pinctrl: kill off set_irq_flags usageRob Herring
set_irq_flags is ARM specific with custom flags which have genirq equivalents. Convert drivers to use the genirq interfaces directly, so we can kill off set_irq_flags. The translation of flags is as follows: IRQF_VALID -> !IRQ_NOREQUEST IRQF_PROBE -> !IRQ_NOPROBE IRQF_NOAUTOEN -> IRQ_NOAUTOEN For IRQs managed by an irqdomain, the irqdomain core code handles clearing and setting IRQ_NOREQUEST already, so there is no need to do this in .map() functions and we can simply remove the set_irq_flags calls. Some users also modify IRQ_NOPROBE and this has been maintained although it is not clear that is really needed. There appears to be a great deal of blind copy and paste of this code. Signed-off-by: Rob Herring <robh@kernel.org> Cc: Stephen Warren <swarren@wwwdotorg.org> Cc: Lee Jones <lee@kernel.org> Cc: Matthias Brugger <matthias.bgg@gmail.com> Cc: Tomasz Figa <tomasz.figa@gmail.com> Cc: Thomas Abraham <thomas.abraham@linaro.org> Cc: Kukjin Kim <kgene@kernel.org> Cc: Krzysztof Kozlowski <k.kozlowski@samsung.com> Cc: linux-gpio@vger.kernel.org Cc: linux-rpi-kernel@lists.infradead.org Cc: linux-arm-kernel@lists.infradead.org Cc: linux-mediatek@lists.infradead.org Cc: linux-samsung-soc@vger.kernel.org Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-07-17pinctrl: Use irq_desc_get_xxx() to avoid redundant lookup of irq_descJiang Liu
Use irq_desc_get_xxx() to avoid redundant lookup of irq_desc while we already have a pointer to corresponding irq_desc. Signed-off-by: Jiang Liu <jiang.liu@linux.intel.com> Cc: Linus Walleij <linus.walleij@linaro.org> Cc: linux-gpio@vger.kernel.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-07-01Merge branch 'irq-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull irq fixes from Thomas Gleixner: "This contains: - a series of fixes for interrupt drivers to prevent a potential race when installing a chained interrupt handler - a fix for cpumask pointer misuse - a fix for using the wrong interrupt number from struct irq_data - removal of unused code and outdated comments - a few new helper functions which allow us to cleanup the interrupt handling code further in 4.3 I decided against doing the cleanup at the end of this merge window and rather do the preparatory steps for 4.3, so we can run the final ABI change at the end of the 4.3 merge window with less risk" * 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (26 commits) ARM/LPC32xx: Use irq not hwirq for __irq_set_handler_locked() genirq: Implement irq_set_handler_locked()/irq_set_chip_handler_name_locked() genirq: Introduce helper irq_desc_get_irq() genirq: Remove irq_node() genirq: Clean up outdated comments related to include/linux/irqdesc.h mn10300: Fix incorrect use of irq_data->affinity MIPS/ralink: Fix race in installing chained IRQ handler MIPS/pci: Fix race in installing chained IRQ handler MIPS/ath25: Fix race in installing chained IRQ handler MIPS/ath25: Fix race in installing chained IRQ handler m68k/psc: Fix race in installing chained IRQ handler avr32/at32ap: Fix race in installing chained IRQ handler sh/intc: Fix race in installing chained IRQ handler sh/intc: Fix potential race in installing chained IRQ handler pinctrl/sun4i: Fix race in installing chained IRQ handler pinctrl/samsung: Fix race in installing chained IRQ handler pinctrl/samsung: Fix race in installing chained IRQ handler pinctrl/exynos: Fix race in installing chained IRQ handler pinctrl/st: Fix race in installing chained IRQ handler pinctrl/adi2: Fix race in installing chained IRQ handler ...
2015-06-25pinctrl/mediatek: Fix race in installing chained IRQ handlerThomas Gleixner
Fix a race where a pending interrupt could be received and the handler called before the handler's data has been setup, by converting to irq_set_chained_handler_and_data(). Search and conversion was done with coccinelle: @@ expression E1, E2, E3; @@ ( -if (irq_set_chained_handler(E1, E3) != 0) - BUG(); | -irq_set_chained_handler(E1, E3); ) -irq_set_handler_data(E1, E2); +irq_set_chained_handler_and_data(E1, E3, E2); @@ expression E1, E2, E3; @@ ( -if (irq_set_chained_handler(E1, E3) != 0) - BUG(); ... | -irq_set_chained_handler(E1, E3); ... ) -irq_set_handler_data(E1, E2); +irq_set_chained_handler_and_data(E1, E3, E2); Reported-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Julia Lawall <Julia.Lawall@lip6.fr> Cc: Linus Walleij <linus.walleij@linaro.org> Cc: Matthias Brugger <matthias.bgg@gmail.com> Cc: Hongzhou Yang <hongzhou.yang@mediatek.com> Cc: Axel Lin <axel.lin@ingics.com> Cc: Yingjoe Chen <yingjoe.chen@mediatek.com> Cc: Maoguang Meng <maoguang.meng@mediatek.com> Cc: Colin Ian King <colin.king@canonical.com> Cc: linux-gpio@vger.kernel.org Cc: linux-arm-kernel@lists.infradead.org Cc: linux-mediatek@lists.infradead.org
2015-06-24Merge tag 'pinctrl-v4.2-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl Pull pin control updates from Linus Walleij: "Here is the bulk of pin control changes for the v4.2 series: Quite a lot of new SoC subdrivers and two new main drivers this time, apart from that business as usual. Details: Core functionality: - Enable exclusive pin ownership: it is possible to flag a pin controller so that GPIO and other functions cannot use a single pin simultaneously. New drivers: - NXP LPC18xx System Control Unit pin controller - Imagination Pistachio SoC pin controller New subdrivers: - Freescale i.MX7d SoC - Intel Sunrisepoint-H PCH - Renesas PFC R8A7793 - Renesas PFC R8A7794 - Mediatek MT6397, MT8127 - SiRF Atlas 7 - Allwinner A33 - Qualcomm MSM8660 - Marvell Armada 395 - Rockchip RK3368 Cleanups: - A big cleanup of the Marvell MVEBU driver rectifying it to correspond to reality - Drop platform device probing from the SH PFC driver, we are now a DT only shop for SuperH - Drop obsolte multi-platform check for SH PFC - Various janitorial: constification, grammar etc Improvements: - The AT91 GPIO portions now supports the set_multiple() feature - Split out SPI pins on the Xilinx Zynq - Support DTs without specific function nodes in the i.MX driver" * tag 'pinctrl-v4.2-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl: (99 commits) pinctrl: rockchip: add support for the rk3368 pinctrl: rockchip: generalize perpin driver-strength setting pinctrl: sh-pfc: r8a7794: add SDHI pin groups pinctrl: sh-pfc: r8a7794: add MMCIF pin groups pinctrl: sh-pfc: add R8A7794 PFC support pinctrl: make pinctrl_register() return proper error code pinctrl: mvebu: armada-39x: add support for Armada 395 variant pinctrl: mvebu: armada-39x: add missing SATA functions pinctrl: mvebu: armada-39x: add missing PCIe functions pinctrl: mvebu: armada-38x: add ptp functions pinctrl: mvebu: armada-38x: add ua1 functions pinctrl: mvebu: armada-38x: add nand functions pinctrl: mvebu: armada-38x: add sata functions pinctrl: mvebu: armada-xp: add dram functions pinctrl: mvebu: armada-xp: add nand rb function pinctrl: mvebu: armada-xp: add spi1 function pinctrl: mvebu: armada-39x: normalize ref clock naming pinctrl: mvebu: armada-xp: rename spi to spi0 pinctrl: mvebu: armada-370: align spi1 clock pin naming pinctrl: mvebu: armada-370: align VDD cpu-pd pin naming with datasheet ...
2015-06-10pinctrl: make pinctrl_register() return proper error codeMasahiro Yamada
Currently, pinctrl_register() just returns NULL on error, so the callers can not know the exact reason of the failure. Some of the pinctrl drivers return -EINVAL, some -ENODEV, and some -ENOMEM on error of pinctrl_register(), although the error code might be different from the real cause of the error. This commit reworks pinctrl_register() to return the appropriate error code and modifies all of the pinctrl drivers to use IS_ERR() for the error checking and PTR_ERR() for getting the error code. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Patrice Chotard <patrice.chotard@st.com> Acked-by: Thierry Reding <treding@nvidia.com> Acked-by: Heiko Stuebner <heiko@sntech.de> Tested-by: Mika Westerberg <mika.westerberg@linux.intel.com> Acked-by: Mika Westerberg <mika.westerberg@linux.intel.com> Acked-by: Lee Jones <lee@kernel.org> Acked-by: Sören Brinkmann <soren.brinkmann@xilinx.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Ray Jui <rjui@broadcom.com> Acked-by: Antoine Tenart <antoine.tenart@free-electrons.com> Acked-by: Hongzhou Yang <hongzhou.yang@mediatek.com> Acked-by: Wei Chen <Wei.Chen@csr.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-06-04pinctrl: Remove .owner fieldFabio Estevam
platform_driver does not need to set the owner field, as it will be populated by the driver core, so just remove it. The semantic patch that makes this change is available in scripts/coccinelle/api/platform_no_drv_owner.cocci. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-06-02pinctrl: mediatek: Fix pinctrl register irq fail bug.Hongzhou Yang
Since mt6397 is no need to support interrupt controller, I judged "interrupt-controller" property to skip it last patch. But the if judgement should on the contrary, this is a bug. And find of_property_read_bool is better for this case. So using of_property_read_bool instead of of_find_property. Also fix bug of misuse pointer. Signed-off-by: Hongzhou Yang <hongzhou.yang@mediatek.com> Reviewed-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-06-02pinctrl: mediatek: Fix bug of ies/smt setting for mt8173.Hongzhou Yang
Add ies/smt support for MSDC3. Also fix ies bug for pin 106 and 107. Signed-off-by: Hongzhou Yang <hongzhou.yang@mediatek.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-05-20pinctrl: mediatek: add OF dependency to MT6397Linus Walleij
X86_64 allmodconfig screams like so: warning: (PINCTRL_MT6397) selects PINCTRL_MTK_COMMON which has unmet direct dependencies (PINCTRL && (ARCH_MEDIATEK || COMPILE_TEST) && OF) So add OF to dependencies to shut up this warning. Cc: Hongzhou Yang <hongzhou.yang@mediatek.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
