path: root/drivers/pnp/quirks.c
2016-02-03PNP: Add Haswell-ULT to Intel MCH size workaroundJosh Boyer
Add device ID 0x0a04 for Haswell-ULT to the list of devices with MCH problems. From a Lenovo ThinkPad T440S: [ 0.188604] pnp: PnP ACPI init [ 0.189044] system 00:00: [mem 0x00000000-0x0009ffff] could not be reserved [ 0.189048] system 00:00: [mem 0x000c0000-0x000c3fff] could not be reserved [ 0.189050] system 00:00: [mem 0x000c4000-0x000c7fff] could not be reserved [ 0.189052] system 00:00: [mem 0x000c8000-0x000cbfff] could not be reserved [ 0.189054] system 00:00: [mem 0x000cc000-0x000cffff] could not be reserved [ 0.189056] system 00:00: [mem 0x000d0000-0x000d3fff] has been reserved [ 0.189058] system 00:00: [mem 0x000d4000-0x000d7fff] has been reserved [ 0.189060] system 00:00: [mem 0x000d8000-0x000dbfff] has been reserved [ 0.189061] system 00:00: [mem 0x000dc000-0x000dffff] has been reserved [ 0.189063] system 00:00: [mem 0x000e0000-0x000e3fff] could not be reserved [ 0.189065] system 00:00: [mem 0x000e4000-0x000e7fff] could not be reserved [ 0.189067] system 00:00: [mem 0x000e8000-0x000ebfff] could not be reserved [ 0.189069] system 00:00: [mem 0x000ec000-0x000effff] could not be reserved [ 0.189071] system 00:00: [mem 0x000f0000-0x000fffff] could not be reserved [ 0.189073] system 00:00: [mem 0x00100000-0xdf9fffff] could not be reserved [ 0.189075] system 00:00: [mem 0xfec00000-0xfed3ffff] could not be reserved [ 0.189078] system 00:00: [mem 0xfed4c000-0xffffffff] could not be reserved [ 0.189082] system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active) [ 0.189216] system 00:01: [io 0x1800-0x189f] could not be reserved [ 0.189220] system 00:01: [io 0x0800-0x087f] has been reserved [ 0.189222] system 00:01: [io 0x0880-0x08ff] has been reserved [ 0.189224] system 00:01: [io 0x0900-0x097f] has been reserved [ 0.189226] system 00:01: [io 0x0980-0x09ff] has been reserved [ 0.189229] system 00:01: [io 0x0a00-0x0a7f] has been reserved [ 0.189231] system 00:01: [io 0x0a80-0x0aff] has been reserved [ 0.189233] system 00:01: [io 0x0b00-0x0b7f] has been reserved [ 0.189235] system 00:01: [io 0x0b80-0x0bff] has been reserved [ 0.189238] system 00:01: [io 0x15e0-0x15ef] has been reserved [ 0.189240] system 00:01: [io 0x1600-0x167f] has been reserved [ 0.189242] system 00:01: [io 0x1640-0x165f] has been reserved [ 0.189246] system 00:01: [mem 0xf8000000-0xfbffffff] could not be reserved [ 0.189249] system 00:01: [mem 0x00000000-0x00000fff] could not be reserved [ 0.189251] system 00:01: [mem 0xfed1c000-0xfed1ffff] has been reserved [ 0.189254] system 00:01: [mem 0xfed10000-0xfed13fff] has been reserved [ 0.189256] system 00:01: [mem 0xfed18000-0xfed18fff] has been reserved [ 0.189258] system 00:01: [mem 0xfed19000-0xfed19fff] has been reserved [ 0.189261] system 00:01: [mem 0xfed45000-0xfed4bfff] has been reserved [ 0.189264] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active) [....] [ 0.583653] resource sanity check: requesting [mem 0xfed10000-0xfed15fff], which spans more than pnp 00:01 [mem 0xfed10000-0xfed13fff] [ 0.583654] ------------[ cut here ]------------ [ 0.583660] WARNING: CPU: 0 PID: 1 at arch/x86/mm/ioremap.c:198 __ioremap_caller+0x2c5/0x380() [ 0.583661] Info: mapping multiple BARs. Your kernel is fine. [ 0.583662] Modules linked in: [ 0.583666] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.3.3-303.fc23.x86_64 #1 [ 0.583668] Hardware name: LENOVO 20AR001GXS/20AR001GXS, BIOS GJET86WW (2.36 ) 12/04/2015 [ 0.583670] 0000000000000000 0000000014cf7e59 ffff880214a1baf8 ffffffff813a625f [ 0.583673] ffff880214a1bb40 ffff880214a1bb30 ffffffff810a07c2 00000000fed10000 [ 0.583675] ffffc90000cb8000 0000000000006000 0000000000000000 ffff8800d6381040 [ 0.583678] Call Trace: [ 0.583683] [<ffffffff813a625f>] dump_stack+0x44/0x55 [ 0.583686] [<ffffffff810a07c2>] warn_slowpath_common+0x82/0xc0 [ 0.583688] [<ffffffff810a085c>] warn_slowpath_fmt+0x5c/0x80 [ 0.583692] [<ffffffff810a6fba>] ? iomem_map_sanity_check+0xba/0xd0 [ 0.583695] [<ffffffff81065835>] __ioremap_caller+0x2c5/0x380 [ 0.583698] [<ffffffff81065907>] ioremap_nocache+0x17/0x20 [ 0.583701] [<ffffffff8103a119>] snb_uncore_imc_init_box+0x79/0xb0 [ 0.583705] [<ffffffff81038900>] uncore_pci_probe+0xd0/0x1b0 [ 0.583707] [<ffffffff813efda5>] local_pci_probe+0x45/0xa0 [ 0.583710] [<ffffffff813f118d>] pci_device_probe+0xfd/0x140 [ 0.583713] [<ffffffff814d9b52>] driver_probe_device+0x222/0x480 [ 0.583715] [<ffffffff814d9e34>] __driver_attach+0x84/0x90 [ 0.583717] [<ffffffff814d9db0>] ? driver_probe_device+0x480/0x480 [ 0.583720] [<ffffffff814d762c>] bus_for_each_dev+0x6c/0xc0 [ 0.583722] [<ffffffff814d930e>] driver_attach+0x1e/0x20 [ 0.583724] [<ffffffff814d8e4b>] bus_add_driver+0x1eb/0x280 [ 0.583727] [<ffffffff81d6af1a>] ? uncore_cpu_setup+0x12/0x12 [ 0.583729] [<ffffffff814da680>] driver_register+0x60/0xe0 [ 0.583733] [<ffffffff813ef78c>] __pci_register_driver+0x4c/0x50 [ 0.583736] [<ffffffff81d6affc>] intel_uncore_init+0xe2/0x2e6 [ 0.583738] [<ffffffff81d6af1a>] ? uncore_cpu_setup+0x12/0x12 [ 0.583741] [<ffffffff81002123>] do_one_initcall+0xb3/0x200 [ 0.583745] [<ffffffff810be500>] ? parse_args+0x1a0/0x4a0 [ 0.583749] [<ffffffff81d5c1c8>] kernel_init_freeable+0x189/0x223 [ 0.583752] [<ffffffff81775c40>] ? rest_init+0x80/0x80 [ 0.583754] [<ffffffff81775c4e>] kernel_init+0xe/0xe0 [ 0.583758] [<ffffffff81781adf>] ret_from_fork+0x3f/0x70 [ 0.583760] [<ffffffff81775c40>] ? rest_init+0x80/0x80 [ 0.583765] ---[ end trace 077c426a39e018aa ]--- 00:00.0 Host bridge [0600]: Intel Corporation Haswell-ULT DRAM Controller [8086:0a04] (rev 0b) Subsystem: Lenovo Device [17aa:220c] Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx- Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort+ >SERR- <PERR- INTx- Latency: 0 Capabilities: <access denied> Kernel driver in use: hsw_uncore Link: https://bugzilla.redhat.com/show_bug.cgi?id=1300955 Tested-by: <robo@tcp.sk> Signed-off-by: Josh Boyer <jwboyer@fedoraproject.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2016-01-03PNP: Add Broadwell to Intel MCH size workaroundChristophe Le Roy
Add device ID 0x1604 for Broadwell to commit cb171f7abb9a ("PNP: Work around BIOS defects in Intel MCH area reporting"). >From a Lenovo ThinkPad T550: system 00:01: [io 0x1800-0x189f] could not be reserved system 00:01: [io 0x0800-0x087f] has been reserved system 00:01: [io 0x0880-0x08ff] has been reserved system 00:01: [io 0x0900-0x097f] has been reserved system 00:01: [io 0x0980-0x09ff] has been reserved system 00:01: [io 0x0a00-0x0a7f] has been reserved system 00:01: [io 0x0a80-0x0aff] has been reserved system 00:01: [io 0x0b00-0x0b7f] has been reserved system 00:01: [io 0x0b80-0x0bff] has been reserved system 00:01: [io 0x15e0-0x15ef] has been reserved system 00:01: [io 0x1600-0x167f] has been reserved system 00:01: [io 0x1640-0x165f] has been reserved system 00:01: [mem 0xf8000000-0xfbffffff] could not be reserved system 00:01: [mem 0xfed1c000-0xfed1ffff] has been reserved system 00:01: [mem 0xfed10000-0xfed13fff] has been reserved system 00:01: [mem 0xfed18000-0xfed18fff] has been reserved system 00:01: [mem 0xfed19000-0xfed19fff] has been reserved system 00:01: [mem 0xfed45000-0xfed4bfff] has been reserved system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active) [...] resource sanity check: requesting [mem 0xfed10000-0xfed15fff], which spans more than pnp 00:01 [mem 0xfed10000-0xfed13fff] ------------[ cut here ]------------ WARNING: CPU: 2 PID: 1 at /build/linux-CrHvZ_/linux-4.2.6/arch/x86/mm/ioremap.c:198 __ioremap_caller+0x2ee/0x360() Info: mapping multiple BARs. Your kernel is fine. Modules linked in: CPU: 2 PID: 1 Comm: swapper/0 Not tainted 4.2.0-1-amd64 #1 Debian 4.2.6-1 Hardware name: LENOVO 20CKCTO1WW/20CKCTO1WW, BIOS N11ET34W (1.10 ) 08/20/2015 0000000000000000 ffffffff817e6868 ffffffff8154e2f6 ffff8802241efbf8 ffffffff8106e5b1 ffffc90000e98000 0000000000006000 ffffc90000e98000 0000000000006000 0000000000000000 ffffffff8106e62a ffffffff817e68c8 Call Trace: [<ffffffff8154e2f6>] ? dump_stack+0x40/0x50 [<ffffffff8106e5b1>] ? warn_slowpath_common+0x81/0xb0 [<ffffffff8106e62a>] ? warn_slowpath_fmt+0x4a/0x50 [<ffffffff810742a3>] ? iomem_map_sanity_check+0xb3/0xc0 [<ffffffff8105dade>] ? __ioremap_caller+0x2ee/0x360 [<ffffffff81036ae6>] ? snb_uncore_imc_init_box+0x66/0x90 [<ffffffff810351a8>] ? uncore_pci_probe+0xc8/0x1a0 [<ffffffff81302d7f>] ? local_pci_probe+0x3f/0xa0 [<ffffffff81303ea4>] ? pci_device_probe+0xc4/0x110 [<ffffffff813d9b1e>] ? driver_probe_device+0x1ee/0x450 [<ffffffff813d9dfb>] ? __driver_attach+0x7b/0x80 [<ffffffff813d9d80>] ? driver_probe_device+0x450/0x450 [<ffffffff813d796a>] ? bus_for_each_dev+0x5a/0x90 [<ffffffff813d9091>] ? bus_add_driver+0x1f1/0x290 [<ffffffff81b37fa8>] ? uncore_cpu_setup+0xc/0xc [<ffffffff813da73f>] ? driver_register+0x5f/0xe0 [<ffffffff81b38074>] ? intel_uncore_init+0xcc/0x2b0 [<ffffffff81b37fa8>] ? uncore_cpu_setup+0xc/0xc [<ffffffff8100213e>] ? do_one_initcall+0xce/0x200 [<ffffffff8108a100>] ? parse_args+0x140/0x4e0 [<ffffffff81b2b0cb>] ? kernel_init_freeable+0x162/0x1e8 [<ffffffff815443f0>] ? rest_init+0x80/0x80 [<ffffffff815443fe>] ? kernel_init+0xe/0xf0 [<ffffffff81553e5f>] ? ret_from_fork+0x3f/0x70 [<ffffffff815443f0>] ? rest_init+0x80/0x80 ---[ end trace 472e7959536abf12 ]--- 00:00.0 Host bridge: Intel Corporation Broadwell-U Host Bridge -OPI (rev 09) Subsystem: Lenovo Device 2223 Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx- Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort+ >SERR- <PERR- INTx- Latency: 0 Capabilities: [e0] Vendor Specific Information: Len=0c <?> Kernel driver in use: bdw_uncore 00: 86 80 04 16 06 00 90 20 09 00 00 06 00 00 00 00 10: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 20: 00 00 00 00 00 00 00 00 00 00 00 00 aa 17 23 22 30: 00 00 00 00 e0 00 00 00 00 00 00 00 00 00 00 00 Signed-off-by: Christophe Le Roy <christophe.fish@gmail.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2015-03-12PNP: Don't check for overlaps with unassigned PCI BARsBjorn Helgaas
After 0509ad5e1a7d ("PNP: disable PNP motherboard resources that overlap PCI BARs"), we disable and warn about PNP resources that overlap PCI BARs. But we assume that all PCI BARs are valid, which is incorrect, because a BAR may not have any space assigned to it. In that case, we will not enable the BAR, so no other resource can conflict with it. Ignore PCI BARs that are unassigned, as indicated by IORESOURCE_UNSET. Firmware often leaves PCI BARs unassigned, containing zero. Zero is a valid BAR value, so we can't just check for that, but the PCI core can set IORESOURCE_UNSET when it detects an unassigned BAR by other means. This should get rid of many of the annoying messages like this: pnp 00:00: disabling [io 0x0061] because it overlaps 0001:05:00.0 BAR 0 [io 0x0000-0x00ff] Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-04-29PNP: Fix compile error in quirks.cBjorn Helgaas
Fix the compile error: drivers/pnp/quirks.c:393:2: error: implicit declaration of function 'pcibios_bus_to_resource' that occurs when building with CONFIG_PCI unset. The quirk is only relevent to Intel devices, so we could use "#if defined(CONFIG_X86) && defined(CONFIG_PCI)" instead, but testing CONFIG_X86 is not strictly necessary. Fixes: cb171f7abb9a (PNP: Work around BIOS defects in Intel MCH area reporting) Reported-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2014-04-24PNP: Work around BIOS defects in Intel MCH area reportingBjorn Helgaas
Work around BIOSes that don't report the entire Intel MCH area. MCHBAR is not an architected PCI BAR, so MCH space is usually reported as a PNP0C02 resource. The MCH space was once 16KB, but is 32KB in newer parts. Some BIOSes still report a PNP0C02 resource that is only 16KB, which means the rest of the MCH space is consumed but unreported. This can cause resource map sanity check warnings or (theoretically) a device conflict if we assigned the unreported space to another device. The Intel perf event uncore driver tripped over this when it claimed the MCH region: resource map sanity check conflict: 0xfed10000 0xfed15fff 0xfed10000 0xfed13fff pnp 00:01 Info: mapping multiple BARs. Your kernel is fine. To prevent this, if we find a PNP0C02 resource that covers part of the MCH space, extend it to cover the entire space. References: http://lkml.kernel.org/r/20140224162400.GE16457@pd.tnic Reported-and-tested-by: Borislav Petkov <bp@alien8.de> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Acked-by: Borislav Petkov <bp@suse.de> Acked-by: Stephane Eranian <eranian@google.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2012-01-06PNP: work around Dell 1536/1546 BIOS MMCONFIG bug that breaks USBBjorn Helgaas
Some Dell BIOSes have MCFG tables that don't report the entire MMCONFIG area claimed by the chipset. If we move PCI devices into that claimed-but-unreported area, they don't work. This quirk reads the AMD MMCONFIG MSRs and adds PNP0C01 resources as needed to cover the entire area. Example problem scenario: BIOS-e820: 00000000cfec5400 - 00000000d4000000 (reserved) Fam 10h mmconf [d0000000, dfffffff] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xd0000000-0xd3ffffff] (base 0xd0000000) pnp 00:0c: [mem 0xd0000000-0xd3ffffff] pci 0000:00:12.0: reg 10: [mem 0xffb00000-0xffb00fff] pci 0000:00:12.0: no compatible bridge window for [mem 0xffb00000-0xffb00fff] pci 0000:00:12.0: BAR 0: assigned [mem 0xd4000000-0xd40000ff] Reported-by: Lisa Salimbas <lisa.salimbas@canonical.com> Reported-by: <thuban@singularity.fr> Tested-by: dann frazier <dann.frazier@canonical.com> References: https://bugzilla.kernel.org/show_bug.cgi?id=31602 References: https://bugs.launchpad.net/ubuntu/+source/linux/+bug/647043 References: https://bugzilla.redhat.com/show_bug.cgi?id=770308 Cc: stable@kernel.org # 2.6.34+ Signed-off-by: Bjorn Helgaas <bhelgaas@google.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-11-04vsprintf: use %pR, %pr instead of %pRt, %pRfBjorn Helgaas
Jesse accidentally applied v1 [1] of the patchset instead of v2 [2]. This is the diff between v1 and v2. The changes in this patch are: - tidied vsprintf stack buffer to shrink and compute size more accurately - use %pR for decoding and %pr for "raw" (with type and flags) instead of adding %pRt and %pRf [1] http://lkml.org/lkml/2009/10/6/491 [2] http://lkml.org/lkml/2009/10/13/441 Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-11-04PNP: print resources consistently with %pRtBjorn Helgaas
This uses %pRt and %pRf to print additional resource information (type, size, prefetchability, etc.) consistently. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-10-23Merge branch 'linus' into testLen Brown
Conflicts: MAINTAINERS arch/x86/kernel/acpi/boot.c arch/x86/kernel/acpi/sleep.c drivers/acpi/Kconfig drivers/pnp/Makefile drivers/pnp/quirks.c Signed-off-by: Len Brown <len.brown@intel.com>
2008-10-16{pci,pnp} quirks.c: don't use deprecated print_fn_descriptor_symbol()Linus Torvalds
I dunno how this missed Bjorn and his quest to use %pF in commit c80cfb0406c01bb5da91bfe30f5cb1fd96831138 ("vsprintf: use new vsprintf symbolic function pointer format"), but it did. So use %pF in the two remaining places that still tried to print out function pointers by hand. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16pnp: make the resource type an unsigned longRene Herman
PnP encodes the resource type directly as its struct resource->flags value which is an unsigned long. Make it so... Signed-off-by: Rene Herman <rene.herman@gmail.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Acked-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Andi Kleen <andi@firstfloor.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-10PNP: convert to using pnp_dbg()Bjorn Helgaas
pnp_dbg() is equivalent to dev_dbg() except that we can turn it on at boot-time with the "pnp.debug" kernel parameter, so we don't have to build a new kernel image. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-10-10PNP: use new vsprintf symbolic function pointer formatBjorn Helgaas
Use the '%pF' format to get rid of an "#ifdef DEBUG". Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-07-26pnp: have quirk_system_pci_resources() include io resourcesRene Herman
quirk_system_pci_resources() disables a PnP mem resource that overlaps a PCI BAR so as to not keep the PCI driver from claiming the resource. Have it do the same for io resources. Here, ACPI claims ports that overlap with my soundcard causing the soundcard driver to fail to load. It's unknown why my ACPI BIOS claims those ports; it did not use to but this is not a (kernel) regression. Some odd BIOS reconfig triggered by temporarily removing the card seems to have brought this on. Signed-off-by: Rene Herman <rene.herman@gmail.com> Acked-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-16PNP: convert resource options to single linked listBjorn Helgaas
ISAPNP, PNPBIOS, and ACPI describe the "possible resource settings" of a device, i.e., the possibilities an OS bus driver has when it assigns I/O port, MMIO, and other resources to the device. PNP used to maintain this "possible resource setting" information in one independent option structure and a list of dependent option structures for each device. Each of these option structures had lists of I/O, memory, IRQ, and DMA resources, for example: dev independent options ind-io0 -> ind-io1 ... ind-mem0 -> ind-mem1 ... ... dependent option set 0 dep0-io0 -> dep0-io1 ... dep0-mem0 -> dep0-mem1 ... ... dependent option set 1 dep1-io0 -> dep1-io1 ... dep1-mem0 -> dep1-mem1 ... ... ... This data structure was designed for ISAPNP, where the OS configures device resource settings by writing directly to configuration registers. The OS can write the registers in arbitrary order much like it writes PCI BARs. However, for PNPBIOS and ACPI devices, the OS uses firmware interfaces that perform device configuration, and it is important to pass the desired settings to those interfaces in the correct order. The OS learns the correct order by using firmware interfaces that return the "current resource settings" and "possible resource settings," but the option structures above doesn't store the ordering information. This patch replaces the independent and dependent lists with a single list of options. For example, a device might have possible resource settings like this: dev options ind-io0 -> dep0-io0 -> dep1->io0 -> ind-io1 ... All the possible settings are in the same list, in the order they come from the firmware "possible resource settings" list. Each entry is tagged with an independent/dependent flag. Dependent entries also have a "set number" and an optional priority value. All dependent entries must be assigned from the same set. For example, the OS can use all the entries from dependent set 0, or all the entries from dependent set 1, but it cannot mix entries from set 0 with entries from set 1. Prior to this patch PNP didn't keep track of the order of this list, and it assigned all independent options first, then all dependent ones. Using the example above, that resulted in a "desired configuration" list like this: ind->io0 -> ind->io1 -> depN-io0 ... instead of the list the firmware expects, which looks like this: ind->io0 -> depN-io0 -> ind-io1 ... Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andi Kleen <ak@linux.intel.com> Acked-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-07-16PNP: support optional IRQ resourcesBjorn Helgaas
This patch adds an IORESOURCE_IRQ_OPTIONAL flag for use when assigning resources to a device. If the flag is set and we are unable to assign an IRQ to the device, we can leave the IRQ disabled but allow the overall resource allocation to succeed. Some devices request an IRQ, but can run without an IRQ (possibly with degraded performance). This flag lets us run the device without the IRQ instead of just leaving the device disabled. This is a reimplementation of this previous change by Rene Herman <rene.herman@gmail.com>: http://git.kernel.org/?p=linux/kernel/git/torvalds/linux-2.6.git;a=commit;h=3b73a223661ed137c5d3d2635f954382e94f5a43 I reimplemented this for two reasons: - to prepare for converting all resource options into a single linked list, as opposed to the per-resource-type lists we have now, and - to preserve the order and number of resource options. In PNPBIOS and ACPI, we configure a device by giving firmware a list of resource assignments. It is important that this list has exactly the same number of resources, in the same order, as the "template" list we got from the firmware in the first place. The problem of a sound card MPU401 being left disabled for want of an IRQ was reported by Uwe Bugla <uwe.bugla@gmx.de>. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andi Kleen <ak@linux.intel.com> Acked-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-07-16PNP: introduce pnp_irq_mask_t typedefBjorn Helgaas
This adds a typedef for the IRQ bitmap, which should cause no functional change, but will make it easier to pass a pointer to a bitmap to pnp_register_irq_resource(). Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andi Kleen <ak@linux.intel.com> Acked-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-07-16PNP: replace pnp_resource_table with dynamically allocated resourcesBjorn Helgaas
PNP used to have a fixed-size pnp_resource_table for tracking the resources used by a device. This table often overflowed, so we've had to increase the table size, which wastes memory because most devices have very few resources. This patch replaces the table with a linked list of resources where the entries are allocated on demand. This removes messages like these: pnpacpi: exceeded the max number of IO resources 00:01: too many I/O port resources References: http://bugzilla.kernel.org/show_bug.cgi?id=9535 http://bugzilla.kernel.org/show_bug.cgi?id=9740 http://lkml.org/lkml/2007/11/30/110 This patch also changes the way PNP uses the IORESOURCE_UNSET, IORESOURCE_AUTO, and IORESOURCE_DISABLED flags. Prior to this patch, the pnp_resource_table entries used the flags like this: IORESOURCE_UNSET This table entry is unused and available for use. When this flag is set, we shouldn't look at anything else in the resource structure. This flag is set when a resource table entry is initialized. IORESOURCE_AUTO This resource was assigned automatically by pnp_assign_{io,mem,etc}(). This flag is set when a resource table entry is initialized and cleared whenever we discover a resource setting by reading an ISAPNP config register, parsing a PNPBIOS resource data stream, parsing an ACPI _CRS list, or interpreting a sysfs "set" command. Resources marked IORESOURCE_AUTO are reinitialized and marked as IORESOURCE_UNSET by pnp_clean_resource_table() in these cases: - before we attempt to assign resources automatically, - if we fail to assign resources automatically, - after disabling a device IORESOURCE_DISABLED Set by pnp_assign_{io,mem,etc}() when automatic assignment fails. Also set by PNPBIOS and PNPACPI for: - invalid IRQs or GSI registration failures - invalid DMA channels - I/O ports above 0x10000 - mem ranges with negative length After this patch, there is no pnp_resource_table, and the resource list entries use the flags like this: IORESOURCE_UNSET This flag is no longer used in PNP. Instead of keeping IORESOURCE_UNSET entries in the resource list, we remove entries from the list and free them. IORESOURCE_AUTO No change in meaning: it still means the resource was assigned automatically by pnp_assign_{port,mem,etc}(), but these functions now set the bit explicitly. We still "clean" a device's resource list in the same places, but rather than reinitializing IORESOURCE_AUTO entries, we just remove them from the list. Note that IORESOURCE_AUTO entries are always at the end of the list, so removing them doesn't reorder other list entries. This is because non-IORESOURCE_AUTO entries are added by the ISAPNP, PNPBIOS, or PNPACPI "get resources" methods and by the sysfs "set" command. In each of these cases, we completely free the resource list first. IORESOURCE_DISABLED In addition to the cases where we used to set this flag, ISAPNP now adds an IORESOURCE_DISABLED resource when it reads a configuration register with a "disabled" value. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2008-06-02PNP: mark resources that conflict with PCI devices "disabled"Bjorn Helgaas
Both the PNP/PCI conflict detection quirk and the PNP system driver must use the same mechanism to mark resources as disabled. I think it's best to keep the resource and to keep the type bit (IORESOURCE_MEM, etc), so that we match the list from firmware as closely as possible. Fixes this regression from 2.6.25: http://lkml.org/lkml/2008/6/1/82 Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Tested-by: Avuton Olrich <avuton@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-15Clean up 'print_fn_descriptor_symbol()' typesLinus Torvalds
Everybody wants to pass it a function pointer, and in fact, that is what you _must_ pass it for it to make sense (since it knows that ia64 and ppc64 use descriptors for function pointers and fetches the actual address from there). So don't make the argument be a 'unsigned long' and force everybody to add a cast. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-14pnp: add ISAPnP MPU option quirksRene Herman
The AD181x and AZT230 chips don't support an IRQ-less MPU401 option but work fine without one. This adds (priority functional) IRQ-less options for each port option to help systems with few available IRQs. The AD1815 quirk can't use pnp_register_irq_resource() due to doubly penalizing the IRQ. Also, while not a practical issue due to no IRQ option being present for the dependents, this needs to add in front, not back. Doesn't use pnp_register_port_resource() for symetry with above. This does not delete the AD1815 independent option even though it should be empty after the IRQ transfer due to AD1816 coming with an empty but still present independent option by default. Was tested on AD1815, AD1816 and AZT2320. The ALSA snd-ad1818a driver also support the AZT2002 ID for MPU401 but this doesn't as I was unable to test it. Signed-off-by: Rene Herman <rene.herman@gmail.com> Tested-by: Uwe Bugla <uwe.bugla@gmx.de> Acked-by: Uwe Bugla <uwe.bugla@gmx.de> Acked-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Takashi Iwai <tiwai@suse.de> Cc: Len Brown <len.brown@intel.com Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-14pnp: clean up pnp_fixup_device()Rene Herman
Make it look a bit more like pci_fixup_device/pci_do_fixups. Also print the PnP ID and delete the () from the "foo+0x0/0x1234()". Signed-off-by: Rene Herman <rene.herman@gmail.com> Tested-by: Uwe Bugla <uwe.bugla@gmx.de> Acked-by: Uwe Bugla <uwe.bugla@gmx.de> Acked-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Takashi Iwai <tiwai@suse.de> Cc: Len Brown <len.brown@intel.com Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29PNP: remove PNP_MAX_* usesBjorn Helgaas
Remove some PNP_MAX_* uses. The pnp_resource_table isn't dynamic yet, but with pnp_get_resource(), we can start moving away from the table size constants. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-29PNP: remove pnp_mem_flags() as an lvalueBjorn Helgaas
A future change will change pnp_mem_flags() from a "#define that simplifies to an lvalue" to "an inline function that returns the flags value." Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Acked-By: Rene Herman <rene.herman@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-28PNP: use dev_printk for quirk messagesBjorn Helgaas
Convert quirk printks to dev_printk(). [akpm@linux-foundation.org: fix warnings, improve output text] Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Adam Belay <ambx1@neo.rr.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28PNP: simplify quirk debug outputBjorn Helgaas
print_fn_descriptor_symbol() prints the address if we don't have a symbol, so no need to print both. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-12PNP: disable PNP motherboard resources that overlap PCI BARsBjorn Helgaas
Some BIOSes have PNP motherboard devices with resources that partially overlap PCI BARs. The PNP system driver claims these motherboard resources, which prevents the normal PCI driver from requesting them later. This patch disables the PNP resources that conflict with PCI BARs so they won't be claimed by the PNP system driver. Of course, this only works if PCI devices have already been enumerated. Currently this is the case because PCI devices are discovered before any PNP init via this path: acpi_pci_root_init() -> acpi_pci_root_add() -> pci_acpi_scan_root() -> pci_scan_bus_parented() -> pci_scan_child_bus() -> ... Avuton Olrich tested this and confirmed that it fixes his ALSA sound card (see http://lkml.org/lkml/2008/1/27/168). References: https://bugzilla.redhat.com/show_bug.cgi?id=280641 https://bugzilla.redhat.com/show_bug.cgi?id=313491 http://lkml.org/lkml/2008/1/9/449 http://thread.gmane.org/gmane.linux.acpi.devel/27312 http://lkml.org/lkml/2008/1/27/168 Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-12PNP: revert Supermicro H8DCE motherboard quirkBjorn Helgaas
There are other systems with similar problems (http://lkml.org/lkml/2008/1/27/168), so we need a more generic quirk. Remove the Supermicro-specific one first. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06PNP: disable Supermicro H8DCE motherboard resources that overlap SATA BARsBjorn Helgaas
Some Supermicro BIOSes describe a SATA PCI BAR as a motherboard resource. The PNP system driver claims motherboard resources, and this prevents the sata_nv driver from requesting it later. This patch disables the PNP0C01/PNP0C02 resources so they won't be claimed by the PNP system driver, so they'll available for sata_nv. This fixes the bugs below, where sata_nv detects only two out of four SATA drives. The signature includes dmesg lines similar to these: pnp: 00:09: iomem range 0xdfefc000-0xdfefcfff has been reserved pnp: 00:09: iomem range 0xdfefd000-0xdfefd3ff has been reserved pnp: 00:09: iomem range 0xdfefe000-0xdfefe3ff has been reserved PCI: Unable to reserve mem region #6:1000@dfefd000 for device 0000:80:07.0 sata_nv: probe of 0000:80:07.0 failed with error -16 PCI: Unable to reserve mem region #6:1000@dfefe000 for device 0000:80:08.0 sata_nv: probe of 0000:80:08.0 failed with error -16 References: https://bugzilla.redhat.com/show_bug.cgi?id=280641 https://bugzilla.redhat.com/show_bug.cgi?id=313491 http://lkml.org/lkml/2008/1/9/449 http://thread.gmane.org/gmane.linux.acpi.devel/27312 This is post-2.6.24 material. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17PNP: use dev_info(), dev_err(), etc in coreBjorn Helgaas
If we have the struct pnp_dev available, we can use dev_info(), dev_err(), etc., to give a little more information and consistency. [akpm@linux-foundation.org: fix warning] Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Adam Belay <ambx1@neo.rr.com> Cc: Len Brown <lenb@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-09-11PNP: remove SMCf010 quirkBjorn Helgaas
If the quirk enables the SIR part of the SMCf010 device, the 8250 driver may claim it as a legacy ttyS device, which makes the legacy probe in the smsc-ircc2 driver fail. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Andrey Borzenkov <arvidjaar@mail.ru> Cc: Michal Piotrowski <michal.k.k.piotrowski@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-26PNP: fix up after LindentBjorn Helgaas
These are manual fixups after running Lindent. No functional change. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Len Brown <lenb@kernel.org> Cc: Adam Belay <ambx1@neo.rr.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-26PNP: Lindent all source filesBjorn Helgaas
Run Lindent on all PNP source files. Produced by: $ quilt new pnp-lindent $ find drivers/pnp -name \*.[ch] | xargs quilt add $ quilt add include/linux/{pnp.h,pnpbios.h} $ scripts/Lindent drivers/pnp/*.c drivers/pnp/*/*.c include/linux/pnp*.h $ quilt refresh --sort Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Len Brown <lenb@kernel.org> Cc: Adam Belay <ambx1@neo.rr.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-06PNP SMCf010 quirk: work around Toshiba Portege 4000 ACPI issuesBjorn Helgaas
When we enable the SMCf010 IR device, the Toshiba Portege 4000 BIOS claims the device is working, but it really isn't configured correctly. The BIOS *will* configure it, but only if we call _SRS after (1) reversing the order of the SIR and FIR I/O port regions and (2) changing the IRQ from active-high to active-low. This patch addresses the 2.6.22 regression: "no irda0 interface (2.6.21 was OK), smsc does not find chip" I tested this on a Portege 4000. The smsc-ircc2 driver correctly detects the device, and "irattach irda0 -s && irdadump" shows transmitted and received packets. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Andrey Borzenkov <arvidjaar@mail.ru> Cc: Samuel Ortiz <samuel@sortiz.org> Cc: "Linus Walleij (LD/EAB)" <linus.walleij@ericsson.com> Cc: Michal Piotrowski <michal.k.k.piotrowski@gmail.com> Cc: Adam Belay <ambx1@neo.rr.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-28PNP SMCf010 quirk: auto-config device if BIOS left it brokenBjorn Helgaas
Some HP firmware leaves the SMCf010 IRDA device incompletely configured, or reports the wrong resources in _CRS. As a workaround, when we find such a device, try to auto-configure the device. This ignores the _CRS data, picks a config from _PRS, and runs _SRS to configure the device. This makes smsc-ircc2 work correctly with PNP resources (with no preconfiguration!) on all the machines I tested. I think Windows does something like this by default for all devices, so we should consider doing the same thing in Linux. This patch addresses part of the 2.6.22 regression: "no irda0 interface (2.6.21 was OK), smsc does not find chip" It fixes smsc-ircc2 PNP device detection on HP nc6000, nc6220, nw8000, nw8240, and possibly other machines. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Samuel Ortiz <samuel@sortiz.org> Cc: "Linus Walleij (LD/EAB)" <linus.walleij@ericsson.com> Cc: Andrey Borzenkov <arvidjaar@mail.ru> Cc: Michal Piotrowski <michal.k.k.piotrowski@gmail.com> Cc: Adam Belay <ambx1@neo.rr.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08PNP: workaround HP BIOS defect that leaves SMCF010 device partly enabledBjorn Helgaas
Some HP/Compaq firmware reports via ACPI that the SMCF010 IR device is enabled, but in fact, it leaves the device partly disabled. HP nw8240 BIOS 68DTV Ver. F.0F, released 9/15/2005 is one BIOS that has this problem. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Keith Owens <kaos@ocs.com.au> Cc: Len Brown <lenb@kernel.org> Cc: Adam Belay <ambx1@neo.rr.com> Cc: Matthieu CASTET <castet.matthieu@free.fr> Cc: Jean Tourrilhes <jt@hpl.hp.com> Cc: Matthew Garrett <mjg59@srcf.ucam.org> Cc: Ville Syrjala <syrjala@sci.fi> Cc: Russell King <rmk+serial@arm.linux.org.uk> Cc: Samuel Ortiz <samuel@sortiz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2005-09-07[PATCH] PNP: make pnp_dbg conditional directly on CONFIG_PNP_DEBUGBjorn Helgaas
Seems pointless to require .c files to test CONFIG_PNP_DEBUG and conditionally define DEBUG before including <linux/pnp.h>. Just test CONFIG_PNP_DEBUG directly in pnp.h. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Adam Belay <ambx1@neo.rr.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
