path: root/drivers/pinctrl/pinctrl-falcon.c
2013-03-07pinctrl: Declare operation structures as constLaurent Pinchart
The pinconf, pinctrl and pinmux operation structures hold function pointers that are never modified. Declare them as const. Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-02-21Merge tag 'driver-core-3.9-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core patches from Greg Kroah-Hartman: "Here is the big driver core merge for 3.9-rc1 There are two major series here, both of which touch lots of drivers all over the kernel, and will cause you some merge conflicts: - add a new function called devm_ioremap_resource() to properly be able to check return values. - remove CONFIG_EXPERIMENTAL Other than those patches, there's not much here, some minor fixes and updates" Fix up trivial conflicts * tag 'driver-core-3.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (221 commits) base: memory: fix soft/hard_offline_page permissions drivercore: Fix ordering between deferred_probe and exiting initcalls backlight: fix class_find_device() arguments TTY: mark tty_get_device call with the proper const values driver-core: constify data for class_find_device() firmware: Ignore abort check when no user-helper is used firmware: Reduce ifdef CONFIG_FW_LOADER_USER_HELPER firmware: Make user-mode helper optional firmware: Refactoring for splitting user-mode helper code Driver core: treat unregistered bus_types as having no devices watchdog: Convert to devm_ioremap_resource() thermal: Convert to devm_ioremap_resource() spi: Convert to devm_ioremap_resource() power: Convert to devm_ioremap_resource() mtd: Convert to devm_ioremap_resource() mmc: Convert to devm_ioremap_resource() mfd: Convert to devm_ioremap_resource() media: Convert to devm_ioremap_resource() iommu: Convert to devm_ioremap_resource() drm: Convert to devm_ioremap_resource() ...
2013-02-05pinctrl/lantiq: add functionality to falcon_pinconf_dbg_showJohn Crispin
The current code only has a stub for falcon_pinconf_dbg_show. This patch adds proper functionality. Signed-off-by: Thomas Langer <thomas.langer@lantiq.com> Signed-off-by: John Crispin <blogic@openwrt.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-02-05pinctrl/lantiq: fix pinconfig parametersJohn Crispin
The Falcon driver only defined the pinconf parameters but did not pass them properly to the underlying api. Signed-off-by: Thomas Langer <thomas.langer@lantiq.com> Signed-off-by: John Crispin <blogic@openwrt.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-02-05pinctrl/lantiq: one of the boot leds was defined incorrectlyJohn Crispin
On the Falcon SoC the bootleds are located on pins 9->14. Signed-off-by: Thomas Langer <thomas.langer@lantiq.com> Signed-off-by: John Crispin <blogic@openwrt.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-02-05pinctrl/lantiq: only probe available pad controllersJohn Crispin
The template falcon.dtsi lists all 6 pad controllers that can be loaded. Only probe those that have status = "okay"; inside the dts file. Signed-off-by: John Crispin <blogic@openwrt.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-01-22pinctrl: Convert to devm_ioremap_resource()Thierry Reding
Convert all uses of devm_request_and_ioremap() to the newly introduced devm_ioremap_resource() which provides more consistent error handling. devm_ioremap_resource() provides its own error messages so all explicit error messages can be removed from the failure code paths. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Cc: Linus Walleij <linus.walleij@linaro.org> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-11pinctrl: Staticize pinconf_opsAxel Lin
They are not referenced outside respective driver. Signed-off-by: Axel Lin <axel.lin@ingics.com> Cc: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Simon Arlott <simon@fire.lp0.eu> Cc: John Crispin <blogic@openwrt.org> Cc: Shawn Guo <shawn.guo@linaro.org> Cc: Stephen Warren <swarren@wwwdotorg.org> Acked-by: Dong Aisheng <dong.aisheng@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-09-13OF: pinctrl: MIPS: lantiq: adds support for FALCON SoCJohn Crispin
Implement support for pinctrl on lantiq/falcon socs. The FALCON has 5 banks of up to 32 pins. Signed-off-by: John Crispin <blogic@openwrt.org> Signed-off-by: Thomas Langer <thomas.langer@lantiq.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Cc: devicetree-discuss@lists.ozlabs.org Cc: linux-kernel@vger.kernel.org
