path: root/drivers/pinctrl/nomadik
2015-09-16genirq: Remove irq argument from irq flow handlersThomas Gleixner
Most interrupt flow handlers do not use the irq argument. Those few which use it can retrieve the irq number from the irq descriptor. Remove the argument. Search and replace was done with coccinelle and some extra helper scripts around it. Thanks to Julia for her help! Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Julia Lawall <Julia.Lawall@lip6.fr> Cc: Jiang Liu <jiang.liu@linux.intel.com>
2015-09-04Merge tag 'pinctrl-v4.3-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl Pull pin control updates from Linus Walleij: "This is the bulk of pin control changes for the v4.3 development cycle. Like with GPIO it's a lot of stuff. If my subsystems are any sign of the overall tempo of the kernel v4.3 will be a gigantic diff. [ It looks like 4.3 is calmer than 4.2 in most other subsystems, but we'll see - Linus ] Core changes: - It is possible configure groups in debugfs. - Consolidation of chained IRQ handler install/remove replacing all call sites where irq_set_handler_data() and irq_set_chained_handler() were done in succession with a combined call to irq_set_chained_handler_and_data(). This series was created by Thomas Gleixner after the problem was observed by Russell King. - Tglx also made another series of patches switching __irq_set_handler_locked() for irq_set_handler_locked() which is way cleaner. - Tglx also wrote a good bunch of patches to make use of irq_desc_get_xxx() accessors and avoid looking up irq_descs from IRQ numbers. The goal is to get rid of the irq number from the handlers in the IRQ flow which is nice. Driver feature enhancements: - Power management support for the SiRF SoC Atlas 7. - Power down support for the Qualcomm driver. - Intel Cherryview and Baytrail: switch drivers to use raw spinlocks in IRQ handlers to play nice with the realtime patch set. - Rework and new modes handling for Qualcomm SPMI-MPP. - Pinconf power source config for SH PFC. New drivers and subdrivers: - A new driver for Conexant Digicolor CX92755. - A new driver for UniPhier PH1-LD4, PH1-Pro4, PH1-sLD8, PH1-Pro5, ProXtream2 and PH1-LD6b SoC pin control support. - Reverse-egineered the S/PDIF settings for the Allwinner sun4i driver. - Support for Qualcomm Technologies QDF2xxx ARM64 SoCs - A new Freescale i.mx6ul subdriver. Cleanup: - Remove platform data support in a number of SH PFC subdrivers" * tag 'pinctrl-v4.3-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl: (95 commits) pinctrl: at91: fix null pointer dereference pinctrl: mediatek: Implement wake handler and suspend resume pinctrl: mediatek: Fix multiple registration issue. pinctrl: sh-pfc: r8a7794: add USB pin groups pinctrl: at91: Use generic irq_{request,release}_resources() pinctrl: cherryview: Use raw_spinlock for locking pinctrl: baytrail: Use raw_spinlock for locking pinctrl: imx6ul: Remove .owner field pinctrl: zynq: Fix typos in smc0_nand_grp and smc0_nor_grp pinctrl: sh-pfc: Implement pinconf power-source param for voltage switching clk: rockchip: add pclk_pd_pmu to the list of rk3288 critical clocks pinctrl: sun4i: add spdif to pin description. pinctrl: atlas7: clear ugly branch statements for pull and drivestrength pinctrl: baytrail: Serialize all register access pinctrl: baytrail: Drop FSF mailing address pinctrl: rockchip: only enable gpio clock when it setting pinctrl/mediatek: fix spelling mistake in dev_err error message pinctrl: cherryview: Serialize all register access pinctrl: UniPhier: PH1-Pro5: add I2C ch6 pin-mux setting pinctrl: nomadik: reflect current input value ...
2015-08-11pinctrl: nomadik: reflect current input valueLinus Walleij
Let us see the current value on the input line in debugfs. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-07-28pinctrl: nomadik: split stn8815 UART0 pin groupsLinus Walleij
Split the UART pin groups so we can activate RX/TX, CTS/RTS and the modem pins (DCD, DSR, RI, DTR) as three different groups with function u0. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-07-27pinctrl: nomadik: depromote GPIO to subsystem_init()Linus Walleij
We no longer have to do GPIO initialization before the pinctrl initialization, instead we can initialize the pinctrl portions of the driver first and then the GPIO. Thus we can move GPIO initialization to a subsystem_initcall(), but not yet to a device_initcall(). Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-07-27pinctrl/ARM: move GPIO and pinctrl deps to device treeLinus Walleij
This gets the GPIO ranges out of the driver and into the device tree where they belong. Standard DT bindings already exist for this. Since no systems with this are deployed we can just augment all device trees and the drivers at the same time and simplify the world. This also defines the array of GPIO chips related to the pin controller. Cc: arm@kernel.org Acked-by: Olof Johansson <olof@lixom.net> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-07-23pinctrl: nomadik: assure GPIO chips are populatedLinus Walleij
If the pin controller probes before the GPIO driver it needs to populate the GPIO driver state containers ahead of the actual driver probe as the addresses are used by both halves of the driver. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-07-23pinctrl: nomadik: find chip from local arrayLinus Walleij
Instead of indexing around the GPIO ranges to find a chip, look directly in the local array of state containers for nmk_gpio_chip:s. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-07-23pinctrl: nomadik: break out state container allocatorLinus Walleij
Break out the function that allocates the nomadik GPIO chip state container to its own function. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-07-20pinctrl: abx500: remove strict modeLinus Walleij
Commit a21763a0b1e5a5ab8310f581886d04beadc16616 "pinctrl: nomadik: activate strict mux mode" put all Nomadik pin controllers to strict mode. This was not good on the Snowball platform: the muxing of GPIOs to different pins is done with hogs in the DTS file, and then these GPIOs are used by offset, relying on hogs to mux the pins. Since that means the pin controller "owns" the pins and at the same time we have a GPIO user, this pin controller is by definition not strict. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-07-17pinctrl: Use irq_desc_get_xxx() to avoid redundant lookup of irq_descJiang Liu
Use irq_desc_get_xxx() to avoid redundant lookup of irq_desc while we already have a pointer to corresponding irq_desc. Signed-off-by: Jiang Liu <jiang.liu@linux.intel.com> Cc: Linus Walleij <linus.walleij@linaro.org> Cc: linux-gpio@vger.kernel.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-06-10pinctrl: make pinctrl_register() return proper error codeMasahiro Yamada
Currently, pinctrl_register() just returns NULL on error, so the callers can not know the exact reason of the failure. Some of the pinctrl drivers return -EINVAL, some -ENODEV, and some -ENOMEM on error of pinctrl_register(), although the error code might be different from the real cause of the error. This commit reworks pinctrl_register() to return the appropriate error code and modifies all of the pinctrl drivers to use IS_ERR() for the error checking and PTR_ERR() for getting the error code. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Patrice Chotard <patrice.chotard@st.com> Acked-by: Thierry Reding <treding@nvidia.com> Acked-by: Heiko Stuebner <heiko@sntech.de> Tested-by: Mika Westerberg <mika.westerberg@linux.intel.com> Acked-by: Mika Westerberg <mika.westerberg@linux.intel.com> Acked-by: Lee Jones <lee@kernel.org> Acked-by: Sören Brinkmann <soren.brinkmann@xilinx.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Ray Jui <rjui@broadcom.com> Acked-by: Antoine Tenart <antoine.tenart@free-electrons.com> Acked-by: Hongzhou Yang <hongzhou.yang@mediatek.com> Acked-by: Wei Chen <Wei.Chen@csr.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-06-01pinctrl: Spelling s/reseved/reserved/Geert Uytterhoeven
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Reviewed-by: Simon Horman <horms+renesas@verge.net.au> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-05-06pinctrl: nomadik: assign chips dynamicallyLinus Walleij
Assign GPIO chip and irqchip to the GPIO container dynamically, so we can set a unique name for each GPIO irqchip and see what chip the hwirq offset actually relates to. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-05-06pinctrl: nomadik: activate strict mux modeLinus Walleij
This activates strict mode muxing for the Nomadik pin controllers, as these do not allow GPIO and functions to use the same pin simultaneously. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-04-15pinctrl: fix allmodconfig noiseLinus Walleij
There was some mess in the dependencies in the pinctrl Kconfig for compile tests under allmodconfig. Mea Culpa. Reported-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2015-04-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree from Jiri Kosina: "Usual trivial tree updates. Nothing outstanding -- mostly printk() and comment fixes and unused identifier removals" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: goldfish: goldfish_tty_probe() is not using 'i' any more powerpc: Fix comment in smu.h qla2xxx: Fix printks in ql_log message lib: correct link to the original source for div64_u64 si2168, tda10071, m88ds3103: Fix firmware wording usb: storage: Fix printk in isd200_log_config() qla2xxx: Fix printk in qla25xx_setup_mode init/main: fix reset_device comment ipwireless: missing assignment goldfish: remove unreachable line of code coredump: Fix do_coredump() comment stacktrace.h: remove duplicate declaration task_struct smpboot.h: Remove unused function prototype treewide: Fix typo in printk messages treewide: Fix typo in printk messages mod_devicetable: fix comment for match_flags
2015-03-06treewide: Fix typo in printk messagesMasanari Iida
This patch fix spelling typo in printk messages. Signed-off-by: Masanari Iida <standby24x7@gmail.com> Acked-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2015-01-11pinctrl: pinconf-generic: Allow driver to specify DT paramsSoren Brinkmann
Additionally to the generic DT parameters, allow drivers to provide driver-specific DT parameters to be used with the generic parser infrastructure. To achieve this 'struct pinctrl_desc' is extended to pass custom pinconf option to the core. In order to pass this kind of information, the related data structures - 'struct pinconf_generic_dt_params', 'pin_config_item' - are moved from pinconf internals to the pinconf-generic header. Additionally pinconfg-generic is refactored to not only iterate over the generic pinconf parameters but also take the parameters into account that are provided through the driver's 'struct pinctrl_desc'. In particular 'pinconf_generic_parse_dt_config()' and 'pinconf_generic_dump' helpers are split into two parts each. In order to have a more generic helper that can be used to process the generic parameters as well as the driver-specific ones. v2: - fix typo - add missing documentation for @conf_items member in struct - rebase to pinctrl/devel: conflict in abx500 - rename _pinconf_generic_dump() to pinconf_generic_dump_one() - removed '_' from _parse_dt_cfg() - removed BUG_ONs, error condition is handled in if statements - removed pinconf_generic_dump_group() & pinconf_generic_dump_pin helpers - fixed up corresponding call sites - renamed pinconf_generic_dump() to pinconf_generic_dump_pins() - added kernel-doc to pinconf_generic_dump_pins() - add kernel-doc - more verbose commit message Signed-off-by: Soren Brinkmann <soren.brinkmann@xilinx.com> Tested-by: Andreas Färber <afaerber@suse.de> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-12-14Merge tag 'driver-core-3.19-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core update from Greg KH: "Here's the set of driver core patches for 3.19-rc1. They are dominated by the removal of the .owner field in platform drivers. They touch a lot of files, but they are "simple" changes, just removing a line in a structure. Other than that, a few minor driver core and debugfs changes. There are some ath9k patches coming in through this tree that have been acked by the wireless maintainers as they relied on the debugfs changes. Everything has been in linux-next for a while" * tag 'driver-core-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (324 commits) Revert "ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries" fs: debugfs: add forward declaration for struct device type firmware class: Deletion of an unnecessary check before the function call "vunmap" firmware loader: fix hung task warning dump devcoredump: provide a one-way disable function device: Add dev_<level>_once variants ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries ath: use seq_file api for ath9k debugfs files debugfs: add helper function to create device related seq_file drivers/base: cacheinfo: remove noisy error boot message Revert "core: platform: add warning if driver has no owner" drivers: base: support cpu cache information interface to userspace via sysfs drivers: base: add cpu_device_create to support per-cpu devices topology: replace custom attribute macros with standard DEVICE_ATTR* cpumask: factor out show_cpumap into separate helper function driver core: Fix unbalanced device reference in drivers_probe driver core: fix race with userland in device_add() sysfs/kernfs: make read requests on pre-alloc files use the buffer. sysfs/kernfs: allow attributes to request write buffer be pre-allocated. fs: sysfs: return EGBIG on write if offset is larger than file size ...
2014-10-20pinctrl: nomadik: drop owner assignment from platform_driversWolfram Sang
A platform_driver does not need to set an owner, it will be populated by the driver core. Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2014-10-20pinctrl: nomadik: amend MMC/SD pinsLinus Walleij
There is a missing MMC/SD pin for MCDATDIR2 which is routed as alt B, add it to the MMC/SD pin group and functions. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-10-20pinctrl: abx500: mark pin config as genericLinus Walleij
This is generic pin configuration, so add .is_generic. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-10-20pinctrl: abx500: retire phandle config mechanismLinus Walleij
The abx500 pin control driver supported a method of fetching the generic config from a phandle to a separate node using the "ste,config" as a phandle. This is not used in any device trees and not documented in the bindings, so drop this support. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-10-20pinctrl: abx500: force-convert to generic config bindingsLinus Walleij
This converts the ABx500 pin controller and all associated device trees to use the standard, generic config bindings for pin controllers. There are no such device trees deployed in the wild so this is safe to do to set a good example. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-10-20pinctrl: nomadik: force-convert to generic config bindingsLinus Walleij
This converts the Nomadik pin controller and all associated device trees to use the standard, generic config bindings for pin controllers. There are no such device trees deployed in the wild so this is safe to do to set a good example. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-10-20pinctrl: abx500: force-convert to generic mux bindingsLinus Walleij
This converts the ABx500 pin controller and all associated device trees to use the standard, generic mux bindings for pin controllers. There are no such device trees deployed in the wild so this is safe to do to set a good example. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-10-20pinctrl: nomadik: force-convert to generic mux bindingsLinus Walleij
This converts the Nomadik pin controller and all associated device trees to use the standard, generic mux bindings for pin controllers. There are no such device trees deployed in the wild so this is safe to do to set a good example. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-10-09Merge tag 'gpio-v3.18-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio Pull GPIO changes from Linus Walleij: "This is the bulk of GPIO changes for the v3.18 development cycle: - Increase the default ARCH_NR_GPIO from 256 to 512. This was done to avoid having a custom <asm/gpio.h> header for the x86 architecture - GPIO is custom and complicated enough as it is already! We want to move to a radix to store the descriptors going forward, and finally get rid of this fixed array size altogether. - Endgame patching of the gpio_remove() semantics initiated by Abdoulaye Berthe. It is not accepted by the system that the removal of a GPIO chip fails during eg reboot or shutdown, and therefore the return value has now painfully been refactored away. For special cases like GPIO expanders on a hot-pluggable bus like USB, we may later add some gpiochip_try_remove() call, but for the cases we have now, return values are moot. - Some incremental refactoring of the gpiolib core and ACPI GPIO library for more descriptor usage. - Refactor the chained IRQ handler set-up method to handle also threaded, nested interrupts and set up the parent IRQ correctly. Switch STMPE and TC3589x drivers to use this registration method. - Add a .irq_not_threaded flag to the struct gpio_chip, so that also GPIO expanders that block but are still not using threaded IRQ handlers. - New drivers for the ARM64 X-Gene SoC GPIO controller. - The syscon GPIO driver has been improved to handle the "DSP GPIO" found on the TI Keystone 2 SoC:s. - ADNP driver switched to use gpiolib irqchip helpers. - Refactor the DWAPB driver to support being instantiated from and MFD cell (platform device). - Incremental feature improvement in the Zynq, MCP23S08, DWAPB, OMAP, Xilinx and Crystalcove drivers. - Various minor fixes" * tag 'gpio-v3.18-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (52 commits) gpio: pch: Build context save/restore only for PM pinctrl: abx500: get rid of unused variable gpio: ks8695: fix 'else should follow close brace '}'' gpio: stmpe: add verbose debug code gpio: stmpe: fix up interrupt enable logic gpio: staticize xway_stp_init() gpio: handle also nested irqchips in the chained handler set-up gpio: set parent irq on chained handlers gpiolib: irqchip: use irq_find_mapping while removing irqchip gpio: crystalcove: support virtual GPIO pinctrl: bcm281xx: make Kconfig dependency more strict gpio: kona: enable only on BCM_MOBILE or for compile testing gpio, bcm-kona, LLVMLinux: Remove use of __initconst gpio: Fix ngpio in gpio-xilinx driver gpio: dwapb: fix pointer to integer cast gpio: xgene: Remove unneeded #ifdef CONFIG_OF guard gpio: xgene: Remove unneeded forward declation for struct xgene_gpio gpio: xgene: Fix missing spin_lock_init() gpio: ks8695: fix switch case indentation gpiolib: add irq_not_threaded flag to gpio_chip ...
2014-10-07Merge tag 'pinctrl-v3.18-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl Pull pin control changes from Linus Walleij: "This is the bulk of pin control changes for the v3.18 development series: - New drivers for the Freescale i.MX21, Qualcomm APQ8084 pin controllers. - Incremental new features on the Rockchip, atlas 6, OMAP, AM437x, APQ8064, prima2, AT91, Tegra, i.MX, Berlin and Nomadik. - Push Freescale drivers down into their own subdirectory. - Assorted sprays of syntax and semantic fixes" * tag 'pinctrl-v3.18-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl: (48 commits) pinctrl: specify bindings for pins and groups pinctrl: nomadik: improve GPIO debug prints pinctrl: abx500: refactor DT parser to take two paths pinctrl: abx500: use helpers for map allocation/free pinctrl: alter device tree bindings for functions pinctrl: nomadik: refactor DT parser to take two paths pinctrl: nomadik: use utils map free function pinctrl: nomadik: use util function to reserve maps pinctrl: qcom: use restart_notifier mechanism for ps_hold pinctrl: sh-pfc: sh73a0: Remove unnecessary SoC data allocation pinctrl: berlin: fix the dt_free_map function pinctrl: at91: disable PD or PU before enabling PU or PD pinctrl: st: remove gpiochip in failure cases pinctrl: at91: Fix error handling while doing gpiochio_irqchip_add pinctrl: at91: Fix failure path in at91_gpio_probe path pinctrl: lantiq: Release gpiochip resources in fail case pinctrl: imx: detect uninitialized pins pinctrl: tegra: Add MIPI pad control pinctrl: at91: Switch to using managed clk_get pinctrl: adi2: Remove duplicate gpiochip_remove_pin_ranges ...
2014-10-02pinctrl: abx500: get rid of unused variableLinus Walleij
commit 2fcea6cecbc965b4e02a39537d9d939f5251bbbd "pinctrl: remove remaining users of gpiochip_remove() retval" removed the use of the return value from gpiochip_remove() but missed to delete the dangling "err" variable: drivers/pinctrl/nomadik/pinctrl-abx500.c: In function 'abx500_gpio_probe': drivers/pinctrl/nomadik/pinctrl-abx500.c:1208:11: warning: unused variable 'err' [-Wunused-variable] Fix this by getting rid of the dangling variable. Reported-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-09-30pinctrl: nomadik: improve GPIO debug printsLinus Walleij
The debugfs file would only define if the line was "pulled" and not which direction (pull up or pull down). Improve this by taking two print paths depending on whether the pin is set as input or output and use the data register directly to figure out whether the pin is set for pull up or pull down. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-09-30pinctrl: abx500: refactor DT parser to take two pathsLinus Walleij
We refactor the DT parser to look for either a config or a function and then look for further nodes and reserve maps, not the two things mixed up like prior to this patch. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-09-30pinctrl: abx500: use helpers for map allocation/freeLinus Walleij
This switches the abx500 driver to use the pin control helper utils for allocating and free:ing maps. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-09-29pinctrl: nomadik: refactor DT parser to take two pathsLinus Walleij
2014-09-29pinctrl: nomadik: use utils map free functionLinus Walleij
Stop brewing our own map free function and rely on the pinctrl utils helpers. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-09-29pinctrl: nomadik: use util function to reserve mapsLinus Walleij
Stop brewing our own pin map reservation function and use the generic code. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-09-23pinctrl: remove remaining users of gpiochip_remove() retvalLinus Walleij
Some drivers accidentally still use the return value from gpiochip_remove(). Get rid of them so we can simplify this function and get rid of the return value. Cc: Abdoulaye Berthe <berthe.ab@gmail.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-09-04pinctrl: clean up after enable refactoringLinus Walleij
commit 2243a87d90b42eb38bc281957df3e57c712b5e56 "pinctrl: avoid duplicated calling enable_pinmux_setting for a pin" removed the .disable callback from the struct pinmux_ops, making the .enable() callback the only remaining callback. However .enable() is a bad name as it seems to imply that a muxing can also be disabled. Rename the callback to .set_mux() and also take this opportunity to clean out any remaining mentions of .disable() from the documentation. Acked-by: Stephen Warren <swarren@nvidia.com> Acked-by: Bjorn Andersson <bjorn.andersson@sonymobile.com> Acked-by: Fan Wu <fwu@marvell.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-08-17pinctrl: abx500: remove useless checkPatrice CHOTARD
pctldev can't be NULL at this stage so remove the check Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Patrice Chotard <patrice.chotard@st.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-07-11pinctrl: nomadik: move all Nomadik drivers to subdirLinus Walleij
We have a bunch of Nomadik family pin control drivers, so let's move them into their own subdirectory. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
