commit 79d2c8bede2c93f9432d7da0bc2f76a195c90fc0 upstream.
The touchpad in the Asus laptop models X505BA/BP and X542BA/BP is
unresponsive after suspend/resume. The following error appears during
resume:
i2c_hid i2c-ELAN1300:00: failed to reset device.
The problem here is that i2c_hid does not notice the interrupt being
generated at this point, because the GPIO is no longer configured
for interrupts.
Fix this by saving pinctrl-amd pin registers during suspend and
restoring them at resume time.
Based on code from pinctrl-intel.
Signed-off-by: Daniel Drake <drake@endlessm.com>
recognized by static analysis tool smatch. Declare constant
Variables with Sparse's suggestion.
Signed-off-by: Ken Xue <Ken.Xue@amd.com>
KERNCZ GPIO is a new IP from AMD. it can be implemented in both x86 and ARM.
Current driver patch only support GPIO in x86.
[Moved back to <linux/gpio.h> header]
