path: root/drivers/pinctrl
2014-01-23Merge tag 'dt-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC DT updates from Olof Johansson: "DT and DT-conversion-related changes for various ARM platforms. Most of these are to enable various devices on various boards, etc, and not necessarily worth enumerating. New boards and systems continue to come in as new devicetree files that don't require corresponding C changes any more, which is indicating that the system is starting to work fairly well. A few things worth pointing out: * ST Ericsson ux500 platforms have made the major push to move over to fully support the platform with DT * Renesas platforms continue their conversion over from legacy platform devices to DT-based for hardware description" * tag 'dt-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (327 commits) ARM: dts: SiRF: add pin group for USP0 with only RX or TX frame sync ARM: dts: SiRF: add lost usp1_uart_nostreamctrl pin group for atlas6 ARM: dts: sirf: add lost minigpsrtc device node ARM: dts: sirf: add clock, frequence-voltage table for CPU0 ARM: dts: sirf: add lost bus_width, clock and status for sdhci ARM: dts: sirf: add lost clocks for cphifbg ARM: dts: socfpga: add pl330 clock ARM: dts: socfpga: update L2 tag and data latency arm: sun7i: cubietruck: Enable the i2c controllers ARM: dts: add support for EXYNOS4412 based TINY4412 board ARM: dts: Add initial support for Arndale Octa board ARM: bcm2835: add USB controller to device tree ARM: dts: MSM8974: Add MMIO architected timer node ARM: dts: MSM8974: Add restart node ARM: dts: sun7i: external clock outputs ARM: dts: sun7i: Change 32768 Hz oscillator node name to clk@N style ARM: dts: sun7i: Add pin muxing options for clock outputs ARM: dts: sun7i: Add rtp controller node ARM: dts: sun5i: Add rtp controller node ARM: dts: sun4i: Add rtp controller node ...
2014-01-21Merge tag 'mfd-3.14-1' of git://git.linaro.org/people/ljones/mfdLinus Torvalds
Pull MFD changes from Lee Jones: "New drivers - Samsung Maxim 14577; Micro USB, Regulator, IRQ Controller and Battery Charger - TI/National Semiconductor LP3943 I2C GPIO Expander and PWM Generator Existing driver adaptions - Expansion of Wolfson Arizona DSP and High-Pass filter controls - TI TWL6040 default Regmap support and Regcache addition/bypass - Some nice Smatch catch fixes - Conversion of TI OMAP-USB and TI TWL6030 to endian neutralness - ChromeOS EC timing (delay) adaptions and added dependency on OF - Many constifications of 'struct {mfd_cell,regmap_irq,et.al}' - Watchdog support added for NVIDIA AS3722 - Convert functions to static in TI AM335x - Realigned previously defeated functionality in TI AM335x - IIO ADC-TSC concurrency dead-lock/timeout resolution - Addition of Power Management and Clock support for Samsung core - DEFINE_PCI_DEVICE_TABLE macro removal from MFD Subsystem - Greater use of irqdomain functionality in ST-E AB8500 - Removal of 'include/linux/mfd/abx500/ab8500-gpio.h' - Wolfson WM831x PMIC Power Management changes s/poweroff/shutdown/ - Device Tree documentation added for TI/Nat Semi LP3943 - Version detection and voltage tables for TI TPS6586x PMIC devices - Simplification of Freescale MC13XXX (de-)initialisation routines - Clean-up and simplification of the Realtek parent driver - Added support for RTL8402 Realtek PCI-Express card reader - Resource leak fix for Maxim 77686 - Possible suspend BUG() fix in OMAP USB TLL - Support for new Wolfson WM5110 Revision (D) - Testing of automatic assignment of of_node in mfd_add_device() - Reversion of the above when it started to cause issues - Remove legacy Platform Data from; TI TWL Core, Qualcomm SSBI and ST-E ABx500 Pinctrl - Clean-ups; tabbing issues, function name changes, 'drvdata = NULL' removal, unused uninitialised warning mitigation, error message clarity, removal of redundant/duplicate checks, licensing (GPL -> GPL2), coding consistency, duplicate function declaration, ret checks, commit corrections, redundant of_match_ptr() helper removal, spelling, #if-deffery removal and header guards name changes" * tag 'mfd-3.14-1' of git://git.linaro.org/people/ljones/mfd: (78 commits) mfd: wm5110: Add register patch for rev D chip mfd: omap-usb-tll: Don't hold lock during pm_runtime_get/put_sync() gpio: lp3943: Remove redundant of_match_ptr helper mfd: sta2x11-mfd: Use named constants for pci_power_t values Documentation: mfd: Fix LDO index in s2mps11.txt mfd: Cleanup mfd-mcp-sa11x0.h header mfd: max8997: Use "IS_ENABLED(CONFIG_OF)" for DT code. mfd: twl6030: Fix endianness problem in IRQ handler mfd: sec-core: Add cells for S5M8767-clocks mfd: max14577: Remove redundant of_match_ptr helper mfd: twl6040: Fix sparse non static symbol warning mfd: Revert "mfd: Always assign of_node in mfd_add_device()" mfd: rtsx: Fix sparse non static symbol warning mfd: max77693: Set proper maximum register for MUIC regmap mfd: max77686: Fix regmap resource leak on driver remove mfd: Represent correct filenames in file headers mfd: rtsx: Add support for card reader rtl8402 mfd: rtsx: Add set pull control macro and simplify rtl8411 mfd: max8997: Enforce mfd_add_devices() return value check mfd: mc13xxx: Simplify probe() & remove() ...
2014-01-21Merge tag 'pinctrl-v3.14-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl Pull bulk pin control changes from Linus Walleij: "This has been queued and tested for a while. Lots of action here, like in the GPIO tree, embedded stuff like this is really hot now it seems. Details in the signed tag. I'm especially happy about the Qualcomm driver as it is used in such a huge subset of mobile handsets out there, and these platforms in general need better upstream support - New driver for the Qualcomm TLMM pin controller and its msm8x74 subdriver. - New driver for the Broadcom Capri BCM281xx SoC. - New subdriver for the imx25 pin controller. - New subdriver for the Tegra124 pin controller. - Lock GPIO lines as IRQs for select combined pin control and GPIO drivers for baytrail and sirf. - Some semi-big refactorings and extenstions to the sirf driver. - Lots of patching, cleanup and fixing in the Renesas "PFC" driver and associated subdrivers as usual. It is settling down a little bit now it seems. - Minor fixes and incremental updates here and there as usual" * tag 'pinctrl-v3.14-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl: (72 commits) pinctrl: sunxi: Honor GPIO output initial vaules pinctrl: capri: add dependency on OF ARM: bcm11351: Enable pinctrl for Broadcom Capri SoCs ARM: pinctrl: Add Broadcom Capri pinctrl driver pinctrl: Add pinctrl binding for Broadcom Capri SoCs pinctrl: Add void * to pinctrl_pin_desc pinctrl: st: Fix a typo in probe pinctrl: Fix some typos and grammar issues in the documentation pinctrl: sirf: lock IRQs when starting them pinctrl: sirf: put gpio interrupt pin into input status automatically pinctrl: sirf: use only one irq_domain for the whole device node pinctrl: single: fix infinite loop caused by bad mask pinctrl: single: fix pcs_disable with bits_per_mux pinctrl: single: fix DT bindings documentation pinctrl: as3722: Set pin to output mode for some function pinctrl: sirf: add pin group for USP0 with only RX or TX frame sync pinctrl: sirf: fix the pins of sdmmc5 connected with TriG pinctrl: sirf: add lost usp1_uart_nostreamctrl group for atlas6 pinctrl: sunxi: Add Allwinner A20 clock output pin functions pinctrl/lantiq: fix typo ...
2014-01-21Merge tag 'gpio-v3.14-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio Pull GPIO tree bulk changes from Linus Walleij: "A big set this merge window, as we have much going on in this subsystem. The changes to other subsystems (notably a slew of ARM machines as I am doing away with their custom APIs) have all been ACKed to the extent possible. Major changes this time: - Some core improvements and cleanups to the new GPIO descriptor API. This seems to be working now so we can start the exodus to this API, moving gradually away from the global GPIO numberspace. - Incremental improvements to the ACPI GPIO core, and move the few GPIO ACPI clients we have to the GPIO descriptor API right *now* before we go any further. We actually managed to contain this *before* we started to litter the kernel with yet another hackish global numberspace for the ACPI GPIOs, which is a big win. - The RFkill GPIO driver and all platforms using it have been migrated to use the GPIO descriptors rather than fixed number assignments. Tegra machine has been migrated as part of this. - New drivers for MOXA ART, Xtensa GPIO32 and SMSC SCH311x. Those should be really good examples of how I expect a nice GPIO driver to look these days. - Do away with custom GPIO implementations on a major part of the ARM machines: ks8695, lpc32xx, mv78xx0. Make a first step towards the same in the horribly convoluted Samsung S3C include forest. We expect to continue to clean this up as we move forward. - Flag GPIO lines used for IRQ on adnp, bcm-kona, em, intel-mid and lynxpoint. This makes the GPIOlib core aware that a certain GPIO line is used for IRQs and can then enforce some semantics such as disallowing a GPIO line marked as in use for IRQ to be switched to output mode. - Drop all use of irq_set_chip_and_handler_name(). The name provided in these cases were just unhelpful tags like "mux" or "demux". - Extend the MCP23s08 driver to handle interrupts. - Minor incremental improvements for rcar, lynxpoint, em 74x164 and msm drivers. - Some non-urgent bug fixes here and there, duplicate #includes and that usual kind of cleanups" Fix up broken Kconfig file manually to make this all compile. * tag 'gpio-v3.14-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (71 commits) gpio: mcp23s08: fix casting caused build warning gpio: mcp23s08: depend on OF_GPIO gpio: mcp23s08: Add irq functionality for i2c chips ARM: S5P[v210|c100|64x0]: Fix build error gpio: pxa: clamp gpio get value to [0,1] ARM: s3c24xx: explicit dependency on <plat/gpio-cfg.h> ARM: S3C[24|64]xx: move includes back under <mach/> scope Documentation / ACPI: update to GPIO descriptor API gpio / ACPI: get rid of acpi_gpio.h gpio / ACPI: register to ACPI events automatically mmc: sdhci-acpi: convert to use GPIO descriptor API ARM: s3c24xx: fix build error gpio: f7188x: set can_sleep attribute gpio: samsung: Update documentation gpio: samsung: Remove hardware.h inclusion gpio: xtensa: depend on HAVE_XTENSA_GPIO32 gpio: clps711x: Enable driver compilation with COMPILE_TEST gpio: clps711x: Use of_match_ptr() net: rfkill: gpio: convert to descriptor-based GPIO interface leds: s3c24xx: Fix build failure ...
2014-01-21mfd/pinctrl: Delete platform data headerLinus Walleij
This deletes the special AB8500 GPIO platform data passing header and merges the few remaining contents down into the abx500 pinctrl driver which handles the abx500 GPIO device. Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2014-01-21pinctrl: abx500: Delete non-devicetree probe pathLinus Walleij
All instances of this device are now coming from device tree- enabled platforms probing without using platform data. Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2014-01-20pinctrl: sunxi: Honor GPIO output initial vaulespinctrl-v3.14-1Chen-Yu Tsai
Some GPIO users, such as fixed-regulator, request GPIO output with initial value of 1. This was ignored by sunxi driver. Cc: stable@vger.kernel.org Signed-off-by: Chen-Yu Tsai <wens@csie.org> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-01-18Revert "ACPI: Add BayTrail SoC GPIO and LPSS ACPI IDs"Rafael J. Wysocki
This reverts commit f6308b36c411 (ACPI: Add BayTrail SoC GPIO and LPSS ACPI IDs), because it causes the Alan Cox' ASUS T100TA to "crash and burn" during boot if the Baytrail pinctrl driver is compiled in. Fixes: f6308b36c411 (ACPI: Add BayTrail SoC GPIO and LPSS ACPI IDs) Reported-by: One Thousand Gnomes <gnomes@lxorguk.ukuu.org.uk> Requested-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-01-16pinctrl: capri: add dependency on OFLinus Walleij
As this driver is using pinconf_generic_dt_node_to_map_pin() it needs to depend on OF so as not to cause build problems on archs that do not support OF. Cc: Sherman Yin <syin@broadcom.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-01-16ARM: pinctrl: Add Broadcom Capri pinctrl driverSherman Yin
Adds pinctrl driver for Broadcom Capri (BCM281xx) SoCs. v4: - PINCTRL selected in Kconfig, PINCTRL_CAPRI selected in bcm_defconfig - make use of regmap - change CAPRI_PIN_UPDATE from macro to inline function. - Handle pull-up strength arg in Ohm instead of enum v3: Re-work driver to be based on generic pin config. Moved config selection from Kconfig to bcm_defconfig. v2: Use hyphens instead of underscore in DT property names. Signed-off-by: Sherman Yin <syin@broadcom.com> Reviewed-by: Christian Daudt <bcm@fixthebug.org> Reviewed-by: Matt Porter <matt.porter@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-01-15pinctrl: st: Fix a typo in probeSrinivas Kandagatla
Probe function had commas instead of semi-colons on some of the lines. This patch just fixes those lines. No functional chagnes done in this patch. Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@st.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-01-15pinctrl: sirf: lock IRQs when starting themLinus Walleij
This uses the new API for tagging GPIO lines as in use by IRQs. This enforces a few semantic checks on how the underlying GPIO line is used. Also assign the gpio_chip.dev pointer to be used for error messages. Cc: Barry Song <Baohua.Song@csr.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-01-15pinctrl: sirf: put gpio interrupt pin into input status automaticallyBarry Song
busses like i2c, spi and so on can parse the virq of their subnode automatically by irq_of_parse_and_map(). for example, i2c will do that in of_i2c_register_devices(). people can put hwirq number attached to a gpio controller in dts, and drivers can directly request the parsed virq. for example, for an i2c client as below, tangoc-ts@5c{ compatible = "pixcir,tangoc-ts"; interrupt-parent = <&gpio>; interrupts = <3 0>; reg = <0x5c>; }; in i2c client probe(), it will request_irq(client->irq, ...) without calling gpio_direction_input(). so here when we set irq type, we also put the pin to input direction. Signed-off-by: Barry Song <Baohua.Song@csr.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-01-15pinctrl: sirf: use only one irq_domain for the whole device nodeBarry Song
in sirfsoc gpio probe(), we create 5 irq_domains for 5 gpio banks. but in irq_create_of_mapping() of irqchip core level, irq_find_host() can only return the 1st irq_domain attached the pinctrl dt device node as we can see from the codes: unsigned int irq_create_of_mapping(struct device_node *controller, const u32 *intspec, unsigned int intsize) { struct irq_domain *domain; ... domain = controller ? irq_find_host(controller) : irq_default_domain; } struct irq_domain *irq_find_host(struct device_node *node) { struct irq_domain *h, *found = NULL; int rc; /* We might want to match the legacy controller last since * it might potentially be set to match all interrupts in * the absence of a device node. This isn't a problem so far * yet though... */ mutex_lock(&irq_domain_mutex); list_for_each_entry(h, &irq_domain_list, link) { if (h->ops->match) rc = h->ops->match(h, node); else rc = (h->of_node != NULL) && (h->of_node == node); if (rc) { found = h; break; } } mutex_unlock(&irq_domain_mutex); return found; } for sirfsoc, the 1st irq_domain attached to the device_node(controller) only can do linear for the 1st 32 gpios. so for devices who use gpio hwirq above 32 and put the information in dt like: tangoc-ts@5c{ compatible = "pixcir,tangoc-ts"; + interrupt-parent = <&gpio>; + interrupts = <34 0>; }; we will fail to get the virq for these devices as hwirq will be bigger than domain->revmap_data.linear.size in: unsigned int irq_linear_revmap(struct irq_domain *domain, irq_hw_number_t hwirq) { /* Check revmap bounds; complain if exceeded */ if (WARN_ON(hwirq >= domain->revmap_data.linear.size)) return 0; return domain->revmap_data.linear.revmap[hwirq]; } this patch drops redundant irq_domain and keep only one to fix the problem. Signed-off-by: Barry Song <Baohua.Song@csr.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-01-15pinctrl: single: fix infinite loop caused by bad maskTomi Valkeinen
commit 4e7e8017a80e1 (pinctrl: pinctrl-single: enhance to configure multiple pins of different modules) improved support for pinctrl-single,bits option, but also caused a regression in parsing badly configured mask data. If the masks in DT data are not quite right, pcs_parse_bits_in_pinctrl_entry() can end up in an infinite loop, trashing memory at the same time. Add a check to verify that each loop actually removes bits from the 'mask', so that the loop can eventually end. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-01-15pinctrl: single: fix pcs_disable with bits_per_muxTomi Valkeinen
pcs_enable() uses vals->mask instead of pcs->fmask when bits_per_mux is enabled. However, pcs_disable() always uses pcs->fmask. Fix pcs_disable() to use vals->mask with bits_per_mux. Signed-off-by: Tomi Valkeinen <tomi.valkeinen@ti.com> Acked-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Acked-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-01-14pinctrl: as3722: Set pin to output mode for some functionMallikarjun Kasoju
If pins are used for function output like pwm, clk32k, power good etc then set it as output mode default. Signed-off-by: Mallikarjun Kasoju <mkasoju@nvidia.com> Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Acked-by: Lee Jones <lee.jones@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-01-08gpio / ACPI: register to ACPI events automaticallyMika Westerberg
Instead of asking each driver to register to ACPI events we can just call acpi_gpiochip_register_interrupts() for each chip that has an ACPI handle. The function checks chip->to_irq and if it is set to NULL (a GPIO driver that doesn't do interrupts) the function does nothing. We also add the a new header drivers/gpio/gpiolib.h that is used for functions internal to gpiolib and add ACPI GPIO chip registering functions to that header. Once that is done we can remove call to acpi_gpiochip_register_interrupts() from its only user, pinctrl-baytrail.c Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com> Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-01-08pinctrl: sirf: add pin group for USP0 with only RX or TX frame syncRongjun Ying
USP0 has multiple functions, and has RX and TX frame sync signals, for some scenarios like audio PCM, we don't need both of them. so here we add two possibilities for USP0 only holding one of TX and RX frame sync. Signed-off-by: Rongjun Ying <Rongjun.Ying@csr.com> Signed-off-by: Barry Song <Barry.Song@csr.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-01-08pinctrl: sirf: fix the pins of sdmmc5 connected with TriGBin Shi
sdmmc5 has only 3 pins CMD, CLK, DATA which are connected with CSR TriG RF multi-GNSS. The hardware connection is like: DATA -- GPS_SGN CLK -- GPS_RF_CLK CMD -- GPS_MAG here we drop redundant pins in sdmmc5 group. Signed-off-by: Bin Shi <Bin.Shi@csr.com> Signed-off-by: Barry Song <Baohua.Song@csr.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-01-08pinctrl: sirf: add lost usp1_uart_nostreamctrl group for atlas6Qipan Li
commit af614b2301f0e304 adds lost USP-based UART pin groups for prima2, but missed usp1_uart_nostreamctrl group for atlas6, this patch fixes it. this makes USP(Universal Serial Ports) port1 can work as uart without stream ctrl. Signed-off-by: Qipan Li <Qipan.Li@csr.com> Signed-off-by: Barry Song <Baohua.Song@csr.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-01-08pinctrl: sunxi: Add Allwinner A20 clock output pin functionsChen-Yu Tsai
This patch adds the clock output pin functions on the A20. The 2 pins can output a configurable clock to be used by external modules. This is used on the CubieTruck, to supply a 32768 Hz low power clock to the onboard Wifi+BT module. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-01-08pinctrl/lantiq: fix typoAntonios Vamporakis
Signed-off-by: Antonios Vamporakis <ant@area128.com> CC: John Crispin <blogic@openwrt.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-01-07pinctrl: sh-pfc: r8a7791: Add I2C pinsValentine Barshak
This adds I2C[0-4] pinmux support to R8A7791 SoC. Signed-off-by: Valentine Barshak <valentine.barshak@cogentembedded.com> Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-01-07pinctrl: sh-pfc: r8a7791: Add VIN pinsValentine Barshak
This adds VIN[0-2] pinmux support to r8a7791 SoC. VIN1 B mirror is also added along with the primary configuration since it's the only one that provides access to all 24 data bits on VIN1. Signed-off-by: Valentine Barshak <valentine.barshak@cogentembedded.com> Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-01-07pinctrl: sh-pfc: r8a7791: Group USB PWEN and OVC pins togetherValentine Barshak
This groups USB PWEN and OVC pins together on R8A7791 SoC, the same way it's done on R8A7790, since both are needed for a USB device. Signed-off-by: Valentine Barshak <valentine.barshak@cogentembedded.com> Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-01-07pinctrl: sh-pfc: r8a7790: Fix vsync value in the vin3_sync_mux arrayValentine Barshak
This fixes a typo in the vin3_sync_mux array (s/VI2/VI3/). Signed-off-by: Valentine Barshak <valentine.barshak@cogentembedded.com> Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2014-01-03Merge tag 'renesas-dt3-for-v3.14' of ↵Olof Johansson
git://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas into next/dt From Simon Horman: Third Round of Renesas ARM Based SoC DT Updates for v3.14 * r8a7791 (R-Car M2) and r8a7790 (R-Car H2) SoCSs - Add SSI, QSPI and MSIOF clocks in device tree r8a7791 (R-Car M2) based Koelsch and r8a7790 (R-Car H2) based Lager boards - Remove reference DTS - Specify external clock frequency in DT - Sync non-reference DTS with referene DTS - Add clocks to DTS * r8a7740 (R-Mobile A1) based Armadillo board - Add gpio-keys device - Add PWM backlight enable GPIO - Add PWM backlight power supply * r8a73a0 (SH-Mobile AG5), r8a7740 (R-Mobile A1) and r8a73a4 (SH-Mobile APE6) SoCs - Specify PFC interrupts in DT * tag 'renesas-dt3-for-v3.14' of git://git.kernel.org/pub/scm/linux/kernel/git/horms/renesas: (72 commits) ARM: shmobile: r8a7791: Add SSI clocks in device tree ARM: shmobile: r8a7790: Add SSI clocks in device tree ARM: shmobile: r8a7791: Add QSPI module clock in device tree ARM: shmobile: r8a7790: Add QSPI module clock in device tree ARM: shmobile: r8a7791: Add MSIOF clocks in device tree ARM: shmobile: r8a7790: Add MSIOF clocks in device tree ARM: shmobile: Remove Koelsch reference DTS ARM: shmobile: Remove Lager reference DTS ARM: shmobile: koelsch: Specify external clock frequency in DT ARM: shmobile: lager: Specify external clock frequency in DT ARM: shmobile: Sync Koelsch DTS with Koelsch reference DTS ARM: shmobile: Sync Lager DTS with Lager reference DTS ARM: shmobile: r8a7791: Add clocks ARM: shmobile: r8a7790: Reference clocks ARM: shmobile: r8a7790: Add clocks ARM: shmobile: armadillo: dts: Add gpio-keys device ARM: shmobile: sh73a0: Specify PFC interrupts in DT ARM: shmobile: r8a7740: Specify PFC interrupts in DT ARM: shmobile: r8a73a4: Specify PFC interrupts in DT ARM: shmobile: armadillo: dts: Add PWM backlight enable GPIO ... Signed-off-by: Olof Johansson <olof@lixom.net>
2013-12-27Merge branches 'powercap' and 'acpi-lpss' with new device IDsRafael J. Wysocki
* powercap: powercap / RAPL: add support for ValleyView Soc * acpi-lpss: ACPI: Add BayTrail SoC GPIO and LPSS ACPI IDs
2013-12-26Merge branch 'tegra/dma-reset-rework' into next/dtOlof Johansson
Bringing in the tegra dma/reset framework cleanup as a base for the DT changes. * tegra/dma-reset-rework: (320 commits) spi: tegra: checking for ERR_PTR instead of NULL ASoC: tegra: update module reset list for Tegra124 clk: tegra: remove bogus PCIE_XCLK clk: tegra: remove legacy reset APIs ARM: tegra: remove legacy DMA entries from DT ARM: tegra: remove legacy clock entries from DT USB: EHCI: tegra: use reset framework Input: tegra-kbc - use reset framework serial: tegra: convert to standard DMA DT bindings serial: tegra: use reset framework spi: tegra: convert to standard DMA DT bindings spi: tegra: use reset framework staging: nvec: use reset framework i2c: tegra: use reset framework ASoC: tegra: convert to standard DMA DT bindings ASoC: tegra: allocate AHUB FIFO during probe() not startup() ASoC: tegra: call pm_runtime APIs around register accesses ASoC: tegra: use reset framework dma: tegra: register as an OF DMA controller dma: tegra: use reset framework ... Signed-off-by: Olof Johansson <olof@lixom.net>
2013-12-20pinctrl: sh-pfc: ARM: Constify pins and cfg_regs arraysLaurent Pinchart
The arrays are never modified, declare them as const. Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-12-20pinctrl: sh-pfc: sh: Constify pins and cfg_regs arraysLaurent Pinchart
2013-12-20pinctrl: sh-pfc: Constify IRQ GPIOs arraysLaurent Pinchart
The arrays are never modified, make them const. Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-12-20pinctrl: sh-pfc: Constify enum_ids and var_field_width compound literalsLaurent Pinchart
The enum_ids and var_field_width fields of struct pinmux_data_reg and pinmux_cfg_reg are initialized using compound literals. Cast them to const to store them in .rodata. Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-12-20pinctrl: msm: Fix set gpio settingAxel Lin
Set g->out_bit bit for gpio output high, clear g->out_bit bit for gpio output low. Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-12-19Merge tag 'v3.13-rc3' into dt3-baseSimon Horman
Linux 3.13-rc3 Conflicts: drivers/pinctrl/sh-pfc/pfc-r8a7740.c drivers/pinctrl/sh-pfc/pfc-sh7372.c
2013-12-16pinctrl: at91: replace clk_prepare + clk_enable by clk_prepare_enableBoris BREZILLON
Replace the clk_prepare and clk_enable calls by a single clk_prepare_enable call. Signed-off-by: Boris BREZILLON <b.brezillon@overkiz.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-12-16pinctrl: at91: fix clk_unprepare and clk_disable orderBoris BREZILLON
clk_unprepare shall be called before clk_disable. Fix the issue by replacing the clk_unprepare and clk_disable calls by a single clk_disable_unprepare call. Signed-off-by: Boris BREZILLON <b.brezillon@overkiz.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-12-16pinctrl: Adds slew-rate, input-enable/disableSherman Yin
This commit adds slew-rate and input-enable/disable support for pinconf -generic. Signed-off-by: Sherman Yin <syin@broadcom.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-12-16pinctrl-msm: Rename compatible to be more specificBjorn Andersson
Use the more specific form 8974 for the compatible to reduce the risk of future mishaps. Signed-off-by: Bjorn Andersson <bjorn.andersson@sonymobile.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-12-16pinctrl-msm: Remove separate allocation of bitmapsBjorn Andersson
Make the bitmaps part of the msm_pinctrl allocation instead of separately allocating them. Signed-off-by: Bjorn Andersson <bjorn.andersson@sonymobile.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-12-16pinctrl-msm: Tidy up error handlingBjorn Andersson
2013-12-16pinctrl-msm: Fix spelling misstakes and missing constsBjorn Andersson
2013-12-16pinctrl: msm: Update Kconfig for PINCTRL_MSM8X74Bjorn Andersson
Add GPIOLIB and OF as dependencies for PINCTRL_MSM8X74, to fix build errors from i386-randconfig. Also add help text and make the entries tristate, while touching these entries. Cc: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Bjorn Andersson <bjorn.andersson@sonymobile.com> [Rebased on top of pin control development branch] Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-12-13pinctrl: pinconf: remove warning: unused variable 'ops'Alexandre Belloni
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-12-13pinctrl: at91: implement at91_pinconf_dbg_showAlexandre Belloni
This allows to get the pin configuration by using debugfs. On my system: # cat /sys/kernel/debug/pinctrl/pinctrl.3/pinconf-pins Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-12-12pinctrl: tegra: add pinmux controller driver for Tegra124Ashwini Ghuge
This adds a driver for the Tegra124 pinmux, and required parameterization data for Tegra124. The driver uses the common Tegra pincontrol driver utility functions to implement the majority of the driver. This driver is not compatible with the earlier NVIDIA's SoCs, hence add new compatibile as "nvidia,tegra124-pinmux". Originally written by Ashwini Gguhe. Thierry: - Cleanups in patches. ldewangan: - Fix some entries for groups. - Fix MUX enums and group sequence. Signed-off-by: Ashwini Ghuge <aghuge@nvidia.com> Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Acked-by: Stephen Warren <swarren@nvidia.com> Tested-by: Stephen Warren <swarren@nvidia.com> CC: Thierry Reding <treding@nvidia.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-12-12sh-pfc: Support GPIO to IRQ mapping specified IRQ resourcesLaurent Pinchart
On non-DT platforms IRQ controllers associated with the GPIOs have a fixed IRQ base value known at compile time. The sh-pfc driver translates GPIO number to IRQ numbers using a hardcoded table. This mechanism breaks on DT platforms, as the IRQ base values are dynamic in that case. Fix this by specifying IRQs associated with GPIOs in IRQ resources, populated automatically from the device tree. When IRQ resources are specified the driver requires one IRQ resource per GPIO able to generate an interrupt, and uses the translation table to compute the IRQ resource offset instead of the IRQ number. Cc: devicetree@vger.kernel.org Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com> Acked-by: Magnus Damm <damm@opensource.se> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-12-12sh-pfc: Rename sh_pfc window field to windowsLaurent Pinchart
There's more than one window, name the field windows. Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com> Acked-by: Magnus Damm <damm@opensource.se> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2013-12-12sh-pfc: sh73a0: Sort IRQ entries by IRQ numberLaurent Pinchart
This makes catching duplicate entries easier. Merge the two IRQ9 entries found after sorting. Signed-off-by: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com> Acked-by: Magnus Damm <damm@opensource.se> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
