This moves all power supply drivers from drivers/power/
to drivers/power/supply/. The intention is a cleaner
source tree, since drivers/power/ also contains frameworks
unrelated to power supply, like adaptive voltage scaling.
Signed-off-by: Sebastian Reichel <sre@kernel.org>
power_supply_get_property() should ideally return -EAGAIN if it is
called while the power_supply is being registered. There was no way
previously to determine if use_cnt == 0 meant that the power_supply
wasn't fully registered yet, or if it had already been unregistered.
Add a new boolean to the power_supply struct to simply show if
registration is completed. Lastly, modify the check in
power_supply_show_property() to also ignore -EAGAIN when so it
doesn't complain about not returning the property.
Signed-off-by: Rhyland Klein <rklein@nvidia.com>
This adds power supply types for USB chargers defined in
the USB Type-C Specification 1.1 and in the
USB Power Delivery Specification Revision 2.0 V1.1.
The following are added :
POWER_SUPPLY_TYPE_USB_TYPE_C, /* Type C Port */
POWER_SUPPLY_TYPE_USB_PD, /* Power Delivery Port */
POWER_SUPPLY_TYPE_USB_PD_DRP, /* PD Dual Role Port */
Signed-off-by: Benson Leung <bleung@chromium.org>
[tomeu: remove the mention to Type C from the comments]
Signed-off-by: Tomeu Vizoso <tomeu.vizoso@collabora.com>
Reviewed-by: Alec Berg <alecaberg@chromium.org>
Reviewed-by: Vincent Palatin <vpalatin@chromium.org>
Reviewed-by: Todd Broch <tbroch@chromium.org>
The fix for NULL pointer exception related to calling uevent for not
finished probe caused to set all writeable properties as non-writeable.
This was caused by checking if property is writeable before the initial
increase of power supply usage counter and in the same time using
wrapper over property_is_writeable(). The wrapper returns ENODEV if the
usage counter is still 0.
The call trace looked like:
device probe:
power_supply_register()
use_cnt = 0;
device_add()
create sysfs entries
power_supply_attr_is_visible()
power_supply_property_is_writeable()
if (use_cnt == 0) return -ENODEV;
use_cnt++;
Replace the usage of wrapper with direct call to property_is_writeable()
from driver. This should be safe call during device probe because
implementations of this callback just return 0/1 for different
properties and they do not access any of the driver's internal data.
Fixes: 8e59c7f23410 ("power_supply: Fix NULL pointer dereference during bq27x00_battery probe")
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Use wrappers over get_property() and set_property() internally in power
supply and for sysfs interface. The wrappers provide safe access if
power supply is not yet registered or t is being destroyed.
In case of syfs the theoretical race could happen between ending of
driver's probe and parallel sysfs access:
some_driver_probe() userspace
drv->psy = power_supply_register()
device_add()
sysfs entries are created
atomic_inc(&psy->use_cnt);
store on sysfs attributes
drv->set_property()
dereference of drv->psy
drv->psy = returned psy;
For leds the race could happen between power supply being destroyed and
ongoing power_supply_changed_work().
Change the ownership of power_supply structure from each driver
implementing the class to the power supply core.
The patch changes power_supply_register() function thus all drivers
implementing power supply class are adjusted.
Each driver provides the implementation of power supply. However it
should not be the owner of power supply class instance because it is
exposed by core to other subsystems with power_supply_get_by_name().
These other subsystems have no knowledge when the driver will unregister
the power supply. This leads to several issues when driver is unbound -
mostly because user of power supply accesses freed memory.
Instead let the core own the instance of struct 'power_supply'. Other
users of this power supply will still access valid memory because it
will be freed when device reference count reaches 0. Currently this
means "it will leak" but power_supply_put() call in next patches will
solve it.
This solves invalid memory references in following race condition
scenario:
Thread 1: charger manager
Thread 2: power supply driver, used by charger manager
THREAD 1 (charger manager) THREAD 2 (power supply driver)
psy = power_supply_get_by_name()
Driver unbind, .remove
power_supply_unregister()
Device fully removed
psy->get_property()
The 'get_property' call is executed in invalid context because the driver was
unbound and struct 'power_supply' memory was freed.
This could be observed easily with charger manager driver (here compiled
with max17040 fuel gauge):
$ cat /sys/devices/virtual/power_supply/cm-battery/capacity &
$ echo "1-0036" > /sys/bus/i2c/drivers/max17040/unbind
[ 55.725123] Unable to handle kernel NULL pointer dereference at virtual address 00000000
[ 55.732584] pgd = d98d4000
[ 55.734060] [00000000] *pgd=5afa2831, *pte=00000000, *ppte=00000000
[ 55.740318] Internal error: Oops: 80000007 [#1] PREEMPT SMP ARM
[ 55.746210] Modules linked in:
[ 55.749259] CPU: 1 PID: 2936 Comm: cat Tainted: G W 3.19.0-rc1-next-20141226-00048-gf79f475f3c44-dirty #1496
[ 55.760190] Hardware name: SAMSUNG EXYNOS (Flattened Device Tree)
[ 55.766270] task: d9b76f00 ti: daf54000 task.ti: daf54000
[ 55.771647] PC is at 0x0
[ 55.774182] LR is at charger_get_property+0x2f4/0x36c
[ 55.779201] pc : [<00000000>] lr : [<c034b0b4>] psr: 60000013
[ 55.779201] sp : daf55e90 ip : 00000003 fp : 00000000
[ 55.790657] r10: 00000000 r9 : c06e2878 r8 : d9b26c68
[ 55.795865] r7 : dad81610 r6 : daec7410 r5 : daf55ebc r4 : 00000000
[ 55.802367] r3 : 00000000 r2 : daf55ebc r1 : 0000002a r0 : d9b26c68
[ 55.808879] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 55.815994] Control: 10c5387d Table: 598d406a DAC: 00000015
[ 55.821723] Process cat (pid: 2936, stack limit = 0xdaf54210)
[ 55.827451] Stack: (0xdaf55e90 to 0xdaf56000)
[ 55.831795] 5e80: 60000013 c01459c4 0000002a c06f8ef8
[ 55.839956] 5ea0: db651000 c06f8ef8 daebac00 c04cb668 daebac08 c0346864 00000000 c01459c4
[ 55.848115] 5ec0: d99eaa80 c06f8ef8 00000fff 00001000 db651000 c027f25c c027f240 d99eaa80
[ 55.856274] 5ee0: d9a06c00 c0146218 daf55f18 00001000 d99eaa80 db4c18c0 00000001 00000001
[ 55.864468] 5f00: daf55f80 c0144c78 c0144c54 c0107f90 00015000 d99eaab0 00000000 00000000
[ 55.872603] 5f20: 000051c7 00000000 db4c18c0 c04a9370 00015000 00001000 daf55f80 00001000
[ 55.880763] 5f40: daf54000 00015000 00000000 c00e53dc db4c18c0 c00e548c 0000000d 00008124
[ 55.888937] 5f60: 00000001 00000000 00000000 db4c18c0 db4c18c0 00001000 00015000 c00e5550
[ 55.897099] 5f80: 00000000 00000000 00001000 00001000 00015000 00000003 00000003 c000f364
[ 55.905239] 5fa0: 00000000 c000f1a0 00001000 00015000 00000003 00015000 00001000 0001333c
[ 55.913399] 5fc0: 00001000 00015000 00000003 00000003 00000002 00000000 00000000 00000000
[ 55.921560] 5fe0: 7fffe000 be999850 0000a225 b6f3c19c 60000010 00000003 00000000 00000000
[ 55.929744] [<c034b0b4>] (charger_get_property) from [<c0346864>] (power_supply_show_property+0x48/0x20c)
[ 55.939286] [<c0346864>] (power_supply_show_property) from [<c027f25c>] (dev_attr_show+0x1c/0x48)
[ 55.948130] [<c027f25c>] (dev_attr_show) from [<c0146218>] (sysfs_kf_seq_show+0x84/0x104)
[ 55.956298] [<c0146218>] (sysfs_kf_seq_show) from [<c0144c78>] (kernfs_seq_show+0x24/0x28)
[ 55.964536] [<c0144c78>] (kernfs_seq_show) from [<c0107f90>] (seq_read+0x1b0/0x484)
[ 55.972172] [<c0107f90>] (seq_read) from [<c00e53dc>] (__vfs_read+0x18/0x4c)
[ 55.979188] [<c00e53dc>] (__vfs_read) from [<c00e548c>] (vfs_read+0x7c/0x100)
[ 55.986304] [<c00e548c>] (vfs_read) from [<c00e5550>] (SyS_read+0x40/0x8c)
[ 55.993164] [<c00e5550>] (SyS_read) from [<c000f1a0>] (ret_fast_syscall+0x0/0x48)
[ 56.000626] Code: bad PC value
[ 56.011652] ---[ end trace 7b64343fbdae8ef1 ]---
Reviewed-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
[for the nvec part]
Reviewed-by: Marc Dietrich <marvin24@gmx.de>
[for compal-laptop.c]
Acked-by: Darren Hart <dvhart@linux.intel.com>
[for the mfd part]
Acked-by: Lee Jones <lee.jones@linaro.org>
[for the hid part]
Acked-by: Jiri Kosina <jkosina@suse.cz>
[for the acpi part]
Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
Replace direct calls to power supply function attributes with wrappers.
Wrappers provide safe access in case of unregistering the power
supply (e.g. by removing the driver). Replace:
- get_property -> power_supply_get_property
- set_property -> power_supply_set_property
- property_is_writeable -> power_supply_property_is_writeable
Acked-by: Jonghwa Lee <jonghwa3.lee@samsung.com>
Acked-by: Pavel Machek <pavel@ucw.cz>
Reviewed-by: Sebastian Reichel <sre@kernel.org>
In power_supply_show_property() routine, we call ->get_property() conditionally
and should check for failure in that case only. There is no point comparing
'ret' for errors when 'ret' is surely zero.
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
Usually PMIC's come with coulomb counting mechanism which can be
used to implement a Fuel Gauginig solution in Software itself.
One of key input to these SW Fuel Gauge solutioons is the boot up
parameters like boot voltage and boot current.
This patch adds the VOLTAGE_BOOT and CURRENT_BOOT power supply attributes
to report bootup voltage and current.
This patch also adds CALIBRATE power supply attribute which useful is
for calibrating the battery/coulomb counter.
Signed-off-by: Ramakrishna Pallala <ramakrishna.pallala@intel.com>
Add new power supply properties for input current, charge termination
current, min and max temperature
POWER_SUPPLY_PROP_TEMP_MIN - minimum operatable temperature
POWER_SUPPLY_PROP_TEMP_MAX - maximum operatable temperature
POWER_SUPPLY_PROP_INPUT_CURRENT_LIMIT - input current limit programmed
by charger. Indicates the input current for a charging source.
POWER_SUPPLY_PROP_CHARGE_TERM_CURRENT - Charge termination current used
to detect the end of charge condition
Signed-off-by: Jenny TC <jenny.tc@intel.com>
The usage of strict_strtol() is not preferred, because strict_strtol() is
obsolete. Thus, kstrtol() should be used.
Signed-off-by: Jingoo Han <jg1.han@samsung.com>
Signed-off-by: Anton Vorontsov <anton@enomsg.org>
As most of the charger chips come with two kinds of safety features
related to timing:
1. Watchdog Timer (interms of seconds/mins)
2. Safety Timer (interms of hours)
This patch adds these to fault causes in POWER_SUPPLY_PROP_HEALTH_* enums
so that whenever there is either watchdog timeout or safety timer timeout
driver could notify the user space accurately about the fault and will
also be helpful for debug.
Add support for power supply attributes CHARGE_CONTROL_LIMIT
and CHARGE_CONTROL_LIMIT_MAX.
These new attributes will enable the user space to implement
custom charging algorithms based on platform state.
Signed-off-by: Anton Vorontsov <anton.vorontsov@linaro.org>
There are different types of chargers avalibale like AC, Solar, USB,
etc.. Even in USB we have different types SDP/DCP/CDP/ACA and all these
chargers have different o/p ratings. For example SDP supports only 500mA
of charge current whereas AC charger can support upto 8A or more.
Similarly batteries also come with charge current and voltage ratings
and these ratings vary depending on its capacity and the technology
used.
This patch adds two new power supply properties
CONSTANT_CHARGE_CURRENT_MAX and CONSTANT_CHARGE_CURRENT_MAX.
It is possible that users can use non-standard chargers or use invalid
batteries especially with mobile devices.
This patch adds a new power supply property called 'AUTHENTIC' to
indicate this to the user(user space).
Minimum and maximum alerts on power supply properties will help or allow
the user space to "proactively" create policies like connect/disconnect
charger or stop/start the user apps based on capacity or temperature
parameters.
These parameters can be used to avoid unnecessary polling from user space
and even from kernel space if the underlying HW can support INT triggers
(ex: max17042/47).
This patch adds the following power supply alert type properties:
CAPACITY_ALERT_MIN
CAPACITY_ALERT_MAX
TEMP_ALERT_MIN
TEMP_ALERT_MAX
TEMP_AMBIENT_ALERT_MIN
TEMP_AMBIENT_ALERT_MAX
Constant Charge Current(CC) is charging parameter which limit the
maximum current which can be pumped into the battery during charge cycle.
Constant Charge Voltage(CV) is also charging parameter which limit the
maximum voltage that battery can reach during charge cycle.
It is very common practice that at low or high temperatures we
do not charge the batteries upto it's fullest charge voltage
to avoid battery and user safety issues.
These sysfs properties will be useful for debug and to implement
certain user space policies like "Charging limited due to OverTemp".
Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
This adds a new sysfs file called 'voltage_ocv' which gives the
Open Circuit Voltage of the battery.
This property can be used for platform shutdown policies and
can be useful for initial capacity estimations.
Note: This patch is generated against linux-next branch.
For files that are actively using linux/device.h, make sure
that they call it out. This will allow us to clean up some
of the implicit uses of linux/device.h within include/*
without introducing build regressions.
Yes, this was created by "cheating" -- i.e. the headers were
cleaned up, and then the fallout was found and fixed, and then
the two commits were reordered. This ensures we don't introduce
build regressions into the git history.
* git://git.infradead.org/battery-2.6: (68 commits)
power_supply: Mark da9052 driver as broken
power_supply: Drop usage of nowarn variant of sysfs_create_link()
s3c_adc_battery: Average over more than one adc sample
power_supply: Add DA9052 battery driver
isp1704_charger: Fix missing check
jz4740-battery: Fix signedness bug
power_supply: Assume mains power by default
sbs-battery: Fix devicetree match table
ARM: rx51: Add bq27200 i2c board info
sbs-battery: Change power supply name
devicetree-bindings: Propagate bq20z75->sbs rename to dt bindings
devicetree-bindings: Add vendor entry for Smart Battery Systems
sbs-battery: Rename internals to new name
bq20z75: Rename to sbs-battery
wm97xx_battery: Use DEFINE_MUTEX() for work_lock
max8997_charger: Remove duplicate module.h
lp8727_charger: Some minor fixes for the header
lp8727_charger: Add header file
power_supply: Convert drivers/power/* to use module_platform_driver()
power_supply: Add "unknown" in power supply type
git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen
For the default value of power supply type, "unknown" is added.
With default prop value, supply type property can be displayed
as default - "Unknown".
Signed-off-by: Milo(Woogyom) Kim <milo.kim@ti.com>
This adds a "scope" attribute to a power_supply, which indicates how
much of the system it powers. It appears in sysfs as "scope" or in
the uevent file as POWER_SUPPLY_SCOPE=. There are presently three
possible values:
Unknown - unknown power topology
System - the power supply powers the whole system
Device - it powers a specific device, or tree of devices
A power supply which doesn't have a "scope" attribute should be assumed to
have "System" scope.
In general, usermode should assume that loss of all System-scoped power
supplies will power off the whole system, but any single one is sufficient
to power the system.
Signed-off-by: Jeremy Fitzhardinge <jeremy@goop.org>
Cc: Richard Hughes <richard@hughsie.com>
It was actually getting this before by a tangled mess of implict
includes that is going to be cleaned up. Fix it now, so we don't
get this after the cleanup.
power_supply_sysfs.c: In function ‘power_supply_attr_is_visible’:
power_supply_sysfs.c:184: error: ‘S_IRUSR’ undeclared (first use in this function)
power_supply_sysfs.c:184: error: (Each undeclared identifier is reported only once
power_supply_sysfs.c:184: error: for each function it appears in.)
power_supply_sysfs.c:184: error: ‘S_IRGRP’ undeclared (first use in this function)
power_supply_sysfs.c:184: error: ‘S_IROTH’ undeclared (first use in this function)
power_supply_sysfs.c:196: error: ‘S_IWUSR’ undeclared (first use in this function)
make[3]: *** [drivers/power/power_supply_sysfs.o] Error 1
Fix format warning:
drivers/power/power_supply_sysfs.c:82: warning: format '%d' expects type 'int', but argument 4 has type 'ssize_t'
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
Don't tell the system about the battery charger if it's not enabled, we
can reasonably assume that if the charger is not enabled then no battery
will ever be connected so reporting state is at best going to waste time
and at worst going to cause confusing information in the UI.
For simplicity and robustness we continue to register and handle interrupts
from the charger.
Sometimes a driver can not report a meaningful value for a certain property
and returns -ENODATA.
Currently when generating a uevent and a property return -ENODATA it is
treated as an error an no uevent is generated at all. This is not an
desirable behavior.
This patch adds a special case for -ENODATA and ignores properties which
return this error code when generating the uevent.
Tested-by: Grazvydas Ignotas <notasas@gmail.com>
USB only gives the maximum current allowed to draw.
Signed-off-by: Heikki Krogerus <ext-heikki.krogerus@nokia.com>
Battery Charging Specification 1.1.
Commit 5f487cd34f4337f9bc27ca19da72a39d1b0a0ab4 (power_supply: Use
attribute groups) causes a regression the power supply core does not
export the 'type' attribute anymore.
POWER_SUPPLY_PROP_TYPE is handled by the power supply core without the
low-level driver, so power_supply_attr_is_visible() must always return
the entry as readable.
Reported-by: Rafael J. Wysocki <rjw@sisk.pl>
Signed-off-by: Daniel Mack <daniel@caiaq.de>
Tested-by: Rafael J. Wysocki <rjw@sisk.pl>
This patch adds support for writeable power supply properties and
exposes them as writeable to sysfs.
A power supply implementation must implement two new function calls in
order to use that feature:
int set_property(struct power_supply *psy,
enum power_supply_property psp,
const union power_supply_propval *val);
int property_is_writeable(struct power_supply *psy,
enum power_supply_property psp);
Cc: Alexey Starikovskiy <astarikovskiy@suse.de>
Cc: Len Brown <len.brown@intel.com>
Cc: Mark Brown <broonie@opensource.wolfsonmicro.com>
Cc: Matt Reimer <mreimer@vpop.net>
Cc: Evgeniy Polyakov <zbr@ioremap.net>
Cc: Tejun Heo <tj@kernel.org>
This fixes a race between power supply device and initial
attributes creation, plus makes it possible to implement
writable properties.
[Daniel Mack - removed superflous return statement
and dropped .mode attribute from POWER_SUPPLY_ATTR]
Suggested-by: Greg KH <gregkh@suse.de>
Suggested-by: Kay Sievers <kay.sievers@vrfy.org>
Tested-by: Daniel Mack <daniel@caiaq.de>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Signed-off-by: Alexey Starikovskiy <astarikovskiy@suse.de>
Signed-off-by: Len Brown <len.brown@intel.com>
There are cases when some device can not report any meaningful value,
e.g. TWL4030 charger can report voltage only when charging is
active.
In these cases drivers will return -ENODATA, and we shouldn't flood
kernel log with error messages.
Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com>
This adds a new sysfs file called 'charge_type' which displays the
type of charging (unknown, n/a, trickle charge, or fast charging).
This allows things like battery diagnostics to determine what the
battery/EC is doing without resorting to changing the 'status' sysfs
output.
Signed-off-by: Andres Salomon <dilinger@collabora.co.uk>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
This reverts commit 8efe444038a205e79b38b7ad03878824901849a8 and
4cbc76eadf56399cd11fb736b33c53aec9caab8c.
Richard@laptop.org was apparently using CAPACITY_LEVEL for debugging
battery/EC problems, and was upset that it was removed. This readds it.
Documentation/power_supply_class.txt
ACPI has smart batteries, which work in units of energy and measure
rate of (dis)charge as power, thus it is not appropriate to export it
as a current_now. Current_now will still be exported to allow
for userland applications to match.
Some systems are able to report problems with batteries being under
temperature.
Acked-by: Anton Vorontsov <cbouatmailru@gmail.com>
Signed-off-by: Samuel Ortiz <sameo@openedhand.com>
Tejun's commit 7b595756ec1f49e0049a9e01a1298d53a7faaa15 made sysfs
attribute->owner unnecessary. But the field was left in the structure to
ease the merge. It's been over a year since that change and it is now
time to start killing attribute->owner along with its users - one arch at
a time!
This patch is attempt #1 to get rid of attribute->owner only for
CONFIG_X86_64 or CONFIG_X86_32 . We will deal with other arches later on
as and when possible - avr32 will be the next since that is something I
can test. Compile (make allyesconfig / make allmodconfig / custom config)
and boot tested.
akpm: the idea is that we put the declaration of sttribute.owner inside
`#ifndef CONFIG_X86'. But that proved to be too ambitious for now because
new usages kept on turning up in subsystem trees.
[akpm: remove the ifdef for now]
Signed-off-by: Parag Warudkar <parag.lkml@gmail.com>
Cc: Greg KH <greg@kroah.com>
Cc: Tejun Heo <htejun@gmail.com>
Cc: Len Brown <lenb@kernel.org>
Cc: Jens Axboe <jens.axboe@oracle.com>
Cc: Jean Delvare <khali@linux-fr.org>
Cc: Roland Dreier <rolandd@cisco.com>
Cc: David Brownell <david-b@pacbell.net>
Cc: Alessandro Zummo <a.zummo@towertech.it>
drivers/power/Kconfig
drivers/power/Makefile
Commit 54d29ad33e3483bcc7ca433a21cf294854e5154a (Power Supply: fix race
in device_create) introduced a race in power_supply_uevent. Previously it
checked that power_supply is available by checking for dev->driver_data.
But now dev->driver_data is set before power_supply->dev is initialised.
Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com>
This adds PROP_CHARGE_COUNTER to the power supply class (documenting it
as well). The OLPC battery driver uses this for spitting out its ACR
values (in uAh). We have some rounding errors (the data sheet claims
416.7, the math actually works out to 416.666667, so we're forced to
choose between overflows or precision loss. I chose precision loss,
and stuck w/ data sheet values), but I don't think anyone will care
that much.
Signed-off-by: Andres Salomon <dilinger@debian.org>
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (112 commits)
ACPI: fix build warning
Revert "cpuidle: build fix for non-x86"
ACPI: update intrd DSDT override console messages
ACPI: update DSDT override documentation
ACPI: Add "acpi_no_initrd_override" kernel parameter
ACPI: its a directory not a folder....
ACPI: misc cleanups
ACPI: add missing prink prefix strings
ACPI: cleanup acpi.h
ACPICA: fix CONFIG_ACPI_DEBUG_FUNC_TRACE build
ACPI: video: Ignore ACPI video devices that aren't present in hardware
ACPI: video: reset brightness on resume
ACPI: video: call ACPI notifier chain for ACPI video notifications
ACPI: create notifier chain to get hotkey events to graphics driver
ACPI: video: delete unused display switch on hotkey event code
ACPI: video: create "brightness_switch_enabled" modparam
cpuidle: Add a poll_idle method
ACPI: cpuidle: Support C1 idle time accounting
ACPI: enable MWAIT for C1 idle
ACPI: idle: Fix acpi_safe_halt usages and interrupt enabling/disabling
This commit:
Author: Andres Salomon <dilinger@queued.net>
Date: Wed Dec 12 14:12:56 2007 -0500
power: remove POWER_SUPPLY_PROP_CAPACITY_LEVEL
Removed CAPACITY_LEVEL from every other code, leaving the array with sysfs
attributes with one more entry than the number of enums in power_supply.h.
This leads to some attributes containing the value of the attribute right
after it. For example, temp_ambient would have the value of
time_to_empty_now. In my case, I had time_to_full_avg have the value which
should be in model_name, when the former was usually empty.
Cc: Andres Salomon <dilinger@debian.org>
egrep serial /proc/acpi/battery/BAT0/info
serial number: 32090
serial number can tell you from the imminent danger
of beeing set on fire.
Signed-off-by: maximilian attems <max@stro.at>
Acked-by: Alexey Starikovskiy <astarikovskiy@suse.de>
Add LiMn (one of the most common for small non-rechargable batteries)
battery technology and voltage_min/_max properties support.
Signed-off-by: Anton Vorontsov <cbou@mail.ru>
In power_supply_create_attrs(), we create static attributes as referenced
by power_supply_static_attrs[i]. After that, if we fail, we unregister
via power_supply_static_attrs[psy->properties[i]]. This is incorrect, as
psy->properties has absolutely no bearing on static attribs. This patch
fixes it to unregister the correct attrib.
Another line which was unnecessarily line wrapped is also unwrapped.
The CAPACITY_LEVEL stuff defines various levels of charge; however, what
is the difference between them? What differentiates between HIGH and NORMAL,
LOW and CRITICAL, etc?
As it appears that these are fairly arbitrary, we end up making such policy
decisions in the kernel (or in hardware). This is the sort of decision that
should be made in userspace, not in the kernel.
If the hardware does not support _CAPACITY and it cannot be easily calculated,
then perhaps the driver should register a custom CAPACITY_LEVEL attribute;
however, userspace should not become accustomed to looking for such a thing,
and we should certainly not encourage drivers to provide CAPACITY_LEVEL
stubs.
The following removes support for POWER_SUPPLY_PROP_CAPACITY_LEVEL. The
OLPC battery driver is the only driver making use of this, so it's
removed from there as well.
