path: root/drivers/pnp
2011-07-25Merge 'akpm' patch seriesLinus Torvalds
* Merge akpm patch series: (122 commits) drivers/connector/cn_proc.c: remove unused local Documentation/SubmitChecklist: add RCU debug config options reiserfs: use hweight_long() reiserfs: use proper little-endian bitops pnpacpi: register disabled resources drivers/rtc/rtc-tegra.c: properly initialize spinlock drivers/rtc/rtc-twl.c: check return value of twl_rtc_write_u8() in twl_rtc_set_time() drivers/rtc: add support for Qualcomm PMIC8xxx RTC drivers/rtc/rtc-s3c.c: support clock gating drivers/rtc/rtc-mpc5121.c: add support for RTC on MPC5200 init: skip calibration delay if previously done misc/eeprom: add eeprom access driver for digsy_mtc board misc/eeprom: add driver for microwire 93xx46 EEPROMs checkpatch.pl: update $logFunctions checkpatch: make utf-8 test --strict checkpatch.pl: add ability to ignore various messages checkpatch: add a "prefer __aligned" check checkpatch: validate signature styles and To: and Cc: lines checkpatch: add __rcu as a sparse modifier checkpatch: suggest using min_t or max_t ... Did this as a merge because of (trivial) conflicts in - Documentation/feature-removal-schedule.txt - arch/xtensa/include/asm/uaccess.h that were just easier to fix up in the merge than in the patch series.
2011-07-25pnpacpi: register disabled resourcesWitold Szczeponik
When parsing PnP ACPI resource structures, it may happen that some of the resources are disabled (in which case "the size" of the resource equals zero). The current solution is to skip these resources completely - with the unfortunate side effect that they are not registered despite the fact that they exist, after all. (The downside of this approach is that these resources cannot be used as templates for setting the actual device's resources because they are missing from the template.) The kernel's APM implementation does not suffer from this problem and registers all resources regardless of "their size". This patch fixes a problem with (at least) the vintage IBM ThinkPad 600E (and most likely also with the 600, 600X, and 770X which have a very similar layout) where some of its PnP devices support options where either an IRQ, a DMA, or an IO port is disabled. Without this patch, the devices can not be configured using the "/sys/bus/pnp/devices/*/resources" interface. The manipulation of these resources is important because the 600E has very demanding requirements. For instance, the number of IRQs is not sufficient to support all devices of the 600E. Fortunately, some of the devices, like the sound card's MPU-401 UART, can be configured to not use any IRQ, hence freeing an IRQ for a device that requires one. (Still, the device's "ResourceTemplate" requires an IRQ resource descriptor which cannot be created if the resource has not been registered in the first place.) As an example, the dependent sets of the 600E's CSC0103 device (the MPU-401 UART) are listed, with the patch applied, as: Dependent: 00 - Priority preferred port 0x300-0x330, align 0xf, size 0x4, 16-bit address decoding irq <none> High-Edge Dependent: 01 - Priority acceptable port 0x300-0x330, align 0xf, size 0x4, 16-bit address decoding irq 5,7,2/9,10,11,15 High-Edge (The same result is obtained when PNPBIOS is used instead of PnP ACPI.) Without the patch, the IRQ resource in the preferred option is not listed at all: Dependent: 00 - Priority preferred port 0x300-0x330, align 0xf, size 0x4, 16-bit address decoding Dependent: 01 - Priority acceptable port 0x300-0x330, align 0xf, size 0x4, 16-bit address decoding irq 5,7,2/9,10,11,15 High-Edge And in fact, the 600E's DSDT lists the disabled IRQ as an option, as can be seen from the following excerpt from the DSDT: Name (_PRS, ResourceTemplate () { StartDependentFn (0x00, 0x00) { IO (Decode16, 0x0300, 0x0330, 0x10, 0x04) IRQNoFlags () {} } StartDependentFn (0x01, 0x00) { IO (Decode16, 0x0300, 0x0330, 0x10, 0x04) IRQNoFlags () {5,7,9,10,11,15} } EndDependentFn () }) With this patch applied, a user space program - or maybe even the kernel - can allocate all devices' resources optimally. For the 600E, this means to find optimal resources for (at least) the serial port, the parallel port, the infrared port, the MWAVE modem, the sound card, and the MPU-401 UART. The patch applies the idea to register disabled resources to all types of resources, not just to IRQs, DMAs, and IO ports. At the same time, it mimics the behavior of the "pnp_assign_xxx" functions from "drivers/pnp/manager.c" where resources with "no size" are considered disabled. No regressions were observed on hardware that does not require this patch. The patch is applied against 2.6.39. NB: The kernel's current PnP interface does not allow for disabling individual resources using the "/sys/bus/pnp/devices/$device/resources" file. Assuming this could be done, a device could be configured to use a disabled resource using a simple series of calls: echo disable > /sys/bus/pnp/devices/$device/resources echo clear > /sys/bus/pnp/devices/$device/resources echo set irq disabled > /sys/bus/pnp/devices/$device/resources echo fill > /sys/bus/pnp/devices/$device/resources echo activate > /sys/bus/pnp/devices/$device/resources This patch addresses only the parsing of PnP ACPI devices. ChangeLog (v1 -> v2): - extend patch description - fix typo in patch itself Signed-off-by: Witold Szczeponik <Witold.Szczeponik@gmx.net> Cc: Len Brown <lenb@kernel.org> Cc: Adam Belay <abelay@mit.edu> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Bjorn Helgaas <bhelgaas@google.com> Cc: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Cc: Matthew Garrett <mjg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-10treewide: Convert uses of struct resource to resource_size(ptr)Joe Perches
Several fixes as well where the +1 was missing. Done via coccinelle scripts like: @@ struct resource *ptr; @@ - ptr->end - ptr->start + 1 + resource_size(ptr) and some grep and typing. Mostly uncompiled, no cross-compilers. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-03-22pnp: only assign IORESOURCE_DMA if CONFIG_ISA_DMA_API is enabledDavid Rientjes
IORESOURCE_DMA cannot be assigned without utilizing the interface provided by CONFIG_ISA_DMA_API, specifically request_dma() and free_dma(). Thus, there's a strict dependency on the config option and limits IORESOURCE_DMA only to architectures that support ISA-style DMA. ia64 is not one of those architectures, so pnp_check_dma() no longer needs to be special-cased for that architecture. pnp_assign_resources() will now return -EINVAL if IORESOURCE_DMA is attempted on such a kernel. Signed-off-by: David Rientjes <rientjes@google.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Russell King <linux@arm.linux.org.uk> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-12Merge branch 'pnp' into releaseLen Brown
2011-01-11PNP / ACPI: Use DEVICE_ACPI_HANDLE() for device ACPI handle accessRafael J. Wysocki
The PNP ACPI driver squirrels the ACPI handles of PNP devices' ACPI companions, but this isn't correct, because those handles should be accessed using the DEVICE_ACPI_HANDLE() macro operating on struct device objects. Using DEVICE_ACPI_HANDLE() in the PNP ACPI driver instead of the driver's own copies of the ACPI handles allows us to avoid a problem with docking stations where a machine docked before suspend to RAM and undocked while suspended crashes during the subsequent resume (in that case the ACPI companion of the PNP device in question doesn't exist any more while the device is being resumed). It also allows us to avoid the problem where suspend to RAM fails when the machine was undocked while suspended before (again, the ACPI companion of the PNP device is not present any more while it is being suspended). This change doesn't fix all of the the PNP ACPI driver's problems with PNP devices in docking stations (generally speaking, the driver has no idea that devices can come and go and doesn't even attempt to handle such events), but at least it makes suspend work for the users of docking stations who don't use the PNP devices located in there. References: https://bugzilla.kernel.org/show_bug.cgi?id=15100 Reported-and-tested-by: Toralf Förster <toralf.foerster@gmx.de> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-12-11ACPI/PNP: avoid section mismatch warningJan Beulich
Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-11-17BKL: remove extraneous #include <smp_lock.h>Arnd Bergmann
The big kernel lock has been removed from all these files at some point, leaving only the #include. Remove this too as a cleanup. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-27PNP: Set up pnp_debug via module and not via boot param.Thomas Renninger
Cleanup only, no functional change (pnp.debug can be enabled and disabled at runtime, but that's not a real enhancement). This one depends on another PNP cleanup patch: PNP: Compile all pnp built-in stuff in one module namespace Signed-off-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-10-27PNP: Compile all pnp built-in stuff in one module namespaceThomas Renninger
This is cleanup mostly, nothing urgent. I came up with it when looking at dynamic debug which can enable pr_debug messages at runtime or boot param for a specific module. Advantages: - Any pnp code can make use of the moduleparam.h interface, the modules will show up as pnp.param. - Passing pnp.ddebug as kernel boot param will enable all pnp debug messages with my previous patch and CONFIG_DYNAMIC_DEBUG enabled. Signed-off-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-10-26Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (53 commits) ACPI: install ACPI table handler before any dynamic tables being loaded ACPI / PM: Blacklist another machine that needs acpi_sleep=nonvs ACPI: Page based coalescing of I/O remappings optimization ACPI: Convert simple locking to RCU based locking ACPI: Pre-map 'system event' related register blocks ACPI: Add interfaces for ioremapping/iounmapping ACPI registers ACPI: Maintain a list of ACPI memory mapped I/O remappings ACPI: Fix ioremap size for MMIO reads and writes ACPI / Battery: Return -ENODEV for unknown values in get_property() ACPI / PM: Fix reference counting of power resources Subject: [PATCH] ACPICA: Fix Scope() op in module level code ACPI battery: support percentage battery remaining capacity ACPI: Make Embedded Controller command timeout delay configurable ACPI dock: move some functions to .init.text ACPI: thermal: remove unused limit code ACPI: static sleep_states[] and acpi_gts_bfs_check ACPI: remove dead code ACPI: delete dedicated MAINTAINERS entries for ACPI EC and BATTERY drivers ACPI: Only processor needs CPU_IDLE ACPICA: Update version to 20101013 ...
2010-10-25Merge branch 'pnp-log' into releaseLen Brown
2010-10-25Merge branch 'pnpacpi-invalid-device-id' into releaseLen Brown
2010-10-24Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) Update broken web addresses in arch directory. Update broken web addresses in the kernel. Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget Revert "Fix typo: configuation => configuration" partially ida: document IDA_BITMAP_LONGS calculation ext2: fix a typo on comment in ext2/inode.c drivers/scsi: Remove unnecessary casts of private_data drivers/s390: Remove unnecessary casts of private_data net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data drivers/infiniband: Remove unnecessary casts of private_data drivers/gpu/drm: Remove unnecessary casts of private_data kernel/pm_qos_params.c: Remove unnecessary casts of private_data fs/ecryptfs: Remove unnecessary casts of private_data fs/seq_file.c: Remove unnecessary casts of private_data arm: uengine.c: remove C99 comments arm: scoop.c: remove C99 comments Fix typo configue => configure in comments Fix typo: configuation => configuration Fix typo interrest[ing|ed] => interest[ing|ed] Fix various typos of valid in comments ... Fix up trivial conflicts in: drivers/char/ipmi/ipmi_si_intf.c drivers/usb/gadget/rndis.c net/irda/irnet/irnet_ppp.c
2010-10-18Update broken web addresses in the kernel.Justin P. Mattock
The patch below updates broken web addresses in the kernel Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Cc: Maciej W. Rozycki <macro@linux-mips.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Finn Thain <fthain@telegraphics.com.au> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Matt Turner <mattst88@gmail.com> Cc: Dimitry Torokhov <dmitry.torokhov@gmail.com> Cc: Mike Frysinger <vapier.adi@gmail.com> Acked-by: Ben Pfaff <blp@cs.stanford.edu> Acked-by: Hans J. Koch <hjk@linutronix.de> Reviewed-by: Finn Thain <fthain@telegraphics.com.au> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-10-01ACPI/PNP: A HID value of an object never changes -> make it constThomas Renninger
Signed-off-by: Thomas Renninger <trenn@suse.de> Signed-off-by: Len Brown <len.brown@intel.com>
2010-10-01PNPACPI: cope with invalid device IDsDmitry Torokhov
If primary ID (HID) is invalid try locating first valid ID on compatible ID list before giving up. This helps, for example, to recognize i8042 AUX port on Sony Vaio VPCZ1 which uses SNYSYN0003 as HID. Without the patch users are forced to boot with i8042.nopnp to make use of their touchpads. Tested-by: Jan-Hendrik Zab <jan@jhz.name> Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Len Brown <len.brown@intel.com>
2010-10-01PNP: log PNP resources, as we do for PCIBjorn Helgaas
ACPI devices are often involved in address space conflicts with PCI devices, so I think it's worth logging the resources they use. Otherwise we have to depend on lspnp or groping around in sysfs to find them. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-09-26isapnp: BKL removalArnd Bergmann
Remove BKL use from isapnp_proc_bus_lseek(), like was done for proc_bus_pci_lseek() a long time ago and recently for Zorro by Geert Uytterhoeven. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Jaroslav Kysela <perex@perex.cz>
2010-07-19PNPACPI: Add support for remote wakeupAlan Stern
This patch (as1354) adds remote-wakeup support to the pnpacpi driver. The new can_wakeup method also allows other PNP protocol drivers (pnpbios or iaspnp) to add wakeup support, but I don't know enough about how they work to actually do it. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Reviewed-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2010-05-06Merge branches 'bugzilla-14337', 'bugzilla-14998', 'bugzilla-15407', ↵Len Brown
'bugzilla-15903' and 'misc-2.6.34' into release
2010-05-06PNP: don't check for conflicts with bridge windowsBjorn Helgaas
With fa35b4926, I broke a lot of PNP resource assignment. That commit made PNPACPI include bridge windows as PNP resources, and PNP resource assignment treats any enabled overlapping PNP resources as conflicts. Since PCI host bridge windows typically include most of the I/O port space, this makes PNP port assigments fail. The PCI host bridge driver will eventually use those PNP window resources, so we should make PNP ignore them when checking for conflicts. This fixes https://bugzilla.kernel.org/show_bug.cgi?id=15903 Reported-and-tested-by: Pavel Kysilka <goldenfish@linuxsoft.cz> Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-04-28PNPACPI: compute Address Space length rather than using _LENBjorn Helgaas
ACPI _CRS Address Space Descriptors have _MIN, _MAX, and _LEN. Linux has been computing Address Spaces as [_MIN to _MIN + _LEN - 1]. Based on the tests in the bug reports below, Windows apparently uses [_MIN to _MAX]. Per spec (ACPI 4.0, Table 6-40), for _CRS fixed-size, fixed location descriptors, "_LEN must be (_MAX - _MIN + 1)", and when that's true, it doesn't matter which way we compute the end. But of course, there are BIOSes that don't follow this rule, and we're better off if Linux handles those exceptions the same way as Windows. This patch makes Linux use [_MIN to _MAX], as Windows seems to do. This effectively reverts 3162b6f0c5e and replaces it with simpler code. https://bugzilla.kernel.org/show_bug.cgi?id=14337 (round) https://bugzilla.kernel.org/show_bug.cgi?id=15480 (truncate) Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-04-06Merge branches 'battery', 'bugzilla-14667', 'bugzilla-15096', ↵Len Brown
'bugzilla-15480', 'bugzilla-15521', 'bugzilla-15605', 'gpe-reference-counters', 'misc', 'pxm-fix' and 'video-random-key' into release
2010-04-04PNPACPI: truncate _CRS windows with _LEN > _MAX - _MIN + 1Bjorn Helgaas
The ACPI spec (sec 6.4.3.5 in v4.0) requires that for Address Space Resource Descriptors, _LEN <= _MAX - _MIN + 1 in all cases, but there are BIOSes that violate this. We experimentally determined that Windows truncates the resource so it doesn't extend past _MAX, so let's do the same thing in Linux. http://bugzilla.kernel.org/show_bug.cgi?id=15480 Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Acked-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-14PNPACPI: add bus number supportBjorn Helgaas
Add support for bus number resources. This is for bridges with a range of bus numbers behind them. Previously, PNP ignored bus number resources. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2010-03-14PNPACPI: add window supportBjorn Helgaas
Add support for resource windows. This is for bridge resources, i.e., regions where a bridge forwards transactions from the primary to the secondary side. This does not add support for *setting* windows via the /proc interface. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-12-16Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (117 commits) ACPI processor: Fix section mismatch for processor_add() ACPI: Add platform-wide _OSC support. ACPI: cleanup pci_root _OSC code. ACPI: Add a generic API for _OSC -v2 msi-wmi: depend on backlight and fix corner-cases problems msi-wmi: switch to using input sparse keymap library msi-wmi: replace one-condition switch-case with if statement msi-wmi: remove unused field 'instance' in key_entry structure msi-wmi: remove custom runtime debug implementation msi-wmi: rework init msi-wmi: remove useless includes X86 drivers: Introduce msi-wmi driver Toshiba Bluetooth Enabling driver (RFKill handler v3) ACPI: fix for lapic_timer_propagate_broadcast() acpi_pad: squish warning ACPI: dock: minor whitespace and style cleanups ACPI: dock: add struct dock_station * directly to platform device data ACPI: dock: dock_add - hoist up platform_device_register_simple() ACPI: dock: remove global 'dock_device_name' ACPI: dock: combine add|alloc_dock_dependent_device (v2) ...
2009-12-16pnpbios: convert to seq_fileAlexey Dobriyan
Convert code away from ->read_proc/->write_proc interfaces. Switch to proc_create()/proc_create_data() which make addition of proc entries reliable wrt NULL ->proc_fops, NULL ->data and so on. Problem with ->read_proc et al is described here commit 786d7e1612f0b0adb6046f19b906609e4fe8b1ba "Fix rmmod/read/write races in /proc entries" Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Adam Belay <abelay@mit.edu> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-16Merge branch 'ipmi' into releaseLen Brown
2009-12-15PNP: add interface to retrieve ACPI device from a PNPACPI deviceBjorn Helgaas
Add pnp_acpi_device(pnp_dev), which takes a PNP device and returns the associated ACPI device (or NULL, if the device is not a PNPACPI device). This allows us to write a PNP driver that can manage both traditional PNPBIOS and ACPI devices, treating ACPI-only functionality as an optional extension. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-12-15tree-wide: convert open calls to remove spaces to skip_spaces() lib functionAndré Goddard Rosa
Makes use of skip_spaces() defined in lib/string.c for removing leading spaces from strings all over the tree. It decreases lib.a code size by 47 bytes and reuses the function tree-wide: text data bss dec hex filename 64688 584 592 65864 10148 (TOTALS-BEFORE) 64641 584 592 65817 10119 (TOTALS-AFTER) Also, while at it, if we see (*str && isspace(*str)), we can be sure to remove the first condition (*str) as the second one (isspace(*str)) also evaluates to 0 whenever *str == 0, making it redundant. In other words, "a char equals zero is never a space". Julia Lawall tried the semantic patch (http://coccinelle.lip6.fr) below, and found occurrences of this pattern on 3 more files: drivers/leds/led-class.c drivers/leds/ledtrig-timer.c drivers/video/output.c @@ expression str; @@ ( // ignore skip_spaces cases while (*str && isspace(*str)) { \(str++;\|++str;\) } | - *str && isspace(*str) ) Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Cc: Julia Lawall <julia@diku.dk> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Neil Brown <neilb@suse.de> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Cc: David Howells <dhowells@redhat.com> Cc: <linux-ext4@vger.kernel.org> Cc: Samuel Ortiz <samuel@sortiz.org> Cc: Patrick McHardy <kaber@trash.net> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-11Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: (109 commits) PCI: fix coding style issue in pci_save_state() PCI: add pci_request_acs PCI: fix BUG_ON triggered by logical PCIe root port removal PCI: remove ifdefed pci_cleanup_aer_correct_error_status PCI: unconditionally clear AER uncorr status register during cleanup x86/PCI: claim SR-IOV BARs in pcibios_allocate_resource PCI: portdrv: remove redundant definitions PCI: portdrv: remove unnecessary struct pcie_port_data PCI: portdrv: minor cleanup for pcie_port_device_register PCI: portdrv: add missing irq cleanup PCI: portdrv: enable device before irq initialization PCI: portdrv: cleanup service irqs initialization PCI: portdrv: check capabilities first PCI: portdrv: move PME capability check PCI: portdrv: remove redundant pcie type calculation PCI: portdrv: cleanup pcie_device registration PCI: portdrv: remove redundant pcie_port_device_probe PCI: Always set prefetchable base/limit upper32 registers PCI: read-modify-write the pcie device control register when initiating pcie flr PCI: show dma_mask bits in /sys ... Fixed up conflicts in: arch/x86/kernel/amd_iommu_init.c drivers/pci/dmar.c drivers/pci/hotplug/acpiphp_glue.c
2009-12-11PNPACPI: save struct acpi_device, not just acpi_handleBjorn Helgaas
Some drivers need to look at things in the acpi_device structure besides the handle. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-11-04vsprintf: use %pR, %pr instead of %pRt, %pRfBjorn Helgaas
Jesse accidentally applied v1 [1] of the patchset instead of v2 [2]. This is the diff between v1 and v2. The changes in this patch are: - tidied vsprintf stack buffer to shrink and compute size more accurately - use %pR for decoding and %pr for "raw" (with type and flags) instead of adding %pRt and %pRf [1] http://lkml.org/lkml/2009/10/6/491 [2] http://lkml.org/lkml/2009/10/13/441 Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-11-04PNP: print resources consistently with %pRtBjorn Helgaas
This uses %pRt and %pRf to print additional resource information (type, size, prefetchability, etc.) consistently. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2009-09-25ACPI: remove acpi_device.flags.hardware_idBjorn Helgaas
Every acpi_device has at least one ID (if there's no _HID or _CID, we give it a synthetic or default ID). So there's no longer a need to check whether an ID exists; we can just use it. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-09-25ACPI: maintain a single list of _HID and _CID IDsBjorn Helgaas
There's no need to treat _HID and _CID differently. Keeping them in a single list makes code that uses the IDs a little simpler because it can just traverse the list rather than checking "do we have a HID?", "do we have any CIDs?" Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Reviewed-by: Alex Chiang <achiang@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-09-25ACPI: use acpi_device_hid() when possibleBjorn Helgaas
Use acpi_device_hid() rather than accessing acpi_device.pnp.hardware_id directly. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-09-23Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (119 commits) ACPI: don't pass handle for fixed hardware notifications ACPI: remove null pointer checks in deferred execution path ACPI: simplify deferred execution path acerhdf: additional BIOS versions acerhdf: convert to dev_pm_ops acerhdf: fix fan control for AOA150 model thermal: add missing Kconfig dependency acpi: switch /proc/acpi/{debug_layer,debug_level} to seq_file hp-wmi: fix rfkill memory leak on unload ACPI: remove unnecessary #ifdef CONFIG_DMI ACPI: linux/acpi.h should not include linux/dmi.h hwmon driver for ACPI 4.0 power meters topstar-laptop: add new driver for hotkeys support on Topstar N01 thinkpad_acpi: fix rfkill memory leak on unload thinkpad-acpi: report brightness events when required thinkpad-acpi: don't poll by default any of the reserved hotkeys thinkpad-acpi: Fix procfs hotkey reset command thinkpad-acpi: deprecate hotkey_bios_mask thinkpad-acpi: hotkey poll fixes thinkpad-acpi: be more strict when detecting a ThinkPad ...
2009-09-22pnp: add a shutdown method to pnp driversDavid Härdeman
The shutdown method is used by the winbond cir driver to setup the hardware for wake-from-S5. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Signed-off-by: David Härdeman <david@hardeman.nu> Cc: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-19Merge branch 'acpica' into releaseLen Brown
2009-08-27ACPICA: Major update for acpi_get_object_info external interfaceBob Moore
Completed a major update for the acpi_get_object_info external interface. Changes include: - Support for variable, unlimited length HID, UID, and CID strings - Support Processor objects the same as Devices (HID,UID,CID,ADR,STA, etc.) - Call the _SxW power methods on behalf of a device object - Determine if a device is a PCI root bridge - Change the ACPI_BUFFER parameter to ACPI_DEVICE_INFO. These changes will require an update to all callers of this interface. See the ACPICA Programmer Reference for details. Also, update all invocations of acpi_get_object_info interface Signed-off-by: Bob Moore <robert.moore@intel.com> Signed-off-by: Lin Ming <ming.m.lin@intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-08-10x86: Introduce GDT_ENTRY_INIT(), initialize bad_bios_desc staticallyAkinobu Mita
Fully initialize bad_bios_desc statically instead of doing some fields statically and some dynamically. Suggested-by: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> LKML-Reference: <20090809080350.GA4765@localhost.localdomain> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-08x86: Introduce GDT_ENTRY_INIT()Akinobu Mita
GDT_ENTRY_INIT is static initializer of desc_struct. We already have similar macro GDT_ENTRY() but it's static initializer for u64 and it cannot be used for desc_struct. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> LKML-Reference: <20090718151219.GD11294@localhost.localdomain> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-07-19x86: Introduce set_desc_base() and set_desc_limit()Akinobu Mita
Rename set_base()/set_limit to set_desc_base()/set_desc_limit() and rewrite them in C. These are naturally introduced by the idea of get_desc_base()/get_desc_limit(). The conversion actually found the bug in apm_32.c: bad_bios_desc is written at run-time, but it is defined const variable. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> LKML-Reference: <20090718151105.GC11294@localhost.localdomain> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-06-24Merge branches 'acerhdf', 'acpi-pci-bind', 'bjorn-pci-root', ↵Len Brown
'bugzilla-12904', 'bugzilla-13121', 'bugzilla-13396', 'bugzilla-13533', 'bugzilla-13612', 'c3_lock', 'hid-cleanups', 'misc-2.6.31', 'pdc-leak-fix', 'pnpacpi', 'power_nocheck', 'thinkpad_acpi', 'video' and 'wmi' into release
