This moves all power supply drivers from drivers/power/
to drivers/power/supply/. The intention is a cleaner
source tree, since drivers/power/ also contains frameworks
unrelated to power supply, like adaptive voltage scaling.
Signed-off-by: Sebastian Reichel <sre@kernel.org>
The change removes redundant sysfs binary file boundary check while
reading eeprom content from userspace, the check is done on caller
side in fs/sysfs/file.c, if binary attribute size is not zero.
Signed-off-by: Vladimir Zapolskiy <vz@mleia.com>
Change the ownership of power_supply structure from each driver
implementing the class to the power supply core.
The patch changes power_supply_register() function thus all drivers
implementing power supply class are adjusted.
Each driver provides the implementation of power supply. However it
should not be the owner of power supply class instance because it is
exposed by core to other subsystems with power_supply_get_by_name().
These other subsystems have no knowledge when the driver will unregister
the power supply. This leads to several issues when driver is unbound -
mostly because user of power supply accesses freed memory.
Instead let the core own the instance of struct 'power_supply'. Other
users of this power supply will still access valid memory because it
will be freed when device reference count reaches 0. Currently this
means "it will leak" but power_supply_put() call in next patches will
solve it.
This solves invalid memory references in following race condition
scenario:
Thread 1: charger manager
Thread 2: power supply driver, used by charger manager
THREAD 1 (charger manager) THREAD 2 (power supply driver)
psy = power_supply_get_by_name()
Driver unbind, .remove
power_supply_unregister()
Device fully removed
psy->get_property()
The 'get_property' call is executed in invalid context because the driver was
unbound and struct 'power_supply' memory was freed.
This could be observed easily with charger manager driver (here compiled
with max17040 fuel gauge):
$ cat /sys/devices/virtual/power_supply/cm-battery/capacity &
$ echo "1-0036" > /sys/bus/i2c/drivers/max17040/unbind
[ 55.725123] Unable to handle kernel NULL pointer dereference at virtual address 00000000
[ 55.732584] pgd = d98d4000
[ 55.734060] [00000000] *pgd=5afa2831, *pte=00000000, *ppte=00000000
[ 55.740318] Internal error: Oops: 80000007 [#1] PREEMPT SMP ARM
[ 55.746210] Modules linked in:
[ 55.749259] CPU: 1 PID: 2936 Comm: cat Tainted: G W 3.19.0-rc1-next-20141226-00048-gf79f475f3c44-dirty #1496
[ 55.760190] Hardware name: SAMSUNG EXYNOS (Flattened Device Tree)
[ 55.766270] task: d9b76f00 ti: daf54000 task.ti: daf54000
[ 55.771647] PC is at 0x0
[ 55.774182] LR is at charger_get_property+0x2f4/0x36c
[ 55.779201] pc : [<00000000>] lr : [<c034b0b4>] psr: 60000013
[ 55.779201] sp : daf55e90 ip : 00000003 fp : 00000000
[ 55.790657] r10: 00000000 r9 : c06e2878 r8 : d9b26c68
[ 55.795865] r7 : dad81610 r6 : daec7410 r5 : daf55ebc r4 : 00000000
[ 55.802367] r3 : 00000000 r2 : daf55ebc r1 : 0000002a r0 : d9b26c68
[ 55.808879] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 55.815994] Control: 10c5387d Table: 598d406a DAC: 00000015
[ 55.821723] Process cat (pid: 2936, stack limit = 0xdaf54210)
[ 55.827451] Stack: (0xdaf55e90 to 0xdaf56000)
[ 55.831795] 5e80: 60000013 c01459c4 0000002a c06f8ef8
[ 55.839956] 5ea0: db651000 c06f8ef8 daebac00 c04cb668 daebac08 c0346864 00000000 c01459c4
[ 55.848115] 5ec0: d99eaa80 c06f8ef8 00000fff 00001000 db651000 c027f25c c027f240 d99eaa80
[ 55.856274] 5ee0: d9a06c00 c0146218 daf55f18 00001000 d99eaa80 db4c18c0 00000001 00000001
[ 55.864468] 5f00: daf55f80 c0144c78 c0144c54 c0107f90 00015000 d99eaab0 00000000 00000000
[ 55.872603] 5f20: 000051c7 00000000 db4c18c0 c04a9370 00015000 00001000 daf55f80 00001000
[ 55.880763] 5f40: daf54000 00015000 00000000 c00e53dc db4c18c0 c00e548c 0000000d 00008124
[ 55.888937] 5f60: 00000001 00000000 00000000 db4c18c0 db4c18c0 00001000 00015000 c00e5550
[ 55.897099] 5f80: 00000000 00000000 00001000 00001000 00015000 00000003 00000003 c000f364
[ 55.905239] 5fa0: 00000000 c000f1a0 00001000 00015000 00000003 00015000 00001000 0001333c
[ 55.913399] 5fc0: 00001000 00015000 00000003 00000003 00000002 00000000 00000000 00000000
[ 55.921560] 5fe0: 7fffe000 be999850 0000a225 b6f3c19c 60000010 00000003 00000000 00000000
[ 55.929744] [<c034b0b4>] (charger_get_property) from [<c0346864>] (power_supply_show_property+0x48/0x20c)
[ 55.939286] [<c0346864>] (power_supply_show_property) from [<c027f25c>] (dev_attr_show+0x1c/0x48)
[ 55.948130] [<c027f25c>] (dev_attr_show) from [<c0146218>] (sysfs_kf_seq_show+0x84/0x104)
[ 55.956298] [<c0146218>] (sysfs_kf_seq_show) from [<c0144c78>] (kernfs_seq_show+0x24/0x28)
[ 55.964536] [<c0144c78>] (kernfs_seq_show) from [<c0107f90>] (seq_read+0x1b0/0x484)
[ 55.972172] [<c0107f90>] (seq_read) from [<c00e53dc>] (__vfs_read+0x18/0x4c)
[ 55.979188] [<c00e53dc>] (__vfs_read) from [<c00e548c>] (vfs_read+0x7c/0x100)
[ 55.986304] [<c00e548c>] (vfs_read) from [<c00e5550>] (SyS_read+0x40/0x8c)
[ 55.993164] [<c00e5550>] (SyS_read) from [<c000f1a0>] (ret_fast_syscall+0x0/0x48)
[ 56.000626] Code: bad PC value
[ 56.011652] ---[ end trace 7b64343fbdae8ef1 ]---
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Reviewed-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
[for the nvec part]
Reviewed-by: Marc Dietrich <marvin24@gmx.de>
[for compal-laptop.c]
Acked-by: Darren Hart <dvhart@linux.intel.com>
[for the mfd part]
Acked-by: Lee Jones <lee.jones@linaro.org>
[for the hid part]
Acked-by: Jiri Kosina <jkosina@suse.cz>
[for the acpi part]
Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
Add new structure 'power_supply_config' for holding run-time
initialization data like of_node, supplies and private driver data.
The power_supply_register() function is changed so all power supply
drivers need updating.
When registering the power supply this new 'power_supply_config' should be
used instead of directly initializing 'struct power_supply'. This allows
changing the ownership of power_supply structure from driver to the
power supply core in next patches.
When a driver does not use of_node or supplies then it should use NULL
as config. If driver uses of_node or supplies then it should allocate
config on stack and initialize it with proper values.
Acked-by: Pavel Machek <pavel@ucw.cz>
[for the nvec part]
[for drivers/platform/x86/compal-laptop.c]
Reviewed-by: Darren Hart <dvhart@linux.intel.com>
[for drivers/hid/*]
Reviewed-by: Jiri Kosina <jkosina@suse.cz>
A platform_driver does not need to set an owner, it will be populated by the
driver core.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
CONFIG_HOTPLUG is going away as an option. As a result, the __dev*
markings need to be removed.
This change removes the use of __devinit, __devexit_p, __devinitconst,
and __devexit from these drivers.
Based on patches originally written by Bill Pemberton, but redone by me
in order to handle some of the coding style issues better, by hand.
Cc: Bill Pemberton <wfp5p@virginia.edu>
Cc: Anton Vorontsov <cbou@mail.ru>
Cc: Andrew Lunn <andrew@lunn.ch>
Cc: Jamie Lentin <jm@lentin.co.uk>
Cc: Jason Cooper <jason@lakedaemon.net>
CONFIG_HOTPLUG is going away as an option so __devexit is no
longer needed.
Signed-off-by: Bill Pemberton <wfp5p@virginia.edu>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
CONFIG_HOTPLUG is going away as an option so __devinit is no longer
needed.
CONFIG_HOTPLUG is going away as an option so __devexit_p is no longer
needed.
Pull OLPC platform updates from Andres Salomon:
"These move the OLPC Embedded Controller driver out of
arch/x86/platform and into drivers/platform/olpc.
OLPC machines are now ARM-based (which means lots of x86 and ARM
changes), but are typically pretty self-contained.. so it makes more
sense to go through a separate OLPC tree after getting the appropriate
review/ACKs."
* 'for-linus-3.6' of git://dev.laptop.org/users/dilinger/linux-olpc:
x86: OLPC: move s/r-related EC cmds to EC driver
Platform: OLPC: move global variables into priv struct
Platform: OLPC: move debugfs support from x86 EC driver
x86: OLPC: switch over to using new EC driver on x86
Platform: OLPC: add a suspended flag to the EC driver
Platform: OLPC: turn EC driver into a platform_driver
Platform: OLPC: allow EC cmd to be overridden, and create a workqueue to call it
drivers: OLPC: update various drivers to include olpc-ec.h
Platform: OLPC: add a stub to drivers/platform/ for the OLPC EC driver
Switch over to using olpc-ec.h in multiple steps, so as not to break builds.
This covers every driver that calls olpc_ec_cmd().
Signed-off-by: Andres Salomon <dilinger@queued.net>
Acked-by: Paul Fox <pgf@laptop.org>
Reduce the mAh value for the BYD LiFe battery from 3100mAh to 2800mAh
to better reflect the average usable capacity as measured by olpc-pwr-log.
Signed-off-by: Richard A. Smith <richard@laptop.org>
Signed-off-by: Daniel Drake <dsd@laptop.org>
Signed-off-by: Anton Vorontsov <anton.vorontsov@linaro.org>
upowerd wants to compute the energy in the battery by looking at this
property. If it's not present then it falls back on using the reported
voltage of the battery at time upowerd loads. That's close but also
means that every time you boot you get a slightly different energy
capacity.
Adding the VOLTAGE_MAX_DESIGN property allows upowerd to compute the
same energy every time.
This patch converts the drivers in drivers/power/* to use the
module_platform_driver() macro which makes the code smaller and a bit
simpler.
Cc: Mike Rapoport <mike@compulab.co.il>
Cc: Lars-Peter Clausen <lars@metafoo.de>
Cc: Nithish Mahalingam <nithish.mahalingam@intel.com>
Cc: MyungJoo Ham <myungjoo.ham@samsung.com>
Cc: Haojian Zhuang <haojian.zhuang@marvell.com>
Cc: Balaji Rao <balajirrao@openmoko.org>
Cc: Mark Brown <broonie@opensource.wolfsonmicro.com>
Acked-by: Clifton Barnes <cabarnes@indesign-llc.com>
Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
It is no longer used, so we can safely remove it.
This patch fixes the following noise (by renaming _drv to _driver):
WARNING: drivers/power/olpc_battery.o(.data+0x100): Section mismatch in reference from the variable olpc_battery_drv to the function .devinit.text:olpc_battery_probe()
The variable olpc_battery_drv references
the function __devinit olpc_battery_probe()
If the reference is valid then annotate the
variable with __init* or __refdata (see linux/init.h) or name the variable:
*driver, *_template, *_timer, *_sht, *_ops, *_probe, *_probe_one, *_console
WARNING: drivers/power/olpc_battery.o(.data+0x104): Section mismatch in reference from the variable olpc_battery_drv to the function .devexit.text:olpc_battery_remove()
the function __devexit olpc_battery_remove()
variable with __exit* (see linux/init.h) or name the variable:
WARNING: drivers/power/olpc_battery.o(.data+0x128): Section mismatch in reference from the variable olpc_battery_drv to the variable .devinit.rodata:olpc_battery_ids
the variable __devinitconst olpc_battery_ids
Battery and AC events can now be used to wake up the system from suspend.
Acked-by: Andres Salomon <dilinger@queued.net>
This is cleaner, and allows suspend/resume (wakeup) handlers to be
added in an upcoming patch.
The patches adding support for CURRENT_NOW, VOLTAGE_NOW, CHARGE_NOW and
CHARGE_FULL_DESIGN were based on a tree not including c566d299
("olpc_battery: Ambient temperature is not available on XO-1.5") and
therefore only modified the then-common, now-XO-1 properties list. This
patch adds the new properties to XO-1.5 as well.
Signed-off-by: Sascha Silbe <sascha-pgp@silbe.org>
{CURRENT,VOLTAGE}_AVG are actually {CURRENT,VOLTAGE}_NOW (the EC code
directly passes through the value from the gas gauge instead of the
internally used average). We retain {CURRENT,VOLTAGE}_AVG as an alias
for compatibility reasons, it will be removed later.
[ pgf@laptop.org: added VOLTAGE_NOW, aliased to VOLTAGE_AVG ]
Signed-off-by: Paul Fox <pgf@laptop.org>
CHARGE_NOW is needed by some user space software (read: UPower) for
internal calculations.
This patch violates the power supply class definition (as we already
do for CAPACITY though it isn't as obvious there), but this is the best
we can do without adding rather sophisticated algorithms to either the EC
or UPower.
Some user space software (read: UPower) uses CHARGE_FULL_DESIGN for internal
calculations. The design capacity of the OLPC batteries is effectively fixed
and only needs to be exported.
The XO-1.5 does not support the ambient temperature property.
Create a separate list of properties for that configuration where
ambient temperature is not included, and apply the correct property
list at runtime.
When the driver was updated to be endian neutral (8e9c7716c)
the signed part of the s16 values was lost. This is because be16_to_cpu()
returns an unsigned value. This patch casts the values back to a s16
number prior to the the implicit cast up to an int.
Cc: <stable@kernel.org>
drivers/power/olpc_battery.c:387: error: unknown field 'owner' specified in initializer
drivers/power/olpc_battery.c:387: warning: excess elements in struct initializer
drivers/power/olpc_battery.c:387: warning: (near initialization for 'olpc_bat_eeprom.attr')
The .owner field has been dropped from the attr struct.
This allows bin_attr->read,write,mmap callbacks to check file specific data
(such as inode owner) as part of any privilege validation.
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
This adds a new sysfs file called 'charge_type' which displays the
type of charging (unknown, n/a, trickle charge, or fast charging).
This allows things like battery diagnostics to determine what the
battery/EC is doing without resorting to changing the 'status' sysfs
output.
Signed-off-by: Andres Salomon <dilinger@collabora.co.uk>
Grab the error code from EC_BAT_ERRCODE and let the user see it (rather
than attempting to decode it as we do with PROP_HEALTH) with a separate
error sysfs file.
This reverts commit 8efe444038a205e79b38b7ad03878824901849a8 and
4cbc76eadf56399cd11fb736b33c53aec9caab8c.
Richard@laptop.org was apparently using CAPACITY_LEVEL for debugging
battery/EC problems, and was upset that it was removed. This readds it.
Documentation/power_supply_class.txt
There are times when the battery is present but trickle charging,
and the EC sets only the TRICKLE bit. So we must check for the bit
when we're checking the charging/present status.
The eeprom read function was placing values into the wrong place in
'buf'; we were starting from buf[off], rather than buf[0].
Also, the for loop that we were using was much uglier than it needed to
be. This cleans it up a bit.
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
As Richard Smith pointed out, ACR * 6250 / 15 provides for less
precision loss than ACR * 4167 / 10, _and_ it doesn't overflow. Switch
to using that equation for CHARGE_COUNTER.
Signed-off-by: Andres Salomon <dilinger@debian.org>
Cc: "Richard A. Smith" <richard@laptop.org>
This adds PROP_CHARGE_COUNTER to the power supply class (documenting it
as well). The OLPC battery driver uses this for spitting out its ACR
values (in uAh). We have some rounding errors (the data sheet claims
416.7, the math actually works out to 416.666667, so we're forced to
choose between overflows or precision loss. I chose precision loss,
and stuck w/ data sheet values), but I don't think anyone will care
that much.
Refuse to run with an EC < 0x44. We're playing it safe, and this is a pretty
old EC version.
Also, add a comment about why we're checking the EC version.
Move portions of the massive switch statement into functions. The layout of
this thing has already caused one bug (a break in the wrong place), it needed
to shrink.
This allows you to dump 0x60 bytes from the battery's EEPROM (starting at
address 0x20). Note that it does an EC command for each byte, so it's pretty
slow. OTOH, if you want to grab just a single byte from somewhere in the
EEPROM, you can do something like:
dd bs=1 count=1 skip=16 if=/sys/class/power_supply/olpc-battery/eeprom | od -x
Userspace battery collection/logging information needs this.
This adds serial number support to the OLPC battery driver.
This adds support for OLPC XO hardware. Open Firmware on XOs don't contain
the VSA, so it is necessary to emulate the PCI BARs in the kernel. This also
adds functionality for running EC commands, and a CONFIG_OLPC.
A number of OLPC drivers depend upon CONFIG_OLPC.
olpc_ec_timeout is a hack to work around Embedded Controller bugs.
[akpm@linux-foundation.org: build fix]
[akpm@linux-foundation.org: geode_has_vsa build fix]
[akpm@linux-foundation.org: olpc_register_battery_callback doesn't exist]
Cc: Andi Kleen <ak@suse.de>
Cc: Jordan Crouse <jordan.crouse@amd.com>
The CAPACITY_LEVEL stuff defines various levels of charge; however, what
is the difference between them? What differentiates between HIGH and NORMAL,
LOW and CRITICAL, etc?
As it appears that these are fairly arbitrary, we end up making such policy
decisions in the kernel (or in hardware). This is the sort of decision that
should be made in userspace, not in the kernel.
If the hardware does not support _CAPACITY and it cannot be easily calculated,
then perhaps the driver should register a custom CAPACITY_LEVEL attribute;
however, userspace should not become accustomed to looking for such a thing,
and we should certainly not encourage drivers to provide CAPACITY_LEVEL
stubs.
The following removes support for POWER_SUPPLY_PROP_CAPACITY_LEVEL. The
OLPC battery driver is the only driver making use of this, so it's
removed from there as well.
Per Jeff Garzik request.
Signed-off-by: Jeff Garzik <jeff@garzik.org>
Signed-off-by: Anton Vorontsov <cbou@mail.ru>
