path: root/drivers/pnp/support.c
2010-03-14PNPACPI: add bus number supportBjorn Helgaas
Add support for bus number resources. This is for bridges with a range of bus numbers behind them. Previously, PNP ignored bus number resources. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-11-04vsprintf: use %pR, %pr instead of %pRt, %pRfBjorn Helgaas
Jesse accidentally applied v1 [1] of the patchset instead of v2 [2]. This is the diff between v1 and v2. The changes in this patch are: - tidied vsprintf stack buffer to shrink and compute size more accurately - use %pR for decoding and %pr for "raw" (with type and flags) instead of adding %pRt and %pRf [1] http://lkml.org/lkml/2009/10/6/491 [2] http://lkml.org/lkml/2009/10/13/441 Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-11-04PNP: print resources consistently with %pRtBjorn Helgaas
This uses %pRt and %pRf to print additional resource information (type, size, prefetchability, etc.) consistently. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2008-10-10PNP: convert to using pnp_dbg()Bjorn Helgaas
pnp_dbg() is equivalent to dev_dbg() except that we can turn it on at boot-time with the "pnp.debug" kernel parameter, so we don't have to build a new kernel image. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-10-10PNP: remove some uses of DEBUG ifdefBjorn Helgaas
Use scnprintf() to build up a buffer of PNP IDs to print. This makes the printk atomic and helps get rid of an #ifdef. Also remove an "#ifdef DEBUG" from some debug functions. The functions only produce debug output, so it's OK to run the function and just have the output be dropped at the end. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-08-01PNP: fix formatting of dbg_pnp_show_resources() outputBjorn Helgaas
Each resource should be printed on its own line, so start snprintf'ing at the beginning of the buffer every time through the loop. Also, use scnprintf() rather than snprintf() when building up the buffer to print. scnprintf() returns the number of characters actually written into the buffer (not including the trailing NULL). snprintf() returns the number of characters that *would be* written, assuming everything would fit in the buffer. That's nice if we want to resize the buffer to make sure everything fits, but in this case, I just want to keep from overflowing the buffer, and it's OK if the output is truncated. Using snprintf() meant that my "len" could grow to be more than the the buffer size, which makes "sizeof(buf) - len" negative, which causes this alarming WARN_ON: http://marc.info/?l=linux-kernel&m=121736480005656&w=2 More useful snprintf/scnprintf discussion: http://lwn.net/Articles/69419/ Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Reported-by: Pete Clements <clem@clem.clem-digital.net> Cc: Rene Herman <rene.herman@keyaccess.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-16PNP: convert resource options to single linked listBjorn Helgaas
ISAPNP, PNPBIOS, and ACPI describe the "possible resource settings" of a device, i.e., the possibilities an OS bus driver has when it assigns I/O port, MMIO, and other resources to the device. PNP used to maintain this "possible resource setting" information in one independent option structure and a list of dependent option structures for each device. Each of these option structures had lists of I/O, memory, IRQ, and DMA resources, for example: dev independent options ind-io0 -> ind-io1 ... ind-mem0 -> ind-mem1 ... ... dependent option set 0 dep0-io0 -> dep0-io1 ... dep0-mem0 -> dep0-mem1 ... ... dependent option set 1 dep1-io0 -> dep1-io1 ... dep1-mem0 -> dep1-mem1 ... ... ... This data structure was designed for ISAPNP, where the OS configures device resource settings by writing directly to configuration registers. The OS can write the registers in arbitrary order much like it writes PCI BARs. However, for PNPBIOS and ACPI devices, the OS uses firmware interfaces that perform device configuration, and it is important to pass the desired settings to those interfaces in the correct order. The OS learns the correct order by using firmware interfaces that return the "current resource settings" and "possible resource settings," but the option structures above doesn't store the ordering information. This patch replaces the independent and dependent lists with a single list of options. For example, a device might have possible resource settings like this: dev options ind-io0 -> dep0-io0 -> dep1->io0 -> ind-io1 ... All the possible settings are in the same list, in the order they come from the firmware "possible resource settings" list. Each entry is tagged with an independent/dependent flag. Dependent entries also have a "set number" and an optional priority value. All dependent entries must be assigned from the same set. For example, the OS can use all the entries from dependent set 0, or all the entries from dependent set 1, but it cannot mix entries from set 0 with entries from set 1. Prior to this patch PNP didn't keep track of the order of this list, and it assigned all independent options first, then all dependent ones. Using the example above, that resulted in a "desired configuration" list like this: ind->io0 -> ind->io1 -> depN-io0 ... instead of the list the firmware expects, which looks like this: ind->io0 -> depN-io0 -> ind-io1 ... Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andi Kleen <ak@linux.intel.com> Acked-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-07-16PNP: in debug resource dump, make empty list obviousBjorn Helgaas
If the resource list is empty, say that explicitly. Previously, it was confusing because often the heading was followed by zero resource lines, then some "add resource" lines from auto-assignment, so the "add" lines looked like current resources. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andi Kleen <ak@linux.intel.com> Acked-by: Rene Herman <rene.herman@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-07-16PNP: replace pnp_resource_table with dynamically allocated resourcesBjorn Helgaas
PNP used to have a fixed-size pnp_resource_table for tracking the resources used by a device. This table often overflowed, so we've had to increase the table size, which wastes memory because most devices have very few resources. This patch replaces the table with a linked list of resources where the entries are allocated on demand. This removes messages like these: pnpacpi: exceeded the max number of IO resources 00:01: too many I/O port resources References: http://bugzilla.kernel.org/show_bug.cgi?id=9535 http://bugzilla.kernel.org/show_bug.cgi?id=9740 http://lkml.org/lkml/2007/11/30/110 This patch also changes the way PNP uses the IORESOURCE_UNSET, IORESOURCE_AUTO, and IORESOURCE_DISABLED flags. Prior to this patch, the pnp_resource_table entries used the flags like this: IORESOURCE_UNSET This table entry is unused and available for use. When this flag is set, we shouldn't look at anything else in the resource structure. This flag is set when a resource table entry is initialized. IORESOURCE_AUTO This resource was assigned automatically by pnp_assign_{io,mem,etc}(). This flag is set when a resource table entry is initialized and cleared whenever we discover a resource setting by reading an ISAPNP config register, parsing a PNPBIOS resource data stream, parsing an ACPI _CRS list, or interpreting a sysfs "set" command. Resources marked IORESOURCE_AUTO are reinitialized and marked as IORESOURCE_UNSET by pnp_clean_resource_table() in these cases: - before we attempt to assign resources automatically, - if we fail to assign resources automatically, - after disabling a device IORESOURCE_DISABLED Set by pnp_assign_{io,mem,etc}() when automatic assignment fails. Also set by PNPBIOS and PNPACPI for: - invalid IRQs or GSI registration failures - invalid DMA channels - I/O ports above 0x10000 - mem ranges with negative length After this patch, there is no pnp_resource_table, and the resource list entries use the flags like this: IORESOURCE_UNSET This flag is no longer used in PNP. Instead of keeping IORESOURCE_UNSET entries in the resource list, we remove entries from the list and free them. IORESOURCE_AUTO No change in meaning: it still means the resource was assigned automatically by pnp_assign_{port,mem,etc}(), but these functions now set the bit explicitly. We still "clean" a device's resource list in the same places, but rather than reinitializing IORESOURCE_AUTO entries, we just remove them from the list. Note that IORESOURCE_AUTO entries are always at the end of the list, so removing them doesn't reorder other list entries. This is because non-IORESOURCE_AUTO entries are added by the ISAPNP, PNPBIOS, or PNPACPI "get resources" methods and by the sysfs "set" command. In each of these cases, we completely free the resource list first. IORESOURCE_DISABLED In addition to the cases where we used to set this flag, ISAPNP now adds an IORESOURCE_DISABLED resource when it reads a configuration register with a "disabled" value. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2008-07-16PNP: add pnp_resource_type_name() helper functionBjorn Helgaas
This patch adds a "pnp_resource_type_name(struct resource *)" that returns the string resource type. This will be used by the sysfs "show resources" function and the debug resource dump function. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2008-07-16PNP: add detail to debug resource dumpBjorn Helgaas
In the debug resource dump, decode the flags and indicate when a resource is disabled or has been automatically assigned. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com> Signed-off-by: Andi Kleen <ak@linux.intel.com>
2008-05-14lib: create common ascii hex arrayHarvey Harrison
Add a common hex array in hexdump.c so everyone can use it. Add a common hi/lo helper to avoid the shifting masking that is done to get the upper and lower nibbles of a byte value. Pull the pack_hex_byte helper from kgdb as it is opencoded many places in the tree that will be consolidated. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Cc: Jason Wessel <jason.wessel@windriver.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29PNP: convert assign, interface to use pnp_get_resource(), not pnp_resource_tableBjorn Helgaas
This removes more direct references to pnp_resource_table from the pnp_assign_resources() path and the /sys user interface path. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-29PNP: add debug when assigning PNP resourcesBjorn Helgaas
This patch adds code to dump PNP resources before and after assigning resources and before writing them to the device. This is enabled by CONFIG_PNP_DEBUG=y. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-04-29PNP: add pnp_eisa_id_to_string()Bjorn Helgaas
Converting the EISA ID to a string is messy and error-prone, and we might as well use the same code for ISAPNP and PNPBIOS. PNPACPI uses the conversion done by the ACPI core with acpi_ex_eisa_id_to_string(). Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Acked-By: Rene Herman <rene.herman@gmail.com> Signed-off-by: Len Brown <len.brown@intel.com>
2007-07-26PNP: fix up after LindentBjorn Helgaas
These are manual fixups after running Lindent. No functional change. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Len Brown <lenb@kernel.org> Cc: Adam Belay <ambx1@neo.rr.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-26PNP: Lindent all source filesBjorn Helgaas
Run Lindent on all PNP source files. Produced by: $ quilt new pnp-lindent $ find drivers/pnp -name \*.[ch] | xargs quilt add $ quilt add include/linux/{pnp.h,pnpbios.h} $ scripts/Lindent drivers/pnp/*.c drivers/pnp/*/*.c include/linux/pnp*.h $ quilt refresh --sort Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Len Brown <lenb@kernel.org> Cc: Adam Belay <ambx1@neo.rr.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2005-09-07[PATCH] PNP: make pnp_dbg conditional directly on CONFIG_PNP_DEBUGBjorn Helgaas
Seems pointless to require .c files to test CONFIG_PNP_DEBUG and conditionally define DEBUG before including <linux/pnp.h>. Just test CONFIG_PNP_DEBUG directly in pnp.h. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Adam Belay <ambx1@neo.rr.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
