[ Upstream commit 7af355e6715b325d8af29822f4c3dbecd7eeebec ]
Reference to 'sys2pci_np' should be dropped in all cases here, not only in
error handling path.
Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr>
The Makefile currently controlling compilation of this code is:
drivers/pinctrl/sirf/pinctrl-sirf.o
--> drivers/pinctrl/sirf/Makefile:obj-y += pinctrl-sirf.o
...meaning that it currently is not being built as a module by anyone.
Lets remove the couple traces of modular infrastructure use, so that
when reading the driver there is no doubt it is builtin-only.
We also delete the MODULE_LICENSE tag etc. since all that information
was (or is now) contained at the top of the file in the comments.
Cc: Linus Walleij <linus.walleij@linaro.org>
Cc: Rongjun Ying <rongjun.ying@csr.com>
Cc: Yuping Luo <yuping.luo@csr.com>
Cc: Barry Song <baohua@kernel.org>
Cc: linux-gpio@vger.kernel.org
drivers/pinctrl/sirf/pinctrl-atlas7.o
---> drivers/pinctrl/sirf/Makefile:obj-y += pinctrl-atlas7.o
We delete the MODULE_LICENSE tag etc. since all that information
is already contained at the top of the file in the comments.
of_find_node_by_name does an of_node_get on its return value,
so an of_node_put is needed on this value before the corresponding
variable goes out of scope.
The Coccinelle semantic patch used to make this change is as follows:
struct device_node *n;
struct device_node *n1;
statement S;
identifier f;
expression E;
constant C;
n = of_find_node_by_name(...)
if (!n) S
... when != of_node_put(n)
when != n1 = f(n,...)
when != E = n
when any
when strict
+ of_node_put(n);
return -C;
of_node_put(n);
n1 = f(n,...)
E = n
return ...;
Signed-off-by: Amitoj Kaur Chawla <amitoj1606@gmail.com>
fix spelling mistake, flaged -> flagged
This code is poking around in the gpio_chip:s internal structures
to achieve some kind of pin to GPIO mappings.
- It is wrong to poke around in these structs and the pinctrl
maintainer was stupid to let it pass unnoticed, mea culpa.
- The right interface to use is gpiochip_add_pin_range()
- The code appears unused: the pin control part of the driver
is not adding any ranges, so we're iterating over an empty
list. Maybe it is poking around in some other pin controllers
GPIO ranges, and that's just totally wrong, again use
gpiochip_add_pin_range() and specify the right pin
controller.
Cc: Guoying Zhang <Guoying.Zhang@csr.com>
Cc: Wei Chen <Wei.Chen@csr.com>
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio
Pull GPIO updates from Linus Walleij:
"Here is the bulk of GPIO changes for v4.5.
Notably there are big refactorings mostly by myself, aimed at getting
the gpio_chip into a shape that makes me believe I can proceed to
preserve state for a proper userspace ABI (character device) that has
already been proposed once, but resulted in the feedback that I need
to go back and restructure stuff. So I've been restructuring stuff.
On the way I ran into brokenness (return code from the get_value()
callback) and had to fix it. Also, refactored generic GPIO to be
simpler.
Some of that is still waiting to trickle down from the subsystems all
over the kernel that provide random gpio_chips, I've touched every
single GPIO driver in the kernel now, oh man I didn't know I was
responsible for so much...
Apart from that we're churning along as usual.
I took some effort to test and retest so it should merge nicely and we
shook out a couple of bugs in -next.
Infrastructural changes:
- In struct gpio_chip, rename the .dev node to .parent to better
reflect the fact that this is not the GPIO struct device
abstraction. We will add that soon so this would be totallt
confusing.
- It was noted that the driver .get_value() callbacks was sometimes
reporting negative -ERR values to the gpiolib core, expecting them
to be propagated to consumer gpiod_get_value() and gpio_get_value()
calls. This was not happening, so as there was a mess of drivers
returning negative errors and some returning "anything else than
zero" to indicate that a line was active. As some would have bit
31 set to indicate "line active" it clashed with negative error
codes. This is fixed by the largeish series clamping values in all
drivers with !!value to [0,1] and then augmenting the code to
propagate error codes to consumers. (Includes some ACKed patches
in other subsystems.)
- Add a void *data pointer to struct gpio_chip. The container_of()
design pattern is indeed very nice, but we want to reform the
struct gpio_chip to be a non-volative, stateless business, and keep
states internal to the gpiolib to be able to hold on to the state
when adding a proper userspace ABI (character device) further down
the road. To achieve this, drivers need a handle at the internal
state that is not dependent on their struct gpio_chip() so we add
gpiochip_add_data() and gpiochip_get_data() following the pattern
of many other subsystems. All the "use gpiochip data pointer"
patches transforms drivers to this scheme.
- The Generic GPIO chip header has been merged into the general
<linux/gpio/driver.h> header, and the custom header for that
removed. Instead of having a separate mm_gpio_chip struct for
these generic drivers, merge that into struct gpio_chip,
simplifying the code and removing the need for separate and
confusing includes.
Misc improvements:
- Stabilize the way GPIOs are looked up from the ACPI legacy
specification.
- Incremental driver features for PXA, PCA953X, Lantiq (patches from
the OpenWRT community), RCAR, Zynq, PL061, 104-idi-48
New drivers:
- Add a GPIO chip to the ALSA SoC AC97 driver.
- Add a new Broadcom NSP SoC driver (this lands in the pinctrl dir,
but the branch is merged here too to account for infrastructural
changes).
- The sx150x driver now supports the sx1502"
* tag 'gpio-v4.5-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (220 commits)
gpio: generic: make bgpio_pdata always visible
gpiolib: fix chip order in gpio list
gpio: mpc8xxx: Do not use gpiochip_get_data() in mpc8xxx_gpio_save_regs()
gpio: mm-lantiq: Do not use gpiochip_get_data() in ltq_mm_save_regs()
gpio: brcmstb: Allow building driver for BMIPS_GENERIC
gpio: brcmstb: Set endian flags for big-endian MIPS
gpio: moxart: fix build regression
gpio: xilinx: Do not use gpiochip_get_data() in xgpio_save_regs()
leds: pca9532: use gpiochip data pointer
leds: tca6507: use gpiochip data pointer
hid: cp2112: use gpiochip data pointer
bcma: gpio: use gpiochip data pointer
avr32: gpio: use gpiochip data pointer
video: fbdev: via: use gpiochip data pointer
gpio: pch: Optimize pch_gpio_get()
Revert "pinctrl: lantiq: Implement gpio_chip.to_irq"
pinctrl: nsp-gpio: use gpiochip data pointer
pinctrl: vt8500-wmt: use gpiochip data pointer
pinctrl: exynos5440: use gpiochip data pointer
pinctrl: at91-pio4: use gpiochip data pointer
This makes the driver use the data pointer added to the gpio_chip
to store a pointer to the state container instead of relying on
container_of().
container_of().
for_each_child_of_node performs an of_node_get on each iteration, so a
return from the loop requires an of_node_put.
A simplified version of the semantic patch that fixes this problem is as
follows (http://coccinelle.lip6.fr):
// <smpl>
local idexpression n;
expression e,e1;
for_each_child_of_node(e1,n) {
of_node_put(n);
e = n
return n;
+ of_node_put(n);
? return ...;
// </smpl>
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
DR needs use the pulse counter direction pin as common gpio
function.
Signed-off-by: Guoying Zhang <Guoying.Zhang@csr.com>
Signed-off-by: Barry Song <Baohua.Song@csr.com>
The vip low 8bit mode and vip high 8 bit mode pin groups had missed
3 pins:vip_vsync, vip_hsync and vip_pxclk. Without these 3 pins, the
vip could not work properly.
Now we add these 3 pins into these two pin groups.
Signed-off-by: Wei Chen <Wei.Chen@csr.com>
Remove write-protect and chip-selector pins from nand pin group.
And then create two separate pin groups for these two pin.
So the nand driver can choose correct pin groups as board desgin:
For example:
1. nand without wp&cs:
nand@17050000 {
pinctrl-0 = <&nd_df_basic_pmx>;
2. nand with wp
nand@17050000 {
pinctrl-0 = <&nd_df_basic_pmx &nd_df_wp_pmx>;
3. nand with cs:
nand@17050000 {
pinctrl-0 = <&nd_df_basic_pmx &nd_df_cs_pmx>;
4. nand with wp&cs:
nand@17050000 {
pinctrl-0 = <&nd_df_basic_pmx &nd_df_wp_pmx &nd_df_cs_pmx>;
The sd9 pin mux with sd3 and it is selected by SYS2PCI_SDIO9SEL.
This makes the codes ugly since the register is not in pinctrl
module.
Signed-off-by: Yonghui Zhang <yonghui.zhang@csr.com>
The nand in atlas7 has two chip select line. But in most time, the
nand only has one chip, so only one chip select line is enough.
The nand driver select this new pin group can free one chip select
line for other modules to avoid pin conflict.
The name .dev in a struct is normally reserved for a struct device
that is let us say a superclass to the thing described by the struct.
struct gpio_chip stands out by confusingly using a struct device *dev
to point to the parent device (such as a platform_device) that
represents the hardware. As we want to give gpio_chip:s real devices,
this is not working. We need to rename this member to parent.
This was done by two coccinelle scripts, I guess it is possible to
combine them into one, but I don't know such stuff. They look like
this:
struct gpio_chip *var;
-var->dev
+var->parent
and:
struct gpio_chip var;
-var.dev
+var.parent
and:
struct bgpio_chip *var;
-var->gc.dev
+var->gc.parent
Plus a few instances of bgpio that I couldn't figure out how
to teach Coccinelle to rewrite.
This patch hits all over the place, but I *strongly* prefer this
solution to any piecemal approaches that just exercise patch
mechanics all over the place. It mainly hits drivers/gpio and
drivers/pinctrl which is my own backyard anyway.
Cc: Haavard Skinnemoen <hskinnemoen@gmail.com>
Cc: Rafał Miłecki <zajec5@gmail.com>
Cc: Richard Purdie <rpurdie@rpsys.net>
Cc: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
Cc: Alek Du <alek.du@intel.com>
Cc: Jaroslav Kysela <perex@perex.cz>
Cc: Takashi Iwai <tiwai@suse.com>
Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Acked-by: Lee Jones <lee.jones@linaro.org>
Acked-by: Jiri Kosina <jkosina@suse.cz>
Acked-by: Hans-Christian Egtvedt <egtvedt@samfundet.no>
Acked-by: Jacek Anaszewski <j.anaszewski@samsung.com>
The the pin groups and pin functions have been changed
in atlas7 step B soc. We have to update the driver
to support step B chip.
Changes:
1. add 5 jtag pins to IOC_TOP:
"jtag_tdo", "jtag_tms","jtag_tck", "jtag_tdi", "jtag_trstn"
these 5 pins can be mutiplex with other functions, so we
have to conver these 5 pins in pinmux.
2. add pin groups for audio digmic, audio spdif, can transceiver
en, can transceiver stb, i2s0, i2s1 and jtag.
3. serval pins can be located to more PADs:
audio_uart0_urfs, audio_uart1_urfs, audio_uart2_urfs,
audio_uart2_urxd, audio_uart2_usclk, audio_uart2_utfs,
audio_uart2_utxd, can0_rxd, can0_txd, can1_rxd, can1_txd
jtag_ntrst, jtag_swdiotms, jtag_tck, jtag_tdi, jtag_tdo,
pw_cko0, pw_cko1, pw_i2s01, pw_pwm0, pw_pwm1, sd2_cdb,
sd2_wpb, uart2_cts, uart2_rts, uart2_rxd, uart2_txd,
uart3_cts, uart3_rts, uart3_rxd, uart3_txd, uart4_cts,
uart4_rts, usb0_drvvbus, usb1_drvvbus.
Because of Changes#3, some functions should have more than one
pin groups. So we have to split the original pin group to serval
pin groups.
For example:
audio_uart0 has 5 pins, on STEPA, each of these 5 pins only has
one related PAD. But on STEPB, audio_uart0_urfs has 4 related
PAD.
So we place the 4 pins with one PAD into a single pin group:
audio_uart0_basic_group.
and place urfs pin wtih different PADs to 4 different pin groups:
audio_uart0_urfs_group0, ..., audio_uart0_urfs_group3
A full audio_uart0 pin group can be:
pinctrl-0 = <&audio_uart0_basic_group &audio_uart0_urfs_group0>;
If audio_uart0 pin group encountered some confiction, we only have
to change the urfs group:
pinctrl-0 = <&audio_uart0_basic_group &audio_uart0_urfs_group2>;
Most interrupt flow handlers do not use the irq argument. Those few
which use it can retrieve the irq number from the irq descriptor.
Remove the argument.
Search and replace was done with coccinelle and some extra helper
scripts around it. Thanks to Julia for her help!
Cc: Julia Lawall <Julia.Lawall@lip6.fr>
Cc: Jiang Liu <jiang.liu@linux.intel.com>
To set/get atlas7 pull & drive strength, we use lots of if/else
to check pad type. But except mask value or immediate value, all
actions in these conditional branches are the same.
So we use predefined pull info table and drive strength table
to reduce these redundancy code.
We had not implemented the pm interface of atlas7 pinctrl
and gpio drivers. So when system resumes from sleep, all
pin configuration and gpio status will be lost.
Now, we implement these interfaces to support pm.
At the same time, this patch also drops a lot of if-else
by look-up table for getting and setting pull.
The irq argument of most interrupt flow handlers is unused or merily
used instead of a local variable. The handlers which need the irq
argument can retrieve the irq number from the irq descriptor.
Search and update was done with coccinelle and the invaluable help of
Julia Lawall.
Use irq_desc_get_xxx() to avoid redundant lookup of irq_desc while we
already have a pointer to corresponding irq_desc.
Signed-off-by: Jiang Liu <jiang.liu@linux.intel.com>
platform_driver does not need to set an owner because
platform_driver_register() will set it.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Currently, pinctrl_register() just returns NULL on error, so the
callers can not know the exact reason of the failure.
Some of the pinctrl drivers return -EINVAL, some -ENODEV, and some
-ENOMEM on error of pinctrl_register(), although the error code
might be different from the real cause of the error.
This commit reworks pinctrl_register() to return the appropriate
error code and modifies all of the pinctrl drivers to use IS_ERR()
for the error checking and PTR_ERR() for getting the error code.
Acked-by: Patrice Chotard <patrice.chotard@st.com>
Acked-by: Thierry Reding <treding@nvidia.com>
Acked-by: Heiko Stuebner <heiko@sntech.de>
Tested-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Acked-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Acked-by: Lee Jones <lee@kernel.org>
Acked-by: Sören Brinkmann <soren.brinkmann@xilinx.com>
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Acked-by: Ray Jui <rjui@broadcom.com>
Acked-by: Antoine Tenart <antoine.tenart@free-electrons.com>
Acked-by: Hongzhou Yang <hongzhou.yang@mediatek.com>
Acked-by: Wei Chen <Wei.Chen@csr.com>
platform_driver does not need to set the owner field, as it will be
populated by the driver core, so just remove it.
The semantic patch that makes this change is available
in scripts/coccinelle/api/platform_no_drv_owner.cocci.
The Pinctrl module (ioc) controls the Pad's function select
(each pad can have 8 functions), Pad's Drive Strength, Pad's
Pull Select and Pad's Input Disable status.
The ioc has two modules, ioc_top & ioc_rtc. Both of these two
modules have function select/clear, Pull select and Drive
Strength registers. But only ioc_rtc has input-disable
registers. The Pads on ioc_top have to access ioc_rtc to set
their input-disable status and intpu-disable-value.
So have to use one ioc driver instance to drive these two
ioc modules at the same time, and each ioc module will be
treat as one bank on the "IOC Device".
The GPIO Controller controls the GPIO status if the Pad has
been config as GPIO by Pinctrl already. Includes the GPIO
Input/output, Interrupt type, Interrupt Status, and Set/Get
Values.
The GPIO pull up/down are controlled by Pinctrl.
There are 7 GPIO Groups and splited into 3 MACROs in atlas7.
The GPIO Groups in one MACRO share one GPIO controllers, each
GPIO Group are treated as one GPIO bank.
For example:
In VDIFM macro, there is one GPIO Controller, it has 3 banks
to control 3 gpio groups. Its gpio name space is from 0 to 95.
The Device Tree can be written as following:
gpio-ranges = <&pinctrl 0 0 0>,
<&pinctrl 32 0 0>,
<&pinctrl 64 0 0>;
gpio-ranges-group-names = "gnss_gpio_grp",
"lcd_vip_gpio_grp",
"sdio_i2s_gpio_grp";
bank#0 is from 0~31, the pins are from pinctrl's "gnss_gpio_grp".
bank#2 is from 32~63, the pins are from pinctrl's "lcd_vip_gpio_grp".
bank#3 is from 64~95, the pins are from pinctrl's "sdio_i2s_gpio_grp".
Instead of referring to a global static variable for the sgpio
locking, use the state container to contain the lock.
Fix typo, "flaged" -> "flagged"
marco chip has been dropped, clear its support.
A platform_driver does not need to set an owner, it will be populated by the
driver core.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
Pull GPIO changes from Linus Walleij:
"This is the bulk of GPIO changes for the v3.18 development cycle:
- Increase the default ARCH_NR_GPIO from 256 to 512. This was done
to avoid having a custom <asm/gpio.h> header for the x86
architecture - GPIO is custom and complicated enough as it is
already! We want to move to a radix to store the descriptors going
forward, and finally get rid of this fixed array size altogether.
- Endgame patching of the gpio_remove() semantics initiated by
Abdoulaye Berthe. It is not accepted by the system that the
removal of a GPIO chip fails during eg reboot or shutdown, and
therefore the return value has now painfully been refactored away.
For special cases like GPIO expanders on a hot-pluggable bus like
USB, we may later add some gpiochip_try_remove() call, but for the
cases we have now, return values are moot.
- Some incremental refactoring of the gpiolib core and ACPI GPIO
library for more descriptor usage.
- Refactor the chained IRQ handler set-up method to handle also
threaded, nested interrupts and set up the parent IRQ correctly.
Switch STMPE and TC3589x drivers to use this registration method.
- Add a .irq_not_threaded flag to the struct gpio_chip, so that also
GPIO expanders that block but are still not using threaded IRQ
handlers.
- New drivers for the ARM64 X-Gene SoC GPIO controller.
- The syscon GPIO driver has been improved to handle the "DSP GPIO"
found on the TI Keystone 2 SoC:s.
- ADNP driver switched to use gpiolib irqchip helpers.
- Refactor the DWAPB driver to support being instantiated from and
MFD cell (platform device).
- Incremental feature improvement in the Zynq, MCP23S08, DWAPB, OMAP,
Xilinx and Crystalcove drivers.
- Various minor fixes"
* tag 'gpio-v3.18-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (52 commits)
gpio: pch: Build context save/restore only for PM
pinctrl: abx500: get rid of unused variable
gpio: ks8695: fix 'else should follow close brace '}''
gpio: stmpe: add verbose debug code
gpio: stmpe: fix up interrupt enable logic
gpio: staticize xway_stp_init()
gpio: handle also nested irqchips in the chained handler set-up
gpio: set parent irq on chained handlers
gpiolib: irqchip: use irq_find_mapping while removing irqchip
gpio: crystalcove: support virtual GPIO
pinctrl: bcm281xx: make Kconfig dependency more strict
gpio: kona: enable only on BCM_MOBILE or for compile testing
gpio, bcm-kona, LLVMLinux: Remove use of __initconst
gpio: Fix ngpio in gpio-xilinx driver
gpio: dwapb: fix pointer to integer cast
gpio: xgene: Remove unneeded #ifdef CONFIG_OF guard
gpio: xgene: Remove unneeded forward declation for struct xgene_gpio
gpio: xgene: Fix missing spin_lock_init()
gpio: ks8695: fix switch case indentation
gpiolib: add irq_not_threaded flag to gpio_chip
Some drivers accidentally still use the return value from
gpiochip_remove(). Get rid of them so we can simplify this function
and get rid of the return value.
Cc: Abdoulaye Berthe <berthe.ab@gmail.com>
we have done that for atlas6 in commit ed36c1a, 086b8904 etc. here we
do same things for prima2.
Signed-off-by: Rongjun Ying <rongjun.ying@csr.com>
This patch releases gpiochip related resources by calling
gpiochip_remove when gpiochip_irqchip_add fails.
CC: Linus Walleij <linus.walleij@linaro.org>
CC: Barry Song <Baohua.Song@csr.com>
CC: Rongjun Ying <rongjun.ying@csr.com>
CC: Yuping Luo <yuping.luo@csr.com>
Signed-off-by: Pramod Gurav <pramod.gurav@smartplayin.com>
commit 2243a87d90b42eb38bc281957df3e57c712b5e56
"pinctrl: avoid duplicated calling enable_pinmux_setting for a pin"
removed the .disable callback from the struct pinmux_ops,
making the .enable() callback the only remaining callback.
However .enable() is a bad name as it seems to imply that a
muxing can also be disabled. Rename the callback to .set_mux()
and also take this opportunity to clean out any remaining
mentions of .disable() from the documentation.
Acked-by: Bjorn Andersson <bjorn.andersson@sonymobile.com>
Acked-by: Fan Wu <fwu@marvell.com>
The I2S controller can use the external clock as reference clock with
master mode. But based on different hardware or software design, this
external clock might be needed or not needed.
So the external input pin can be an independent pinctrl group, and the
card driver can decice to get it or not.
The I2S controller can output mclk to external audio codec. But by
hardware design, some codecs need mclk and some codecs do not need
mclk. So the mclk pin can be an independent pinctrl group, and the
card driver can get it or not based on boards.
According to key customer's requirement, fix "line over 80
characters".
Signed-off-by: Bin Shi <Bin.Shi@csr.com>
Signed-off-by: Qipan Li <Qipan.Li@csr.com>
this patch fixes:
WARNING: quoted string split across lines
902: FILE: drivers/pinctrl/sirf/pinctrl-sirf.c:902:
+MODULE_AUTHOR("Rongjun Ying <rongjun.ying@csr.com>, "
+ "Yuping Luo <yuping.luo@csr.com>, "
903: FILE: drivers/pinctrl/sirf/pinctrl-sirf.c:903:
+ "Barry Song <baohua.song@csr.com>");
What the patch does:
1. Call pinmux_disable_setting ahead of pinmux_enable_setting
each time pinctrl_select_state is called
2. Remove the HW disable operation in pinmux_disable_setting function.
3. Remove the disable ops in struct pinmux_ops
4. Remove all the disable ops users in current code base.
Notes:
1. Great thanks for the suggestion from Linus, Tony Lindgren and
Stephen Warren and Everyone that shared comments on this patch.
2. The patch also includes comment fixes from Stephen Warren.
The reason why we do this:
1. To avoid duplicated calling of the enable_setting operation
without disabling operation inbetween which will let the pin
descriptor desc->mux_usecount increase monotonously.
2. The HW pin disable operation is not useful for any of the
existing platforms.
And this can be used to avoid the HW glitch after using the
item #1 modification.
In the following case, the issue can be reproduced:
1. There is a driver that need to switch pin state dynamically,
e.g. between "sleep" and "default" state
2. The pin setting configuration in a DTS node may be like this:
component a {
pinctrl-names = "default", "sleep";
pinctrl-0 = <&a_grp_setting &c_grp_setting>;
pinctrl-1 = <&b_grp_setting &c_grp_setting>;
The "c_grp_setting" config node is totally identical, maybe like
following one:
c_grp_setting: c_grp_setting {
pinctrl-single,pins = <GPIO48 AF6>;
3. When switching the pin state in the following official pinctrl
sequence:
pin = pinctrl_get();
state = pinctrl_lookup_state(wanted_state);
pinctrl_select_state(state);
pinctrl_put();
Test Result:
1. The switch is completed as expected, that is: the device's
pin configuration is changed according to the description in the
"wanted_state" group setting
2. The "desc->mux_usecount" of the corresponding pins in "c_group"
is increased without being decreased, because the "desc" is for
each physical pin while the setting is for each setting node
in the DTS.
Thus, if the "c_grp_setting" in pinctrl-0 is not disabled ahead
of enabling "c_grp_setting" in pinctrl-1, the desc->mux_usecount
will keep increasing without any chance to be decreased.
According to the comments in the original code, only the setting,
in old state but not in new state, will be "disabled" (calling
pinmux_disable_setting), which is correct logic but not intact. We
still need consider case that the setting is in both old state
and new state. We can do this in the following two ways:
1. Avoid to "enable"(calling pinmux_enable_setting) the "same pin
setting" repeatedly
2. "Disable"(calling pinmux_disable_setting) the "same pin setting",
actually two setting instances, ahead of enabling them.
Analysis:
1. The solution #2 is better because it can avoid too much
iteration.
2. If we disable all of the settings in the old state and one of
the setting(s) exist in the new state, the pins mux function
change may happen when some SoC vendors defined the
"pinctrl-single,function-off"
in their DTS file.
old_setting => disabled_setting => new_setting.
3. In the pinmux framework, when a pin state is switched, the
setting in the old state should be marked as "disabled".
Conclusion:
1. To Remove the HW disabling operation to above the glitch mentioned
above.
2. Handle the issue mentioned above by disabling all of the settings
in old state and then enable the all of the settings in new state.
Signed-off-by: Fan Wu <fwu@marvell.com>
Acked-by: Maxime Coquelin <maxime.coquelin@st.com>
Commit 294d1351ff47726f0f110b88e816cbafe89512fb
"pinctrl: sirf: switch to using allocated state container"
caused a build conflict due to a bad conflict resolution
when cherry-picking the patch. Fix it up.
Cc: Barry Song <Baohua.Song@csr.com>
This rewrites the SIRF pinctrl driver to allocate a state container
for the GPIO chip, just as is done for the pin controller, and
use the gpiochip_add_pin_range() to add the range from the gpiochip
side rather than adding the range from the pinctrl side.
All resulting changes are done in order to pass around a state
container rather than refer to a static global object.
Acked-by: Barry Song <Baohua.Song@csr.com>
The patch 7420d2d09b12: "pinctrl: sirf: switch driver to use gpiolib
irqchip helpers" from Apr 15, 2014, leads to the following static
checker warning:
drivers/pinctrl/sirf/pinctrl-sirf.c:578 sirfsoc_gpio_handle_irq()
warn: buffer overflow 'sgpio_chip.sgpio_bank' 5 <= 31
Cc: Dan Carpenter <dan.carpenter@oracle.com>
This switches the SiRF pinctrl driver over to using the gpiolib
irqchip helpers simplifying some of the code.
all gpio banks are in one chip, that makes software clean in mapping
irq and gpio.
The sirfsoc_irqchip_to_bank() is obviously misnamed, as it is
not converting an irqchip to a bank but converts a gpiochip
to a bank so rename it sirfsoc_gpiochip_to_bank().
Pull bulk of gpio updates from Linus Walleij:
"A pretty big chunk of changes this time, but it has all been on
rotation in linux-next and had some testing. Of course there will be
some amount of fixes on top...
- Merged in a branch of irqchip changes from Thomas Gleixner: we need
to have new callbacks from the irqchip to determine if the GPIO
line will be eligible for IRQs, and this callback must be able to
say "no". After some thinking I got the branch from tglx and have
switched all current users over to use this.
- Based on tglx patches, we have added some generic irqchip helpers
in the gpiolib core. These will help centralize code when GPIO
drivers have simple chained/cascaded IRQs. Drivers will still
define their irqchip vtables, but the gpiolib core will take care
of irqdomain set-up, mapping from local offsets to Linux irqs, and
reserve resources by marking the GPIO lines for IRQs.
- Initially the PL061 and Nomadik GPIO/pin control drivers have been
switched over to use the new gpiochip-to-irqchip infrastructure
with more drivers expected for the next kernel cycle. The
factoring of just two drivers still makes it worth it so it is
already a win.
- A new driver for the Synopsys DesignWare APB GPIO block.
- Modify the DaVinci GPIO driver to be reusable also for the new TI
Keystone architecture.
- A new driver for the LSI ZEVIO SoCs.
- Delete the obsolte tnetv107x driver.
- Some incremental work on GPIO descriptors: have
gpiod_direction_output() use a logical level, respecting assertion
polarity through ACTIVE_LOW flags, adding gpiod_direction_output_raw()
for the case where you want to set that very value. Add
gpiochip_get_desc() to fetch a GPIO descriptor from a specific
offset on a certain chip inside driver code.
- Switch ACPI GPIO code over to using gpiochip_get_desc() and get rid
of gpio_to_desc().
- The ACPI GPIO event handling code has been reworked after
encountering an actual real life implementation.
- Support for ACPI GPIO operation regions.
- Generic GPIO chips can now be assigned labels/names from platform
data.
- We now clamp values returned from GPIO drivers to the boolean [0,1]
range.
- Some improved documentation on how to use the polarity flag was
added.
- a large slew of incremental driver updates and non-critical fixes.
Some targeted for stable"
* tag 'gpio-v3.15-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (80 commits)
gpio: rcar: Add helper variable dev = &pdev->dev
gpio-lynxpoint: force gpio_get() to return "1" and "0" only
gpio: unmap gpio irqs properly
pch_gpio: set value before enabling output direction
gpio: moxart: Actually set output state in moxart_gpio_direction_output()
gpio: moxart: Avoid forward declaration
gpio: mxs: Allow for recursive enable_irq_wake() call
gpio: samsung: Add missing "break" statement
gpio: twl4030: Remove redundant assignment
gpio: dwapb: correct gpio-cells in binding document
gpio: iop: fix devm_ioremap_resource() return value checking
pinctrl: coh901: convert driver to use gpiolib irqchip
pinctrl: nomadik: convert driver to use gpiolib irqchip
gpio: pl061: convert driver to use gpiolib irqchip
gpio: add IRQ chip helpers in gpiolib
pinctrl: nomadik: factor in platform data container
pinctrl: nomadik: rename secondary to latent
gpio: Driver for SYSCON-based GPIOs
gpio: generic: Use platform_device_id->driver_data field for driver flags
pinctrl: coh901: move irq line locking to resource callbacks
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl
Pull pin control bulk changes from Linus Walleij:
"Pin control bulk changes for the v3.15 series, no new core
functionality this time, just incremental driver updates:
- A large refactoring of the MVEBU (Marvell) driver.
- A large refactoring of the Tegra (nVidia) driver.
- GPIO interrupt including soft edges support in the STi driver.
- Misc updates to PFC (Renesas), AT91, ADI2 (Blackfin),
pinctrl-single, sirf (CSR), msm (Qualcomm), Exynos (Samsung), sunxi
(AllWinner), i.MX (Freescale), Baytrail"
* tag 'pinctrl-v3.15-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl: (72 commits)
pinctrl: tegra: add some missing Tegra114 entries
pinctrl: tegra: fix some mistakes in Tegra124
pinctrl: msm: fix up out-of-order merge conflict
pinctrl: st: Fix error check for of_irq_to_resource usage
pinctrl: tegra: consistency cleanup
pinctrl: tegra: dynamically calculate function list of groups
pinctrl: tegra: init Tegra20/30 at module_init time
pinctrl: st: Use ARRAY_SIZE instead of raw value for number of delays
pinctrl: st: add pinctrl support for the STiH407 SoC
pinctrl: st: Enhance the controller to manage unavailable registers
pinctrl: msm: Simplify msm_config_reg() and callers
pinctrl: msm: Remove impossible WARN_ON()s
pinctrl: msm: Replace lookup tables with math
pinctrl: msm: Drop OF_IRQ dependency
pinctrl: msm: Drop unused includes
pinctrl: msm: Check for ngpios > MAX_NR_GPIO
pinctrl: msm: Silence recursive lockdep warning
pinctrl: mvebu: silence WARN to dev_warn
pinctrl: msm: drop wake_irqs bitmap
pinctrl-baytrail: add function mux checking in gpio pin request
This switches all GPIO and pin control drivers with irqchips
that were using .startup() and .shutdown() callbacks to lock
GPIO lines for IRQ usage over to using the .request_resources()
and .release_resources() callbacks just introduced into the
irqchip vtable.
Cc: Jean-Jacques Hiblot <jjhiblot@traphandler.com>
commit 655dada6277991 causes kernel panic, this patch fixes it.
[ 1.197816] [ffffffee] *pgd=0d7fd821, *pte=00000000, *ppte=00000000
[ 1.204070] Internal error: Oops: 17 [#1] PREEMPT SMP ARM
[ 1.209447] Modules linked in:
[ 1.212490] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.14.0-rc1 #3
[ 1.218737] task: cd03c000 ti: cd040000 task.ti: cd040000
[ 1.224127] PC is at gpiod_lock_as_irq+0xc/0x64
[ 1.228634] LR is at sirfsoc_gpio_irq_startup+0x18/0x44
[ 1.233842] pc : [<c01d3990>] lr : [<c01d1c38>] psr: a0000193
[ 1.233842] sp : cd041d30 ip : 00000000 fp : 00000000
[ 1.245296] r10: 00000000 r9 : cd023db4 r8 : 60000113
[ 1.250505] r7 : 0000003e r6 : cd023dd4 r5 : c06bfa54 r4 : cd023d80
[ 1.257014] r3 : 00000020 r2 : 00000000 r1 : ffffffea r0 : ffffffea
[ 1.263526] Flags: NzCv IRQs off FIQs on Mode SVC_32 ISA ARM Segment kernel
[ 1.270903] Control: 10c53c7d Table: 00004059 DAC: 00000015
[ 1.276631] Process swapper/0 (pid: 1, stack limit = 0xcd040240)
[ 1.282620] Stack: (0xcd041d30 to 0xcd042000)
[ 1.286963] 1d20: cd023d80 c01d1c38 c01d1c20 cd023d80
[ 1.295124] 1d40: 00000001 c0068438 cd023d80 ccb6d880 cd023dd4 c0067044 0000718e c006719c
[ 1.303283] 1d60: 00000800 00000083 ccb6d880 cd023d80 c02b41d8 00000083 0000003e ccb7c410
[ 1.311442] 1d80: 00000000 c00671dc 00000083 0000003e c02b41d8 cd3dd5c0 0000003e ccb7c634
[ 1.319601] 1da0: cd040030 c00672a8 cd3dd5c0 ccb7c410 ccb6d340 ccb7c410 ccb6d340 cd3dd400
[ 1.327760] 1dc0: cd3dd410 c02b4434 ccb7c410 c01265a8 00000001 cd3dd410 c0687108 00000000
[ 1.335919] 1de0: c0687108 00000000 00000000 c0240170 c0240158 cd3dd410 c06c30d0 c023e8bc
[ 1.344079] 1e00: c023e9d4 00000000 cd3dd410 c023e9d4 c0682150 c023cf88 cd003e98 cd2d50c4
[ 1.352238] 1e20: cd3dd410 cd3dd444 c06822f0 c023e768 cd3dd418 cd3dd410 c06822f0 c023de14
[ 1.360397] 1e40: cd3dd418 00000000 cd3dd410 c023c398 cd041e78 cd041ea8 cd3dd400 cd3dd410
[ 1.368556] 1e60: 00000083 00000000 cd3dd400 cd3dd410 00000083 000000c8 c04e00c8 c023fee8
[ 1.376715] 1e80: 00000000 cd041ea8 cd3dd400 00000001 00000083 c024048c c0435ef8 c0434dec
[ 1.384874] 1ea0: c068da58 c04c6d04 c0682150 c0435ef8 ffffffff 00000000 00000000 c068da58
[ 1.393033] 1ec0: 00000020 00000000 00000000 00000000 c05dabb8 00000007 c068d640 c068d640
[ 1.401193] 1ee0: c04c247c c04c249c 00000000 c00088e8 cd004c00 c043bbb8 cd029180 c03812a0
[ 1.409352] 1f00: 00000000 00000000 60000113 c0673728 60000113 c0673728 00000000 00000000
[ 1.417511] 1f20: cd7fce01 c0390a54 00000065 c003a81c c049e8bc 00000007 cd7fce0e 00000007
[ 1.425670] 1f40: 00000000 c05dabb8 00000007 c068d640 c068d640 c04c050c c04e00c8 00000065
[ 1.433829] 1f60: c04e00c0 c04c0c54 00000007 00000007 c04c050c c037d8fc cd03c000 c004322c
[ 1.441988] 1f80: c0662b40 0000d640 c03737c0 00000000 00000000 00000000 00000000 00000000
[ 1.450147] 1fa0: 00000000 c03737cc 00000000 c000e478 00000000 00000000 00000000 00000000
[ 1.458307] 1fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.466467] 1fe0: 00000000 00000000 00000000 00000000 00000013 00000000 0002d481 05014092
[ 1.474640] [<c01d3990>] (gpiod_lock_as_irq) from [<c01d1c38>] (sirfsoc_gpio_irq_startup+0x18/0x44)
[ 1.483661] [<c01d1c38>] (sirfsoc_gpio_irq_startup) from [<c0068438>] (irq_startup+0x34/0x6c)
[ 1.492163] [<c0068438>] (irq_startup) from [<c0067044>] (__setup_irq+0x450/0x4b8)
[ 1.499714] [<c0067044>] (__setup_irq) from [<c00671dc>] (request_threaded_irq+0xa8/0x128)
[ 1.507960] [<c00671dc>] (request_threaded_irq) from [<c00672a8>] (request_any_context_irq+0x4c/0x7c)
[ 1.517164] [<c00672a8>] (request_any_context_irq) from [<c02b4434>] (gpio_extcon_probe+0x144/0x1d4)
[ 1.526279] [<c02b4434>] (gpio_extcon_probe) from [<c0240170>] (platform_drv_probe+0x18/0x48)
[ 1.534783] [<c0240170>] (platform_drv_probe) from [<c023e8bc>] (driver_probe_device+0x120/0x238)
[ 1.543641] [<c023e8bc>] (driver_probe_device) from [<c023cf88>] (bus_for_each_drv+0x58/0x8c)
[ 1.552143] [<c023cf88>] (bus_for_each_drv) from [<c023e768>] (device_attach+0x74/0x88)
[ 1.560126] [<c023e768>] (device_attach) from [<c023de14>] (bus_probe_device+0x84/0xa8)
[ 1.568113] [<c023de14>] (bus_probe_device) from [<c023c398>] (device_add+0x440/0x520)
[ 1.576012] [<c023c398>] (device_add) from [<c023fee8>] (platform_device_add+0xb4/0x214)
[ 1.584084] [<c023fee8>] (platform_device_add) from [<c024048c>] (platform_device_register_full+0xb8/0xdc)
[ 1.593719] [<c024048c>] (platform_device_register_full) from [<c04c6d04>] (sirfsoc_init_late+0xec/0xf4)
[ 1.603185] [<c04c6d04>] (sirfsoc_init_late) from [<c04c249c>] (init_machine_late+0x20/0x28)
[ 1.611603] [<c04c249c>] (init_machine_late) from [<c00088e8>] (do_one_initcall+0xf8/0x144)
[ 1.619934] [<c00088e8>] (do_one_initcall) from [<c04c0c54>] (kernel_init_freeable+0x13c/0x1dc)
[ 1.628620] [<c04c0c54>] (kernel_init_freeable) from [<c03737cc>] (kernel_init+0xc/0x118)
