path: root/drivers/pnp/pnpacpi/rsparser.c
2011-11-06PNPACPI: Simplify disabled resource registrationWitold Szczeponik
The attached patch simplifies 29df8d8f8702f0f53c1375015f09f04bc8d023c1. As the "pnp_xxx" structs are not designed to cope with IORESOURCE_DISABLED, and hence no code can test for this value, setting this value is actually a "no op" and can be skipped altogether. It is sufficient to remove the checks for "empty" resources and continue processing. The patch is applied against 3.1. Signed-off-by: Witold Szczeponik <Witold.Szczeponik@gmx.net> Acked-by: Bjorn Helgaas <bhelgaas@google.com> Signed-off-by: Len Brown <len.brown@intel.com>
2011-07-25Merge 'akpm' patch seriesLinus Torvalds
* Merge akpm patch series: (122 commits) drivers/connector/cn_proc.c: remove unused local Documentation/SubmitChecklist: add RCU debug config options reiserfs: use hweight_long() reiserfs: use proper little-endian bitops pnpacpi: register disabled resources drivers/rtc/rtc-tegra.c: properly initialize spinlock drivers/rtc/rtc-twl.c: check return value of twl_rtc_write_u8() in twl_rtc_set_time() drivers/rtc: add support for Qualcomm PMIC8xxx RTC drivers/rtc/rtc-s3c.c: support clock gating drivers/rtc/rtc-mpc5121.c: add support for RTC on MPC5200 init: skip calibration delay if previously done misc/eeprom: add eeprom access driver for digsy_mtc board misc/eeprom: add driver for microwire 93xx46 EEPROMs checkpatch.pl: update $logFunctions checkpatch: make utf-8 test --strict checkpatch.pl: add ability to ignore various messages checkpatch: add a "prefer __aligned" check checkpatch: validate signature styles and To: and Cc: lines checkpatch: add __rcu as a sparse modifier checkpatch: suggest using min_t or max_t ... Did this as a merge because of (trivial) conflicts in - Documentation/feature-removal-schedule.txt - arch/xtensa/include/asm/uaccess.h that were just easier to fix up in the merge than in the patch series.
2011-07-25pnpacpi: register disabled resourcesWitold Szczeponik
When parsing PnP ACPI resource structures, it may happen that some of the resources are disabled (in which case "the size" of the resource equals zero). The current solution is to skip these resources completely - with the unfortunate side effect that they are not registered despite the fact that they exist, after all. (The downside of this approach is that these resources cannot be used as templates for setting the actual device's resources because they are missing from the template.) The kernel's APM implementation does not suffer from this problem and registers all resources regardless of "their size". This patch fixes a problem with (at least) the vintage IBM ThinkPad 600E (and most likely also with the 600, 600X, and 770X which have a very similar layout) where some of its PnP devices support options where either an IRQ, a DMA, or an IO port is disabled. Without this patch, the devices can not be configured using the "/sys/bus/pnp/devices/*/resources" interface. The manipulation of these resources is important because the 600E has very demanding requirements. For instance, the number of IRQs is not sufficient to support all devices of the 600E. Fortunately, some of the devices, like the sound card's MPU-401 UART, can be configured to not use any IRQ, hence freeing an IRQ for a device that requires one. (Still, the device's "ResourceTemplate" requires an IRQ resource descriptor which cannot be created if the resource has not been registered in the first place.) As an example, the dependent sets of the 600E's CSC0103 device (the MPU-401 UART) are listed, with the patch applied, as: Dependent: 00 - Priority preferred port 0x300-0x330, align 0xf, size 0x4, 16-bit address decoding irq <none> High-Edge Dependent: 01 - Priority acceptable port 0x300-0x330, align 0xf, size 0x4, 16-bit address decoding irq 5,7,2/9,10,11,15 High-Edge (The same result is obtained when PNPBIOS is used instead of PnP ACPI.) Without the patch, the IRQ resource in the preferred option is not listed at all: Dependent: 00 - Priority preferred port 0x300-0x330, align 0xf, size 0x4, 16-bit address decoding Dependent: 01 - Priority acceptable port 0x300-0x330, align 0xf, size 0x4, 16-bit address decoding irq 5,7,2/9,10,11,15 High-Edge And in fact, the 600E's DSDT lists the disabled IRQ as an option, as can be seen from the following excerpt from the DSDT: Name (_PRS, ResourceTemplate () { StartDependentFn (0x00, 0x00) { IO (Decode16, 0x0300, 0x0330, 0x10, 0x04) IRQNoFlags () {} } StartDependentFn (0x01, 0x00) { IO (Decode16, 0x0300, 0x0330, 0x10, 0x04) IRQNoFlags () {5,7,9,10,11,15} } EndDependentFn () }) With this patch applied, a user space program - or maybe even the kernel - can allocate all devices' resources optimally. For the 600E, this means to find optimal resources for (at least) the serial port, the parallel port, the infrared port, the MWAVE modem, the sound card, and the MPU-401 UART. The patch applies the idea to register disabled resources to all types of resources, not just to IRQs, DMAs, and IO ports. At the same time, it mimics the behavior of the "pnp_assign_xxx" functions from "drivers/pnp/manager.c" where resources with "no size" are considered disabled. No regressions were observed on hardware that does not require this patch. The patch is applied against 2.6.39. NB: The kernel's current PnP interface does not allow for disabling individual resources using the "/sys/bus/pnp/devices/$device/resources" file. Assuming this could be done, a device could be configured to use a disabled resource using a simple series of calls: echo disable > /sys/bus/pnp/devices/$device/resources echo clear > /sys/bus/pnp/devices/$device/resources echo set irq disabled > /sys/bus/pnp/devices/$device/resources echo fill > /sys/bus/pnp/devices/$device/resources echo activate > /sys/bus/pnp/devices/$device/resources This patch addresses only the parsing of PnP ACPI devices. ChangeLog (v1 -> v2): - extend patch description - fix typo in patch itself Signed-off-by: Witold Szczeponik <Witold.Szczeponik@gmx.net> Cc: Len Brown <lenb@kernel.org> Cc: Adam Belay <abelay@mit.edu> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Bjorn Helgaas <bhelgaas@google.com> Cc: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Cc: Matthew Garrett <mjg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-10treewide: Convert uses of struct resource to resource_size(ptr)Joe Perches
Several fixes as well where the +1 was missing. Done via coccinelle scripts like: @@ struct resource *ptr; @@ - ptr->end - ptr->start + 1 + resource_size(ptr) and some grep and typing. Mostly uncompiled, no cross-compilers. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-04-28PNPACPI: compute Address Space length rather than using _LENBjorn Helgaas
ACPI _CRS Address Space Descriptors have _MIN, _MAX, and _LEN. Linux has been computing Address Spaces as [_MIN to _MIN + _LEN - 1]. Based on the tests in the bug reports below, Windows apparently uses [_MIN to _MAX]. Per spec (ACPI 4.0, Table 6-40), for _CRS fixed-size, fixed location descriptors, "_LEN must be (_MAX - _MIN + 1)", and when that's true, it doesn't matter which way we compute the end. But of course, there are BIOSes that don't follow this rule, and we're better off if Linux handles those exceptions the same way as Windows. This patch makes Linux use [_MIN to _MAX], as Windows seems to do. This effectively reverts 3162b6f0c5e and replaces it with simpler code. https://bugzilla.kernel.org/show_bug.cgi?id=14337 (round) https://bugzilla.kernel.org/show_bug.cgi?id=15480 (truncate) Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-04-06Merge branches 'battery', 'bugzilla-14667', 'bugzilla-15096', ↵Len Brown
'bugzilla-15480', 'bugzilla-15521', 'bugzilla-15605', 'gpe-reference-counters', 'misc', 'pxm-fix' and 'video-random-key' into release
2010-04-04PNPACPI: truncate _CRS windows with _LEN > _MAX - _MIN + 1Bjorn Helgaas
The ACPI spec (sec 6.4.3.5 in v4.0) requires that for Address Space Resource Descriptors, _LEN <= _MAX - _MIN + 1 in all cases, but there are BIOSes that violate this. We experimentally determined that Windows truncates the resource so it doesn't extend past _MAX, so let's do the same thing in Linux. http://bugzilla.kernel.org/show_bug.cgi?id=15480 Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Acked-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-14PNPACPI: add bus number supportBjorn Helgaas
Add support for bus number resources. This is for bridges with a range of bus numbers behind them. Previously, PNP ignored bus number resources. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-03-14PNPACPI: add window supportBjorn Helgaas
Add support for resource windows. This is for bridge resources, i.e., regions where a bridge forwards transactions from the primary to the secondary side. This does not add support for *setting* windows via the /proc interface. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-12-11PNPACPI: save struct acpi_device, not just acpi_handleBjorn Helgaas
Some drivers need to look at things in the acpi_device structure besides the handle. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-06-24Merge branches 'acerhdf', 'acpi-pci-bind', 'bjorn-pci-root', ↵Len Brown
'bugzilla-12904', 'bugzilla-13121', 'bugzilla-13396', 'bugzilla-13533', 'bugzilla-13612', 'c3_lock', 'hid-cleanups', 'misc-2.6.31', 'pdc-leak-fix', 'pnpacpi', 'power_nocheck', 'thinkpad_acpi', 'video' and 'wmi' into release
2009-05-27PNPACPI: parse Extended Address Space DescriptorsBjorn Helgaas
Extended Address Space Descriptors are new in ACPI 3.0 and allow the BIOS to communicate device resource cacheability attributes (write-back, write-through, uncacheable, etc) to the OS. Previously, PNPACPI ignored these descriptors, so if a BIOS used them, a device could be responding at addresses the OS doesn't know about. This patch adds support for these descriptors in _CRS and _PRS. We don't attempt to encode them for _SRS (just like we don't attempt to encode the existing 16-, 32-, and 64-bit Address Space Descriptors). Unfortunately, I don't have a way to test this. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-04-28irq: change ACPI GSI APIs to also take a device argumentYinghai Lu
We want to use dev_to_node() later on, to be aware of the 'home node' of the GSI in question. [ Impact: cleanup, prepare the IRQ code to be more NUMA aware ] Signed-off-by: Yinghai Lu <yinghai@kernel.org> Acked-by: Len Brown <lenb@kernel.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Suresh Siddha <suresh.b.siddha@intel.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Len Brown <lenb@kernel.org> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Tony Luck <tony.luck@intel.com> Cc: linux-acpi@vger.kernel.org Cc: linux-ia64@vger.kernel.org LKML-Reference: <49F65560.20904@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-10PNP: convert to using pnp_dbg()Bjorn Helgaas
pnp_dbg() is equivalent to dev_dbg() except that we can turn it on at boot-time with the "pnp.debug" kernel parameter, so we don't have to build a new kernel image. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-10-10PNPACPI: use dev_printk when possibleBjorn Helgaas
Use dev_printk() when possible for more informative error messages. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-08-25PNPACPI: ignore the producer/consumer bit for extended IRQ descriptorsBjorn Helgaas
The Extended Interrupt descriptor has a producer/consumer bit, but it's not clear what that would mean, and existing BIOSes use the bit inconsistently. This patch makes Linux PNPACPI ignore the bit. The ACPI spec contains examples of PCI Interrupt Link devices marked as ResourceProducers, but many BIOSes mark them as ResourceConsumers. I also checked with a Windows contact, who said: Windows uses only "resource consumer" when dealing with interrupts. There's no useful way of looking at a resource producer of interrupts. ... NT-based Windows largely infers the producer/consumer stuff from the device type and ignores the bits in the namespace. This was necessary because Windows 98 ignored them and early namespaces contained random junk. The reason I want to change this is because if PNPACPI devices exclude ResourceProducer IRQ resources, we can't write PNP drivers for those devices. For example, on machines such as the the HP rx7620, rx7640, rx8620, rx8640, and Superdome, HPET interrupts are ResourceProducers. The HPET driver currently has to use acpi_bus_register_driver() and do its own _CRS parsing, even though it requires absolutely no ACPI-specific functionality. It would be better if the HPET driver were a PNP driver and took advantage of the _CRS parsing built into PNPACPI. This producer/consumer check was originally added here: http://git.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git;a=commitdiff;h=2b8de5f50e4a302b83ebcd5b0120621336d50bd6 to fix this bug: http://bugzilla.kernel.org/show_bug.cgi?id=6292 However, the bug was related only to memory and I/O port resources, where the distinction is sensible and important to Linux. Given that the distinction is muddled for IRQ resources, I think it was a mistake to add the check there. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2008-07-16PNPACPI: add support for HP vendor-specific CCSR descriptorsBjorn Helgaas
The HP CCSR descriptor describes MMIO address space that should appear as a MEM resource. This patch adds support for parsing these descriptors in the _CRS data. The visible effect of this is that these MEM resources will appear in /sys/devices/pnp0/.../resources, which means that "lspnp -v" will report it, user applications can use this to locate device CSR space, and kernel drivers can use the normal PNP resource accessors to locate them. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2008-07-16PNP: convert resource options to single linked listBjorn Helgaas
ISAPNP, PNPBIOS, and ACPI describe the "possible resource settings" of a device, i.e., the possibilities an OS bus driver has when it assigns I/O port, MMIO, and other resources to the device. PNP used to maintain this "possible resource setting" information in one independent option structure and a list of dependent option structures for each device. Each of these option structures had lists of I/O, memory, IRQ, and DMA resources, for example: dev independent options ind-io0 -> ind-io1 ... ind-mem0 -> ind-mem1 ... ... dependent option set 0 dep0-io0 -> dep0-io1 ... dep0-mem0 -> dep0-mem1 ... ... dependent option set 1 dep1-io0 -> dep1-io1 ... dep1-mem0 -> dep1-mem1 ... ... ... This data structure was designed for ISAPNP, where the OS configures device resource settings by writing directly to configuration registers. The OS can write the registers in arbitrary order much like it writes PCI BARs. However, for PNPBIOS and ACPI devices, the OS uses firmware interfaces that perform device configuration, and it is important to pass the desired settings to those interfaces in the correct order. The OS learns the correct order by using firmware interfaces that return the "current resource settings" and "possible resource settings," but the option structures above doesn't store the ordering information. This patch replaces the independent and dependent lists with a single list of options. For example, a device might have possible resource settings like this: dev options ind-io0 -> dep0-io0 -> dep1->io0 -> ind-io1 ... All the possible settings are in the same list, in the order they come from the firmware "possible resource settings" list. Each entry is tagged with an independent/dependent flag. Dependent entries also have a "set number" and an optional priority value. All dependent entries must be assigned from the same set. For example, the OS can use all the entries from dependent set 0, or all the entries from dependent set 1, but it cannot mix entries from set 0 with entries from set 1. Prior to this patch PNP didn't keep track of the order of this list, and it assigned all independent options first, then all dependent ones. Using the example above, that resulted in a "desired configuration" list like this: ind->io0 -> ind->io1 -> depN-io0 ... instead of the list the firmware expects, which looks like this: ind->io0 -> depN-io0 -> ind-io1 ... Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andi Kleen <ak@linux.intel.com> Acked-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-07-16PNP: remove extra 0x100 bit from option priorityBjorn Helgaas
When building resource options, ISAPNP and PNPBIOS set the priority to something like "0x100 | PNP_RES_PRIORITY_ACCEPTABLE", but we immediately mask off the 0x100 again in pnp_build_option(), so that bit looks superfluous. Thanks to Rene Herman <rene.herman@gmail.com> for pointing this out. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andi Kleen <ak@linux.intel.com> Acked-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-07-16PNPACPI: ignore _PRS interrupt numbers larger than PNP_IRQ_NRBjorn Helgaas
ACPI Extended Interrupt Descriptors can encode 32-bit interrupt numbers, so an interrupt number may exceed the size of the bitmap we use to track possible IRQ settings. To avoid corrupting memory, complain and ignore too-large interrupt numbers. There's similar code in pnpacpi_parse_irq_option(), but I didn't change that because the small IRQ descriptor can only encode IRQs 0-15, which do not exceed bitmap size. In the future, we could handle IRQ numbers greater than PNP_IRQ_NR by replacing the bitmap with a table or list. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andi Kleen <ak@linux.intel.com> Acked-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-07-16PNP: centralize resource option allocationsBjorn Helgaas
This patch moves all the option allocations (pnp_mem, pnp_port, etc) into the pnp_register_{mem,port,irq,dma}_resource() functions. This will make it easier to rework the option data structures. The non-trivial part of this patch is the IRQ handling. The backends have to allocate a local pnp_irq_mask_t bitmap, populate it, and pass a pointer to pnp_register_irq_resource(). Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andi Kleen <ak@linux.intel.com> Acked-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-07-16PNP: introduce pnp_irq_mask_t typedefBjorn Helgaas
This adds a typedef for the IRQ bitmap, which should cause no functional change, but will make it easier to pass a pointer to a bitmap to pnp_register_irq_resource(). Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andi Kleen <ak@linux.intel.com> Acked-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-07-16PNP: define PNP-specific IORESOURCE_IO_* flags alongside IRQ, DMA, MEMBjorn Helgaas
PNP previously defined PNP_PORT_FLAG_16BITADDR and PNP_PORT_FLAG_FIXED in a private header file, but put those flags in struct resource.flags fields. Better to make them IORESOURCE_IO_* flags like the existing IRQ, DMA, and MEM flags. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andi Kleen <ak@linux.intel.com> Acked-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-07-16PNPACPI: keep disabled resources when parsing current configBjorn Helgaas
When we parse a device's _CRS data (the current resource settings), we should keep track of everything we find, even if it's currently disabled or invalid. This is what we already do for ISAPNP and PNPBIOS, and it helps keep things matched up when we subsequently re-encode resources. For example, consider a device with (mem, irq0, irq1, io), where irq0 is disabled. If we drop irq0 when parsing the _CRS, we will mistakenly put irq1 in the irq0 slot when we encode resources for an _SRS call. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2008-07-16PNP: replace pnp_resource_table with dynamically allocated resourcesBjorn Helgaas
PNP used to have a fixed-size pnp_resource_table for tracking the resources used by a device. This table often overflowed, so we've had to increase the table size, which wastes memory because most devices have very few resources. This patch replaces the table with a linked list of resources where the entries are allocated on demand. This removes messages like these: pnpacpi: exceeded the max number of IO resources 00:01: too many I/O port resources References: http://bugzilla.kernel.org/show_bug.cgi?id=9535 http://bugzilla.kernel.org/show_bug.cgi?id=9740 http://lkml.org/lkml/2007/11/30/110 This patch also changes the way PNP uses the IORESOURCE_UNSET, IORESOURCE_AUTO, and IORESOURCE_DISABLED flags. Prior to this patch, the pnp_resource_table entries used the flags like this: IORESOURCE_UNSET This table entry is unused and available for use. When this flag is set, we shouldn't look at anything else in the resource structure. This flag is set when a resource table entry is initialized. IORESOURCE_AUTO This resource was assigned automatically by pnp_assign_{io,mem,etc}(). This flag is set when a resource table entry is initialized and cleared whenever we discover a resource setting by reading an ISAPNP config register, parsing a PNPBIOS resource data stream, parsing an ACPI _CRS list, or interpreting a sysfs "set" command. Resources marked IORESOURCE_AUTO are reinitialized and marked as IORESOURCE_UNSET by pnp_clean_resource_table() in these cases: - before we attempt to assign resources automatically, - if we fail to assign resources automatically, - after disabling a device IORESOURCE_DISABLED Set by pnp_assign_{io,mem,etc}() when automatic assignment fails. Also set by PNPBIOS and PNPACPI for: - invalid IRQs or GSI registration failures - invalid DMA channels - I/O ports above 0x10000 - mem ranges with negative length After this patch, there is no pnp_resource_table, and the resource list entries use the flags like this: IORESOURCE_UNSET This flag is no longer used in PNP. Instead of keeping IORESOURCE_UNSET entries in the resource list, we remove entries from the list and free them. IORESOURCE_AUTO No change in meaning: it still means the resource was assigned automatically by pnp_assign_{port,mem,etc}(), but these functions now set the bit explicitly. We still "clean" a device's resource list in the same places, but rather than reinitializing IORESOURCE_AUTO entries, we just remove them from the list. Note that IORESOURCE_AUTO entries are always at the end of the list, so removing them doesn't reorder other list entries. This is because non-IORESOURCE_AUTO entries are added by the ISAPNP, PNPBIOS, or PNPACPI "get resources" methods and by the sysfs "set" command. In each of these cases, we completely free the resource list first. IORESOURCE_DISABLED In addition to the cases where we used to set this flag, ISAPNP now adds an IORESOURCE_DISABLED resource when it reads a configuration register with a "disabled" value. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2008-06-11PNPACPI: use _CRS IRQ descriptor length for _SRSBjorn Helgaas
When configuring the resources of an ACPI device, we first evaluate _CRS to get a template of resource descriptors, then fill in the specific resource values we want, and finally evaluate _SRS to actually configure the device. Some resources have optional fields, so the size of encoded descriptors varies depending on the specific values. For example, IRQ descriptors can be either two or three bytes long. The third byte contains triggering information and can be omitted if the IRQ is edge-triggered and active high. The BIOS often assumes that IRQ descriptors in the _SRS buffer use the same format as those in the _CRS buffer, so this patch enforces that constraint. The "Start Dependent Function" descriptor also has an optional byte, but we don't currently encode those descriptors, so I didn't do anything for those. I have tested this patch on a Toshiba Portege 4000. Without the patch, parport_pc claims the parallel port only if I use "pnpacpi=off". This patch makes it work with PNPACPI. This is an extension of a patch by Tom Jaeger: http://bugzilla.kernel.org/show_bug.cgi?id=9487#c42 References: http://bugzilla.kernel.org/show_bug.cgi?id=5832 Enabling ACPI Plug and Play in kernels >2.6.9 kills Parallel support http://bugzilla.kernel.org/show_bug.cgi?id=9487 buggy firmware expects four-byte IRQ resource descriptor (was: Serial port disappears after Suspend on Toshiba R25) http://git.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git;a=commitdiff;h=1d5b285da1893b90507b081664ac27f1a8a3dc5b related ACPICA fix Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com>
2008-06-11pnpacpi: fix shareable IRQ encode/decodeBjorn Helgaas
When we encode IRQ resources, we should use the "shareable" flag we got from _PRS rather than guessing based on the IRQ trigger mode. This is based on a patch by Tom Jaeger: http://bugzilla.kernel.org/show_bug.cgi?id=9487#c32 Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com>
2008-06-11pnpacpi: fix IRQ flag decodingBjorn Helgaas
When decoding IRQ trigger mode and polarity, it is not enough to mask by IORESOURCE_BITS because there are now additional bits defined. For example, if IORESOURCE_IRQ_SHAREABLE was set, we failed to set *triggering and *polarity at all. I can't point to a failure that this patch fixes, but bugs in this area have caused problems when resuming after suspend, for example: http://bugzilla.kernel.org/show_bug.cgi?id=6316 http://bugzilla.kernel.org/show_bug.cgi?id=9487 https://bugs.launchpad.net/ubuntu/+source/linux-source-2.6.22/+bug/152187 This is based on a patch by Tom Jaeger: http://bugzilla.kernel.org/show_bug.cgi?id=9487#c32 [rene.herman@keyaccess.nl: fix comment] Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-29PNPACPI: move _CRS/_PRS warnings closer to the actionBjorn Helgaas
Move warnings about _CRS and _PRS problems to the place where we actually make the ACPI calls. Then we don't have to pass around acpi_status values any more than necessary. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Acked-By: Rene Herman <rene.herman@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-29PNP: make generic pnp_add_mem_resource()Bjorn Helgaas
Add a pnp_add_mem_resource() that can be used by all the PNP backends. This consolidates a little more pnp_resource_table knowledge into one place. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-29PNP: make generic pnp_add_io_resource()Bjorn Helgaas
Add a pnp_add_io_resource() that can be used by all the PNP backends. This consolidates a little more pnp_resource_table knowledge into one place. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-29PNP: make generic pnp_add_dma_resource()Bjorn Helgaas
Add a pnp_add_dma_resource() that can be used by all the PNP backends. This consolidates a little more pnp_resource_table knowledge into one place. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-29PNP: make generic pnp_add_irq_resource()Bjorn Helgaas
Add a pnp_add_irq_resource() that can be used by all the PNP backends. This consolidates a little more pnp_resource_table knowledge into one place. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-29PNP: remove pnp_resource_table references from resource decodersBjorn Helgaas
This removes a few more references to the pnp_resource_table. No functional change. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-29PNP: make pnp_resource_table private to PNP coreBjorn Helgaas
There are no remaining references to the PNP_MAX_* constants or the pnp_resource_table structure outside of the PNP core. Make them private to the PNP core. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-29PNP: convert encoders to use pnp_get_resource(), not pnp_resource_tableBjorn Helgaas
This removes more direct references to pnp_resource_table. This path is used when telling a device what resources it should use. This doesn't convert ISAPNP because ISA needs to know the config register index in addition to the resource itself. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Acked-By: Rene Herman <rene.herman@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-29PNP: use dev_printk when possibleBjorn Helgaas
Use dev_printk() when possible for more informative error messages. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Acked-By: Rene Herman <rene.herman@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-29PNP: add pnp_init_resources(struct pnp_dev *) interfaceBjorn Helgaas
Add pnp_init_resources(struct pnp_dev *) to replace pnp_init_resource_table(), which takes a pointer to the pnp_resource_table itself. Passing only the pnp_dev * reduces the possibility for error in the caller and removes the pnp_resource_table implementation detail from the interface. Even though pnp_init_resource_table() is exported, I did not export pnp_init_resources() because it is used only by the PNP core. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Acked-By: Rene Herman <rene.herman@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-29PNP: add debug output to encodersBjorn Helgaas
Add debug output to encoders (enabled by CONFIG_PNP_DEBUG). This uses dev_printk, so I had to add pnp_dev arguments at the same time. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Acked-By: Rene Herman <rene.herman@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-29PNP: remove more pnp_resource_table argumentsBjorn Helgaas
Stop passing around struct pnp_resource_table pointers. In most cases, the caller doesn't need to know how the resources are stored inside the struct pnp_dev. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Acked-By: Rene Herman <rene.herman@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-29PNP: add debug output to option registrationBjorn Helgaas
Add debug output to resource option registration functions (enabled by CONFIG_PNP_DEBUG). This uses dev_printk, so I had to add pnp_dev arguments at the same time. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Acked-By: Rene Herman <rene.herman@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-29PNPACPI: pass pnp_dev instead of acpi_handleBjorn Helgaas
Pass the pnp_dev pointer when possible instead of the acpi_handle. This allows better error messages and reduces the chance of error in the caller. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Acked-By: Rene Herman <rene.herman@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-29PNPACPI: extend irq_flags() to set IORESOURCE_IRQ_SHAREABLE when appropriateBjorn Helgaas
This simplifies IRQ resource parsing slightly by computing all the IORESOURCE_IRQ_* flags at the same time. This also keeps track of shareability information when parsing options from _PRS. Previously we ignored shareability in _PRS. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Acked-By: Rene Herman <rene.herman@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-29PNPACPI: hoist dma_flags() out of pnpacpi_parse_allocated_dmaresource()Bjorn Helgaas
Hoist dma_flags() out of pnpacpi_parse_allocated_dmaresource() into its caller. This makes pnpacpi_parse_allocated_dmaresource() more similar to pnpbios_parse_allocated_dmaresource(). Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Acked-By: Rene Herman <rene.herman@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-29PNPACPI: use temporaries to reduce repetitionBjorn Helgaas
No functional change, just fewer words and fewer chances for transcription errors. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Acked-By: Rene Herman <rene.herman@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-29PNPACPI: pnpacpi_encode_ext_irq() wrongly set "irq" instead of "extended_irq"Bjorn Helgaas
pnpacpi_encode_ext_irq() should set resource->data.extended_irq, not resource->data.irq. This has been wrong since at least 2.6.12. I haven't seen any bug reports, but it's clearly incorrect. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-23pnpacpi: fix potential corruption on "pnpacpi: exceeded the max number of ↵Len Brown
IRQ resources 2" PNP_MAX_IRQ is 2 If a device invokes pnpacpi_parse_allocated_irqresource() 0, 1, or 2 times, we are happy. The 3rd time, we will fail and print "pnpacpi: exceeded the max number of IRQ resources: 2" The 4th and subsequent calls (if this ever happened) would silently scribble on irq_resource[2], which doesn't actualy exist. Found-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-26pnpacpi: reduce printk severity for "pnpacpi: exceeded the max number of ..."Len Brown
We have been printing these messages at KERN_ERR since 2.6.24, per http://bugzilla.kernel.org/show_bug.cgi?id=9535 But KERN_ERR pops up on a console booted with "quiet" and causes users to get alarmed and file bugs about the message itself: https://bugzilla.redhat.com/show_bug.cgi?id=436589 So reduce the severity of these messages to KERN_WARNING, which is not printed by "quiet". This message will still be seen without "quiet", but a lot of messages are printed in that mode and it will be less likely to cause undue alarm. We could go all the way to KERN_DEBUG, but this is a real warning after all, so it seems prudent not to require "debug" to see it. Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-06pnp: declare PNP option parsing functions as __initThomas Renninger
There are three kind of parse functions provided by PNP acpi/bios: - get current resources - set resources - get possible resources The first two may be needed later at runtime. The possible resource settings should never change dynamically. And even if this would make any sense (I doubt it), the current implementation only parses possible resource settings at early init time: -> declare all the option parsing __init [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Thomas Renninger <trenn@suse.de> Acked-By: Rene Herman <rene.herman@gmail.com> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
