path: root/drivers/pinctrl/pinctrl-adi2-bf60x.c
2015-07-16added tabs instead of spacesMario Bambagini
Tabs have been inserted instead of spaces to indent the code correctly. Same error fixed four times. Signed-off-by: Mario Bambagini <mario.bambagini@gmail.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-02-25pinctrl: pinctrl-adi: combine multiple groups of one function togetherSonic Zhang
The data pins of some peripheral are different if connecting to different devices in one pinmux function. In the PPI case, data pins can be used in 8, 16 and 24 pin groups individually. Add these groups into one ppi function. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-09-23pinctrl: pinctrl-adi2-bf60x: remove useless and duplicated GPIO definition ↵Sonic Zhang
for PPI2. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-09-19pinctrl: ADI PIN control driver for the GPIO controller on bf54x and bf60x.Sonic Zhang
The new ADI GPIO2 controller was introduced since the BF548 and BF60x processors. It differs a lot from the old one on BF5xx processors. So, create a pinctrl driver under the pinctrl framework. - Define gpio ports and pin interrupt controllers as individual platform devices. - Register a pinctrl driver for the whole GPIO ports and pin interrupt devices. - Probe pint devices before port devices. Put device instances into the global gpio and pint lists. - Define peripheral, irq and gpio reservation bit masks for each gpio port as runtime resources. - Save and restore gpio port and pint status MMRs in syscore PM functions. - Create the plug-in subdrivers to hold the pinctrl soc data for bf54x and bf60x. Add soc data into struct adi_pinctrl. Initialize the soc data in pin controller probe function. Get the pin groups and functions via the soc data reference. - Call gpiochip_add_pin_range() in gpio device probe function to register range cross reference between gpio device and pin control device. - Get range by pinctrl_find_gpio_range_from_pin(), find gpio_port object by container_of() and find adi_pinctrl by pin control device name. - Handle peripheral and gpio requests in pinctrl operation functions. - Demux gpio IRQs via the irq_domain created by each GPIO port. v2-changes: - Remove unlinke() directive. v3-changes: - Rename struct adi_pmx to adi_pinctrl. - Fix the comments of struct gpio_pint. - Remove unused pin_base in struct gpio_port. - Change pint_assign into bool type. - Add comments about the relationship between pint device and port device to the driver header. - Use BIT macro to shift bit. - Remove all bitmap reservation help functions. Inline reservation functions into the actual code. - Remove gpio and offset mutual reference help functions. - Remove all help functions to find gpio_port and adi_pinctrl structs. Get range by pinctrl_find_gpio_range_from_pin(), find gpio_port object by container_of() and find adi_pinctrl by pin control device name. - Pass bool type usage variable to port_setup help function. - Separate long bit operations into several lines and add comments. - Use debugfs to output all GPIO request information. - Avoid to set drvdata to NULL - Add explanation to function adi_gpio_init_int() - Call gpiochip_add_pin_range() in gpio device probe function to register range cross reference between gpio device and pin control device. - Remove the reference to pin control device from the gpio_port struct. Remove the reference list to gpio device from the adi_pinctrl struct. Replace the global adi_pinctrl list with adi_gpio_port_list. Walk through the gpio list to do power suspend and resume operations. - Remove the global GPIO base from struct adi_pinctrl, define pin base in the platform data for each GPIO port device. - Initialize adi_pinctrl_setup in arch_initcall(). - print the status of triggers, whether it is in GPIO mode, if it is flagged to be used as IRQ, etc in adi_pin_dbg_show(). - Create the plug-in subdrivers to hold the pinctrl soc data for bf54x and bf60x. Add soc data into struct adi_pinctrl. Initialize the soc data in pin controller probe function. Get the pin groups and functions via the soc data reference. v4-changes: - remove useless system_state checking. - replace dev_err with dev_warn in both irq and gpio pin cases. - comment on relationship between irq type and invert operation. - It is not necessary to check the reservation mode of the requested pin in IRQ chip operation. Remove the reservation map. - Use existing gpio/pinctrl subsystem debugfs files. Remove pinctrl-adi2 driver specific debugfs output. - Add linkport group and function information for bf60x. - Separate uart and ctsrts pins into 2 groups. - Separate APAPI and alternative ATAPI pins into 2 groups. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
