[ Upstream commit 583b53ece0b0268c542a1eafadb62e3d4b0aab8c ]
The driver fails to probe with -EPROBE_DEFER if battery's power supply
(charger driver) isn't ready yet and this results in a bit noisy error
message in KMSG during kernel's boot up. Let's silence the harmless
error message.
Signed-off-by: Dmitry Osipenko <digetx@gmail.com>
Reviewed-by: Andrew F. Davis <afd@ti.com>
Reviewed-by: Pali Rohár <pali@kernel.org>
Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.com>
commit a60ec78d306c6548d4adbc7918b587a723c555cc upstream.
This driver's remove path calls cancel_delayed_work().
However, that function does not wait until the work function
finishes. This could mean that the work function is still
running after the driver's remove function has finished,
which would result in a use-after-free.
Fix by calling cancel_delayed_work_sync(), which ensures that
that the work is properly cancelled, no longer running, and
unable to re-schedule itself.
This issue was detected with the help of Coccinelle.
Cc: stable <stable@vger.kernel.org>
Signed-off-by: Sven Van Asbroeck <TheSven73@gmail.com>
[ Upstream commit 8288022284859acbcc3cf1a073a1e2692d6c2543 ]
We may want to use the device pointer in device_init_wakeup() with
functions that expect the device to already be added with device_add().
For example, if we were to link the device initializing wakeup to
something in sysfs such as a class for wakeups we'll run into an error.
It looks like this code was written with the assumption that the device
would be added before initializing wakeup due to the order of operations
in power_supply_unregister().
Let's change the order of operations so we don't run into problems here.
Fixes: 948dcf966228 ("power_supply: Prevent suspend until power supply events are processed")
Cc: Tri Vo <trong@android.com>
Cc: Kalesh Singh <kaleshsingh@google.com>
Cc: Ravi Chandra Sadineni <ravisadineni@chromium.org>
Cc: Viresh Kumar <viresh.kumar@linaro.org>
Signed-off-by: Stephen Boyd <swboyd@chromium.org>
Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
[ Upstream commit 14d338a857f05f894ba3badd9e6d3039c68b8180 ]
NULL check before some freeing functions is not needed.
Signed-off-by: Thomas Meyer <thomas@m3y3r.de>
Reviewed-by: Kevin Hilman <khilman@baylibre.com>
[ Upstream commit 079cdff3d0a09c5da10ae1be35def7a116776328 ]
This avoids getting woken up from suspend after power interruptions
when the bci wrongly thinks the battery is full just because
of input current going low because of low input power
Signed-off-by: Andreas Kemnade <andreas@kemnade.info>
[ Upstream commit 8314c212f995bc0d06b54ad02ef0ab4089781540 ]
the charging current uses unsigned int variables, if we step back
if the current is still low, we would run into negative which
means setting the target to a huge value.
Better add checks here.
[ Upstream commit cb90a2c6f77fe9b43d1e3f759bb2f13fe7fa1811 ]
Since the max8998 MFD driver supports instantiation by DT, platform data
retrieval is handled in MFD probe and cell drivers should get use
the pdata field of max8998_dev struct to obtain them.
Fixes: ee999fb3f17f ("mfd: max8998: Add support for Device Tree")
Signed-off-by: Tomasz Figa <tomasz.figa@gmail.com>
Signed-off-by: Paweł Chmiel <pawel.mikolaj.chmiel@gmail.com>
[ Upstream commit 9f1e44774be578fb92776add95f1fcaf8284d692 ]
There should be only one instance of struct shdwc in the system. This is
referenced through at91_shdwc. Return in probe if at91_shdwc is already
allocated.
Signed-off-by: Claudiu Beznea <claudiu.beznea@microchip.com>
Acked-by: Nicolas Ferre <nicolas.ferre@microchip.com>
[ Upstream commit 54baff8d4e5dce2cef61953b1dc22079cda1ddb1 ]
If kstrtoul() fails then we print "charge_full" when it's uninitialized.
The debug printk doesn't add anything so I deleted it and cleaned these
two functions up a bit.
[ Upstream commit 87a2b65fc855e6be50f791c2ebbb492541896827 ]
This adds rate limiting to the message that is printed when reading a
power supply property via sysfs returns an error. This will prevent
userspace applications from unintentionally dDOSing the system by
continuously reading a property that returns an error.
Signed-off-by: David Lechner <david@lechnology.com>
[ Upstream commit 349ced9984ff540ce74ca8a0b2e9b03dc434b9dd ]
Fix a similar endless event loop as was done in commit
8dcf32175b4e ("i2c: prevent endless uevent loop with
CONFIG_I2C_DEBUG_CORE"):
The culprit is the dev_dbg printk in the i2c uevent handler. If
this is activated (for instance by CONFIG_I2C_DEBUG_CORE) it results
in an endless loop with systemd-journald.
This happens if user-space scans the system log and reads the uevent
file to get information about a newly created device, which seems
fair use to me. Unfortunately reading the "uevent" file uses the
same function that runs for creating the uevent for a new device,
generating the next syslog entry
Both CONFIG_I2C_DEBUG_CORE and CONFIG_POWER_SUPPLY_DEBUG were reported
in https://bugs.freedesktop.org/show_bug.cgi?id=76886 but only former
seems to have been fixed. Drop debug prints as it was done in I2C
subsystem to resolve the issue.
Signed-off-by: Andrey Smirnov <andrew.smirnov@gmail.com>
Cc: Chris Healy <cphealy@gmail.com>
Cc: linux-pm@vger.kernel.org
commit c3422ad5f84a66739ec6a37251ca27638c85b6be upstream.
Currently there is no check on platform_get_irq() return value
in case it fails, hence never actually reporting any errors and
causing unexpected behavior when using such value as argument
for function regmap_irq_get_virq().
Fix this by adding a proper check, a message reporting any errors
and returning *pirq*
Addresses-Coverity-ID: 1443940 ("Improper use of negative value")
Fixes: 843735b788a4 ("power: axp288_charger: axp288 charger driver")
Cc: stable@vger.kernel.org
Signed-off-by: Gustavo A. R. Silva <gustavo@embeddedor.com>
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
commit f25a646fbe2051527ad9721853e892d13a99199e upstream.
Fix incorrect return value.
Signed-off-by: Baolin Wang <baolin.wang@linaro.org>
commit ed54ffbe554f0902689fd6d1712bbacbacd11376 upstream.
According to [1] and [2], the temperature values are in tenths of degree
Celsius. Exposing the Celsius value makes the battery appear on fire:
$ upower -i /org/freedesktop/UPower/devices/battery_olpc_battery
temperature: 236.9 degrees C
Tested on OLPC XO-1 and OLPC XO-1.75 laptops.
[1] include/linux/power_supply.h
[2] Documentation/power/power_supply_class.txt
Fixes: fb972873a767 ("[BATTERY] One Laptop Per Child power/battery driver")
Signed-off-by: Lubomir Rintel <lkundrak@v3.sk>
Acked-by: Pavel Machek <pavel@ucw.cz>
[ Upstream commit 3ffa6583e24e1ad1abab836d24bfc9d2308074e5 ]
If a device gets removed right after having registered a power_supply node,
we might enter in a deadlock between the remove call (that has a lock on
the parent device) and the deferred register work.
Allow the deferred register work to exit without taking the lock when
we are in the remove state.
Stack trace on a Ubuntu 16.04:
[16072.109121] INFO: task kworker/u16:2:1180 blocked for more than 120 seconds.
[16072.109127] Not tainted 4.13.0-41-generic #46~16.04.1-Ubuntu
[16072.109129] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[16072.109132] kworker/u16:2 D 0 1180 2 0x80000000
[16072.109142] Workqueue: events_power_efficient power_supply_deferred_register_work
[16072.109144] Call Trace:
[16072.109152] __schedule+0x3d6/0x8b0
[16072.109155] schedule+0x36/0x80
[16072.109158] schedule_preempt_disabled+0xe/0x10
[16072.109161] __mutex_lock.isra.2+0x2ab/0x4e0
[16072.109166] __mutex_lock_slowpath+0x13/0x20
[16072.109168] ? __mutex_lock_slowpath+0x13/0x20
[16072.109171] mutex_lock+0x2f/0x40
[16072.109174] power_supply_deferred_register_work+0x2b/0x50
[16072.109179] process_one_work+0x15b/0x410
[16072.109182] worker_thread+0x4b/0x460
[16072.109186] kthread+0x10c/0x140
[16072.109189] ? process_one_work+0x410/0x410
[16072.109191] ? kthread_create_on_node+0x70/0x70
[16072.109194] ret_from_fork+0x35/0x40
[16072.109199] INFO: task test:2257 blocked for more than 120 seconds.
[16072.109202] Not tainted 4.13.0-41-generic #46~16.04.1-Ubuntu
[16072.109204] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[16072.109206] test D 0 2257 2256 0x00000004
[16072.109208] Call Trace:
[16072.109211] __schedule+0x3d6/0x8b0
[16072.109215] schedule+0x36/0x80
[16072.109218] schedule_timeout+0x1f3/0x360
[16072.109221] ? check_preempt_curr+0x5a/0xa0
[16072.109224] ? ttwu_do_wakeup+0x1e/0x150
[16072.109227] wait_for_completion+0xb4/0x140
[16072.109230] ? wait_for_completion+0xb4/0x140
[16072.109233] ? wake_up_q+0x70/0x70
[16072.109236] flush_work+0x129/0x1e0
[16072.109240] ? worker_detach_from_pool+0xb0/0xb0
[16072.109243] __cancel_work_timer+0x10f/0x190
[16072.109247] ? device_del+0x264/0x310
[16072.109250] ? __wake_up+0x44/0x50
[16072.109253] cancel_delayed_work_sync+0x13/0x20
[16072.109257] power_supply_unregister+0x37/0xb0
[16072.109260] devm_power_supply_release+0x11/0x20
[16072.109263] release_nodes+0x110/0x200
[16072.109266] devres_release_group+0x7c/0xb0
[16072.109274] wacom_remove+0xc2/0x110 [wacom]
[16072.109279] hid_device_remove+0x6e/0xd0 [hid]
[16072.109284] device_release_driver_internal+0x158/0x210
[16072.109288] device_release_driver+0x12/0x20
[16072.109291] bus_remove_device+0xec/0x160
[16072.109293] device_del+0x1de/0x310
[16072.109298] hid_destroy_device+0x27/0x60 [hid]
[16072.109303] usbhid_disconnect+0x51/0x70 [usbhid]
[16072.109308] usb_unbind_interface+0x77/0x270
[16072.109311] device_release_driver_internal+0x158/0x210
[16072.109315] device_release_driver+0x12/0x20
[16072.109318] usb_driver_release_interface+0x77/0x80
[16072.109321] proc_ioctl+0x20f/0x250
[16072.109325] usbdev_do_ioctl+0x57f/0x1140
[16072.109327] ? __wake_up+0x44/0x50
[16072.109331] usbdev_ioctl+0xe/0x20
[16072.109336] do_vfs_ioctl+0xa4/0x600
[16072.109339] ? vfs_write+0x15a/0x1b0
[16072.109343] SyS_ioctl+0x79/0x90
[16072.109347] entry_SYSCALL_64_fastpath+0x24/0xab
[16072.109349] RIP: 0033:0x7f20da807f47
[16072.109351] RSP: 002b:00007ffc422ae398 EFLAGS: 00000246 ORIG_RAX: 0000000000000010
[16072.109353] RAX: ffffffffffffffda RBX: 00000000010b8560 RCX: 00007f20da807f47
[16072.109355] RDX: 00007ffc422ae3a0 RSI: 00000000c0105512 RDI: 0000000000000009
[16072.109356] RBP: 0000000000000000 R08: 00007ffc422ae3e0 R09: 0000000000000010
[16072.109357] R10: 00000000000000a6 R11: 0000000000000246 R12: 0000000000000000
[16072.109359] R13: 00000000010b8560 R14: 00007ffc422ae2e0 R15: 0000000000000000
Reported-and-tested-by: Richard Hughes <rhughes@redhat.com>
Tested-by: Aaron Skomra <Aaron.Skomra@wacom.com>
Signed-off-by: Benjamin Tissoires <benjamin.tissoires@redhat.com>
Fixes: 7f1a57fdd6cb ("power_supply: Fix possible NULL pointer dereference on early uevent")
Signed-off-by: Sebastian Reichel <sebastian.reichel@collabora.co.uk>
[ Upstream commit 09bebb1adb21ecd04adf7ccb3b06f73e3a851e93 ]
Vexpress platforms provide two different restart handlers: SYS_REBOOT
that restart the entire system, while DB_RESET only restarts the
daughter board containing the CPU. DB_RESET is overridden by SYS_REBOOT
if it exists.
notifier_chain_register used in register_restart_handler by design
relies on notifiers to be registered once only, however vexpress restart
notifier can get registered twice. When this happen it corrupts list
of notifiers, as result some notifiers can be not called on proper
event, traverse on list can be cycled forever, and second unregister
can access already freed memory.
So far, since this was the only restart handler in the system, no issue
was observed even if the same notifier was registered twice. However
commit 6c5c0d48b686 ("watchdog: sp805: add restart handler") added
support for SP805 restart handlers and since the system under test
contains two vexpress restart and two SP805 watchdog instances, it was
observed that during the boot traversing the restart handler list looped
forever as there's a cycle in that list resulting in boot hang.
This patch fixes the issues by ensuring that the notifier is installed
only once.
Cc: Sebastian Reichel <sre@kernel.org>
Signed-off-by: Sudeep Holla <sudeep.holla@arm.com>
Fixes: 46c99ac66222 ("power/reset: vexpress: Register with kernel restart handler")
channels
commit a427503edaaed9b75ed9746a654cece7e93e60a8 upstream.
If an iio channel defines a basic property, there are duplicate entries
in /sys/class/power/*/uevent.
So add a check to avoid duplicates. Since all channels may be duplicates,
we have to modify the related error check.
Signed-off-by: H. Nikolaus Schaller <hns@goldelico.com>
Fixes: e60fea794e6e ("power: battery: Generic battery driver using IIO")
properties
commit 932d47448c3caa0fa99e84d7f5bc302aa286efd8 upstream.
We did have sporadic problems in the pinctrl framework during boot
where a pin group name unexpectedly became NULL leading to a NULL
dereference in strcmp.
Detailled analysis of the failing cases did reveal that there were
two devm allocated objects close to each other. The second one was
the affected group_desc in pinmux and the first one was the
psy_desc->properties buffer of the gab driver.
Review of the gab code showed that the address calculation for
one memcpy() is wrong. It does
properties + sizeof(type) * index
but C is defined to do the index multiplication already for
pointer + integer additions. Hence the factor was applied twice
and the memcpy() does write outside of the properties buffer.
Sometimes it happened to be the pinctrl and triggered the strcmp(NULL).
Anyways, it is overkill to use a memcpy() here instead of a simple
assignment, which is easier to read and has less risk for wrong
address calculations. So we change code to a simple assignment.
If we initialize the index to the first free location, we can even
remove the local variable 'properties'.
This bug seems to exist right from the beginning in 3.7-rc1 in
commit e60fea794e6e ("power: battery: Generic battery driver using IIO")
commit a1b94355ea3fde5e13db7ff37c0272fcde4e29b2 upstream.
acpi_match_device can potentially return NULL, so it is prudent to
check if acpi_id is null before it is dereferenced. Add a check
and an error message to indicate the failure.
Reviewed-by: Pali Rohár <pali.rohar@gmail.com>
Signed-off-by: Sebastian Reichel <sre@kernel.org>
Cc: Amit Pundir <amit.pundir@linaro.org>
[ Upstream commit 633e8799ddc09431be2744c4a1efdbda13af2b0b ]
This changed is needed to avoid locking problem during
boot as shown:
<5>[ 8.824096] Registering SWP/SWPB emulation handler
<6>[ 8.977294] clock: disabling unused clocks to save power
<3>[ 9.108154] BUG: sleeping function called from invalid context at kernel_albert/kernel/mutex.c:269
<3>[ 9.122894] in_atomic(): 1, irqs_disabled(): 0, pid: 1, name: swapper/0
<4>[ 9.130249] 3 locks held by swapper/0/1:
<4>[ 9.134613] #0: (&__lockdep_no_validate__){......}, at: [<c0342430>] __driver_attach+0x58/0xa8
<4>[ 9.144500] #1: (&__lockdep_no_validate__){......}, at: [<c0342440>] __driver_attach+0x68/0xa8
<4>[ 9.154357] #2: (&polling_timer){......}, at: [<c0053770>] run_timer_softirq+0x108/0x3ec
<4>[ 9.163726] Backtrace:
<4>[ 9.166473] [<c001269c>] (dump_backtrace+0x0/0x114) from [<c067e5f0>] (dump_stack+0x20/0x24)
<4>[ 9.175811] r6:00203230 r5:0000010d r4:d782e000 r3:60000113
<4>[ 9.182250] [<c067e5d0>] (dump_stack+0x0/0x24) from [<c007441c>] (__might_sleep+0x10c/0x128)
<4>[ 9.191650] [<c0074310>] (__might_sleep+0x0/0x128) from [<c0688f60>] (mutex_lock_nested+0x34/0x36c)
<4>[ 9.201660] r5:c02d5350 r4:d79a0c64
<4>[ 9.205688] [<c0688f2c>] (mutex_lock_nested+0x0/0x36c) from [<c02d5350>] (regulator_set_current_limit+0x30/0x118)
<4>[ 9.217071] [<c02d5320>] (regulator_set_current_limit+0x0/0x118) from [<c0435ce0>] (update_charger+0x84/0xc4)
<4>[ 9.228027] r7:d782fb20 r6:00000101 r5:c1767e94 r4:00000000
<4>[ 9.234436] [<c0435c5c>] (update_charger+0x0/0xc4) from [<c0435d40>] (psy_changed+0x20/0x48)
<4>[ 9.243804] r5:d782e000 r4:c1767e94
<4>[ 9.247802] [<c0435d20>] (psy_changed+0x0/0x48) from [<c0435dec>] (polling_timer_func+0x84/0xb8)
<4>[ 9.257537] r4:c1767e94 r3:00000002
<4>[ 9.261566] [<c0435d68>] (polling_timer_func+0x0/0xb8) from [<c00537e4>] (run_timer_softirq+0x17c/0x3ec)
<4>[ 9.272033] r4:c1767eb0 r3:00000000
<4>[ 9.276062] [<c0053668>] (run_timer_softirq+0x0/0x3ec) from [<c004b000>] (__do_softirq+0xf0/0x298)
<4>[ 9.286010] [<c004af10>] (__do_softirq+0x0/0x298) from [<c004b650>] (irq_exit+0x98/0xa0)
<4>[ 9.295013] [<c004b5b8>] (irq_exit+0x0/0xa0) from [<c000edbc>] (handle_IRQ+0x60/0xc0)
<4>[ 9.303680] r4:c1194e98 r3:c00bc778
<4>[ 9.307708] [<c000ed5c>] (handle_IRQ+0x0/0xc0) from [<c0008504>] (gic_handle_irq+0x34/0x68)
<4>[ 9.316955] r8:000ac383 r7:d782fc3c r6:d782fc08 r5:c11936c4 r4:e0802100
<4>[ 9.324310] r3:c026ba48
<4>[ 9.327301] [<c00084d0>] (gic_handle_irq+0x0/0x68) from [<c068c2c0>] (__irq_svc+0x40/0x74)
<4>[ 9.336456] Exception stack(0xd782fc08 to 0xd782fc50)
<4>[ 9.342041] fc00: d6e30e6c ac383627 00000000 ac383417 ea19c000 ea200000
<4>[ 9.351104] fc20: beffffff 00000667 000ac383 d6e30670 d6e3066c d782fc94 d782fbe8 d782fc50
<4>[ 9.360168] fc40: c026ba48 c001d1f0 00000113 ffffffff
Fixes: b2998049cfae ("[BATTERY] pda_power platform driver")
Signed-off-by: Michael Trimarchi <michael@amarulasolutions.com>
Signed-off-by: Anthony Brandon <anthony@amarulasolutions.com>
[ Upstream commit 8b20839988f1ed5e534b270f3776709b640dc7e0 ]
Function devm_kzalloc() will return a NULL pointer. However, in function
isp1704_charger_probe(), the return value of devm_kzalloc() is directly
used without validation. This may result in a bad memory access bug.
Fixes: 34a109610e2a ("isp1704_charger: Add DT support")
Signed-off-by: Pan Bian <bianpan2016@163.com>
[ Upstream commit 6cf62a3b97e78ba41d31390e59a1ddc98a9e3622 ]
Allow platform-code to disable the reset on probe and suspend/resume
by setting a "disable-reset" boolean device property on the device.
There are several reasons why the platform-code may want to disable
the reset on probe and suspend/resume:
1) Resetting the charger should never be necessary it should always have
sane values programmed. If it is running with invalid values while we
are not running (system turned off or suspended) there is a big problem
as that may lead to overcharging the battery.
2) The reset in suspend() is meant to put the charger back into default
mode, but this is not necessary and not a good idea. If the charger has
been programmed with a higher max charge_current / charge_voltage then
putting it back in default-mode will reset those to the safe power-on
defaults, leading to slower charging, or charging to a lower voltage
(and thus not using the full capacity) while suspended which is
undesirable. Reprogramming the max charge_current / charge_voltage
after the reset will not help here as that will put the charger back
in host mode and start the i2c watchdog if the host then does not do
anything for 40s (iow if we're suspended for more then 40s) the watchdog
expires resetting the device to default-mode, including resetting all
the registers to there safe power-on defaults. So the only way to keep
using custom charge settings while suspending is to keep the charger in
its normal running state with the i2c watchdog disabled. This is fine
as the charger will still automatically switch from constant current
to constant voltage and stop charging when the battery is full.
3) Besides never being necessary resetting the charger also causes
problems on systems where the charge voltage limit is set higher then the
reset value, if this is the case and the charger is reset while charging
and the battery voltage is between the 2 voltages, then about half the
time the charger gets confused and claims to be charging (REG08 contains
0x64) but in reality the charger has decoupled itself from VBUS (Q1 off)
and is drawing 0A from VBUS, leaving the system running from the battery.
This last problem is happening on a GPD-win mini PC with a bq24292i
charger chip combined with a max17047 fuel-gauge and a LiHV battery.
I've checked and TI does not list any errata for the bq24292i which
could explain this (there are no errata at all).
Cc: Liam Breck <kernel@networkimprov.net>
Cc: Tony Lindgren <tony@atomide.com>
Acked-by: Liam Breck <kernel@networkimprov.net>
[ Upstream commit d63d07c6fc25182af6d3ab5b3b8737b0c1025ebd ]
If the charger is unplugged before the battery is full we may
see an over/under voltage fault. Ignore this rather then emitting
a message or uevent.
This fixes messages like these getting logged on charger unplug + replug:
bq24190-charger 15-006b: Fault: boost 0, charge 1, battery 0, ntc 0
bq24190-charger 15-006b: Fault: boost 0, charge 0, battery 0, ntc 0
Cc: Hans de Goede <hdegoede@redhat.com>
Signed-off-by: Liam Breck <kernel@networkimprov.net>
'ab8500_charger_init_hw_registers()'
[ Upstream commit 09edcb647542487864e23aa8d2ef26be3e08978a ]
If an error occurs when we enable the backup battery charging, we should
go through the error handling path directly.
Before commit db43e6c473b5 ("ab8500-bm: Add usb power path support") this
was the case, but this commit has added some code between the last test and
the 'out' label.
So, in case of error, this added code is executed and the error may be
silently ignored.
Fix it by adding the missing 'goto out', as done in all other error
handling paths.
Fixes: db43e6c473b5 ("ab8500-bm: Add usb power path support")
Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr>
[ Upstream commit bf59fddde1c3eab89eb8dca8f3d3dc097887d2bb ]
'ret' is know to be 0 at this point, because it has not been updated by the
the previous call to 'abx500_mask_and_set_register_interruptible()'.
Fix it by updating 'ret' before checking if an error occurred.
Fixes: 84edbeeab67c ("ab8500-charger: AB8500 charger driver")
commit 348c7cf5fcbcb68838255759d4cb45d039af36d2 upstream.
This change resolves a new compile-time warning
when built as a loadable module:
WARNING: modpost: missing MODULE_LICENSE() in drivers/power/reset/zx-reboot.o
see include/linux/module.h for more information
This adds the license as "GPL v2", which matches the header of the file.
MODULE_DESCRIPTION and MODULE_AUTHOR are also added.
Signed-off-by: Jesse Chan <jc@linux.com>
[ Upstream commit 248efcf00602f0282587999bcc221a872bd72530 ]
In order for the MSB -> LSB latching to work correctly we must read the
2 8 bit registers of a 12 bit value in one consecutive read.
This fixes voltage_ocv reporting inconsistent values on my tablet.
[ Upstream commit 4949fc5e071f8e8d8122e0b16cf6a2ec1ca36258 ]
2 8 bit registers of a 15 bit value in one consecutive read.
This fixes charge_full reporting 3498768 on some reads and 3354624 one
other reads on my tablet (for the 3354624 value the raw LSB is 0x00).
[ Upstream commit 6f074bc878dc9b00c0df0bf3a8cb1d9e294cd881 ]
If reading the register fails, return the actual error code, instead
of the uninitialized val variable;
commit ba52e75718784fda1b683ee0bfded72a0b83b047 upstream.
Reading both fault and status registers and logging any fault should
take priority over handling status register update.
Fix by moving the status handling to later in interrupt routine.
Fixes: d7bf353fd0aa3 ("bq24190_charger: Add support for TI BQ24190 Battery Charger")
Acked-by: Mark Greer <mgreer@animalcreek.com>
irq_handle_thread()
commit 68abfb8015832ddf728b911769659468efaf8bd9 upstream.
Caching the fault register after a single I2C read may not keep an accurate
value.
Fix by doing two reads in irq_handle_thread() and using the cached value
elsewhere. If a safety timer fault later clears itself, we apparently don't get
an interrupt (INT), however other interrupts would refresh the register cache.
From the data sheet: "When a fault occurs, the charger device sends out INT
and keeps the fault state in REG09 until the host reads the fault register.
Before the host reads REG09 and all the faults are cleared, the charger
device would not send any INT upon new faults. In order to read the
current fault status, the host has to read REG09 two times consecutively.
The 1st reads fault register status from the last read [1] and the 2nd reads
the current fault register status."
[1] presumably a typo; should be "last fault"
component
commit 2d9fee6a42ea170e4378b3363a7ad385d0e67281 upstream.
We wrongly get uevents for bq24190-charger and bq24190-battery on every
register change.
Fix by checking the association with charger and battery before
emitting uevent(s).
commit d62acc5ef0621463446091ebd7a345e06e9ab80c upstream.
The device specific data is not fully initialized on
request_threaded_irq(). This may cause a crash when the IRQ handler
tries to reference them.
Fix the issue by installing IRQ handler at the end of the probe.
commit e05ad7e0741ce0505e1df157c62b22b95172bb97 upstream.
pm_resume() does a register_reset() which clears charger host mode.
Fix by calling set_mode_host() after the reset.
commit 767eee362fd72bb2ca44cc80419ca4b38c6d8369 upstream.
The interrupt signal is TRIGGER_FALLING. This is is specified in the
data sheet PIN FUNCTIONS: "The INT pin sends active low, 256us
pulse to host to report charger device status and fault."
Also the direction can be seen in the data sheet Figure 37 "BQ24190
with D+/D- Detection and USB On-The-Go (OTG)" which shows a 10k
pull-up resistor installed for the sample configurations.
commit bdd9968d35f7fcdb76089347d1529bf079534214 upstream.
val might become 7 in which case stime[7] (array of length 7) would be
accessed during the scnprintf call later and that will cause issues.
Obviously, string concatenation is not intended here so just a comma needs
to be added to fix the issue.
Fixes: 98a276649358 ("power_supply: Add new lp8788 charger driver")
Signed-off-by: Giedrius Statkevičius <giedrius.statkevicius@gmail.com>
Acked-by: Milo Kim <milo.kim@ti.com>
commit 0b0408745e7ff24757cbfd571d69026c0ddb803c upstream.
LPDDR memories can only handle up to 400 uncontrolled power off. Ensure the
proper power off sequence is used before shutting down the platform.
Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
commit 3bee9ea1de687925d116670f036599cbed8b66b0 upstream.
The BQ27510 and BQ27520 use a slightly different register map than the
BQ27500, add a new type enum and add these gauges to it.
Fixes: d74534c27775 ("power: bq27xxx_battery: Add support for additional bq27xxx family devices")
Based-on-patch-by: Kenneth R. Crudup <kenny@panix.com>
Signed-off-by: Andrew F. Davis <afd@ti.com>
commit 075eb5719d53e8bb4a406ad87e1de99319aa50f0 upstream.
There's a typo, it should do pm_runtime_get_sync, not put.
Cc: Mark A. Greer <mgreer@animalcreek.com>
Reviewed-by: Mark Greer <mgreer@animalcreek.com>
git://git.kernel.org/pub/scm/linux/kernel/git/sre/linux-power-supply
Pull power supply and reset updates from Sebastian Reichel:
- move power supply drivers to drivers/power/supply
- unify location of power supply DT documentation
- tps65217-charger: IRQ support
- act8945a-charger: misc. cleanups & improvements
- sbs-battery cleanup
- fix users of deprecated create_singlethread_workqueue()
- misc fixes.
* tag 'for-v4.9' of git://git.kernel.org/pub/scm/linux/kernel/git/sre/linux-power-supply: (46 commits)
power: supply: bq27xxx_battery: allow kernel poll_interval parameter runtime update
power: supply: sbs-battery: Cleanup removal of chip->pdata
power: reset: st: Remove obsolete platforms from dt doc
power: reset: st-poweroff: Remove obsolete platforms.
power: reset: zx-reboot: Unmap region obtained by of_iomap
power: reset: xgene-reboot: Unmap region obtained by of_iomap
power: supply: ab8500: cleanup with list_first_entry_or_null()
power: reset: add in missing white space in error message text
sbs-battery: make writes to ManufacturerAccess optional
power: bq24257: Fix use of uninitialized pointer bq->charger
power: supply: sbs-battery: simplify DT parsing
power: supply: bq24735-charger: Request status GPIO with initial input setup
power: supply: sbs-battery: Use gpio_desc and sleeping calls for battery detect
power: supply: act8945a_charger: Add max current property
power: supply: act8945a_charger: Add capacity level property
doc: bindings: power: act8945a-charger: Update properties.
power: supply: act8945a_charger: Fix the power supply type
power: supply: act8945a_charger: Add status change update support
power: supply: act8945a_charger: Improve state handling
power: supply: act8945a_charger: Remove "battery_temperature"
update
Fix issue with poll_interval being not updated till the previous
interval expired.
Cc: Liam Breck <liam@networkimprov.net>
Signed-off-by: Matt Ranostay <matt@ranostay.consulting>
There where still a few lingering references to pdata after commit
power: supply: sbs-battery: simplify DT parsing.
Remove pdata from struct·sbs_info and conditional checks to ser if this
was set from the i2c read / write functions.
Instead of call max in each function for incrementing poll_retry_count
do it once in the probe function.
Fixup null pointer dereference in to pdata in sbs_external_power_changed.
Change retry counts to u32 to avoid need for max.
Signed-off-by: Phil Reid <preid@electromag.com.au>
This patch removes support for STiH415/6 SoC's from the
st-poweroff driver, as support for these platforms is
being removed from the kernel.
Signed-off-by: Peter Griffin <peter.griffin@linaro.org>
Cc: <linux-pm@vger.kernel.org>
Free memory mapping, if probe is not successful.
Signed-off-by: Arvind Yadav <arvind.yadav.cs@gmail.com>
The combo of list_empty() check and return list_first_entry()
can be replaced with list_first_entry_or_null().
A dev_err message spans two lines and the literal string is missing
a white space between words. Add the white space.
According to the Smart Battery Data Specification, the use
of ManufacturerAcess (register 0x0) is implementation-defined.
It appears that some batteries use writes to this register
in order to implement certain functionality, but others may
simply NAK all writes to it. As a result, write failures to
ManufacturerAccess should not be used as an indicator of
battery presence, nor as a failure to enter sleep mode.
The failed write access was seen with SANYO AP13J3K.
Cc: Brian Norris <briannorris@chromium.org>
bq->charger is initialized in bq24257_power_supply_init.
Therefore, bq24257_power_supply_init should be called before the
registration of the IRQ handler bq24257_irq_handler_thread that calls
power_supply_changed(bq->charger).
Signed-off-by: Georges Savoundararadj <savoundg@gmail.com>
Cc: Aurelien Chanot <chanot.a@gmail.com>
Cc: Andreas Dannenberg <dannenberg@ti.com>
Fixes: 2219a935963e ("power_supply: Add TI BQ24257 charger driver")
Use a more common logging style.
Miscellanea:
o Use pr_warn
o Coalesce formats adding missing spaces
o Argument alignment
o Remove unnecessary OOM messages as k.alloc does stack dumps
Acked-by: Nishanth Menon <nm@ti.com>
[khilman: update shortlog]
Signed-off-by: Kevin Hilman <khilman@baylibre.com>
