path: root/drivers/power/max17042_battery.c
2011-07-08power_supply: MAX17042: Support additional propertiesDonggeun Kim
This patch supports additional properties (PRESENT, CYCLE_COUNT, VOLTAGE_MAX, VOLTAGE_MIN_DESIGN, CURRENT_NOW, CURRENT_AVG, CHARGE_FULL, and TEMP). Plus, initialization code for registers is added. Signed-off-by: Donggeun Kim <dg77.kim@samsung.com> Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com> Signed-off-by: KyungMin Park <kyungmin.park@samsung.com> Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
2011-07-08max17042_battery: Remove obsolete cleanup for clientdataWolfram Sang
A few new i2c-drivers came into the kernel which clear the clientdata-pointer on exit or error. This is obsolete meanwhile, the core will do it. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Cc: MyungJoo Ham <myungjoo.ham@samsung.com> Cc: Kyungmin Park <kyungmin.park@samsung.com> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
2011-01-14power_supply: Add MAX17042 Fuel Gauge DriverMyungJoo Ham
The MAX17042 is a fuel gauge with an I2C interface for lithium-ion betteries. Unlike its predecessor MAX17040, MAX17042 uses 16bit registers. Besides, MAX17042 has much more features than MAX17040; e.g., a thermistor, current and current accumulation measurement, battery internal resistance estimate, average values of measurement, and others. This patch implements a driver for MAX17042. In this initial release, we have implemented the most basic features of a fuel gauge: measure the battery capacity and voltage. Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
