Signed-off-by: Stefan Brüns <stefan.bruens@rwth-aachen.de>
Acked-by: Jiri Kosina <jkosina@suse.cz>
This reverts commit 02b2aaaa57ab41504e8d03a3b2ceeb9440a2c188.
This interface was determined to be flawed and required too invasive a
fix for the RC cycle. This will be revisited in 3.20.
Signed-off-by: Darren Hart <dvhart@linux.intel.com>
git://git.infradead.org/users/dvhart/linux-platform-drivers-x86
Pull x86 platform driver update from Darren Hart:
- thinkpad-acpi: Switch to software mute, cleanups
- acerhdf: Bang-bang thermal governor, new models, cleanups
- dell-laptop: New keyboard backlight support and documentation
- toshiba_acpi: Keyboard backlight updates, hotkey handling
- dell-wmi: Keypress filtering, WMI event processing
- eeepc-laptop: Multiple cleanups, improved error handling, documentation
- hp_wireless: Inform the user if hp_wireless_input_setup()/add() fails
- misc: Code cleanups, quirks, various new IDs
* tag 'platform-drivers-x86-v3.19-1' of git://git.infradead.org/users/dvhart/linux-platform-drivers-x86: (33 commits)
platform/x86/acerhdf: Still depends on THERMAL
Documentation: Add entry for dell-laptop sysfs interface
acpi: Remove _OSI(Linux) for ThinkPads
thinkpad-acpi: Try to use full software mute control
acerhdf: minor clean up
acerhdf: added critical trip point
acerhdf: Use bang-bang thermal governor
acerhdf: Adding support for new models
acerhdf: Adding support for "manual mode"
dell-smo8800: Add more ACPI ids and change description of driver
platform: x86: dell-laptop: Add support for keyboard backlight
toshiba_acpi: Add keyboard backlight mode change event
toshiba_acpi: Change notify funtion to handle more events
toshiba_acpi: Move hotkey enabling code to its own function
dell-wmi: Don't report keypresses on keybord illumination change
dell-wmi: Don't report keypresses for radio state changes
toshiba-acpi: Add missing ID (TOS6207)
Sony-laptop: Deletion of an unnecessary check before the function call "pci_dev_put"
platform: x86: Deletion of checks before backlight_device_unregister()
acerhdf uses thermal interfaces so it should depend on THERMAL.
It also should not select a thermal driver without checking that
THERMAL is enabled.
This fixes the following build errors when THERMAL=m and
ACERHDF=y.
drivers/built-in.o: In function `acerhdf_set_mode':
acerhdf.c:(.text+0x3e02e1): undefined reference to `thermal_zone_device_update'
drivers/built-in.o: In function `acerhdf_unbind':
acerhdf.c:(.text+0x3e052d): undefined reference to `thermal_zone_unbind_cooling_device'
drivers/built-in.o: In function `acerhdf_bind':
acerhdf.c:(.text+0x3e0593): undefined reference to `thermal_zone_bind_cooling_device'
drivers/built-in.o: In function `acerhdf_init':
acerhdf.c:(.init.text+0x1c2f5): undefined reference to `thermal_cooling_device_register'
acerhdf.c:(.init.text+0x1c360): undefined reference to `thermal_zone_device_register'
drivers/built-in.o: In function `acerhdf_unregister_thermal':
acerhdf.c:(.text.unlikely+0x3c67): undefined reference to `thermal_cooling_device_unregister'
acerhdf.c:(.text.unlikely+0x3c91): undefined reference to `thermal_zone_device_unregister'
Acked-by: Peter Feuerer <peter@piie.net>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core update from Greg KH:
"Here's the set of driver core patches for 3.19-rc1.
They are dominated by the removal of the .owner field in platform
drivers. They touch a lot of files, but they are "simple" changes,
just removing a line in a structure.
Other than that, a few minor driver core and debugfs changes. There
are some ath9k patches coming in through this tree that have been
acked by the wireless maintainers as they relied on the debugfs
changes.
Everything has been in linux-next for a while"
* tag 'driver-core-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (324 commits)
Revert "ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries"
fs: debugfs: add forward declaration for struct device type
firmware class: Deletion of an unnecessary check before the function call "vunmap"
firmware loader: fix hung task warning dump
devcoredump: provide a one-way disable function
device: Add dev_<level>_once variants
ath: use seq_file api for ath9k debugfs files
debugfs: add helper function to create device related seq_file
drivers/base: cacheinfo: remove noisy error boot message
Revert "core: platform: add warning if driver has no owner"
drivers: base: support cpu cache information interface to userspace via sysfs
drivers: base: add cpu_device_create to support per-cpu devices
topology: replace custom attribute macros with standard DEVICE_ATTR*
cpumask: factor out show_cpumap into separate helper function
driver core: Fix unbalanced device reference in drivers_probe
driver core: fix race with userland in device_add()
sysfs/kernfs: make read requests on pre-alloc files use the buffer.
sysfs/kernfs: allow attributes to request write buffer be pre-allocated.
fs: sysfs: return EGBIG on write if offset is larger than file size
thinkpad-acpi:
ThinkPads have hardware volume controls and three buttons to control
them. (These are separate from the standard mixer.) By default,
the buttons are:
- Mute: Mutes the hardware volume control and, on some models,
generates KEY_MUTE.
- Up: Unmutes, generates KEY_VOLUMEUP, and increases volume if
applicable. (Newer thinkpads only have hardware mute/unmute.)
- Down: Unmutes, generates KEY_VOLUMEDOWN, and decreases volume
if applicable.
This behavior is unfortunate, since modern userspace will also
handle the hotkeys and change the other mixer. If the software
mixer is muted and the hardware mixer is unmuted and you push mute,
hilarity ensues as they both switch state.
Rather than adding a lot of complex ALSA integration to fix this,
just disable the special ThinkPad volume controls when possible.
This turns the mute and volume buttons into regular buttons, and
standard software controls will work as expected.
ALSA already knows about the mute light on models with a mute light,
so everything should just work.
This should also allow us to remove _OSI(Linux) for all ThinkPads.
For future reference: It turns out that we can ask ACPI for one of
three behaviors directly on very new models. They are "latch" (the
default), "none" (no automatic control), and "toggle" (mute unmutes
when muted). All of the modes besides "none" seem to be a bit
buggy, though, and there doesn't seem to be a consistent way to get
any notification when the HW mute state is changed.
Signed-off-by: Andy Lutomirski <luto@mit.edu>
Acked-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br>
* renamed bios_settings_t to bios_settings, as it is no typedef
* replaced "unsigned char" by u8 in bios_settings struct for better
readability.
Cc: platform-driver-x86@vger.kernel.org
Cc: Darren Hart <dvhart@infradead.org>
Cc: Andreas Mohr <andi@lisas.de>
Acked-by: Borislav Petkov <bp@suse.de>
Signed-off-by: Peter Feuerer <peter@piie.net>
added critical trip point which represents the temperature limit.
Added return -EINVAL in case wrong trip point is provided.
Cc: Borislav Petkov <bp@suse.de>
Cc: Javi Merino <javi.merino@arm.com>
acerhdf has been doing an on-off fan control using hysteresis by
post-manipulating the outcome of thermal subsystem trip point handling.
This patch enables acerhdf to use the bang-bang governor, which is
intended for on-off controlled fans.
CC: Zhang Rui <rui.zhang@intel.com>
Acked-and-tested-by: Borislav Petkov <bp@suse.de>
added following new models:
* Aspire 5755G
* AO521
* AO751h
* Aspire One 753
* Extensa 5420
* Aspire 5315
* Aspire 5739G
* TravelMate TM8573T
Some Acer models require an additional command to turn off the fan after
bios mode has been enabled. Adding new section in bios table to allow
support for those models, by writing an extra "manual mode" register.
This patch adds other ACPI ids from Windows inf driver which should be handled
by dell-smo8800 driver. ACPI devices have same structure -- one IRQ number.
This patch also updates description of module.
Signed-off-by: Pali Rohár <pali.rohar@gmail.com>
This patch adds support for configuring keyboard backlight settings on supported
Dell laptops. It exports kernel leds interface and uses Dell SMBIOS tokens or
keyboard class interface.
With this patch it is possible to set:
* keyboard backlight level
* timeout after which will be backlight automatically turned off
* input activity triggers (keyboard, touchpad, mouse) which enable backlight
* ambient light settings
Settings are exported via sysfs:
/sys/class/leds/dell::kbd_backlight/
Code is based on newly released documentation by Dell in libsmbios project.
Thanks to Dan Carpenter who reported bug about unpredictable results in
quirks->kbd_timeouts for loop. His fix adds needs_kbd_timeouts flag to
quirk structure to indicate if kbd_timeouts array is empty or not.
Signed-off-by: Gabriele Mazzotta <gabriele.mzt@gmail.com>
Cc: Dan Carpenter <dan.carpenter@oracle.com>
Minor English corrections to comments.
A previous patch added support to handle more events.
This patch adds support to update the sysfs group whenever we receive
a 0x92 event, which indicates a change in the keyboard backlight mode,
removing the update group code from toshiba_kbd_bl_mode_store, as it is
no longer needed there.
Signed-off-by: Azael Avalos <coproscefalo@gmail.com>
Currently the function toshiba_acpi_notify only takes care of hotkeys,
however, the TOSXXXX devices receive more events that can be useful.
This patch changes the function to be able to handle more events,
and in the process, move all hotkey related code residing in it to
a new function called toshiba_acpi_process_hotkeys.
The hotkey enabling code is being used by *_setup_keyboard and also by
*_resume.
This patch creates a new function called toshiba_acpi_enable_hotkeys to
be used by these two functions to avoid duplicating code.
Keyboard illumination level changes are performed by the BIOS, so no
events should be reported on keypress. This is already done on systems
using the legacy keymap, do it also for systems that don't use it.
The WMI events associated to KEY_WLAN are for all the radio devices
available. Use KEY_RFKILL instead since it's more appropriate.
The state of radio devices is changed directly by the BIOS when hotkeys
are pressed, so no events should be reported.
Merged two patches modifying this one line
In hpwl_add() there is a unused variable err to which we assign the
result of hp_wireless_input_setup() but we don't do anything depending
on the result so print out a message that informs the user if add()
(hp_wireless_input_setup()) fails since acpi_device_probe() doesn't
print anything in this case.
Signed-off-by: Giedrius Statkevicius <giedriuswork@gmail.com>
toshiba-acpi was always missing TOS6207 ID so it did not load automatically
on some laptops (such as Portege R100). But it worked fine if loaded manually.
Commit 135740de7764 ("toshiba_acpi: Convert to use acpi_driver") broke that
and the driver does not work even when loaded manually since then.
Add TOS6207 ID to fix it.
Tested on Toshiba Portege R100.
Signed-off-by: Ondrej Zary <linux@rainbow-software.org>
"pci_dev_put"
The pci_dev_put() function tests whether its argument is NULL
and then returns immediately. Thus the test around the call
is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring <elfring@users.sourceforge.net>
The backlight_device_unregister() function tests whether its argument is NULL
and then returns immediately. Thus the test around the call is not needed.
For msi-wmi.c:
Acked-by: Anisse Astier <anisse@astier.eu>
Bug 86521 uncovered that some TOS6208 devices also return
non zero values on a write call to the backlight method,
thus getting caught and bailed out by the extra check code.
This patch changes the set_lcd_brightness function to its
"original" state by just adapting it to the new function
format.
Wifi on this laptop does not work unless asus-nb-wmi.wapf=4 is specified on
the kerne commandline, add a quirk for this.
Cc: stable@vger.kernel.org
BugLink: https://bugs.launchpad.net/bugs/1173681
HP ZBook 15 laptop needs a non-standard mapping (x_inverted).
BugLink: http://bugzilla.opensuse.org/show_bug.cgi?id=905329
Signed-off-by: Dominique Leuenberger <dimstar@opensuse.org>
Cc: <stable@vger.kernel.org>
Signed-off-by: Masatake YAMATO <yamato@redhat.com>
The WMI buffer can contain multiple events. First value in buffer is
length of event followed by data of specified length. After that is next
length and next data. When length is zero then there is no more events
in bufffer.
This patch adds support for processing all events in buffer (not only
first) and parse more event types (not only hotkey events). Because of
variable length of events sometimes BIOS fills more hotkeys (or other
values) into single WMI event. In this case this patch also processes
these multiple hotkeys (and not only first one).
Some event types are just ignored because kernel is not interested in
them (e.g. NIC Link status, battery unplug, ...).
This patch is based on DSDT table from Dell Latitude E6440. Code should
be backward compatible so will process other events of old types same as
before this patch.
This patch also fixes a problem with unknown WMI event messages being
written to the log. Now all known events are parsed and those which are
not interesting to the kernel are dropped without an unknown WMI event
message.
Tested-by: Pali Rohár <pali.rohar@gmail.com>
eeepc_acpi_notify increases the indentation level to a whopping four. If
we revise the conditions a bit, we can reduce that to a more soothing
two and satisfy the indentation guidelines in Documentation/CodingStyle.
Remove an unwanted space while we're in the neighbourhood.
Signed-off-by: Frans Klaver <fransklaver@gmail.com>
s/tempurature/temperature/
Signed-off-by: Chen Hanxiao <chenhanxiao@cn.fujitsu.com>
In eeepc_hotk_thaw, we assume that get_acpi() will effectively return a
bool. However, it is possible that get_acpi() returns an error instead.
We should not be writing error values to the ACPI device, even though
it's quite possible that we couldn't contact the ACPI device in the
first place.
eeepc_get_fan_pwm and eeepc_set_fan_pwm convert the PWM value read from
the fan to a range lmsensors understands. Unfortunately this is only
clear if you are familiar with how lmsensors handles duty cycles.
Introduce two conversion functions that document the goal of these
conversions.
eeepc_[gs]et_fan_ctrl uses some magic numbers. These numbers mean
something more than just the number. Describe them with macros instead
of comments in one of the functions.
The rfkill notifier node names are used in three different places. As a
matter of style, it is better to store them somewhere and have the
compiler warn us about typos in the function arguments.
As per Documentation/CodingStyle ch. 2, it is preferred that we don't
break user visible strings, in order to allow users to grep for them.
In eeepc_rfkill_hotplug there's an if statement with a big tail that
ends right before the out_unlock label. We might as well invert the
condition and jump to out_unlock in that case, pretty much like the rest
of the code does. This removes an indentation level for a large chunk of
code and also stops suggesting there might be an else clause.
Instead of using a magic constant 0x20 in some drivers to get data only
from the KBC port we should use the constant defined in i8042.h with
the same value. Also, this makes these drivers uniform with what
constant the only other filter function uses in
drivers/input/misc/ideapad_slidebar.c.
Signed-off-by: Giedrius Statkevičius <giedriuswork@gmail.com>
i8042.h/serio.h
Make hp_accel dependent on SERIO_I8042 in the Kconfig because since commit
a4c724d0723b078e4ab4670e557cda1795036a7a ('platform: hp_accel: add a i8042
filter to remove HPQ6000 data from kb bus stream') hp_accel includes i8042.h
and serio.h.
Reported-by: Jim Davis <jim.epost@gmail.com>
Add a i8042 filter to hp_accel to remove accelerometer's data with acpi
id HPQ6000 from keyboard bus stream. The codes sent by accelerometer are
e0 25, e0 26, e0 27 and e0 28. The relevant information is already
passed through /dev/freefall so no need to send these undocumented weird
signals through the keyboard bus. Also, unclogs `dmesg` because atkbd
complained about weird scan codes, saves processing power and disk
space.
Acked-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
Reviewed-by: Éric Piel <eric.piel@tremplin-utc.net>
The Yoga 3 does not contain any physical rfkill switch. Therefore
disable the rfkill switch identically to the Yoga 2 approach.
Signed-off-by: Stephan Mueller <smueller@chronox.de>
The acpi-video backlight interface on the Acer KAV80 is broken, and worse
it causes the entire machine to slow down significantly after a suspend/resume.
Blacklist it, and use the acer-wmi backlight interface instead. Note that
the KAV80 is somewhat unique in that it is the only Acer model where we
fall back to acer-wmi after blacklisting, rather then using the native
(e.g. intel) backlight driver. This is done because there is no native
backlight interface on this model.
BugLink: https://bugzilla.redhat.com/show_bug.cgi?id=1128309
The acpi-video backlight interface on the NC210 does not work, blacklist it
and use the samsung-laptop interface instead.
BugLink: https://bugzilla.redhat.com/show_bug.cgi?id=861573
X550VB as many others Asus laptops need wapf4 quirk to make RFKILL
switch be functional. Otherwise system boots with wireless card
disabled and is only possible to enable it by suspend/resume.
Bug report:
http://bugzilla.redhat.com/show_bug.cgi?id=1089731#c23
Reported-and-tested-by: Vratislav Podzimek <vpodzime@redhat.com>
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
As bug #72551, the Toshiba TECRA A50-A series models also come with the
new keymap layout as found out by Azael Avalos, so add it to the dmi
table.
Buglink: https://bugzilla.kernel.org/show_bug.cgi?id=76971
Reported-and-tested-by: Blindekinder <rafael.raccuia@blindekinder.com>
Cc: Azael Avalos <coproscefalo@gmail.com>
Signed-off-by: Aaron Lu <aaron.lu@intel.com>
A platform_driver does not need to set an owner, it will be populated by the
driver core.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
driver core.
The kernel used to contain two functions for length-delimited,
case-insensitive string comparison, strnicmp with correct semantics and
a slightly buggy strncasecmp. The latter is the POSIX name, so strnicmp
was renamed to strncasecmp, and strnicmp made into a wrapper for the new
strncasecmp to avoid breaking existing users.
To allow the compat wrapper strnicmp to be removed at some point in the
future, and to avoid the extra indirection cost, do
s/strnicmp/strncasecmp/g.
Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk>
Cc: Henrique de Moraes Holschuh <ibm-acpi@hmh.eng.br>
Pull x86 platform driver updates from Darren Hart:
"The following have all spent at least a few days in linux-next, most
for more than a week. These are mostly cleanups and error handling
improvements with a few updates to extend existing support to newer
hardware.
Details:
- dell-wmi: fix access out of memory
- eeepc-laptop: cleanups, refactoring, sysfs perms, and improved
error handling
- intel-rst: ACPI and error handling cleanups
- thinkpad-acpi: whitespace cleanup
- toshiba_acpi: HCI/SCI interface update, keyboard backlight type 2
support, new scancodes, cleanups"
* tag 'platform-drivers-x86-v3.18-1' of git://git.infradead.org/users/dvhart/linux-platform-drivers-x86: (23 commits)
toshiba_acpi: Adapt kbd_bl_timeout_store to the new kbd type
toshiba_acpi: Change HCI/SCI functions return code type
toshiba_acpi: Unify return codes prefix from HCI/SCI to TOS
toshiba_acpi: Rename hci_raw to tci_raw
dell-wmi: Fix access out of memory
eeepc-laptop: clean up control flow in *_rfkill_notifier
eeepc-laptop: store_cpufv: return error if set_acpi fails
eeepc-laptop: check proper return values in get_cpufv
eeepc-laptop: make fan1_input really read-only
eeepc-laptop: pull out SENSOR_STORE_FUNC and SENSOR_SHOW_FUNC macros
eeepc-laptop: tell sysfs that the disp attribute is write-only
eeepc-laptop: pull out ACPI_STORE_FUNC and ACPI_SHOW_FUNC macros
eeepc-laptop: use DEVICE_ATTR* to instantiate device_attributes
eeepc-laptop: change sysfs function names to API expectations
eeepc-laptop: clean up coding style
eeepc-laptop: simplify parse_arg()
intel-rst: Clean up ACPI add function
intel-rst: Use ACPI_FAILURE() macro instead !ACPI_SUCCESS() for error checking
x86: thinkpad_acpi.c: fixed spacing coding style issue
toshiba_acpi: Support new keyboard backlight type
Pull ACPI and power management updates from Rafael Wysocki:
"Features-wise, to me the most important this time is a rework of
wakeup interrupts handling in the core that makes them work
consistently across all of the available sleep states, including
suspend-to-idle. Many thanks to Thomas Gleixner for his help with
this work.
Second is an update of the generic PM domains code that has been in
need of some care for quite a while. Unused code is being removed, DT
support is being added and domains are now going to be attached to
devices in bus type code in analogy with the ACPI PM domain. The
majority of work here was done by Ulf Hansson who also has been the
most active developer this time.
Apart from this we have a traditional ACPICA update, this time to
upstream version 20140828 and a few ACPI wakeup interrupts handling
patches on top of the general rework mentioned above. There also are
several cpufreq commits including renaming the cpufreq-cpu0 driver to
cpufreq-dt, as this is what implements generic DT-based cpufreq
support, and a new DT-based idle states infrastructure for cpuidle.
In addition to that, the ACPI LPSS driver is updated, ACPI support for
Apple machines is improved, a few bugs are fixed and a few cleanups
are made all over.
Finally, the Adaptive Voltage Scaling (AVS) subsystem now has a tree
maintained by Kevin Hilman that will be merged through the PM tree.
Numbers-wise, the generic PM domains update takes the lead this time
with 32 non-merge commits, second is cpufreq (15 commits) and the 3rd
place goes to the wakeup interrupts handling rework (13 commits).
Specifics:
- Rework the handling of wakeup IRQs by the IRQ core such that all of
them will be switched over to "wakeup" mode in suspend_device_irqs()
and in that mode the first interrupt will abort system suspend in
progress or wake up the system if already in suspend-to-idle (or
equivalent) without executing any interrupt handlers. Among other
things that eliminates the wakeup-related motivation to use the
IRQF_NO_SUSPEND interrupt flag with interrupts which don't really
need it and should not use it (Thomas Gleixner and Rafael Wysocki)
- Switch over ACPI to handling wakeup interrupts with the help of the
new mechanism introduced by the above IRQ core rework (Rafael Wysocki)
- Rework the core generic PM domains code to eliminate code that's
not used, add DT support and add a generic mechanism by which
devices can be added to PM domains automatically during enumeration
(Ulf Hansson, Geert Uytterhoeven and Tomasz Figa).
- Add debugfs-based mechanics for debugging generic PM domains
(Maciej Matraszek).
- ACPICA update to upstream version 20140828. Included are updates
related to the SRAT and GTDT tables and the _PSx methods are in the
METHOD_NAME list now (Bob Moore and Hanjun Guo).
- Add _OSI("Darwin") support to the ACPI core (unfortunately, that
can't really be done in a straightforward way) to prevent
Thunderbolt from being turned off on Apple systems after boot (or
after resume from system suspend) and rework the ACPI Smart Battery
Subsystem (SBS) driver to work correctly with Apple platforms
(Matthew Garrett and Andreas Noever).
- ACPI LPSS (Low-Power Subsystem) driver update cleaning up the code,
adding support for 133MHz I2C source clock on Intel Baytrail to it
and making it avoid using UART RTS override with Auto Flow Control
(Heikki Krogerus).
- ACPI backlight updates removing the video_set_use_native_backlight
quirk which is not necessary any more, making the code check the
list of output devices returned by the _DOD method to avoid
creating acpi_video interfaces that won't work and adding a quirk
for Lenovo Ideapad Z570 (Hans de Goede, Aaron Lu and Stepan Bujnak)
- New Win8 ACPI OSI quirks for some Dell laptops (Edward Lin)
- Assorted ACPI code cleanups (Fabian Frederick, Rasmus Villemoes,
Sudip Mukherjee, Yijing Wang, and Zhang Rui)
- cpufreq core updates and cleanups (Viresh Kumar, Preeti U Murthy,
Rasmus Villemoes)
- cpufreq driver updates: cpufreq-cpu0/cpufreq-dt (driver name change
among other things), ppc-corenet, powernv (Viresh Kumar, Preeti U
Murthy, Shilpasri G Bhat, Lucas Stach)
- cpuidle support for DT-based idle states infrastructure, new ARM64
cpuidle driver, cpuidle core cleanups (Lorenzo Pieralisi, Rasmus
Villemoes)
- ARM big.LITTLE cpuidle driver updates: support for DT-based
initialization and Exynos5800 compatible string (Lorenzo Pieralisi,
Kevin Hilman)
- Rework of the test_suspend kernel command line argument and a new
trace event for console resume (Srinivas Pandruvada, Todd E Brandt)
- Second attempt to optimize swsusp_free() (hibernation core) to make
it avoid going through all PFNs which may be way too slow on some
systems (Joerg Roedel)
- devfreq updates (Paul Bolle, Punit Agrawal, Ãrjan Eide).
- rockchip-io Adaptive Voltage Scaling (AVS) driver and AVS entry
update in MAINTAINERS (Heiko Stübner, Kevin Hilman)
- PM core fix related to clock management (Geert Uytterhoeven)
- PM core's sysfs code cleanup (Johannes Berg)"
* tag 'pm+acpi-3.18-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (105 commits)
ACPI / fan: printk replacement
PM / clk: Fix crash in clocks management code if !CONFIG_PM_RUNTIME
PM / Domains: Rename cpu_data to cpuidle_data
cpufreq: cpufreq-dt: fix potential double put of cpu OF node
cpufreq: cpu0: rename driver and internals to 'cpufreq_dt'
PM / hibernate: Iterate over set bits instead of PFNs in swsusp_free()
cpufreq: ppc-corenet: remove duplicate update of cpu_data
ACPI / sleep: Rework the handling of ACPI GPE wakeup from suspend-to-idle
PM / sleep: Rename platform suspend/resume functions in suspend.c
PM / sleep: Export dpm_suspend_late/noirq() and dpm_resume_early/noirq()
ACPICA: Introduce acpi_enable_all_wakeup_gpes()
ACPICA: Clear all non-wakeup GPEs in acpi_hw_enable_wakeup_gpe_block()
ACPI / video: check _DOD list when creating backlight devices
PM / Domains: Move dev_pm_domain_attach|detach() to pm_domain.h
cpufreq: Replace strnicmp with strncasecmp
cpufreq: powernv: Set the cpus to nominal frequency during reboot/kexec
cpufreq: powernv: Set the pstate of the last hotplugged out cpu in policy->cpus to minimum
cpufreq: Allow stop CPU callback to be used by all cpufreq drivers
PM / devfreq: exynos: Enable building exynos PPMU as module
PM / devfreq: Export helper functions for drivers
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio
Pull GPIO changes from Linus Walleij:
"This is the bulk of GPIO changes for the v3.18 development cycle:
- Increase the default ARCH_NR_GPIO from 256 to 512. This was done
to avoid having a custom <asm/gpio.h> header for the x86
architecture - GPIO is custom and complicated enough as it is
already! We want to move to a radix to store the descriptors going
forward, and finally get rid of this fixed array size altogether.
- Endgame patching of the gpio_remove() semantics initiated by
Abdoulaye Berthe. It is not accepted by the system that the
removal of a GPIO chip fails during eg reboot or shutdown, and
therefore the return value has now painfully been refactored away.
For special cases like GPIO expanders on a hot-pluggable bus like
USB, we may later add some gpiochip_try_remove() call, but for the
cases we have now, return values are moot.
- Some incremental refactoring of the gpiolib core and ACPI GPIO
library for more descriptor usage.
- Refactor the chained IRQ handler set-up method to handle also
threaded, nested interrupts and set up the parent IRQ correctly.
Switch STMPE and TC3589x drivers to use this registration method.
- Add a .irq_not_threaded flag to the struct gpio_chip, so that also
GPIO expanders that block but are still not using threaded IRQ
handlers.
- New drivers for the ARM64 X-Gene SoC GPIO controller.
- The syscon GPIO driver has been improved to handle the "DSP GPIO"
found on the TI Keystone 2 SoC:s.
- ADNP driver switched to use gpiolib irqchip helpers.
- Refactor the DWAPB driver to support being instantiated from and
MFD cell (platform device).
- Incremental feature improvement in the Zynq, MCP23S08, DWAPB, OMAP,
Xilinx and Crystalcove drivers.
- Various minor fixes"
* tag 'gpio-v3.18-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (52 commits)
gpio: pch: Build context save/restore only for PM
pinctrl: abx500: get rid of unused variable
gpio: ks8695: fix 'else should follow close brace '}''
gpio: stmpe: add verbose debug code
gpio: stmpe: fix up interrupt enable logic
gpio: staticize xway_stp_init()
gpio: handle also nested irqchips in the chained handler set-up
gpio: set parent irq on chained handlers
gpiolib: irqchip: use irq_find_mapping while removing irqchip
gpio: crystalcove: support virtual GPIO
pinctrl: bcm281xx: make Kconfig dependency more strict
gpio: kona: enable only on BCM_MOBILE or for compile testing
gpio, bcm-kona, LLVMLinux: Remove use of __initconst
gpio: Fix ngpio in gpio-xilinx driver
gpio: dwapb: fix pointer to integer cast
gpio: xgene: Remove unneeded #ifdef CONFIG_OF guard
gpio: xgene: Remove unneeded forward declation for struct xgene_gpio
gpio: xgene: Fix missing spin_lock_init()
gpio: ks8695: fix switch case indentation
gpiolib: add irq_not_threaded flag to gpio_chip
