path: root/drivers/power
2014-02-14Merge tag 'for-v3.14-fixes' of git://git.infradead.org/battery-2.6Linus Torvalds
Pull battery fixes from Dmitry Eremin-Solenikov: - Fix NULL pointer dereference in max17040 driver - Add bq2415x dts bindings documentation - Fix misleading comment in ds2782 driver - Remove useless check in isp1704 charger driver. * tag 'for-v3.14-fixes' of git://git.infradead.org/battery-2.6: power: max17040: Fix NULL pointer dereference when there is no platform_data dt: binding documentation for bq2415x charger isp1704_charger: remove useless check in isp1704_charger_probe() power: ds2782_battery: Typo in comment
2014-02-01power: max17040: Fix NULL pointer dereference when there is no platform_dataKrzysztof Kozlowski
Fix NULL pointer dereference of "chip->pdata" if platform_data was not supplied to the driver. The driver during probe stored the pointer to the platform_data: chip->pdata = client->dev.platform_data; Later it was dereferenced in max17040_get_online() and max17040_get_status(). If platform_data was not supplied, the NULL pointer exception would happen: [ 6.626094] Unable to handle kernel of a at virtual address 00000000 [ 6.628557] pgd = c0004000 [ 6.632868] [00000000] *pgd=66262564 [ 6.634636] Unable to handle kernel paging request at virtual address e6262000 [ 6.642014] pgd = de468000 [ 6.644700] [e6262000] *pgd=00000000 [ 6.648265] Internal error: Oops: 5 [#1] PREEMPT SMP ARM [ 6.653552] Modules linked in: [ 6.656598] CPU: 0 PID: 31 Comm: kworker/0:1 Not tainted 3.10.14-02717-gc58b4b4 #505 [ 6.664334] Workqueue: events max17040_work [ 6.668488] task: dfa11b80 ti: df9f6000 task.ti: df9f6000 [ 6.673873] PC is at show_pte+0x80/0xb8 [ 6.677687] LR is at show_pte+0x3c/0xb8 [ 6.681503] pc : [<c001b7b8>] lr : [<c001b774>] psr: 600f0113 [ 6.681503] sp : df9f7d58 ip : 600f0113 fp : 00000009 [ 6.692965] r10: 00000000 r9 : 00000000 r8 : dfa11b80 [ 6.698171] r7 : df9f7ea0 r6 : e6262000 r5 : 00000000 r4 : 00000000 [ 6.704680] r3 : 00000000 r2 : e6262000 r1 : 600f0193 r0 : c05b3750 [ 6.711194] Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel [ 6.718485] Control: 10c53c7d Table: 5e46806a DAC: 00000015 [ 6.724218] Process kworker/0:1 (pid: 31, stack limit = 0xdf9f6238) [ 6.730465] Stack: (0xdf9f7d58 to 0xdf9f8000) [ 6.914325] [<c001b7b8>] (show_pte+0x80/0xb8) from [<c047107c>] (__do_kernel_fault.part.9+0x44/0x74) [ 6.923425] [<c047107c>] (__do_kernel_fault.part.9+0x44/0x74) from [<c001bb7c>] (do_page_fault+0x2c4/0x360) [ 6.933144] [<c001bb7c>] (do_page_fault+0x2c4/0x360) from [<c0008400>] (do_DataAbort+0x34/0x9c) [ 6.941825] [<c0008400>] (do_DataAbort+0x34/0x9c) from [<c000e5d8>] (__dabt_svc+0x38/0x60) [ 6.950058] Exception stack(0xdf9f7ea0 to 0xdf9f7ee8) [ 6.955099] 7ea0: df0c1790 00000000 00000002 00000000 df0c1794 df0c1790 df0c1790 00000042 [ 6.963271] 7ec0: df0c1794 00000001 00000000 00000009 00000000 df9f7ee8 c0306268 c0306270 [ 6.971419] 7ee0: a00f0113 ffffffff [ 6.974902] [<c000e5d8>] (__dabt_svc+0x38/0x60) from [<c0306270>] (max17040_work+0x8c/0x144) [ 6.983317] [<c0306270>] (max17040_work+0x8c/0x144) from [<c003f364>] (process_one_work+0x138/0x440) [ 6.992429] [<c003f364>] (process_one_work+0x138/0x440) from [<c003fa64>] (worker_thread+0x134/0x3b8) [ 7.001628] [<c003fa64>] (worker_thread+0x134/0x3b8) from [<c00454bc>] (kthread+0xa4/0xb0) [ 7.009875] [<c00454bc>] (kthread+0xa4/0xb0) from [<c000eb28>] (ret_from_fork+0x14/0x2c) [ 7.017943] Code: e1a03005 e2422480 e0826104 e59f002c (e7922104) [ 7.024017] ---[ end trace 73bc7006b9cc5c79 ]--- Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Fixes: c6f4a42de60b981dd210de01cd3e575835e3158e Cc: <stable@vger.kernel.org>
2014-01-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: 1) BPF debugger and asm tool by Daniel Borkmann. 2) Speed up create/bind in AF_PACKET, also from Daniel Borkmann. 3) Correct reciprocal_divide and update users, from Hannes Frederic Sowa and Daniel Borkmann. 4) Currently we only have a "set" operation for the hw timestamp socket ioctl, add a "get" operation to match. From Ben Hutchings. 5) Add better trace events for debugging driver datapath problems, also from Ben Hutchings. 6) Implement auto corking in TCP, from Eric Dumazet. Basically, if we have a small send and a previous packet is already in the qdisc or device queue, defer until TX completion or we get more data. 7) Allow userspace to manage ipv6 temporary addresses, from Jiri Pirko. 8) Add a qdisc bypass option for AF_PACKET sockets, from Daniel Borkmann. 9) Share IP header compression code between Bluetooth and IEEE802154 layers, from Jukka Rissanen. 10) Fix ipv6 router reachability probing, from Jiri Benc. 11) Allow packets to be captured on macvtap devices, from Vlad Yasevich. 12) Support tunneling in GRO layer, from Jerry Chu. 13) Allow bonding to be configured fully using netlink, from Scott Feldman. 14) Allow AF_PACKET users to obtain the VLAN TPID, just like they can already get the TCI. From Atzm Watanabe. 15) New "Heavy Hitter" qdisc, from Terry Lam. 16) Significantly improve the IPSEC support in pktgen, from Fan Du. 17) Allow ipv4 tunnels to cache routes, just like sockets. From Tom Herbert. 18) Add Proportional Integral Enhanced packet scheduler, from Vijay Subramanian. 19) Allow openvswitch to mmap'd netlink, from Thomas Graf. 20) Key TCP metrics blobs also by source address, not just destination address. From Christoph Paasch. 21) Support 10G in generic phylib. From Andy Fleming. 22) Try to short-circuit GRO flow compares using device provided RX hash, if provided. From Tom Herbert. The wireless and netfilter folks have been busy little bees too. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (2064 commits) net/cxgb4: Fix referencing freed adapter ipv6: reallocate addrconf router for ipv6 address when lo device up fib_frontend: fix possible NULL pointer dereference rtnetlink: remove IFLA_BOND_SLAVE definition rtnetlink: remove check for fill_slave_info in rtnl_have_link_slave_info qlcnic: update version to 5.3.55 qlcnic: Enhance logic to calculate msix vectors. qlcnic: Refactor interrupt coalescing code for all adapters. qlcnic: Update poll controller code path qlcnic: Interrupt code cleanup qlcnic: Enhance Tx timeout debugging. qlcnic: Use bool for rx_mac_learn. bonding: fix u64 division rtnetlink: add missing IFLA_BOND_AD_INFO_UNSPEC sfc: Use the correct maximum TX DMA ring size for SFC9100 Add Shradha Shah as the sfc driver maintainer. net/vxlan: Share RX skb de-marking and checksum checks with ovs tulip: cleanup by using ARRAY_SIZE() ip_tunnel: clear IPCB in ip_tunnel_xmit() in case dst_link_failure() is called net/cxgb4: Don't retrieve stats during recovery ...
2014-01-25isp1704_charger: remove useless check in isp1704_charger_probe()Wei Yongjun
Neither devm_usb_get_phy_by_phandle() nor devm_usb_get_phy() can return a NULL result, so remove the useless !isp->phy check. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
2014-01-25power: ds2782_battery: Typo in commentMatthias Brugger
Change missleading comment to actual shift value provided by the chip. Signed-off-by: Matthias Brugger <matthias.bgg@gmail.com>
2014-01-15power,goldfish: Add dependency on HAS_IOMEMRichard Weinberger
On archs like S390 or um this driver cannot build nor work. Make it depend on HAS_IOMEM to bypass build failures. drivers/built-in.o: In function `goldfish_battery_probe': drivers/power/goldfish_battery.c:181: undefined reference to `devm_ioremap' Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-23max17042_battery: Add IRQF_ONESHOT flag to use default irq handlerJonghwa Lee
This patch adds IRQF_ONESHOT flag to max17042's irq since it uses primary default handler. Without this flag, requesting irq will be denied with returning error. Signed-off-by: Jonghwa Lee <jonghwa3.lee@samsung.com> Signed-off-by: MyungJoo Ham <myungjoo.ham@samsung.com> Signed-off-by: Anton Vorontsov <anton@enomsg.org>
2013-12-23gpio-charger: Support wakeup eventsDmitry Eremin-Solenikov
Add support for using gpio-charger IRQ as a wakeup event. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: Anton Vorontsov <anton@enomsg.org>
2013-12-23power_supply: Add charger support for Maxim 14577Krzysztof Kozlowski
MAX14577 chip is a multi-function device which includes MUIC, charger and voltage regulator. The driver is located in drivers/mfd. This patch supports battery charging control of MAX14577 chip and provides power supply class information to userspace. Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Anton Vorontsov <anton@enomsg.org>
2013-12-23isp1704_charger: Add DT supportSebastian Reichel
This patch introduces device tree support to the isp1704 charger driver. Adding support involved moving the handling of the enable GPIO from board code into the driver. Signed-off-by: Sebastian Reichel <sre@debian.org> Signed-off-by: Anton Vorontsov <anton@enomsg.org>
2013-12-23charger-manager: of_cm_parse_desc() should be staticAnton Vorontsov
Fixes the following warning: drivers/power/charger-manager.c:1539:21: warning: symbol 'of_cm_parse_desc' was not declared. Should it be static? Signed-off-by: Anton Vorontsov <anton@enomsg.org>
2013-12-23bq2415x_charger: Add DT supportSebastian Reichel
This adds DT support to the bq2415x driver. Signed-off-by: Sebastian Reichel <sre@debian.org> Reviewed-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Anton Vorontsov <anton@enomsg.org>
2013-12-23power_supply: Add power_supply_get_by_phandleSebastian Reichel
Add method to get power supply by device tree phandle. Signed-off-by: Sebastian Reichel <sre@debian.org> Reviewed-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Anton Vorontsov <anton@enomsg.org>
2013-12-23bq2415x_charger: Use power_supply notifier for automodePali Rohár
This patch removing set_mode_hook function from board data and replacing it with new string variable of notifier power supply device. After this change it is possible to add DT support because driver does not need specific board function anymore. Only static data and name of power supply device is required. Signed-off-by: Pali Rohár <pali.rohar@gmail.com> Reviewed-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Anton Vorontsov <anton@enomsg.org>
2013-12-23power: reset: Add as3722 power-off driverLaxman Dewangan
ams AS3722 supports the power off functionality to turn off system. This commit adds power off driver for ams AS3722. Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Tested-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Anton Vorontsov <anton@enomsg.org>
2013-12-23charger-manager: Support deivce tree in charger manager driverJonghwa Lee
Charger-manager can parse charger_desc data from devicetree which is used to register charger manager. Signed-off-by: Jonghwa Lee <jonghwa3.lee@samsung.com> Signed-off-by: Myungjoo Ham <myungjoo.ham@samsung.com> Signed-off-by: Anton Vorontsov <anton@enomsg.org>
2013-12-23charger-manager: Modify the way of checking battery's temperatureJonghwa Lee
Charger-manager driver used to check battery temperature through the callback function passed by platform data. Unfortunatley, without that pre-defined callback function, charger-manager can't get battery's temperature at all. Also passing callback function through platform data ruins DT support for charger-manager. This patch mondifies charger-manager driver to get temperature of battery without pre-defined callback function. Now, charger-manager can use either of battery thermometer in fuel-gauge and ouside of battery. It uses thermal framework interface for outer thermometer if thermal fw is enabled. Otherwise, it tries to use fuel-gauge's through the power supply interface. Signed-off-by: Jonghwa Lee <jonghwa3.lee@samsung.com> Signed-off-by: Myungjoo Ham <myungjoo.ham@samsung.com> Signed-off-by: Anton Vorontsov <anton@enomsg.org>
2013-12-01power_supply: Add power_supply notifierPali Rohár
This patch adds a notifier chain to the power_supply, this helps drivers in other subsystem to listen to changes in power supply subsystem. This would help to take some actions in those drivers on changing the power supply properties. One such scenario is to increase/decrease system performance based on the battery capacity/voltage. Another scenario is to adjust the h/w peak current detection voltage/current thresholds based on battery voltage/capacity. The notifier helps drivers to listen to changes in power_suppy susbystem without polling the power_supply properties Signed-off-by: Jenny TC <jenny.tc@intel.com> Signed-off-by: Pali Rohár <pali.rohar@gmail.com> Acked-by: Jenny TC <jenny.tc@intel.com> Signed-off-by: Anton Vorontsov <anton@enomsg.org>
2013-12-01max17042_battery: Fix build errors caused by missing REGMAP_I2C configAustin Boyle
max17042 now uses regmap interface but does not enable config option. This patch fixes the following build errors: drivers/power/max17042_battery.c:661:15: error: variable ‘max17042_regmap_config’ has initializer but incomplete type drivers/power/max17042_battery.c:662:2: error: unknown field ‘reg_bits’ specified in initializer drivers/power/max17042_battery.c:662:2: warning: excess elements in struct initializer drivers/power/max17042_battery.c:662:2: warning: (near initialization for ‘max17042_regmap_config’) drivers/power/max17042_battery.c:663:2: error: unknown field ‘val_bits’ specified in initializer drivers/power/max17042_battery.c:663:2: warning: excess elements in struct initializer drivers/power/max17042_battery.c:663:2: warning: (near initialization for ‘max17042_regmap_config’) drivers/power/max17042_battery.c:664:2: error: unknown field ‘val_format_endian’ specified in initializer drivers/power/max17042_battery.c:664:23: error: ‘REGMAP_ENDIAN_NATIVE’ undeclared here (not in a function) drivers/power/max17042_battery.c:664:2: warning: excess elements in struct initializer drivers/power/max17042_battery.c:664:2: warning: (near initialization for ‘max17042_regmap_config’) drivers/power/max17042_battery.c: In function ‘max17042_probe’: drivers/power/max17042_battery.c:684:2: error: implicit declaration of function ‘devm_regmap_init_i2c’ Signed-off-by: Austin Boyle <boyle.austin@gmail.com> Acked-by: Jonghwa Lee <jonghwa3.lee@samsung.com> Signed-off-by: Anton Vorontsov <anton@enomsg.org>
2013-12-01power_supply: Fix Oops from NULL pointer dereference from wakeup_source_activateShuah Khan
power_supply_register() calls device_init_wakeup() to register a wakeup source before initializing dev_name. As a result, device_wakeup_enable() end up registering wakeup source with a null name when wakeup_source_register() gets called with dev_name(dev) which is null at the time. When kernel is booted with wakeup_source_activate enabled, it will panic when the trace point code tries to dereference ws->name. Fixed the problem by moving up the kobject_set_name() call prior to accesses to dev_name(). Replaced kobject_set_name() with dev_set_name() which is the right interface to be called from drivers. Fixed the call to device_del() prior to device_add() in for wakeup_init_failed error handling code. Trace after the change: bash-2143 [003] d... 132.280697: wakeup_source_activate: BAT1 state=0x20001 kworker/3:2-1169 [003] d... 132.281305: wakeup_source_deactivate: BAT1 state=0x30000 Oops message: [ 819.769934] device: 'BAT1': device_add [ 819.770078] PM: Adding info for No Bus:BAT1 [ 819.770235] BUG: unable to handle kernel NULL pointer dereference at (null) [ 819.770435] IP: [<ffffffff813381c0>] skip_spaces+0x30/0x30 [ 819.770572] PGD 3efd90067 PUD 3eff61067 PMD 0 [ 819.770716] Oops: 0000 [#1] SMP [ 819.770829] Modules linked in: arc4 iwldvm mac80211 x86_pkg_temp_thermal coretemp kvm_intel joydev i915 kvm uvcvideo ghash_clmulni_intel videobuf2_vmalloc aesni_intel videobuf2_memops videobuf2_core aes_x86_64 ablk_helper cryptd videodev iwlwifi lrw rfcomm gf128mul glue_helper bnep btusb media bluetooth parport_pc hid_generic ppdev snd_hda_codec_hdmi drm_kms_helper snd_hda_codec_realtek cfg80211 drm tpm_infineon samsung_laptop snd_hda_intel usbhid snd_hda_codec hid snd_hwdep snd_pcm microcode snd_page_alloc snd_timer psmouse i2c_algo_bit lpc_ich tpm_tis video wmi mac_hid serio_raw ext2 lp parport r8169 mii [ 819.771802] CPU: 0 PID: 2167 Comm: bash Not tainted 3.12.0+ #25 [ 819.771876] Hardware name: SAMSUNG ELECTRONICS CO., LTD. 900X3C/900X3D/900X4C/900X4D/SAMSUNG_NP1234567890, BIOS P03AAC 07/12/2012 [ 819.772022] task: ffff88002e6ddcc0 ti: ffff8804015ca000 task.ti: ffff8804015ca000 [ 819.772119] RIP: 0010:[<ffffffff813381c0>] [<ffffffff813381c0>] skip_spaces+0x30/0x30 [ 819.772242] RSP: 0018:ffff8804015cbc70 EFLAGS: 00010046 [ 819.772310] RAX: 0000000000000003 RBX: ffff88040cfd6d40 RCX: 0000000000000018 [ 819.772397] RDX: 0000000000020001 RSI: 0000000000000000 RDI: 0000000000000000 [ 819.772484] RBP: ffff8804015cbcc0 R08: 0000000000000000 R09: ffff8803f0768d40 [ 819.772570] R10: ffffea001033b800 R11: 0000000000000000 R12: ffffffff81c519c0 [ 819.772656] R13: 0000000000020001 R14: 0000000000000000 R15: 0000000000020001 [ 819.772744] FS: 00007ff98309b740(0000) GS:ffff88041f200000(0000) knlGS:0000000000000000 [ 819.772845] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 [ 819.772917] CR2: 0000000000000000 CR3: 00000003f59dc000 CR4: 00000000001407f0 [ 819.773001] Stack: [ 819.773030] ffffffff81114003 ffff8804015cbcb0 0000000000000000 0000000000000046 [ 819.773146] ffff880409757a18 ffff8803f065a160 0000000000000000 0000000000020001 [ 819.773273] 0000000000000000 0000000000000000 ffff8804015cbce8 ffffffff8143e388 [ 819.773387] Call Trace: [ 819.773434] [<ffffffff81114003>] ? ftrace_raw_event_wakeup_source+0x43/0xe0 [ 819.773520] [<ffffffff8143e388>] wakeup_source_report_event+0xb8/0xd0 [ 819.773595] [<ffffffff8143e3cd>] __pm_stay_awake+0x2d/0x50 [ 819.773724] [<ffffffff8153395c>] power_supply_changed+0x3c/0x90 [ 819.773795] [<ffffffff8153407c>] power_supply_register+0x18c/0x250 [ 819.773869] [<ffffffff813d8d18>] sysfs_add_battery+0x61/0x7b [ 819.773935] [<ffffffff813d8d69>] battery_notify+0x37/0x3f [ 819.774001] [<ffffffff816ccb7c>] notifier_call_chain+0x4c/0x70 [ 819.774071] [<ffffffff81073ded>] __blocking_notifier_call_chain+0x4d/0x70 [ 819.774149] [<ffffffff81073e26>] blocking_notifier_call_chain+0x16/0x20 [ 819.774227] [<ffffffff8109397a>] pm_notifier_call_chain+0x1a/0x40 [ 819.774316] [<ffffffff81095b66>] hibernate+0x66/0x1c0 [ 819.774407] [<ffffffff81093931>] state_store+0x71/0xa0 [ 819.774507] [<ffffffff81331d8f>] kobj_attr_store+0xf/0x20 [ 819.774613] [<ffffffff811f8618>] sysfs_write_file+0x128/0x1c0 [ 819.774735] [<ffffffff8118579d>] vfs_write+0xbd/0x1e0 [ 819.774841] [<ffffffff811861d9>] SyS_write+0x49/0xa0 [ 819.774939] [<ffffffff816d1052>] system_call_fastpath+0x16/0x1b [ 819.775055] Code: 89 f8 48 89 e5 f6 82 c0 a6 84 81 20 74 15 0f 1f 44 00 00 48 83 c0 01 0f b6 10 f6 82 c0 a6 84 81 20 75 f0 5d c3 66 0f 1f 44 00 00 <80> 3f 00 55 48 89 e5 74 15 48 89 f8 0f 1f 40 00 48 83 c0 01 80 [ 819.775760] RIP [<ffffffff813381c0>] skip_spaces+0x30/0x30 [ 819.775881] RSP <ffff8804015cbc70> [ 819.775949] CR2: 0000000000000000 [ 819.794175] ---[ end trace c4ef25127039952e ]--- Signed-off-by: Shuah Khan <shuah.kh@samsung.com> Acked-by: Anton Vorontsov <anton@enomsg.org> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: stable@vger.kernel.org Signed-off-by: Anton Vorontsov <anton@enomsg.org>
2013-11-18Merge tag 'for-v3.13' of git://git.infradead.org/battery-2.6Linus Torvalds
Pull battery updates from Anton Vorontsov: "Highlights: - A new driver for TI BQ24735 Battery Chargers, courtesy of NVidia. - Device tree bindings for TWL4030 chips. - Random fixes and cleanups" * tag 'for-v3.13' of git://git.infradead.org/battery-2.6: pm2301-charger: Remove unneeded NULL checks twl4030_charger: Add devicetree support power_supply: Fix documentation for TEMP_*ALERT* properties max17042_battery: Support regmap to access device's registers max17042_battery: Use SIMPLE_DEV_PM_OPS charger-manager : Replace kzalloc to devm_kzalloc and remove uneccessary code bq2415x_charger: Fix max battery regulation voltage tps65090-charger: Use "IS_ENABLED(CONFIG_OF)" for DT code tps65090-charger: Drop devm_free_irq of devm_ allocated irq power_supply: Add support for bq24735 charger pm2301-charger: Staticize pm2xxx_charger_die_therm_mngt pm2301-charger: Check return value of regulator_enable ab8500-charger: Remove redundant break ab8500-charger: Check return value of regulator_enable isp1704_charger: Fix driver to work with changes introduced in v3.5
2013-11-15tree-wide: use reinit_completion instead of INIT_COMPLETIONWolfram Sang
Use this new function to make code more comprehensible, since we are reinitialzing the completion, not initializing. [akpm@linux-foundation.org: linux-next resyncs] Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Acked-by: Linus Walleij <linus.walleij@linaro.org> (personally at LCE13) Cc: Ingo Molnar <mingo@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-12pm2301-charger: Remove unneeded NULL checksDan Carpenter
If "pm2" were NULL we would oops printing the error message. Fortunately, that's not possible so I have removed the NULL checks. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Anton Vorontsov <anton@enomsg.org>
2013-11-12twl4030_charger: Add devicetree supportNeilBrown
This allows the charger to be enabled with devicetree, and allows the parameters for charging the backup battery to be set. Signed-off-by: NeilBrown <neilb@suse.de> Acked-by: Kumar Gala <galak@codeaurora.org> Acked-by: Grant Likely <grant.likely@linaro.org> Signed-off-by: Anton Vorontsov <anton@enomsg.org>
2013-10-25max17042_battery: Support regmap to access device's registersJonghwa Lee
This patch makes max17042 fuelguage driver uses regmap API to access its device's registers. Signed-off-by: Jonghwa Lee <jonghwa3.lee@samsung.com> Signed-off-by: Myungjoo Ham <myungjoo.ham@samsung.com> Signed-off-by: Anton Vorontsov <anton@enomsg.org>
2013-10-25max17042_battery: Use SIMPLE_DEV_PM_OPSManish Badarkhe
Use the SIMPLE_DEV_PM_OPS macro to declare the driver's pm_ops. Signed-off-by: Manish Badarkhe <badarkhe.manish@gmail.com> Signed-off-by: Anton Vorontsov <anton@enomsg.org>
2013-10-25charger-manager : Replace kzalloc to devm_kzalloc and remove uneccessary codeJonghwa Lee
Use devm function for dynamic memory allocation. Signed-off-by: Jonghwa Lee <jonghwa3.lee@samsung.com> Signed-off-by: Myungjoo Ham <myungjoo.ham@samsung.com> Signed-off-by: Anton Vorontsov <anton@enomsg.org>
2013-10-25bq2415x_charger: Fix max battery regulation voltageAlexandre Belloni
As per the datasheets, maximum battery regulation voltage is 4440mV. The formula is (voltage - offset) / step, so the maximum value is: (4440 - 3500) / 20 = 47 Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Thanks-to: Pali Rohár <pali.rohar@gmail.com> Signed-off-by: Anton Vorontsov <anton@enomsg.org>
2013-10-25tps65090-charger: Use "IS_ENABLED(CONFIG_OF)" for DT codeManish Badarkhe
Instead of "#if defined(CONFIG_OF)" use "IS_ENABLED(CONFIG_OF)" option for DT code to avoid if-deffery in code. Also, arranged header files in alphabetically. Signed-off-by: Manish Badarkhe <badarkhe.manish@gmail.com> Acked-by: Rhyland Klein <rklein@nvidia.com> Signed-off-by: Anton Vorontsov <anton@enomsg.org>
2013-10-25tps65090-charger: Drop devm_free_irq of devm_ allocated irqWei Yongjun
The devm_request_irq function allocates irq that is released when a driver detaches. Thus, there is no reason to explicitly call devm_free_irq in probe or remove functions. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: Anton Vorontsov <anton@enomsg.org>
2013-10-25power_supply: Add support for bq24735 chargerDarbha Sriharsha
Adds support for the bq24735 charger chipset. The bq24735 is a high-efficiency, synchronous battery charger. It allows control of the charging current, input current, and the charger voltage DAC's through SMBus. Signed-off-by: Darbha Sriharsha <dsriharsha@nvidia.com> Signed-off-by: Rhyland Klein <rklein@nvidia.com> Thanks-to: Stephen Warren <swarren@wwwdotorg.org> Thanks-to: Thierry Reding <thierry.reding@gmail.com> Thanks-to: Manish Badarkhe <badarkhe.manish@gmail.com> Signed-off-by: Anton Vorontsov <anton@enomsg.org>
2013-10-25pm2301-charger: Staticize pm2xxx_charger_die_therm_mngtSachin Kamat
pm2xxx_charger_die_therm_mngt is used only in this file. Make it static. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Acked-by: Lee Jones <lee.jones@linaro.org> Signed-off-by: Anton Vorontsov <anton@enomsg.org>
2013-10-25pm2301-charger: Check return value of regulator_enableSachin Kamat
Check the return value of regulator_enable to silence the following warning: drivers/power/pm2301_charger.c:725:20: warning: ignoring return value of ‘regulator_enable’, declared with attribute warn_unused_result [-Wunused-result] Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Acked-by: Lee Jones <lee.jones@linaro.org> Signed-off-by: Anton Vorontsov <anton@enomsg.org>
2013-10-25ab8500-charger: Remove redundant breakSachin Kamat
Each of the if-else blocks has a break statement. Remove the additional one which is unreachable. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Acked-by: Lee Jones <lee.jones@linaro.org> Signed-off-by: Anton Vorontsov <anton@enomsg.org>
2013-10-25ab8500-charger: Check return value of regulator_enableSachin Kamat
Check the return value of regulator_enable to silence the following type of warnings: drivers/power/ab8500_charger.c:1390:20: warning: ignoring return value of ‘regulator_enable’, declared with attribute warn_unused_result [-Wunused-result] Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Acked-by: Lee Jones <lee.jones@linaro.org> Signed-off-by: Anton Vorontsov <anton@enomsg.org>
2013-10-22isp1704_charger: Fix driver to work with changes introduced in v3.5Pali Rohár
* omap musb driver does not report USB_EVENT_ENUMERATED event anymore * omap musb driver reporting USB_EVENT_VBUS when charger is connected * read last event from phy->last_event (instead from ulpi register) * do not call wall charger detection more times Signed-off-by: Pali Rohár <pali.rohar@gmail.com> Signed-off-by: Anton Vorontsov <anton@enomsg.org>
2013-09-13Remove GENERIC_HARDIRQ config optionMartin Schwidefsky
After the last architecture switched to generic hard irqs the config options HAVE_GENERIC_HARDIRQS & GENERIC_HARDIRQS and the related code for !CONFIG_GENERIC_HARDIRQS can be removed. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-09-10Merge tag 'for-v3.12' of git://git.infradead.org/battery-2.6Linus Torvalds
Pull battery/power supply driver updates from Anton Vorontsov: "New drivers: - APM X-Gene system reboot driver by Feng Kan and Loc Ho (APM). - Qualcomm MSM reboot/poweroff driver by Abhimanyu Kapur (Codeaurora). - Texas Instruments BQ24190 charger driver by Mark A. Greer (Animal Creek Technologies). - Texas Instruments TWL4030 MADC battery driver by Lukas Märdian and Marek Belisko (Golden Delicious Computers). The driver is used on Freerunner GTA04 phones. Highlighted fixes and improvements: - Suspend/wakeup logic improvements: power supply objects will block system suspend until all power supply events are processed. Thanks to Zoran Markovic (Linaro), Arve Hjonnevag and Todd Poynor (Google)" * tag 'for-v3.12' of git://git.infradead.org/battery-2.6: rx51_battery: Fix channel number when reading adc value power: Add twl4030_madc battery driver. bq24190_charger: Workaround SS definition problem on i386 builds power_supply: Prevent suspend until power supply events are processed vexpress-poweroff: Should depend on the required infrastructure twl4030-charger: Fix compiler warning with regulator_enable() rx51_battery: Replace hardcoded channels values. bq24190_charger: Add support for TI BQ24190 Battery Charger ab8500-charger: We print an unintended error message max8925_power: Fix missing of_node_put power_supply: Replace strict_strtol() with kstrtol() power: Add APM X-Gene system reboot driver power_supply: tosa_battery: Get rid of irq_to_gpio usage power supply: collie_battery: Convert to use dev_pm_ops power_supply: Make goldfish_battery depend on GOLDFISH || COMPILE_TEST power: reset: Add msm restart support MAINTAINERS: drivers/power: add entry for SmartReflex AVS drivers
2013-08-30rx51_battery: Fix channel number when reading adc valueMarek Belisko
This issue was introduced in commit 8e2747f031bd "power: rx51_battery: Replace hardcoded channels values." Original code use channel as argument which was shifted by one in function. After mentioned commit argument is already shifted so we need to get index back. Signed-off-by: Marek Belisko <marek.belisko@open-nandra.com> Signed-off-by: Anton Vorontsov <anton@enomsg.org>
2013-08-30power: Add twl4030_madc battery driver.Marek Belisko
This driver is used and tested on gta04 phone. It's using twl4030_madc (similar to rx51 existing driver). Driver also implement charging and discharging calibration data so user can define ranges and level. Signed-off-by: Marek Belisko <marek@goldelico.com> Signed-off-by: Lukas Märdian <lukas@goldelico.com> Signed-off-by: Anton Vorontsov <anton@enomsg.org>
2013-08-28bq24190_charger: Workaround SS definition problem on i386 buildsAnton Vorontsov
For __i386__ builds we have: arch/x86/include/uapi/asm/ptrace-abi.h:#define SS 16 And in the driver: BQ24190_SYSFS_FIELD_RO(vbus_stat, SS, VBUS_STAT) That breaks the build like this: drivers/power/bq24190_charger.c:375:138: error: ‘BQ24190_REG_16’ undeclared here (not in a function) drivers/power/bq24190_charger.c:375:162: error: ‘BQ24190_REG_16_THERM_STAT_MASK’ undeclared here (not in a function) drivers/power/bq24190_charger.c:375:203: error: ‘BQ24190_REG_16_THERM_STAT_SHIFT’ undeclared here (not in a function) With this commit we workaround the problem by undefining 'SS'. Reported-by: kbuild test robot <fengguang.wu@intel.com> Signed-off-by: Anton Vorontsov <anton@enomsg.org>
2013-08-27power_supply: Prevent suspend until power supply events are processedZoran Markovic
This patch, originally authored by Arve Hjonnevag and Todd Poynor, prevents the system from entering suspend mode until the power supply plug, unplug, or any other change of state event is fully processed. This guarantees that the screen lights up and displays the battery charging state. The implementation uses the power supply wakeup_source object. Cc: David Woodhouse <dwmw2@infradead.org> Cc: Arve Hjonnevag <arve@android.com> Cc: Todd Poynor <toddpoynor@google.com> Cc: John Stultz <john.stultz@linaro.org> Signed-off-by: Zoran Markovic <zoran.markovic@linaro.org> Signed-off-by: Anton Vorontsov <anton@enomsg.org>
2013-08-27vexpress-poweroff: Should depend on the required infrastructurePawel Moll
ARM Versatile Express reset driver requires platform-specific config infrastructure to be present in the kernel. When VEXPRESS_CONFIG is not selected, the build will fail like this: drivers/built-in.o: In function `vexpress_reset_do.clone.0': iio-trig-interrupt.c:(.text+0x1aff38): undefined reference to `__vexpress_config_func_get' iio-trig-interrupt.c:(.text+0x1aff4c): undefined reference to `vexpress_config_write' Added required dependency to the Kconfig entry. Signed-off-by: Pawel Moll <pawel.moll@arm.com> Signed-off-by: Anton Vorontsov <anton@enomsg.org>
2013-08-27twl4030-charger: Fix compiler warning with regulator_enable()Peter Ujfalusi
The return value of regulator_enable need to be checked. This patch fixes the following warning: drivers/power/twl4030_charger.c: In function ‘twl4030_charger_enable_usb’: drivers/power/twl4030_charger.c:192:20: warning: ignoring return value of ‘regulator_enable’, declared with attribute warn_unused_result [-Wunused-result] Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Anton Vorontsov <anton@enomsg.org>
2013-08-27rx51_battery: Replace hardcoded channels values.Marek Belisko
In twl4030_madc header exist defines for fixed channels + add rx51 specific channels and replace all hardcoded channels values. Signed-off-by: Marek Belisko <marek.belisko@open-nandra.com> Signed-off-by: Anton Vorontsov <anton@enomsg.org>
2013-08-27bq24190_charger: Add support for TI BQ24190 Battery ChargerMark A. Greer
Add driver support for the Texas Instruments BQ24190 battery charger. Some of the information provided by the device is about the charger and other information is about the battery so create two power_supply objects (one for each) and provide the appropriate information for each one. The device has many fields that go beyond what is reasonable to report or modify using the existing 'POWER_SUPPLY_PROP_*' properties so the driver exports the register fields via sysfs. They are prefixed by 'f_' (for 'field') to make it easier to distinguish between a register field and a "normal" sysfs file exported by the power_supply infrastructure. Signed-off-by: Mark A. Greer <mgreer@animalcreek.com> Signed-off-by: Anton Vorontsov <anton@enomsg.org>
2013-08-27ab8500-charger: We print an unintended error messageDan Carpenter
There is a missing break statement here, so we print an error message that the USB type is invalid. The original code still works fine though except for the error message. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Anton Vorontsov <anton@enomsg.org>
2013-08-27max8925_power: Fix missing of_node_putLibo Chen
Decrease np device_node refcount after we are done with the node. Signed-off-by: Libo Chen <libo.chen@huawei.com> Signed-off-by: Anton Vorontsov <anton@enomsg.org>
2013-08-20treewide: Fix typo in printkMasanari Iida
Correct spelling typo in printk Signed-off-by: Masanari Iida <standby24x7@gmail.com> Acked-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-08-09power_supply: Replace strict_strtol() with kstrtol()Jingoo Han
The usage of strict_strtol() is not preferred, because strict_strtol() is obsolete. Thus, kstrtol() should be used. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Anton Vorontsov <anton@enomsg.org>
