2011-08-19 | s3c-adc-battery: Fix compilation error due to missing header (module.h) | Vasily Khoruzhick | |
Add linux/module.h to fix this compilation error: drivers/power/s3c_adc_battery.c:435:15: error: expected declaration specifiers or ‘...’ before string constant drivers/power/s3c_adc_battery.c:435:1: warning: data definition has no type or storage class drivers/power/s3c_adc_battery.c:435:1: warning: type defaults to ‘int’ in declaration of ‘MODULE_AUTHOR’ drivers/power/s3c_adc_battery.c:435:15: warning: function declaration isn’t a prototype drivers/power/s3c_adc_battery.c:436:20: error: expected declaration specifiers or ‘...’ before string constant drivers/power/s3c_adc_battery.c:436:1: warning: data definition has no type or storage class drivers/power/s3c_adc_battery.c:436:1: warning: type defaults to ‘int’ in declaration of ‘MODULE_DESCRIPTION’ drivers/power/s3c_adc_battery.c:436:20: warning: function declaration isn’t a prototype drivers/power/s3c_adc_battery.c:437:16: error: expected declaration specifiers or ‘...’ before string constant drivers/power/s3c_adc_battery.c:437:1: warning: data definition has no type or storage class drivers/power/s3c_adc_battery.c:437:1: warning: type defaults to ‘int’ in declaration of ‘MODULE_LICENSE’ drivers/power/s3c_adc_battery.c:437:16: warning: function declaration isn’t a prototype make[2]: *** [drivers/power/s3c_adc_battery.o] Error 1 Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com> Signed-off-by: Ian Lartey <ian@opensource.wolfsonmicro.com> Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com> | |||
2011-07-08 | s3c_adc_battery: Fix annotation for s3c_adc_battery_probe() | Mark Brown | |
A probe() function is used at device init time rather than system init time. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Vasily Khoruzhick <anarsoul@gmail.com> Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com> | |||
2011-03-16 | s3c_adc_battery: Fix method names when PM not set | Heiko Stuebner | |
s3c_adc_battery declares wrong method names when CONFIG_PM is not set. Signed-off-by: Heiko Stuebner <heiko@sntech.de> Acked-by: Vasily Khoruzhick <anarsoul@gmail.com> Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com> | |||
2011-01-14 | Merge git://git.infradead.org/battery-2.6 | Linus Torvalds | |
* git://git.infradead.org/battery-2.6: (21 commits) power_supply: Add MAX17042 Fuel Gauge Driver olpc_battery: Fix up XO-1.5 properties list olpc_battery: Add support for CURRENT_NOW and VOLTAGE_NOW olpc_battery: Add support for CHARGE_NOW olpc_battery: Add support for CHARGE_FULL_DESIGN olpc_battery: Ambient temperature is not available on XO-1.5 jz4740-battery: Should include linux/io.h s3c_adc_battery: Add gpio_inverted field to pdata power_supply: Don't use flush_scheduled_work() power_supply: Fix use after free and memory leak gpio-charger: Fix potential race between irq handler and probe/remove gpio-charger: Provide default name for the power_supply gpio-charger: Check result of kzalloc jz4740-battery: Check if platform_data is supplied isp1704_charger: Detect charger after probe isp1704_charger: Set isp->dev before anything needs it isp1704_charger: Detect HUB/Host chargers isp1704_charger: Correct length for storing model power_supply: Add gpio charger driver jz4740-battery: Protect against concurrent battery readings ... | |||
2010-12-22 | s3c_adc_battery: Add gpio_inverted field to pdata | Vasily Khoruzhick | |
Add support for inverted gpio_charge_finished values. This change is necessary for H1940 support. Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com> Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com> | |||
2010-11-01 | tree-wide: fix comment/printk typos | Uwe Kleine-König | |
"gadget", "through", "command", "maintain", "maintain", "controller", "address", "between", "initiali[zs]e", "instead", "function", "select", "already", "equal", "access", "management", "hierarchy", "registration", "interest", "relative", "memory", "offset", "already", Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz> | |||
2010-07-23 | Add s3c-adc-battery driver | Vasily Khoruzhick | |
s3c-adc-battery is driver for monitoring and charging battery on iPAQ H1930/H1940/RX1950. It depends on s3c-adc driver to get battery voltage and current. Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com> Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com> |
