commit eb31aae8cb5eb54e234ed2d857ddac868195d911 upstream.
Some Dell BIOSes have MCFG tables that don't report the entire
MMCONFIG area claimed by the chipset. If we move PCI devices into
that claimed-but-unreported area, they don't work.
This quirk reads the AMD MMCONFIG MSRs and adds PNP0C01 resources as
needed to cover the entire area.
Example problem scenario:
BIOS-e820: 00000000cfec5400 - 00000000d4000000 (reserved)
Fam 10h mmconf [d0000000, dfffffff]
PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xd0000000-0xd3ffffff] (base 0xd0000000)
pnp 00:0c: [mem 0xd0000000-0xd3ffffff]
pci 0000:00:12.0: reg 10: [mem 0xffb00000-0xffb00fff]
pci 0000:00:12.0: no compatible bridge window for [mem 0xffb00000-0xffb00fff]
pci 0000:00:12.0: BAR 0: assigned [mem 0xd4000000-0xd40000ff]
Reported-by: Lisa Salimbas <lisa.salimbas@canonical.com>
Reported-by: <thuban@singularity.fr>
Tested-by: dann frazier <dann.frazier@canonical.com>
References: https://bugzilla.kernel.org/show_bug.cgi?id=31602
References: https://bugs.launchpad.net/ubuntu/+source/linux/+bug/647043
References: https://bugzilla.redhat.com/show_bug.cgi?id=770308
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
* Merge akpm patch series: (122 commits)
drivers/connector/cn_proc.c: remove unused local
Documentation/SubmitChecklist: add RCU debug config options
reiserfs: use hweight_long()
reiserfs: use proper little-endian bitops
pnpacpi: register disabled resources
drivers/rtc/rtc-tegra.c: properly initialize spinlock
drivers/rtc/rtc-twl.c: check return value of twl_rtc_write_u8() in twl_rtc_set_time()
drivers/rtc: add support for Qualcomm PMIC8xxx RTC
drivers/rtc/rtc-s3c.c: support clock gating
drivers/rtc/rtc-mpc5121.c: add support for RTC on MPC5200
init: skip calibration delay if previously done
misc/eeprom: add eeprom access driver for digsy_mtc board
misc/eeprom: add driver for microwire 93xx46 EEPROMs
checkpatch.pl: update $logFunctions
checkpatch: make utf-8 test --strict
checkpatch.pl: add ability to ignore various messages
checkpatch: add a "prefer __aligned" check
checkpatch: validate signature styles and To: and Cc: lines
checkpatch: add __rcu as a sparse modifier
checkpatch: suggest using min_t or max_t
Did this as a merge because of (trivial) conflicts in
- Documentation/feature-removal-schedule.txt
- arch/xtensa/include/asm/uaccess.h
that were just easier to fix up in the merge than in the patch series.
When parsing PnP ACPI resource structures, it may happen that some of
the resources are disabled (in which case "the size" of the resource
equals zero).
The current solution is to skip these resources completely - with the
unfortunate side effect that they are not registered despite the fact
that they exist, after all. (The downside of this approach is that
these resources cannot be used as templates for setting the actual
device's resources because they are missing from the template.) The
kernel's APM implementation does not suffer from this problem and
registers all resources regardless of "their size".
This patch fixes a problem with (at least) the vintage IBM ThinkPad 600E
(and most likely also with the 600, 600X, and 770X which have a very
similar layout) where some of its PnP devices support options where
either an IRQ, a DMA, or an IO port is disabled. Without this patch,
the devices can not be configured using the
"/sys/bus/pnp/devices/*/resources" interface.
The manipulation of these resources is important because the 600E has
very demanding requirements. For instance, the number of IRQs is not
sufficient to support all devices of the 600E. Fortunately, some of the
devices, like the sound card's MPU-401 UART, can be configured to not
use any IRQ, hence freeing an IRQ for a device that requires one.
(Still, the device's "ResourceTemplate" requires an IRQ resource
descriptor which cannot be created if the resource has not been
registered in the first place.)
As an example, the dependent sets of the 600E's CSC0103 device (the
MPU-401 UART) are listed, with the patch applied, as:
Dependent: 00 - Priority preferred
port 0x300-0x330, align 0xf, size 0x4, 16-bit address decoding
irq <none> High-Edge
Dependent: 01 - Priority acceptable
irq 5,7,2/9,10,11,15 High-Edge
(The same result is obtained when PNPBIOS is used instead of PnP ACPI.)
Without the patch, the IRQ resource in the preferred option is not
listed at all:
And in fact, the 600E's DSDT lists the disabled IRQ as an option, as can
be seen from the following excerpt from the DSDT:
Name (_PRS, ResourceTemplate ()
StartDependentFn (0x00, 0x00)
IO (Decode16, 0x0300, 0x0330, 0x10, 0x04)
IRQNoFlags () {}
StartDependentFn (0x01, 0x00)
IRQNoFlags () {5,7,9,10,11,15}
EndDependentFn ()
With this patch applied, a user space program - or maybe even the kernel
- can allocate all devices' resources optimally. For the 600E, this
means to find optimal resources for (at least) the serial port, the
parallel port, the infrared port, the MWAVE modem, the sound card, and
the MPU-401 UART.
The patch applies the idea to register disabled resources to all types
of resources, not just to IRQs, DMAs, and IO ports. At the same time,
it mimics the behavior of the "pnp_assign_xxx" functions from
"drivers/pnp/manager.c" where resources with "no size" are considered
disabled.
No regressions were observed on hardware that does not require this
patch.
The patch is applied against 2.6.39.
NB: The kernel's current PnP interface does not allow for disabling individual
resources using the "/sys/bus/pnp/devices/$device/resources" file. Assuming
this could be done, a device could be configured to use a disabled resource
using a simple series of calls:
echo disable > /sys/bus/pnp/devices/$device/resources
echo clear > /sys/bus/pnp/devices/$device/resources
echo set irq disabled > /sys/bus/pnp/devices/$device/resources
echo fill > /sys/bus/pnp/devices/$device/resources
echo activate > /sys/bus/pnp/devices/$device/resources
This patch addresses only the parsing of PnP ACPI devices.
ChangeLog (v1 -> v2):
- extend patch description
- fix typo in patch itself
Signed-off-by: Witold Szczeponik <Witold.Szczeponik@gmx.net>
Cc: Len Brown <lenb@kernel.org>
Cc: Adam Belay <abelay@mit.edu>
Cc: Bjorn Helgaas <bjorn.helgaas@hp.com>
Cc: Bjorn Helgaas <bhelgaas@google.com>
Cc: Henrique de Moraes Holschuh <hmh@hmh.eng.br>
Cc: Matthew Garrett <mjg@redhat.com>
Several fixes as well where the +1 was missing.
Done via coccinelle scripts like:
struct resource *ptr;
- ptr->end - ptr->start + 1
+ resource_size(ptr)
and some grep and typing.
Mostly uncompiled, no cross-compilers.
IORESOURCE_DMA cannot be assigned without utilizing the interface
provided by CONFIG_ISA_DMA_API, specifically request_dma() and
free_dma(). Thus, there's a strict dependency on the config option and
limits IORESOURCE_DMA only to architectures that support ISA-style DMA.
ia64 is not one of those architectures, so pnp_check_dma() no longer
needs to be special-cased for that architecture.
pnp_assign_resources() will now return -EINVAL if IORESOURCE_DMA is
attempted on such a kernel.
Signed-off-by: David Rientjes <rientjes@google.com>
Cc: "Luck, Tony" <tony.luck@intel.com>
The PNP ACPI driver squirrels the ACPI handles of PNP devices' ACPI
companions, but this isn't correct, because those handles should be
accessed using the DEVICE_ACPI_HANDLE() macro operating on struct
device objects.
Using DEVICE_ACPI_HANDLE() in the PNP ACPI driver instead of the
driver's own copies of the ACPI handles allows us to avoid a problem
with docking stations where a machine docked before suspend to RAM
and undocked while suspended crashes during the subsequent resume (in
that case the ACPI companion of the PNP device in question doesn't
exist any more while the device is being resumed). It also allows us
to avoid the problem where suspend to RAM fails when the machine was
undocked while suspended before (again, the ACPI companion of the PNP
device is not present any more while it is being suspended).
This change doesn't fix all of the the PNP ACPI driver's problems
with PNP devices in docking stations (generally speaking, the driver
has no idea that devices can come and go and doesn't even attempt to
handle such events), but at least it makes suspend work for the
users of docking stations who don't use the PNP devices located in
there.
References: https://bugzilla.kernel.org/show_bug.cgi?id=15100
Reported-and-tested-by: Toralf Förster <toralf.foerster@gmx.de>
Acked-by: Bjorn Helgaas <bjorn.helgaas@hp.com>
Signed-off-by: Len Brown <len.brown@intel.com>
Signed-off-by: Jan Beulich <jbeulich@novell.com>
The big kernel lock has been removed from all these files at some point,
leaving only the #include.
Remove this too as a cleanup.
Cleanup only, no functional change (pnp.debug can be enabled
and disabled at runtime, but that's not a real enhancement).
This one depends on another PNP cleanup patch:
PNP: Compile all pnp built-in stuff in one module namespace
Signed-off-by: Thomas Renninger <trenn@suse.de>
Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com>
This is cleanup mostly, nothing urgent.
I came up with it when looking at dynamic debug which can
enable pr_debug messages at runtime or boot param
for a specific module.
Advantages:
- Any pnp code can make use of the moduleparam.h interface, the modules
will show up as pnp.param.
- Passing pnp.ddebug as kernel boot param will enable all pnp debug messages
with my previous patch and CONFIG_DYNAMIC_DEBUG enabled.
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (53 commits)
ACPI: install ACPI table handler before any dynamic tables being loaded
ACPI / PM: Blacklist another machine that needs acpi_sleep=nonvs
ACPI: Page based coalescing of I/O remappings optimization
ACPI: Convert simple locking to RCU based locking
ACPI: Pre-map 'system event' related register blocks
ACPI: Add interfaces for ioremapping/iounmapping ACPI registers
ACPI: Maintain a list of ACPI memory mapped I/O remappings
ACPI: Fix ioremap size for MMIO reads and writes
ACPI / Battery: Return -ENODEV for unknown values in get_property()
ACPI / PM: Fix reference counting of power resources
Subject: [PATCH] ACPICA: Fix Scope() op in module level code
ACPI battery: support percentage battery remaining capacity
ACPI: Make Embedded Controller command timeout delay configurable
ACPI dock: move some functions to .init.text
ACPI: thermal: remove unused limit code
ACPI: static sleep_states[] and acpi_gts_bfs_check
ACPI: remove dead code
ACPI: delete dedicated MAINTAINERS entries for ACPI EC and BATTERY drivers
ACPI: Only processor needs CPU_IDLE
ACPICA: Update version to 20101013
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
Update broken web addresses in arch directory.
Update broken web addresses in the kernel.
Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget
Revert "Fix typo: configuation => configuration" partially
ida: document IDA_BITMAP_LONGS calculation
ext2: fix a typo on comment in ext2/inode.c
drivers/scsi: Remove unnecessary casts of private_data
drivers/s390: Remove unnecessary casts of private_data
net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data
drivers/infiniband: Remove unnecessary casts of private_data
drivers/gpu/drm: Remove unnecessary casts of private_data
kernel/pm_qos_params.c: Remove unnecessary casts of private_data
fs/ecryptfs: Remove unnecessary casts of private_data
fs/seq_file.c: Remove unnecessary casts of private_data
arm: uengine.c: remove C99 comments
arm: scoop.c: remove C99 comments
Fix typo configue => configure in comments
Fix typo interrest[ing|ed] => interest[ing|ed]
Fix various typos of valid in comments
Fix up trivial conflicts in:
drivers/char/ipmi/ipmi_si_intf.c
drivers/usb/gadget/rndis.c
net/irda/irnet/irnet_ppp.c
The patch below updates broken web addresses in the kernel
Cc: Maciej W. Rozycki <macro@linux-mips.org>
Cc: Finn Thain <fthain@telegraphics.com.au>
Cc: Randy Dunlap <rdunlap@xenotime.net>
Cc: Matt Turner <mattst88@gmail.com>
Cc: Dimitry Torokhov <dmitry.torokhov@gmail.com>
Cc: Mike Frysinger <vapier.adi@gmail.com>
Acked-by: Ben Pfaff <blp@cs.stanford.edu>
Acked-by: Hans J. Koch <hjk@linutronix.de>
Reviewed-by: Finn Thain <fthain@telegraphics.com.au>
If primary ID (HID) is invalid try locating first valid ID on compatible
ID list before giving up.
This helps, for example, to recognize i8042 AUX port on Sony Vaio VPCZ1
which uses SNYSYN0003 as HID. Without the patch users are forced to
boot with i8042.nopnp to make use of their touchpads.
Tested-by: Jan-Hendrik Zab <jan@jhz.name>
ACPI devices are often involved in address space conflicts with PCI devices,
so I think it's worth logging the resources they use. Otherwise we have to
depend on lspnp or groping around in sysfs to find them.
Remove BKL use from isapnp_proc_bus_lseek(), like was done for
proc_bus_pci_lseek() a long time ago and recently for Zorro
by Geert Uytterhoeven.
Cc: Jaroslav Kysela <perex@perex.cz>
This patch (as1354) adds remote-wakeup support to the pnpacpi driver.
The new can_wakeup method also allows other PNP protocol drivers
(pnpbios or iaspnp) to add wakeup support, but I don't know enough
about how they work to actually do it.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Reviewed-by: Bjorn Helgaas <bjorn.helgaas@hp.com>
'bugzilla-15903' and 'misc-2.6.34' into release
With fa35b4926, I broke a lot of PNP resource assignment. That commit made
PNPACPI include bridge windows as PNP resources, and PNP resource assignment
treats any enabled overlapping PNP resources as conflicts. Since PCI host
bridge windows typically include most of the I/O port space, this makes PNP
port assigments fail.
The PCI host bridge driver will eventually use those PNP window resources,
so we should make PNP ignore them when checking for conflicts.
This fixes https://bugzilla.kernel.org/show_bug.cgi?id=15903
Reported-and-tested-by: Pavel Kysilka <goldenfish@linuxsoft.cz>
ACPI _CRS Address Space Descriptors have _MIN, _MAX, and _LEN. Linux has
been computing Address Spaces as [_MIN to _MIN + _LEN - 1]. Based on the
tests in the bug reports below, Windows apparently uses [_MIN to _MAX].
Per spec (ACPI 4.0, Table 6-40), for _CRS fixed-size, fixed location
descriptors, "_LEN must be (_MAX - _MIN + 1)", and when that's true, it
doesn't matter which way we compute the end. But of course, there are
BIOSes that don't follow this rule, and we're better off if Linux handles
those exceptions the same way as Windows.
This patch makes Linux use [_MIN to _MAX], as Windows seems to do. This
effectively reverts 3162b6f0c5e and replaces it with simpler code.
https://bugzilla.kernel.org/show_bug.cgi?id=14337 (round)
https://bugzilla.kernel.org/show_bug.cgi?id=15480 (truncate)
'bugzilla-15480', 'bugzilla-15521', 'bugzilla-15605', 'gpe-reference-counters', 'misc', 'pxm-fix' and 'video-random-key' into release
The ACPI spec (sec 6.4.3.5 in v4.0) requires that for Address Space Resource
Descriptors, _LEN <= _MAX - _MIN + 1 in all cases, but there are BIOSes that
violate this. We experimentally determined that Windows truncates the
resource so it doesn't extend past _MAX, so let's do the same thing in
Linux.
http://bugzilla.kernel.org/show_bug.cgi?id=15480
Acked-by: Rafael J. Wysocki <rjw@sisk.pl>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Add support for bus number resources. This is for bridges with a range of
bus numbers behind them. Previously, PNP ignored bus number resources.
Add support for resource windows. This is for bridge resources, i.e.,
regions where a bridge forwards transactions from the primary to the
secondary side. This does not add support for *setting* windows via
the /proc interface.
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (117 commits)
ACPI processor: Fix section mismatch for processor_add()
ACPI: Add platform-wide _OSC support.
ACPI: cleanup pci_root _OSC code.
ACPI: Add a generic API for _OSC -v2
msi-wmi: depend on backlight and fix corner-cases problems
msi-wmi: switch to using input sparse keymap library
msi-wmi: replace one-condition switch-case with if statement
msi-wmi: remove unused field 'instance' in key_entry structure
msi-wmi: remove custom runtime debug implementation
msi-wmi: rework init
msi-wmi: remove useless includes
X86 drivers: Introduce msi-wmi driver
Toshiba Bluetooth Enabling driver (RFKill handler v3)
ACPI: fix for lapic_timer_propagate_broadcast()
acpi_pad: squish warning
ACPI: dock: minor whitespace and style cleanups
ACPI: dock: add struct dock_station * directly to platform device data
ACPI: dock: dock_add - hoist up platform_device_register_simple()
ACPI: dock: remove global 'dock_device_name'
ACPI: dock: combine add|alloc_dock_dependent_device (v2)
Convert code away from ->read_proc/->write_proc interfaces. Switch to
proc_create()/proc_create_data() which make addition of proc entries
reliable wrt NULL ->proc_fops, NULL ->data and so on.
Problem with ->read_proc et al is described here commit
786d7e1612f0b0adb6046f19b906609e4fe8b1ba "Fix rmmod/read/write races in
/proc entries"
Add pnp_acpi_device(pnp_dev), which takes a PNP device and returns the
associated ACPI device (or NULL, if the device is not a PNPACPI device).
This allows us to write a PNP driver that can manage both traditional
PNPBIOS and ACPI devices, treating ACPI-only functionality as an optional
extension.
Makes use of skip_spaces() defined in lib/string.c for removing leading
spaces from strings all over the tree.
It decreases lib.a code size by 47 bytes and reuses the function tree-wide:
64688 584 592 65864 10148 (TOTALS-BEFORE)
64641 584 592 65817 10119 (TOTALS-AFTER)
Also, while at it, if we see (*str && isspace(*str)), we can be sure to
remove the first condition (*str) as the second one (isspace(*str)) also
evaluates to 0 whenever *str == 0, making it redundant. In other words,
"a char equals zero is never a space".
Julia Lawall tried the semantic patch (http://coccinelle.lip6.fr) below,
and found occurrences of this pattern on 3 more files:
drivers/leds/led-class.c
drivers/leds/ledtrig-timer.c
drivers/video/output.c
expression str;
( // ignore skip_spaces cases
while (*str && isspace(*str)) { \(str++;\|++str;\) }
- *str &&
isspace(*str)
Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com>
Cc: Julia Lawall <julia@diku.dk>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Richard Purdie <rpurdie@rpsys.net>
Cc: Neil Brown <neilb@suse.de>
Cc: Kyle McMartin <kyle@mcmartin.ca>
Cc: <linux-ext4@vger.kernel.org>
Cc: Samuel Ortiz <samuel@sortiz.org>
Cc: Patrick McHardy <kaber@trash.net>
Cc: Takashi Iwai <tiwai@suse.de>
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6
* 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: (109 commits)
PCI: fix coding style issue in pci_save_state()
PCI: add pci_request_acs
PCI: fix BUG_ON triggered by logical PCIe root port removal
PCI: remove ifdefed pci_cleanup_aer_correct_error_status
PCI: unconditionally clear AER uncorr status register during cleanup
x86/PCI: claim SR-IOV BARs in pcibios_allocate_resource
PCI: portdrv: remove redundant definitions
PCI: portdrv: remove unnecessary struct pcie_port_data
PCI: portdrv: minor cleanup for pcie_port_device_register
PCI: portdrv: add missing irq cleanup
PCI: portdrv: enable device before irq initialization
PCI: portdrv: cleanup service irqs initialization
PCI: portdrv: check capabilities first
PCI: portdrv: move PME capability check
PCI: portdrv: remove redundant pcie type calculation
PCI: portdrv: cleanup pcie_device registration
PCI: portdrv: remove redundant pcie_port_device_probe
PCI: Always set prefetchable base/limit upper32 registers
PCI: read-modify-write the pcie device control register when initiating pcie flr
PCI: show dma_mask bits in /sys
Fixed up conflicts in:
arch/x86/kernel/amd_iommu_init.c
drivers/pci/dmar.c
drivers/pci/hotplug/acpiphp_glue.c
Some drivers need to look at things in the acpi_device structure
besides the handle.
That is "success", "unknown", "through", "performance", "[re|un]mapping"
, "access", "default", "reasonable", "[con]currently", "temperature"
, "channel", "[un]used", "application", "example","hierarchy", "therefore"
, "[over|under]flow", "contiguous", "threshold", "enough" and others.
Jesse accidentally applied v1 [1] of the patchset instead of v2 [2]. This
is the diff between v1 and v2.
The changes in this patch are:
- tidied vsprintf stack buffer to shrink and compute size more
accurately
- use %pR for decoding and %pr for "raw" (with type and flags) instead
of adding %pRt and %pRf
[1] http://lkml.org/lkml/2009/10/6/491
[2] http://lkml.org/lkml/2009/10/13/441
This uses %pRt and %pRf to print additional resource information (type,
size, prefetchability, etc.) consistently.
Every acpi_device has at least one ID (if there's no _HID or _CID, we
give it a synthetic or default ID). So there's no longer a need to
check whether an ID exists; we can just use it.
There's no need to treat _HID and _CID differently. Keeping them in
a single list makes code that uses the IDs a little simpler because it
can just traverse the list rather than checking "do we have a HID?",
"do we have any CIDs?"
Reviewed-by: Alex Chiang <achiang@hp.com>
Use acpi_device_hid() rather than accessing acpi_device.pnp.hardware_id
directly.
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (119 commits)
ACPI: don't pass handle for fixed hardware notifications
ACPI: remove null pointer checks in deferred execution path
ACPI: simplify deferred execution path
acerhdf: additional BIOS versions
acerhdf: convert to dev_pm_ops
acerhdf: fix fan control for AOA150 model
thermal: add missing Kconfig dependency
acpi: switch /proc/acpi/{debug_layer,debug_level} to seq_file
hp-wmi: fix rfkill memory leak on unload
ACPI: remove unnecessary #ifdef CONFIG_DMI
ACPI: linux/acpi.h should not include linux/dmi.h
hwmon driver for ACPI 4.0 power meters
topstar-laptop: add new driver for hotkeys support on Topstar N01
thinkpad_acpi: fix rfkill memory leak on unload
thinkpad-acpi: report brightness events when required
thinkpad-acpi: don't poll by default any of the reserved hotkeys
thinkpad-acpi: Fix procfs hotkey reset command
thinkpad-acpi: deprecate hotkey_bios_mask
thinkpad-acpi: hotkey poll fixes
thinkpad-acpi: be more strict when detecting a ThinkPad
The shutdown method is used by the winbond cir driver to setup the
hardware for wake-from-S5.
Signed-off-by: David Härdeman <david@hardeman.nu>
Cc: Dmitry Torokhov <dtor@mail.ru>
Completed a major update for the acpi_get_object_info external interface.
Changes include:
- Support for variable, unlimited length HID, UID, and CID strings
- Support Processor objects the same as Devices (HID,UID,CID,ADR,STA, etc.)
- Call the _SxW power methods on behalf of a device object
- Determine if a device is a PCI root bridge
- Change the ACPI_BUFFER parameter to ACPI_DEVICE_INFO.
These changes will require an update to all callers of this interface.
See the ACPICA Programmer Reference for details.
Also, update all invocations of acpi_get_object_info interface
Signed-off-by: Bob Moore <robert.moore@intel.com>
Signed-off-by: Lin Ming <ming.m.lin@intel.com>
Fully initialize bad_bios_desc statically instead of doing some
fields statically and some dynamically.
Suggested-by: "H. Peter Anvin" <hpa@zytor.com>
LKML-Reference: <20090809080350.GA4765@localhost.localdomain>
GDT_ENTRY_INIT is static initializer of desc_struct.
We already have similar macro GDT_ENTRY() but it's static
initializer for u64 and it cannot be used for desc_struct.
LKML-Reference: <20090718151219.GD11294@localhost.localdomain>
Rename set_base()/set_limit to set_desc_base()/set_desc_limit()
and rewrite them in C. These are naturally introduced by the
idea of get_desc_base()/get_desc_limit().
The conversion actually found the bug in apm_32.c:
bad_bios_desc is written at run-time, but it is defined const
variable.
LKML-Reference: <20090718151105.GC11294@localhost.localdomain>
