Signed-off-by: Bjorn Andersson <bjorn.andersson@sonymobile.com>
Reviewed-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Signed-off-by: Sebastian Reichel <sre@kernel.org>
This commit adds a resource-managed version of the
power_supply_get_by_phandle() function.
Don't call the power_supply_changed() from power_supply_register() when
parent is still probing because it may lead to accessing parent too
early.
In bq27x00_battery this caused NULL pointer exception because uevent of
power_supply_changed called back the the get_property() method provided
by the driver. The get_property() method accessed pointer which should
be returned by power_supply_register().
Starting from bq27x00_battery_probe():
di->bat = power_supply_register()
kobject_uevent()
power_supply_uevent()
power_supply_show_property()
power_supply_get_property()
bq27x00_battery_get_property()
dereference of di->bat which is NULL here
The dereference of di->bat (value returned by power_supply_register())
is the currently visible problem. However calling back the methods
provided by driver before ending the probe may lead to accessing other
driver-related data which is not yet initialized.
The call to power_supply_changed() is postponed till probing ends -
mutex of parent device is released.
Reported-by: H. Nikolaus Schaller <hns@goldelico.com>
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Fixes: 297d716f6260 ("power_supply: Change ownership from driver to core")
Tested-By: Dr. H. Nikolaus Schaller <hns@goldelico.com>
Power supply is often registered during probe of a driver. The
power_supply_register() returns pointer to newly allocated structure as
return value. However before returning the power_supply_register()
calls back the get_property() method provided by the driver through
uevent.
In that time the driver probe is still in progress and driver did not
assigned pointer to power supply to its local variables. This leads to
NULL pointer dereference from get_property() function.
device_add()
kobject_uevent()
dereference of (di->bat) which is NULL here
The first uevent of power supply (the one coming from device creation)
should not call back to the driver. To prevent that from happening,
increment the atomic use counter at the end of power_supply_register().
This means that power_supply_get_property() will return -ENODEV.
IMPORTANT:
The patch has impact on this first uevent sent from power supply because
it will not contain properties from power supply.
The uevent with properties will be sent later after indicating that
power supply has changed. This also has a race now, but will be fixed in
other patches.
Increment the power_supply.use_cnt usage counter on:
- power_supply_get_by_phandle()
- power_supply_get_by_name()
and decrement it on power_supply_put() call.
This helps tracking of valid usage of power supply instance by
consumers. The usage counter itself also allows safe calling of
power_supply_get_property-like functions even when driver unregisters
this power supply.
Reviewed-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
The power_supply_get_by_phandle() and power_supply_get_by_name() use
function class_find_device() for obtaining the reference to power
supply. Each use of class_find_device() increases the power supply's
device reference counter.
However the reference counter was not decreased by users of this API.
Thus final device_unregister() call from power_supply_unregister() could
not release the device and clean up its resources. This lead to memory
leak if at least once power_supply_get_by_*() was called between
registering and unregistering the power supply.
Add and document new API power_supply_put() for decrementing the
reference counter.
Acked-by: Pavel Machek <pavel@ucw.cz>
Reviewed-by: Sebastian Reichel <sre@kernel.org>
Change the ownership of power_supply structure from each driver
implementing the class to the power supply core.
The patch changes power_supply_register() function thus all drivers
implementing power supply class are adjusted.
Each driver provides the implementation of power supply. However it
should not be the owner of power supply class instance because it is
exposed by core to other subsystems with power_supply_get_by_name().
These other subsystems have no knowledge when the driver will unregister
the power supply. This leads to several issues when driver is unbound -
mostly because user of power supply accesses freed memory.
Instead let the core own the instance of struct 'power_supply'. Other
users of this power supply will still access valid memory because it
will be freed when device reference count reaches 0. Currently this
means "it will leak" but power_supply_put() call in next patches will
solve it.
This solves invalid memory references in following race condition
scenario:
Thread 1: charger manager
Thread 2: power supply driver, used by charger manager
THREAD 1 (charger manager) THREAD 2 (power supply driver)
psy = power_supply_get_by_name()
Driver unbind, .remove
Device fully removed
psy->get_property()
The 'get_property' call is executed in invalid context because the driver was
unbound and struct 'power_supply' memory was freed.
This could be observed easily with charger manager driver (here compiled
with max17040 fuel gauge):
$ cat /sys/devices/virtual/power_supply/cm-battery/capacity &
$ echo "1-0036" > /sys/bus/i2c/drivers/max17040/unbind
[ 55.725123] Unable to handle kernel NULL pointer dereference at virtual address 00000000
[ 55.732584] pgd = d98d4000
[ 55.734060] [00000000] *pgd=5afa2831, *pte=00000000, *ppte=00000000
[ 55.740318] Internal error: Oops: 80000007 [#1] PREEMPT SMP ARM
[ 55.746210] Modules linked in:
[ 55.749259] CPU: 1 PID: 2936 Comm: cat Tainted: G W 3.19.0-rc1-next-20141226-00048-gf79f475f3c44-dirty #1496
[ 55.760190] Hardware name: SAMSUNG EXYNOS (Flattened Device Tree)
[ 55.766270] task: d9b76f00 ti: daf54000 task.ti: daf54000
[ 55.771647] PC is at 0x0
[ 55.774182] LR is at charger_get_property+0x2f4/0x36c
[ 55.779201] pc : [<00000000>] lr : [<c034b0b4>] psr: 60000013
[ 55.779201] sp : daf55e90 ip : 00000003 fp : 00000000
[ 55.790657] r10: 00000000 r9 : c06e2878 r8 : d9b26c68
[ 55.795865] r7 : dad81610 r6 : daec7410 r5 : daf55ebc r4 : 00000000
[ 55.802367] r3 : 00000000 r2 : daf55ebc r1 : 0000002a r0 : d9b26c68
[ 55.808879] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 55.815994] Control: 10c5387d Table: 598d406a DAC: 00000015
[ 55.821723] Process cat (pid: 2936, stack limit = 0xdaf54210)
[ 55.827451] Stack: (0xdaf55e90 to 0xdaf56000)
[ 55.831795] 5e80: 60000013 c01459c4 0000002a c06f8ef8
[ 55.839956] 5ea0: db651000 c06f8ef8 daebac00 c04cb668 daebac08 c0346864 00000000 c01459c4
[ 55.848115] 5ec0: d99eaa80 c06f8ef8 00000fff 00001000 db651000 c027f25c c027f240 d99eaa80
[ 55.856274] 5ee0: d9a06c00 c0146218 daf55f18 00001000 d99eaa80 db4c18c0 00000001 00000001
[ 55.864468] 5f00: daf55f80 c0144c78 c0144c54 c0107f90 00015000 d99eaab0 00000000 00000000
[ 55.872603] 5f20: 000051c7 00000000 db4c18c0 c04a9370 00015000 00001000 daf55f80 00001000
[ 55.880763] 5f40: daf54000 00015000 00000000 c00e53dc db4c18c0 c00e548c 0000000d 00008124
[ 55.888937] 5f60: 00000001 00000000 00000000 db4c18c0 db4c18c0 00001000 00015000 c00e5550
[ 55.897099] 5f80: 00000000 00000000 00001000 00001000 00015000 00000003 00000003 c000f364
[ 55.905239] 5fa0: 00000000 c000f1a0 00001000 00015000 00000003 00015000 00001000 0001333c
[ 55.913399] 5fc0: 00001000 00015000 00000003 00000003 00000002 00000000 00000000 00000000
[ 55.921560] 5fe0: 7fffe000 be999850 0000a225 b6f3c19c 60000010 00000003 00000000 00000000
[ 55.929744] [<c034b0b4>] (charger_get_property) from [<c0346864>] (power_supply_show_property+0x48/0x20c)
[ 55.939286] [<c0346864>] (power_supply_show_property) from [<c027f25c>] (dev_attr_show+0x1c/0x48)
[ 55.948130] [<c027f25c>] (dev_attr_show) from [<c0146218>] (sysfs_kf_seq_show+0x84/0x104)
[ 55.956298] [<c0146218>] (sysfs_kf_seq_show) from [<c0144c78>] (kernfs_seq_show+0x24/0x28)
[ 55.964536] [<c0144c78>] (kernfs_seq_show) from [<c0107f90>] (seq_read+0x1b0/0x484)
[ 55.972172] [<c0107f90>] (seq_read) from [<c00e53dc>] (__vfs_read+0x18/0x4c)
[ 55.979188] [<c00e53dc>] (__vfs_read) from [<c00e548c>] (vfs_read+0x7c/0x100)
[ 55.986304] [<c00e548c>] (vfs_read) from [<c00e5550>] (SyS_read+0x40/0x8c)
[ 55.993164] [<c00e5550>] (SyS_read) from [<c000f1a0>] (ret_fast_syscall+0x0/0x48)
[ 56.000626] Code: bad PC value
[ 56.011652] ---[ end trace 7b64343fbdae8ef1 ]---
[for the nvec part]
Reviewed-by: Marc Dietrich <marvin24@gmx.de>
[for compal-laptop.c]
Acked-by: Darren Hart <dvhart@linux.intel.com>
[for the mfd part]
Acked-by: Lee Jones <lee.jones@linaro.org>
[for the hid part]
Acked-by: Jiri Kosina <jkosina@suse.cz>
[for the acpi part]
Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
Add simple wrappers for accessing power supply's function attributes:
- get_property -> power_supply_get_property
- set_property -> power_supply_set_property
- property_is_writeable -> power_supply_property_is_writeable
- external_power_changed -> power_supply_external_power_changed
This API along with atomic usage counter adds a safe way of accessing a
power supply from another driver. If power supply is unregistered after
obtaining reference to it by some driver, then the API wrappers won't be
executed in invalid (freed) context.
Next patch changing the ownership of power supply class is still needed
to fully fix race conditions in accessing freed power supply.
Add new structure 'power_supply_config' for holding run-time
initialization data like of_node, supplies and private driver data.
The power_supply_register() function is changed so all power supply
drivers need updating.
When registering the power supply this new 'power_supply_config' should be
used instead of directly initializing 'struct power_supply'. This allows
changing the ownership of power_supply structure from driver to the
power supply core in next patches.
When a driver does not use of_node or supplies then it should use NULL
as config. If driver uses of_node or supplies then it should allocate
config on stack and initialize it with proper values.
[for the nvec part]
[for drivers/platform/x86/compal-laptop.c]
Reviewed-by: Darren Hart <dvhart@linux.intel.com>
[for drivers/hid/*]
Reviewed-by: Jiri Kosina <jkosina@suse.cz>
Allow drivers to store private data inside power_supply structure for
later usage in power supply operations.
Usage of driver private data is necessary to access driver's state
container object from power supply calls (like get_property()) if struct
'power_supply' is a stored there as a pointer, for example:
struct some_driver_info {
struct i2c_client *client;
struct power_supply *power_supply;
In such case one cannot use container_of() and must store pointer to
state container as private data.
Using devm_power_supply_register allows the unregister to happen
automatically on error or final put.
Signed-off-by: NeilBrown <neilb@suse.de>
Add a 'no_thermal' property to the power supply class. If true then
thermal zone won't be created for this power supply in
Power supply drivers may want to set it if they support
POWER_SUPPLY_PROP_TEMP and they are forwarding this get property call to
other thermal zone.
If they won't set it lockdep may report false positive deadlock for
thermal zone's mutex because of nested calls to thermal_zone_get_temp().
First is the call to thermal_zone_get_temp() of the driver's thermal
zone. Thermal core gets POWER_SUPPLY_PROP_TEMP property from this
driver. The driver then calls other thermal zone thermal_zone_get_temp()
and returns result.
Example of such driver is charger manager.
This piece of code was added so that we return -EPROBE_DEFER when no devices are
registered. But even if class_for_each_device() returns 0, we are going to
return -EPROBE_DEFER only.
And so this code isn't required at all. Remove it.
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
Using 'goto' statements for freeing resources on failures is a good choice as it
makes code very clean, and reduces the chances of human errors.
Though in most cases compiler may take care of this. But adding unnecessary
'goto' statements wouldn't make anything better. Code becomes less readable
actually.
At multiple places we are doing exactly what PTR_ERR_OR_ZERO() does. And so that
routine can be reused instead of increasing lines of code here.
The 'if' statements in power_supply_changed_work() are mostly there for taking
care of races and normally they will always evaluate to true. Optimize them for
fast execution with 'likely' statements.
Also there is need to have better comments in code to mention about the races
clearly. Get them in place.
Cc: Zoran Markovic <zrn.markovic@gmail.com>
There is no need to check the value of ret.intval before returning it, as we
will be returning zero explicitly when ret.intval is zero.
So essentially we will end up returning value of ret.intval as it is. Drop the
unnecessary 'if' statements.
We need to stop 'class_for_each_device' loop when a supply matches with the
of-node. In order to achieve this we currently return -EINVAL from
__power_supply_populate_supplied_from() on successful match.
class_for_each_device() is free to return similar errors in other cases as well
and so the choice of return value here isn't particularly great.
This commit isn't removing the Hack but making it more elegant by returning '1'
instead.
Also power_supply_find_supply_from_node() can return errors other than
-EPROBE_DEFER now if class_for_each_device() fails.
Callers of power_supply_find_supply_from_node(), i.e.
power_supply_check_supplies(), must propagate the errors returned by it instead
of returning their own.
of_node_put() was called twice in power_supply_check_supplies() whereas a single
call will also work. Rearrange code a bit to make that feasible.
In few routines, we need to end the do-while loop when no more "power-supplies"
are available. Currently we are doing 'continue' which will make the
'while(np)' conditional statement run again.
Skip this by doing a 'break' instead.
Typecast from 'void *' to any other pointer type falls under implicit typecasts
category and so doesn't require explicit typecasts. Drop them.
If power-supply's DT node doesn't have a valid "power-supplies" entry, then
power_supply_check_supplies() should return early instead of trying to allocate
memory for "supplied_from" array.
In routine power_supply_check_supplies(), 'cnt' is counting the number of
supplies passed in "power-supplies" field of a node. The value of 'cnt' will
always be one more than the number of supplies after the do-while loop ends. And
so we need to allocate memory for 'cnt - 1' char pointers. But we are allocating
memory for 'cnt' instead.
Fix this by not over-allocating memory.
Fixes the following sparse warnings:
drivers/power/power_supply_core.c:540:5: warning:
symbol '__power_supply_register' was not declared. Should it be static?
Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
Currently, all the power supply devices are registered with wakeup source,
this results in that every power_supply_changed() invocation brings
the system out of suspend-to-freeze state.
This is overkill as some device drivers, e.g. ACPI battery driver,
have the ability to check the device status and wake up the system
from sleeping only when necessary.
Thus introduce a new API which allows device to be registered
w/o wakeup source.
Signed-off-by: Zhang Rui <rui.zhang@intel.com>
Add method to get power supply by device tree phandle.
Signed-off-by: Sebastian Reichel <sre@debian.org>
Reviewed-by: Pavel Machek <pavel@ucw.cz>
Signed-off-by: Anton Vorontsov <anton@enomsg.org>
This patch adds a notifier chain to the power_supply, this helps drivers
in other subsystem to listen to changes in power supply subsystem.
This would help to take some actions in those drivers on changing the
power supply properties. One such scenario is to increase/decrease system
performance based on the battery capacity/voltage. Another scenario is to
adjust the h/w peak current detection voltage/current thresholds based on
battery voltage/capacity. The notifier helps drivers to listen to changes
in power_suppy susbystem without polling the power_supply properties
Signed-off-by: Jenny TC <jenny.tc@intel.com>
Signed-off-by: Pali Rohár <pali.rohar@gmail.com>
Acked-by: Jenny TC <jenny.tc@intel.com>
power_supply_register() calls device_init_wakeup() to register a wakeup
source before initializing dev_name. As a result, device_wakeup_enable()
end up registering wakeup source with a null name when
wakeup_source_register() gets called with dev_name(dev) which is null at
the time.
When kernel is booted with wakeup_source_activate enabled, it will panic
when the trace point code tries to dereference ws->name.
Fixed the problem by moving up the kobject_set_name() call prior to
accesses to dev_name(). Replaced kobject_set_name() with dev_set_name()
which is the right interface to be called from drivers. Fixed the call to
device_del() prior to device_add() in for wakeup_init_failed error
handling code.
Trace after the change:
bash-2143 [003] d... 132.280697: wakeup_source_activate: BAT1 state=0x20001
kworker/3:2-1169 [003] d... 132.281305: wakeup_source_deactivate: BAT1 state=0x30000
Oops message:
[ 819.769934] device: 'BAT1': device_add
[ 819.770078] PM: Adding info for No Bus:BAT1
[ 819.770235] BUG: unable to handle kernel NULL pointer dereference at (null)
[ 819.770435] IP: [<ffffffff813381c0>] skip_spaces+0x30/0x30
[ 819.770572] PGD 3efd90067 PUD 3eff61067 PMD 0
[ 819.770716] Oops: 0000 [#1] SMP
[ 819.770829] Modules linked in: arc4 iwldvm mac80211 x86_pkg_temp_thermal coretemp kvm_intel joydev i915 kvm uvcvideo ghash_clmulni_intel videobuf2_vmalloc aesni_intel videobuf2_memops videobuf2_core aes_x86_64 ablk_helper cryptd videodev iwlwifi lrw rfcomm gf128mul glue_helper bnep btusb media bluetooth parport_pc hid_generic ppdev snd_hda_codec_hdmi drm_kms_helper snd_hda_codec_realtek cfg80211 drm tpm_infineon samsung_laptop snd_hda_intel usbhid snd_hda_codec hid snd_hwdep snd_pcm microcode snd_page_alloc snd_timer psmouse i2c_algo_bit lpc_ich tpm_tis video wmi mac_hid serio_raw ext2 lp parport r8169 mii
[ 819.771802] CPU: 0 PID: 2167 Comm: bash Not tainted 3.12.0+ #25
[ 819.771876] Hardware name: SAMSUNG ELECTRONICS CO., LTD. 900X3C/900X3D/900X4C/900X4D/SAMSUNG_NP1234567890, BIOS P03AAC 07/12/2012
[ 819.772022] task: ffff88002e6ddcc0 ti: ffff8804015ca000 task.ti: ffff8804015ca000
[ 819.772119] RIP: 0010:[<ffffffff813381c0>] [<ffffffff813381c0>] skip_spaces+0x30/0x30
[ 819.772242] RSP: 0018:ffff8804015cbc70 EFLAGS: 00010046
[ 819.772310] RAX: 0000000000000003 RBX: ffff88040cfd6d40 RCX: 0000000000000018
[ 819.772397] RDX: 0000000000020001 RSI: 0000000000000000 RDI: 0000000000000000
[ 819.772484] RBP: ffff8804015cbcc0 R08: 0000000000000000 R09: ffff8803f0768d40
[ 819.772570] R10: ffffea001033b800 R11: 0000000000000000 R12: ffffffff81c519c0
[ 819.772656] R13: 0000000000020001 R14: 0000000000000000 R15: 0000000000020001
[ 819.772744] FS: 00007ff98309b740(0000) GS:ffff88041f200000(0000) knlGS:0000000000000000
[ 819.772845] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 819.772917] CR2: 0000000000000000 CR3: 00000003f59dc000 CR4: 00000000001407f0
[ 819.773001] Stack:
[ 819.773030] ffffffff81114003 ffff8804015cbcb0 0000000000000000 0000000000000046
[ 819.773146] ffff880409757a18 ffff8803f065a160 0000000000000000 0000000000020001
[ 819.773273] 0000000000000000 0000000000000000 ffff8804015cbce8 ffffffff8143e388
[ 819.773387] Call Trace:
[ 819.773434] [<ffffffff81114003>] ? ftrace_raw_event_wakeup_source+0x43/0xe0
[ 819.773520] [<ffffffff8143e388>] wakeup_source_report_event+0xb8/0xd0
[ 819.773595] [<ffffffff8143e3cd>] __pm_stay_awake+0x2d/0x50
[ 819.773724] [<ffffffff8153395c>] power_supply_changed+0x3c/0x90
[ 819.773795] [<ffffffff8153407c>] power_supply_register+0x18c/0x250
[ 819.773869] [<ffffffff813d8d18>] sysfs_add_battery+0x61/0x7b
[ 819.773935] [<ffffffff813d8d69>] battery_notify+0x37/0x3f
[ 819.774001] [<ffffffff816ccb7c>] notifier_call_chain+0x4c/0x70
[ 819.774071] [<ffffffff81073ded>] __blocking_notifier_call_chain+0x4d/0x70
[ 819.774149] [<ffffffff81073e26>] blocking_notifier_call_chain+0x16/0x20
[ 819.774227] [<ffffffff8109397a>] pm_notifier_call_chain+0x1a/0x40
[ 819.774316] [<ffffffff81095b66>] hibernate+0x66/0x1c0
[ 819.774407] [<ffffffff81093931>] state_store+0x71/0xa0
[ 819.774507] [<ffffffff81331d8f>] kobj_attr_store+0xf/0x20
[ 819.774613] [<ffffffff811f8618>] sysfs_write_file+0x128/0x1c0
[ 819.774735] [<ffffffff8118579d>] vfs_write+0xbd/0x1e0
[ 819.774841] [<ffffffff811861d9>] SyS_write+0x49/0xa0
[ 819.774939] [<ffffffff816d1052>] system_call_fastpath+0x16/0x1b
[ 819.775055] Code: 89 f8 48 89 e5 f6 82 c0 a6 84 81 20 74 15 0f 1f 44 00 00 48 83 c0 01 0f b6 10 f6 82 c0 a6 84 81 20 75 f0 5d c3 66 0f 1f 44 00 00 <80> 3f 00 55 48 89 e5 74 15 48 89 f8 0f 1f 40 00 48 83 c0 01 80
[ 819.775760] RIP [<ffffffff813381c0>] skip_spaces+0x30/0x30
[ 819.775881] RSP <ffff8804015cbc70>
[ 819.775949] CR2: 0000000000000000
[ 819.794175] ---[ end trace c4ef25127039952e ]---
Signed-off-by: Shuah Khan <shuah.kh@samsung.com>
Acked-by: Anton Vorontsov <anton@enomsg.org>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Cc: stable@vger.kernel.org
This patch, originally authored by Arve Hjonnevag and Todd Poynor,
prevents the system from entering suspend mode until the power supply
plug, unplug, or any other change of state event is fully processed. This
guarantees that the screen lights up and displays the battery charging
state. The implementation uses the power supply wakeup_source object.
Cc: Arve Hjonnevag <arve@android.com>
Cc: Todd Poynor <toddpoynor@google.com>
Cc: John Stultz <john.stultz@linaro.org>
Signed-off-by: Zoran Markovic <zoran.markovic@linaro.org>
of_parse_phandle increments the refcount for a dt node before returning
it. Add of_node_put where needed to properly decrement the refcount when
we are done using a given node.
Signed-off-by: Rhyland Klein <rklein@nvidia.com>
With this patch the power_supply_core will try to populate supplied_from
hierarchy from the device tree.
This patch adds support for supplies to register a list of char *'s which
represent the list of supplies which supply them. This is the opposite as
the supplied_to list.
This change maintains support for supplied_to until all drivers which make
use of it already are converted.
All in-kernel users of class_find_device() don't really need mutable
data for match callback.
In two places (kernel/power/suspend_test.c, drivers/scsi/osd/osd_uld.c)
this patch changes match callbacks to use const search data.
The const is propagated to rtc_class_open() and power_supply_get_by_name()
parameters.
Note that there's a dev reference leak in suspend_test.c that's not
touched in this patch.
Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl>
Pull battery subsystem updates from Anton Vorontsov:
"Highlights:
- Two new drivers from Pali Rohár and N900 hackers: rx51_battery and
bq2415x_charger. The drivers are a part of a solution to replace
the proprietary Nokia BME stack
- Power supply core now registers devices with a thermal cooling
subsystem, so we can now automatically throttle charging. Thanks
to Ramakrishna Pallala!
- Device tree support for ab8500 and max8925_power drivers
- Random fixups and enhancements for a bunch of drivers."
* tag 'for-v3.8-merged' of git://git.infradead.org/battery-2.6: (22 commits)
max8925_power: Add support for device-tree initialization
ab8500: Add devicetree support for chargalg
ab8500: Add devicetree support for charger
ab8500: Add devicetree support for btemp
ab8500: Add devicetree support for fuelgauge
twl4030_charger: Change TWL4030_MODULE_* ids to TWL_MODULE_*
jz4740-battery: Use devm_request_and_ioremap
jz4740-battery: Use devm_kzalloc
bq27x00_battery: Fixup nominal available capacity reporting
bq2415x_charger: Fix style issues
bq2415x_charger: Add Kconfig/Makefile entries
power_supply: Add bq2415x charger driver
power_supply: Add new Nokia RX-51 (N900) power supply battery driver
max17042_battery: Fix missing verify_model_lock() return value check
ds2782_battery: Fix signedness bug in ds278x_read_reg16()
lp8788-charger: Fix ADC channel names
lp8788-charger: Fix wrong ADC conversion
lp8788-charger: Use consumer device name on setting IIO channels
power_supply: Register power supply for thermal cooling device
power_supply: Add support for CHARGE_CONTROL_* attributes
This patch registers the power supply as a cooling device if the power
supply has support for charge throttling.
Now with this change low level drivers need not register with thermal
framework as it is automatically done by power supply framework.
Signed-off-by: Ramakrishna Pallala <ramakrishna.pallala@intel.com>
Signed-off-by: Anton Vorontsov <anton.vorontsov@linaro.org>
This patch adds the thermal zone parameter as an argument to
the tzd_register() function call; and updates other drivers
using this function.
Signed-off-by: Durgadoss R <durgadoss.r@intel.com>
Remove tc1/tc2 in generic thermal layer.
.get_trend() callback starts to take effect from this patch.
Reviewed-by: Rafael J. Wysocki <rjw@sisk.pl>
Reviewed-by: Valentin, Eduardo <eduardo.valentin@ti.com>
This merge is performed to take commit c56f5c0342dfee11a1 ("Thermal: Make
Thermal trip points writeable") out of Linus' tree and then fixup power
supply class. This is needed since thermal stuff added a new argument:
CC drivers/power/power_supply_core.o
drivers/power/power_supply_core.c: In function ‘psy_register_thermal’:
drivers/power/power_supply_core.c:204:6: warning: passing argument 3 of ‘thermal_zone_device_register’ makes integer from pointer without a cast [enabled by default]
include/linux/thermal.h:154:29: note: expected ‘int’ but argument is of type ‘struct power_supply *’
drivers/power/power_supply_core.c:204:6: error: too few arguments to function ‘thermal_zone_device_register’
include/linux/thermal.h:154:29: note: declared here
make[1]: *** [drivers/power/power_supply_core.o] Error 1
make: *** [drivers/power/] Error 2
Battery and charger contribute to Thermals in most of the embedded
devices. So, it makes sense to identify them as Thermal zones in a
particular platform.
This patch registers a thermal zone if the power supply is reporting
a temperature property. The thermal zone will be used by platform's
thermal management solution.
Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
The function is not exported to modules, plus we do want to catch anyone
who tries to create complex hierarchy (in that case we'd need to change
'powers' symlink to a directory, probably under a different name to not
break ABI).
This patch fixes the following build error:
ERROR: "sysfs_create_link_nowarn" [drivers/power/power_supply.ko] undefined!
If no power class device is found in power_supply_is_system_supplied(),
the function currently returns 0, which basically means that the system
is supposed to be running on battery. In practice, mobile devices tend
to always implement at least one power class device and more often two
(battery and AC adapter). Systems with no registered power class
devices are more likely to be desktop systems, where the system is
always powered by mains.
So, change the default return value of
power_supply_is_system_supplied() from 0 (running on battery) to 1
(running on mains.)
Signed-off-by: Jean Delvare <jdelvare@suse.de>
Cc: Matthew Garrett <mjg59@srcf.ucam.org>
Cc: Alex Deucher <alexander.deucher@amd.com>
If a power supply has a scope of "Device", then allow the power supply
to indicate what device it actually powers. This is represented in the
power supply's sysfs directory as a symlink named "powers", which points to
the sysfs directory of the powered device.
If the device has children, then the sub-devices are also powered by
the same power supply.
Signed-off-by: Jeremy Fitzhardinge <jeremy@goop.org>
Cc: Richard Hughes <richard@hughsie.com>
Calling device_add causes an inital uevent for that device to be generated.
The power_supply uevent function calls the drivers get_property function,
which might causes the driver to update its state, which again might
causes the driver to call power_supply_changed(). Since the power_supplys
changed_work has not been initialized at this point the behavior is
undefined and can result in an OOPS.
This patch fixes the issue by initializing the power_supplys changed_work
prior to adding the power_supplys device to the device tree.
Reported-by: Grazvydas Ignotas <notasas@gmail.com>
Tested-by: Grazvydas Ignotas <notasas@gmail.com>
flush_scheduled_work() is deprecated and scheduled to be removed.
In battery drivers, the work can be canceled on probe failure and
removal and should be flushed on suspend. Replace
flush_scheduled_work() usages with direct cancels and flushes.
device_unregister() might free its argument. This leads to freed
memory use in kfree(). Also use put_device() instead of kfree()
as dev may be already used in another layer after call to device_add().
Signed-off-by: Vasiliy Kulikov <segoon@openwall.com>
This fixes a race between power supply device and initial
attributes creation, plus makes it possible to implement
writable properties.
[Daniel Mack - removed superflous return statement
and dropped .mode attribute from POWER_SUPPLY_ATTR]
Suggested-by: Greg KH <gregkh@suse.de>
Suggested-by: Kay Sievers <kay.sievers@vrfy.org>
Tested-by: Daniel Mack <daniel@caiaq.de>
This adds a function that indicates that a battery is fully charged.
It also includes functions to get a power_supply device from the class
of registered devices by name reference. These can be used to find a
specific battery to call power_supply_set_battery_charged() on.
Some battery drivers might need this information to calibrate
themselves.
Signed-off-by: Daniel Mack <daniel@caiaq.de>
Cc: Ian Molton <spyro@f2s.com>
Cc: Anton Vorontsov <cbou@mail.ru>
Cc: Matt Reimer <mreimer@vpop.net>
While I'm at it, cleanup the power supply code so that EXPORT_SYMBOL_GPL
appears directly after the symbole declaration. checkpatch.pl wants it
that way.
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6
drivers/power/Makefile
