path: root/drivers/pnp/Makefile
2010-10-27PNP: Compile all pnp built-in stuff in one module namespaceThomas Renninger
This is cleanup mostly, nothing urgent. I came up with it when looking at dynamic debug which can enable pr_debug messages at runtime or boot param for a specific module. Advantages: - Any pnp code can make use of the moduleparam.h interface, the modules will show up as pnp.param. - Passing pnp.ddebug as kernel boot param will enable all pnp debug messages with my previous patch and CONFIG_DYNAMIC_DEBUG enabled. Signed-off-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-10-23Merge branch 'linus' into testLen Brown
Conflicts: MAINTAINERS arch/x86/kernel/acpi/boot.c arch/x86/kernel/acpi/sleep.c drivers/acpi/Kconfig drivers/pnp/Makefile drivers/pnp/quirks.c Signed-off-by: Len Brown <len.brown@intel.com>
2008-10-10PNP: remove old CONFIG_PNP_DEBUG optionBjorn Helgaas
CONFIG_PNP_DEBUG is no longer used to turn on dev_dbg() in PNP, since we have pnp_dbg() which can be enabled at boot-time, so this patch removes the config option. Note that pnp_dock_event() checks "#ifdef DEBUG". But there's never been a clear path for enabling that via configgery. It happened that CONFIG_PNP_DEBUG enabled it after 1bd17e63a068db6, but that was accidental and only in 2.6.26. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-10-10PnP: move pnpacpi/pnpbios_init to after PCI initLinus Torvalds
We already did that a long time ago for pnp_system_init, but pnpacpi_init and pnpbios_init remained as subsys_initcalls, and get linked into the kernel before the arch-specific routines that finalize the PCI resources (pci_subsys_init). This means that the PnP routines would either register their resources before the PCI layer could, or would be unable to check whether a PCI resource had already been registered. Both are problematic. I wanted to do this before 2.6.27, but every time we change something like this, something breaks. That said, _every_ single time we trust some firmware (like PnP tables) more than we trust the hardware itself (like PCI probing), the problems have been worse. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17PNP: use dev_info(), dev_err(), etc in coreBjorn Helgaas
If we have the struct pnp_dev available, we can use dev_info(), dev_err(), etc., to give a little more information and consistency. [akpm@linux-foundation.org: fix warning] Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Adam Belay <ambx1@neo.rr.com> Cc: Len Brown <lenb@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
