commit 1bd303dc04c3f744474e77c153575087b657f7e1 upstream.
The pingroups dump of debugfs hits WARN_ON() in pinctrl_groups_show().
Filling non-existing ports with '-1' turned out a bad idea.
Fixes: 336306ee1f2d ("pinctrl: uniphier: add UniPhier PH1-LD20 pinctrl driver")
commit 9592bc256d50481dfcdba93890e576a728fb373c upstream.
Fixes: 70f2f9c4cf25 ("pinctrl: uniphier: add UniPhier PH1-LD11 pinctrl driver")
commit df1539c25cce98e2ac69881958850c6535240707 upstream.
Fix the pin-mux values for the MDC, MDIO, MDIO_INTL, PHYRSTL pins.
Fixes: 1e359ab1285e ("pinctrl: uniphier: add Ethernet pin-mux settings")
Add the following Ethernet interfaces:
PH1-LD4: MII, RMII
PH1-Pro4: MII, RMII, RGMII
PH1-sLD8: MII, RMII (Built-in PHY is also supported)
ProXstream2: MII, RMII, RGMII
PH1-LD6b: RMII, RGMII
PH1-LD11: RMII (Built-in PHY is also supported)
PH1-LD20: RMII, RGMII
This SoC has no SD card controller. Nor does it have USB port3.
These pin-mux settings have no point.
These are input-only pins. They do not support drive controlling
in the first place.
According to the hardware document, setting the drive control is
prohibited for these pins (N-channel Open Drain pins). Set their
drive control attribute to "fixed".
My mistake in the initial support patches.
Add pin configuration and pinmux support for UniPhier PH1-LD20 SoC.
Add pin configuration and pinmux support for UniPhier PH1-LD11 SoC.
Currently, the UniPhier pinctrl driver itself is a syscon, but it
turned out much more reasonable to make it a child node of a syscon
because our syscon node consists of a bunch of system configuration
registers, not only pinctrl, but also phy, and misc registers.
It is difficult to split the node.
To allow to migrate to the new DT structure, this commit adds new
compatible strings to not disturb the existing DT. After a while,
the old binding will be removed.
This is needed to get access to UniPhier System Bus (external bus).
These pins do not support pin-muxing, but it is useful to support
pin configuration for them.
PH1-LD4 and PH1-sLD8 SoCs have pins that support pin configuration
(pin biasing, drive strength control), but not pin-muxing.
Allow to fill the mux value table with -1 for those pins; pins with
mux value -1 will be skipped in the pin-mux set function. The mux
value type should be changed from "unsigned" to "int" in order to
accommodate -1 as a special case.
Upcoming new pinctrl drivers for PH1-LD11 and PH-LD20 support input
signal gating for each pin. (While, existing ones only support it
per pin-group.) This commit updates the core part for that.
The core part of the UniPhier pinctrl driver needs to support a new
capability for upcoming UniPhier ARMv8 SoCs. This sometimes happens
because pinctrl drivers include really SoC-specific stuff.
This commit intends to tidy up SoC-specific parameters of the existing
drivers before adding the new one. Having just one flag would be
better than adding a new struct member every time a new SoC-specific
capability comes up.
At this time, there is one flag, UNIPHIER_PINCTRL_CAPS_DBGMUX_SEPARATE.
This capability (I'd say rather quirk) was added for PH1-Pro4 and
PH1-Pro5 as requirement from a customer. For those SoCs, one pin-mux
setting is controlled by the combination of two separate registers; the
LSB bits at register offset (8 * N) and the MSB bits at (8 * N + 4).
Because it is impossible to update two separate registers atomically,
the LOAD_PINCTRL register should be set in order to make the pin-mux
settings really effective.
Unfortunately, the pin number of the new SoC, PH1-LD11, is not
contiguous. The base frame work must be adjusted to support the new
SoC pinctrl driver. The pin_desc_get() exploits radix-tree for pin
look-up, so it works more efficiently with sparse pin space.
The new ARMv8 SoC, PH1-LD20, supports more fine-grained drive
strength control. Drive strength of some pins are controlled by
3-bit width registers (8-level granularity).
strength control. Some of the configuration registers on it have
3-bit width.
The feature will be supported in the next commit, but a problem is
that macro names are getting longer and longer in the current naming
scheme.
Before moving forward, this commit renames macros as follows:
UNIPHIER_PIN_DRV_4_8 -> UNIPHIER_PIN_DRV_1BIT
UNIPHIER_PIN_DRV_8_12_16_20 -> UNIPHIER_PIN_DRV_2BIT
UNIPHIER_PIN_DRV_FIXED_4 -> UNIPHIER_PIN_DRV_FIXED4
UNIPHIER_PIN_DRV_FIXED_5 -> UNIPHIER_PIN_DRV_FIXED5
UNIPHIER_PIN_DRV_FIXED_8 -> UNIPHIER_PIN_DRV_FIXED8
Currently, every SoC driver defines struct pinctrl_desc statically,
i.e. it consumes memory footprint even if it is not probed.
In multi-platform, many pinctrl drivers are linked (generally as
built-in objects), although only one of them is actually used.
So, it is reasonable to allocate memory dynamically where possible.
Every SoC driver sets the same name for struct pinctrl_desc and
platform_driver. The common probe function can set desc->name
instead of duplicating strings in each SoC driver.
The owner of the struct pinctrl_desc matches that of platform_driver.
Set it in the common probe function.
These pin tables were generated by parsing hardware documents with
a script, but the script had a bug. Fix the register offsets.
Make function/variable names match the file names for consistency.
Without this, reading the "pins" in the debugfs causes kernel BUG.
Fixes: 6e9088920258 ("pinctrl: UniPhier: add UniPhier pinctrl core support")
Use devm_pinctrl_register() for pin control registration and remove
need of .remove callback.
Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com>
Rename pinctrl_utils_dt_free_map to pinctrl_utils_free_map, since
it does not depend on device tree despite the current name. This
will enforce a consistent naming in pinctr-utils.c and will make
it clear it can be called from outside device tree (e.g. from
ACPI handling code).
Signed-off-by: Irina Tirdea <irina.tirdea@intel.com>
The current "CONFIG_PINCTRL_UNIPHIER_PH1_*" is too long. It would
not hurt to drop "PH1_" because "UNIPHIER_" already well specifies
the SoC family. Also, rename files for consistency.
Add COMPILE_TEST for the compilation test coverage.
There is a plan to support more pinctrl drivers for this SoC family.
Move the driver entries into a sub menu by using "menuconfig".
Also, add the missing dependency "depends on OF && MFD_SYSCON".
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl
Pull pin control updates from Linus Walleij:
"This is the big bulk of pin control changes for the v4.4 kernel
development cycle. Development pace is high in pin control again this
merge window. 28 contributors, 83 patches.
It hits a few sites outside the pin control subsystem:
- Device tree bindings in Documentation (as usual)
- MAINTAINERS
- drivers/base/* for the "init" state handling by Doug Anderson.
This has been ACKed by Greg.
- drivers/usb/renesas_usbhs/rcar2.c, for a dependent Renesas change
in the USB subsystem. This has been ACKed by both Greg and Felipe.
- arch/arm/boot/dts/sama5d2.dtsi - this should ideally have gone
through the ARM SoC tree but ended up here.
This time I am using Geert Uytterhoeven as submaintainer for SH PFC
since the are three-four people working in parallel with new Renesas
ASICs.
Summary of changes:
Infrastructure:
- Doug Anderson wrote a patch adding an "init" state different from
the "default" state for pin control state handling in the core
framework. This is applied before the driver's probe() call if
defined and takes precedence over "default". If both are defined,
"init" will be applied *before* probe() and "default" will be
applied *after* probe().
Significant subdriver improvements:
- SH PFC is switched to getting GPIO ranges from the device tree
ranges property on DT platforms.
- Got rid of CONFIG_ARCH_SHMOBILE_LEGACY, we are all modernized.
- Got rid of SH PFC hardcoded IRQ numbers.
- Allwinner sunxi external interrupt through the "r" controller.
- Moved the Cygnus driver to use DT-provided GPIO ranges.
New drivers:
- Atmel PIO4 pin controller for the SAMA4D2 family
New subdrivers:
- Rockchip RK3036 subdriver
- Renesas SH PFC R8A7795 subdriver
- Allwinner sunxi A83T PIO subdriver
- Freescale i.MX7d iomux lpsr subdriver
- Marvell Berlin BG4CT subdriver
- SiRF Atlas 7 step B SoC subdriver
- Intel Broxton SoC subdriver
Apart from this, the usual slew if syntactic and semantic fixes"
* tag 'pinctrl-v4.4-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl: (81 commits)
pinctrl: pinconf: remove needless loop
pinctrl: uniphier: guard uniphier directory with CONFIG_PINCTRL_UNIPHIER
pinctrl: zynq: fix UTF-8 errors
pinctrl: zynq: Initialize early
pinctrl: at91: add missing of_node_put
pinctrl: tegra-xusb: Correct lane mux options
pinctrl: intel: Add Intel Broxton pin controller support
pinctrl: intel: Allow requesting pins which are in ACPI mode as GPIOs
pinctrl: intel: Add support for multiple GPIO chips sharing the interrupt
drivers/pinctrl: Add the concept of an "init" state
pinctrl: uniphier: set input-enable before pin-muxing
pinctrl: cygnus: Add new compatible string for gpio controller driver
pinctrl: cygnus: Remove GPIO to Pinctrl pin mapping from driver
pinctrl: cygnus: Optional DT property to support pin mappings
pinctrl: sunxi: Add irq pinmuxing to sun6i "r" pincontroller
pinctrl: sunxi: Fix irq_of_xlate for the r_pio pinctrl block
pinctrl: sh-pfc: Remove obsolete r8a7778 platform_device_id entry
pinctrl: sh-pfc: Remove obsolete r8a7779 platform_device_id entry
pinctrl: sh-pfc: Stop including <linux/platform_data/gpio-rcar.h>
usb: renesas_usbhs: Remove unneeded #include <linux/platform_data/gpio-rcar.h>
CONFIG_PINCTRL_UNIPHIER is more suitable than CONFIG_ARCH_UNIPHIER
to guard the drivers/pinctrl/uniphier directory.
The current CONFIG_PINCTRL_UNIPHIER_CORE is a bit long
(it would break the indentation in drivers/pinctrl/Makefile),
so rename it into CONFIG_PINCTRL_UNIPHIER.
While IECTRL is disabled, input signals are pulled-down internally.
If pin-muxing is set up first, glitch signals (Low to High transition)
might be input to hardware blocks.
Bad case scenario:
[1] The hardware block is already running before pinctrl is handled.
(the reset is de-asserted by default or by a firmware, for example)
[2] The pin-muxing is set up. The input signals to hardware block
are pulled-down by the chip-internal biasing.
[3] The pins are input-enabled. The signals from the board reach the
hardware block.
Actually, one invalid character is input to the UART blocks for such
SoCs as PH1-LD4, PH1-sLD8, where UART devices start to run at the
power on reset.
To avoid such problems, pins should be input-enabled before muxing.
Reported-by: Dai Okamura <okamura.dai@socionext.com>
Add SD card pinmux settings for PH1-LD4, PH1-Pro4, PH1-sLD8,
PH1-Pro5, ProXstream2, and PH1-LD6b SoCs.
Currently, input enable settings are missing from the PH1-sLD8
pinctrl driver. (All the entries in the pin table are set to
UNIPHIER_PIN_IECTRL_NONE).
Fill the table with correct values.
Fixes: 95372f9dc892 ("pinctrl: UniPhier: add UniPhier PH1-sLD8 pinctrl driver")
The initial version of this driver missed to add I2C ch6 pin-muxing.
Add pin configuration and pinmux support for UniPhier PH1-LD6b SoC.
Changes in v2:
- sort groups and funcs alphabetically
- add i2c pin-mux settings
- sort members of platform_driver
- change to tristate
- add THIS_MODULE to pinctrl_desc
- use module_platform_driver
Add pin configuration and pinmux support for UniPhier ProXstream2
SoC.
Changes in v2:
Add pin configuration and pinmux support for UniPhier PH1-Pro5 SoC.
Changes in v2:
Add pin configuration and pinmux support for UniPhier PH1-sLD8 SoC.
Changes in v2:
Add pin configuration and pinmux support for UniPhier PH1-Pro4 SoC.
Changes in v2:
Add pin configuration and pinmux support for UniPhier PH1-LD4 SoC.
Changes in v2:
- add missing "emmc_dat8" group
The core support for the pinctrl drivers for all the UniPhier SoCs.
Changes in v2:
- drop vogus THIS_MODULE because this file is always built-in
- drop vogus "include <linux/module.h> because this file is
always built-in
